no device npm1300_ek (one button sample) with nRF52 DK on I2C Bus
I try to get the one button sample to work. There were several details missing to be able to compile and run this sample, which was very frustrating. After editing/updating the
prj.conf: CONFIG_I2C=y
CMakeLists.txt: set(SHIELD npm1300_ek)
nrf52dk_nrf52832.overlay:
 #include <zephyr/dt-bindings/pinctrl/nrf-pinctrl.h>
 &i2c1 {
 status = "okay";
 pinctrl-0 = <&i2c1_default>;
 pinctrl-1 = <&i2c1_sleep>;
 clock-frequency = <I2C_BITRATE_STANDARD>;
 //clock-frequency = <10000>;
 &i2c1_default {
 group1 {
 psels = <NRF_PSEL(TWIM_SDA, 0, 26)>,
 <NRF_PSEL(TWIM_SCL, 0, 27)>;
 bias-pull-up;
&i2c1_sleep {
 group1 {
 low-power-enable;
My zephyr.dts i2c1 snippet:
/* node '/soc/i2c@40004000' defined in zephyr/dts/arm/nordic/nrf52832.dtsi:172 */
		i2c1: i2c@40004000 {
			#address-cells = < 0x1 >;      /* in zephyr/dts/arm/nordic/nrf52832.dtsi:181 */
			#size-cells = < 0x0 >;         /* in zephyr/dts/arm/nordic/nrf52832.dtsi:182 */
			reg = < 0x40004000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52832.dtsi:183 */
			interrupts = < 0x4 0x1 >;      /* in zephyr/dts/arm/nordic/nrf52832.dtsi:184 */
			easydma-maxcnt-bits = < 0x8 >; /* in zephyr/dts/arm/nordic/nrf52832.dtsi:185 */
			zephyr,pm-device-runtime-auto; /* in zephyr/dts/arm/nordic/nrf52832.dtsi:187 */
			compatible = "nordic,nrf-twi"; /* in zephyr/boards/nordic/nrf52dk/nrf52dk_nrf52832.dts:188 */
			status = "okay";               /* in ../../../../mnt/df01dc22-f3bf-40d5-9858-752a58c9832d/devprojects/nordicsemi/npm13xx_one_button/build/npm13xx_one_button/zephyr/boards/nrf52dk_nrf52832.overlay:9 */
			pinctrl-0 = < &i2c1_default >; /* in ../../../../mnt/df01dc22-f3bf-40d5-9858-752a58c9832d/devprojects/nordicsemi/npm13xx_one_button/build/npm13xx_one_button/zephyr/boards/nrf52dk_nrf52832.overlay:10 */
			pinctrl-1 = < &i2c1_sleep >;   /* in ../../../../mnt/df01dc22-f3bf-40d5-9858-752a58c9832d/devprojects/nordicsemi/npm13xx_one_button/build/npm13xx_one_button/zephyr/boards/nrf52dk_nrf52832.overlay:11 */
			pinctrl-names = "default",
			                "sleep";       /* in ../../../../mnt/df01dc22-f3bf-40d5-9858-752a58c9832d/devprojects/nordicsemi/npm13xx_one_button/build/npm13xx_one_button/zephyr/boards/nrf52dk_nrf52832.overlay:12 */
			clock-frequency = < 0x186a0 >; /* in ../../../../mnt/df01dc22-f3bf-40d5-9858-752a58c9832d/devprojects/nordicsemi/npm13xx_one_button/build/npm13xx_one_button/zephyr/boards/nrf52dk_nrf52832.overlay:13 */
with claudes assistance/support i got it to compile and run. But an i2c scan i2c0 shows no device at all.
What minimal required steps/configuration have to setup to get I2C enabled and detect devices on the bus should be?
Trying with the nrf-connect (Ubuntu) Linux-Desktop app (2x USB -C, 1x LiPo Battery) i get NPM detected, the LiPo Battery to and can change parameters for ex. the LED's live, so the BOARD is working.
Any support/hint/help is appreciated.
