The firmware always halts execution during boot after providing these logs:
26/05/22 10:38:33.925 89737.861 13892 0 E: Device id 00 00 00 does not match config 1f 16 01
26/05/22 10:38:33.929 89737.865 4 0 I: Starting bootloader
26/05/22 10:38:33.932 89737.868 3 0 E: Failed to open flash area ID 1 (image 0 slot 1): -19, cannot continue
I'm trying to connect to a 16 Mbit AT25EU0161A Renesas external flash. I probed the SCK, MOSI, CS, and MISO pins; however, I've never managed to see any signal on the MISO pin.
I've attached the Logic Analyzer's capture for your reference.
I've even added a 300us delay to create a settle-down time between the CS and the MOSI & SCK pulse, but that also did not work.
Here are my configurations:
&spi00 {
status = "okay";
cs-gpios = <&gpio2 5 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&spi00_default>;
pinctrl-1 = <&spi00_sleep>;
at25eu0: at25eu0161a@0 {
compatible = "jedec,spi-nor";
status = "okay";
reg = <0>;
spi-max-frequency = <2000000>;
jedec-id = [1f 16 01];
size = <16777216>;
has-dpd;
t-enter-dpd = <10000>;
t-exit-dpd = <35000>;
partitions {
#address-cells = <1>;
#size-cells = <1>;
slot1_partition: mcuboot_secondary: partition@0 {
label = "image-1";
reg = <0x0 0x143000>;
/omit-if-no-ref/ spi00_default: spi00_default {
group1 {
psels = <NRF_PSEL(SPIM_SCK, 2, 6)>,
<NRF_PSEL(SPIM_MOSI, 2, 8)>,
<NRF_PSEL(SPIM_MISO, 2, 4)>;
/omit-if-no-ref/ spi00_sleep: spi00_sleep {
group1 {
low-power-enable;
};Theser are my prj.conf settings:
# SPI config CONFIG_SPI=y CONFIG_SPI_NOR=y CONFIG_SPI_NOR_SFDP_RUNTIME=y CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
These are my .conf files for the mcuboot:
CONFIG_GPIO=y CONFIG_MULTITHREADING=y CONFIG_BOOT_MAX_IMG_SECTORS=512 # External SPIM flash for secondary slot CONFIG_SPI=y CONFIG_SPI_NRFX=y CONFIG_SPI_NOR=y CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096 CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
SPI wiring:
CS -> nRF54L15 P2.05
SCK -> nRF54L15 P2.06
SI/MOSI -> nRF54L15 P2.08
SO/MISO -> nRF54L15 P2.04
HOLD/RESET -> nRF54L15 P2.03 pulled internally high. (also verified on hardware)
WP -> pulled high via an external 10K resistor.
The bootloader is MCUBoot v2.1.0-ncs3-3. The failure happens during MCUBoot/Zephyr spi_nor_configure(), where command 0x9F is sent correctly, but MISO returns 00 00 00 instead of 1F 16 01.
SPI mode is mode 0, SCK 2 MHz. As mentioned above, putting a CS delay did not solve the issue.
