Unable to recover NRF52840
I'm programming a batch of 100 NRF52840 devices (new ISP1807-LR modules), and I'm unable to recover or program several of them. Most work fine, and I've never seen this issue until this batch. Does this sound like there is an error with the chips? Or would it point more towards the board/soldering?
Thanks for your help!
Here is the .bat file I'm using:
@echo off
cd C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin
echo Flashing bootloader...
nrfjprog --recover -f nrf52 --log
nrfjprog --program "itsybitsy_nrf52840_express_bootloader-0.8.0_s140_6.1.1.hex" -f nrf52 --chiperase --reset --log
echo Waiting for drive to appear...
:WAIT_FOR_DRIVE
if exist "E:\\" goto COPY_UF2
timeout /t 1 /nobreak >nul
goto WAIT_FOR_DRIVE
:COPY_UF2
echo Drive found! Copying UF2...
copy "C:\Users\Andrew\Documents\WARBL\WARBL2\UF2 files\current_firmware\WARBL2_firmware.uf2" E:\
echo Done!
And here is the printout:
Recovering device. This operation might take 30s.
[error] [ Client] - Encountered error -21: Command recover executed for 153 milliseconds with result -21
[error] [ Worker] - An unknown error.
ERROR: Recover failed. Please make sure that the correct device family is given
ERROR: and try again.
[error] [ Client] - Encountered error -102: Command read_device_info executed for 154 milliseconds with result -102
[error] [ Client] - Encountered error -102: Command read_memory_descriptors executed for 60 milliseconds with result -102
Failed to read device memories.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
  • I desoldered a few of the modules and checked the continuity of the PCBs, and as far as I can tell the boards are okay. This leads me to wonder if there is an issue with some of the modules or if they somehow have gotten damaged.
  • Hi
    Can you share the full flash log here with the --log command? The errors shown here are pretty generic, so this can be due to a few different things. What are you using to program/recover the boards? A DK or a dedicated J-Link programmer? Please confirm what supply voltage the board and programmer runs on. These should match to make sure it runs correctly.
    Is there anything different with this batch in HW terms compared to older batches? My guess is that there's an electrical or physical issue on these new boards that result in issues when flashing them.
    Simon
  • Hi Simon, thanks very much for your help. At this point I'm starting to think that the modules were damaged because I didn't have JLCPCB bake them (they said that their automatic recommendation for baking only is triggered by MSL5 components). It appears that a few of the modules have Vcc and Gnd shorted internally. I'm in touch with both JLCPCB and Insight about this as well and they've been very helpful.
    However, in response to your questions, I'm using a J-Link EDU Mini v.1.0 for programming. The programmer is powered by USB but I'm not sure what voltage it actually runs on. The NRF has 3.0 V to VCC_NRF and USB (5.0 V) to VBUS. I am curious about the possible voltage mismatch, as I've never considered this (although again, I haven't seen issues in the past).
    The only difference on this batch of boards is that I've added a magnetometer to the board, but I don't see that causing any issues. The schematic for the board is here: https://warbl.xyz/WARBL2_schematic.pdf
    I'm pasting in an example lengthy log below. Thanks again!
    [2026-May-19 14:33:56] [debug] --------------------------------------------------------------------------------
    [2026-May-19 14:33:56] [debug] nrfjprog --recover -f nrf52 --log
    [2026-May-19 14:33:56] [debug] nrfjprog version 10.24.2 external
    [2026-May-19 14:33:56] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
    [2026-May-19 14:33:56] [ info] Library loaded, loading member functions.
    [2026-May-19 14:33:56] [ info] Member functions succesfully loaded.
    [2026-May-19 14:33:56] [debug] [ Client] - open
    [2026-May-19 14:33:56] [debug] [ Client] - start
    [2026-May-19 14:33:56] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 1cad72ca-fe2a-4f4d-a172-7b86b106ff43.
    [2026-May-19 14:33:57] [trace] [ Client] - Command open executed for 48 milliseconds with result 0
    [2026-May-19 14:33:57] [debug] [ Client] - config
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2026-May-19 14:33:57] [trace] [ Client] - Command config executed for 15 milliseconds with result 0
    [2026-May-19 14:33:57] [debug] [ JLink] - Logger sink registered in JLink logger
    [2026-May-19 14:33:57] [debug] [ nRF52] - open
    [2026-May-19 14:33:57] [debug] [ nRF52] - just_check_family
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - open_dll
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2026-May-19 14:33:57] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink_V794e\JLink_x64.dll.
