nrf9151 flashing/recovery using nrf9151DK fails with varying error messages
Hello, we are having issues with using the nrf9151DK as a programmer for our own custom nrf9151 board. As the board seems to be locked, we tried to unlock it using the nrfutil device recover command. This command, however, is never successful. Most failures contain errors about Memory Access errors; most times it also mentions "Probably a memory protection issue. Probe access is secure".
The VSCode extension reports the hardware as NRF9151_xxxx_REV3 (which on Google does not return any results, btw).
This log contains various attempts at making it work. Both the target and dev-board have been power-cycled between some attempts.
vincent@VM-Kubuntu-23:~/work/WX$ nrfutil device list
1052078938
Product         J-Link
Board version   PCA10201
Ports           /dev/ttyACM0, vcom: 0
                /dev/ttyACM1, vcom: 1
Traits          boardController, devkit, jlink, modem, seggerUsb, serialPorts, usb
Supported devices found: 1
vincent@VM-Kubuntu-23:~/work/WX$ west flash --recover
FATAL ERROR: --build-dir was not given, and neither /home/vincent/work/WX nor /home/vincent/work/WX/build are zephyr build directories.
vincent@VM-Kubuntu-23:~/work/WX$ cd nrf_test_ws2812/
vincent@VM-Kubuntu-23:~/work/WX/nrf_test_ws2812$ west flash --recover
-- west flash: rebuilding
[0/5] Performing build step for 'nrf_test_ws2812'
ninja: no work to do.
[4/5] cd /home/vincent/work/WX/nrf_test_ws2812/build/_sysbuild && /home/vincent/ncs/toolchains/911f4c5c26/usr/local/bin/cmake -E true
-- west flash: using runner nrfutil
-- runners.nrfutil: reset after flashing requested
Using board 001052078938
-- runners.nrfutil: Recovering and erasing all flash memory.
-- runners.nrfutil: Flashing file: /home/vincent/work/WX/nrf_test_ws2812/build/merged.hex
-- runners.nrfutil: Connecting to probe
Error: One or more batch tasks failed:
* 1052078938: Device error: Failed to read AccessPort register 0x00: Unknown error in the J-Link DLL (error code =-1) (Generic)
FATAL ERROR: command exited with status 1: nrfutil --json device x-execute-batch --batch-path /home/vincent/work/WX/nrf_test_ws2812/build/nrf_test_ws2812/zephyr/generated_nrfutil_batch.json --serial-number 1052078938
vincent@VM-Kubuntu-23:~/work/WX/nrf_test_ws2812$ nrfutil device erase
❌ Failed to erase 1052078938, Failed to attach to target: The Application core access port is protected (All)        Error: One or more erase tasks failed:
* 1052078938: Failed to attach to target: The Application core access port is protected (All) (NotAvailableBecauseProtection)
The operation was unavailable for some of the devices because they had readback protection enabled. These devices might be possible to unlock using the `recover` subcommand. See `nrfutil device recover --help` for more information.
vincent@VM-Kubuntu-23:~/work/WX/nrf_test_ws2812$ nrfutil device recover
❌ Failed to recover 1052078938, Device error: Emulator error: Failed to connect to device: Unable to detect a supported core        Error: One or more recover tasks failed:
* 1052078938: Device error: Emulator error: Failed to connect to device: Unable to detect a supported core (Generic)
❌ Failed to erase 1052078938, Device error: Failed to read from memory address 0x50003620: Failed to write AccessPort register 0x04: Unknown error in the J-Link DLL (error code =-1)        Error: One or more erase tasks failed:
* 1052078938: Device error: Failed to read from memory address 0x50003620: Failed to write AccessPort register 0x04: Unknown error in the J-Link DLL (error code =-1) (Generic)
vincent@VM-Kubuntu-23:~/work/WX/nrf_test_ws2812$ nrfutil device list
1052078938
Product         J-Link
❌ Failed to recover 1052078938, Device error: Unable to recognize the device: Unknown part number 0x12880000        Error: One or more recover tasks failed:
* 1052078938: Device error: Unable to recognize the device: Unknown part number 0x12880000  (Generic)
vincent@VM-Kubuntu-23:~/work/WX/nrf_test_ws2812$ nrfutil device recover --family NRF91
error: invalid value 'NRF91' for '--family <FAMILY>'
  [possible values: nrf51, nrf52, nrf53, nrf54l, nrf54h, nrf91, nrf92]
For more information, try '--help'.
