I have init spi4- for
Complete hardware is fine, Yet SPI communication is not happening, Am I missing something? I did nothing extra than this.
Hi Shubham,
Please share the following:
Benjamin
Hi Benjamin,
1. Application log-
PIN13 ON RET=0
PIN14 ON RET=0
PIN15 ON RET=0
LED ON RAW = 0x0000
PIN13 OFF RET=0
PIN14 OFF RET=0
PIN15 OFF RET=0
LED OFF RAW = 0x0000
PIN13 ON RET=0
PIN14 ON RET=0
PIN15 ON RET=0
LED ON RAW = 0x0000
PIN13 OFF RET=0
PIN14 OFF RET=0
PIN15 OFF RET=0
PIN13 ON RET=0
PIN14 ON RET=0
PIN15 ON RET=0
LED ON RAW = 0x0000
PIN13 OFF RET=0
PIN14 OFF RET=0
PIN15 OFF RET=0
PIN13 ON RET=0
PIN14 ON RET=0
PIN15 ON RET=0
1385.config
0880.zephyr.dts
Building spicheck
west build --build-dir c:/ncs/RTUD/spicheck/build c:/ncs/RTUD/spicheck
[0/1] Re-running CMake...
Loading Zephyr default modules (Zephyr base (cached)).
-- Application: C:/ncs/RTUD/spicheck
-- CMake version: 3.21.0
-- Cache files will be written to: C:/ncs/v3.2.4/zephyr/.cache
-- Zephyr version: 4.2.99 (C:/ncs/v3.2.4/zephyr)
-- Found west (found suitable version "1.4.0", minimum required is "0.14.0")
-- Board: rtud, qualifiers: nrf5340/cpuapp
-- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/fd21892d0f/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/fd21892d0f/opt/zephyr-sdk)
-- Found BOARD.dts: C:/ncs/RTUD/spicheck/boards/rtud/rtud_nrf5340_cpuapp.dts
-- Found devicetree overlay: C:/ncs/RTUD/spicheck/boards/rtud_nrf5340_cpuapp.overlay
-- Generated zephyr.dts: C:/ncs/RTUD/spicheck/build/spicheck/zephyr/zephyr.dts
-- Generated pickled edt: C:/ncs/RTUD/spicheck/build/spicheck/zephyr/edt.pickle
-- Generated devicetree_generated.h: C:/ncs/RTUD/spicheck/build/spicheck/zephyr/include/generated/zephyr/devicetree_generated.h
Parsing C:/ncs/v3.2.4/zephyr/Kconfig
Loaded configuration 'C:/ncs/RTUD/spicheck/build/spicheck/zephyr/.config'
Merged configuration 'C:/ncs/RTUD/spicheck/build/spicheck/zephyr/.config.sysbuild'
No change to configuration in 'C:/ncs/RTUD/spicheck/build/spicheck/zephyr/.config'
No change to Kconfig header in 'C:/ncs/RTUD/spicheck/build/spicheck/zephyr/include/generated/zephyr/autoconf.h'
-- Found gen_kobject_list: C:/ncs/v3.2.4/zephyr/scripts/build/gen_kobject_list.py
-- Configuring done
-- Generating done
-- Build files have been written to: C:/ncs/RTUD/spicheck/build/spicheck
[4/155] Building C object CMakeFiles/app.dir/src/main.c.obj
C:/ncs/RTUD/spicheck/src/main.c:26:36: warning: missing braces around initializer [-Wmissing-braces]
26 | static struct spi_config spi_cfg = {
[155/155] Linking C executable zephyr\zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 46168 B 1 MB 4.40%
RAM: 11568 B 448 KB 2.52%
IDT_LIST: 0 GB 32 KB 0.00%
Generating files from C:/ncs/RTUD/spicheck/build/spicheck/zephyr/zephyr.elf for board: rtud
[5/5] Generating ../merged.hex
* Terminal will be reused by tasks, press any key to close it.
