uart30 receive issue
Dear Nordic,
i have started my application with toolchain & sdk both v3.3.0, using custom services & charachteristics, with BLE advertising @500ms interval works fine. but when i disabled VCOM0 from board configurator and then in overlay declaring uart30 pinsP0.0 as TX and P0.1 as RX . Transmit works fine, But recieve not, even in polling mode. when i downgrade sdk and tool chain both to 2.8.0 it started works with all other functionality.
is it issue with sdk and toolchain  3.3.0 &3.31 , or any other method to get it work.
below is prj.conf
CONFIG_GPIO=y
# Bluetooth
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
CONFIG_BT_DEVICE_NAME="Lock_Poc_1.8"
CONFIG_BT_GATT_SERVICE_CHANGED=y
CONFIG_BT_MAX_PAIRED=5
CONFIG_BT_DEVICE_APPEARANCE=0
CONFIG_BT_EXT_ADV=y
CONFIG_BT_PRIVACY=n
CONFIG_BT_SMP=y
CONFIG_BT_BONDABLE=y
CONFIG_BT_FIXED_PASSKEY=y
CONFIG_BT_SETTINGS=y
CONFIG_BT_GATT_DYNAMIC_DB=y
CONFIG_BT_ID_MAX=2
# Buffer parameters to support secure connections and DFU framing packets
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_BUF_ACL_TX_SIZE=251
#CONFIG_BT_PRIVACY=y
#CONFIG_BT_SMP_SC_ONLY=y
#CONFIG_BT_CTLR_TX_PWR_PLUS_8=y
#CONFIG_BT_CTLR_TX_PWR_PLUS_7
#CONFIG_BT_CTLR_TX_PWR_PLUS_6
#CONFIG_BT_CTLR_TX_PWR_PLUS_5
#CONFIG_BT_CTLR_TX_PWR_PLUS_4
#CONFIG_BT_CTLR_TX_PWR_PLUS_3
#CONFIG_BT_CTLR_TX_PWR_PLUS_2
#CONFIG_BT_CTLR_TX_PWR_0
#CONFIG_BT_CTLR_TX_PWR_MINUS_4
#CONFIG_BT_CTLR_TX_PWR_MINUS_8
#CONFIG_BT_CTLR_TX_PWR_MINUS_12
#CONFIG_BT_CTLR_TX_PWR_MINUS_16
#CONFIG_BT_CTLR_TX_PWR_MINUS_20
CONFIG_BT_CTLR_TX_PWR_MINUS_40=y
#CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y
#CONFIG_BT_CTLR_ADVANCED_FEATURES=y
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUMGR=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
#===============For Sleep Mode===========#
CONFIG_PM=y
CONFIG_PM_DEVICE=y
CONFIG_PM_DEVICE_RUNTIME=y
CONFIG_CRC=y
CONFIG_POWEROFF=y
CONFIG_HWINFO=y
#=============for store variable in internal Flash==========#
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
#======================for Button2/GPIO Input==============//
CONFIG_INPUT=y
CONFIG_INPUT_MODE_THREAD=y
#CONFIG_DK_BUTTONS_AND_LEDS=y
CONFIG_REBOOT=y #for Factory reset
# Enable C library extensions and POSIX RTC & Time management
CONFIG_POSIX_API=y
#===================for stack information================#
CONFIG_THREAD_STACK_INFO=y
CONFIG_INIT_STACKS=y
CONFIG_STACK_SENTINEL=y
#===================for change stack ================#
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
#==========================For I2C==================#
#CONFIG_STDOUT_CONSOLE=y
#CONFIG_CBPRINTF_FP_SUPPORT=y
CONFIG_I2C=y
CONFIG_SENSOR=y
CONFIG_I2C_NRFX=y
#==================Fro Consol & UART ouput ==================#
CONFIG_SERIAL=y
CONFIG_UART_LINE_CTRL=n
CONFIG_UART_ASYNC_API=n
CONFIG_CONSOLE=n
CONFIG_UART_CONSOLE=n
CONFIG_PRINTK=n
#=============detach pins from low power crystal=========#
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
below is overlay
/* For more help, browse the devicetree documentation at docs.zephyrproject.org/.../index.html
* You can also visit the nRF DeviceTree extension documentation at docs.nordicsemi.com/.../ncs_configure_app.html
&uicr {
nfct-pins-as-gpios;
&pinctrl {
i2c22_default: i2c22_default {
group1 {
psels = <NRF_PSEL(TWIM_SCL, 1, 3)>,
<NRF_PSEL(TWIM_SDA, 1, 2)>;
bias-pull-up;
i2c22_sleep: i2c22_sleep {
group1 {
low-power-enable;
&i2c22 {
status = "okay";
clock-frequency = <I2C_BITRATE_STANDARD>;
pinctrl-0 = <&i2c22_default>;
pinctrl-1 = <&i2c22_sleep>;
rx8111: rtc@32 {
status = "okay";
compatible = "epson,rx8111";
reg = <0x32>;
&uart20 {
status = "disabled";
chosen {
// /delete-property/ zephyr,console;
// /delete-property/ zephyr,shell-uart;
// /delete-property/ zephyr,uart-mcumgr;
&uart30 {
status = "okay";
current-speed = <115200>;
pinctrl-0 = <&uart30_default>;
pinctrl-1 = <&uart30_sleep>;
&pinctrl {
uart30_default: uart30_default {
group1 {
psels = <NRF_PSEL(UART_TX, 0, 0)>;
group2 {
psels = <NRF_PSEL(UART_RX, 0, 1)>;
bias-pull-up;
uart30_sleep: uart30_sleep {
group1 {
psels = <NRF_PSEL(UART_TX, 0, 0)>,
low-power-enable;
  • surely will update with that also tommorow . i am busy with another task
  • today i tried even in sdk 3.4.0 , having same issue
    while deep diving in driver file by debug, it shows no poll_in bytes, even receiving continuosly in loop.
