External OTA related issue (SPI + External Flash + OTA)
Hi Team,
I am working on OTA using an external Winbond flash IC (W25Q64) with the nRF52832 controller in NCS SDK version 2.9.2. I have completed all the required configurations, but I am still facing errors during the OTA process.
Currently, I am testing with a simple connectable beacon application. I am sharing all the related files and RTT logs below. Could you please help me identify what is going wrong in the configuration or implementation?
I have shared the logs and files below:
Logs *** Booting MCUboot v2.1.0-dev-12e5ee106034 ***
*** Using nRF Connect SDK v2.9.0-7787b2649840 ***
*** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
[00:00:00.002,777] <inf> mcuboot: Starting bootloader
[00:00:00.003,082] <err> mcuboot: Failed to open flash area ID 1 (image 0 slot 1): -19, cannot continue
files:
  1. my_crt2.dts
  2. my_crt.overlay
  3. my_crt.dtsi
  4. mcuboot.conf
  5. mcuboot.overlay
Please review them and let me know if there are any issues in the configuration.
my_crt2_dts
/dts-v1/;
#include <nordic/nrf52832_qfaa.dtsi>
#include "my_crt2-pinctrl.dtsi"
    model = "Custom Board auto generated by nRF Connect for VS Code";
    compatible = "embel_tech,my-crt2";
    chosen {
        zephyr,sram             = &sram0;
        zephyr,flash            = &flash0;
        zephyr,code-partition   = &slot0_partition;
        nordic,pm-ext-flash     = &w25q64;
&spi0 {
    status = "okay";
    pinctrl-0 = <&spi0_default>;
    pinctrl-1 = <&spi0_sleep>;
    cs-gpios = <&gpio0 26 GPIO_ACTIVE_LOW>;
    w25q64: w25q64@0 {
        compatible = "jedec,spi-nor";
        reg = <0>;
        status = "okay";
        spi-max-frequency = <8000000>;
        jedec-id = [ef 40 17];
        size = <0x800000>;
        sfdp-bfp = [
            e5 20 f1 ff  ff ff ff 03
            44 eb 08 6b  08 3b 04 bb
            ee ff ff ff  ff ff 00 ff
            ff ff 00 ff  0c 20 0f 52
            10 d8 00 ff  23 72 f5 00
            82 ed 04 cc  44 83 68 44
            30 b0 30 b0  f7 c4 d5 5c
            00 be 29 ff  f0 d0 ff ff
        has-dpd;
        t-enter-dpd = <3000>;
        t-exit-dpd  = <30000>;
        partitions {
            #address-cells = <1>;
            #size-cells = <1>;
            slot1_partition: partition@0 {
                label = "image-1";
                reg = <0x00000000 0x00069000>;
&flash0 {
    partitions {
        #size-cells = <1>;
        boot_partition: partition@0 {
            label = "mcuboot";
            reg = <0x00000000 DT_SIZE_K(48)>;
        slot0_partition: partition@c000 {
            label = "image-0";
            reg = <0x0000c000 0x00069000>;
        storage_partition: partition@75000 {
            label = "storage";
            reg = <0x00075000 DT_SIZE_K(44)>;
&gpiote {
    status = "okay";
&gpio0 {
    status = "okay";
    gpiote-instance = <&gpiote>;
my_crt2_overlay-
/* STEP 2.1 - Add external flash to application */
&w25q64 {
	status = "okay";
	chosen {
my_crt_dtsi
    /* SPI2 - replace pin numbers with your actual pins */
    spi0_default: spi0_default {
        group1 {
            psels = <NRF_PSEL(SPIM_SCK,  0, 30)>,
                    <NRF_PSEL(SPIM_MOSI, 0, 29)>,
                    <NRF_PSEL(SPIM_MISO, 0, 27)>;
    spi0_sleep: spi0_sleep {
        group1 {
            low-power-enable;
mcuboot.conf-
# ── Clock (nRF52832 custom board: no 32 kHz XTAL) ───────────────
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
# ── Console (RTT only, no UART on custom board) ──────────────────
CONFIG_SERIAL=n
CONFIG_UART_CONSOLE=n
CONFIG_CONSOLE=y
CONFIG_RTT_CONSOLE=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG=y
CONFIG_LOG_BACKEND_RTT=y
# ── SPI NOR driver (Exercise step 1.2) ──────────────────────────
CONFIG_GPIO=y
CONFIG_SPI=y
CONFIG_SPI_NOR=y
CONFIG_SPI_NOR_SFDP_DEVICETREE=y
CONFIG_FLASH=y
CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_NORDIC_QSPI_NOR=n
CONFIG_MULTITHREADING=y
# ── nRF52832 PAN-58 (SPIM errata workaround) ────────────────────
CONFIG_SOC_NRF52832_ALLOW_SPIM_DESPITE_PAN_58=y
# ── MCUboot sectors (Exercise step 4) ───────────────────────────
CONFIG_BOOT_MAX_IMG_SECTORS=512
mcuboot.overlay
&w25q64 {
    status = "okay";
    chosen {
    Do you have sysbuild.conf?
    You should have the following in the sysbuild.conf file
    SB_CONFIG_BOOTLOADER_MCUBOOT=y
    SB_CONFIG_PARTITION_MANAGER=y
    SB_CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
    SB_CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
    The -19 (ENODEV) error at runtime almost certainly means the W25Q64 device node is not visible to MCUboot.
    The size of the flash is also not correct in the overlay file. You can try the following overlay (sysbuild/mcuboot.overlay). The SPI configuration from the main dts file should also be included in the sysbuild mcuboot overlay.
    &pinctrl {
            group1 {
            group1 {
                low-power-enable;
    &spi0 {
        status = "okay";
        w25q64: w25q64@0 {
            reg = <0>;
            status = "okay";
            size = <0x4000000>;  /* 64 Mbit in bits */
            sfdp-bfp = [
            has-dpd;
        chosen {
    Sysbuild/mcuboot.conf
    # ── Console (RTT only) ──────────────────────────────────────────
    CONFIG_SERIAL=n
    CONFIG_CONSOLE=y
    CONFIG_LOG=y
    # ── SPI NOR flash driver ─────────────────────────────────────────
    CONFIG_GPIO=y
    CONFIG_SPI=y
    CONFIG_SPI_NOR=y
    CONFIG_FLASH=y
    # ── nRF52832 PAN-58 errata workaround ───────────────────────────
    # ── MCUboot sectors ─────────────────────────────────────────────
    Try these and do a pristin build. You can check if the error still persists there.
    Thanks.
    BR
    Kazi
    It is working after adding anomaly-58-workaround;.
    I have one question: Is it possible for the DFU service and DFU logo to be visible only when the user chooses to perform a firmware update? Otherwise, the DFU service and logo should remain hidden.
    Thanks.
    Rohit
  • Hello Rohit,
    It's good that sample works after adding anomaly-58 workaround. I am not fully cleat though how it helps. Because this error Failed to open flash area ID 1 (image 0 slot 1): -19  is related to mcuboot partition.
    ''I have one question: Is it possible for the DFU service and DFU logo to be visible only when the user chooses to perform a firmware update? Otherwise, the DFU service and logo should remain hidden.''
    I think this previous case (+) SMP (DFU) service enabling/disabling - can I set the default in kconfig? - Nordic Q&A - Nordic DevZone - Nordic DevZone is relevant to find the answer.
    Thanks.
    BR
    Kazi