* Executing task: nRF Connect: Build [incremental]: spicheck/build
Failed to determine build parameters
* Executing task: nRF Connect: Generate config rtud/nrf5340/cpuapp for c:\ncs\RTUD\spicheck
Building spicheck
west build --build-dir c:/ncs/RTUD/spicheck/build c:/ncs/RTUD/spicheck --pristine --board rtud/nrf5340/cpuapp -- -DCONFIG_DEBUG_THREAD_INFO=y -DBOARD_ROOT="c:/ncs/rtud/spicheck"
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: C:/ncs/toolchains/fd21892d0f/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
Parsing C:/ncs/v3.2.4/zephyr/share/sysbuild/Kconfig
Loaded configuration 'C:/ncs/RTUD/spicheck/build/_sysbuild/empty.conf'
Merged configuration 'C:/ncs/RTUD/spicheck/build/_sysbuild/empty.conf'
Configuration saved to 'C:/ncs/RTUD/spicheck/build/zephyr/.config'
Kconfig header saved to 'C:/ncs/RTUD/spicheck/build/_sysbuild/autoconf.h'
* Running CMake for spicheck *
-- Found Dtc: C:/ncs/toolchains/fd21892d0f/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
Loaded configuration 'C:/ncs/RTUD/spicheck/boards/rtud/rtud_nrf5340_cpuapp_defconfig'
Merged configuration 'C:/ncs/RTUD/spicheck/prj.conf'
Merged configuration 'C:/ncs/RTUD/spicheck/build/spicheck/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/ncs/RTUD/spicheck/build/spicheck/zephyr/.config'
Kconfig header saved to 'C:/ncs/RTUD/spicheck/build/spicheck/zephyr/include/generated/zephyr/autoconf.h'
-- Found GnuLd: c:/ncs/toolchains/fd21892d0f/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/fd21892d0f/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
[4/181] Generating include/generated/zephyr/version.h
-- Zephyr version: 4.2.99 (C:/ncs/v3.2.4/zephyr), build: ncs-v3.2.4
[5/181] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[6/181] Generating include/generated/device-api-sections.ld, include/generated/device-api-sections.cmake
[7/181] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, include/generated/zephyr/syscall_list.h
[8/181] Generating include/generated/zephyr/driver-validation.h
[9/181] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-size.h
[10/181] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[11/181] Generating include/generated/zephyr/offsets.h
[12/181] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.S.obj
[13/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[14/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj
[15/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[16/181] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fpu.c.obj
[17/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread_monitor.c.obj
[18/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[19/181] Building C object CMakeFiles/app.dir/src/main.c.obj
[20/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[21/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/libc/validate_libc.c.obj
[22/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[23/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[24/181] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault.c.obj
[25/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/clock.c.obj
[26/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[27/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/dec.c.obj
[28/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/heap/heap.c.obj
[29/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[30/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/hex.c.obj
[31/181] Linking C static library app\libapp.a
[32/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[33/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/timeutil.c.obj
[34/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitmask.c.obj
[35/181] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[36/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
[37/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/rb.c.obj
[38/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/last_section_id.c.obj
[39/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/onoff.c.obj
[40/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitarray.c.obj
[41/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/notify.c.obj
[42/181] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/ring_buffer.c.obj
[43/181] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/debug/thread_info.c.obj
[44/181] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_cache.c.obj
[45/181] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.2.4/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[46/181] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/mem_mgmt/mem_attr.c.obj
[47/181] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj
[48/181] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_mgmt.c.obj
[49/181] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj
[50/181] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj
[51/181] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/backends/log_backend_rtt.c.obj
[52/181] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[53/181] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.2.4/nrfxlib/crypto/nrf_cc312_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[54/181] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.obj
[55/181] Building ASM object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi_on_reset.S.obj
[56/181] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.2.4/nrfxlib/crypto/nrf_cc312_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
[57/181] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/scb.c.obj
[58/181] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v3.2.4/nrf/lib/boot_banner/banner.c.obj
[59/181] Generating linker_zephyr_pre0.cmd
[60/181] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread_abort.c.obj
[61/181] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[62/181] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[63/181] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/tls.c.obj
[64/181] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c.obj
[65/181] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/init.c.obj
[66/181] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/xip.c.obj
[67/181] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[68/181] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/vector_table.S.obj
[69/181] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/__aeabi_read_tp.S.obj
[70/181] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/swap_helper.S.obj
[71/181] Linking C static library zephyr\libzephyr.a
[72/181] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi.c.obj
[73/181] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/fatal.c.obj
[74/181] Linking C static library zephyr\arch\common\libisr_tables.a
[75/181] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/prep_c.c.obj
[76/181] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_manage.c.obj
[77/181] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/isr_wrapper.c.obj
[78/181] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_init.c.obj
[79/181] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_idle.c.obj
[80/181] Linking C static library zephyr\arch\arch\arm\core\libarch__arm__core.a
[81/181] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread.c.obj
[82/181] Building C object zephyr/arch/arch/arm/core/cortex_m/cmse/CMakeFiles/arch__arm__core__cortex_m__cmse.dir/arm_core_cmse.c.obj
[83/181] Linking C static library zephyr\arch\common\libarch__common.a
[84/181] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/assert.c.obj
[85/181] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu_regions.c.obj
[86/181] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_core_mpu.c.obj
[87/181] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu.c.obj
[88/181] Linking C static library zephyr\arch\arch\arm\core\cortex_m\cmse\libarch__arm__core__cortex_m__cmse.a