    also for SDK3.4.0  zephyr.dts is
    /dts-v1/;
    /* node '/' defined in zephyr/dts/vendor/nordic/nrf_common.dtsi:25 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:19 */
    #size-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:20 */
    compatible = "nordic,nrf54l15dk_nrf54l15-cpuapp"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp.dts:13 */
    model = "Nordic nRF54L15 DK nRF54L15 Application MCU"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp.dts:14 */
    /* node '/pin-controller' defined in zephyr/dts/vendor/nordic/nrf_common.dtsi:26 */
    pinctrl: pin-controller {
    compatible = "nordic,nrf-pinctrl"; /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:31 */
    /* node '/pin-controller/uart20_default' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:7 */
    uart20_default: uart20_default {
    phandle = < 0x7 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:114 */
    /* node '/pin-controller/uart20_default/group1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:8 */
    group1 {
    psels = < 0x24 >,
    < 0x2000026 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:9 */
    /* node '/pin-controller/uart20_default/group2' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:13 */
    group2 {
    psels = < 0x1000025 >,
    < 0x3000027 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:14 */
    bias-pull-up; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:16 */
    /* node '/pin-controller/uart20_sleep' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:20 */
    uart20_sleep: uart20_sleep {
    phandle = < 0x8 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:115 */
    /* node '/pin-controller/uart20_sleep/group1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:21 */
    group1 {
    < 0x2000026 >,
    < 0x3000027 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:22 */
    low-power-enable; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:25 */
    /* node '/pin-controller/uart20_sleep/group2' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:28 */
    group2 {
    psels = < 0x24 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:29 */
    low-power-enable; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:30 */
    bias-pull-up; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:31 */
    /* node '/pin-controller/uart30_default' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:35 */
    phandle = < 0x13 >; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:54 */
    /* node '/pin-controller/uart30_default/group1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:36 */
    group1 {
    psels = < 0x0 >; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:62 */
    /* node '/pin-controller/uart30_default/group2' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:41 */
    group2 {
    psels = < 0x1000001 >; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:65 */
    bias-pull-up; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:66 */
    /* node '/pin-controller/uart30_sleep' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:48 */
    phandle = < 0x14 >; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:55 */
    /* node '/pin-controller/uart30_sleep/group1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:49 */
    group1 {
    psels = < 0x0 >,
    < 0x1000001 >; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:72 */
    low-power-enable; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:74 */
    /* node '/pin-controller/spi00_default' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:58 */
    spi00_default: spi00_default {
    phandle = < 0x4 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:117 */
    /* node '/pin-controller/spi00_default/group1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:59 */
    group1 {
    psels = < 0x4000041 >,
    < 0x5000042 >,
    < 0x6000044 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:60 */
    /* node '/pin-controller/spi00_sleep' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:66 */
    spi00_sleep: spi00_sleep {
    phandle = < 0x5 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:118 */
    /* node '/pin-controller/spi00_sleep/group1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:67 */
    group1 {
    < 0x5000042 >,
    < 0x6000044 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:68 */
    low-power-enable; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:71 */
    /* node '/pin-controller/pwm20_default' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:75 */
    pwm20_default: pwm20_default {
    phandle = < 0xe >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:128 */
    /* node '/pin-controller/pwm20_default/group1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:76 */
    group1 {
    psels = < 0x1600002a >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:77 */
    /* node '/pin-controller/pwm20_sleep' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:81 */
    pwm20_sleep: pwm20_sleep {
    phandle = < 0xf >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:129 */
    /* node '/pin-controller/pwm20_sleep/group1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:82 */
    group1 {
    psels = < 0x1600002a >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:83 */
    low-power-enable; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:84 */
    /* node '/pin-controller/spi22_default' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:103 */
    spi22_default: spi22_default {
    phandle = < 0xc >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:149 */
    /* node '/pin-controller/spi22_default/group1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:104 */
    group1 {
    psels = < 0x400002b >,
    < 0x6000027 >,
    < 0x5000026 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:105 */
    bias-pull-down; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:108 */
    /* node '/pin-controller/spi22_sleep' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:112 */
    spi22_sleep: spi22_sleep {
    phandle = < 0xd >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:150 */
    /* node '/pin-controller/spi22_sleep/group1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:113 */
    group1 {
    < 0x6000027 >,
    < 0x5000026 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:114 */
    bias-pull-down; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:117 */
    low-power-enable; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l_05_10_15-pinctrl.dtsi:118 */
    /* node '/pin-controller/i2c22_default' defined in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:8 */
    phandle = < 0x9 >; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:28 */
    /* node '/pin-controller/i2c22_default/group1' defined in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:9 */
    group1 {
    psels = < 0xb000023 >,
    < 0xc000022 >; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:10 */
    bias-pull-up; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:12 */
    /* node '/pin-controller/i2c22_sleep' defined in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:16 */
    phandle = < 0xa >; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:29 */
    /* node '/pin-controller/i2c22_sleep/group1' defined in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:17 */
    group1 {
    < 0xc000022 >; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:18 */
    low-power-enable; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:20 */
    /* node '/entropy_bt_hci' defined in zephyr/dts/vendor/nordic/nrf_common.dtsi:34 */
    rng_hci: entropy_bt_hci {
    compatible = "zephyr,bt-hci-entropy"; /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:35 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf_common.dtsi:36 */
    /* node '/cpus' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:22 */
    cpus {
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:23 */
    #size-cells = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:24 */
    /* node '/cpus/cpu@0' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:26 */
    cpuapp: cpu: cpu@0 {
    compatible = "arm,cortex-m33f"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:27 */
    reg = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:28 */
    device_type = "cpu"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:29 */
    clocks = < &hfpll >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:30 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:31 */
    #size-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:32 */
    /* node '/cpus/cpu@0/itm@e0000000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:34 */
    itm: itm@e0000000 {
    compatible = "arm,armv8m-itm"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:35 */
    reg = < 0xe0000000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:36 */
    swo-ref-frequency = < 0x7a12000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:37 */
    /* node '/clocks' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:52 */
    clocks {
    /* node '/clocks/pclk' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:53 */
    pclk: pclk {
    compatible = "fixed-clock"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:54 */
    #clock-cells = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:55 */
    clock-frequency = < 0xf42400 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:56 */
    phandle = < 0x12 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:596 */
    /* node '/clocks/lfxo' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:59 */
    lfxo: lfxo {
    compatible = "nordic,nrf54l-lfxo"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:60 */
    #clock-cells = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:61 */
    clock-frequency = < 0x8000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:62 */
    load-capacitors = "internal"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:35 */
    load-capacitance-femtofarad = < 0x4268 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:36 */
    phandle = < 0x11 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:596 */
    /* node '/clocks/hfxo' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:65 */
    hfxo: hfxo {
    compatible = "nordic,nrf54l-hfxo"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:66 */
    #clock-cells = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:67 */
    clock-frequency = < 0x1e84800 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:68 */
    startup-time-us = < 0x672 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:69 */