    [2026-May-19 14:33:57] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2026-May-19 14:33:57] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2026-May-19 14:33:57] [debug] [ Client] - enum_emu_snr
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - Set batch mode
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - dll_version
    [2026-May-19 14:33:57] [ info] [SeggerBackend] - Segger dll version 7.94.e loaded.
    [2026-May-19 14:33:57] [trace] [ Worker] - Command open executed for 4 milliseconds with result 0
    [2026-May-19 14:33:57] [debug] [ nRF52] - config
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - enum_emu_snr
    [2026-May-19 14:33:57] [trace] [ Worker] - Command config executed for 2 milliseconds with result 0
    [2026-May-19 14:33:57] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0
    [2026-May-19 14:33:57] [debug] [ Client] - connect_to_emu_with_snr
    [2026-May-19 14:33:57] [debug] [ nRF52] - enum_emu_con_info
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - is_connected_to_emu
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - enum_emu_con_info
    [2026-May-19 14:33:57] [trace] [ Worker] - Command enum_emu_con_info executed for 2 milliseconds with result 0
    [2026-May-19 14:33:57] [debug] [ nRF52] - connect_to_emu_with_snr
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - ---just_get_num_emus
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - Segger logging enabled.
    [2026-May-19 14:33:57] [trace] [ JLink] - Firmware: J-Link EDU Mini V1 compiled Mar 29 2024 01:02:31
    [2026-May-19 14:33:57] [trace] [ JLink] - Hardware: V1.00
    [2026-May-19 14:33:57] [trace] [ JLink] - S/N: 801041539
    [2026-May-19 14:33:57] [trace] [ JLink] - OEM: SEGGER
    [2026-May-19 14:33:57] [trace] [ JLink] - Feature(s): FlashBP, GDB
    [2026-May-19 14:33:57] [trace] [ JLink] - Bootloader: 2016 Nov 30
    [2026-May-19 14:33:57] [trace] [ JLink] - USB speed mode: Full speed (12 MBit/s)
    [2026-May-19 14:33:57] [trace] [ JLink] - TELNET listener socket opened on port 19021
    [2026-May-19 14:33:57] [trace] [ JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2026-May-19 14:33:57] [trace] [ JLink] - WEBSRV Webserver running on local port 19080
    [2026-May-19 14:33:57] [trace] [ JLink] - Looking for J-Link GUI Server exe at: C:\Program Files\SEGGER\JLink_V794e\JLinkGUIServer.exe
    [2026-May-19 14:33:57] [trace] [ JLink] - Forking J-Link GUI Server: C:\Program Files\SEGGER\JLink_V794e\JLinkGUIServer.exe
    [2026-May-19 14:33:57] [trace] [ Client] - Command connect_to_emu_with_snr executed for 109 milliseconds with result 0
    [2026-May-19 14:33:57] [debug] [ Client] - read_connected_emu_snr
    [2026-May-19 14:33:57] [trace] [ Client] - Command read_connected_emu_snr executed for 15 milliseconds with result 0
    [2026-May-19 14:33:57] [trace] [ JLink] - J-Link GUI Server info: "J-Link GUI server V7.94e "
    [2026-May-19 14:33:57] [trace] [ JLink] - - 74.016ms returns "O.K."
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_HasError()
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_Lock()
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.001ms returns 0x01
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.001ms returns 0x00
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.003ms returns 0x00
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_SetHookUnsecureDialog
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_SetHookUnsecureDialog(...)
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.007ms returns 0
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2026-May-19 14:33:57] [trace] [ JLink] - - 2.170ms returns 0x00
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_GetSpeedInfo()
    [2026-May-19 14:33:57] [trace] [ JLink] - 96000000 Hz / n, n >= 24
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 4000kHz
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_SetSpeed(2000)
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.071ms
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_GetSpeed()
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.002ms returns 2000
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_GetSN()
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.002ms returns 801041539
    [2026-May-19 14:33:57] [debug] [ nRF52] - read_device_family
    [2026-May-19 14:33:57] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 92 milliseconds with result 0
    [2026-May-19 14:33:57] [debug] [ nRF52] - read_connected_emu_snr
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_IsOpen()
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.024ms returns 0x01
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - read_connected_emu_snr
    [2026-May-19 14:33:57] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2026-May-19 14:33:57] [debug] [ Client] - recover
    [2026-May-19 14:33:57] [debug] [ nRF52] - recover
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.005ms returns 0x01
    [2026-May-19 14:33:57] [debug] [ nRF52] - Just_recover
    [2026-May-19 14:33:57] [debug] [ nRF52] - Just_is_ctrl_ap_available
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - read_access_port_register
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - coresight_configure
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_GetHWStatus(...)
