In this post DECT NR+ power class and bandwidth/data rate dejans mentioned:
"Maximum theoretical peak data rate is 3.4 Mbps when transmission is scheduled into packets of 4 slots using MCS4, and these 4 slot packets are transmitted back-to-back. In this case, each of the physical layer packets carries 5600 bits which gives the rate of 5600bits / (4*416 us) =3,36Mbit/s. However, there is currently a limitation of scheduling packets back-to-back. Due to this firmware limitation, maximum achievable rate is 2.4 Mbps. Maximum peak data rates with 4 slot packets are 0.552, 1.118, 1.646, 2.222 and 3.360 Mbit/s for MCS0, 1, 2, 3 and 4, respectively."
Has this changed with the v2.0.0 PHY firmware?
