Configure and Connect nRF7002 to nRF52840 on SDK 2.2.2
I am using nRF52840 as host processor. Now I need to connect to nRF7002 for WiFi usage. I am using ncs 2.2.2 SDK. I have a few questions?
1. Does nRF7002 work on v2.2.2? I created the nRF7002 device on the device tree with "nordic,nrf7002-spi" compatible . However, I cannot link to it. The CONFIG_NRF700X_SPI=y is not supported.
error: undefined reference to `__device_dts_ord_133'
2. Can you provide an example of configure and link nRF7002 to nRF52840 on v2.2.2 SDK?
3. If I have to move to higher version of SDK, what is the steps to do the upgrade?
My device tree:
&spi1 {
status = "okay";
cs-gpios = <&gpio0 20 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&spi1_default>;
pinctrl-1 = <&spi1_sleep>;
nrf7002: nrf7002@0 {
compatible = "nordic,nrf7002-spi";
status = "okay";
reg = <0>; /* SPI chip select index */
spi-max-frequency = <8000000>; /* 8 MHz */
/*duplex = "full";*/ /* required for SPI_CONFIG_DT */
/*frame-format = "motorola";*/ /* required for SPI_CONFIG_DT */
label = "nrf7002";
/* GPIOs for control signals */
iovdd-ctrl-gpios = <&gpio0 10 GPIO_ACTIVE_HIGH>;
bucken-gpios = <&gpio0 11 GPIO_ACTIVE_HIGH>;
host-irq-gpios = <&gpio1 1 GPIO_ACTIVE_HIGH>;
/* Optional: COEX interface */
coex {
compatible = "nordic,nrf700x-coex";
grant-gpios = <&gpio1 2 GPIO_ACTIVE_HIGH>;
req-gpios = <&gpio1 3 GPIO_ACTIVE_HIGH>;
/*prio-gpios = <&gpio1 2 GPIO_ACTIVE_HIGH>;*/
status0-gpios = <&gpio1 5 GPIO_ACTIVE_HIGH>;
/*status1-gpios = <&gpio1 4 GPIO_ACTIVE_HIGH>;*/
My code:
const struct device *nrf7002_dev = DEVICE_DT_GET(DT_NODELABEL(nrf7002));
if (!device_is_ready(nrf7002_dev))
LOG_ERR("SPI device not ready\n");
return -1;
LOG_INF("SPI device READY\n");
Thank you.
    I assume you mean ncs v3.2.2?
    nRF7002 shall be supported in this version.
    In your device tree, try to add these sections (taken from the nrf7002eb device tree files):
     * Copyright (c) 2024 Nordic Semiconductor ASA
    #include <freq.h>
    	chosen {
    		zephyr,wifi = &wlan0;
    &spi1 {
    	status = "okay";
    	nrf70: nrf7002@0 {
    		status = "okay";
    		wlan0: wlan0 {
    			compatible = "nordic,wlan";
    		wlan1: wlan1 {
    		wifi-max-tx-pwr-2g-dsss = <21>;
    		wifi-max-tx-pwr-2g-mcs0 = <16>;
    		wifi-max-tx-pwr-2g-mcs7 = <16>;
    		wifi-max-tx-pwr-5g-low-mcs0 = <13>;
    		wifi-max-tx-pwr-5g-low-mcs7 = <13>;
    		wifi-max-tx-pwr-5g-mid-mcs0 = <13>;
    		wifi-max-tx-pwr-5g-mid-mcs7 = <13>;
    		wifi-max-tx-pwr-5g-high-mcs0 = <12>;
    		wifi-max-tx-pwr-5g-high-mcs7 = <12>;
    		...rest of your configuration..
    I suspect that the issue is the chosen "zephyr,wifi = &wlan0" is missing from your overlay.
    Could you check if this works as intended?
    Håkon
  • Sorry, I am using nRF Connect S?DK v2.2.0. I am still seeing the same issue. Where can I find the complete example of nRF7002 used in nRF52840?
    Thanks!
  • No chance in SDK 2.2.0. I don't see DTS bindings in my 2.6.1 SDK installation either.
    do see bindings in the SDK 2.9.2 version here, so this is probably close to the minimum required SDK version. But you should probably upgrade all the way to a recent 3.x version here while you are at it.
