Guidance Required for nRF9151 Antenna RF Certification Testing and VNA Validation
Hello Nordic Community,
We are developing a custom product based on nRF9151 using NCS SDK v3.1.0.
On the hardware side, we have already completed antenna matching and tuning activities, including component optimization of the matching network. We are currently performing VNA (Vector Network Analyzer) measurements to verify antenna performance (S11/Return Loss) across the required LTE frequency bands.
For RF validation and certification preparation, we would like guidance on the recommended testing methodology from Nordic.
We found the following modem RF test command:
AT%XRFTEST=1,1,28,7000,23,1,4,1,0,0,0,0
Example configuration:
  • Band 28
  • 700 MHz
  • LTE-M (Cat-M1)
  • +23 dBm TX Power
  • CW Modulation
Our current validation approach includes:
  1. Antenna tuning and matching network optimization.
  2. VNA measurements (S11/Return Loss).
  3. Firmware-based RF transmission testing using %XRFTEST.
  4. Planned conducted and radiated measurements in an RF laboratory.
We would appreciate guidance on the following:
  1. Is %XRFTEST the recommended and valid method for RF antenna testing and certification preparation on nRF9151?
  2. Which firmware/modem firmware version is recommended for laboratory RF testing?
  3. After VNA verification, what additional RF validation steps are recommended by Nordic before certification?
  4. Are there specific Nordic procedures for:
    • Conducted TX measurements
    • Radiated antenna measurements
    • Output power verification
    • Band and frequency verification
    • LTE-M certification pre-compliance testing
  5. Can certification-related RF measurements be performed using firmware-controlled test commands such as %XRFTEST, or is there a dedicated Nordic test methodology that should be followed?
  6. Are there any limitations of %XRFTEST when compared to certification lab test procedures?
We are looking for guidance on the complete validation flow, including antenna tuning, VNA measurements, firmware-based RF testing, and certification testing for an nRF9151-based design.
Thank you for your support and guidance.
Best Regards,
Milan
  • Your approach looks good. %XRFTEST is useful for antenna validation and basic RF checks, but certification labs typically perform standardized conducted and radiated measurements with dedicated test equipment. After VNA tuning, play fnf online and enjoy exciting rhythm battles with catchy music anytime. I would recommend verifying TX power, frequency accuracy,  sensitivity, and radiated performance before certification testing. @fnf garcello
  • Thank you for the clarification.
    Our current objective is not certification testing. We only want to perform antenna validation and characterization using laboratory equipment, primarily VNA measurements.
    We would like to confirm whether using %XRFTEST to generate RF transmissions, together with VNA-based measurements and analysis, is an acceptable approach for evaluating our antenna design.
    In particular, we would like to validate both:
    • TX performance (using %XRFTEST transmission modes)
    • RX performance and antenna behavior across the required LTE bands
    Is this methodology appropriate for antenna evaluation on nRF9151, or would you recommend a different approach for TX/RX antenna characterization before moving to any certification activities?
    Thank you for your guidance.
    Yes, %XRFTEST is the correct approach for what you are doing. It is non-signaling mode only.
    TX test transmits a CW signal on a given frequency and returns the internally measured TX power, while RX test enables the receiver and measures incoming signal power (RSSI) at the antenna port.
    You can use the Production Test Image, see PTI.
    For certification, the next steps would be conducted performance testing in signaling mode, followed by radiated OTA testing in an anechoic chamber at a test house.
    Additional sources: Testing RF performance - Production test
    Benjamin