vincent@VM-Kubuntu-23:~/work/WX/nrf_test_ws2812$ nrfutil device recover --family nrf91
❌ Failed to recover 1052078938, Device error: Unable to detect CTRL-AP at 4        Error: One or more recover tasks failed:
* 1052078938: Device error: Unable to detect CTRL-AP at 4 (Generic)
vincent@VM-Kubuntu-23:~/work/WX/nrf_test_ws2812$ nrfutil device device-info
serial_number: 001052078938
        boardVersion: PCA10201
        deviceFamily: NRF91_FAMILY
        deviceName: nRF9151
        deviceVersion: NRF9151_xxxx_REV3
        jlinkObFirmwareVersion: J-Link OB-nRF5340-NordicSemi compiled Jul  8 2025 10:15:34
vincent@VM-Kubuntu-23:~/work/WX/nrf_test_ws2812$ nrfutil device fw-update
error: unrecognized subcommand 'fw-update'
Usage: nrfutil device [OPTIONS] [COMMAND]
❌ Failed to recover 1052078938, Device error: Failed to write DebugPort register 0x08: Unknown error in the J-Link DLL (error code =-1)        Error: One or more recover tasks failed:
* 1052078938: Device error: Failed to write DebugPort register 0x08: Unknown error in the J-Link DLL (error code =-1) (Generic)
❌ Failed to recover 1052078938, Device error: Unable to recognize the device: Unknown part number 0x91590009        Error: One or more recover tasks failed:
* 1052078938: Device error: Unable to recognize the device: Unknown part number 0x91590009  (Generic)
❌ Failed to recover 1052078938, Device error: NVMC Failed to write to NVMC.CONFIG:  failed: Failed to read from memory address 0x50003108: Failed to write DebugPort register 0x08: Unknown error in the J-Link DLL (error code =-1)                            Error: One or more recover tasks failed:
* 1052078938: Device error: NVMC Failed to write to NVMC.CONFIG:  failed: Failed to read from memory address 0x50003108: Failed to write DebugPort register 0x08: Unknown error in the J-Link DLL (error code =-1) (Generic)
❌ Failed to recover 1052078938, Device error: Failed to read AccessPort register 0xfc: Unknown error in the J-Link DLL (error code =-1)        Error: One or more recover tasks failed:
* 1052078938: Device error: Failed to read AccessPort register 0xfc: Unknown error in the J-Link DLL (error code =-1) (Generic)
❌ Failed to recover 1052078938, Device error: Failed to read AccessPort register 0x08: Unknown error in the J-Link DLL (error code =-1)        Error: One or more recover tasks failed:
* 1052078938: Device error: Failed to read AccessPort register 0x08: Unknown error in the J-Link DLL (error code =-1) (Generic)
vincent@VM-Kubuntu-23:~/work/WX/nrf_test_ws2812$ nrfutil device recover --swd-clock-frequency 100
❌ Failed to recover 1052078938, Device error: Failed to read AccessPort register 0x34: Unknown error in the J-Link DLL (error code =-1)        Error: One or more recover tasks failed:
* 1052078938: Device error: Failed to read AccessPort register 0x34: Unknown error in the J-Link DLL (error code =-1) (Generic)
❌ Failed to recover 1052078938, Device error: Setting the debug port SELECT register failed while powering up sys and debug regions (Unknown error in the J-Link DLL (error code =-1)).        Error: One or more recover tasks failed:
* 1052078938: Device error: Setting the debug port SELECT register failed while powering up sys and debug regions (Unknown error in the J-Link DLL (error code =-1)).
