We obtained a Power Profiler Kit II.
I updated nrf Connect to latest version, then installed App power profiler.
The following state is reached:
When i launch the App Programmer v4.7.4, I see the Power Profiler Kit II as selectable device.
When I launch App Power Profiler v4.3.1, there is no listed device in menu "Select device" which is analogue to programmer's menu, where it is listed.
So basically the device is "fully there" in the system, but App Power Profiler v4.3.1 does not list it.
Asking AI, the following suggestion was made: Search the App Power Profiler v4.3.1's install path for a firmware with name like pca63100_ppk2*.hex
I found pca63100_ppk2_1.2.4_db16a94.hex. Telling the AI, the AI suggested: use programmer to flash that firmware to listed PPK2.
As I cannot backup the PPK2's firmware (read-protection), i was VERY reluctant to do so, because applying the wrong firmware surely will brick the device.
So, I want to inquire here, at nordic forum, whether AI's suggestion is a good tip or a bad AI recommendation.
Also, I'd like to know in the latter case, what I need to do to get PPK2 listed in App Power Profiler v4.3.1 and any refined instructions/test steps are also welcome.
Be aware, that I also started nrfConnect (with no observable device-detection-change in any way) as:
~/Downloads/nrfconnect361x8664.AppImage --no-sandbox
Thank you and best regards,
Richard H.
