Peripheral access - failure analysis
Hi All, In the NRF54L15 SoC, the main ARM core and the co-processor RISC core share the same set of peripherals even though both the cores can have separate sections of RAM and Flash memories.
So, can the two cores have separate memory mapping for all the peripherals in the SoC so that failure in accessing the peripherals by one core do not affect peripheral access by the other core ?
The development setup iam planning to use are:
1. NRF54L15 based Off-the-shelf module
2. WIndows 11 host development PC
3. Bare-metal implementation on the SoC module
Let me know any more inputs required. Thanks in advance !
    That is an interesting question. I think it has the same memory mapping for the peripherals, and it is rather up to the user to make sure that there wont really be a conflict. Do you have a specific concern in mind?
    Elfving
  • So, if we assume that I map couple of peripherals like ADC and I2C to the RISC core, and in the field, during real-time operational use case, one of the peripherals fails ( like abnormal behavior) , then I would want the main ARM core to take over and gracefully complete (or atleast exit from) the operation.Is that possible in this SoC ?
    Also, another query is, if the peripherals are memory mapped, if there is any data / memory corruption in the memory map area, what is the effect on the access to the peripherals ?
    Thanks Elfving for your prompt response !  Looking forward to your inputs to the above concerns...
    Interesting. I don't think there are any HW features that helps this exact use-case, but this could be communicated between the cores and we have some sw frameworks for this. The most tempting idea to me would be to use a watchdog, to make the M33 take over when the flpr runs into an issue. But I can't really imagine how moving control to the main cpu would solve this potential issue, but the possibility is there I guess. I think whether this would work would depend on the peripheral, but I have seen some examples of two cores accessing one peripheral.
    I guess what exact effect depends on the problem. There is tamper protection and other security features on the 54L, though they might be a bit more SW-focused than something like hardware domain isolation and separate memory mapping for each core.
    I think I'd answer your question better if you could be even clearer about the use-case though. I can also make the case private if you prefer. Zephyr/NCS can be a bit strict about the SW architecture setup, but it typically has features needed to address whatever you are concerned about.
    Lesson 3 and 4 here might interest you, and clear things up.
    Elfving
