[nRF52DK] Unable to Recover due to Error -21
Hello everyone!
We were working with our nRF52DK boards and one of our students had issues flashing a board. He used a recent version of Segger J-Link Commander (V9.30 as far as I remember).
It is not possible to recover the device anymore. We got it working once by replacing the J-Link firmware with an older V8.10f version, but as soon as the board is power cycled, it does not recover successfully anymore.
We flahsed a RIOT OS application on it and during the flashing process, the UICR register is set to enable the Pinreset for Pin 15 with this J-Link command after flashing the memory:
`Write4 0x10001200 00000015 00000015`
Holding the reset button while connecting the nRF52DK to the computer does not have any effect, but we disabled the J-Link Mass Storage Device as it does not work anyway.
Solder Bridge SB9 is not cut.
The programs are running on WSL, but running the same programs in a native Linux environment yields the same errors.
The board is a PCA10040 3.0.0 from 2023.9 Serial 1050351525.
Logs from `nrfjprog`:
cbuec@W11nMate:~$ nrfjprog --version
nrfjprog version: 10.24.2 external
JLinkARM.dll version: 8.10f
cbuec@W11nMate:~$ nrfjprog --recover --log
Recovering device. This operation might take 30s.
[error] [ Client] - Encountered error -21: Command recover executed for 30373 milliseconds with result -21
[error] [ Worker] - Encountered error while performing post-recover cleanup. -90: Access protection is enabled, can't read device version.
ERROR: Recover failed. Please make sure that the correct device family is given
ERROR: and try again.
[2026-Jul-06 14:30:50] [debug] --------------------------------------------------------------------------------
[2026-Jul-06 14:30:50] [debug] nrfjprog --recover --log
[2026-Jul-06 14:30:50] [debug] nrfjprog version 10.24.2 external
[2026-Jul-06 14:30:50] [ info] Load library at /opt/nrf-command-line-tools/lib/libnrfjprogdll.so.
[2026-Jul-06 14:30:50] [ info] Library loaded, loading member functions.
[2026-Jul-06 14:30:50] [ info] Member functions succesfully loaded.
[2026-Jul-06 14:30:50] [debug] [ Client] - open
[2026-Jul-06 14:30:50] [debug] [ Client] - start
[2026-Jul-06 14:30:50] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 47c34c86-0a5e-42e4-997e-165821d33969.
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2026-Jul-06 14:30:50] [debug] [  JLink] - Logger sink registered in JLink logger
[2026-Jul-06 14:30:50] [debug] [  nRFXX] - open
[2026-Jul-06 14:30:50] [debug] [  nRFXX] - just_check_family
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - open_dll
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2026-Jul-06 14:30:50] [ info] [SeggerBackend] - Load library at /opt/SEGGER/JLink/libjlinkarm.so.8.
[2026-Jul-06 14:30:50] [trace] [ Client] - Command open executed for 12 milliseconds with result 0
[2026-Jul-06 14:30:50] [debug] [ Client] - config
[2026-Jul-06 14:30:50] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2026-Jul-06 14:30:50] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - Set batch mode
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - dll_version
[2026-Jul-06 14:30:50] [ info] [SeggerBackend] - Segger dll version 8.10.f loaded.
[2026-Jul-06 14:30:50] [trace] [ Worker] - Command open executed for 10 milliseconds with result 0
[2026-Jul-06 14:30:50] [debug] [  nRFXX] - config
[2026-Jul-06 14:30:50] [trace] [ Client] - Command config executed for 2 milliseconds with result 0
[2026-Jul-06 14:30:50] [debug] [ Client] - enum_emu_snr
[2026-Jul-06 14:30:50] [trace] [ Client] - Command enum_emu_con_info executed for 5 milliseconds with result 0
[2026-Jul-06 14:30:50] [debug] [ Client] - connect_to_emu_with_snr
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - enum_emu_snr
[2026-Jul-06 14:30:50] [trace] [ Worker] - Command config executed for 2 milliseconds with result 0
[2026-Jul-06 14:30:50] [debug] [  nRFXX] - enum_emu_con_info
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - is_connected_to_emu
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - enum_emu_con_info
[2026-Jul-06 14:30:50] [trace] [ Worker] - Command enum_emu_con_info executed for 5 milliseconds with result 0
[2026-Jul-06 14:30:50] [debug] [  nRFXX] - connect_to_emu_with_snr
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - ---just_get_num_emus
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - Segger logging enabled.
[2026-Jul-06 14:30:50] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Oct  9 2024 11:01:34
[2026-Jul-06 14:30:50] [trace] [  JLink] - Hardware: V1.00
[2026-Jul-06 14:30:50] [trace] [  JLink] - S/N: 1050351525
[2026-Jul-06 14:30:50] [trace] [  JLink] - OEM: SEGGER
[2026-Jul-06 14:30:50] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
[2026-Jul-06 14:30:50] [trace] [  JLink] - Bootloader: 2021 May 18
[2026-Jul-06 14:30:50] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
[2026-Jul-06 14:30:50] [trace] [  JLink] - TELNET listener socket opened on port 19021
[2026-Jul-06 14:30:50] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2026-Jul-06 14:30:50] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
[2026-Jul-06 14:30:50] [trace] [  JLink] - Looking for J-Link GUI Server exe at: /opt/SEGGER/JLink/JLinkGUIServerExe
[2026-Jul-06 14:30:50] [trace] [  JLink] - Forking J-Link GUI Server: /opt/SEGGER/JLink/JLinkGUIServerExe
[2026-Jul-06 14:30:50] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V8.10f "
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 89.358ms returns "O.K."
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_Lock()
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 0.001ms returns 0x01
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 0.001ms returns 0x00
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 0.004ms returns 0
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 3.861ms returns 0x00
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_GetSpeedInfo()
[2026-Jul-06 14:30:50] [trace] [  JLink] - 128000000 Hz / n, n >= 64
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 0.005ms
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_SetSpeed(2000)
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 0.712ms
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_GetSpeed()
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 0.003ms returns 2000
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - SWD clock set to 2000kHz
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_GetSN()
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 0.002ms returns 1050351525
[2026-Jul-06 14:30:50] [debug] [  nRFXX] - read_device_family
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_IsOpen()
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 0.004ms returns 0x01
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - read_debug_port_idr
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - read_debug_port_register
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - coresight_configure
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_GetHWStatus(...)
