ECC key derivation and agreement
Hey,
I am trying to implement ecdh key agreement and derivation, but I am getting PSA_ERROR_INVALID_ARGUMENT (-135) from psa_key_derivation_key_agreement:
Any idea what is causing this, because when I was testing with psa_raw_key_agreement it succeeded.
The test setup was based on crypto ecdh sample and sdk is v3.2.1.
main.c:
 * Copyright (c) 2021 Nordic Semiconductor ASA
#include <psa/crypto.h>
#include <psa/crypto_extra.h>
#include <stdio.h>
#include <stdlib.h>
#include <zephyr/kernel.h>
LOG_MODULE_REGISTER(ecdh, LOG_LEVEL_DBG);
#ifdef CONFIG_BUILD_WITH_TFM
#include <tfm_ns_interface.h>
#include "./server_pub_key.h"
#define APP_SUCCESS (0)
#define APP_ERROR (-1)
#define APP_SUCCESS_MESSAGE "Example finished successfully!"
#define APP_ERROR_MESSAGE "Example exited with error!"
#define PRINT_HEX(p_label, p_text, len)               \
    LOG_INF("---- %s (len: %u): ----", p_label, len); \
    LOG_HEXDUMP_INF(p_text, len, "Content:");         \
    LOG_INF("---- %s end  ----", p_label);            \
#define PRINT_HEXSTRING(p_label, p_data, len)                                \
    LOG_INF("---- %s (len: %u, str_len: %u) ----", p_label, len, len * 2);   \
    uint8_t string[len * 2 + 1];                                             \
    for (size_t i = 0; i < len; i++) {                                       \
      snprintf(string + 2 * i, (sizeof(string) - 2 * i), "%02x", p_data[i]); \
    LOG_INF("%s", string);                                                   \
#define KEY_PAIR_TYPE PSA_KEY_TYPE_ECC_KEY_PAIR(PSA_ECC_FAMILY_SECP_R1)
#define KEY_SIZE (384)
#define PUB_KEY_TYPE PSA_KEY_TYPE_PUBLIC_KEY_OF_KEY_PAIR(KEY_PAIR_TYPE)
#define PUB_KEY_SIZE PSA_EXPORT_PUBLIC_KEY_OUTPUT_SIZE(PUB_KEY_TYPE, KEY_SIZE)
#define RAW_KEY_AGREEMENT_SIZE PSA_RAW_KEY_AGREEMENT_OUTPUT_SIZE(KEY_PAIR_TYPE, KEY_SIZE)
#define AGREEMENT_ALG PSA_ALG_ECDH
#define DERIVATION_ALG PSA_ALG_HKDF(PSA_ALG_SHA_256)
int crypto_init(void) {
  psa_status_t status;
  /* Initialize PSA Crypto */
  status = psa_crypto_init();
  if (status != PSA_SUCCESS)
    return APP_ERROR;
  return APP_SUCCESS;
mbedtls_svc_key_id_t crypto_gen_key() {
  int err;
  mbedtls_svc_key_id_t new_key;
  psa_key_attributes_t attrib = psa_key_attributes_init();
  psa_set_key_algorithm(&attrib, PSA_ALG_KEY_AGREEMENT(AGREEMENT_ALG, DERIVATION_ALG));
  psa_set_key_type(&attrib, KEY_PAIR_TYPE);
  psa_set_key_bits(&attrib, KEY_SIZE);
  psa_set_key_usage_flags(&attrib, PSA_KEY_USAGE_DERIVE);
  err = psa_generate_key(&attrib, &new_key);
  if (err != PSA_SUCCESS) {
    LOG_ERR("Failed to create key pair, %d", err);
    return 0;
  return new_key;
mbedtls_svc_key_id_t crypto_derive_enc_key(mbedtls_svc_key_id_t private_key) {
  int err;
  psa_key_derivation_operation_t op =
      psa_key_derivation_operation_init();
