WiFi does not reconnect after net_if_down / net_if_up cycle
Description
I'm working on a battery-powered application where WiFi needs to be shut down between cloud sync intervals. I'm following the same pattern as the wifi/shutdown sample (calling net_if_down() to power off the nRF7002 and net_if_up() to bring it back). After wakeup, WiFi was never reconnecting (no supplicant association logged, NET_EVENT_L4_CONNECTED never fires). I also see an Unbalanced suspend warning during shutdown and high current (~30–40 mA) when the interface is supposed to be off.
[00:00:59.511] pm_device: Unbalanced suspend
[00:00:59.512] wifi_supplicant: Network interface 1 down
[00:00:59.525] queva_connection_manager: Network disconnected
I'm also using the BLE WiFi provisioning service in the firmware.
Issue 1: WiFi never reconnects after net_if_up()
Root cause: After net_if_up(), the supplicant re-adds the interface via add_interface(), but this runs asynchronously on the supplicant's internal iface_wq work queue. My original code called NET_REQUEST_WIFI_CONNECT_STORED immediately after net_if_up(). It returned 0 but the connection never completed, because the supplicant wasn't ready yet and silently dropped the request.
Relying on L2_WIFI_CONNECTIVITY_AUTO_CONNECT alone doesn't help either. conn_mgr fires conn_mgr_if_connect on NET_EVENT_IF_ADMIN_UP, which also races with add_interface() and gets dropped for the same reason.
Fix: Enable CONFIG_WIFI_READY_LIB=y and register a wifi_ready_callback. When the callback fires with wifi_ready=true (NET_EVENT_SUPPLICANT_READY received, meaning add_interface() has fully completed), submit a work item that calls NET_REQUEST_WIFI_CONNECT_STORED. This is the correct point to trigger reconnection.
static void wifi_reconnect_work_fn(struct k_work *work)
    struct net_if *iface = net_if_get_first_wifi();
    int err = net_mgmt(NET_REQUEST_WIFI_CONNECT_STORED, iface, NULL, 0);
    if (err && err != -EALREADY) {
        LOG_WRN("Wi-Fi connect stored failed: %d", err);
static K_WORK_DEFINE(wifi_reconnect_work, wifi_reconnect_work_fn);
static void wifi_ready_cb(bool wifi_ready)
    if (wifi_ready) {
        app_work_submit(&wifi_reconnect_work);
After this fix, the reconnection sequence looks like:
[00:08:14.861] Bringing WiFi back up
[00:08:15.114] wifi_supplicant: Network interface 1 up
[00:08:15.183] Wi-Fi supplicant ready          ← wifi_ready_cb fires here
[00:08:20.320] Network connected               ← L4 up ~5s later
[00:08:23.321] Connecting to Azure IoT Hub
[00:08:27.407] AZURE_IOT_HUB_EVT_READY         ← connected ~7s after net_if_up
Issue 2: pm_device Unbalanced suspend warning
Every call to net_if_down() produces this warning. After investigation I traced it to a trailing pm_device_runtime_put_async() call inside finalize_spi_transaction() in spi_nrfx_spim.c, which fires from the DMA completion ISR after net_if_down() has already driven the SPI PM usage count to zero. The PM runtime returns -EALREADY and takes no action.
I tried removing zephyr,pm-device-runtime-auto from both &spi4 and the nrf7002@0 child node in the board DTS (based on the suggestion that the nRF Wi-Fi driver manages the SPI bus power state internally), but the warning persists. This confirms it originates inside the nRF Wi-Fi driver itself, not from our PM configuration.
Remaining questions
  1. Is net_if_down() / net_if_up() the confirmed correct API for periodic WiFi power cycling on nRF7002, or is there a preferred alternative?
  2. Is NET_EVENT_SUPPLICANT_READY (via wifi_ready_callback) the right signal to wait for before issuing NET_REQUEST_WIFI_CONNECT_STORED after net_if_up()? Or should we be waiting for a different event?
  3. Can you confirm whether zephyr,pm-device-runtime-auto should or should not be set on the SPI node used by nRF7002? And is the Unbalanced suspend warning on net_if_down() expected/known behavior?
  • Hello Michael,
    Apologies for the delay in response.
    Yes, net_if_down() / net_if_up are the right APIs for the network interface to be turned on and off and this also affects the power states active and shutdown.
    This also seems correct to me as you must make sure that the supplicant is ready first before the Wi-Fi management requests are called.
    I don't think the unbalanced suspend warning is a common/expected issue on net_if_down(). The "unbalanced suspend" warning is a result of pm_device_runtime_put or pm_device_runtime_put_async() being called more than pm_device_runtime_get(). This leads to an already suspended device to be suspended and an -EALREADY error is given.
    I have talked with a colleague to confirm about your question about zephyr,pm-device-runtime-auto. If you want to set runtime power management for specific devices, then it should still be possible to use. In order to set device runtime power management, you can use CONFIG_PM_DEVICE_RUNTIME. You can take a look at the following documentation: Device Runtime Power Management.
    Best Regards,
    Samruddhi