    load-capacitors = "internal"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:40 */
    load-capacitance-femtofarad = < 0x3a98 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:41 */
    phandle = < 0x6 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:243 */
    /* node '/clocks/hfpll' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:72 */
    hfpll: hfpll {
    compatible = "fixed-clock"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:73 */
    #clock-cells = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:74 */
    clock-frequency = < 0x7a12000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:75 */
    phandle = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:30 */
    /* node '/soc' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:79 */
    soc {
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:80 */
    #size-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:81 */
    compatible = "simple-bus"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:23 */
    interrupt-parent = < &cpuapp_nvic >; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:24 */
    ranges; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:25 */
    /* node '/soc/uicr@ffd000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:86 */
    uicr: uicr@ffd000 {
    compatible = "nordic,nrf-uicr"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:87 */
    reg = < 0xffd000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:88 */
    ranges = < 0x0 0xffd000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:89 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:90 */
    #size-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:91 */
    nfct-pins-as-gpios; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:5 */
    /* node '/soc/uicr@ffd000/uicr@500' defined in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:62 */
    bl_storage: uicr@500 {
    reg = < 0x500 0x460 >; /* in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:63 */
    /* node '/soc/ficr@ffc000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:95 */
    ficr: ficr@ffc000 {
    compatible = "nordic,nrf-ficr"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:96 */
    reg = < 0xffc000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:97 */
    #nordic,ficr-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:98 */
    /* node '/soc/memory@20000000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:101 */
    cpuapp_sram: memory@20000000 {
    compatible = "mmio-sram"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:102 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:103 */
    #size-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:104 */
    reg = < 0x20000000 0x40000 >; /* in zephyr/dts/vendor/nordic/nrf54l15.dtsi:10 */
    ranges = < 0x0 0x20000000 0x40000 >; /* in zephyr/dts/vendor/nordic/nrf54l15.dtsi:11 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:31 */
    /* node '/soc/peripheral@50000000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:114 */
    global_peripherals: peripheral@50000000 {
    reg = < 0x50000000 0x10000000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:115 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:116 */
    #size-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:117 */
    ranges = < 0x0 0x50000000 0x10000000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:118 */
    /* node '/soc/peripheral@50000000/dppic@42000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:121 */
    dppic00: dppic@42000 {
    compatible = "nordic,nrf-dppic"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:122 */
    reg = < 0x42000 0x808 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:123 */
    channels = < 0x8 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:125 */
    groups = < 0x2 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:126 */
    status = "okay"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:95 */
    /* node '/soc/peripheral@50000000/ppib@43000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:129 */
    ppib00: ppib@43000 {
    compatible = "nordic,nrf-ppib"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:130 */
    reg = < 0x43000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:131 */
    channels = < 0x8 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:133 */
    status = "okay"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:111 */
    /* node '/soc/peripheral@50000000/ppib@44000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:136 */
    ppib01: ppib@44000 {
    compatible = "nordic,nrf-ppib"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:137 */
    reg = < 0x44000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:138 */
    channels = < 0x8 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:140 */
    status = "okay"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:115 */
    /* node '/soc/peripheral@50000000/spi@4a000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:143 */
    spi00: spi@4a000 {
    compatible = "nordic,nrf-spim"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:150 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:151 */
    #size-cells = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:152 */
    reg = < 0x4a000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:153 */
    interrupts = < 0x4a 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:154 */
    clocks = < &hfpll >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:155 */
    max-frequency = < 0x1e84800 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:156 */
    easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:157 */
    rx-delay-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:158 */
    rx-delay = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:159 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:115 */
    cs-gpios = < &gpio2 0x5 0x1 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:116 */
    pinctrl-0 = < &spi00_default >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:117 */
    pinctrl-1 = < &spi00_sleep >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:118 */
    pinctrl-names = "default",
    "sleep"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:119 */
    /* node '/soc/peripheral@50000000/spi@4a000/mx25r6435f@0' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:121 */
    mx25r64: mx25r6435f@0 {
    compatible = "jedec,spi-nor"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:122 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:123 */
    reg = < 0x0 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:124 */
    spi-max-frequency = < 0x7a1200 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:125 */
    jedec-id = [ C2 28 17 ]; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:126 */
    sfdp-bfp = [ E5 20 F1 FF FF FF FF 03 44 EB 08 6B 08 3B 04 BB EE FF FF FF FF FF 00 FF FF FF 00
    FF 0C 20 0F 52 10 D8 00 FF 23 72 F5 00 82 ED 04 CC 44 83 48 44 30 B0 30 B0 F7 C4
    D5 5C 00 BE 29 FF F0 D0 FF FF ]; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:127 */
    size = < 0x4000000 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:131 */
    has-dpd; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:132 */
    t-enter-dpd = < 0x2710 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:133 */
    t-exit-dpd = < 0x88b8 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:134 */
    reset-gpios = < &gpio2 0x0 0x1 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:135 */
    /* node '/soc/peripheral@50000000/uart@4a000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:163 */
    uart00: uart@4a000 {
    compatible = "nordic,nrf-uarte"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:164 */
    reg = < 0x4a000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:165 */
    interrupts = < 0x4a 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:166 */
    clocks = < &hfpll >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:167 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:168 */
    endtx-stoptx-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:169 */
    frame-timeout-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:170 */
    /* node '/soc/peripheral@50000000/vpr@4c000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:173 */
    cpuflpr_vpr: vpr@4c000 {
    compatible = "nordic,nrf-vpr-coprocessor"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:174 */
    reg = < 0x4c000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:175 */
    ranges = < 0x0 0x4c000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:176 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:177 */
    #size-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:178 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:179 */
    enable-secure; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:180 */
    hibernation-ram-block = < 0x20 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:181 */
    /* node '/soc/peripheral@50000000/vpr@4c000/mailbox@1' defined in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:44 */
    cpuapp_vevif_rx: mailbox@1 {
    compatible = "nordic,nrf-vevif-event-rx"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:45 */
    reg = < 0x1 0x1000 >; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:46 */
    status = "disabled"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:47 */
    interrupts = < 0x4c 0x1 >; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:48 */
    #mbox-cells = < 0x1 >; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:49 */
    nordic,events = < 0x1 >; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:50 */
    nordic,events-mask = < 0x100000 >; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:51 */
    /* node '/soc/peripheral@50000000/vpr@4c000/mailbox@0' defined in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:54 */
    cpuapp_vevif_tx: mailbox@0 {
    compatible = "nordic,nrf-vevif-task-tx"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:55 */
    reg = < 0x0 0x1000 >; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:56 */
    #mbox-cells = < 0x1 >; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:57 */
    nordic,tasks = < 0x7 >; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:58 */
    nordic,tasks-mask = < 0x7f0000 >; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:59 */
    status = "disabled"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:60 */
    /* node '/soc/peripheral@50000000/gpio@50400' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:193 */
    gpio2: gpio@50400 {
