Porting child image based project to sysbuild
Hi
We are currently porting a project with a custom board and custom netcore image to sysbuild.
My current problem is, that we have a custom project for the netcore image which was added to the appcore project via CMakeLists.txt and add_child_image.
How is this done via sysbuild nowadays?
The former child image needs to be build during appcore build and added to the domain netcore so sysbuild recognizes it.
I tried it with the sysbuild cmake file:
ExternalZephyrProject_Add(
    APPLICATION net_core
    SOURCE_DIR "${CMAKE_CURRENT_LIST_DIR}/../netcore-project"
    BOARD pan_ng_module/nrf5340/cpunet
set_property(GLOBAL PROPERTY DOMAIN_APP_CPUNET net_core)
set(CPUNET_PM_DOMAIN_DYNAMIC_PARTITION net_core CACHE INTERNAL "")
add_dependencies(${DEFAULT_IMAGE} net_core)
But then there is the net_provision.hex which I don't know why it is produced!
Do I need to define the image for the netcore domain differently?
Thanks for any hint!
Cheers,
Thilo
  • Yeah correct but! Here we go:
    Partition Offset 0x1008800 in the partitions dtsi:
    Error one:
    -- runners.nrfutil: Flashing file: ..../build/net_core/../signed_by_b0_net_core.hex
    -- runners.nrfutil: Connecting to probe
    -- runners.nrfutil: Erasing address ranges touched by firmware
    Error: One or more batch tasks failed:
     * 600104758: Device error: Address range 0x02008800..0x0200fa18 is outside the memory ranges defined for programming through the Network core (Generic)
    Partition Offset 0x8800 without changes of me at the nrfsdk:
    Error one:
    /media/data/projects/pan-ng/nrf-sdk-3.3.0/ZephyrSDK/nrf/subsys/pcd/src/pcd.c: In function 'network_core_pcd_cmdset':
    <command-line>: warning: overflow in conversion from 'long long unsigned int' to 'off_t' {aka 'long int'} changes value from '18446744073692809216' to '-16742400' [-Woverflow]
    <command-line>: note: in definition of macro 'PCD_NET_CORE_APP_OFFSET'
    Error two:
    - runners.nrfutil: Flashing file: /media/data/projects/pan-ng/nrf-sdk-3.3.0/PAN-NG-PROD_APPCORE/build/net_provision.hex
    * 600104758: Device error: Address range 0x000085a8..0x000085c8 is outside the memory ranges defined for programming through the Network core (Generic)
    Either way, something wents wrong!
    IMHO, the parition offset with 0x8800 is the correct one in devicetree, so I tried to fix that.
    Cheers,
    Thilo
  • Hi Thilo,
    I see. I am not able to understand what is going on there. I put together (with help of AI) a minimal sample that demonstrat a nRF5340 project with mcuboot and b0n using sysbuild and without partition manager. This builds for the DK and seems to work as expected. Can you use that as a reference? It whoudl work out of the box on a nRF5340 DK when built with NCS v3.4.0-rc1 (and can together with the DK board files hopefully be used as a reference for your custom board).sysbuild_netcore_demo.zip
  • Hi Thilo,
    Not in the sense that I am not sure why things are not working with your project. But have you had a look at the demo I uploded earlier today? Does that work for you as well, and if so can you use that as a reference?
  • Hi Einar
    Thanks for the demo.
    This inspired me, to port our project to a nrf5340dk.
    Now I tracked the problem down to our board, as it does not happen with the nrf5340dk.
    Perhaps you can help me further. Here is the content of the nrf/subsys/pcd/CMakeLists.txt:
      add_custom_target(b0n_target)
      zephyr_dt_import(EDT_PICKLE_FILE ${CMAKE_BINARY_DIR}/../b0n/zephyr/edt.pickle TARGET b0n_target)
      dt_nodelabel(s0_partition_path NODELABEL s0_partition REQUIRED TARGET b0n_target)
      dt_reg_addr(s0_partition_address PATH ${s0_partition_path} TARGET b0n_target)
      # TODO: Likely need rework when mapped-partition is available/used
      dt_chosen(flash_path PROPERTY "zephyr,flash" TARGET b0n_target)
      dt_reg_addr(flash_address PATH ${flash_path} TARGET b0n_target)
      math(EXPR s0_offset_address "${s0_partition_address} - ${flash_address}" OUTPUT_FORMAT HEXADECIMAL)
      message(STATUS "CTCTCTCTCTC: ${s0_partition_path}: ${flash_address} ${s0_partition_address} ${s0_offset_address}")
      zephyr_library_compile_options("-DPCD_NET_CORE_APP_OFFSET=${s0_offset_address}")
    I added the "message" line.
    For the nrf5340dk, I get the following (which is correct):
    -- CTCTCTCTCTC: /soc/flash-controller@41080000/flash@1000000/partitions/partition@8800: 0x1000000 0x1008800 0x8800
    For our board I get the following:
    -- CTCTCTCTCTC: /soc/flash-controller@41080000/flash@1000000/partitions/partition@8800: 0x1000000 0x8800 0xffffffffff008800
    Which obviously is wrong.
    Now my question. How can this be?
    I added the partitions overlay for the nrf5340dk and have exactly the same partitions definition for our board.
    What am I missing?
    Thanks!
    Cheers,
    Thilo
