nRF7002 locks up when coexistence is enabled
We are currently experiencing an issue with the nRF7002 that appears to be present when coexistence is enabled: The nRF7002 becomes unresponsive, seemingly at random, multiple times a day. This issue occurs on both our custom hardware as well the nRF7002DK running our application. With coexistence disabled, I have yet to see this issue occur.
In my logs, I see that the RPU goes to sleep but doesn't return until after CONFIG_NRF_WIFI_RPU_RECOVERY_PS_ACTIVE_TIMEOUT_MS has elapsed when the watchdog triggers an RPU recovery.
[01:26:22.920,410] <inf> wifi_nrf: hal_rpu_ps_wake: RPU PS state is AWAKE
[01:26:22.931,304] <inf> wifi_nrf: hal_rpu_ps_sleep: RPU PS state is ASLEEP
[01:26:23.034,851] <inf> wifi_nrf: hal_rpu_ps_wake: RPU PS state is AWAKE
[01:26:23.045,562] <inf> wifi_nrf: hal_rpu_ps_sleep: RPU PS state is ASLEEP
[01:26:23.055,572] <inf> wifi_nrf: hal_rpu_ps_wake: RPU PS state is AWAKE
[01:26:23.066,467] <inf> wifi_nrf: hal_rpu_ps_sleep: RPU PS state is ASLEEP
[01:27:12.849,395] <inf> wifi_nrf: hal_rpu_ps_wake: RPU PS state is AWAKE
[01:27:12.850,463] <inf> wifi_nrf: Received watchdog interrupt
[01:27:12.850,952] <inf> wifi_nrf: Processing watchdog interrupt
[01:27:12.851,501] <inf> wifi_nrf: RPU sleep opp diff: 49785 ms, last RPU sleep opp time: 5183066
[01:27:12.852,142] <inf> wifi_nrf: RPU recovery needed
[01:27:12.853,424] <err> wifi_nrf: nrf_wifi_rpu_recovery_work_handler: Starting RPU recovery
[01:27:12.854,064] <err> wifi_nrf: nrf_wifi_rpu_recovery_work_handler: Bringing the interface down
Sometimes this happens eight minutes after powering on, other times it can happen after 30 minutes. In this instance it took nearly 1.5 hours. I have tried preventing the nRF7002 from going to sleep with CONFIG_NRF_WIFI_LOW_POWER=n. I reduced CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT from 7500 to 4000. Nothing I've done so far seems to prevent this issue from occurring while coexistence is enabled. While I can tune the watchdog timeout value to minimise the time that the nRF7002 is "offline", this is not the ideal solution given this issue happens so frequently.
The current use case of our application involves scanning for BLE peripherals while being connected to a peripheral that is sending one small packet of data once a second. This data is sent to our backend via a TLS connection as well as to a device connected locally via a TCP connection. Our application is also broadcasting small packets via UDP once a second on the local network and has a TCP socket listener open.
We are using NCS v3.1.1 but upgraded to v3.3.0 to see if the issue still exists, which it does. Coexistence is configured as described in Nordic's documentation but for 4-wire mode. Our application is not overloading the system (plenty of idle time). BLE scanning is configured for 100ms interval with 20ms window. Our hardware is using the shared antenna configuration.
Have I missed something? I'm all out of ideas at the moment.
Jon
    So looks like rpu recovery is functioning the way it should atleast, though it is odd to me that it is needed more when using BLE-coexistance. There might be something with the complexities of PTA and 4-wire here that is at fault.
    I'll ask the relevant R&D team and get back to you.
    How are you enabling it for 4-wire mode btw?
    I would expect that to make it kick in immediately. Especially if you do not have CONFIG_NRF_WIFI_RPU_RECOVERY=n. Is that not what you are seeing?
    Elfving
  • Hi, Elfving
    Our hardware design is based off of the nRF7002DK and so we also copied the coexistence configuration from its board definition files, which is configured for 4-wire coexistence if I am not mistaken:
    nrf_radio_coex: coex {
    	status = "okay";
    	compatible = "nordic,nrf7002-coex";
    	req-gpios = <&gpio0 28 GPIO_ACTIVE_HIGH>;
    	status0-gpios = <&gpio0 30 GPIO_ACTIVE_HIGH>;
    	grant-gpios = <&gpio0 24 (GPIO_PULL_DOWN | GPIO_ACTIVE_LOW)>;
    	swctrl1-gpios = <&gpio0 29 GPIO_ACTIVE_HIGH>;
    According to Kconfig.nrfwifi, CONFIG_NRF_WIFI_RPU_RECOVERY depends on CONFIG_NRF_WIFI_LOW_POWER:
    config NRF_WIFI_RPU_RECOVERY
    	bool "RPU recovery mechanism"
    	# Relies on power-save mode, so, LPM is needed
    	depends on NRF_WIFI_LOW_POWER
    	default y
    	select EXPERIMENTAL
    	help
    		Enable the RPU recovery mechanism to recover from an RPU (nRF70) hang.
    		This feature performs an interface reset (down and up), which triggers
    		a RPU cold boot. The application's network connection will be lost during
    		the recovery process, and it is the application's responsibility to
    		re-establish the network connection.
    I can confirm that during my test with CONFIG_NRF_WIFI_LOW_POWER=n, the RPU recovery mechanism never kicked in. I would have thought CONFIG_NRF_WIFI_RPU_RECOVERY would be available even without CONFIG_NRF_WIFI_LOW_POWER as we have no use for low-power mode but still want the safety of recovery.
    I saw references to the nAN that you linked but admittedly only read it now, leaving me even more confused as to how coexistence is supposed to work or be configured. Is it correct to say that the driver selects 3-wire or 4-wire mode depending on the pins configured?
    I tested with the swctrl1-gpios property removed from the coex node to enable, I assume, 3-wire mode to see if there is any difference but the issue still remains. I have configured the PTA and non-PTA registers.
    Jon
  • Hi again,
    I've asked the relevant R&D team:
    • Nordic's BLE Coex sample only supports 3-wire interface. 4-wire mode is possible on nRF70 but not exercised in any sample so far and requires changes in the dts files, wi-fi coex initialization firmware and also in the BLE coex software.
    • Is 4-wire a strict requirement or they can move to the default 3-wire coex?
    • If they can share the code changes (against NCS ver x) they have made w.r.t coex, we can review those.
    Elfving
  • Hi, Elfving
    According to the "coexistence of short-range radio and other radios" webpage regarding nRF70 coexistence, only the req-gpiosstatus0-gpios, and grant-gpios properties are required by the nrf_radio_coex node for nRF70 coexistence.
    But then, what is the swctrl1-gpios property in the nRF7002DK devicetree doing?
    4-wire is not even a requirement. We used the nRF7002DK design as a reference and modified pin assignments for our hardware. Since the nRF7002DK devicetree had all four coexistence lines defined, we did the same.
    We have not made any code changes to the SDK.
    I have tested 3-wire coexistence, but there is still no improvement to the situation. I have double-checked our configuration against the BLE Coex sample but there is nothing fundamentally different in terms of nRF70 and coexistence configurations. I will try running our code on the nRF7002DK with separate antennas enabled to see if the problem is isolated to the shared antenna configuration.
    Jon
  • Hi and sorry about the wait, I've been gone for a few days.
    It looks like you are indeed using the 3-wire coex. swctrl1 is defined in the DTS as a generic hw feature (required for 4-wire), but not used in the coex sample.This is quite exhaustive and gives you more of the details.
    I agree running this with separate antennas will help understand the issue you are facing.
    Elfving