  mbedtls_svc_key_id_t enc_key = 0;
  err = psa_key_derivation_setup(&op, PSA_ALG_KEY_AGREEMENT(
    LOG_ERR("Failed to setup key derivation, %d", err);
    goto exit;
  err = psa_key_derivation_key_agreement(
      &op, PSA_KEY_DERIVATION_INPUT_SECRET,
      private_key, pub_key, sizeof(pub_key));
    LOG_ERR("Failed to execute key agreement and derivation, %d", err);
    goto exit;
  psa_set_key_algorithm(&attrib, PSA_ALG_CCM);
  psa_set_key_type(&attrib, PSA_KEY_TYPE_AES);
  psa_set_key_bits(&attrib, 256);
                          PSA_KEY_USAGE_DECRYPT |
                              PSA_KEY_USAGE_ENCRYPT |
                              PSA_KEY_USAGE_EXPORT);
  err = psa_key_derivation_output_key(&attrib, &op, &enc_key);
    LOG_ERR("Failed to generate AES key, %d", err);
    goto exit;
exit:
  psa_reset_key_attributes(&attrib);
  psa_key_derivation_abort(&op);
  return enc_key;
int main(void) {
  int status;
  LOG_INF("Starting ECDH example...");
  /* Init crypto */
  status = crypto_init();
  if (status != APP_SUCCESS) {
    LOG_INF(APP_ERROR_MESSAGE);
    return APP_ERROR;
  __auto_type my_key = crypto_gen_key();
  if (!my_key) return APP_ERROR;
  uint8_t shared_secret[RAW_KEY_AGREEMENT_SIZE];
  size_t out_size;
  status = psa_raw_key_agreement(PSA_ALG_ECDH, my_key, pub_key, sizeof(pub_key),
                                 shared_secret, sizeof(shared_secret), &out_size);
  if (status != PSA_SUCCESS) {
    LOG_ERR("Failed to create key agreement, %d", status);
    // return APP_ERROR;
  } else {
    PRINT_HEXSTRING("secret:", shared_secret, out_size);
    PRINT_HEX("secret:", shared_secret, out_size);
  __auto_type enc_key = crypto_derive_enc_key(my_key);
  if (!enc_key) return APP_ERROR;
  uint8_t enc_key_bytes[PSA_EXPORT_KEY_OUTPUT_SIZE(PSA_KEY_TYPE_AES, 256)];
  size_t enc_export_size;
  status = psa_export_key(enc_key, enc_key_bytes, sizeof(enc_key_bytes), &enc_export_size);
    LOG_ERR("Failed to export AES key");
    return APP_ERROR;
  PRINT_HEXSTRING("enc_key", enc_key_bytes, enc_export_size);
  PRINT_HEX("enc_key", enc_key_bytes, enc_export_size);
  uint8_t own_pub_key[PUB_KEY_SIZE];
  size_t export_size;
  status = psa_export_public_key(my_key, own_pub_key, sizeof(own_pub_key), &export_size);
    LOG_ERR("Failed to export public key, %d", status);
    return APP_ERROR;
  PRINT_HEXSTRING("pubkey:", own_pub_key, export_size);
  PRINT_HEX("pubkey:", own_pub_key, export_size);
  LOG_INF(APP_SUCCESS_MESSAGE);
  return APP_SUCCESS;
server_pub_key.h:
#ifndef DC8A1BF7_016B_49E2_AAD2_025785B64CA1
#define DC8A1BF7_016B_49E2_AAD2_025785B64CA1
unsigned char pub_key[] = {
    0x04, 0xf1, 0x30, 0x2c, 0x19, 0x98, 0xc7, 0x8d, 0x44, 0x29, 0x95, 0x1e,
    0xc7, 0xde, 0x83, 0x25, 0xef, 0x26, 0x83, 0x93, 0x76, 0x8c, 0xdd, 0x68,
    0x6c, 0x4a, 0x05, 0x3a, 0x0d, 0x1f, 0x4f, 0xf5, 0x6f, 0x56, 0xea, 0x9f,
