Porting child image based project to sysbuild
Hi
We are currently porting a project with a custom board and custom netcore image to sysbuild.
My current problem is, that we have a custom project for the netcore image which was added to the appcore project via CMakeLists.txt and add_child_image.
How is this done via sysbuild nowadays?
The former child image needs to be build during appcore build and added to the domain netcore so sysbuild recognizes it.
I tried it with the sysbuild cmake file:
ExternalZephyrProject_Add(
    APPLICATION net_core
    SOURCE_DIR "${CMAKE_CURRENT_LIST_DIR}/../netcore-project"
    BOARD pan_ng_module/nrf5340/cpunet
set_property(GLOBAL PROPERTY DOMAIN_APP_CPUNET net_core)
set(CPUNET_PM_DOMAIN_DYNAMIC_PARTITION net_core CACHE INTERNAL "")
add_dependencies(${DEFAULT_IMAGE} net_core)
But then there is the net_provision.hex which I don't know why it is produced!
Do I need to define the image for the netcore domain differently?
Thanks for any hint!
Cheers,
Thilo
  • Hi Einar
    will try with 3.4.0-rc1! Cause I moved already to partition definition in the dts and don't want to step back.
    Cheers,
    Thilo
  • Hi Einar
    nope.
    With 3.4.0-rc1 the PCD CMakelists.txt still contains the problem, that it does not recognize the correct offset from the devicetree partitioning.
    ...../nrf-sdk-3.4.0/ZephyrSDK/nrf/subsys/pcd/src/pcd.c: In function 'network_core_pcd_cmdset':
    <command-line>: warning: overflow in conversion from 'long long unsigned int' to 'off_t' {aka 'long int'} changes value from '18446744073692809216' to '-16742400' [-Woverflow]
    ...../nrf-sdk-3.4.0/ZephyrSDK/nrf/subsys/pcd/src/pcd.c:205:49: note: in expansion of macro 'PCD_NET_CORE_APP_OFFSET'
      205 |         err = pcd_cmd_write(cmd, src_addr, len, PCD_NET_CORE_APP_OFFSET);
    and the net_provision.hex has the same problem.
    Error: One or more batch tasks failed:
    * 600104758: Device error: Address range 0x000085a8..0x000085c8 is outside the memory ranges defined for programming through the Network core (Generic)
    Address range is without the offset of flash1.
    Here are the changes which I need to add to make it work.
    Theses are workarounds and not fixes, but perhaps you understand better why I need to make theses and can give me an hint!
    diff --git a/scripts/bootloader/provision.py b/scripts/bootloader/provision.py
    index 0998176b75..7503e63c12 100644
    --- a/scripts/bootloader/provision.py
    +++ b/scripts/bootloader/provision.py
    @@ -269,7 +269,7 @@ def main():
         # The LCS and implementation ID is stored in the OTP before the
         # rest of the provisioning data so add it to the given base
         # address
    -    provision_address = args.provision_addr + num_bytes_provisioned_elsewhere
    +    provision_address = args.provision_addr + 0x1000000 + num_bytes_provisioned_elsewhere
         max_size = args.max_size - num_bytes_provisioned_elsewhere
         hashes = []
    diff --git a/subsys/pcd/CMakeLists.txt b/subsys/pcd/CMakeLists.txt
    index bdc04c4a65..d00fabef65 100644
    --- a/subsys/pcd/CMakeLists.txt
    +++ b/subsys/pcd/CMakeLists.txt
    @@ -19,6 +19,7 @@ if(CONFIG_PCD_APP AND NOT CONFIG_PARTITION_MANAGER_ENABLED)
       # TODO: Likely need rework when mapped-partition is available/used
       dt_chosen(flash_path PROPERTY "zephyr,flash" TARGET b0n_target)
       dt_reg_addr(flash_address PATH ${flash_path} TARGET b0n_target)
    -  math(EXPR s0_offset_address "${s0_partition_address} - ${flash_address}" OUTPUT_FORMAT HEXADECIMAL)
    +  message("remove \" - \${flash_address}\"")
    +  math(EXPR s0_offset_address "${s0_partition_address}" OUTPUT_FORMAT HEXADECIMAL)
       zephyr_library_compile_options("-DPCD_NET_CORE_APP_OFFSET=${s0_offset_address}")
     endif()
    Cheers
    Thilo
  • Hi Thilo,
    I see. I have discussed this internally but we are not able to explain why you see this. I suspect there may be some problems with your device tree configuration (from your board files or overlays), but I am having problems understanding how. Have you compared your board files to the DK files in v3.4.0-rc1 or main?
  • We created two dtsi files with the content generated via pm_to_dtsi.py.
    Added compatible fixed-partitions and address-cells and size-cells, both 1, and included theses dtsi into our common.dtsi files.
    Here is the cpunet_partitions.dtsi:
    	chosen {
    		zephyr,code-partition = &cpunet_app_partition;
    &flash1 {
    	partitions {
    		#address-cells = <1>;
    		#size-cells = <1>;
    		b0n_partition: partition@0 {
    			label = "b0n";
    			reg = <0x0 0x8580>;
    		bl_storage: provision_partition: partition@8580 {
    			label = "b0-provision-data";
    			reg = <0x8580 0x280>;
    		cpunet_app_partition: s0_partition: partition@8800 {
    			label = "cpunet_app";
    			reg = <0x8800 0x10000>;
    For b0n there is an overlay, so it is placed into the b0n_partition:
        chosen {
            zephyr,code-partition = &b0n_partition;
    Thats it.
    Other partitions (besides for the cpuapp in flash0) we do not have in our devicetree.
    When I add the flash offset to the parition offset, than the cpunet app has the wrong offset when trying to flash:
    -- runners.nrfutil: Flashing file: ..../build/net_core/../signed_by_b0_net_core.hex
    -- runners.nrfutil: Connecting to probe
    -- runners.nrfutil: Erasing address ranges touched by firmware
     * 600104758: Device error: Address range 0x02008800..0x0200fa18 is outside the memory ranges defined for programming through the Network core (Generic)
    So on the one hand, the flash offset is added, and on the other it is not.
    Any ideas?
    Cheers,
    Thilo
  • Hi Thilo,
    Looking at the error "Address range 0x02008800..0x0200fa18 is outside the memory ranges defined for programming through the Network core (Generic)", it seems you have some remains of earlier attempts of adding the 0x01000000 offset, and so that is added twice. That needs to be reverted.
