How to use the connectivity board as a BT device in Linux host system?
Hi Nordic support, I check the serialization page (infocenter.nordicsemi.com/.../lib_serialization.html) And prepare a connectivity board as below for my host system. Detail as below:
Board: PCA10028
SD: S130V2
FW: SDK11-ble_connectivity (prjs location: nRF5_SDK_11.0.0_89a8197\examples\ble_central_and_peripheral\ble_connectivity\pca10028\ser_s130_hci\arm5_no_packs )
And then I used a USB to UART cable just connect the Rx/Tx and GND as the serialization page mentioned, aka the application side is connect to a UART cable to PC. (infocenter.nordicsemi.com/.../nrf51_setups_serialization.html)
Back to my linux host system, I try to use the bluez utilities to control the connectivity board, but it fail. The command is like below:
$ sudo hciattach -r /dev/ttyUSB0 any 115200 noflow
Device setup complete
$ hciconfig
hci0:	Type: BR/EDR  Bus: UART
	BD Address: 00:00:00:00:00:00  ACL MTU: 0:0  SCO MTU: 0:0
	DOWN
	RX bytes:0 acl:0 sco:0 events:0 errors:0
	TX bytes:0 acl:0 sco:0 commands:0 errors:0
$ sudo hciconfig hci0 up
Can't init device hci0: Cannot assign requested address (99)
Here is our issue:
  1. Our target is to take your solution to play as a BT PHY in our system, and the Linux BT stacks will use it as a BT host to scan/connect/pair with other BT devices.
  2. Is the HCI_uart project really support the standard HCI command?
  3. How to make this experiment work?
Thanks.
1 2