    0x4f, 0x5b, 0xf0, 0x36, 0x78, 0xb7, 0xa2, 0xac, 0x70, 0x86, 0x41, 0xb5,
    0xcd, 0x14, 0x1f, 0xd3, 0xda, 0x90, 0x9d, 0x6e, 0x37, 0x7a, 0xfc, 0xee,
    0x78, 0x89, 0x5a, 0x71, 0x90, 0x89, 0x08, 0x08, 0x45, 0xae, 0xca, 0xf2,
    0x8d, 0x81, 0xba, 0x4a, 0x2c, 0x32, 0x88, 0x24, 0xfb, 0xd2, 0xc5, 0xf0,
    0xf2, 0x05, 0x05, 0xd1, 0x2a, 0x06, 0x58, 0x62, 0x3f, 0x15, 0xdb, 0xe9,
    0x0d};
#endif /* DC8A1BF7_016B_49E2_AAD2_025785B64CA1 */
And conf files:
prj.conf:
# Copyright (c) 2024 Nordic Semiconductor ASA
# The Zephyr CMSIS emulation assumes that ticks are ms, currently
CONFIG_SYS_CLOCK_TICKS_PER_SEC=1000
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=4096
# Enable logging
CONFIG_CONSOLE=y
CONFIG_LOG=y
# Enable nRF Security backend for PSA Crypto API
CONFIG_NRF_SECURITY=y
CONFIG_MBEDTLS_PSA_CRYPTO_C=y
# Enable cryptographic features
CONFIG_PSA_WANT_GENERATE_RANDOM=y
CONFIG_PSA_WANT_ECC_SECP_R1_256=y
CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE=y
CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT=y
CONFIG_PSA_WANT_ALG_ECDH=y
CONFIG_PSA_WANT_ALG_HKDF=y
CONFIG_PSA_WANT_KEY_TYPE_AES=y
CONFIG_PSA_WANT_ALG_CCM=y
nrf9151dk_nrf9151_ns.conf:
CONFIG_TFM_PROFILE_TYPE_NOT_SET=y
# CONFIG_TFM_PROFILE_TYPE_MINIMAL=y
# Using hardware crypto accelerator
CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
nrf9151dk_nrf9151.conf:
# Enable both oberon driver and hardware crypto accelerator
# Key derivation is only supported in software driver but is using chained
# driver to accelerate sub-operations.
CONFIG_PSA_CRYPTO_DRIVER_OBERON=y
# Mbedtls configuration
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=8192
    Your issue seems to be due to a curve configuration mismatch. As your code uses P-384 (KEY_SIZE 384) but your prj.conf only enables P-256. Can you try adding this to your prj.conf:
    CONFIG_PSA_WANT_ECC_SECP_R1_384=y
    Best Regards,
    Syed Maysum
  • Hey,
    Thanks, I totally missed that miss configuration.
    I also have a question about TFM size when using crypto APIs. Is it possible reduce the TFM partition size to or under 100kB? I am currently hovering around 163kB.
               FLASH:      163228 B       160 KB     99.63%
                 RAM:       36884 B        88 KB     40.93%
    Here is the current configuration for TFM:
    CONFIG_TFM_CMAKE_BUILD_TYPE_MINSIZEREL=n
    CONFIG_TFM_PARTITION_CRYPTO=y
    CONFIG_TFM_SFN=y
    # CONFIG_TFM_CRYPTO_SINGLE_PART_FUNCS_DISABLED=y
    CONFIG_TFM_PARTITION_INTERNAL_TRUSTED_STORAGE=n
    CONFIG_TFM_PARTITION_PROTECTED_STORAGE=n
    CONFIG_TFM_PARTITION_INITIAL_ATTESTATION=n
    CONFIG_PM_PARTITION_SIZE_TFM=0x28000
    I tried enabling minsizerel, which would have reduced the TFM partition size to around 130kB but that causes TFM to throw a SecureFault.
