Inquiry regarding NCSDK-38697: Unexpected DFU behavior when migrating from Partition Manager to Devicetree (NCS v3.2.4 to v3.3.1)
Hello.
We are developing a project based on the nRF54L15 SoC, utilizing MCUboot, image compression, and TF-M (Trusted Firmware-M).
As part of our upgrade from NCS v3.2.4 to v3.3.1, we are currently working on migrating our flash partitioning approach from Partition Manager to Devicetree.
We are aware of the known issue NCSDK-38697, which is highly critical for us. However, there seems to be a discrepancy between the description of NCSDK-38697 and our actual test results.
NCSDK-38697: Updating compressed DFU for an old project does not work with the new partitioning approach with DTS
nrfconnectdocs.nordicsemi.com/.../known_issues.html
Here is what we observed during our DFU testing:
  • PM to DTS: When we applied a Devicetree-configured firmware update to a device currently running Partition Manager-configured firmware, the DFU update succeeded.
  • DTS to DTS: Conversely, when we applied a Devicetree-configured firmware update to a device already running Devicetree-configured firmware, the DFU update failed.
Is this behavior expected or somehow related to the phenomenon described in NCSDK-38697?
Additionally, could you please provide a rough timeline on when NCSDK-38697 is expected to be fixed?
Since the migration guide mentions that the Partition Manager will be deprecated and removed in the future, we would like to complete our transition to Devicetree as early as possible.
a.da
  • The sizes of slot1_partition and slot0_partition in distributor/sysbuild/mcuboot/boards/nrf54l15dk_nrf54l15_cpuapp_dts.overlay and distributor/boards/nrf54l15dk_nrf54l15_cpuapp_ns_dts.overlay should be the same. See this example: nrf91_bootloader_partitions.dtsi
    It might also need distributor/boards/nrf54l15dk_nrf54l15_cpuapp_ns.conf as the content of nrf54l15dk_nrf54l15_cpuapp.conf.
    No, that is incorrect.
    Since this project has image compression enabled, slot0_partition and slot1_partition do not need to be the same size.
    As you know, the secondary slot only needs to be large enough to hold the compressed binary, which is naturally smaller than the uncompressed application in the primary slot.
    To reiterate, this is a direct migration from Partition Manager to Devicetree.
    Under the previous Partition Manager configuration, this exact asymmetrical partition layout worked perfectly fine without any issues.
    Instead of questioning these fundamental configurations, we need you to focus on the actual replication. Please run the sample project we provided on your nRF54L15DK, reproduce the DTS-to-DTS DFU failure, and investigate why the DTS implementation is failing where the Partition Manager succeeded.
    We look forward to your report on the root cause after you have successfully executed the DFU with the provided sample.
  •  I ran your project. Did you get the same error log after updating the package? Since you only mention that the DFU update failed without a log, I need to confirm that we are seeing the same issue.
    Could you also provide the partition file (pm_static.yml)?
  • Did you get the same error log after updating the package?
    Yes, it is the exact same log.
    Since you requested a sample project to reproduce the issue, we provided the complete environment that replicates that exact behavior.
    To help you compare and isolate the issue, I have attached the following files:
    • pm_static_nrf54l15dk_nrf54l15_cpuapp_ns_pm.yml: The partition file from before our DTS migration.
    • sysbuild_pm.conf: The configuration tailored for the Partition Manager (PM) version of this sample.
    • The PM-configured build artifacts ( merged.hex and dfu_application.zip files): Verified to successfully complete the DFU update without any issues.
    4174.pm.zip
    When building this PM-based version, please ensure that FILE_SUFFIX=pm is set.
    With both the failing DTS setup and the working PM setup now in your hands, you have all the necessary data to advance the investigation and pinpoint the root cause.
    We look forward to your analysis.
  • It fails on hash verification due to a changing header padding value.
    Here is the PR for that TFM+compression issue https://github.com/nrfconnect/sdk-mcuboot/pull/704