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 1.944ms returns 0
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
[2026-Jul-06 14:30:50] [trace] [ Client] - Command connect_to_emu_with_snr executed for 140 milliseconds with result 0
[2026-Jul-06 14:30:50] [debug] [ Client] - read_connected_emu_snr
[2026-Jul-06 14:30:50] [trace] [ Client] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2026-Jul-06 14:30:50] [debug] [ Client] - read_device_family
[2026-Jul-06 14:30:50] [trace] [ Client] - Command read_device_family executed for 0 milliseconds with result 0
[2026-Jul-06 14:30:50] [debug] [ Client] - select_family
[2026-Jul-06 14:30:50] [trace] [ Client] - Command select_family executed for 0 milliseconds with result 0
[2026-Jul-06 14:30:50] [debug] [ Client] - recover
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 1.123ms returns 0
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 0.805ms returns 0
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x00)
[2026-Jul-06 14:30:50] [trace] [  JLink] - Value=0x2BA01477
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 0.841ms returns 0
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 1.013ms returns 0
[2026-Jul-06 14:30:50] [ info] [  nRFXX] - Discovered device from family NRF52.
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 0.047ms
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - set_core_data
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - Set core data:
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] -   Device ID: nRF52
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] -   Expected core: 234881279
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] -   Existing Expected core: 4294967295
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] -   Coprocessor: APPLICATION
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] -   AHB AP index: 0
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] -   Core base address: 4294967295
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - ---set_coresight_ahb_ap_index
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_ExecCommand("CORESIGHT_SetIndexAHBAPToUse = 0", ...).
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 0.002ms returns 0x00
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_ExecCommand("device = nRF52", ...).
[2026-Jul-06 14:30:50] [trace] [  JLink] - Device "NRF52" selected.
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 1.113ms returns 0x00
[2026-Jul-06 14:30:50] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 140 milliseconds with result 0
[2026-Jul-06 14:30:50] [debug] [  nRF52] - read_connected_emu_snr
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 0.008ms returns 0x01
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - read_connected_emu_snr
[2026-Jul-06 14:30:50] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2026-Jul-06 14:30:50] [debug] [  nRF52] - read_device_family
[2026-Jul-06 14:30:50] [trace] [ Worker] - Command read_device_family executed for 0 milliseconds with result 0
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] -   Existing Expected core: 234881279
[2026-Jul-06 14:30:50] [trace] [ Worker] - Command select_family executed for 0 milliseconds with result 0
[2026-Jul-06 14:30:50] [debug] [  nRF52] - recover
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 0.007ms returns 0x01
[2026-Jul-06 14:30:50] [debug] [  nRF52] - Just_recover
[2026-Jul-06 14:30:50] [debug] [  nRF52] - Just_is_ctrl_ap_available
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 2.317ms returns 0
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
[2026-Jul-06 14:30:50] [trace] [  JLink] - Value=0xF0000040
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 1.557ms returns 0
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 1.029ms returns 0
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
[2026-Jul-06 14:30:50] [trace] [  JLink] - Value=0x02880000
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 0.889ms returns 0
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 1.195ms returns 0
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 1.170ms returns 0
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 1.046ms returns 0
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - write_access_port_register
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - ---just_write_access_port_register
[2026-Jul-06 14:30:50] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 0.883ms returns 0
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000001)
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 1.154ms returns 0
[2026-Jul-06 14:30:50] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:30:50] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:30:50] [trace] [  JLink] - - 1.651ms returns 0
[2026-Jul-06 14:30:51] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:30:51] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:30:51] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:30:51] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:30:51] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:30:51] [trace] [  JLink] - - 1.891ms returns 0
[2026-Jul-06 14:30:51] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:30:51] [trace] [  JLink] - - 1.642ms returns 0
[2026-Jul-06 14:30:52] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:30:52] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:30:52] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:30:52] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:30:52] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:30:52] [trace] [  JLink] - - 0.987ms returns 0
[2026-Jul-06 14:30:52] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:30:52] [trace] [  JLink] - - 0.924ms returns 0
[2026-Jul-06 14:30:53] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:30:53] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:30:53] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:30:53] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:30:53] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:30:53] [trace] [  JLink] - - 1.045ms returns 0
[2026-Jul-06 14:30:53] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:30:53] [trace] [  JLink] - - 3.833ms returns 0
[2026-Jul-06 14:30:54] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:30:54] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:30:54] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:30:54] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:30:54] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:30:54] [trace] [  JLink] - - 2.180ms returns 0
[2026-Jul-06 14:30:54] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:30:54] [trace] [  JLink] - - 1.228ms returns 0
[2026-Jul-06 14:30:55] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:30:55] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:30:55] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:30:55] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:30:55] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:30:55] [trace] [  JLink] - - 1.723ms returns 0
[2026-Jul-06 14:30:55] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:30:55] [trace] [  JLink] - - 2.278ms returns 0
[2026-Jul-06 14:30:56] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:30:56] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:30:56] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:30:56] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:30:56] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:30:56] [trace] [  JLink] - - 2.812ms returns 0
[2026-Jul-06 14:30:56] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:30:56] [trace] [  JLink] - - 1.902ms returns 0
[2026-Jul-06 14:30:57] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:30:57] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:30:57] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:30:57] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:30:57] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:30:57] [trace] [  JLink] - - 2.234ms returns 0
[2026-Jul-06 14:30:57] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:30:57] [trace] [  JLink] - - 3.008ms returns 0
[2026-Jul-06 14:30:58] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:30:58] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:30:58] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:30:58] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:30:58] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:30:58] [trace] [  JLink] - - 3.303ms returns 0
[2026-Jul-06 14:30:58] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:30:58] [trace] [  JLink] - - 3.067ms returns 0
[2026-Jul-06 14:30:59] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:30:59] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:30:59] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:30:59] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:30:59] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:30:59] [trace] [  JLink] - - 1.743ms returns 0
[2026-Jul-06 14:30:59] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:30:59] [trace] [  JLink] - - 2.041ms returns 0
[2026-Jul-06 14:31:00] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:00] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:00] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:00] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:00] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 2.760ms returns 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:00] [debug] [  nRF52] - Just_debug_reset
[2026-Jul-06 14:31:00] [debug] [  nRF52] - Just_is_ctrl_ap_available
[2026-Jul-06 14:31:00] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
[2026-Jul-06 14:31:00] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 1.639ms returns 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
