We are using a BM833 chip on out PCB. There, we may or may not (config-dependant) interact with a sensor via I2C. We observed (statistically), that using the I2C communication seems to cause a significant rise in power consumtion after some days of permanently running the system that initially draws 5-10uA, after a certain time rises to draw 250-300uA.
Is there a known issue repeatedly using I2C? If yes, how can that be detected and circumvented?
Code to init, called once on start:
* @brief TWI initialization.
void twim_init (void)
ret_code_t err_code;
//scl was 7, sda was 5
const nrfx_twim_config_t twim_config = {
.scl = __i2cmscl,
.sda = __i2cmsda,
.frequency = NRF_TWIM_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH
err_code = nrfx_twim_init(&m_twi, &twim_config, twim_handler, NULL);
nrfx_twim_enable(&m_twi);
NRF_LOG_INFO("I2C Master inited and enabled.");
Code to "talk", called for querying registers of the sensor:
// Function to write a DPS registers value
void i2c_reg8_write(uint8_t devIndex, uint8_t regIndex, uint8_t value)
myTrans.retry=5;
m_xfer_done = false;
m_sample[0]=regIndex;
m_sample[1]=value;
err_code = nrfx_twim_tx(&m_twi, devIndex, m_sample, 2, true);
while (!m_xfer_done && myTrans.retry--)
__WFE();
return;
// Function to read a DPS registers value
uint8_t i2c_reg8_read(uint8_t devIndex, uint8_t regIndex)
myTrans.retry=5;
err_code = nrfx_twim_tx(&m_twi, devIndex, ®Index, 1, true);
__WFE();
if (NRF_SUCCESS == err_code)
myTrans.retry=5;
err_code = nrfx_twim_rx(&m_twi, devIndex, m_sample, 2);
__WFE();
return m_sample[0];
void i2c_reg16_write(uint8_t devIndex, uint8_t regIndex, uint16_t value)
myTrans.retry=5;
m_sample[1]=value&0xff;
m_sample[2]=value>>8;
err_code = nrfx_twim_tx(&m_twi, devIndex, m_sample, 3, true);
__WFE();
return;
uint16_t i2c_reg16_read(uint8_t devIndex, uint8_t regIndex)
myTrans.retry=5;
__WFE();
myTrans.retry=5;
__WFE();
uint16_t res=m_sample[0];
res=res<<8|m_sample[1];
return res;
Hope to have provided necessary info.
Richard
