Inquiry on Feasibility of Single-Slot BLE OTA for nRF54L05 Due to Memory Constraints (NCS v3.0.0)
Hi Nordic Support Team,
We are currently developing a product based on the nRF54L05 SoC using nRF Connect SDK (NCS) v3.0.0. Our application is facing significant Flash memory constraints; the device only has 500 KB of Flash, and we need to implement BLE OTA (Over-The-Air) firmware updates.
We initially tried the standard MCUboot dual-slot (primary + secondary) approach. However, this consumes most of the available Flash, leaving insufficient space for our application. As a result, our application code cannot fit in the primary slot. We also attempted to configure the system in single-slot mode using CONFIG_SINGLE_APPLICATION_SLOT=y to reclaim the secondary slot for our application. Unfortunately, this leads to a Kconfig warning indicating a conflict between MCUMGR_GRP_IMG (selected by NCS_SAMPLE_MCUMGR_BT_OTA_DFU_MCUBOOT) and MCUBOOT_BOOTLOADER_MODE_SINGLE_APP:
"warning: MCUMGR_GRP_IMG (defined at subsys/mgmt/mcumgr/grp/img_mgmt/Kconfig:15) has direct dependencies FLASH && IMG_MANAGER && !MCUBOOT_BOOTLOADER_MODE_SINGLE_APP && MCUMGR with value n, but is currently being y-selected by the following symbols: - NCS_SAMPLE_MCUMGR_BT_OTA_DFU_BACKEND_MCUBOOT..."
It appears that BLE DFU functionalities are incompatible with the single-slot configuration, a limitation we observed in previous DevZone threads.
Therefore, we would like to ask:
  1. Is there any officially supported method or workaround to perform single-slot BLE OTA on the nRF54L05 with NCS v3.0.0? Or is the current standard recommendation for nRF54L05 still limited to serial DFU (UART) only, as noted in previous discussions? We understand that single-slot update is supported for Serial Recovery, but we need an OTA solution.
  2. Are there any other techniques or upcoming features in NCS (e.g., image compression or a minimal single-slot SMP server) that could help us fit both the bootloader and a BLE DFU-capable application within the 500 KB Flash of the nRF54L05?
  3. If internal single-slot BLE OTA is not feasible, what are the recommended workarounds?
Any guidance or suggestions you could provide would be greatly appreciated.
Thank you for your support.
Best Regards,
Ryan
    Based on the single-slot configuration, I found that entering the firmware loader mode must be triggered by the application, and no OTA service is provided. Is there a way, similar to MCUboot, to provide an OTA service or an SMP service at the application layer, and then upgrade the program?
    Best Regards.
    Ryan
  • Your description requires dual slot (or external flash chip) if I understand it correctly.
    Single slot requires a switch to bootloader mode before you can transfer the update data to the device.
  • My current project needs to be like the nRF5_SDK: after connecting to the device, it should provide an OTA service and be able to directly send a zip package for upgrading. Is there a way to accomplish this design?
  • Hi ,
    I think my key issue right now is that I need a service to control the app project's jump to the firmware loader. The entire process is the same as in the nRF5 SDK. In the nRF5 SDK, I can use the following files provided in the SDK to initialize the OTA service.
    After connecting with the nRF Connect app, the mobile app shows a DFU option, and I can send a ZIP upgrade file. But with the current design, I need to handle this logic myself—for example, by detecting a specific character and then jumping to the firmware loader. However, the nRF Connect app does not display the DFU option (because there is no OTA service). So, can I use the OTA service provided in the older version of the SDK to simulate this jump behavior? That way, I would be able to meet my requirements.
    Best Regards.
    Ryan.
    I have created a test sample based on the single_slot sample that should support the nrf54l15dk/nrf54l05/cpuapp build target.
    single_slot.zip
    Additional build configuration to enable SMP service in the main app
    The SMP service allows you to send the a mcumgr command to reset the device into the FW Loader application.
    Resetting into the DFU mode with the nRF Device Manager app:
    After the reset you should see the device advertising as "FW Loader" if you go back to the scanner view. You can then reconnect and complete the FW update.