[2026-Jul-06 14:31:00] [trace] [  JLink] - Value=0x02880000
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 2.658ms returns 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 1.872ms returns 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 1.699ms returns 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 1.998ms returns 0
[2026-Jul-06 14:31:00] [debug] [SeggerBackend] - write_access_port_register
[2026-Jul-06 14:31:00] [debug] [SeggerBackend] - ---just_write_access_port_register
[2026-Jul-06 14:31:00] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 2.510ms returns 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000001)
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 3.051ms returns 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000000)
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 1.862ms returns 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000000)
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 1.762ms returns 0
[2026-Jul-06 14:31:00] [debug] [  nRF52] - Just_readback_status
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 1.986ms returns 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 1.977ms returns 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 1.331ms returns 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 1.703ms returns 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 1.334ms returns 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 1.682ms returns 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - Value=0x00000000
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 1.633ms returns 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 1.393ms returns 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 1.354ms returns 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 1.279ms returns 0
[2026-Jul-06 14:31:00] [ info] [  nRF52] - Protection status read as APPROTECT -> ALL
[2026-Jul-06 14:31:00] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000001)
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 1.324ms returns 0
[2026-Jul-06 14:31:00] [trace] [  JLink] - - 2.225ms returns 0
[2026-Jul-06 14:31:01] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:01] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:01] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:01] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:01] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:01] [trace] [  JLink] - - 2.533ms returns 0
[2026-Jul-06 14:31:01] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:01] [trace] [  JLink] - - 1.858ms returns 0
[2026-Jul-06 14:31:02] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:02] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:02] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:02] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:02] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:02] [trace] [  JLink] - - 2.004ms returns 0
[2026-Jul-06 14:31:02] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:02] [trace] [  JLink] - - 3.012ms returns 0
[2026-Jul-06 14:31:03] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:03] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:03] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:03] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:03] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:03] [trace] [  JLink] - - 1.961ms returns 0
[2026-Jul-06 14:31:03] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:03] [trace] [  JLink] - - 2.218ms returns 0
[2026-Jul-06 14:31:04] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:04] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:04] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:04] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:04] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:04] [trace] [  JLink] - - 1.723ms returns 0
[2026-Jul-06 14:31:04] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:04] [trace] [  JLink] - - 4.416ms returns 0
[2026-Jul-06 14:31:05] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:05] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:05] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:05] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:05] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:05] [trace] [  JLink] - - 3.025ms returns 0
[2026-Jul-06 14:31:05] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:05] [trace] [  JLink] - - 7.445ms returns 0
[2026-Jul-06 14:31:06] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:06] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:06] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:06] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:06] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:06] [trace] [  JLink] - - 3.238ms returns 0
[2026-Jul-06 14:31:06] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:06] [trace] [  JLink] - - 2.266ms returns 0
[2026-Jul-06 14:31:07] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:07] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:07] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:07] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:07] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:07] [trace] [  JLink] - - 2.139ms returns 0
[2026-Jul-06 14:31:07] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:07] [trace] [  JLink] - - 3.771ms returns 0
[2026-Jul-06 14:31:08] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:08] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:08] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:08] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:08] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:08] [trace] [  JLink] - - 1.023ms returns 0
[2026-Jul-06 14:31:08] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:08] [trace] [  JLink] - - 3.457ms returns 0
[2026-Jul-06 14:31:09] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:09] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:09] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:09] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:09] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:09] [trace] [  JLink] - - 2.914ms returns 0
[2026-Jul-06 14:31:09] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:10] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:10] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:10] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:10] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:10] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 1.730ms returns 0
[2026-Jul-06 14:31:10] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 1.392ms returns 0
[2026-Jul-06 14:31:10] [debug] [  nRF52] - Just_debug_reset
[2026-Jul-06 14:31:10] [debug] [  nRF52] - Just_is_ctrl_ap_available
[2026-Jul-06 14:31:10] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
[2026-Jul-06 14:31:10] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 1.267ms returns 0
[2026-Jul-06 14:31:10] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
[2026-Jul-06 14:31:10] [trace] [  JLink] - Value=0x02880000
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 1.017ms returns 0
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 3.592ms returns 0
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 1.451ms returns 0
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 1.463ms returns 0
[2026-Jul-06 14:31:10] [debug] [SeggerBackend] - write_access_port_register
[2026-Jul-06 14:31:10] [debug] [SeggerBackend] - ---just_write_access_port_register
[2026-Jul-06 14:31:10] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
[2026-Jul-06 14:31:10] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 1.488ms returns 0
[2026-Jul-06 14:31:10] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000001)
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 2.279ms returns 0
[2026-Jul-06 14:31:10] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000000)
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 2.600ms returns 0
[2026-Jul-06 14:31:10] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000000)
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 2.276ms returns 0
[2026-Jul-06 14:31:10] [debug] [  nRF52] - Just_readback_status
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 3.266ms returns 0
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 2.917ms returns 0
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 1.722ms returns 0
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 1.770ms returns 0
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 2.324ms returns 0
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 2.105ms returns 0
[2026-Jul-06 14:31:10] [trace] [  JLink] - Value=0x00000000
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 1.741ms returns 0
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 1.665ms returns 0
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 1.716ms returns 0
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 1.853ms returns 0
[2026-Jul-06 14:31:10] [ info] [  nRF52] - Protection status read as APPROTECT -> ALL
[2026-Jul-06 14:31:10] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000001)
[2026-Jul-06 14:31:10] [trace] [  JLink] - - 2.920ms returns 0
[2026-Jul-06 14:31:11] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:11] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:11] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:11] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:11] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:11] [trace] [  JLink] - - 4.431ms returns 0
[2026-Jul-06 14:31:11] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:11] [trace] [  JLink] - - 3.917ms returns 0