    Good to hear the P-384 config fixed the issue. On TF-M size question, yes MinSizeRel can shrinks the image but as you have SecureFault so we may keep it as it is and try the other size reductions first. Can you try adding these config:
    CONFIG_TFM_LOG_LEVEL_SILENCE=y
    CONFIG_TFM_PSA_FRAMEWORK_HAS_MM_IOVEC=y
    CONFIG_TFM_CRYPTO_ASYM_SIGN_MODULE_ENABLED=n
    CONFIG_TFM_CRYPTO_ASYM_ENCRYPT_MODULE_ENABLED=n
    CONFIG_TFM_CRYPTO_CIPHER_MODULE_ENABLED=n
    CONFIG_TFM_CRYPTO_PAKE_MODULE_ENABLED=n
    Also double-check your prj.conf and only enable the CONFIG_PSA_WANT_* options you actually use, that often makes more difference than the TF-M settings alone.
    Best Regards,
    Syed Maysum
  • Hey,
    Disabling logging dropped about 32kB, now around 130kB for the tfm size, but I was unable to reduce it any further.
    Here are the current configs, the commented out symbols didn't have any impact:
    # TFM configurations (~130kB)
    CONFIG_TFM_CMAKE_BUILD_TYPE_MINSIZEREL=y
    # CONFIG_TFM_CMAKE_BUILD_TYPE_DEBUG=y
    CONFIG_TFM_SFN=y
    # CONFIG_TFM_CRYPTO_ASYM_SIGN_MODULE_ENABLED=n
    # CONFIG_TFM_CRYPTO_ASYM_ENCRYPT_MODULE_ENABLED=y
    # CONFIG_TFM_CRYPTO_CIPHER_MODULE_ENABLED=n
    # CONFIG_TFM_CRYPTO_PAKE_MODULE_ENABLED=n
    # CONFIG_HW_UNIQUE_KEY=n
    # CONFIG_HW_UNIQUE_KEY_RANDOM=n
    # CONFIG_TFM_CRYPTO_BUILTIN_KEYS=n
    CONFIG_PM_PARTITION_SIZE_TFM=0x20000
    CONFIG_PM_PARTITION_SIZE_TFM_SRAM=0x8000
    CONFIG_MBEDTLS_PSA_CRYPTO_STORAGE_C=n
    # CONFIG_MBEDTLS_ENABLE_HEAP=y
    # CONFIG_MBEDTLS_HEAP_SIZE=8192
    CONFIG_PSA_WANT_ALG_HMAC_DRBG=y
    CONFIG_PSA_WANT_ALG_HMAC=y
    CONFIG_PSA_WANT_ALG_SHA_256=y
    # CONFIG_PSA_WANT_ALG_RSA_OAEP=y
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_4096=y
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY=y
    # CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_MAIN_STACK_SIZE=8192
    # CONFIG_HEAP_MEM_POOL_SIZE=4096
    CONFIG_HEAP_MEM_POOL_SIZE=8192
    # Enable logging
    CONFIG_CONSOLE=y
    CONFIG_LOG=y
    Dropping of around 32 kB from log silence is a good win. It looks the TF-M module disables didn’t help because your PSA_WANT_* config already keeps those modules out of the build and the remaining 130 kB is mostly the crypto libraries (P-384, ECDH, HKDF, CCM, Oberon and CC3XX).
    However you can try disabling unused CC3XX hardware sub-drivers:
    CONFIG_PSA_USE_CC3XX_ASYMMETRIC_SIGNATURE_DRIVER=n
    CONFIG_PSA_USE_CC3XX_CIPHER_DRIVER=n
    CONFIG_PSA_USE_CC3XX_HASH_DRIVER=n
    CONFIG_PSA_USE_CC3XX_MAC_DRIVER=n
    But keep CC3XX for key agreement (ECDH), AEAD (CCM), and key management. If you still need more after measuring, you can have P-256 instead of P-384 (Only if your server allows it).
    Best Regards,
    Syed Maysum
