RTT Viewer connecting to nrf5340 cpunet core will trigger a mass erase and afterwards one needs to recover the core
Hi all!
I need to see the printks and log messages from the b0n and cpunet app in RTT Viewer.
The problem is, whenever I connect with the SEGGER RTT Viewer to the netcore, I do get the following error message:
CTRL-AP indicates that the device is secured.
For debugger connection the device needs to be unsecured.
Note: Unsecuring will trigger a mass erase of the internal flash, SRAM and UICR of both the application and the network core.
In another ticket, Vidar answered me the following:
Hi Thilo,
It would better if you created a new ticket for this, but I will try to help here.
To troubleshoot this, please disable APPROTECT by using the nrfutil commands below (note: the order matters, netcore needs to be recovered first),
then try to connect the RTT viewer again to see if you get the same error (there will not be any logs).
nrfutil device recover --core network
nrfutil device recover --core application
Cheers
Vidar
Sadly that doesn't change anything. I execute the first command (recover netcore) and then connect via RTT Viewer and the same error message appears and the chip has no fw on it anymore.
Any other idea?
Cheers,
Thilo
  • Hi Vidar
    it looks like, that you are on the right track:
    (v3.4.0-rc1) cest@simt406:/media/data/projects/pan-ng/nrf-sdk-3.4.0/PAN-NG-PROD_APPCORE$ nrfutil device cpu-register-read --core network
    Error: One or more read cpu registers tasks failed:
     * 600104758: Failed to attach to target: The Network core access port is protected (All) (NotAvailableBecauseProtection)
    The operation was unavailable for some of the devices because they had readback protection enabled. These devices might be possible to unlock using the `recover` subcommand. See `nrfutil device recover --help` for more information.
    How can I it be, that our fw locks theses registers?
    I can flash your demo and connect with rtt viewer.
    But after I flash our fw, the netcore is protected again.
    How can I prevent it, to get protected when flashing our fw?
    Cheers,
    Thilo
  • Hi Thilo,
    If the netcore FW is going in a boot loop, it may be difficult to attach the debugger without using the recovery mechanism. Is that possibly what happens, or does the network core FW appear to function as it is supposed to?
    To try to confirm or rule out this, you can compile B0n and the other FW with CONFIG_RESET_ON_FATAL_ERROR set to "=n". This will prevent the device from entering an endless boot loop if a kernel panic is triggered.
    Cheers,
    Vidar
  • Hi Vidar
    Sorry for the delay. I had short priorities switch.
    I just tried it to add CONFIG_RESET_ON_FATAL_ERROR to both b0n and the netcore app, sadly it does not change anything.
    HW was our own board and a nrf5340dk.
    Cheers,
    Thilo
  • Hi Thilo,
    No problem. But would you be able to provide me a minimal version of your project that would allow me to reproduce this on my side? The only explanations I can think of now is that either you have some different APPROTECT settings (you can check the build/<netcore fw>/zephyr/.config to compare) that locks the debugger port, or that the app core is not powering on the network core for some reason.
    Cheers
    Vidar
  • Hi Vidar
    I minized the source files to two main.c at left the prj.confs for mcuboot, appcore app, b0n and netcore app.
    It still occurs as before so it is most probably something with the configs.
    min-example.zip
    Here are the commands I use to compile it:
    # open a toolchain shell:
    <path_to_nrf_toolchain>/nrfutil/bin/nrfutil sdk-manager toolchain launch --shell --toolchain-path <path_to_nrf_toolchain>
    # inside the shell
    . <path_to_nrfsdk>/zephyr/zephyr-env.sh
    west build --board nrf5340dk/nrf5340/cpuapp --pristine --sysbuild
    west flash --no-rebuild --recover
    I hope you can tell me whats going on.
    Thank you!
    Cheers,
    Thilo
    [EDIT]I just searched the zip, I did upload. It was above the "Hi Vidar" which is not recognizable place. So I moved the link more visible in the midth of the message.[/EDIT]
