Hi
I'm encountering a problem than the ANT device cannot be scanned. you can use project "ble_ant_app_hrm_v324"(ncs 324), and modify "
Hi
Thanks for checking in, we're working to reproduce this issue now. Is the ANT traffic still the same as the sample project? How frequent are the 0x4015 errors? If you have a log with the latest code we can take a look.
The project ble_ant_app_hrm_v324.zip and ble_ant_app_hrm_v292.zip that I have provide before, the code is the same, but it has issuse running on V324, while it runs normally on V292. It seems to be unrelated to the printfs? Can you check the differences between the ncs v324 and v292?
HI
Did you find the reason why version 292 doesn't have this problem?
We're still attempting to reproduce the issue on our side with v3.2.4 and the modified handler. If you're able to share a log from that build, even a short one showing the first occurrence, that would be helpful.
As far as the v2.9.2 differences, there were no changes to event dispatch in the ANT components. We are evaluating SDK dependencies between versions to determine if timing and context changes exposed an issue. I will update you as soon as I have more information.
I can't reproduce the issue when no printfs in antplus_evt_handler for now. The issue feedback from our user. I will try to reproduce it. The picture is the log I record in user.