   This might indicate that the debug port is unavailable. Double-check device power supply and SWD lines, and ensure that SWD is not disabled (Generic)
vincent@VM-Kubuntu-23:~/work/WX/nrf_test_ws2812$ nrfutil device recover --swd-clock-frequency 20
vincent@VM-Kubuntu-23:~/work/WX/nrf_test_ws2812$ nrfutil device recover --swd-clock-frequency 30
vincent@VM-Kubuntu-23:~/work/WX/nrf_test_ws2812$ nrfutil device recover --swd-clock-frequency 50
❌ Failed to recover 1052078938, Device error: Memory access error at 0x50039e10. Probably a memory protection issue. Probe access is Secure        Error: One or more recover tasks failed:
* 1052078938: Device error: Memory access error at 0x50039e10. Probably a memory protection issue. Probe access is Secure (Generic)
❌ Failed to recover 1052078938, Device error: Failed to read AccessPort register 0x00: Unknown error in the J-Link DLL (error code =-1)        Error: One or more recover tasks failed:
❌ Failed to recover 1052078938, Device error: Failed to read from memory address 0x500038e4: Failed to write DebugPort register 0x08: Unknown error in the J-Link DLL (error code =-1)        Error: One or more recover tasks failed:
* 1052078938: Device error: Failed to read from memory address 0x500038e4: Failed to write DebugPort register 0x08: Unknown error in the J-Link DLL (error code =-1) (Generic)
❌ Failed to recover 1052078938, Device error: Memory access error at 0x00000000. Probably a memory protection issue. Probe access is Secure        Error: One or more recover tasks failed:
* 1052078938: Device error: Memory access error at 0x00000000. Probably a memory protection issue. Probe access is Secure (Generic)
vincent@VM-Kubuntu-23:~/work/WX/nrf_test_ws2812$ nrfutil device recover --x-force-device NRF9151_xxxx_REV3
❌ Failed to recover 1052078938, Device error: Unable to recognize the device: The device NRF9151_xxxx_REV3 does not correspond to any known device in thError: One or more recover tasks failed:
* 1052078938: Device error: Unable to recognize the device: The device NRF9151_xxxx_REV3 does not correspond to any known device in the device database  (Generic)
❌ Failed to recover 1052078938, Device error: Failed to write AccessPort register 0x00: Unknown error in the J-Link DLL (error code =-1)                Error: One or more recover tasks failed:
* 1052078938: Device error: Failed to write AccessPort register 0x00: Unknown error in the J-Link DLL (error code =-1) (Generic)
❌ Failed to recover 1052078938, Device error: TrustZone Flash access error. Probe has Secure access                                                     Error: One or more recover tasks failed:
* 1052078938: Device error: TrustZone Flash access error. Probe has Secure access (Generic)
Trying to reset the device using the nrf Connect Desktop application also does not work. Please see the attached error logs.
12:58:45.101  Initialising the bundled nrfutil device
12:58:45.301  Using the bundled core version for nrfutil device: 8.1.1
12:58:45.376  Getting serial port options from the persistent store for 001052078938.pc-nrfconnect-programmer
12:58:45.377  Device connected with the serial number 001052078938
12:58:45.393  Using nrfutil device version: 2.19.2
12:58:45.394  Using nrf-device-lib version: 0.22.20
12:58:45.394  Using nrf-probe version: 0.58.3
12:58:45.394  Using SEGGER J-Link version: JLink_V9.50
12:58:45.394  Your version of SEGGER J-Link (9.50) is newer than the one this app was tested with (9.24a). The tested version is not required, and your J-Link version will most likely work fine. If you get issues related to J-Link with your devices, use the tested version.
12:58:48.045  Selecting device with the serial number 001052078938
12:58:48.369  Error: Failed with exit code 1. One or more device info tasks failed: * 1052078938: Device error: Failed to read AccessPort register 0x34: Unknown error in the J-Link DLL (error code =-1) (Generic) Message: Operation device-info failed, Device error: Failed to read AccessPort register 0x34: Unknown error in the J-Link DLL (error code =-1).
