Inquiries on the Axon hardware
We've been investigating the use of the nrF54LM20B with the integrated Axon NPU.
In order to gauge the Axon's effectiveness, we've constructed a benchmark that profiles the Axon's inference times on 64 differently sized basic CNN models from ~4KB to ~1.2MB (INT8 quantized).
Hence, it is surprising that the results from our benchmark show that the Axon's performance scales practically linearly with model size.
We have not tested Axon models larger than ~1.2MB yet, but we expected to hit a memory wall far before that point.
Since we've been hitting the Axon with models where the largest layer is >1MB, it seems that either this tightly coupled memory is very generously sized, or our understanding of how the Axon operates is faulty in some way.
Our understanding of the Axon's internals are as follows, guided in part by the Axon NPU's block diagram shown above:
- CPU writes input values to interlay buffer
- Axon reads first layer weights from RRAM, input values from interlayer buffer into interconnected memory
- resulting activation values (i.e. intermediate output values) are stored in Axon's tightly coupled memory or written to interlayer buffer if necessary
- on to next layer...
- repeat until final output is written to interlayer buffer
From this understanding, it would follow that once an entire layer + previous activation values fail to fit in the Axon's tightly coupled memory that performance would crash as the Axon would be constantly swapping layer weights in and out.
Knowing roughly how Axon infers on an architectural level would be highly useful in letting us build ML models that are optimal for this NPU.
Thank you for any help you may be able to provide in clearing this up.
    Let me look into this and get back to you.
    Swathy
    Sorry for the delay.
    The Axon NPU TCM is very small relative to the model size, it is essentially a cache. Axon NPU is continuously reading from/writing to system memory, to/from TCM. So rather than reading in an entire layer, Axon NPU loads a small portion, consumes it in its entirety, then reads in the next portion. This is all pipe-lined so there are minimal stalls for waiting for data. The layer input/output activations are always read from/written to the interlayer buffer. In some cases there are intermediate results within a layer that need to be stored to it as well. With convolutions this is not the case though.
    So you are mostly correct, it's just that the job is performed in parallel with reading in the input and weights and quantization parameters into its cache and performing compute on the cached values.
    Best Regards,
    Swathy
    Thank you for the clear and detailed response. That the Axon NPU is pipelined in the way you describe makes a lot of sense in retrospect, and certainly clears up our benchmarking efforts.
