Hi Nordic Support Team,
We are working on an nRF5340-based application using the nRF Connect SDK and would like to implement FOTA for both the application core and the network core (HCI firmware).
Current Setup
Device: nRF5340
SDK: nRF Connect SDK
Bootloader: MCUboot (Sysbuild)
BLE HCI running on the network core
FOTA images are downloaded from our cloud server (AWS S3)
From the documentation, we understand that the recommended approach for wireless FOTA is Simultaneous Multi-Image DFU, where both the application core and network core are updated during the same reboot.
We also understand that:
The application core cannot directly write to network core flash.
MCUboot transfers the network core image through the PCD library using shared SRAM.
The network core bootloader (B0n) copies the image from RAM into network core flash and performs verification.
Planned Configuration
We intend to enable the following Sysbuild options:
SB_CONFIG_SECURE_BOOT_NETCORE=y
SB_CONFIG_NETCORE_APP_UPDATE=y
SB_CONFIG_MCUBOOT_NRF53_MULTI_IMAGE_UPDATE=y
For MCUboot, we understand the following options are required:
CONFIG_PCD_APP=y
CONFIG_FLASH_SIMULATOR=y
CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES=y
CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y
CONFIG_BOOT_IMAGE_ACCESS_HOOK_NRF5340=y
CONFIG_UPDATEABLE_IMAGE_NUMBER=2
We also understand that the partition layout should include:
mcuboot_primary
mcuboot_secondary
mcuboot_primary_1 (RAM / ram_flash)
mcuboot_secondary_1
pcd_sram
Questions
Is the above configuration sufficient to support simultaneous FOTA for both the application core and the network core?
Is there any additional configuration required in Sysbuild, MCUboot, Partition Manager, or the application that is not explicitly mentioned in the documentation?
Since our network core only runs the standard Bluetooth HCI firmware supplied with the SDK (no custom application), is simultaneous multi-image DFU still the recommended approach?
Are there any reference samples or production-ready examples demonstrating simultaneous application core + network core FOTA using MCUboot?
We are currently using image compression:
SB_CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT=y
The documentation mentions that compressed images currently support only single-image DFU. Does this mean that network core FOTA is completely unsupported when compression is enabled, and therefore image compression must be disabled to perform simultaneous multi-image updates?
Once configured correctly, will the generated
dfu_application.zipautomatically include both the application core image and the network core image, allowing a single FOTA package to update both cores in one reboot?
Any guidance or recommended configuration would be greatly appreciated.
Thank you.
This version is concise, technically accurate, and structured in the format Nordic DevZone engineers typically respond to quickly.
