SPIM
Hi everyone,
I am trying to use SPIM for an external DAC. The DAC does not require MISO, only SCK, MOSI, and CS.
I configured SPIM like this:
#define SPI_DAC NRF_SPIM2
SPI_DAC->ENABLE = SPIM_ENABLE_ENABLE_Enabled;
SPI_DAC->FREQUENCY = SPIM_FREQUENCY_FREQUENCY_M8 << SPIM_FREQUENCY_FREQUENCY_Pos;
SPI_DAC->PSEL.CSN = NRF_SPIM_PIN_NOT_CONNECTED;
SPI_DAC->PSEL.SCK = NRF_GPIO_PIN_MAP(0, 29);
SPI_DAC->PSEL.MOSI = NRF_GPIO_PIN_MAP(1, 10);
SPI_DAC->PSEL.MISO = NRF_SPIM_PIN_NOT_CONNECTED;
SPI_DAC->TXD.LIST = 0;
SPI_DAC->RXD.LIST = 0;
SPI_DAC->TXD.PTR = (uint32_t)&dac_tx_buf;
SPI_DAC->TXD.MAXCNT = 2;
SPI_DAC->RXD.PTR = (uint32_t)&dac_rx_dummy;
SPI_DAC->RXD.MAXCNT = 2;
SPI_DAC->CONFIG =
    (SPIM_CONFIG_ORDER_MsbFirst << SPIM_CONFIG_ORDER_Pos) |
    (SPIM_CONFIG_CPOL_ActiveHigh << SPIM_CONFIG_CPOL_Pos) |
    (SPIM_CONFIG_CPHA_Leading << SPIM_CONFIG_CPHA_Pos); // Mode 0
Then I try to start the transfer like this:
SPI_DAC->EVENTS_END = 0;
SPI_DAC->TASKS_START = 1;
while (!SPI_DAC->EVENTS_END) {
    LOG_DBG("in while");
    k_sleep(K_SECONDS(5));
The problem is that the code stays forever in this while loop, meaning EVENTS_END is never set.
I checked the signals with a logic analyzer. The CS pin goes low, but SCLK and MOSI do not toggle. They just stay in their idle states.
Does anyone know what could prevent SPIM from actually starting the transfer in this case?
    Did you delete your previous message about solving the issue? I will look for it now.
  • Yea i did. But now i saw what the problem is. On nrf5340 CSN is not supported, only for SPIM4 on dedicated pin.
    You need to configure CSN pin as output in the GPIO peripheral with intial value high before enabling SPIM. source:SPIM — Serial peripheral interface master with EasyDMA
    The key points here is to configure GPIO before SPIM is enabled and to set PSEL registers while SPIM is disabled. So , your approach is correct now.
    For example something like below code (based on your code in first thread)
    // 1. Make sure SPIM is disabled first
    SPI_DAC->ENABLE = SPIM_ENABLE_ENABLE_Disabled;
    // 2. Configure GPIO pins BEFORE enabling SPIM
    // SCK - output, initial value same as CPOL (0 for Mode 0)
    nrf_gpio_pin_clear(NRF_GPIO_PIN_MAP(0, 29));
    nrf_gpio_cfg_output(NRF_GPIO_PIN_MAP(0, 29));
    // MOSI - output, initial value 0
    nrf_gpio_pin_clear(NRF_GPIO_PIN_MAP(1, 10));
    nrf_gpio_cfg_output(NRF_GPIO_PIN_MAP(1, 10));
    // CSN - output, initial value 1 (deasserted/high)
    nrf_gpio_pin_set(CSPIN);
    nrf_gpio_cfg_output(CSPIN);
    // 3. Configure PSEL registers while SPIM is still disabled
    SPI_DAC->PSEL.CSN  = CSPIN;  // SPIM will now control CS automatically
    // 4. Configure frequency and SPI mode
    SPI_DAC->CONFIG =
    // 5. Set up DMA buffers
    SPI_DAC->RXD.PTR    = 0;
    SPI_DAC->RXD.MAXCNT = 0;  // No RX needed for DAC
    // 6. Enable SPIM
    // 7. Start transfer - SPIM will automatically:
    //    - Pull CSN low
    //    - Clock out data on MOSI
    //    - Pull CSN high when done
    while (!SPI_DAC->EVENTS_END) { /* wait */ }
  • Yes u are right but only for SPIM4 or this is wrong?
  • Can you please explain what did you mean here?
    SPIM4 is the only instance supporting up to 32 Mbps, but this is not directly related to the EVENTS_END never being set issue. have you tried the example code I showed before?
