RSSI Measurement
After working with the path loss monitoring sample in NCS, I was wondering if there is a sample that accomplishes something similar to the following:
  • Central on nRF52840-DK
    • Scans and connects to peripheral
    • Makes RSSI measurement of packets coming from Peripheral = RSSI@Central
    • Reports RSSI@Central and RSSI@Peripheral as a transaction pair over COM port
  • Peripheral on nRF21540-DK (nrf52840)
    • Makes RSSI measurement of packets coming from Central = RSSI@Peripheral
    • Sends RSSI@Peripheral measurement back to Central
James
  • Hi James,
    Path Loss Monitoring will not fit here. It only fires events on zone transitions (Low / Middle / High), not continuous values, so it cannot give you the per-packet RSSI pair you want.
    The primitive you actually want is HCI_Read_RSSI on the live bt_conn handle. Both ends of a connection can call it, so the Central reads RSSI of packets from the Peripheral and the Peripheral reads RSSI of packets from the Central. Poll it on a work queue at whatever cadence you need.
    The samples/bluetooth/rssi_power_control sample (NCS v3.2.0+) is the closest existing reference for the Central-side polling pattern. Its actual purpose is automated TX power control, so you would take the RSSI-polling skeleton and drop the power-control loop.
    For your bidirectional setup you also need the same polling on the Peripheral side and a small custom GATT notify characteristic for the back-channel. The Peripheral notifies its own RSSI to the Central; the Central reads its own RSSI on each notification and prints the pair over UART.
    Hope this helps!
    Mohammad
    Novel Bits
    https://novelbits.io
  • Mohammad,
    Thank you for your suggestion!  I started with the samples/bluetooth/rssi_power_control sample project as you mentioned.  That was a good foundation to get me to what I wanted.  AI helped me implement the GATT notify characteristic, and now I have it working as intended.  I can see RSSI pairs for each direction of the link streaming out of the central.
    James
