Different LTE-M current consumption behaviors and RAI inactivity handling on nRF9151
We are currently performing power consumption measurements on the Nordic nRF9151 using the PPK2 in LTE-M with an Objenious SIM card.
During our tests, we observed two different network behaviors leading to significantly different current consumption profiles, even when running exactly the same test scenario.
1. Different network attach behaviors and current consumption
The attached screenshots correspond to:
  • Same firmware
  • Same LTE-M configuration
  • Same SIM card
  • Same location and radio conditions
  • Same test procedure
The test simply consists of:
  1. Setting CFUN=1
  2. Waiting for network registration
  3. Repeating the same attach sequence again a few seconds later without changing any parameter
Despite this, we observe two different attach behaviors with very different energy consumption, in some cases almost double.
Logs:
[2026-05-26 09:56:37.039] at+cfun=1
[2026-05-26 09:56:37.897]
[2026-05-26 09:56:37.898] OK
[2026-05-26 09:56:38.982]
[2026-05-26 09:56:38.982] +CEREG: 2,"E485","093F9E11",7
[2026-05-26 09:56:40.786]
[2026-05-26 09:56:40.786] +CEREG: 1,"E485","093F9E11",7,,,"11100000","11100000"
[2026-05-26 09:56:47.918] at+cfun=0
[2026-05-26 09:56:49.870] +CEREG: 1,"E485","093F9E10",7,,,"11100000","11100000"
[2026-05-26 09:56:54.306]
[2026-05-26 09:56:54.788]
[2026-05-26 09:56:54.788] OK
[2026-05-26 09:56:54.788] +CEREG: 0
[2026-05-26 09:56:57.621] at+cereg=5
[2026-05-26 09:56:58.961]
[2026-05-26 09:56:58.962] OK
[2026-05-26 09:57:02.461] at+cfun=1
[2026-05-26 09:57:03.198]
[2026-05-26 09:57:03.198] OK
[2026-05-26 09:57:04.593]
[2026-05-26 09:57:04.593] +CEREG: 2,"E485","093F9E10",7
[2026-05-26 09:57:05.015]
[2026-05-26 09:57:05.015] +CEREG: 1,"E485","093F9E10",7,,,"11100000","11100000"
[2026-05-26 09:57:15.791] at+cfun=0
[2026-05-26 09:57:22.234]
[2026-05-26 09:57:22.234] OK
[2026-05-26 09:57:22.236]
[2026-05-26 09:57:22.236] +CEREG: 0
[2026-05-26 09:57:26.291] at+cereg=5
[2026-05-26 09:57:27.091]
[2026-05-26 09:57:27.091] OK
[2026-05-26 09:57:29.946] at+cfun=1
[2026-05-26 09:57:30.901]
[2026-05-26 09:57:30.901] OK
[2026-05-26 09:57:32.098]
[2026-05-26 09:57:32.098] +CEREG: 2,"E485","093F9E10",7
[2026-05-26 09:57:32.508]
[2026-05-26 09:57:32.508] +CEREG: 1,"E485","093F9E10",7,,,"11100000","11100000"
[2026-05-26 09:57:41.527] at+cops?*
[2026-05-26 09:57:46.284]
[2026-05-26 09:57:46.284] +COPS: 0,2,"20820",7
[2026-05-26 09:57:46.286]
[2026-05-26 09:57:46.288] OK
[2026-05-26 09:58:36.929] AT%XSYSTEMMODE?
[2026-05-26 09:58:38.099]
[2026-05-26 09:58:38.099] %XSYSTEMMODE: 1,0,0,0
[2026-05-26 09:58:38.105]
[2026-05-26 09:58:38.105] OK
We also observe similar behavior differences during:
  • UDP transmissions
  • DTLS handshake procedures
However, with other operators (for example Orange), we do not observe these differences, which makes us think this could be related to operator-side LTE-M configuration or network behavior.
Could you please help us understand:
  • What LTE-M signaling or network procedures could explain these differences?
2. RAI behavior and inactivity timer reduction in NB-IoT protocol
We are also testing RAI behavior on the nRF9151 in order to reduce the inactivity time after UDP transmissions.
We enabled RAI using:
AT%RAI=2
Relevant logs:
AT%RAI=2
OK
AT+CFUN=1
OK
+CEREG: 2,"C3D1","093F9ED8",9
%RAI: "093F9ED8","20820",0,1
+CEREG: 1,"C3D1","093F9ED8",9,,,"11100000","11100000"
From the %RAI notification, it seems that:
  • AS-RAI is disabled by the network
  • CP-RAI is enabled
Based on our understanding, CP-RAI should reduce the inactivity time after uplink UDP transmissions in NB-IoT protocol.
We verified this behavior with another modem platform, where enabling CP-RAI effectively reduces the inactivity duration.
However, on the nRF9151, enabling:
AT%RAI=2
does not seem to change the inactivity duration or current consumption behavior after UDP transmissions.
Could you please confirm:
  1. Is AT%RAI=2 the correct command to enable CP-RAI on nRF9151 for UDP traffic?
  2. Is there a modem trace or debug method allowing us to verify whether the RAI indication is actually transmitted and accepted by the network?
Thank you.
    Thank you for your explanation.
    I checked the firmware running on the device and confirmed that I am using SLM.
    AT#XSLMVER
    #XSLMVER: "2.6.0","2.6.1-lte-11b6ed4846a8"
    I then tried to apply the RAI configuration using the socket option you suggested.
    First, I tested with #XSSOCKETOPT, but it returned an error:
    AT#XSSOCKETOPT=1,61,2
    ERROR
    Then I tried with #XSOCKETOPT:
    AT#XSOCKETOPT=1,61,2
    OK
    After that I executed the complete DTLS flow:
    AT#XSSOCKET=1,2,0,1001
    AT#XCONNECT="<server>",4433
    AT#XSEND="ABABABA"
    The transmission completed successfully.