  • My console output:
    Building npm13xx_ek
    west build --build-dir /home/thomas/ncs/v3.2.0/zephyr/samples/shields/npm13xx_ek/build /home/thomas/ncs/v3.2.0/zephyr/samples/shields/npm13xx_ek --pristine --board nrf52dk/nrf52832 -- -DCONF_FILE="prj.conf" -DEXTRA_DTC_OVERLAY_FILE=npm1300.overlay -DDTC_OVERLAY_FILE=boards/nrf52dk_nrf52832.overlay -DDEBUG_THREAD_INFO=On -DCONFIG_DEBUG_THREAD_INFO=y -DSHIELD=npm1300_ek -Dnpm13xx_ek_DEBUG_THREAD_INFO=Off
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: /home/thomas/ncs/toolchains/43683a87ea/usr/local/bin/python3.12 (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: /home/thomas/.cache/zephyr
    -- Found west (found suitable version "1.4.0", minimum required is "0.14.0")
    -- Board: nrf52dk, qualifiers: nrf52832
    -- Shield(s): npm1300_ek
    Parsing /home/thomas/ncs/v3.2.0/zephyr/share/sysbuild/Kconfig
    Loaded configuration '/home/thomas/ncs/v3.2.0/zephyr/samples/shields/npm13xx_ek/build/_sysbuild/empty.conf'
    Merged configuration '/home/thomas/ncs/v3.2.0/zephyr/samples/shields/npm13xx_ek/build/_sysbuild/empty.conf'
    Configuration saved to '/home/thomas/ncs/v3.2.0/zephyr/samples/shields/npm13xx_ek/build/zephyr/.config'
    Kconfig header saved to '/home/thomas/ncs/v3.2.0/zephyr/samples/shields/npm13xx_ek/build/_sysbuild/autoconf.h'
       * Running CMake for npm13xx_ek *
    -- Application: /home/thomas/ncs/v3.2.0/zephyr/samples/shields/npm13xx_ek
    -- CMake version: 3.21.0
    -- Found Python3: /home/thomas/ncs/toolchains/43683a87ea/usr/local/bin/python (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Zephyr version: 4.2.99 (/home/thomas/ncs/v3.2.0/zephyr)
    -- Found host-tools: zephyr 0.17.0 (/home/thomas/ncs/toolchains/43683a87ea/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (/home/thomas/ncs/toolchains/43683a87ea/opt/zephyr-sdk)
    -- Found Dtc: /home/thomas/ncs/toolchains/43683a87ea/usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6")
    -- Found BOARD.dts: /home/thomas/ncs/v3.2.0/zephyr/boards/nordic/nrf52dk/nrf52dk_nrf52832.dts
    -- Found devicetree overlay: /home/thomas/ncs/v3.2.0/zephyr/boards/shields/npm1300_ek/npm1300_ek.overlay
    -- Found devicetree overlay: boards/nrf52dk_nrf52832.overlay
    -- Found devicetree overlay: npm1300.overlay
    -- Generated zephyr.dts: /home/thomas/ncs/v3.2.0/zephyr/samples/shields/npm13xx_ek/build/npm13xx_ek/zephyr/zephyr.dts
    -- Generated pickled edt: /home/thomas/ncs/v3.2.0/zephyr/samples/shields/npm13xx_ek/build/npm13xx_ek/zephyr/edt.pickle
    -- Generated devicetree_generated.h: /home/thomas/ncs/v3.2.0/zephyr/samples/shields/npm13xx_ek/build/npm13xx_ek/zephyr/include/generated/zephyr/devicetree_generated.h
    Parsing /home/thomas/ncs/v3.2.0/zephyr/Kconfig
    Loaded configuration '/home/thomas/ncs/v3.2.0/zephyr/boards/nordic/nrf52dk/nrf52dk_nrf52832_defconfig'
    Merged configuration '/home/thomas/ncs/v3.2.0/zephyr/samples/shields/npm13xx_ek/prj.conf'
    Merged configuration '/home/thomas/ncs/v3.2.0/zephyr/samples/shields/npm13xx_ek/build/npm13xx_ek/zephyr/misc/generated/extra_kconfig_options.conf'
    Merged configuration '/home/thomas/ncs/v3.2.0/zephyr/samples/shields/npm13xx_ek/build/npm13xx_ek/zephyr/.config.sysbuild'
    Configuration saved to '/home/thomas/ncs/v3.2.0/zephyr/samples/shields/npm13xx_ek/build/npm13xx_ek/zephyr/.config'
    Kconfig header saved to '/home/thomas/ncs/v3.2.0/zephyr/samples/shields/npm13xx_ek/build/npm13xx_ek/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: /home/thomas/ncs/toolchains/43683a87ea/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
    -- Found assembler: /home/thomas/ncs/toolchains/43683a87ea/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    -- Using ccache: /home/thomas/ncs/toolchains/43683a87ea/usr/bin/ccache
    -- Found gen_kobject_list: /home/thomas/ncs/v3.2.0/zephyr/scripts/build/gen_kobject_list.py
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/thomas/ncs/v3.2.0/zephyr/samples/shields/npm13xx_ek/build/npm13xx_ek
    -- Configuring done
    -- Generating done
    [5/234] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.2.99 (/home/thomas/ncs/v3.2.0/zephyr), build: ncs-v3.2.0
    [234/234] Linking C executable zephyr/zephyr.elf
               FLASH:      109680 B       512 KB     20.92%
                 RAM:       19488 B        64 KB     29.74%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from /home/thomas/ncs/v3.2.0/zephyr/samples/shields/npm13xx_ek/build/npm13xx_ek/zephyr/zephyr.elf for board: nrf52dk
    [10/10] Generating ../merged.hex
    the lower Version(s) of nRF Connect and Zeohyr shouldn't be an issue?
    nRF52_DK_usr said:
    USB-C is connected to "USB PMIC" and the Battery to /P1-header,
    VBATIN & VBAT are connected via Jumper.
    On the nrf52 DK i use VDD (between RESET and 5V) on P1 header connected to VDDIO ot the TWI npm1300_EK header.
    (P2) NTC & 10k are connected via jumper.
    SDA -> P0.26
    SCL->P0.27
    Compiling the mentioned example, after manually adding set(SHIELD npm1300_ek) in CMakeLists.txt) results in the folllowing output:
    This is the same setup as I have.
    What about P18? Is there a jumper present on this header?
    This one should not be present if the voltages differs between the NPM EK and nRF DK.
    Could you share a picture of how the jumpers are setup on your NPM1300-EK?
    Håkon
  • On P18 is no jumper. See my jumper configuration picture attached.
  • HI, what about the SHIELD detect pins on the nRF52 DK using the I/O expander for boards that follow arduino standard, see from the nRF52 DK userguide v3.x.x?
    "The I/O expander releases these GPIOs for general use when the nRF52 DK is used together with boards
    that follow the Arduino standard. The I/O expander can be permanently enabled by shorting solder bridge
    SB18, or permanently disabled by cutting the shorting track on SB19. You must also short SB18 when
    cutting SB19 for full compatibility with the Arduino standard.
    The I/O expander can be temporarily enabled by connecting SHIELD DETECT to ground."
