no device npm1300_ek (one button sample) with nRF52 DK on I2C Bus
I try to get the one button sample to work. There were several details missing to be able to compile and run this sample, which was very frustrating. After editing/updating the
prj.conf: CONFIG_I2C=y
CMakeLists.txt: set(SHIELD npm1300_ek)
nrf52dk_nrf52832.overlay:
 #include <zephyr/dt-bindings/pinctrl/nrf-pinctrl.h>
 &i2c1 {
 status = "okay";
 pinctrl-0 = <&i2c1_default>;
 pinctrl-1 = <&i2c1_sleep>;
 clock-frequency = <I2C_BITRATE_STANDARD>;
 //clock-frequency = <10000>;
 &i2c1_default {
 group1 {
 psels = <NRF_PSEL(TWIM_SDA, 0, 26)>,
 <NRF_PSEL(TWIM_SCL, 0, 27)>;
 bias-pull-up;
&i2c1_sleep {
 group1 {
 low-power-enable;
My zephyr.dts i2c1 snippet:
/* node '/soc/i2c@40004000' defined in zephyr/dts/arm/nordic/nrf52832.dtsi:172 */
		i2c1: i2c@40004000 {
			#address-cells = < 0x1 >;      /* in zephyr/dts/arm/nordic/nrf52832.dtsi:181 */
			#size-cells = < 0x0 >;         /* in zephyr/dts/arm/nordic/nrf52832.dtsi:182 */
			reg = < 0x40004000 0x1000 >;   /* in zephyr/dts/arm/nordic/nrf52832.dtsi:183 */
			interrupts = < 0x4 0x1 >;      /* in zephyr/dts/arm/nordic/nrf52832.dtsi:184 */
			easydma-maxcnt-bits = < 0x8 >; /* in zephyr/dts/arm/nordic/nrf52832.dtsi:185 */
			zephyr,pm-device-runtime-auto; /* in zephyr/dts/arm/nordic/nrf52832.dtsi:187 */
			compatible = "nordic,nrf-twi"; /* in zephyr/boards/nordic/nrf52dk/nrf52dk_nrf52832.dts:188 */
			status = "okay";               /* in ../../../../mnt/df01dc22-f3bf-40d5-9858-752a58c9832d/devprojects/nordicsemi/npm13xx_one_button/build/npm13xx_one_button/zephyr/boards/nrf52dk_nrf52832.overlay:9 */
			pinctrl-0 = < &i2c1_default >; /* in ../../../../mnt/df01dc22-f3bf-40d5-9858-752a58c9832d/devprojects/nordicsemi/npm13xx_one_button/build/npm13xx_one_button/zephyr/boards/nrf52dk_nrf52832.overlay:10 */
			pinctrl-1 = < &i2c1_sleep >;   /* in ../../../../mnt/df01dc22-f3bf-40d5-9858-752a58c9832d/devprojects/nordicsemi/npm13xx_one_button/build/npm13xx_one_button/zephyr/boards/nrf52dk_nrf52832.overlay:11 */
			pinctrl-names = "default",
			                "sleep";       /* in ../../../../mnt/df01dc22-f3bf-40d5-9858-752a58c9832d/devprojects/nordicsemi/npm13xx_one_button/build/npm13xx_one_button/zephyr/boards/nrf52dk_nrf52832.overlay:12 */
			clock-frequency = < 0x186a0 >; /* in ../../../../mnt/df01dc22-f3bf-40d5-9858-752a58c9832d/devprojects/nordicsemi/npm13xx_one_button/build/npm13xx_one_button/zephyr/boards/nrf52dk_nrf52832.overlay:13 */
with claudes assistance/support i got it to compile and run. But an i2c scan i2c0 shows no device at all.
What minimal required steps/configuration have to setup to get I2C enabled and detect devices on the bus should be?
Trying with the nrf-connect (Ubuntu) Linux-Desktop app (2x USB -C, 1x LiPo Battery) i get NPM detected, the LiPo Battery to and can change parameters for ex. the LED's live, so the BOARD is working.
Any support/hint/help is appreciated.
  • HI, i tried some LOG_DBG and some LED switching....with worked partially but is confusing too.
    static const struct device *leds_npm = NPM13XX_DEVICE(leds);
    	k_sleep(K_MSEC(100));
    	LOG_DBG("=====Boot complete=====");
    	int err = i2c_is_ready_dt(&i2c_spec);
    	k_sleep(K_MSEC(1000));
    	printk("====One Button===\n");
    	//printk("PMIC Init Status: %d\n", device_init(pmic->state));
    	LOG_DBG("I2C bus state: %d", err);
    	LOG_DBG("I2C0 state: %p", (void*)i2c->state);
    	LOG_DBG("LEDs name: %s\n", leds_npm->name);
    	LOG_DBG("LEDs ready: %d\n", device_is_ready(leds));
    	LOG_DBG("PMIC name: %s", (pmic->name));
    	LOG_DBG("PMIC state: %p", (void*)pmic->state);
    	//LOG_DBG("PMIC config: %s", pmic->ops);
    	LOG_DBG("Charger name: %s", (charger->name));
    	if (!device_is_ready(leds)) {
    		printk("Error: led device is not ready\n");
    		//return 0;
    	if (!configure_events()) {
    		printk("Error: could not configure events\n");
    		//return 0;
    	while (1) {
    		led_on(leds_npm, 2U);
    		k_msleep(flash_time_ms);
    		led_off(leds_npm, 2U);
    The amber LED is blinking, removing SDA/SDC or Jumper on P17 results in no blinking.
    Adding another LED1 by:
    -adapt npm1300.overlay with: >nordic,led1-mode="host";<
    pristine rebuild DOESN'T work, against expectation. Why?
    The LED is "not ready", but switching in a while loop, so the I2C signal from nRF52 DK is obviously working. Confusing.
    Here is the .hex that I used for testing:
    8400.zephyr.hex
    And here is a picture of my setup:
    It is similar to yours, and I also tried setting up similar to your setup (P15 header), and still did not see any issues.
    Could you try my .hex file and see if this behaves similar?
    Håkon
  • HI, thanks for the file, but how do i flash the hexfile onto my nRF52 DK in VS Code?
  • You can use nrfutil from cmd line:
    nrfutil device program --firmware zephyr.hex
    Or you can use the nRF connect for desktop -> "Programmer" application if you want a graphical interface.
    Håkon
  • *** Booting nRF Connect SDK v3.3.0-ba167d9f3db4 ***
    *** Using Zephyr OS v4.3.99-fd9204a02d52 ***
    Set up button at gpio@50000000 pin 13
    V: 4.165 I: 0.0001 T: 24.79
    Charger Status: 5, Error: 0, VBUS: connected
    V: 4.165 I: 0.0003 T: 24.79
