Problem with updatable MCUBoot + multi updatable images
I work on a zephyr project with updatable MCUBoot and two updatable images. This configuration ends up with an unbootable image. The reason is that the CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER ends up with value 1 while the SECURE_BOOT_APPCORE is enabled and MCUBOOT_UPDATEABLE_IMAGES > 1. The following patch seems to solve the issue:
diff --git a/sysbuild/CMakeLists.txt b/sysbuild/CMakeLists.txt
index 7abed9c84c..155f83be32 100644
--- a/sysbuild/CMakeLists.txt
+++ b/sysbuild/CMakeLists.txt
@@ -232,6 +232,17 @@ function(${SYSBUILD_CURRENT_MODULE_NAME}_pre_cmake)
       set(${current_cache_name} ${value} CACHE INTERNAL "" FORCE)
     endforeach()
+    if(SB_CONFIG_SECURE_BOOT_APPCORE)
+      math(EXPR correct_mcuboot_image_number "${mcuboot_total_images} - 1")
+      if(NOT ${NCS_MCUBOOT_MCUBOOT_IMAGE_NUMBER} EQUAL ${correct_mcuboot_image_number})
+        set(image_list b0;mcuboot;${updateable_images})
+        foreach(image ${image_list})
+          set_config_int(${image} CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER ${correct_mcuboot_image_number})
+        endforeach()
+        set(NCS_MCUBOOT_MCUBOOT_IMAGE_NUMBER ${correct_mcuboot_image_number} CACHE INTERNAL "" FORCE)
+      endif()
+    endif()
     # Assign image IDs for MCUboot extra images
     set(dfu_slots_application_kconfigs CONFIG_MCUBOOT_EXTRA_1_IMAGE_NUMBER;CONFIG_MCUBOOT_EXTRA_2_IMAGE_NUMBER)
     set(dfu_slots_cache_names NCS_MCUBOOT_EXTRA_1_IMAGE_NUMBER;NCS_MCUBOOT_EXTRA_2_IMAGE_NUMBER)
NCS v3.5.0-preview1
nRF54L15 DK
Could you confirm if you can reproduce the issue?
Filip
  • Hi Filip,
    Could you elaborate on the details of the reproduction?
    Amanda H.
  • Hi Amanda,
    To reproduce the issue, you need to build the following architecture:
    b0
    mcuboot (s0)
    mcuboot (s1)
    custom app 1 (mcuboot_primary)
    custom app 1 (mcuboot_secondary)
    custom app 2 (mcuboot_primary_1)
    custom app 2 (mcuboot_secondary_1)
    To achieve this, you need the following options:
    SB_CONFIG_SECURE_BOOT_APPCORE=y
    SB_CONFIG_BOOTLOADER_MCUBOOT=y
    SB_CONFIG_MCUBOOT_UPDATEABLE_IMAGES=2
    This log shows that the MCUBoot doesn't even see image index 2 (only 0 and 1). This ends up with unbootable primary image:
    Fprotect disabled. No protection applied.
    LCS-awareness disabled.
    Attempting to boot slot 0.
    Attempting to boot from address 0x7800.
    I: Trying to get Firmware version
    I: Firmware signature verified.
    Firmware version 1
    I: Setting monotonic counter (version: 1, slot: 0)
    *** Booting MCUboot v2.3.0-dev-b39452e9c7e8 ***
    *** Using nRF Connect SDK v3.5.0-preview1-f62d6ecf1b15 ***
    *** Using Zephyr OS v4.4.0-b1fd0755fc8e ***
    I: Starting bootloader
    I: LCS-awareness disabled, skipping LCS check
    I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Boot source: none
    I: Image index: 0, Swap type: none
    I: Image index: 1, Swap type: none
    W: Cannot upgrade: not a compatible amount of sectors
    E: Image in the primary slot is not valid!
    E: Unable to find bootable image
    Here is the log after applying the patch I provided:
    Firmware version 1
    I: Image index: 2, Swap type: none
    I: Bootloader chainload address offset: 0x23000
    I: Image version: v0.0.0
    I: Jumping to the first image slot
    *** Booting nRF Connect SDK v3.5.0-preview1-f62d6ecf1b15 ***
      Recovery App (nRF54L15 POC)
      NCS version: 3.5.0-preview1
    Normal boot - chain-loading main app (image 1)...
    Jumping to 0x000e8800 (MSP=0x200166e8, Reset=0x000f30fd)
      Main app - nRF54L15
    BLE advertising as "Main App"
    It now sees all 3 images and works fine.
    Filip
  • Thanks for the nice sharing. I have forwarded it to the internal team.
