Porting child image based project to sysbuild
Hi
We are currently porting a project with a custom board and custom netcore image to sysbuild.
My current problem is, that we have a custom project for the netcore image which was added to the appcore project via CMakeLists.txt and add_child_image.
How is this done via sysbuild nowadays?
The former child image needs to be build during appcore build and added to the domain netcore so sysbuild recognizes it.
I tried it with the sysbuild cmake file:
ExternalZephyrProject_Add(
    APPLICATION net_core
    SOURCE_DIR "${CMAKE_CURRENT_LIST_DIR}/../netcore-project"
    BOARD pan_ng_module/nrf5340/cpunet
set_property(GLOBAL PROPERTY DOMAIN_APP_CPUNET net_core)
set(CPUNET_PM_DOMAIN_DYNAMIC_PARTITION net_core CACHE INTERNAL "")
add_dependencies(${DEFAULT_IMAGE} net_core)
But then there is the net_provision.hex which I don't know why it is produced!
Do I need to define the image for the netcore domain differently?
Thanks for any hint!
Cheers,
Thilo
  • Hi Einnar
    when I offset my dts for flash1 with 0x0100000, then I get, when executing west flash:
    [error] [ Client] - Encountered error -173: Command erase_file executed for 4 milliseconds with result -173
    [error] [ Worker] - Address 0x02008800 does not map to a known memory.
    I figured, when I use 0x8800, the flash1 is automatically offset with 0x1000000, therefore I used the offsets instead of absoulte.
    so, thats my cpunet dtsi for the partitioning:
    &flash1 {
    	partitions {
    		#address-cells = <1>;
    		#size-cells = <1>;
    		b0n_partition: partition@0 {
    			label = "b0n";
    			reg = <0x0 0x8580>;
    		bl_storage: provision_partition: partition@8580 {
    			label = "b0-provision-data";
    			reg = <0x8580 0x280>;
    		cpunet_app_partition: s0_partition: partition@8800 {
    			label = "cpunet_app";
    			reg = <0x8800 0x37800>;
    When I activate SB_CONFIG_MERGED_HEX_FILES=y, I get an build error regarding net_provision hex missing:
    -- Configuring done (29.7s)
    -- Generating done (0.0s)
    -- Build files have been written to: ...... /build
    ninja: error: 'net_provision/zephyr/zephyr.hex', needed by 'merged_...._nrf5340_cpunet.hex', missing and no known rule to make it
    Am I missing something here?
    Thanks!
    Cheers,
    Thilo
  • Hi
    I think there are some problems regarding the move from pm_static.yml to devicetree.
    for flash one (cpunet) partition definiton, I need to define the partition offsets with an offset of 0x1000000.
    NRF/subsys/pcd/CMakeLists.txt:22
    math(EXPR s0_offset_address "${s0_partition_address} - ${flash_address}" OUTPUT_FORMAT HEXADECIMAL)
    s0_partition_address: 0x8800
    flash_address: 0x1000000
    s0_offset_address is then negative value. So I need to remove "- ${flash_address}" to have the correct offset here.
    The other part is the net_provision which simple uses 0x8800 but needs to use the 0x1008800 when creating the net_provision.hex to have the correct offset.
    the script NRF/scripts/bootloader/provision.py should add the offset of the dts parent in my case flash1 or the cmake script which is calling the provision.py
    I need to change these two positions to have a working fw.
    Cheers,
    Thilo
  • Hi Thilo,
    One thing first that I shoudl have asked about before. Which exact SDK version are you using?
    That said, assuming 3.4.0-rc1 or main, where there has been some significant changes. A key here, si how flash1 is defined for cpunet, with a range. See here.
  • Hi Einar
    sorry I should have mentioned the sdk version we use.
    we use 3.3.0 currently.
    Cheers,
    Thilo
  • Hi Thilo,
    I see. Then I would recommend continuing with the partiion manager for now (but consider removing it if you later move to NCS 3.4.0).