    compatible = "nordic,nrf-gpio"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:194 */
    gpio-controller; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:195 */
    reg = < 0x50400 0x300 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:196 */
    #gpio-cells = < 0x2 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:197 */
    ngpios = < 0xb >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:198 */
    port = < 0x2 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:200 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:77 */
    phandle = < 0x3 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:116 */
    /* node '/soc/peripheral@50000000/timer@55000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:203 */
    timer00: timer@55000 {
    compatible = "nordic,nrf-timer"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:204 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:205 */
    reg = < 0x55000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:206 */
    cc-num = < 0x6 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:207 */
    max-bit-width = < 0x20 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:208 */
    interrupts = < 0x55 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:209 */
    clocks = < &hfpll >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:210 */
    prescaler = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:211 */
    /* node '/soc/peripheral@50000000/dppic@82000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:214 */
    dppic10: dppic@82000 {
    compatible = "nordic,nrf-dppic"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:215 */
    reg = < 0x82000 0x808 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:216 */
    channels = < 0x18 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:218 */
    groups = < 0x6 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:219 */
    status = "okay"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:99 */
    /* node '/soc/peripheral@50000000/ppib@83000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:222 */
    ppib10: ppib@83000 {
    compatible = "nordic,nrf-ppib"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:223 */
    reg = < 0x83000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:224 */
    channels = < 0x8 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:226 */
    status = "okay"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:119 */
    /* node '/soc/peripheral@50000000/ppib@84000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:229 */
    ppib11: ppib@84000 {
    compatible = "nordic,nrf-ppib"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:230 */
    reg = < 0x84000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:231 */
    channels = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:233 */
    status = "okay"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:123 */
    /* node '/soc/peripheral@50000000/timer@85000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:236 */
    timer10: timer@85000 {
    compatible = "nordic,nrf-timer"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:237 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:238 */
    reg = < 0x85000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:239 */
    cc-num = < 0x8 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:240 */
    max-bit-width = < 0x20 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:241 */
    interrupts = < 0x85 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:242 */
    clocks = < &hfxo >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:243 */
    prescaler = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:244 */
    /* node '/soc/peripheral@50000000/egu@87000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:247 */
    egu10: egu@87000 {
    compatible = "nordic,nrf-egu"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:248 */
    reg = < 0x87000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:249 */
    interrupts = < 0x87 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:250 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:251 */
    /* node '/soc/peripheral@50000000/radio@8a000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:254 */
    radio: radio@8a000 {
    compatible = "nordic,nrf-radio"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:255 */
    reg = < 0x8a000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:256 */
    interrupts = < 0x8a 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:257 */
    dfe-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:259 */
    ieee802154-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:260 */
    ble-2mbps-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:261 */
    ble-coded-phy-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:262 */
    ble-cs-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:263 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:89 */
    /* node '/soc/peripheral@50000000/radio@8a000/ieee802154' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:265 */
    ieee802154: ieee802154 {
    compatible = "nordic,nrf-ieee802154"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:266 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:93 */
    /* node '/soc/peripheral@50000000/radio@8a000/bt_hci_sdc' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:270 */
    bt_hci_sdc: bt_hci_sdc {
    compatible = "nordic,bt-hci-sdc"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:271 */
    status = "okay"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:40 */
    /* node '/soc/peripheral@50000000/radio@8a000/bt_hci_controller' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:275 */
    bt_hci_controller: bt_hci_controller {
    compatible = "zephyr,bt-hci-ll-sw-split"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:276 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:277 */
    /* node '/soc/peripheral@50000000/dppic@c2000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:281 */
    dppic20: dppic@c2000 {
    compatible = "nordic,nrf-dppic"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:282 */
    reg = < 0xc2000 0x808 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:283 */
    channels = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:285 */
    groups = < 0x6 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:286 */
    status = "okay"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:103 */
    /* node '/soc/peripheral@50000000/ppib@c3000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:289 */
    ppib20: ppib@c3000 {
    compatible = "nordic,nrf-ppib"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:290 */
    reg = < 0xc3000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:291 */
    channels = < 0x8 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:293 */
    status = "okay"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:127 */
    /* node '/soc/peripheral@50000000/ppib@c4000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:296 */
    ppib21: ppib@c4000 {
    compatible = "nordic,nrf-ppib"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:297 */
    reg = < 0xc4000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:298 */
    channels = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:300 */
    status = "okay"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:131 */
    /* node '/soc/peripheral@50000000/ppib@c5000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:303 */
    ppib22: ppib@c5000 {
    compatible = "nordic,nrf-ppib"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:304 */
    reg = < 0xc5000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:305 */
    channels = < 0x4 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:307 */
    status = "okay"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:135 */
    /* node '/soc/peripheral@50000000/i2c@c6000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:310 */
    i2c20: i2c@c6000 {
    compatible = "nordic,nrf-twim"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:311 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:312 */
    #size-cells = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:313 */
    reg = < 0xc6000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:314 */
    interrupts = < 0xc6 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:315 */
    easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:316 */
    clock-tolerance-percent = < 0x6 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:317 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:318 */
    zephyr,pm-device-runtime-auto; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:319 */
    /* node '/soc/peripheral@50000000/spi@c6000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:322 */
    spi20: spi@c6000 {
    compatible = "nordic,nrf-spim"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:329 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:330 */
    #size-cells = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:331 */
    reg = < 0xc6000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:332 */
    interrupts = < 0xc6 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:333 */
    max-frequency = < 0x7a1200 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:334 */
    easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:335 */
    rx-delay-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:336 */
    rx-delay = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:337 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:338 */
    /* node '/soc/peripheral@50000000/uart@c6000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:341 */
    uart20: uart@c6000 {
    compatible = "nordic,nrf-uarte"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:342 */
    reg = < 0xc6000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:343 */
    interrupts = < 0xc6 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:344 */
    endtx-stoptx-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:346 */
    frame-timeout-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:347 */
    current-speed = < 0x1c200 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:113 */
    pinctrl-0 = < &uart20_default >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:114 */
    pinctrl-1 = < &uart20_sleep >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:115 */
    "sleep"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:116 */
    status = "okay"; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:79 */
    /* node '/soc/peripheral@50000000/i2c@c7000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:350 */