[2026-Jul-06 14:31:12] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:12] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:12] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:12] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:12] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:12] [trace] [  JLink] - - 1.448ms returns 0
[2026-Jul-06 14:31:12] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:12] [trace] [  JLink] - - 2.739ms returns 0
[2026-Jul-06 14:31:13] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:13] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:13] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:13] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:13] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:13] [trace] [  JLink] - - 1.054ms returns 0
[2026-Jul-06 14:31:13] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:13] [trace] [  JLink] - - 2.035ms returns 0
[2026-Jul-06 14:31:14] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:14] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:14] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:14] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:14] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:14] [trace] [  JLink] - - 1.176ms returns 0
[2026-Jul-06 14:31:14] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:14] [trace] [  JLink] - - 3.192ms returns 0
[2026-Jul-06 14:31:15] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:15] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:15] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:15] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:15] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:15] [trace] [  JLink] - - 1.311ms returns 0
[2026-Jul-06 14:31:15] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:15] [trace] [  JLink] - - 1.918ms returns 0
[2026-Jul-06 14:31:16] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:16] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:16] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:16] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:16] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:16] [trace] [  JLink] - - 1.101ms returns 0
[2026-Jul-06 14:31:16] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:16] [trace] [  JLink] - - 2.421ms returns 0
[2026-Jul-06 14:31:17] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:17] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:17] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:17] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:17] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:17] [trace] [  JLink] - - 1.337ms returns 0
[2026-Jul-06 14:31:17] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:17] [trace] [  JLink] - - 2.251ms returns 0
[2026-Jul-06 14:31:18] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:18] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:18] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:18] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:18] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:18] [trace] [  JLink] - - 1.054ms returns 0
[2026-Jul-06 14:31:18] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:18] [trace] [  JLink] - - 1.111ms returns 0
[2026-Jul-06 14:31:19] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:19] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:19] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:19] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:19] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:19] [trace] [  JLink] - - 1.092ms returns 0
[2026-Jul-06 14:31:19] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:19] [trace] [  JLink] - - 2.946ms returns 0
[2026-Jul-06 14:31:20] [debug] [SeggerBackend] - read_access_port_register
[2026-Jul-06 14:31:20] [debug] [SeggerBackend] - ---just_read_access_port_register
[2026-Jul-06 14:31:20] [debug] [SeggerBackend] - ---just_select_access_port_register
[2026-Jul-06 14:31:20] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
[2026-Jul-06 14:31:20] [trace] [  JLink] - Value=0x00000001
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 2.646ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - JLINK_HasError()
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 3.121ms returns 0
[2026-Jul-06 14:31:20] [debug] [  nRF52] - Just_debug_reset
[2026-Jul-06 14:31:20] [debug] [  nRF52] - Just_is_ctrl_ap_available
[2026-Jul-06 14:31:20] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
[2026-Jul-06 14:31:20] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 2.878ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
[2026-Jul-06 14:31:20] [trace] [  JLink] - Value=0x02880000
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 3.684ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 2.634ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 1.723ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 2.907ms returns 0
[2026-Jul-06 14:31:20] [debug] [SeggerBackend] - write_access_port_register
[2026-Jul-06 14:31:20] [debug] [SeggerBackend] - ---just_write_access_port_register
[2026-Jul-06 14:31:20] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 1.595ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000001)
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 1.215ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000000)
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 4.244ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000000)
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 1.639ms returns 0
[2026-Jul-06 14:31:20] [debug] [  nRF52] - Just_readback_status
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 4.410ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 2.475ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 2.279ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 3.366ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 1.830ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 1.933ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - Value=0x00000000
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 2.813ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 1.772ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 1.929ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 1.406ms returns 0
[2026-Jul-06 14:31:20] [ info] [  nRF52] - Protection status read as APPROTECT -> ALL
[2026-Jul-06 14:31:20] [debug] [  nRF52] - Just_read_device_version
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 2.147ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 1.798ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 1.410ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 1.939ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 1.878ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 1.739ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 1.294ms returns 0
[2026-Jul-06 14:31:20] [error] [ Client] - Encountered error -21: Command recover executed for 30373 milliseconds with result -21
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 1.370ms returns 0
[2026-Jul-06 14:31:20] [trace] [  JLink] - - 1.280ms returns 0
Logs from `JLinkExe` version 8.10f:
SEGGER J-Link Commander V8.10f (Compiled Nov  6 2024 16:11:03)
DLL version V8.10f, compiled Nov  6 2024 16:09:58
Connecting to J-Link via USB...O.K.
Hardware version: V1.00
J-Link uptime (since boot): 0d 00h 15m 28s
S/N: 1050351525
License(s): RDI, FlashBP, FlashDL, JFlash, GDB
VTref=3.300V
Type "connect" to establish a target connection, '?' for help
J-Link>connect
Please specify device / core. <Default>: NRF52
Type '?' for selection dialog
Device>nRF52832_XXAA
Please specify target interface:
  J) JTAG (Default)
  S) SWD
  T) cJTAG
TIF>S
Specify target interface speed [kHz]. <Default>: 4000 kHz
Speed>1000
Device "NRF52832_XXAA" selected.
Connecting to target via SWD
InitTarget() start
CTRL-AP indicates that the device is secured.
For debugger connection the device needs to be unsecured.
Note: Unsecuring will trigger a mass erase of the internal flash.
Executing default behavior previously saved in the registry.
Device will be unsecured now.
InitTarget() end - Took 4.13s
Connect failed. Resetting via Reset pin and trying again.
InitTarget() start
InitTarget() end - Took 4.12s
Error occurred: Could not connect to the target device.
For troubleshooting steps visit: https://wiki.segger.com/J-Link_Troubleshooting
J-Link>
Logs from JLinkExe version 9.56:
SEGGER J-Link Commander V9.56 (Compiled Jul  1 2026 16:55:06)
DLL version V9.56, compiled Jul  1 2026 16:54:21
Connecting to J-Link ...Updating firmware:  J-Link OB-nRF5340-NordicSemi compiled Jun 11 2026 13:12:28
Replacing firmware: J-Link OB-nRF5340-NordicSemi compiled Oct  9 2024 11:01:34
Waiting for new firmware to boot
New firmware booted successfully
O.K.
Firmware: J-Link OB-nRF5340-NordicSemi compiled Jun 11 2026 13:12:28
J-Link uptime (since boot): 0d 00h 00m 05s
S/N: 1050351525
License(s): RDI,FlashBP,FlashDL,JFlash,GDB
VTref=3.300V
J-Link>connect
Please specify device / core. <Default>: NRF52832_XXAA
Device>NRF52832_XXAA
  J) JTAG (Default)
  S) SWD
  T) cJTAG
TIF>S
Speed>1000
InitTarget() start
InitTarget() start
****** Error: J-Link script file function InitTarget() returned with error code -1
For troubleshooting steps visit: https://kb.segger.com/J-Link_Troubleshooting
J-Link>
Logs from `nrfutil`:
cbuec@W11nMate:~$ nrfutil device --version
nrfutil-device 2.19.4 (ae7891d 2026-06-30)
commit-hash: ae7891dd1b346c405d104061a4f18a8f4f897635
commit-date: 2026-06-30
host: x86_64-unknown-linux-gnu
build-timestamp: 2026-06-30T13:55:44.140980858Z
classification: nrf-external
Detected SEGGER J-Link version: JLink_V8.10f
The device command version you are currently using was tested with a different J-Link version (JLink_V9.24a) than the one you have installed (JLink_V8.10f). The tested version is not required, and your J-Link version will most likely work fine. If you get issues related to J-Link with your devices, use the tested version.
