Connecting LPCOMP CROSS event to TWO DPPI-driven tasks (GPIOTE toggle + TIMER count) simultaneously — only the last-configured one fires
Subject: Connecting LPCOMP CROSS event to TWO DPPI-driven tasks (GPIOTE toggle + TIMER count) simultaneously — only the last-configured one fires
Chip: nRF54L15
SDK: nRF Connect SDK v2.9.0 (Zephyr 3.7.99)
Board: nrf54l15dk/nrf54l15/cpuapp
I'm trying to connect the LPCOMP CROSS event, via DPPI, to TWO different tasks at the same time:
1) A GPIOTE OUT task (to toggle a pin — closed-loop drive)
2) A TIMER COUNT task (to count the crossings — frequency measurement)
Goal: whenever LPCOMP's CROSS event fires, it should BOTH toggle a GPIO pin AND increment a TIMER — simultaneously, from the same single event.
I tried two approaches and both gave the same result: only the LAST configured task actually fires; the other one is silently never triggered.
Approach A — two separate DPPI channels, both publishing from the same event:
uint32_t evt_cross = nrf_lpcomp_event_address_get(NRF_LPCOMP, NRF_LPCOMP_EVENT_CROSS);
uint32_t task_tgl = nrfx_gpiote_out_task_address_get(&gpiote, DRIVE_PIN);
uint32_t task_cnt = nrfx_timer_task_address_get(&sense_tmr, NRF_TIMER_TASK_COUNT);
nrfx_gppi_channel_alloc(&dppi_drive);
nrfx_gppi_channel_endpoints_setup(dppi_drive, evt_cross, task_tgl); // configured 1st
nrfx_gppi_channel_alloc(&dppi_count);
nrfx_gppi_channel_endpoints_setup(dppi_count, evt_cross, task_cnt); // configured 2nd
// in engine_wake():
nrfx_gppi_channels_enable(BIT(dppi_drive) | BIT(dppi_count));
Result: only dppi_count (configured 2nd) actually works. If I reverse the order (configure count first, then drive second), only drive works instead — the last one configured always "wins". It looks like evt_cross's PUBLISH register only holds a single channel, and the second call to channel_endpoints_setup silently overwrites the first.
Approach B — a single DPPI channel, with two tasks subscribed to it:
nrfx_gppi_channel_alloc(&dppi_cross);
nrfx_gppi_event_endpoint_setup(dppi_cross, evt_cross); // publish: once
nrfx_gppi_task_endpoint_setup(dppi_cross, task_tgl); // subscribe #1
nrfx_gppi_task_endpoint_setup(dppi_cross, task_cnt); // subscribe #2
nrfx_gppi_channels_enable(BIT(dppi_cross));
Result: with this approach, NEITHER task seems to fire at all (the TIMER count consistently reads back 0, even when I isolate-test LPCOMP by shorting its input to a pin I toggle in software with a known square wave).
My questions:
1. On nRF54L15, does an event's PUBLISH register really only support a single DPPI channel (i.e., can one event only ever publish to one channel at a time)?
2. Should Approach B (one channel, two tasks subscribed) be supported in hardware? If so, is there a step I might be missing in my code (e.g. correct ordering of ENABLE/SUBSCRIBE register writes, or a domain/instance mismatch)?
3. Could there be a DPPI domain mismatch between LPCOMP (which, per the datasheet block diagram, appears to sit alongside DPPIC30 in that domain) and GPIOTE20/TIMER20/TIMER21 (a different instance/domain number)? In other words, is it possible LPCOMP's event simply cannot reach the DPPI bus that GPIOTE20/TIMER20 are on, and a PPIB (domain-to-domain bridge) is required?
4. If "one event fanning out to multiple tasks" is genuinely not supported on this chip/peripheral combination, what is the recommended approach? (For example: drive one task via DPPI and handle the other via a CPU interrupt instead?)
My end goal: use the LPCOMP CROSS event to both drive a GPIO pin (for closed-loop excitation) and count the same crossings with a TIMER — ideally both handled fully in hardware via DPPI, without CPU involvement.
Thank you in advance for any guidance.
    Question 1: Can one event publish to multiple DPPI channels?
    No. The datasheet explicitly states "One publish register per event," and the PUBLISH register has a single CHIDX field. This means Approach A cannot work by design, writing to the same event's publish register a second time overwrites the first channel assignment, which is what you observed.
    Question 2: Why Didn't Approach B Work?
    Approach B should work in theory (one channel with multiple task subscriptions), but it failed likely because:
    Domain mismatch not handled - LPCOMP publishes on DPPIC30; GPIOTE/TIMER subscribe on DPPIC20
    Missing PPIB configuration - No bridge was set up between the domains
    Errata [26] workaround not applied - For nRF54L15 Rev 1 and 2, the PPIB channel number must match the DPPIC channel index (e.g., use PPIB channel 0 with DPPIC channel 0) https://docs.nordicsemi.com/r/bundle/errata_nrf54l15_rev2/page/err/nrf54l15/rev2/latest/anomaly_l15_26.html
    Question 3: Is there a DPPI domain mismatch?
    Likely wes. Looking at the instantiation table:
    Peripheral        Domain        DPPIC
    LPCOMP        LP        DPPIC30 (4 channels)
    GPIOTE20        PERI        DPPIC20 (16 channels)
    TIMER20/21        PERI        DPPIC20 (16 channels)
    LPCOMP is in the LP power domain with DPPIC30, while GPIOTE20 and TIMER20/21 are in the PERI power domain with DPPIC20. These domains cannot communicate directly via DPPI.
    Use PPIB (PPI Bridge) to Cross Domains. To connect LPCOMP -> GPIOTE20/TIMER20, you must bridge the LP domain to the PERI domain using PPIB30 -> PPIB22 (per the Figure 23: Power domains and PPI bridges in datasheet).
    Hope that helps,
    Kenneth