    i2c21: i2c@c7000 {
    compatible = "nordic,nrf-twim"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:351 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:352 */
    #size-cells = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:353 */
    reg = < 0xc7000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:354 */
    interrupts = < 0xc7 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:355 */
    easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:356 */
    clock-tolerance-percent = < 0x6 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:357 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:358 */
    zephyr,pm-device-runtime-auto; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:359 */
    /* node '/soc/peripheral@50000000/spi@c7000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:362 */
    spi21: spi@c7000 {
    compatible = "nordic,nrf-spim"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:369 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:370 */
    #size-cells = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:371 */
    reg = < 0xc7000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:372 */
    interrupts = < 0xc7 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:373 */
    max-frequency = < 0x7a1200 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:374 */
    easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:375 */
    rx-delay-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:376 */
    rx-delay = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:377 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:378 */
    /* node '/soc/peripheral@50000000/uart@c7000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:381 */
    uart21: uart@c7000 {
    compatible = "nordic,nrf-uarte"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:382 */
    reg = < 0xc7000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:383 */
    interrupts = < 0xc7 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:384 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:385 */
    endtx-stoptx-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:386 */
    frame-timeout-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:387 */
    /* node '/soc/peripheral@50000000/i2c@c8000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:390 */
    i2c22: i2c@c8000 {
    compatible = "nordic,nrf-twim"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:391 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:392 */
    #size-cells = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:393 */
    reg = < 0xc8000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:394 */
    interrupts = < 0xc8 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:395 */
    easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:396 */
    clock-tolerance-percent = < 0x6 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:397 */
    zephyr,pm-device-runtime-auto; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:399 */
    status = "okay"; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:26 */
    clock-frequency = < 0x186a0 >; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:27 */
    pinctrl-0 = < &i2c22_default >; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:28 */
    pinctrl-1 = < &i2c22_sleep >; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:29 */
    "sleep"; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:30 */
    /* node '/soc/peripheral@50000000/i2c@c8000/rtc@32' defined in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:32 */
    rx8111: rtc@32 {
    status = "okay"; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:33 */
    compatible = "epson,rx8111"; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:34 */
    reg = < 0x32 >; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:35 */
    /* node '/soc/peripheral@50000000/spi@c8000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:402 */
    spi22: nordic_expansion_spi: spi@c8000 {
    compatible = "nordic,nrf-spim"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:409 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:410 */
    #size-cells = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:411 */
    reg = < 0xc8000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:412 */
    interrupts = < 0xc8 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:413 */
    max-frequency = < 0x7a1200 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:414 */
    easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:415 */
    rx-delay-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:416 */
    rx-delay = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:417 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:418 */
    cs-gpios = < &gpio1 0xa 0x1 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:148 */
    pinctrl-0 = < &spi22_default >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:149 */
    pinctrl-1 = < &spi22_sleep >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:150 */
    "sleep"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:151 */
    /* node '/soc/peripheral@50000000/uart@c8000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:421 */
    uart22: uart@c8000 {
    compatible = "nordic,nrf-uarte"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:422 */
    reg = < 0xc8000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:423 */
    interrupts = < 0xc8 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:424 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:425 */
    endtx-stoptx-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:426 */
    frame-timeout-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:427 */
    /* node '/soc/peripheral@50000000/egu@c9000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:430 */
    egu20: egu@c9000 {
    compatible = "nordic,nrf-egu"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:431 */
    reg = < 0xc9000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:432 */
    interrupts = < 0xc9 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:433 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:434 */
    /* node '/soc/peripheral@50000000/timer@ca000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:437 */
    timer20: timer@ca000 {
    compatible = "nordic,nrf-timer"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:438 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:439 */
    reg = < 0xca000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:440 */
    cc-num = < 0x6 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:441 */
    max-bit-width = < 0x20 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:442 */
    interrupts = < 0xca 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:443 */
    prescaler = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:444 */
    /* node '/soc/peripheral@50000000/timer@cb000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:447 */
    timer21: timer@cb000 {
    compatible = "nordic,nrf-timer"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:448 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:449 */
    reg = < 0xcb000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:450 */
    cc-num = < 0x6 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:451 */
    max-bit-width = < 0x20 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:452 */
    interrupts = < 0xcb 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:453 */
    prescaler = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:454 */
    /* node '/soc/peripheral@50000000/timer@cc000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:457 */
    timer22: timer@cc000 {
    compatible = "nordic,nrf-timer"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:458 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:459 */
    reg = < 0xcc000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:460 */
    cc-num = < 0x6 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:461 */
    max-bit-width = < 0x20 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:462 */
    interrupts = < 0xcc 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:463 */
    prescaler = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:464 */
    /* node '/soc/peripheral@50000000/timer@cd000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:467 */
    timer23: timer@cd000 {
    compatible = "nordic,nrf-timer"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:468 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:469 */
    reg = < 0xcd000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:470 */
    cc-num = < 0x6 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:471 */
    max-bit-width = < 0x20 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:472 */
    interrupts = < 0xcd 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:473 */
    prescaler = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:474 */
    /* node '/soc/peripheral@50000000/timer@ce000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:477 */
    timer24: timer@ce000 {
    compatible = "nordic,nrf-timer"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:478 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:479 */
    reg = < 0xce000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:480 */
    cc-num = < 0x6 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:481 */
    max-bit-width = < 0x20 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:482 */
    interrupts = < 0xce 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:483 */
    prescaler = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:484 */
    /* node '/soc/peripheral@50000000/pdm@d0000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:487 */
    pdm20: pdm@d0000 {
    compatible = "nordic,nrf-pdm"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:488 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:489 */
    reg = < 0xd0000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:490 */
    interrupts = < 0xd0 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:491 */
    /* node '/soc/peripheral@50000000/pdm@d1000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:494 */
    pdm21: pdm@d1000 {
    compatible = "nordic,nrf-pdm"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:495 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:496 */
    reg = < 0xd1000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:497 */
    interrupts = < 0xd1 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:498 */
