I2C clock stretching nRF54L / Zephyr
This is nRF54L10 with Zephyr, SDK & toolchain both v3.02 on a custom board.
I am investigating I2C crashing on the 54L10. This happens during writing data to a MAX41462 radio IC via 12c, this involves writing a packet of 25 bytes @10kbps. I am sending a burst of 5 packets at 100ms spacing, repeated every second as a test.
The transmit routine runs in a work queue. I use the following code to write:
rc = i2c_reg_write_byte(i2c_dev, I2C_ADDR,REG_ADDR, data);
The MAX41462 has a 4 byte FIFO buffer and implements flow control by I2C clock stretching which seems to be causing the crash - using a logic analyser I can see the clock signal being held low after 8 bits of data transfer. So are there any tricks techniques or tweaks or caveats when using I2C clock stretching peripherals?
(Note I do realise that my problem could lie with the peripheral IC latching, but I need to understand how nRF/Zephyr handles things to get a holistic view of the situation)
Incidentally the MAX41462 requires SDA to be toggled after power up. Is it OK to configure the line as a GPIO output and toggle before running i2c_configure() ?
    ''I am investigating I2C crashing on the 54L10. This happens during writing data to a MAX41462 radio IC via 12c, this involves writing a packet of 25 bytes @10kbps.''
    The supported baudrate for nRF54l05/10/15 is
    ''The main features of TWIM are the following:
    • I2C compatible for 100 kbps and 400 kbps
    • 1000 kbps bit rate support for selected pull-up resistor/bus capacitance combinations
    • Supported baud rates:
      • 100 kbps
      • 400 kbps
      • 1000 kbps''
    source:TWIM — I2C compatible two-wire interface controller with EasyDMA • nRF54L15 | nRF54L10 | nRF54L05 Datasheet • Technical Documentation
    You can try at least 100kbps as a first try to see if that helps.
    ''Incidentally the MAX41462 requires SDA to be toggled after power up. Is it OK to configure the line as a GPIO output and toggle before running i2c_configure() ?''
    It should be possible to implement if TWIM is disabled. ''
    The SCL and SDA signals are mapped to physical pins using the PSEL.SCL and PSEL.SDA registers.
    These registers and their configurations are only used when TWIM is enabled, and retained while the device is in System ON mode. When the peripheral is disabled, the pins behave as regular GPIOs and are configured according to their respective OUT bit field and PIN_CNF[n] register. Configure registers PSEL.SCL and PSEL.SDA when TWIM is disabled.''
    TWIM pin configuration • nRF54L15 | nRF54L10 | nRF54L05 Datasheet • Technical Documentation
    Thanks.
    BR
    Kazi
  • You can try at least 100kbps as a first try to see if that helps.
    OK, but I don't want to blindly try things, I want to understand what's what.
    Is I2C clock stretching supported? Can I configure a timeout by code, kconfig etc?
    Do you mean enabled as in kconfig/devicetree, or enabled by running  i2c_configure()? Also, I'd rather not be talking directly to registers if possible while using Zephyr.
  • ''Run at 100 kbps minimum with the TWIM peripheral''
    The supported bit rate of TWIM is 100kbos, 400kbps, 100 kbps, which I mentioned in my previous reply with the source link. This frequency is enforced at the Zephyr driver level. You will configure this in the device tree file(overlay file). For example:
    &i2c20 {
        status = "okay";
        pinctrl-0 = <&i2c20_default>;
        pinctrl-1 = <&i2c20_sleep>;
        clock-frequency = <I2C_BITRATE_STANDARD>;  /* 100 kbps */
        /* Example sensor device */
        my_sensor: sensor@48 {
            compatible = "vendor,sensor";
            reg = <0x48>;
            status = "okay";
    When we set ''I2C_BITRATE_STANDARD'' as clock frequency, we set it as 100kbps.
    ''Do you mean enabled as in kconfig/devicetree, or enabled by running  i2c_configure()? Also, I'd rather not be talking directly to registers if possible while using Zephyr.''
    No, these PSEL.SCL and PSEL.SDA registers are not configured in the kconfig or not by running i2c_configure(). This is set in the pincntrl file of board file.
    for example:
    &pinctrl {
        /omit-if-no-ref/ i2c21_default: i2c21_default {
            group1 {
                psels = <NRF_PSEL(TWIM_SCL, 1, 11)>,
                        <NRF_PSEL(TWIM_SDA, 1, 12)>;
                bias-pull-up;
        /omit-if-no-ref/ i2c21_sleep: i2c21_sleep {
            group1 {
                low-power-enable;
    Now getting back to the clock stretching of TWIM again, since it is supported in TWIM, it may possible to set the bit rate below 100kbps according to this old case (+) I2C frequencies below 100kbps - Nordic Q&A - Nordic DevZone - Nordic DevZone. I will talk to team to be sure.
    ''The MAX41462 has a 4 byte FIFO buffer and implements flow control by I2C clock stretching which seems to be causing the crash - using a logic analyser I can see the clock signal being held low after 8 bits of data transfer. ''
    Could you please share the error log and the output from logic analyser?
    Thanks.
    BR
    Kazi
  • It was the peripheral holding the clock line. I have rewritten my code to use burst writes instead of individual register writes and it's a lot happier now. I can see the clock stretching working on the LA so all good.
    I do still need to explore the possibility of manually controlling the SDA  and/or SCL lines whilst the interface is configured for i2c/twi. Would you prefer I raised a separate ticket for that?
    According to datasheet ''
    Only one peripheral can be assigned to drive a GPIO pin at a time. If more than one peripheral is assigned to a GPIO pin, it could result in unpredictable behavior.
    When TWIM is in System OFF mode or disabled, the pins using TWIM must be configured by the GPIO peripheral according to the following table to ensure correct pin behavior.'' it's possible to control manually SDA and SCL line while interface is configured for i2c/twi.
    You can read this case (+) nRF54L15 I2C and GPIO sharing pin control - Nordic Q&A - Nordic DevZone - Nordic DevZoneto get idea how to initiate this?
