Request for documented CRACEN/PK microcode interface for a clean-room open-source implementation on nRF54L
Hello Nordic engineers,
I maintain the lolren/nrf54-arduino-core project: a bare-metal Arduino core for nRF54 boards that deliberately avoids Zephyr and vendor RTOS dependencies. One current limitation is that secp256r1 ECC is software-only in my core because the nRF54L CRACEN PK path depends on Nordic-supplied microcode; as a result, Thread/Matter pairing is currently CPU-bound and significantly slower than it should be. I have been working from the public nRF54L15/L10/L05 datasheet and from the nRF Connect SDK CRACEN/KMU documentation and driver sources.
From the public documentation, my understanding is that on nRF54L15 / nRF54L10 / nRF54L05, CRACEN uses uploaded microcode for asymmetric operations, that the blob must be loaded into a special CRACEN RAM area after reset, and that Nordic’s current SDK copies a 5,120-byte ba414ep_ucode payload into a dedicated microcode address before calling sx_pk_init(). Public PK registers expose operand pointers, size fields, curve selection, endianness control, status/error reporting, and start/IRQ control, but the actual operation encoding and microcode contract are not documented publicly. A recent DevZone thread about PK.COMMAND.OPEADDR appears to confirm that this public documentation is incomplete for standalone bring-up.
I am not asking Nordic to open-source the existing proprietary microcode blob. I am asking whether Nordic can provide enough architectural and interface documentation to make a clean-room, open-source replacement feasible for the nRF54L CRACEN PK engine.
The specific questions I would appreciate help with are:
  • Microcode loader/interface contract
    • What is the public, supported format of the CRACEN/PK microcode image, if any?
    • Is the payload simply a raw instruction/data image copied to CRACEN RAM, or does it have a header, version field, checksum, or ABI/version handshake?
    • What is the required memory layout, alignment, base address, size limit, and reset/power-cycle invalidation model for the uploaded image?
    • Is there a documented way to detect “compatible microcode present” versus “missing/incompatible microcode”?
  • PK engine programming model
    • What is the expected meaning/encoding of PK.COMMAND.OPEADDR, and where is the complete operation map documented?
    • For each supported asymmetric primitive, what are the exact operand/result slot layouts expected by the PK engine or loaded microcode?
    • Are there hidden or mandatory conventions for operand slots, auxiliary buffers, modulus staging, endianness, padding, or scratch space beyond what is visible in PK.POINTERS, PK.COMMAND, PK.CONTROL, and PK.STATUS?
    • Are there example register sequences for at least P-256 ECDH, P-256 ECDSA verify, Ed25519 verify/sign, X25519, and any RSA operations that are expected to be supported on nRF54L?
  • Security, timing, and side-channel expectations
    • Which timing/side-channel properties are part of the required compatibility contract, versus properties of Nordic’s current internal implementation?
    • Are there mandatory countermeasure settings or behaviours for PKE/IKG usage, given the documented protection against timing attacks/DPA and tamper-event handling?
    • Should a compatible replacement reproduce the same ERRORFLAGS, FAILPTR, zeroisation behaviour, and tamper behaviour, or is numeric correctness alone sufficient?
  • Validation and tooling
    • Can Nordic provide a minimal set of authoritative test vectors and expected register/memory traces for one or two representative operations?
    • Is there any recommended trace/debug tooling for CRACEN PK bring-up beyond the public nRF Connect SDK tooling and the standard debug stack?
    • Are there existing public samples that exercise the PK path without going through the full PSA abstraction?
  • Licensing and redistribution
    • Is a clean-room reimplementation of the externally visible CRACEN PK behaviour permitted, provided it does not copy Nordic’s distributed microcode blob or non-public sources?
    • Are the instruction encoding, operation map, or other aspects of the microcode ABI considered confidential or third-party encumbered?
    • If Nordic can document the interface, would redistribution of an independently implemented replacement for use on Nordic ICs be acceptable from Nordic’s perspective?
  • Hi Loren,
    Please take a look at the Disclaimer section in the datasheet (page 145/146). The following has been mentioned here:
    " CRACEN is recommended for use with the libraries in Nordic Semiconductor device SDKs. These libraries are tested and verified to work with the CRACEN hardware. The CRACEN subsystem documentation and register descriptions are for reference only and can be used for modifying the Nordic supplied SDK libraries or implementing new features. Nordic Semiconductor ASA reserves the right to change the CRACEN documentation and register descriptions without further notice. Changes will not trigger erratas and will not be seen as changing form/fit/function of the device. Please note that Nordic cannot support questions directly related to the register interface or modification of the source code implementation. Nordic provide support for the top-level API in the software library distributed as part of the device SDK."
    Best Regards,
    Samruddhi
  • Thank you for your answer! This helps me a lot to get closer to my goal! I was expecting some answer that leads to nowhere, but my problem is solved now!
    Nordic support rulez!
