Hi, I used two 51822 modules for my project. One should send a byte and other one should receive. I used the exact same configurations of radio examples (transmitter and received). But it didn't work. Radio configuration is as below: // Radio config NRF_RADIO->TXPOWER = (RADIO_TXPOWER_TXPOWER_0dBm << RADIO_TXPOWER_TXPOWER_Pos); NRF_RADIO->FREQUENCY = 7UL; // Frequency bin 7, 2407MHz NRF_RADIO->MODE = (RADIO_MODE_MODE_Nrf_1Mbit << RADIO_MODE_MODE_Pos);
// Radio address config
NRF_RADIO->PREFIX0 =
((uint32_t)swap_bits(0xC3) << 24) // Prefix byte of address 3 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC2) << 16) // Prefix byte of address 2 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC1) << 8) // Prefix byte of address 1 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC0) << 0); // Prefix byte of address 0 converted to nRF24L series format
NRF_RADIO->PREFIX1 =
((uint32_t)swap_bits(0xC7) << 24) // Prefix byte of address 7 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC6) << 16) // Prefix byte of address 6 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC4) << 0); // Prefix byte of address 4 converted to nRF24L series format
NRF_RADIO->BASE0 = bytewise_bitswap(0x01234567UL); // Base address for prefix 0 converted to nRF24L series format
NRF_RADIO->BASE1 = bytewise_bitswap(0x89ABCDEFUL); // Base address for prefix 1-7 converted to nRF24L series format
NRF_RADIO->TXADDRESS = 0x00UL; // Set device address 0 to use when transmitting
NRF_RADIO->RXADDRESSES = 0x01UL; // Enable device address 0 to use to select which addresses to receive
// Packet configuration
NRF_RADIO->PCNF0 = (PACKET_S1_FIELD_SIZE << RADIO_PCNF0_S1LEN_Pos) |
(PACKET_S0_FIELD_SIZE << RADIO_PCNF0_S0LEN_Pos) |
(PACKET_LENGTH_FIELD_SIZE << RADIO_PCNF0_LFLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
NRF_RADIO->PCNF1 = (RADIO_PCNF1_WHITEEN_Disabled << RADIO_PCNF1_WHITEEN_Pos) |
(RADIO_PCNF1_ENDIAN_Big << RADIO_PCNF1_ENDIAN_Pos) |
(PACKET_BASE_ADDRESS_LENGTH << RADIO_PCNF1_BALEN_Pos) |
(PACKET_STATIC_LENGTH << RADIO_PCNF1_STATLEN_Pos) |
(PACKET_PAYLOAD_MAXSIZE << RADIO_PCNF1_MAXLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
// CRC Config
NRF_RADIO->CRCCNF = (RADIO_CRCCNF_LEN_One << RADIO_CRCCNF_LEN_Pos); // Number of checksum bits
if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_Two << RADIO_CRCCNF_LEN_Pos))
NRF_RADIO->CRCINIT = 0xFFFFUL; // Initial value
NRF_RADIO->CRCPOLY = 0x11021UL; // CRC poly: x^16+x^12^x^5+1
else if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_One << RADIO_CRCCNF_LEN_Pos))
NRF_RADIO->CRCINIT = 0xFFUL; // Initial value
NRF_RADIO->CRCPOLY = 0x107UL; // CRC poly: x^8+x^2^x^1+1
After debugging, I understood that transmission works file (or at least I think!) but in receiving, the program stock in a white for END task. In blow, read_packet function is brought: NRF_RADIO->EVENTS_READY = 0U; // Enable radio and wait for ready NRF_RADIO->TASKS_RXEN = 1U;
while (NRF_RADIO->EVENTS_READY == 0U)
cnt1++;
// wait
NRF_RADIO->EVENTS_END = 0U;
// Start listening and wait for address received event
NRF_RADIO->TASKS_START = 1U;
// Wait for end of packet or buttons state changed
while ((NRF_RADIO->EVENTS_END == 0U) && (cnt2 < 30000))
cnt2++;
// wait
if (NRF_RADIO->CRCSTATUS == 1U)
result = packet;
nrf_gpio_pin_toggle(18);
nrf_gpio_pin_toggle(19);
nrf_gpio_pin_toggle(20);
nrf_gpio_pin_toggle(21);
nrf_gpio_pin_toggle(22);
NRF_RADIO->EVENTS_DISABLED = 0U;
// Disable radio
NRF_RADIO->TASKS_DISABLE = 1U;
while (NRF_RADIO->EVENTS_DISABLED == 0U)
cnt3++;
// wait
I appreciate if anyone can help me