cbuec@W11nMate:~$ nrfutil device recover
❌ Failed to recover 1050351525, Device error: Access port is still protected after Erase and Reset        Error: One or more recover tasks failed:
 * 1050351525: Device error: Access port is still protected after Erase and Reset (Generic)
Logs from `nrfutil` with Segger J-Link version 9.24a:
cbuec@W11nMate:~/Downloads$ nrfutil device --version
Detected SEGGER J-Link version: JLink_V9.24a
cbuec@W11nMate:~/Downloads$ nrfutil device recover
Logs from "nRF Connect for Desktop Programmer" version 4.7.5 on Windows:
2026-07-06T12:46:20.312Z INFO Initialising the bundled nrfutil device
2026-07-06T12:46:20.322Z DEBUG Application data folder: C:\Users\cbuec\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
2026-07-06T12:46:20.356Z DEBUG App pc-nrfconnect-programmer v4.7.5 (official)
2026-07-06T12:46:20.356Z DEBUG App path: C:\Users\cbuec\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer
2026-07-06T12:46:20.356Z DEBUG nRFConnect 5.2.0, required by the app is (>=5.2.0)
2026-07-06T12:46:20.356Z DEBUG nRFConnect path: C:\Users\cbuec\AppData\Local\Programs\nrfconnect\resources\app.asar
2026-07-06T12:46:20.356Z DEBUG HomeDir: C:\Users\cbuec
2026-07-06T12:46:20.356Z DEBUG TmpDir: C:\Users\cbuec\AppData\Local\Temp
2026-07-06T12:46:23.804Z INFO Successfully installed nrfutil core version: 8.1.1
2026-07-06T12:46:27.011Z INFO Successfully installed nrfutil device version: 2.19.2
2026-07-06T12:46:27.126Z INFO Using the bundled core version for nrfutil device: 8.1.1
2026-07-06T12:46:27.243Z INFO Using nrfutil device version: 2.19.2
2026-07-06T12:46:27.243Z INFO Using nrf-device-lib version: 0.22.20
2026-07-06T12:46:27.244Z INFO Using nrf-probe version: 0.58.3
2026-07-06T12:46:27.244Z INFO Using SEGGER J-Link version: JLink_V9.30
2026-07-06T12:46:27.245Z INFO Your version of SEGGER J-Link (9.30) is newer than the one this app was tested with (9.24a). The tested version is not required, and your J-Link version will most likely work fine. If you get issues related to J-Link with your devices, use the tested version.
2026-07-06T12:46:29.800Z INFO Getting serial port options from the persistent store for 001050351525.pc-nrfconnect-programmer
2026-07-06T12:46:29.801Z INFO Device connected with the serial number 001050351525
2026-07-06T12:46:29.818Z INFO Getting serial port options from the persistent store for 001050351525.pc-nrfconnect-programmer
2026-07-06T12:46:34.472Z INFO Selecting device with the serial number 001050351525
2026-07-06T12:46:36.089Z INFO Selected device with the serial number 001050351525
2026-07-06T12:46:36.090Z INFO Using nrfutil device to communicate with target via JLink
2026-07-06T12:46:36.091Z INFO JLink OB firmware version J-Link OB-nRF5340-NordicSemi compiled Jun 11 2026 13:12:28
2026-07-06T12:46:36.091Z INFO Device family NRF52_FAMILY
2026-07-06T12:46:36.091Z INFO Device version
2026-07-06T12:46:36.091Z INFO Board version PCA10040
2026-07-06T12:46:36.333Z INFO Reading readback protection status for Application core
2026-07-06T12:46:36.333Z INFO Reading readback protection status for Application core 0%
2026-07-06T12:46:36.401Z INFO Reading readback protection status for Application core 50%
2026-07-06T12:46:36.420Z INFO Reading readback protection status for Application core 100%
2026-07-06T12:46:36.421Z INFO Application core protection status 'NRFDL_PROTECTION_STATUS_ALL'
2026-07-06T12:46:36.423Z INFO Reading readback protection status for Application core completed
2026-07-06T12:46:36.474Z INFO Skipping reading core Application information as it is protected.
2026-07-06T12:46:37.452Z ERROR Error: Failed with exit code 1.
One or more batch tasks failed:
 * 1050351525: Failed to attach to target: The Application core access port is currently closed. AP-Protect might be enabled (NotAvailableBecauseProtection)
The operation is unavailable for some of the devices because they have readback protection enabled. These devices might be possible to unlock using the `recover` subcommand. See `nrfutil device recover --help` for more information.
Message: Batch task reset failed, Failed to attach to target: The Application core access port is currently closed. AP-Protect might be enabled.
2026-07-06T12:47:11.422Z INFO Recovering Application core
2026-07-06T12:47:11.423Z INFO Recovering Application core 0%
2026-07-06T12:47:11.486Z INFO Recovering Application core 50%
2026-07-06T12:49:12.316Z ERROR Failed "recovering application core". Error: code: 1, description: Generic, message: Batch task recover failed, Device error: Access port is still protected after Erase and Reset
The state is now that we have two boards that are essentially bricked and a third board that seems to flash okay with the new firmware (but I do not want to try to make more logs and brick that too).
Any help in this regard would be much appreciated.
Best Regards,
Chris
  • Hi Chris,
    I am working on your case and will update it later once I have enough information.
    Amanda H.
  • Hi Chris,
    Could you run nrfutil with the --log-level tracing flag, and then send the log? I.e. nrfutil device recover --log-level tracing, and then the log file from $HOME/.nrfutil/logs/nrfutil-device.log.
    There's also an errata for the nRF52832 which could cause this: https://docs.nordicsemi.com/r/bundle/errata_nrf52832_rev1/page/err/nrf52832/rev1/latest/anomaly_832…, so you should check your watchdog settings.
    -Amanda H.
