trying to send and receive the data through can bus moduler using with nrf9160 and esp32 controller (using SPI)
can anyone help me with this situations that i'm facing from a 1 month so i'm connecting esp32 controller to seengreat RS485 Dual CAN Bus moduler and the other hand i'm connecting nrf9160 to seengreat RS485 Dual CAN Bus moduler but i can't send or receive any messages through this and i attach the both screenshot from nrf serial terminal and from esp32 controller terminal and also i attach my overlay code and my both project files. i tried with 125,250,500 KBPS bus speed but i didn't make it and this can bus moduler have 16MHZ and it has 120 ohm resister attached with the moduler and i tried spi-max-frequency = <125000>,<250000>, <500000>, <1000000>.WACS (2).zipWACS_esp32 (2).zip
here is my overlay file code
// can mcp2515 drivers overlay
&pinctrl {
    spi3_default: spi3_default {
        group1 {
            psels = <NRF_PSEL(SPIM_SCK, 0, 13)>,
                    <NRF_PSEL(SPIM_MOSI, 0, 11)>,
                    <NRF_PSEL(SPIM_MISO, 0, 12)>;
    spi3_sleep: spi3_sleep {
    group1 {
            low-power-enable;
    chosen {
        zephyr,canbus = &mcp2515;
&spi3 {
    status = "okay";
    pinctrl-0 = <&spi3_default>;
    pinctrl-1 = <&spi3_sleep>;
    cs-gpios = <&gpio0 25 GPIO_ACTIVE_LOW>;
    mcp2515: can@0 {
        compatible = "microchip,mcp2515";
        reg = <0>;
        spi-max-frequency = <250000>;
        int-gpios = <&gpio0 17 GPIO_ACTIVE_LOW>;
        osc-freq = <16000000>;
        bus-speed = <250000>;
        status = "okay";
// UART overlay
&uart2 {
    status = "okay";
    current-speed = <115200>;
i spend too much time on this and still didn't get anything from this so please help me to get through with this and what else i can do for debugging cuz i change the wires many times and now i order new can bus moduler to get confirmation about that is the moduler don't have the problem or what, i don't know
thanks
vivek
  • Hi syed,
    - one thing you have to know that i'm using seengreat rs485 dual CAN Bus module and i bought three of them, two from amazon and one from company's website cuz at first i thought there is something wrong with the CAN chip but now i still get the same result. i don't know what's wrong with this. please help me, i'm stuck in this situations from almost last three months.
    - I gave the VCC (power) from the esp32 to CAN module and it's 3.3v cuz i connect to 3.3v pin in esp32 so i didn't give the VCC (power) from nrf and i connect the nrf GND to esp32 GND.
    - When i run esp32 code, CANH = 2.23v and CANL = 1.38v and it's stays where they are like it's not moving.
    - I run ESP32's MCP2515 in loopback mode and here is the output
    thanks
  • Hi Vivek,
    Thanks for the details, trying three modules with the same result tells us the modules themselves are fine, and your loopback test passing tells us the ESP32's CAN chip and wiring are fine too. So I think the problem isn't the parts or your code, it's on the physical bus side, where the signal actually goes out on the CANH/CANL wires.
    Normally on a working bus, CANH and CANL both sit near 2.5 V when idle and move together when a message is sent. Yours show CANH normal at 2.23 V but CANL stuck low at 1.38 V and not moving, that's the sign of a CAN transceiver that isn't being driven properly, which most likely comes down to power. As per my understanding each board has its own CAN transceiver, and both need a solid 3.3 V to work. Right now you're powering the modules from the ESP32's 3.3 V pin (Correct me if I am wrong) , which seems not able to hold a steady voltage for both so the nRF side transceiver is likely running under powered.
    For testing purpose, could you try powering both CAN modules from a separate, steady 3.3 V supply instead of the ESP32 pin, and keep all the grounds connected together. Then run your normal test again and watch whether CANH/CANL start moving. Let me know how it goes and we'll take it from there.
    Syed Maysum