[89/181] Linking C static library zephyr\arch\arch\arm\core\cortex_m\libarch__arm__core__cortex_m.a
[90/181] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/errno_wrap.c.obj
[91/181] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/exit.c.obj
[92/181] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/locks.c.obj
[93/181] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/cbprintf.c.obj
[94/181] Linking C static library zephyr\arch\arch\arm\core\mpu\libarch__arm__core__mpu.a
[95/181] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/time/time.c.obj
[96/181] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/chk_fail.c.obj
[97/181] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abort.c.obj
[98/181] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/stdio.c.obj
[99/181] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj
[100/181] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_base_addresses.c.obj
[101/181] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/common/reboot.c.obj
[102/181] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/common/gppi_init.c.obj
[103/181] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_binding_headers.c.obj
[104/181] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_enabled_instances.c.obj
[105/181] Linking C static library zephyr\lib\libc\common\liblib__libc__common.a
[106/181] Linking C static library zephyr\lib\libc\picolibc\liblib__libc__picolibc.a
[107/181] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/nrf53/soc.c.obj
[108/181] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/nrf53/nrf53_cpunet_mgmt.c.obj
[109/181] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/rtt_console.c.obj
[110/181] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[111/181] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[112/181] Building C object zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/common/gpiote_nrfx.c.obj
[113/181] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_mcp23sxx.c.obj
[114/181] Linking C static library zephyr\drivers\console\libdrivers__console.a
[115/181] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[116/181] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[117/181] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[118/181] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_mcp23xxx.c.obj
[119/181] Linking C static library zephyr\soc\soc\nrf5340\libsoc__nordic.a
[120/181] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[121/181] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[122/181] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
[123/181] Building C object modules/nrf/drivers/hw_cc3xx/CMakeFiles/..__nrf__drivers__hw_cc3xx.dir/hw_cc3xx.c.obj
[124/181] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_common.c.obj
[125/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeslicing.c.obj
[126/181] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
[127/181] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
[128/181] Linking C static library modules\nrf\drivers\hw_cc3xx\lib..__nrf__drivers__hw_cc3xx.a
[129/181] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
[130/181] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v3.2.4/modules/hal/nordic/nrfx/bsp/stable/mdk/system_nrf5340_application.c.obj
[131/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
[132/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipe.c.obj
[133/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[134/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
[135/181] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[136/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[137/181] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v3.2.4/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[138/181] Linking C static library zephyr\drivers\spi\libdrivers__spi.a
[139/181] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v3.2.4/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
[140/181] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v3.2.4/modules/hal/nordic/nrfx/drivers/src/nrfx_clock_hfclk.c.obj
[141/181] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v3.2.4/modules/hal/nordic/nrfx/drivers/src/nrfx_clock_lfclk.c.obj
[142/181] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v3.2.4/modules/hal/nordic/nrfx/drivers/src/nrfx_clock_hfclkaudio.c.obj
[143/181] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v3.2.4/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[144/181] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v3.2.4/modules/hal/nordic/nrfx/drivers/src/nrfx_clock_hfclk192m.c.obj
[145/181] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v3.2.4/modules/hal/nordic/nrfx/helpers/nrfx_gppi_dppi.c.obj
[146/181] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v3.2.4/modules/hal/nordic/nrfx/drivers/src/nrfx_clock_xo24m.c.obj
[147/181] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v3.2.4/modules/hal/nordic/nrfx/drivers/src/nrfx_clock_xo.c.obj
[148/181] Building C object modules/segger/CMakeFiles/modules__segger.dir/C_/ncs/v3.2.4/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
[149/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[150/181] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
[151/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[152/181] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v3.2.4/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj
[153/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
[154/181] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[155/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[156/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[157/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[158/181] Linking C static library modules\segger\libmodules__segger.a
[159/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[160/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[161/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[162/181] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[163/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/float.c.obj
[164/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[165/181] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v3.2.4/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[166/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
[167/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
[168/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
[169/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
[170/181] Linking C static library modules\hal_nordic\modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[171/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
[172/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
[173/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
[174/181] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
[175/181] Linking C static library zephyr\kernel\libkernel.a
[176/181] Linking C executable zephyr\zephyr_pre0.elf
[177/181] Generating linker.cmd
[178/181] Generating isr_tables.c, isr_tables_vt.ld, isr_tables_swi.ld
[179/181] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[180/181] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[181/181] Linking C executable zephyr\zephyr.elf
[7/10] No install step for 'spicheck'
[8/10] Completed 'spicheck'
[9/10] cmd.exe /C "cd /D C:\ncs\RTUD\spicheck\build\_sysbuild && C:\ncs\toolchains\fd21892d0f\opt\bin\cmake.exe -E true"
[10/10] Generating ../merged.hex
Hi Benjamin,
I waited for your answer, but I have resolved an issue. In the nRF5340_PS_v16.pdf it is mentioned that for SPIM4 "The GPIO must use the high drive H0H1 configuration in the DRIVE field of the PIN_CNF GPIO register."
With default S0S1, we were not able to communicate with MCP23S17.
Solution is -