    /* node '/soc/peripheral@50000000/pwm@d2000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:501 */
    pwm20: pwm@d2000 {
    compatible = "nordic,nrf-pwm"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:502 */
    reg = < 0xd2000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:504 */
    interrupts = < 0xd2 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:505 */
    #pwm-cells = < 0x3 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:506 */
    idleout-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:507 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:127 */
    pinctrl-0 = < &pwm20_default >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:128 */
    pinctrl-1 = < &pwm20_sleep >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:129 */
    "sleep"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:130 */
    phandle = < 0x16 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:44 */
    /* node '/soc/peripheral@50000000/pwm@d3000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:510 */
    pwm21: pwm@d3000 {
    compatible = "nordic,nrf-pwm"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:511 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:512 */
    reg = < 0xd3000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:513 */
    interrupts = < 0xd3 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:514 */
    #pwm-cells = < 0x3 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:515 */
    idleout-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:516 */
    /* node '/soc/peripheral@50000000/pwm@d4000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:519 */
    pwm22: pwm@d4000 {
    compatible = "nordic,nrf-pwm"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:520 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:521 */
    reg = < 0xd4000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:522 */
    interrupts = < 0xd4 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:523 */
    #pwm-cells = < 0x3 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:524 */
    idleout-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:525 */
    /* node '/soc/peripheral@50000000/adc@d5000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:528 */
    adc: adc@d5000 {
    compatible = "nordic,nrf-saadc"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:529 */
    reg = < 0xd5000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:530 */
    interrupts = < 0xd5 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:531 */
    #io-channel-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:533 */
    zephyr,pm-device-runtime-auto; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:534 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:140 */
    /* node '/soc/peripheral@50000000/nfct@d6000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:537 */
    nfct: nfct@d6000 {
    compatible = "nordic,nrf-nfct-v2"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:538 */
    reg = < 0xd6000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:539 */
    interrupts = < 0xd6 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:540 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:65 */
    /* node '/soc/peripheral@50000000/temp@d7000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:544 */
    temp: temp@d7000 {
    compatible = "nordic,nrf-temp"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:545 */
    reg = < 0xd7000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:546 */
    interrupts = < 0xd7 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:547 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:97 */
    /* node '/soc/peripheral@50000000/gpio@d8200' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:551 */
    gpio1: gpio@d8200 {
    compatible = "nordic,nrf-gpio"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:552 */
    gpio-controller; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:553 */
    reg = < 0xd8200 0x300 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:554 */
    #gpio-cells = < 0x2 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:555 */
    ngpios = < 0x11 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:556 */
    port = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:558 */
    gpiote-instance = < &gpiote20 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:559 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:73 */
    phandle = < 0xb >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:148 */
    /* node '/soc/peripheral@50000000/gpiote@da000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:562 */
    gpiote20: gpiote@da000 {
    compatible = "nordic,nrf-gpiote"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:563 */
    reg = < 0xda000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:564 */
    instance = < 0x14 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:566 */
    interrupts = < 0xdb 0x1 >; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:82 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:81 */
    phandle = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:559 */
    /* node '/soc/peripheral@50000000/i2s@dd000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:569 */
    i2s20: i2s@dd000 {
    compatible = "nordic,nrf-i2s"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:570 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:571 */
    #size-cells = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:572 */
    reg = < 0xdd000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:573 */
    interrupts = < 0xdd 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:574 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:575 */
    /* node '/soc/peripheral@50000000/qdec@e0000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:578 */
    qdec20: qdec@e0000 {
    compatible = "nordic,nrf-qdec"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:579 */
    reg = < 0xe0000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:580 */
    interrupts = < 0xe0 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:581 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:582 */
    /* node '/soc/peripheral@50000000/qdec@e1000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:585 */
    qdec21: qdec@e1000 {
    compatible = "nordic,nrf-qdec"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:586 */
    reg = < 0xe1000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:587 */
    interrupts = < 0xe1 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:588 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:589 */
    /* node '/soc/peripheral@50000000/grtc@e2000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:592 */
    grtc: grtc@e2000 {
    compatible = "nordic,nrf-grtc"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:593 */
    reg = < 0xe2000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:594 */
    cc-num = < 0xc >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:595 */
    clocks = < &lfxo >,
    < &pclk >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:596 */
    clock-names = "lfclock",
    "hfclock"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:597 */
    extended-channels = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:599 */
    interrupts = < 0xe4 0x1 >,
    < 0xe5 0x1 >; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:73 */
    owned-channels = < 0x0 0x1 0x2 0x3 0x4 0x5 0x6 0x7 0x8 0x9 0xa 0xb >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:54 */
    child-owned-channels = < 0x3 0x4 0x7 0x8 0x9 0xa 0xb >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:56 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:57 */
    /* node '/soc/peripheral@50000000/dppic@102000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:602 */
    dppic30: dppic@102000 {
    compatible = "nordic,nrf-dppic"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:603 */
    reg = < 0x102000 0x808 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:604 */
    channels = < 0x4 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:606 */
    groups = < 0x2 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:607 */
    status = "okay"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:107 */
    /* node '/soc/peripheral@50000000/ppib@103000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:610 */
    ppib30: ppib@103000 {
    compatible = "nordic,nrf-ppib"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:611 */
    reg = < 0x103000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:612 */
    channels = < 0x4 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:614 */
    status = "okay"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:139 */
    /* node '/soc/peripheral@50000000/i2c@104000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:617 */
    i2c30: i2c@104000 {
    compatible = "nordic,nrf-twim"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:618 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:619 */
    #size-cells = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:620 */
    reg = < 0x104000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:621 */
    interrupts = < 0x104 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:622 */
    easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:623 */
    clock-tolerance-percent = < 0x6 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:624 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:625 */
    zephyr,pm-device-runtime-auto; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:626 */
    /* node '/soc/peripheral@50000000/spi@104000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:629 */
    spi30: spi@104000 {
    compatible = "nordic,nrf-spim"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:636 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:637 */
    #size-cells = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:638 */
    reg = < 0x104000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:639 */
    interrupts = < 0x104 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:640 */
    max-frequency = < 0x7a1200 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:641 */
    easydma-maxcnt-bits = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:642 */
    rx-delay-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:643 */
    rx-delay = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:644 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:645 */
    /* node '/soc/peripheral@50000000/uart@104000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:648 */
    uart30: uart@104000 {