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.524ms returns 0
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_CORESIGHT_Configure()
    [2026-May-19 14:33:57] [trace] [ JLink] - - 102.314ms returns 0
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - read_debug_port_idr
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - read_debug_port_register
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.933ms returns -1
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.561ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.938ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.962ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.954ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.969ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.942ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.958ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.984ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.978ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.960ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.963ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.957ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.964ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.959ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.986ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.973ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.982ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 2.983ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.980ms returns -1
    [2026-May-19 14:33:57] [error] [ Client] - Encountered error -21: Command recover executed for 153 milliseconds with result -21
    [2026-May-19 14:33:57] [trace] [ JLink] - - 1.000ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.983ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.972ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 1.010ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.941ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.971ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.996ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.974ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.981ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.979ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.087ms
    [2026-May-19 14:33:57] [error] [ Worker] - An unknown error.
    [2026-May-19 14:33:57] [trace] [ Worker] - Command recover executed for 146 milliseconds with result -21
    [2026-May-19 14:33:57] [debug] [ nRF52] - close
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.007ms returns 0x01
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - close
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - disconnect_from_emu
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - is_connected_to_device
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_IsConnected()
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.002ms returns FALSE
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.748ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.565ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 2.985ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.987ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.951ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.995ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.989ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.961ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.990ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.949ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.994ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.977ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 3.192ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.740ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.976ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.752ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.991ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.968ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.970ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 2.988ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.992ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 2.981ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 2.977ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.999ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.943ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.985ms returns -1
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - Ignore exception An unknown error.
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.032ms
    [2026-May-19 14:33:57] [trace] [ JLink] - JLINK_Close()
    [2026-May-19 14:33:57] [debug] [SeggerBackend] - Segger Backend closed.
    [2026-May-19 14:33:57] [debug] [ nRF52] - nRF family DLL closed
    [2026-May-19 14:33:57] [trace] [ Client] - Command close executed for 92 milliseconds with result 0
    [2026-May-19 14:33:57] [debug] [ Client] - terminate
    [2026-May-19 14:33:57] [trace] [ Worker] - Command close executed for 91 milliseconds with result 0
    [2026-May-19 14:33:57] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2026-May-19 14:33:57] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2026-May-19 14:33:57] [trace] [ Worker] - Executed 8 commands for 337 milliseconds
    [2026-May-19 14:33:57] [debug] [ Client] - Worker process exited with code: 0
    [2026-May-19 14:33:57] [debug] [ Client] - Child process terminated with result 0
    [2026-May-19 14:33:57] [trace] [ Client] - Executed 8 commands for 447 milliseconds
    [2026-May-19 14:33:57] [debug] --------------------------------------------------------------------------------
    [2026-May-19 14:33:57] [debug] nrfjprog --program itsybitsy_nrf52840_express_bootloader-0.8.0_s140_6.1.1.hex -f nrf52 --chiperase --reset --log
    [2026-May-19 14:33:57] [debug] nrfjprog version 10.24.2 external
    [2026-May-19 14:33:57] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
    [2026-May-19 14:33:57] [ info] Library loaded, loading member functions.
    [2026-May-19 14:33:57] [ info] Member functions succesfully loaded.
    [2026-May-19 14:33:57] [debug] [ Client] - open
    [2026-May-19 14:33:57] [debug] [ Client] - start
    [2026-May-19 14:33:57] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence c696a3f0-3abf-4bef-b771-e1d78efa9ff8.
    [2026-May-19 14:33:57] [trace] [ Client] - Command open executed for 38 milliseconds with result 0
    [2026-May-19 14:33:57] [trace] [ Worker] - Command open executed for 3 milliseconds with result 0
    [2026-May-19 14:33:57] [trace] [ Client] - Command enum_emu_con_info executed for 16 milliseconds with result 0
    [2026-May-19 14:33:57] [trace] [ Client] - Command connect_to_emu_with_snr executed for 76 milliseconds with result 0
    [2026-May-19 14:33:57] [trace] [ Client] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2026-May-19 14:33:57] [debug] [ Client] - read_device_info
    [2026-May-19 14:33:57] [trace] [ JLink] - - 51.982ms returns "O.K."
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.000ms returns 0x00
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.007ms returns 0x00
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.009ms returns 0
    [2026-May-19 14:33:57] [trace] [ JLink] - - 3.746ms returns 0x00
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.006ms
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.081ms
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.003ms returns 2000
    [2026-May-19 14:33:57] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 70 milliseconds with result 0
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.008ms returns 0x01
    [2026-May-19 14:33:57] [debug] [ nRF52] - read_device_info
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.002ms returns 0x01
    [2026-May-19 14:33:57] [debug] [ nRF52] - Just_read_device_version
    [2026-May-19 14:33:57] [debug] [ nRF52] - Just_readback_status
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.173ms returns 0
    [2026-May-19 14:33:57] [trace] [ JLink] - - 102.386ms returns 0
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.944ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.997ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.861ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.975ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.988ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.967ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 1.054ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.911ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 2.982ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 2.449ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.504ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.932ms returns -1
    [2026-May-19 14:33:57] [error] [ Client] - Encountered error -102: Command read_device_info executed for 153 milliseconds with result -102
    [2026-May-19 14:33:57] [warning] Failed to read device info. Attempting to complete command anyways.