  • Hello Amanda,
    it seems like the log level is called trace, but here is the log you requested:
    cbuec@W11nMate:~$ nrfutil device recover --log-level trace
    [2026-07-08T07:58:54.158Z] [1546] INFO - [nrfutil_common::logger] nrfutil-device (version = 2.19.4, platform = x86_64-unknown-linux-gnu, classification = nrf-external) invoked with recover --log-level trace
    [2026-07-08T07:58:54.158Z] [1546] DEBUG - [nrfutil_device] Detected that we are running through nrfutil since NRFUTIL_EXEC_PATH was set. Setting NRF_PROBE_PATH to /home/cbuec/.nrfutil/lib/nrfutil-device
    [2026-07-08T07:58:54.159Z] [1546] INFO - [nrfutil_device::watch] Starting parent process watchdog, current parent process ID: 1544
    [2026-07-08T07:58:54.159Z] [1546] DEBUG - [probe] Worker timeout: None
    [2026-07-08T07:58:54.208Z] [1546] INFO - [jlink::backend] Opened J-Link DLL at /opt/SEGGER/JLink/libjlinkarm.so with version 9.24a
    [2026-07-08T07:58:54.208Z] [1546] DEBUG - [nrfdl::context] Plugin BOARDCONTROLLER does not support `get_version_list`
    [2026-07-08T07:58:54.208Z] [1546] DEBUG - [nrfdl::context] Plugin SDFU-RS does not support `get_version_list`
    [2026-07-08T07:58:54.208Z] [1546] DEBUG - [nrfdl::context] Plugin MCUBOOT does not support `get_version_list`
    [2026-07-08T07:58:54.208Z] [1546] INFO - [nrfutil_device::device] Getting devices for operations
    [2026-07-08T07:58:54.208Z] [1546] DEBUG - [nrfdl::device_lister] enumerate_devices
    [2026-07-08T07:58:54.208Z] [1546] DEBUG - [nusb::platform::linux_usbfs::enumeration] Probing device "/sys/devices/platform/vhci_hcd.0/usb1/1-1"
    [2026-07-08T07:58:54.208Z] [1546] DEBUG - [serialport_lister::platform] [Linux] Linux serialport enumerate.
    [2026-07-08T07:58:54.213Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1088), system_path: "/sys/devices/platform/serial8250/serial8250:0/serial8250:0.0/tty/ttyS0", device_path: "/devices/platform/serial8250/serial8250:0/serial8250:0.0/tty/ttyS0", device_node: Some("/dev/ttyS0"), subsystem_name: Some("tty"), system_name: "ttyS0", instance_number: Some(0), device_type: None, driver: None, action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250/serial8250:0/serial8250:0.0", device_path: "/devices/platform/serial8250/serial8250:0/serial8250:0.0", device_node: None, subsystem_name: Some("serial-base"), system_name: "serial8250:0.0", instance_number: Some(0), device_type: Some("port"), driver: Some("port"), action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250/serial8250:0", device_path: "/devices/platform/serial8250/serial8250:0", device_node: None, subsystem_name: Some("serial-base"), system_name: "serial8250:0", instance_number: Some(0), device_type: Some("ctrl"), driver: Some("ctrl"), action: None, parent: Some(Device { initialized: true, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250", device_path: "/devices/platform/serial8250", device_node: None, subsystem_name: Some("platform"), system_name: "serial8250", instance_number: Some(8250), device_type: None, driver: Some("serial8250"), action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform", device_path: "/devices/platform", device_node: None, subsystem_name: None, system_name: "platform", instance_number: None, device_type: None, driver: None, action: None, parent: None }) }) }) }) }, no parent USB device found.
    [2026-07-08T07:58:54.213Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1089), system_path: "/sys/devices/platform/serial8250/serial8250:0/serial8250:0.1/tty/ttyS1", device_path: "/devices/platform/serial8250/serial8250:0/serial8250:0.1/tty/ttyS1", device_node: Some("/dev/ttyS1"), subsystem_name: Some("tty"), system_name: "ttyS1", instance_number: Some(1), device_type: None, driver: None, action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250/serial8250:0/serial8250:0.1", device_path: "/devices/platform/serial8250/serial8250:0/serial8250:0.1", device_node: None, subsystem_name: Some("serial-base"), system_name: "serial8250:0.1", instance_number: Some(1), device_type: Some("port"), driver: Some("port"), action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250/serial8250:0", device_path: "/devices/platform/serial8250/serial8250:0", device_node: None, subsystem_name: Some("serial-base"), system_name: "serial8250:0", instance_number: Some(0), device_type: Some("ctrl"), driver: Some("ctrl"), action: None, parent: Some(Device { initialized: true, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250", device_path: "/devices/platform/serial8250", device_node: None, subsystem_name: Some("platform"), system_name: "serial8250", instance_number: Some(8250), device_type: None, driver: Some("serial8250"), action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform", device_path: "/devices/platform", device_node: None, subsystem_name: None, system_name: "platform", instance_number: None, device_type: None, driver: None, action: None, parent: None }) }) }) }) }, no parent USB device found.
    [2026-07-08T07:58:54.213Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1090), system_path: "/sys/devices/platform/serial8250/serial8250:0/serial8250:0.2/tty/ttyS2", device_path: "/devices/platform/serial8250/serial8250:0/serial8250:0.2/tty/ttyS2", device_node: Some("/dev/ttyS2"), subsystem_name: Some("tty"), system_name: "ttyS2", instance_number: Some(2), device_type: None, driver: None, action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250/serial8250:0/serial8250:0.2", device_path: "/devices/platform/serial8250/serial8250:0/serial8250:0.2", device_node: None, subsystem_name: Some("serial-base"), system_name: "serial8250:0.2", instance_number: Some(2), device_type: Some("port"), driver: Some("port"), action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250/serial8250:0", device_path: "/devices/platform/serial8250/serial8250:0", device_node: None, subsystem_name: Some("serial-base"), system_name: "serial8250:0", instance_number: Some(0), device_type: Some("ctrl"), driver: Some("ctrl"), action: None, parent: Some(Device { initialized: true, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250", device_path: "/devices/platform/serial8250", device_node: None, subsystem_name: Some("platform"), system_name: "serial8250", instance_number: Some(8250), device_type: None, driver: Some("serial8250"), action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform", device_path: "/devices/platform", device_node: None, subsystem_name: None, system_name: "platform", instance_number: None, device_type: None, driver: None, action: None, parent: None }) }) }) }) }, no parent USB device found.
