nRF9160 - mfw 1.3.7 - NCS 3.2.4 - DNS lookup fails with some SIM cards using cloudflare
In my experience, DNS lookup fails with some SIM cards using cloudflare as primary DNS.
I wrote to the SIM card provider about that issue and get the following answer:
The reason for the issue you are seeing is a different behavior of DNS resolution services of Cloudflare (1.1.1.1) and Google (8.8.8.8).  Cloudflare is the primary DNS, and Google is the secondary DNS server provided to the modem by our SIM card.  The response from Cloudflare is longer and not supported by NRF9160, resulting in the Truncated response flag being set to 1 by Cloudflare.  Google response is shorter and is not truncated.
The "other" SIM uses Google as a primary DNS resolution server that is compatible with the modem.
Our SIM sets Cloudflare as a primary DNS resolution server.  The expected behavior from the modem is that it would retry DNS resolution using TCP after initial UDP attempt fails.  Unfortunately, your modem does not support the TCP retry option.
The way to eliminate this issue is to have your application try Cloudflare first and if it fails, then try Google second.  Alternatively, you can manually re-configure DNS servers on the Nordic device to use Google (8.8.8.8) first and either 8.8.4.4 or 1.1.1.1 secondary.
The pain here is:
Though the getaddrinfo is offloaded to the modem, I'm not able to exchange the dns server.
Using LTE_LC_DNS_FALLBACK_ADDRESS ends up in calling nrf_setdnsaddr and the docu there says
"The fallback DNS address is used only when the network-provided DNS addresses are
 missing or unreachable. The fallback DNS does not override the network-provided DNS."
Though the SIm card sets the "1.1.1.1", a LTE_LC_DNS_FALLBACK_ADDRESS "8.8.8.8" will
not get effective.
Are there any other options?
To be frank: in rare cases using that SIM, cloudflare answers the modem's request with a message of 86 bytes. I'm not sure, if their explanation with "longer" really fits.
  • Follow up question:
    Is it possible, to not use the "off-loading" just for the  getaddrinfo?
    Thanks for detailed description. Your understanding of the fallback DNS is correct and since your SIM actively provides 1.1.1.1 as the primary DNS, setting CONFIG_LTE_LC_DNS_FALLBACK_ADDRESS="8.8.8.8" will have no effect on normal lookups, as it applies when the network provided DNS is missing. There seems no supported API to replace operator provided DNS servers while using the modem's offloaded getaddrinfo(). However you may try following options:
    • Try sending a raw DNS query over UDP directly to 8.8.8.8 using a normal offloaded UDP socket, bypassing the modem's DNS client entirely. This does not require disabling socket offloading and avoids the truncation issue. You can implement a retry, try 1.1.1.1 first and fall back to 8.8.8.8 if it fails.
    • Moreover it could be possible to use Zephyr's native DNS resolver with a specific server in principle but may it will not be a straight forward or a recommended option.
    And it seems logical that a 86 byte response would not normally trigger truncation. To check what happens on failure, can you share modem trace. Thanks
    Best Regards,
    Syed Maysum
  • Thanks for your answer.
    While the issue itself isn't that hard (exchanging the SIM or modem will help), let me express, that my concern is the general way to handle such things.
    As user I'm now faced two parties: the one who explains, that a second DNS is common and overcomes the issue. And the other party sticks to the DNS provided by the SIM and with that the means to escape are blocked.
    Without "deep dive" into DNS (RFC 1035) and the common practice (here the use of the TC flag) it's hard to see, what is the "intended interoperable" way to go.
    To propose to implement the DNS lookup by my self is then something, what I would understand for short term.
    But for mid or long term, I would expect, that it gets possible to set the DNS server, regardless what the SIM card provides. For me this is not about, what is the right way, it's about having means to handle the situation in time.
  • Just as update:
    Finally the MVNO (SIM provider) managed it to fix the behavior of their DNS service.
    Thanks a lot for your update and glad that the SIM provider managed to fix this behavior. Do let me know if it's fine to close this ticket.
    Best Regards,
    Syed Maysum