    [2026-May-19 14:33:57] [debug] [ Client] - read_memory_descriptors
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.930ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.073ms
    [2026-May-19 14:33:57] [trace] [ Worker] - Command read_device_info executed for 147 milliseconds with result -102
    [2026-May-19 14:33:57] [debug] [ nRF52] - read_memory_descriptors
    [2026-May-19 14:33:57] [debug] [ nRF52] - Just_read_memory_descriptors
    [2026-May-19 14:33:57] [trace] [ JLink] - - 1.003ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 2.991ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 2.439ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.536ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 1.070ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.868ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.965ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 2.994ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 1.004ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.940ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.998ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 1.002ms returns -1
    [2026-May-19 14:33:57] [error] [ Client] - Encountered error -102: Command read_memory_descriptors executed for 60 milliseconds with result -102
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.045ms
    [2026-May-19 14:33:57] [trace] [ Worker] - Command read_memory_descriptors executed for 49 milliseconds with result -102
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.018ms returns 0x01
    [2026-May-19 14:33:57] [trace] [ JLink] - - 1.056ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.564ms returns -1
    [2026-May-19 14:33:57] [trace] [ JLink] - - 0.955ms returns -1
    [2026-May-19 14:33:58] [trace] [ JLink] - - 0.995ms returns -1
    [2026-May-19 14:33:58] [trace] [ JLink] - JLINK_HasError()
    [2026-May-19 14:33:58] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2026-May-19 14:33:58] [trace] [ JLink] - - 0.972ms returns -1
    [2026-May-19 14:33:58] [trace] [ JLink] - - 0.989ms returns -1
    [2026-May-19 14:33:58] [trace] [ JLink] - - 0.975ms returns -1
    [2026-May-19 14:33:58] [trace] [ JLink] - - 0.981ms returns -1
    [2026-May-19 14:33:58] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2026-May-19 14:33:58] [trace] [ JLink] - - 0.974ms returns -1
    [2026-May-19 14:33:58] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2026-May-19 14:33:58] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2026-May-19 14:33:58] [trace] [ JLink] - - 2.997ms returns -1
    [2026-May-19 14:33:58] [trace] [ JLink] - - 0.997ms returns -1
    [2026-May-19 14:33:58] [trace] [ JLink] - - 0.942ms returns -1
    [2026-May-19 14:33:58] [trace] [ JLink] - - 0.990ms returns -1
    [2026-May-19 14:33:58] [trace] [ JLink] - - 0.980ms returns -1
    [2026-May-19 14:33:58] [debug] [SeggerBackend] - Ignore exception An unknown error.
    [2026-May-19 14:33:58] [trace] [ JLink] - - 0.042ms
    [2026-May-19 14:33:58] [trace] [ JLink] - JLINK_Close()
    [2026-May-19 14:33:58] [debug] [SeggerBackend] - Segger Backend closed.
    [2026-May-19 14:33:58] [debug] [ nRF52] - nRF family DLL closed
    [2026-May-19 14:33:58] [trace] [ Client] - Command close executed for 92 milliseconds with result 0
    [2026-May-19 14:33:58] [trace] [ Worker] - Command close executed for 77 milliseconds with result 0
    [2026-May-19 14:33:58] [debug] [ Client] - terminate
    [2026-May-19 14:33:58] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2026-May-19 14:33:58] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2026-May-19 14:33:58] [trace] [ Worker] - Executed 9 commands for 350 milliseconds
    [2026-May-19 14:33:58] [debug] [ Client] - Worker process exited with code: 0
    [2026-May-19 14:33:58] [debug] [ Client] - Child process terminated with result 0
    [2026-May-19 14:33:58] [trace] [ Client] - Executed 9 commands for 450 milliseconds
  • Hi Andrew
    Looks like the logging is not able to get a connection with the nRF in the first place. If Vcc and GND are shorted you would indeed have issues with flashing them, so if this is the case for all faulty devices I think you have the cause nailed down. Let me know if anything else is required from us here, or if we can close this ticket.
    Simon
  • Thank you Simon-- at this point I'm assuming that there was an issue either with the modules or with assembly, so you can close this ticket.
    Best,
    -Andrew