    compatible = "nordic,nrf-uarte"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:649 */
    reg = < 0x104000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:650 */
    interrupts = < 0x104 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:651 */
    endtx-stoptx-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:653 */
    frame-timeout-supported; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:654 */
    status = "okay"; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:52 */
    current-speed = < 0x1c200 >; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:53 */
    pinctrl-0 = < &uart30_default >; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:54 */
    pinctrl-1 = < &uart30_sleep >; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:55 */
    "sleep"; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:56 */
    /* node '/soc/peripheral@50000000/clock@10e000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:657 */
    clock: clock@10e000 {
    compatible = "nordic,nrf-clock"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:658 */
    reg = < 0x10e000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:659 */
    interrupts = < 0x105 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:660 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:101 */
    /* node '/soc/peripheral@50000000/power@10e000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:664 */
    power: power@10e000 {
    compatible = "nordic,nrf-power"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:665 */
    reg = < 0x10e000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:666 */
    ranges = < 0x0 0x10e000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:667 */
    interrupts = < 0x105 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:668 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:669 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:670 */
    #size-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:671 */
    /* node '/soc/peripheral@50000000/power@10e000/gpregret1@500' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:673 */
    gpregret1: gpregret1@500 {
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:674 */
    #size-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:675 */
    compatible = "nordic,nrf-gpregret"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:676 */
    reg = < 0x500 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:677 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:105 */
    /* node '/soc/peripheral@50000000/power@10e000/gpregret1@500/boot_mode@0' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:107 */
    boot_mode0: boot_mode@0 {
    compatible = "zephyr,retention"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:108 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:109 */
    reg = < 0x0 0x1 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:110 */
    /* node '/soc/peripheral@50000000/power@10e000/gpregret2@504' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:681 */
    gpregret2: gpregret2@504 {
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:682 */
    #size-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:683 */
    compatible = "nordic,nrf-gpregret"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:684 */
    reg = < 0x504 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:685 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:686 */
    /* node '/soc/peripheral@50000000/comparator@106000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:690 */
    comp: comparator@106000 {
    compatible = "nordic,nrf-comp"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:695 */
    reg = < 0x106000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:696 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:697 */
    interrupts = < 0x106 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:698 */
    /* node '/soc/peripheral@50000000/watchdog@108000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:704 */
    wdt30: watchdog@108000 {
    compatible = "nordic,nrf-wdt"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:705 */
    reg = < 0x108000 0x620 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:706 */
    interrupts = < 0x108 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:707 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:708 */
    /* node '/soc/peripheral@50000000/watchdog@109000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:712 */
    wdt31: watchdog@109000 {
    compatible = "nordic,nrf-wdt"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:713 */
    reg = < 0x109000 0x620 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:714 */
    interrupts = < 0x109 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:715 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:716 */
    /* node '/soc/peripheral@50000000/gpio@10a000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:719 */
    gpio0: gpio@10a000 {
    compatible = "nordic,nrf-gpio"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:720 */
    gpio-controller; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:721 */
    reg = < 0x10a000 0x300 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:722 */
    #gpio-cells = < 0x2 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:723 */
    ngpios = < 0x7 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:724 */
    port = < 0x0 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:726 */
    gpiote-instance = < &gpiote30 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:727 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:69 */
    phandle = < 0x17 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:70 */
    /* node '/soc/peripheral@50000000/gpiote@10c000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:730 */
    gpiote30: gpiote@10c000 {
    compatible = "nordic,nrf-gpiote"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:731 */
    reg = < 0x10c000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:732 */
    instance = < 0x1e >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:734 */
    interrupts = < 0x10d 0x1 >; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:90 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:85 */
    phandle = < 0x15 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:727 */
    /* node '/soc/peripheral@50000000/regulator@120000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:737 */
    regulators: regulator@120000 {
    compatible = "nordic,nrf54l-regulators"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:738 */
    reg = < 0x120000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:739 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:741 */
    #size-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:742 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:45 */
    /* node '/soc/peripheral@50000000/regulator@120000/regulator@120600' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:744 */
    vregmain: regulator@120600 {
    compatible = "nordic,nrf5x-regulator"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:745 */
    reg = < 0x120600 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:746 */
    regulator-name = "VREGMAIN"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:748 */
    status = "okay"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:49 */
    regulator-initial-mode = < 0x1 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:50 */
    /* node '/soc/rram-controller@5004b000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:754 */
    rram_controller: rram-controller@5004b000 {
    compatible = "nordic,rram-controller"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:755 */
    reg = < 0x5004b000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:756 */
    ranges; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:757 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:758 */
    #size-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:759 */
    interrupts = < 0x4b 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:760 */
    /* node '/soc/rram-controller@5004b000/rram@0' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:762 */
    cpuapp_rram: rram@0 {
    compatible = "soc-nv-flash"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:763 */
    erase-block-size = < 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:764 */
    write-block-size = < 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:765 */
    status = "okay"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:766 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:767 */
    #size-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:768 */
    reg = < 0x0 0x17d000 >; /* in zephyr/dts/vendor/nordic/nrf54l15.dtsi:15 */
    ranges = < 0x0 0x0 0x17d000 >; /* in zephyr/dts/vendor/nordic/nrf54l15.dtsi:16 */
    /* node '/soc/rram-controller@5004b000/rram@0/partitions' defined in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:8 */
    partitions {
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:9 */
    #size-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:10 */
    /* node '/soc/rram-controller@5004b000/rram@0/partitions/partition@0' defined in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:12 */
    boot_partition: partition@0 {
    compatible = "zephyr,mapped-partition"; /* in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:13 */
    label = "mcuboot"; /* in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:14 */
    reg = < 0x0 0xf800 >; /* in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:18 */
    /* node '/soc/rram-controller@5004b000/rram@0/partitions/partition@10000' defined in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:40 */
    slot0_partition: partition@10000 {
    compatible = "zephyr,mapped-partition"; /* in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:41 */
    label = "image-0"; /* in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:42 */
    reg = < 0x10000 0xb2000 >; /* in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:43 */
    /* node '/soc/rram-controller@5004b000/rram@0/partitions/partition@c2000' defined in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:46 */
    slot1_partition: partition@c2000 {
    compatible = "zephyr,mapped-partition"; /* in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:47 */
    label = "image-1"; /* in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:48 */
    reg = < 0xc2000 0xb2000 >; /* in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:49 */
    /* node '/soc/rram-controller@5004b000/rram@0/partitions/partition@174000' defined in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:52 */
