How to Automatically Reset and Start the Application After Flashing a Merged Hex File in OTA
Dear Nordic Team,
We are working with the nRF52833 using nRF5 SDK 17.1.0 and have implemented OTA DFU in our application.in OTA We have merged all firmware components (Application, Bootloader, and , SoftDevice )  into a single HEX file and flashed it to the device. that Currently, after flashing the merged HEX file. We need to manually reset or power-cycle the hardware for the application to begin running.
Our requirement is for the device to reset automatically through firmware/software after flashing is completed. We do not want to send a reset command manually or perform a hardware   through reset
\Users\admin>nrfutil settings generate --family NRF52 --application Echo_UnderDash_II.hex --application-version 1 --bootloader-version 1 --bl-settings-version 2 bl_settings.hex
Note: Generating a DFU settings page with backup page included.
This is only required for bootloaders from nRF5 SDK 15.1 and newer.
If you want to skip backup page generation, use --no-backup option.
Generated Bootloader DFU settings .hex file and stored it in: bl_settings.hex
Bootloader DFU Settings:
* File: bl_settings.hex
* Family: nRF52
* Start Address: 0x0007F000
* CRC: 0x41774DEA
* Settings Version: 0x00000002 (2)
* App Version: 0x00000001 (1)
* Bootloader Version: 0x00000001 (1)
* Bank Layout: 0x00000000
* Current Bank: 0x00000000
* Application Size: 0x0000F0E4 (61668 bytes)
* Application CRC: 0xD9F2EDB8
* Bank0 Bank Code: 0x00000001
* Softdevice Size: 0x00000000 (0 bytes)
* Boot Validation CRC: 0xE22406CE
* SD Boot Validation Type: 0x00000000 (0)
* App Boot Validation Type: 0x00000001 (1)
C:\Users\admin>mergehex --merge s140_nrf52_7.2.0_softdevice.hex secure_bootloader_ble_s140_pca10100.hex Echo_UnderDash_II.hex bl_settings.hex --output final_dongle.hex
Parsing input files.
Merging file "s140_nrf52_7.2.0_softdevice.hex" into output.
Merging file "secure_bootloader_ble_s140_pca10100.hex" into output.
Merging file "Echo_UnderDash_II.hex" into output.
Merging file "bl_settings.hex" into output.
Storing merged file.
C:\Users\admin>nrfjprog --eraseall
Erasing user available code and UICR flash areas.
Applying system reset.
C:\Users\admin>nrfjprog --program final_dongle.hex --verify
[ #################### ] 3.035s | Program file - Done programming
[ #################### ] 2.965s | Verify file - Done verifying
After flashing, the device should reset automatically and start the application.
We do not want to send a reset command manually or perform a hardware reset. The device should automatically reset through firmware/software after the flashing process is completed. i want reset  automatic and start application.
We do not want to use the nrfjprog --reset command. The device should automatically reset and start the application through firmware/software after the flashing process is completed, without requiring any manual reset command or hardware reset.
