Hi
I'm very new and looking at the PTR5518 breakout board. The docs below specify some of the pins:
Are the pins EN, RX, TX, RTS etc. tied to P0.08, P0.09, P0.12, P0.19, respectively, only in the stock firmware? That is, these pins are tied to EN, RX, RTS, etc. because that's how they're defined in the firmware. So, a custom firmware could well give very different pin assignments. But then, isn't it necessary to ground EN in order to ground RTS (P0.19) in order to program the board? If so, is it that P0.19 needs to be grounded for flash programming?
Thanks
