I have a question regarding copying the generated images to a dedicated location after the build has finished.
I need to copy:
- build/merged_CPUNET.hex
- build/merged.hex
- build/signed_by_mcuboot_and_b0_ipc_radio.bin
- build/project_name/zephyr/zephyr.signed.encrypted.bin
Total 4 images. The hex files to be used for factory programming and bin files for bootloader.
After a bit of struggling, I found that sysbuild/CMakeLists is the place to put the copy commands. As there are targets merged_hex and merged_CPUNET_hex available. I.e. depnding on those two targets assures all the images are done, right?
I get the files copied. But the question is how to get the version string, to change the name of the copied file to include the version?
https://docs.zephyrproject.org/latest/build/version/index.html
states that I could use APP_VERSION_STRING in cmake. But the variable is not populated yet, seems to be.
In short, the question is: how to get the APP_VERSION_NUMBER in systbuild/CMakeLists? So I could copy the files and change the names to include the version number.
I got a recommendation from AI before posting to use:
sysbuild_get(app_version_string IMAGE ${DEFAULT_IMAGE} VAR APP_VERSION_EXTENDED_STRING CACHE)
but it return empty variable. The DEFAULT_IMAGE is correct, checked.
I have "VERSION" file available in root dir, as required.
ncs version 3.0.2
BR, Madis