    [2026-07-08T07:58:54.213Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1091), system_path: "/sys/devices/platform/serial8250/serial8250:0/serial8250:0.3/tty/ttyS3", device_path: "/devices/platform/serial8250/serial8250:0/serial8250:0.3/tty/ttyS3", device_node: Some("/dev/ttyS3"), subsystem_name: Some("tty"), system_name: "ttyS3", instance_number: Some(3), device_type: None, driver: None, action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250/serial8250:0/serial8250:0.3", device_path: "/devices/platform/serial8250/serial8250:0/serial8250:0.3", device_node: None, subsystem_name: Some("serial-base"), system_name: "serial8250:0.3", instance_number: Some(3), device_type: Some("port"), driver: Some("port"), action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250/serial8250:0", device_path: "/devices/platform/serial8250/serial8250:0", device_node: None, subsystem_name: Some("serial-base"), system_name: "serial8250:0", instance_number: Some(0), device_type: Some("ctrl"), driver: Some("ctrl"), action: None, parent: Some(Device { initialized: true, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250", device_path: "/devices/platform/serial8250", device_node: None, subsystem_name: Some("platform"), system_name: "serial8250", instance_number: Some(8250), device_type: None, driver: Some("serial8250"), action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform", device_path: "/devices/platform", device_node: None, subsystem_name: None, system_name: "platform", instance_number: None, device_type: None, driver: None, action: None, parent: None }) }) }) }) }, no parent USB device found.
    [2026-07-08T07:58:54.213Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1092), system_path: "/sys/devices/platform/serial8250/serial8250:0/serial8250:0.4/tty/ttyS4", device_path: "/devices/platform/serial8250/serial8250:0/serial8250:0.4/tty/ttyS4", device_node: Some("/dev/ttyS4"), subsystem_name: Some("tty"), system_name: "ttyS4", instance_number: Some(4), device_type: None, driver: None, action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250/serial8250:0/serial8250:0.4", device_path: "/devices/platform/serial8250/serial8250:0/serial8250:0.4", device_node: None, subsystem_name: Some("serial-base"), system_name: "serial8250:0.4", instance_number: Some(4), device_type: Some("port"), driver: Some("port"), action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250/serial8250:0", device_path: "/devices/platform/serial8250/serial8250:0", device_node: None, subsystem_name: Some("serial-base"), system_name: "serial8250:0", instance_number: Some(0), device_type: Some("ctrl"), driver: Some("ctrl"), action: None, parent: Some(Device { initialized: true, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250", device_path: "/devices/platform/serial8250", device_node: None, subsystem_name: Some("platform"), system_name: "serial8250", instance_number: Some(8250), device_type: None, driver: Some("serial8250"), action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform", device_path: "/devices/platform", device_node: None, subsystem_name: None, system_name: "platform", instance_number: None, device_type: None, driver: None, action: None, parent: None }) }) }) }) }, no parent USB device found.
    [2026-07-08T07:58:54.214Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1093), system_path: "/sys/devices/platform/serial8250/serial8250:0/serial8250:0.5/tty/ttyS5", device_path: "/devices/platform/serial8250/serial8250:0/serial8250:0.5/tty/ttyS5", device_node: Some("/dev/ttyS5"), subsystem_name: Some("tty"), system_name: "ttyS5", instance_number: Some(5), device_type: None, driver: None, action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250/serial8250:0/serial8250:0.5", device_path: "/devices/platform/serial8250/serial8250:0/serial8250:0.5", device_node: None, subsystem_name: Some("serial-base"), system_name: "serial8250:0.5", instance_number: Some(5), device_type: Some("port"), driver: Some("port"), action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250/serial8250:0", device_path: "/devices/platform/serial8250/serial8250:0", device_node: None, subsystem_name: Some("serial-base"), system_name: "serial8250:0", instance_number: Some(0), device_type: Some("ctrl"), driver: Some("ctrl"), action: None, parent: Some(Device { initialized: true, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250", device_path: "/devices/platform/serial8250", device_node: None, subsystem_name: Some("platform"), system_name: "serial8250", instance_number: Some(8250), device_type: None, driver: Some("serial8250"), action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform", device_path: "/devices/platform", device_node: None, subsystem_name: None, system_name: "platform", instance_number: None, device_type: None, driver: None, action: None, parent: None }) }) }) }) }, no parent USB device found.
    [2026-07-08T07:58:54.214Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1094), system_path: "/sys/devices/platform/serial8250/serial8250:0/serial8250:0.6/tty/ttyS6", device_path: "/devices/platform/serial8250/serial8250:0/serial8250:0.6/tty/ttyS6", device_node: Some("/dev/ttyS6"), subsystem_name: Some("tty"), system_name: "ttyS6", instance_number: Some(6), device_type: None, driver: None, action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250/serial8250:0/serial8250:0.6", device_path: "/devices/platform/serial8250/serial8250:0/serial8250:0.6", device_node: None, subsystem_name: Some("serial-base"), system_name: "serial8250:0.6", instance_number: Some(6), device_type: Some("port"), driver: Some("port"), action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250/serial8250:0", device_path: "/devices/platform/serial8250/serial8250:0", device_node: None, subsystem_name: Some("serial-base"), system_name: "serial8250:0", instance_number: Some(0), device_type: Some("ctrl"), driver: Some("ctrl"), action: None, parent: Some(Device { initialized: true, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250", device_path: "/devices/platform/serial8250", device_node: None, subsystem_name: Some("platform"), system_name: "serial8250", instance_number: Some(8250), device_type: None, driver: Some("serial8250"), action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform", device_path: "/devices/platform", device_node: None, subsystem_name: None, system_name: "platform", instance_number: None, device_type: None, driver: None, action: None, parent: None }) }) }) }) }, no parent USB device found.
    [2026-07-08T07:58:54.214Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1095), system_path: "/sys/devices/platform/serial8250/serial8250:0/serial8250:0.7/tty/ttyS7", device_path: "/devices/platform/serial8250/serial8250:0/serial8250:0.7/tty/ttyS7", device_node: Some("/dev/ttyS7"), subsystem_name: Some("tty"), system_name: "ttyS7", instance_number: Some(7), device_type: None, driver: None, action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250/serial8250:0/serial8250:0.7", device_path: "/devices/platform/serial8250/serial8250:0/serial8250:0.7", device_node: None, subsystem_name: Some("serial-base"), system_name: "serial8250:0.7", instance_number: Some(7), device_type: Some("port"), driver: Some("port"), action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250/serial8250:0", device_path: "/devices/platform/serial8250/serial8250:0", device_node: None, subsystem_name: Some("serial-base"), system_name: "serial8250:0", instance_number: Some(0), device_type: Some("ctrl"), driver: Some("ctrl"), action: None, parent: Some(Device { initialized: true, device_major_minor_number: None, system_path: "/sys/devices/platform/serial8250", device_path: "/devices/platform/serial8250", device_node: None, subsystem_name: Some("platform"), system_name: "serial8250", instance_number: Some(8250), device_type: None, driver: Some("serial8250"), action: None, parent: Some(Device { initialized: false, device_major_minor_number: None, system_path: "/sys/devices/platform", device_path: "/devices/platform", device_node: None, subsystem_name: None, system_name: "platform", instance_number: None, device_type: None, driver: None, action: None, parent: None }) }) }) }) }, no parent USB device found.