12:58:48.369  Selected device with the serial number 001052078938
12:58:48.369  Using nrfutil device to communicate with target via JLink
12:58:48.617  Reading readback protection status for Application core
12:58:48.619  Reading readback protection status for Application core 0%
12:58:48.697  Reading readback protection status for Application core 50%
12:58:48.721  Reading readback protection status for Application core 100%
12:58:48.722  Application core protection status 'NRFDL_PROTECTION_STATUS_NONE'
12:58:48.723  Reading readback protection status for Application core completed
12:58:49.084  Loading core information for Application core
12:58:49.086  Loading core information for Application core 0%
12:58:49.160  Loading core information for Application core 50%
12:58:49.174  Loading core information for Application core 100%
12:58:49.176  Loading core information for Application core completed
12:58:49.752  Error: Failed with exit code 1. One or more batch tasks failed: * 1052078938: Device error: Unable to recognize the device: Unknown part number 0x22a20009 (Generic) Message: Batch task reset failed, Device error: Unable to recognize the device: Unknown part number 0x22a20009.
12:59:08.253  Reading readback protection status for Application core
12:59:08.254  Reading readback protection status for Application core 0%
12:59:08.341  Reading readback protection status for Application core 50%
12:59:08.342  Reading readback protection status for Application core 50%
12:59:08.359  Reading readback protection status for Application core 100%
12:59:08.359  Application core protection status 'NRFDL_PROTECTION_STATUS_NONE'
12:59:08.360  Reading readback protection status for Application core completed
12:59:08.709  Reading memory for Application core
12:59:08.710  Reading memory for Application core 0%
12:59:08.782  Reading memory for Application core 50%
12:59:09.123  Error: Failed with exit code 1. One or more batch tasks failed: * 1052078938: Device error: Failed to read from memory address 0x50003100: Failed to write DebugPort register 0x08: Unknown error in the J-Link DLL (error code =-1) (Generic) Message: Batch task memory-read failed, Device error: Failed to read from memory address 0x50003100: Failed to write DebugPort register 0x08: Unknown error in the J-Link DLL (error code =-1).
12:59:41.038  Parsing HEX file: /home/vincent/work/WX/nrf_test_ws2812/build/merged.hex
12:59:41.060  File was last modified at 6/19/2026, 11:56:43 AM
12:59:41.090  Update files regions according to Application core
12:59:41.090  Parse memory regions for file
12:59:50.803  Update files regions according to Application core
12:59:50.803  Parse memory regions for file
12:59:51.025  Reading readback protection status for Application core
12:59:51.026  Reading readback protection status for Application core 0%
12:59:51.102  Reading readback protection status for Application core 50%
12:59:51.103  Reading readback protection status for Application core 50%
12:59:51.156  Failed "reading readback protection status for application core". Error: code: 1, description: Generic, message: Batch task protection-get failed, Device error: Unable to recognize the device: Unknown part number 0x91510109
12:59:51.234  Error: Failed with exit code 1. One or more batch tasks failed: * 1052078938: Device error: Unable to recognize the device: Unknown part number 0x91510109 (Generic) Message: Batch task protection-get failed, Device error: Unable to recognize the device: Unknown part number 0x91510109.
13:01:07.399  Device connected with the serial number 001052078938
13:01:07.403  Update files regions according to Application core
13:01:07.403  Parse memory regions for file
13:01:13.099  Getting serial port options from the persistent store for 001052078938.pc-nrfconnect-programmer
13:01:13.099  Device connected with the serial number 001052078938
13:01:13.137  Getting serial port options from the persistent store for 001052078938.pc-nrfconnect-programmer
13:01:47.100  Selecting device with the serial number 001052078938
13:01:47.426  Selected device with the serial number 001052078938
13:01:47.427  Using nrfutil device to communicate with target via JLink
13:01:47.427  JLink OB firmware version J-Link OB-nRF5340-NordicSemi compiled Jul 8 2025 10:15:34
13:01:47.427  Device family NRF91_FAMILY
13:01:47.427  Device version NRF9151_xxxx_REV3
13:01:47.427  Board version PCA10201
13:01:47.446  Update files regions according to Application core
13:01:47.446  Parse memory regions for file
13:01:47.669  Reading readback protection status for Application core
13:01:47.670  Reading readback protection status for Application core 0%
13:01:47.745  Reading readback protection status for Application core 50%
13:01:47.746  Reading readback protection status for Application core 50%
13:01:47.771  Reading readback protection status for Application core 100%
13:01:47.771  Application core protection status 'NRFDL_PROTECTION_STATUS_ALL'
13:01:47.772  Reading readback protection status for Application core completed
13:01:47.890  Skipping reading core Application information as it is protected.
