I want to use a new source LF clock to raise the precision from +-250ppm to around +-20ppm. I already have an oscillator mounted in my PCB, so I want to use it for BLE. I need very high precision (<10us), so this would be a great upgrade. The external oscillator is SiT1533 (SiT1533AI-H4-DCC-32.768D SiTime | Mouser United Kingdom). The variant only allows for rail-to-rail mode.
Setup
- nRF5340, NCS v2.8.0, target
nrf5340dk/nrf5340/cpuapp(secure, no TF-M). - Sysbuild with
hci_ipcnetcore image (SDC + MPSL). - External rail-to-rail 32.768 kHz clock, ~20 ppm, wired to XL1 only, XL2 floating, no external caps. The source toggles correctly before firmware boots.
- Use case: BLE controller-time sync, target precision < 10 µs.
Conflicts:
- XL1 already assigned to
spi_heepoMOSI in P0.00. Also, P0.00 attached to an interrupt from an outside sensor. Currently not enabled nor connected. I tried to deactivate both at least in firmware. In HW they doesn't seem to introduce any noisy signal. - XL2 already assigned to flash pin, but not really used. In HW it apparently introduces a small signal of around 10mV peak to peak and 32,768 KHz. Could this be a problem?
Application prj.conf
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM=y
CONFIG_SOC_ENABLE_LFXO=y
CONFIG_SOC_LFXO_CAP_EXTERNAL=y
(_EXT_FULL_SWING was dropped per DRGN-15064.)
Netcore sysbuild/hci_ipc.conf — same K32SRC_XTAL + 20PPM to match the app core (per DevZone #120382).
BYPASS bit — nrfx HAL helper nrf_oscillators_lfxo_bypass_set() doesn't expand on this SoC (DevZone #111425), so we write the register directly:
static int lfclk_bypass_full_swing(void) {
NRF_OSCILLATORS->XOSC32KI.BYPASS = 1;
return 0;
SYS_INIT(lfclk_bypass_full_swing, EARLY, 0); // also tried PRE_KERNEL_1, 0
DT — no lfxo node label in NCS v2.8.0 yet (lands later via Zephyr PR #92664), so we rely entirely on Kconfig.
Symptom
- After flashing, the firmware doesn't boot. RTT attaches but no log output → looks like a hang in
PRE_KERNEL_1waiting forLFCLKSTARTED. However, I tried to use EARLY for SYS_INIT without success. - On the scope, the external 32.768 kHz signal at XL1 stops toggling after the firmware runs LFXO init. A full power-cycle of the board (not just a debugger reset) is required to bring the external oscillator back.
- Reverting both cores to
K32SRC_RCrestores normal boot.
Questions
- What is the officially supported, race-free way in NCS v2.8.0 to configure an external rail-to-rail 32.768 kHz source on XL1, XL2 floating?
- Is the recommended workaround to set
CONFIG_SOC_ENABLE_LFXO=nand do all four steps (BYPASS=1→LFXO_CAP=External→XL1/XL2 MCUSEL=Peripheral) ourselves in one SYS_INIT atEARLY, 0? - Any additional netcore Kconfigs needed for MPSL/SDC with an external LFXO source?
Happy to share full configs, overlay and scope traces.
