UART TX timing differs between ISR callback and workqueue
Hello Nordic team,
Environment:
  • SDK 3.1.0
  • nRF54L15
  • UART / RS-232
I am seeing different UART TX timing depending on whether I transmit from inside the UART RX callback vs using a k_work handler.
On our nRF‑based device at 9600 baud, each byte correctly takes ~1.04 ms.
However, the gap between bytes (idle time between stop bit of one byte and start bit of the next) changes drastically depending on context:
1. UART RX callback → UART TX
If we call our transmit function directly inside the UART RX callback (or a parser function invoked from it), the inter‑byte gap is only ~53 µs.
2. k_work_delayable handler → UART TX
If we schedule the exact same transmit function using k_work_schedule(), the inter‑byte gap increases to ~313 µs, and the target device (RS‑232 peer) accepts the frame reliably.
Nothing else changes; same bytes, same baud rate, same framing.
This difference in inter‑byte spacing is causing a downstream RS‑232 device (non‑Nordic) to fail to parse frames correctly unless TX happens from a workqueue instead of inside the RX callback.
I will attach logic analyzer screenshots showing both cases.
Questions:
  1. Is it expected that UART TX behaves differently when called inside the RX callback vs from a workqueue?
  2. Is there a known restriction that UART TX should not be triggered directly inside the RX callback?
Any guidance or clarification would be appreciated. I will provide LA captures and source snippets in the attachments. Thank you.
// This psuedo code is placed in the same location within an UART RX callback.
// My device recieves a UART message then transmits a UART acknoweldgement.
// Non-working code
void ProcessUartRx()
    SendAck(message->header.message_id);
// Working code
void delayed_ack_handler(struct k_work *work);
static uint8_t g_pending_ack_msg_id;
K_WORK_DELAYABLE_DEFINE(g_delayed_ack_work, delayed_ack_handler);
    SendAck(g_pending_ack_msg_id);
    _pending_ack_msg_id = message->header.message_id;
    k_work_schedule(&g_delayed_ack_work, K_MSEC(0));
Saleae Logic Analyzer captures
failed-uart.salworking-uart.sal
Screenshots
  • Hi Kamal,
    If my math is not completely off today it should take about 1.04 ms to transmit one byte at 9600 baud: (1 start bit + 8 data bits + 1 stop bit) / 9600. And I expect the UART transmitter to continue transmitting while the thread is sleeping in k_msleep() since the busy wait is only 100us,  so this time should not be complety wasted either. I think a simple test you could do is to increase the busy wait from 100 us to 2000 us and see how this affects the gap between the bytes.
    Vidar
  • I have to move onto a new task so I can't test out different wait times. Going back to the original question, why is uart_poll_out() not following the baud rate? I should have no issue using uart_poll_out() since they lower levels (Zephyr/Nordic/Hardware) should be handling the timing between bytes to ensure the 9600 baud rate is followed.
  • I think part of the problem here is that that END event that trigger the UART callback is triggered on the last bit of the transmitted byte, the UART hardware at the same time now start the to transmit the STOP bit. It may look like that if you trigger a new byte during while the STOP bit is still in progress that this cause some conflict in the hardware itself. I guess the reason you see it in specific is that you are running at very low baudrate and don't use the EasyDMA functionality that most do.
    We might need to look at this deeper after the summer holidays, but for now write the entire buffer of bytes.
    Kenneth
