Not able to open flash area in custom nrf52840 board (mass storage) Flash area 0 open error -19
Using the flash : https://datasheet4u.com/download_new.php?id=1588116
on SPI : XF_CS (P0.13), SCLK (P1.09) , SDI (P0.08) , SDO (P0.05)
Flash specific parts in the nrf52840dk_nrf52840.overlay
&pinctrl {
    uart1_default: uart1_default {
        group1 {
            psels = <NRF_PSEL(UART_TX, 1, 1)>;
        group2 {
            psels = <NRF_PSEL(UART_RX, 1, 4)>;
            bias-pull-up;
    uart1_sleep: uart1_sleep {
        group1 {
        group2 {
            bias-pull-up;
    i2c0_default: i2c0_default {
        group1 {
            psels = <NRF_PSEL(TWIM_SDA, 0, 0)>,
                    <NRF_PSEL(TWIM_SCL, 0, 1)>;
            bias-pull-up;
    i2c0_sleep: i2c0_sleep {
        group1 {
            low-power-enable;
            // bias-pull-up;
    spi1_default: spi1_default {
        group1 {
            psels = <NRF_PSEL(SPIM_SCK, 1, 9)>,
                <NRF_PSEL(SPIM_MOSI, 0, 8)>,
                <NRF_PSEL(SPIM_MISO, 0, 5)>;
    spi1_sleep: spi1_sleep {
        group1 {
            low-power-enable;
    // spi2_default: spi2_default {
    //  group1 {
    //      psels = <NRF_PSEL(SPIM_SCK, 1, 9)>,
    //          <NRF_PSEL(SPIM_MOSI, 0, 8)>,
    //          <NRF_PSEL(SPIM_MISO, 0, 5)>;
    // spi2_sleep: spi2_sleep {
    //  group1 {
    //      low-power-enable;
&flash0
    partitions {
        #address-cells = <1>;
        #size-cells = <1>;
        slot0_partition: partition@c000 {
            reg = <0x0000C000 0x00066000>; /* 408 KiB */
        slot1_partition: partition@72000 {
            reg = <0x00072000 0x00066000>; /* 408 KiB */
        storage_partition: partition@d8000 {
            label = "storage";
            reg = <0x000d8000 0x00028000>; /* 160 KiB */
&spi1 {
    compatible = "nordic,nrf-spi";
    status = "okay";
    cs-gpios = <&gpio0 13 GPIO_ACTIVE_LOW>;
    pinctrl-0 = <&spi1_default>;
    pinctrl-1 = <&spi1_sleep>;
    mx25r64: mx25r6435f@0 {
        compatible = "jedec,spi-nor";
        reg = <0>;
        spi-max-frequency = <32000000>;
        jedec-id = [00 C8 60];
        size = <536870912>; /* 512 MiB */
        //wp-gpios = <&gpio0 22 GPIO_ACTIVE_LOW>;
        //hold-gpios = <&gpio0 13 GPIO_ACTIVE_LOW>;
        sfdp-bfp = [
        e5 20 f3 ff ff ff ff 1f 44 eb 08 6b 08 3b 42 bb
        fe ff ff ff ff ff 00 ff ff ff 44 eb 0c 20 0f 52
        10 d8 00 ff d4 39 a5 fe 82 d8 14 58 ec 62 16 33
        7a 75 7a 75 04 bd d5 5c 29 06 14 00 08 50 00 01
        // t-enter-dpd = <10000>;
        // t-exit-dpd = <35000>;
        partitions {
            #size-cells = <1>;
            external_storage: partition@0 {
                label = "external-storage";
                reg = <0x00000000 0x00800000>;
    msc_disk0 {
        status = "okay";
        compatible = "zephyr,flash-disk";
        partition = <&external_storage>;
        disk-name = "NAND";
        cache-size = <4096>;
main.c
static int mount_app_fs(struct fs_mount_t *mnt)
    // Clean initialization
    mnt->type = FS_FATFS;
    mnt->fs_data = &fat_fs;
    /* This MUST match the 'disk-name' in your DeviceTree + a colon */
    mnt->mnt_point = "/NAND:";
    /* Use Disk Access API to bridge the Flash-Disk driver */
    mnt->flags = FS_MOUNT_FLAG_USE_DISK_ACCESS;
    return fs_mount(mnt);
static int setup_flash(struct fs_mount_t *mnt)
    int rc = 0;
#if CONFIG_DISK_DRIVER_FLASH
    unsigned int id;
    const struct flash_area *pfa;
    mnt->storage_dev = (void *)STORAGE_PARTITION_ID;
    id = STORAGE_PARTITION_ID;
    rc = flash_area_open(id, &pfa);
    printk("Area %u at 0x%x on %s for %u bytes\n",
           id, (unsigned int)pfa->fa_off, pfa->fa_dev->name,
           (unsigned int)pfa->fa_size);
    if (rc < 0 && IS_ENABLED(CONFIG_APP_WIPE_STORAGE)) {
        printk("Erasing flash area ... ");
        rc = flash_area_flatten(pfa, 0, pfa->fa_size);
        printk("%d\n", rc);
    if (rc < 0) {
        flash_area_close(pfa);
    return rc;
void setup_disk(void);
    struct fs_mount_t *mp = &fs_mnt;
    struct fs_dir_t dir;
    struct fs_statvfs sbuf;
    int rc;
    fs_dir_t_init(&dir);
    // if (IS_ENABLED(CONFIG_DISK_DRIVER_FLASH)) {
    //  rc = setup_flash(mp);
    //  if (rc < 0) {
    //      LOG_ERR("Failed to setup flash area");
    //      return;
    // if (!IS_ENABLED(CONFIG_FILE_SYSTEM_LITTLEFS) &&
    //     !IS_ENABLED(CONFIG_FAT_FILESYSTEM_ELM)) {
    //  LOG_INF("No file system selected");
    //  return;
    rc = mount_app_fs(mp);
    if (rc < 0) {
        LOG_ERR("Failed to mount filesystem");
        return;
    /* Allow log messages to flush to avoid interleaved output */
    k_sleep(K_MSEC(50));
    printk("Mount %s: %d\n", fs_mnt.mnt_point, rc);
    rc = fs_statvfs(mp->mnt_point, &sbuf);
    if (rc < 0) {
        printk("FAIL: statvfs: %d\n", rc);
        return;
    printk("%s: bsize = %lu ; frsize = %lu ;"
           " blocks = %lu ; bfree = %lu\n",
           mp->mnt_point,
           sbuf.f_bsize, sbuf.f_frsize,
           sbuf.f_blocks, sbuf.f_bfree);
    rc = fs_opendir(&dir, mp->mnt_point);
    printk("%s opendir: %d\n", mp->mnt_point, rc);
    if (rc < 0) {
        LOG_ERR("Failed to open directory");
    while (rc >= 0) {
        struct fs_dirent ent = { 0 };
        rc = fs_readdir(&dir, &ent);
        if (rc < 0) {
            LOG_ERR("Failed to read directory entries");
        if (ent.name[0] == 0) {
            printk("End of files\n");
        printk("  %c %zu %s\n",
               (ent.type == FS_DIR_ENTRY_FILE) ? 'F' : 'D',
               ent.size,
               ent.name);
    (void)fs_closedir(&dir);
    return;