    storage_partition: partition@174000 {
    compatible = "zephyr,mapped-partition"; /* in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:53 */
    label = "storage"; /* in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:54 */
    reg = < 0x174000 0x9000 >; /* in zephyr/dts/vendor/nordic/nrf54l15_cpuapp_partition.dtsi:55 */
    /* node '/soc/memory@50041000' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:772 */
    nrf_mpc: memory@50041000 {
    compatible = "nordic,nrf-mpc"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:773 */
    reg = < 0x50041000 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:774 */
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:775 */
    #size-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:776 */
    override-num = < 0x5 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:777 */
    override-granularity = < 0x1000 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:778 */
    /* node '/soc/cpuapp-ppb-bus' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:781 */
    cpuapp_ppb: cpuapp-ppb-bus {
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:782 */
    #size-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:783 */
    compatible = "simple-bus"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:65 */
    ranges; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:66 */
    /* node '/soc/cpuapp-ppb-bus/interrupt-controller@e000e100' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:785 */
    cpuapp_nvic: nvic: interrupt-controller@e000e100 {
    #address-cells = < 0x1 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:786 */
    compatible = "arm,v8m-nvic"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:787 */
    reg = < 0xe000e100 0xc00 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:788 */
    arm,num-irq-priority-bits = < 0x3 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:789 */
    interrupt-controller; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:790 */
    #interrupt-cells = < 0x2 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:791 */
    phandle = < 0x2 >; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:24 */
    /* node '/soc/cpuapp-ppb-bus/timer@e000e010' defined in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:794 */
    cpuapp_systick: systick: timer@e000e010 {
    compatible = "arm,armv8m-systick"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:795 */
    reg = < 0xe000e010 0x10 >; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:796 */
    status = "disabled"; /* in zephyr/dts/vendor/nordic/nrf54l_05_10_15.dtsi:797 */
    /* node '/chosen' defined in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:17 */
    chosen {
    zephyr,bt-hci = &bt_hci_sdc; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:18 */
    zephyr,entropy = &psa_rng; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:19 */
    zephyr,console = &uart20; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:13 */
    zephyr,shell-uart = &uart20; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:14 */
    zephyr,uart-mcumgr = &uart20; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:15 */
    zephyr,bt-mon-uart = &uart20; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:16 */
    zephyr,bt-c2h-uart = &uart20; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:17 */
    zephyr,flash-controller = &rram_controller; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:18 */
    zephyr,flash = &cpuapp_rram; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:19 */
    zephyr,ieee802154 = &ieee802154; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:20 */
    zephyr,boot-mode = &boot_mode0; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:21 */
    zephyr,code-partition = &slot0_partition; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp.dts:17 */
    zephyr,sram = &cpuapp_sram; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp.dts:18 */
    zephyr,storage-area = &storage_partition; /* in ../../../../media/mantra/Data/EDRIVE/CEBUProjects/git_M0153_Door_Lock/DOORLOCK_FIRMWARE/POC/KHODIDAS/Lock_Poc/nrf54l15dk_nrf54l15_cpuapp.overlay:84 */
    /* node '/rng' defined in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:28 */
    rng: rng {
    status = "disabled"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:29 */
    compatible = "nordic,nrf-cracen-ctrdrbg"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:30 */
    /* node '/psa-rng' defined in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:33 */
    psa_rng: psa-rng {
    compatible = "zephyr,psa-crypto-rng"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:34 */
    status = "okay"; /* in zephyr/dts/arm/nordic/nrf54l_05_10_15_cpuapp.dtsi:35 */
    /* node '/leds' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:10 */
    leds {
    compatible = "gpio-leds"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:11 */
    /* node '/leds/led_0' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:13 */
    led0: led_0 {
    gpios = < &gpio2 0x9 0x0 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:14 */
    label = "Green LED 0"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:15 */
    /* node '/leds/led_1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:18 */
    led1: led_1 {
    gpios = < &gpio1 0xa 0x0 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:19 */
    label = "Green LED 1"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:20 */
    /* node '/leds/led_2' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:23 */
    led2: led_2 {
    gpios = < &gpio2 0x7 0x0 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:24 */
    label = "Green LED 2"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:25 */
    /* node '/leds/led_3' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:28 */
    led3: led_3 {
    gpios = < &gpio1 0xe 0x0 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:29 */
    label = "Green LED 3"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:30 */
    /* node '/pwmleds' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:34 */
    pwmleds {
    compatible = "pwm-leds"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:35 */
    /* node '/pwmleds/pwm_led_1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:43 */
    pwm_led1: pwm_led_1 {
    pwms = < &pwm20 0x0 0x1312d00 0x0 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:44 */
    /* node '/buttons' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:48 */
    buttons {
    compatible = "gpio-keys"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:49 */
    /* node '/buttons/button_0' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:51 */
    button0: button_0 {
    gpios = < &gpio1 0xd 0x11 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:52 */
    label = "Push button 0"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:53 */
    zephyr,code = < 0xb >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:54 */
    /* node '/buttons/button_1' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:57 */
    button1: button_1 {
    gpios = < &gpio1 0x9 0x11 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:58 */
    label = "Push button 1"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:59 */
    zephyr,code = < 0x2 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:60 */
    /* node '/buttons/button_2' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:63 */
    button2: button_2 {
    gpios = < &gpio1 0x8 0x11 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:64 */
    label = "Push button 2"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:65 */
    zephyr,code = < 0x3 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:66 */
    /* node '/buttons/button_3' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:69 */
    button3: button_3 {
    gpios = < &gpio0 0x4 0x11 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:70 */
    label = "Push button 3"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:71 */
    zephyr,code = < 0x4 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:72 */
    /* node '/aliases' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:76 */
    aliases {
    led0 = &led0; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:77 */
    led1 = &led1; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:78 */
    led2 = &led2; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:79 */
    led3 = &led3; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:80 */
    pwm-led0 = &pwm_led1; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:81 */
    sw0 = &button0; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:82 */
    sw1 = &button1; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:83 */
    sw2 = &button2; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:84 */
    sw3 = &button3; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:85 */
    watchdog0 = &wdt31; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:86 */
    mcuboot-button0 = &button0; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:25 */
    mcuboot-led0 = &led0; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l_05_10_15_cpuapp_common.dtsi:26 */
    /* node '/nordic_expansion_header' defined in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:93 */
    nordic_expansion_header: nordic_expansion_header {
    compatible = "nordic,expansion-board-header"; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:94 */
    #gpio-cells = < 0x2 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:95 */
    gpio-map-mask = < 0xffffffff 0xffffffc0 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:96 */
    gpio-map-pass-thru = < 0x0 0x3f >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:97 */
    gpio-map = < 0x4 0x0 &gpio1 0x4 0x0 >,
    < 0x5 0x0 &gpio1 0x5 0x0 >,
    < 0x6 0x0 &gpio1 0x6 0x0 >,
    < 0x7 0x0 &gpio1 0x7 0x0 >,
    < 0x8 0x0 &gpio1 0x8 0x0 >,
    < 0x9 0x0 &gpio1 0x9 0x0 >,
    < 0xa 0x0 &gpio1 0xa 0x0 >,
    < 0xb 0x0 &gpio1 0xb 0x0 >,
    < 0xc 0x0 &gpio1 0xc 0x0 >,
    < 0xd 0x0 &gpio1 0xd 0x0 >,
    < 0xe 0x0 &gpio1 0xe 0x0 >; /* in zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_common.dtsi:98 */
    Finally resolve
    #CONFIG_POWEROFF=y & #CONFIG_PM_DEVICE_RUNTIME=y in prj.conf file causing the issue. disabling it worked.
    also removed file inclusion as below.
    #include <zephyr/sys/poweroff.h>
    #include <zephyr/pm/device_runtime.h>
    #include <zephyr/pm/policy.h>
    Still it is possible to make uart suspend and resume for power consumption.
    So my issue resolved
    Thank you for Support