    I also verified that %RAI notification is still showing:
    (Network CP-RAI enabled, AS-RAI disabled)
    However, after comparing the PPK2 measurements with my previous tests (without AT#XSOCKETOPT=1,61,2), I do not observe any visible reduction of the inactivity duration or overall energy consumption.
    The current profile after transmission appears very similar to the previous behavior.
    Logs:
    [2026-06-03 09:04:43.223] at
    [2026-06-03 09:04:43.224] Ready
    [2026-06-03 09:04:43.225] at
    [2026-06-03 09:04:43.225] OK
    [2026-06-03 09:04:43.225] AT#XSMVER
    [2026-06-03 09:04:43.226] ERROR
    [2026-06-03 09:04:43.226] AT#XSLMVER
    [2026-06-03 09:04:43.226] #XSLMVER: "2.6.0","2.6.1-lte-11b6ed4846a8"
    [2026-06-03 09:04:43.226] OK
    [2026-06-03 09:04:43.227] at
    [2026-06-03 09:04:43.227] OK
    [2026-06-03 09:04:43.227] at+cops?
    [2026-06-03 09:04:43.227] +COPS: 1
    [2026-06-03 09:04:43.228] OK
    [2026-06-03 09:04:43.228] at+cops=0
    [2026-06-03 09:04:43.230] AT%RAI=1
    [2026-06-03 09:04:43.230] OK
    [2026-06-03 09:04:43.230] AT%XSYSTEMMODE=0,1,0,0
    [2026-06-03 09:04:43.230] AT%XSYSTEMMODE?
    [2026-06-03 09:04:43.230] %XSYSTEMMODE: 0,1,0,0
    [2026-06-03 09:04:43.235] at+cfun=0
    [2026-06-03 09:04:43.235] OK
    [2026-06-03 09:04:43.235] AT%RAI=2
    [2026-06-03 09:04:43.236]
    [2026-06-03 09:04:43.236] OK
    [2026-06-03 09:04:43.236] AT%XSYSTEMMODE?
    [2026-06-03 09:04:43.236] %XSYSTEMMODE: 0,1,0,0
    [2026-06-03 09:04:43.237] OK
    [2026-06-03 09:04:43.237] at+cfun=1
    [2026-06-03 09:04:43.237] %RAI: "093F9ED9","20820",0,1
    [2026-06-03 09:04:43.238] at+cops?
    [2026-06-03 09:04:43.238] +COPS: 0,2,"20820",9
    [2026-06-03 09:04:43.238] OK
    [2026-06-03 09:04:43.238] AT+CEINFO?
    [2026-06-03 09:04:43.239]
    [2026-06-03 09:04:43.239] +CEINFO: 0,1,I,8,2,-119,3
    [2026-06-03 09:04:43.239] OK
    [2026-06-03 09:04:43.239] at+cedrxs?
    [2026-06-03 09:04:43.240]
    [2026-06-03 09:04:43.240] +CEDRXS: 4,"1100"
    [2026-06-03 09:04:43.240] +CEDRXS: 5,"1100"
    [2026-06-03 09:04:43.240] OK
    [2026-06-03 09:04:43.241] AT#XSSOCKET=1,2,0,1001
    [2026-06-03 09:04:43.241] #XSSOCKET: 0,2,273
    [2026-06-03 09:04:43.242]
    [2026-06-03 09:04:43.242] OK
    [2026-06-03 09:04:43.242] AT#XSSOCKETOPT=1,61,2
    [2026-06-03 09:04:43.242] ERROR
    [2026-06-03 09:04:43.243] AT#XSOCKETOPT=1,61,2
    [2026-06-03 09:04:43.243] OK
    [2026-06-03 09:04:43.243] AT#XCONNECT="91.134.105.76",4433
    [2026-06-03 09:04:43.244] #XCONNECT: 1
    [2026-06-03 09:04:43.244] OK
    [2026-06-03 09:04:43.244] %RAI: "093F9ED8","20820",0,1
    [2026-06-03 09:04:43.244] AT#XSEND="ABABABA"
    [2026-06-03 09:04:43.245] #XSEND: 7
    [2026-06-03 09:04:43.245] OK
    [2026-06-03 09:04:43.245] AT#XSOCKETOPT=0
    [2026-06-03 09:04:43.245] ERROR
    [2026-06-03 09:04:43.247] AT#XSEND="ABABABA"
    [2026-06-03 09:04:43.248] #XSEND: 7
    [2026-06-03 09:04:43.248] OK
    Thank you.
    I also tried to test SMS functionality on the same setup, but I am facing issues.
    My network attachment is successful:
    +CEREG: 0,1,"E485","093F9E10",7
    However, SMS commands do not seem to work.
    When using SLM SMS command:
    AT#XSMS=1
    ERROR
    When using standard AT SMS commands:
    AT+CMGF=1
    +CMS ERROR: 302
    Could you please confirm whether SMS functionality is supported in SLM v2.6.0 (nRF Connect SDK 2.6.1)?
    Or is SMS support disabled by default in this firmware configuration?
    Thank you.
    Thanks for you logs and confirming you are using Serial Modem. Can you please try out this sequence:
    AT#XSEND="ABABABA"
    AT#XSOCKETOPT=1,61,1
    As it looks that CP-RAI requires both RAI_LAST and RAI_NO_DATA.
    And yes SMS functionality is supported in Serial Modem, please make sure CONFIG_SM_SMS=y is enabled in your configuration and secondly 302 means Not allowed, so you must check with your operator if the SMS service is supported in the SIM card.
    Best Regards,
    Syed Maysum