13:01:48.873  Error: Failed with exit code 1. One or more batch tasks failed: * 1052078938: Failed to attach to target: The Application core access port is currently closed. AP-Protect might be enabled (NotAvailableBecauseProtection) The operation is unavailable for some of the devices because they have readback protection enabled. These devices might be possible to unlock using the `recover` subcommand. See `nrfutil device recover --help` for more information. Message: Batch task reset failed, Failed to attach to target: The Application core access port is currently closed. AP-Protect might be enabled.
13:02:14.865  Recovering Application core
13:02:14.867  Recovering Application core 0%
13:02:14.947  Recovering Application core 50%
13:02:15.584  Failed "recovering application core". Error: code: 1, description: Generic, message: Batch task recover failed, Device error: Setting the debug port SELECT register failed while powering up sys and debug regions (Unknown error in the J-Link DLL (error code =-1)). This might indicate that the debug port is unavailable. Double-check device power supply and SWD lines, and ensure that SWD is not disabled
13:02:15.682  Error: Failed with exit code 1. One or more batch tasks failed: * 1052078938: Device error: Setting the debug port SELECT register failed while powering up sys and debug regions (Unknown error in the J-Link DLL (error code =-1)). This might indicate that the debug port is unavailable. Double-check device power supply and SWD lines, and ensure that SWD is not disabled (Generic) Message: Batch task recover failed, Device error: Setting the debug port SELECT register failed while powering up sys and debug regions (Unknown error in the J-Link DLL (error code =-1)). This might indicate that the debug port is unavailable. Double-check device power supply and SWD lines, and ensure that SWD is not disabled.
13:02:26.343  Recovering Application core
13:02:26.345  Recovering Application core 0%
13:02:26.416  Recovering Application core 50%
13:02:26.417  Recovering Application core 50%
13:02:27.181  Failed "recovering application core". Error: code: 1, description: Generic, message: Batch task recover failed, Device error: Memory access error at 0x00000000. Probably a memory protection issue. Probe access is Secure
13:02:27.266  Error: Failed with exit code 1. One or more batch tasks failed: * 1052078938: Device error: Memory access error at 0x00000000. Probably a memory protection issue. Probe access is Secure (Generic) Message: Batch task recover failed, Device error: Memory access error at 0x00000000. Probably a memory protection issue. Probe access is Secure.
Please advise on what other tests to run.
    I see that you are using a VM. As a first step, can you maybe try to use the recover command from outside the VM?
    And for me to check if there is something visible directly on the board, can you send me a picture of the DK please?
    Simon
  • Hello, thank you for your response. Running the recovery outside of a VM does not change behaviour.
    Please see the attached images of the DK / target board.
    Let me know if you need more angles.
    mainboardSchematic.pdf
    I've also attached the mainboard schematics.
    Sören Oesterwind
  • Hi Sören,
    That shouldn't be an issue, but I don't think you need to connect the "SEL" pin on the nRF9151 DK to the ground. This pin is used to detect if an external board is connected through the ground. But in your case you already have the "VTG" pin that does that job better. The "SEL" pin is easier to use when providing VDD from the DK to the external board.
    Also, I see on your schematic that your board is using 3.3V. Did you configure the DK to also use 3.3V? By default, it is set to 1.8V which would explain why it can't communicate with your board. If you didn't set the DK to 3.3V, you can do it through the "Board configurator" application from nRF Connect for Desktop (link).
    Finally. I don't know if you already did that, but check all your power voltage on your board to see if maybe the chip is only missing power. Because in your case, seeing "nRF9151" on the debugger interface is not very relevant as the board you are using to do you debugging also has a nRF9151. If you have another (recent) DK that has another chip as their main chip (i.e. nRF54L15 DK) you can clearly see if the chip has changed or not.
    Simon
    we were able to resolve the issue. There was an issue with the ground connection between the boards. Either the GND pin wasn't properly connected, or the jumper wire was unstable. After fixing the broken GND connection, we are able to flash the chip without issue.
    Looking back, it was a trivial issue which should have been detected earlier. Thank you for your help; your hints were very valuable.
    Sören Oesterwind
