Issue with k_sleep() in the ipt_initiator Sample.
I am currently testing the `ipt_initiator` sample on the nRF54L15-DK v1.0.0 using nRF Connect SDK v3.3.1.
When I call `k_sleep()` inside the loop in the `main()` function, the following error occurs:
I: Distance estimates: median: 0.95m, update: 0.98m, time_delta: 1012ms
I: Distance estimates: median: 0.98m, update: 0.99m, time_delta: 1514ms
I: Distance estimates: median: 0.98m, update: 0.89m, time_delta: 510ms
I: Distance estimates: median: 0.98m, update: 0.93m, time_delta: 1011ms
E: SoftDevice Controller ASSERT: 142, 151
E: ***** HARD FAULT *****
E: Fault escalation (see below)
E: ARCH_EXCEPT with reason 3
E: r0/a1: 0x00000003 r1/a2: 0x00000001 r2/a3: 0x00000000
E: r3/a4: 0x00000003 r12/ip: 0x00000000 r14/lr: 0x0002bbf9
E: xpsr: 0x210000f5
E: s[ 0]: 0x00000097 s[ 1]: 0x00323431 s[ 2]: 0x00000000 s[ 3]: 0x00000000
E: s[ 4]: 0x0002bbd5 s[ 5]: 0x000008d9 s[ 6]: 0x0000008e s[ 7]: 0x00323431
E: s[ 8]: 0x000057e4 s[ 9]: 0x000057e4 s[10]: 0x200027e0 s[11]: 0x000057c5
E: s[12]: 0x20002700 s[13]: 0x200023b0 s[14]: 0x200027f8 s[15]: 0x20001658
E: fpscr: 0x00000000
E: Faulting instruction address (r15/pc): 0x0002bc06
E: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
E: Fault during interrupt handling
E: Current thread: 0x20003f38 (unknown)
*** Booting nRF Connect SDK v3.3.1-1d7a0b0e49b8 ***
*** Using Zephyr OS v4.3.99-37e6c28576ee ***
I: Starting Channel Sounding IPT Initiator Sample
I: SoftDevice Controller build revision:
I: fc 51 7a e9 58 2c 6f fb |.Qz.X,o.
I: 6d 35 9f 17 3e 08 c8 c1 |m5..>...
I: 7b e9 5b 95 |{.[.
I: HW Platform: Nordic Semiconductor (0x0002)
I: HW Variant: nRF54Lx (0x0005)
I: Firmware: Standard Bluetooth control
This issue does not occur if I do not call `k_sleep()`.
My goal is to send the Channel Sounding measurement results to a smartphone every 500 ms. Is there a recommended way to achieve this without causing the above error?
I have attached the project ZIP file for your reference.
Thank you in advance for your support.
Best regards.
Kenta
cs_ipt_initiator.zip
  • Hi Kenta!
    If you just want to produce a single distance estimate every 500 ms you can change the connection interval and CS procedure interval that is being used in the ipt_initiator sample.
    Note that the CS procedure interval configured here https://github.com/nrfconnect/sdk-nrf/blob/b466e871ffdc67c6361a71012bbb706df971c51a/samples/bluetooth/channel_sounding/ipt_initiator/src/main.c#L645 is in units of connection intervals.
    The connection interval is configured here in the ipt_initiator: https://github.com/nrfconnect/sdk-nrf/blob/b466e871ffdc67c6361a71012bbb706df971c51a/samples/bluetooth/channel_sounding/ipt_initiator/src/main.c#L573
    You could for example change the connection interval to 50 ms by setting
    .conn_param = BT_LE_CONN_PARAM(40, 40, 0, BT_GAP_MS_TO_CONN_TIMEOUT(4000))
    and the CS procedure interval to 10 by setting
    	uint16_t desired_procedure_interval = 10;
    This will give a resulting CS procedure interval of 10 * 50 ms = 500 ms.
    The sample produces one distance estimate per CS procedure so you should see something like this in the logs:
    I: Distance estimates: median: 0.86m, update: 0.86m, time_delta: 500ms
    I: Distance estimates: median: 0.86m, update: 0.85m, time_delta: 500ms
    I: Distance estimates: median: 0.86m, update: 0.87m, time_delta: 500ms
    I: Distance estimates: median: 0.87m, update: 0.87m, time_delta: 500ms
    I: Distance estimates: median: 0.87m, update: 0.86m, time_delta: 500ms
    And note that the median estimate here might not make sense anymore if you are only estimating new distances every 500 ms unless you know both devices are stationary.
  • Hi, Erik.
    Great!
    That solved the problem!
    I'll stick with this approach and see how it goes.
    Thanks a lot!
    Kenta.
