nRF54L15 PDM clock runs at ~1/32 of expected (PCLK1M instead of PCLK32M) on a custom board works on DK
# nRF54L15 PDM clock runs at ~1/32 of expected (PCLK1M instead of PCLK32M) on a custom board -works on DK
## Summary
On a custom nRF54L15 board, the PDM peripheral clock (PDM_CLK) comes out at **20 kHz**
measured on a logic analyzer, where I expect **1.28 MHz** (fs = 16 kHz, RATIO = 80).
The PDM **PRESCALER register reads 25** (correct), so the divider is right -but the
**clock source feeding the PDM is ~32x too low**: it behaves as if the PDM is sourced from
**PCLK1M (~1 MHz)** instead of **PCLK32M (32 MHz)**.
The same application/driver path works on the nRF54L15-DK. Critically, the **stock
"known-good" firmware that works on the DK shows the identical ~1/32 clock on this custom
board**, so this is not specific to my application code.
I'm looking for: **what determines whether the PDM gets PCLK32M vs a much lower peripheral
clock, and how do I force the 32 MHz peripheral clock (PCLK32M) to the PERI domain / the
PDM on a custom board?**
## Environment
- nRF Connect SDK **v3.3.0** (Zephyr 4.3.99)
- SoC: **nRF54L15** (cpuapp), custom board
- Zephyr DMIC API → `dmic_nrfx_pdm` driver, nodes `pdm20` and `pdm21`
- Mics: Infineon IM72D128V PDM. pdm20 = P1.12 (CLK) / P1.09 (DIN); pdm21 = P1.11 (CLK) / P1.10 (DIN)
- Requested config: `pcm_rate = 16000`, 16-bit, `min/max_pdm_clk_freq` bracket = 1.17–1.70 MHz
## Measurements / evidence
| Measurement | Method | Result |
| PDM_CLK pin frequency | logic analyzer on P1.12 | **20.0 kHz** (expected 1.28 MHz) |
| PDM PRESCALER register | `nrf_pdm_prescaler_get(NRF_PDM20)` at runtime | **25** (correct for 1.28 MHz from 32 MHz) |
| Implied PDM source clock | 20 kHz × PRESCALER (×2 per datasheet formula) | **~0.5–1.0 MHz** (≈ PCLK1M; ~1/32 of PCLK32M) |
| CPU clock | timed a fixed CPU loop against GRTC/k_uptime | **~64 MHz (full speed)** |
| HFXO start | `z_nrf_clock_control_get_onoff(CLOCK_CONTROL_NRF_SUBSYS_HF)` + `onoff_request`, spin-wait | **starts OK in ~5 ms** |
| `dmic_configure()` | return value | **0 (success)**, blocks flow, no -EINVAL |
| PCM data | drained blocks | **constant** (mic not clocked in its operating range -consistent with a clock far below the IM72D128V's ~1 MHz minimum) |
So: divider correct, CPU full speed, HFXO healthy -only the **PDM's peripheral source
clock** is ~1/32 of PCLK32M. The nRF54L15 PDM has only a `PRESCALER` register (no
`CLKSELECT`/`MCLKCONFIG`), i.e. it is hardwired to PCLK32M, so there is no DT clock-source
to reroute.
## What I have already tried (no change to the ~1/32 ratio)
DeviceTree / Kconfig (all matched to the nRF54L15-DK board files):
- `clock-source = "PCLK32M"` and `"PCLK32M_HFXO"` (the latter raised it from ~6 kHz to ~20 kHz, but no further)
- `&clock { status = "okay"; }``CONFIG_CLOCK_CONTROL_NRF=y`
- `&hfxo { load-capacitors = "internal"; load-capacitance-femtofarad = <…>; }`
- `&lfxo { load-capacitors = "internal"; … }`
- `&regulators { status = "okay"; }` + `&vregmain { regulator-initial-mode = <NRF5X_REG_MODE_DCDC>; }` + `CONFIG_REGULATOR=y`
- `&grtc` identical to DK (owned-channels, status okay)
- `CONFIG_PM_DEVICE=y`, `CONFIG_PM_DEVICE_RUNTIME=y`
- PDM clock bracket variations (1.17–1.70 MHz → PRESCALER 25; 380–640 kHz → PRESCALER 63). The output scales exactly with PRESCALER, confirming the divider works and the **source** is fixed at ~1/32.
Application:
- Held constant-latency: `nrf_sys_event_request_global_constlat()` (`CONFIG_NRF_SYS_EVENT=y`) for the lifetime of capture.
- Verified `CONFIG_CLOCK_CONTROL_NRF=y`, `CONFIG_REGULATOR=y`, DCDC mode, PRESCALER value, HFXO start, CPU speed all in the flashed image.
## The key data point
The **proto firmware that runs correctly on the nRF54L15-DK** (real PDM audio) produces the
**same ~1/32 PDM clock on this custom board**. Same SoC, same SDK, equivalent DT -only the
physical board differs.
## Questions
1. On the nRF54L15, what establishes **PCLK32M (32 MHz)** for a PERI-domain peripheral like
   the PDM, and under what condition would a PERI peripheral instead be clocked at
   **~PCLK1M (~1 MHz)** -a clean ~1/32?
2. Is there a board-level dependency (supply/decoupling, DCDC inductor, a specific clock or
   power-domain request) required for PCLK32M to reach the PERI domain that the DK satisfies
   but a custom board might not?
3. The PDM `PRESCALER` reads 25 and the pin is 20 kHz -can you confirm the
   `CLK = PCLK32M / (2 × PRESCALER)` vs `CLK = PCLK32M / PRESCALER` formula for the
   nRF54L15, so I can back-compute the true source frequency exactly?
4. Is there a register I can read at runtime to confirm the actual PCLK32M frequency / the
   PDM's clock source, to prove whether it is PCLK1M vs PCLK32M?
## Minimal DT (PDM + clock/power), matched to the DK
```dts
&clock      { status = "okay"; };
&regulators { status = "okay"; };
&vregmain   { status = "okay"; regulator-initial-mode = <NRF5X_REG_MODE_DCDC>; };
&hfxo       { load-capacitors = "internal"; load-capacitance-femtofarad = <8000>; };
&lfxo       { load-capacitors = "internal"; load-capacitance-femtofarad = <17000>; };
&pdm20 {
    status = "okay";
    pinctrl-0 = <&pdm20_default_alt>;   /* CLK P1.12, DIN P1.09 */
    pinctrl-names = "default";
    clock-source = "PCLK32M";
    queue-size = <20>;
prj.conf (clock/power relevant):
CONFIG_AUDIO=y
CONFIG_AUDIO_DMIC=y
CONFIG_AUDIO_DMIC_NRFX_PDM=y
CONFIG_REGULATOR=y
CONFIG_PM_DEVICE=y
