nRF9151-DK (HW Rev 1.4.0) — SIM completely undetectable on two boards, all diagnostics exhausted
Hardware & Firmware
  • Board: nRF9151-DK (DKA), two separate units, both sourced from Farnell/Mouser
  • DK Hardware Revision: 1.4.0
  • DK PCB version: v0.2.0 (from Board Configurator log)
  • Board Controller FW: 1.2.1
  • Modem firmware: mfw_nrf91x1_2.0.4
  • TF-M: v2.1.1-ncs4
  • AT%HWVERSION: nRF9151 LACA A1A
  • nRF Connect for Desktop: latest available at time of testing
  • Application tested: stock AT Client sample (nrf/samples/nrf9x/at_client)
Problem Description
Both nRF9151-DK boards are completely unable to detect or communicate with any SIM card. The symptom is identical on both boards. Two different nano-SIM cards were tested. Previous nRF9151-DK boards sourced from a different supplier worked without issue. The modem AT interface itself is healthy — AT+CGMR, AT%HWVERSION, AT+CFUN, and IMEI retrieval (confirmed via nRF Quick Start) all function correctly. Only SIM-related commands fail.
Board Configurator State
  • SIM Option: SIM Card selected (not eSIM)
  • Write config applied, board power cycled
  • sim-select pin (pin 14): ON
Full AT Command History — Session 1 (initial diagnostics)
AT+CFUN?
+CFUN: 0
OK
AT+CIMI
ERROR
AT+CFUN=1
OK
AT+CFUN?
+CFUN: 1
OK
AT+CIMI
ERROR
AT%UICC?
ERROR
AT%XICCID
ERROR
AT+CRSM=176,28589,0,0,10
ERROR
AT+CGMR
mfw_nrf91x1_2.0.4
OK
AT%HWVERSION
OK
Full AT Command History — Session 2 (following Nordic AI assistant advice)
AT+CFUN?
+CFUN: 0
OK
AT+CFUN=1
OK
AT+CIMI
ERROR
AT+CFUN=0
OK
AT%XFACTORYRESET=0
OK
AT+CIMI
ERROR
AT+CFUN?
+CFUN: 0
OK
AT+CFUN=1
OK
AT+CIMI
ERROR
AT+CFUN=0
OK
AT%CSUS=0
OK
AT+CFUN=1
OK
AT+CIMI
ERROR
AT+CFUN=0
OK
AT%CSUS?
%CSUS: 0
OK
AT+CFUN=0
OK
AT%XSIM=1
OK
AT+CFUN=1
OK
%XSIM: 0,9
Key Diagnostic Findings
  1. AT+CIMI returns plain ERROR in both CFUN=0 and CFUN=1 — not +CME ERROR: 10 (no SIM) or +CME ERROR: 13 (SIM failure). This pattern persists across two boards and two different SIM cards.
  2. AT%UICC? returns ERROR — the SIM interface software-switching command is not functioning or not applicable on this hardware variant.
  3. AT%XFACTORYRESET=0 did not resolve the issue — modem NVM configuration is not the cause.
  4. AT%CSUS=0 explicitly selects the external SIM interface. Even after applying this in CFUN=0 and then switching to CFUN=1, AT+CIMI still returns ERROR.
  5. %XSIM: 0,9 — after enabling SIM state notifications with AT%XSIM=1 and entering CFUN=1, the modem unsolicited response reports SIM state 0 (not ready) with cause code 9. This confirms the modem is actively attempting to initialize the SIM interface but failing at the hardware communication level.
  6. AT+CRSM=176,28589,0,0,10 returns ERROR — direct SIM filesystem access is impossible.
  7. nRF Quick Start Verify passes — Manufacturer, Hardware version, and IMEI are all read correctly, confirming the modem itself is functional.
Custom Application Boot Output (for reference)
[00:00:00.289] <inf> hall_pickup: Bringing LTE interface up...
[00:00:00.546] <inf> nrf_modem_lib_trace: Trace thread ready
[00:00:00.662] <inf> hall_pickup: Waiting for LTE connection...
+CEREG: 90
[00:00:00.906] <wrn> nrf_modem_lib_netif: The modem reports a UICC failure. Is SIM installed?
What Has Been Ruled Out
  • Faulty SIM card — two different SIM cards tested on both boards, all fail identically
  • Application firmware interference — AT Client sample used in clean state
  • Modem NVM configuration — AT%XFACTORYRESET=0 performed, no change
  • Incorrect SIM interface selection — AT%CSUS=0 explicitly applied, no change
  • Modem AT interface fault — standard modem queries (AT+CGMR, AT%HWVERSION, IMEI) all respond correctly
  • Board Configurator not applied — Write config applied, board power cycled
Questions
  1. What does %XSIM: 0,9 specifically indicate? What is cause code 9 in the context of %XSIM on mfw_nrf91x1_2.0.4?
  2. What does the LACA variant code in AT%HWVERSION: nRF9151 LACA A1A indicate regarding the SIM interface? Does this variant have a functioning external nano-SIM interface, or does it differ from previously available variants?
  3. Why does AT%UICC? return plain ERROR on mfw_nrf91x1_2.0.4 with this hardware variant? Is AT%UICC unsupported on nRF9151 LACA A1A?
  4. Is Board Controller FW 1.2.1 on DK Hardware Revision 1.4.0 (DK v0.2.0) fully compatible with SIM mux switching via the Board Configurator? Could an outdated Board Controller FW cause the sim-select signal to not switch correctly despite Write config being applied?
  5. Is there a known issue with nRF9151-DK boards at Hardware Revision 1.4.0 or DK v0.2.0 related to SIM card detection?
  6. Both affected boards share the same supplier batch (Farnell). Is there a known batch or revision difference compared to boards from other distributors that would affect SIM functionality?