    [2026-07-08T07:58:54.214Z] [1546] TRACE - [serialport_lister::platform] [Linux] get_lister_item: sys_path = /sys/devices/platform/vhci_hcd.0/usb1/1-1/1-1:1.0/tty/ttyACM0
    [2026-07-08T07:58:54.214Z] [1546] TRACE - [serialport_lister::platform] [Linux] get_lister_item: devnode = /dev/ttyACM0
    [2026-07-08T07:58:54.214Z] [1546] TRACE - [serialport_lister::platform] [Linux] get_lister_item: usb_interface_number = 0
    [2026-07-08T07:58:54.214Z] [1546] TRACE - [serialport_lister::platform] [Linux] parent syspath: /sys/devices/platform/vhci_hcd.0/usb1
    [2026-07-08T07:58:54.214Z] [1546] TRACE - [serialport_lister::platform] [Linux] set container ID: /sys/devices/platform/vhci_hcd.0/usb1
    [2026-07-08T07:58:54.214Z] [1546] TRACE - [serialport_lister::platform] [Linux] get_lister_item: sys_path = /sys/devices/platform/vhci_hcd.0/usb1/1-1/1-1:1.2/tty/ttyACM1
    [2026-07-08T07:58:54.214Z] [1546] TRACE - [serialport_lister::platform] [Linux] get_lister_item: devnode = /dev/ttyACM1
    [2026-07-08T07:58:54.214Z] [1546] TRACE - [serialport_lister::platform] [Linux] get_lister_item: usb_interface_number = 2
    [2026-07-08T07:58:54.214Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1281), system_path: "/sys/devices/virtual/tty/console", device_path: "/devices/virtual/tty/console", device_node: Some("/dev/console"), subsystem_name: Some("tty"), system_name: "console", instance_number: None, device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.214Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(58624), system_path: "/sys/devices/virtual/tty/hvc0", device_path: "/devices/virtual/tty/hvc0", device_node: Some("/dev/hvc0"), subsystem_name: Some("tty"), system_name: "hvc0", instance_number: Some(0), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.215Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(58625), system_path: "/sys/devices/virtual/tty/hvc1", device_path: "/devices/virtual/tty/hvc1", device_node: Some("/dev/hvc1"), subsystem_name: Some("tty"), system_name: "hvc1", instance_number: Some(1), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.215Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(58626), system_path: "/sys/devices/virtual/tty/hvc2", device_path: "/devices/virtual/tty/hvc2", device_node: Some("/dev/hvc2"), subsystem_name: Some("tty"), system_name: "hvc2", instance_number: Some(2), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.215Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(58627), system_path: "/sys/devices/virtual/tty/hvc3", device_path: "/devices/virtual/tty/hvc3", device_node: Some("/dev/hvc3"), subsystem_name: Some("tty"), system_name: "hvc3", instance_number: Some(3), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.215Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(58628), system_path: "/sys/devices/virtual/tty/hvc4", device_path: "/devices/virtual/tty/hvc4", device_node: Some("/dev/hvc4"), subsystem_name: Some("tty"), system_name: "hvc4", instance_number: Some(4), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.215Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(58629), system_path: "/sys/devices/virtual/tty/hvc5", device_path: "/devices/virtual/tty/hvc5", device_node: Some("/dev/hvc5"), subsystem_name: Some("tty"), system_name: "hvc5", instance_number: Some(5), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.215Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(58630), system_path: "/sys/devices/virtual/tty/hvc6", device_path: "/devices/virtual/tty/hvc6", device_node: Some("/dev/hvc6"), subsystem_name: Some("tty"), system_name: "hvc6", instance_number: Some(6), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.215Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(58631), system_path: "/sys/devices/virtual/tty/hvc7", device_path: "/devices/virtual/tty/hvc7", device_node: Some("/dev/hvc7"), subsystem_name: Some("tty"), system_name: "hvc7", instance_number: Some(7), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.215Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1282), system_path: "/sys/devices/virtual/tty/ptmx", device_path: "/devices/virtual/tty/ptmx", device_node: Some("/dev/ptmx"), subsystem_name: Some("tty"), system_name: "ptmx", instance_number: None, device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.215Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1280), system_path: "/sys/devices/virtual/tty/tty", device_path: "/devices/virtual/tty/tty", device_node: Some("/dev/tty"), subsystem_name: Some("tty"), system_name: "tty", instance_number: None, device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.215Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1024), system_path: "/sys/devices/virtual/tty/tty0", device_path: "/devices/virtual/tty/tty0", device_node: Some("/dev/tty0"), subsystem_name: Some("tty"), system_name: "tty0", instance_number: Some(0), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.215Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1025), system_path: "/sys/devices/virtual/tty/tty1", device_path: "/devices/virtual/tty/tty1", device_node: Some("/dev/tty1"), subsystem_name: Some("tty"), system_name: "tty1", instance_number: Some(1), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.215Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1034), system_path: "/sys/devices/virtual/tty/tty10", device_path: "/devices/virtual/tty/tty10", device_node: Some("/dev/tty10"), subsystem_name: Some("tty"), system_name: "tty10", instance_number: Some(10), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.215Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1035), system_path: "/sys/devices/virtual/tty/tty11", device_path: "/devices/virtual/tty/tty11", device_node: Some("/dev/tty11"), subsystem_name: Some("tty"), system_name: "tty11", instance_number: Some(11), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.215Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1036), system_path: "/sys/devices/virtual/tty/tty12", device_path: "/devices/virtual/tty/tty12", device_node: Some("/dev/tty12"), subsystem_name: Some("tty"), system_name: "tty12", instance_number: Some(12), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.215Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1037), system_path: "/sys/devices/virtual/tty/tty13", device_path: "/devices/virtual/tty/tty13", device_node: Some("/dev/tty13"), subsystem_name: Some("tty"), system_name: "tty13", instance_number: Some(13), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.215Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1038), system_path: "/sys/devices/virtual/tty/tty14", device_path: "/devices/virtual/tty/tty14", device_node: Some("/dev/tty14"), subsystem_name: Some("tty"), system_name: "tty14", instance_number: Some(14), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.215Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1039), system_path: "/sys/devices/virtual/tty/tty15", device_path: "/devices/virtual/tty/tty15", device_node: Some("/dev/tty15"), subsystem_name: Some("tty"), system_name: "tty15", instance_number: Some(15), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.216Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1040), system_path: "/sys/devices/virtual/tty/tty16", device_path: "/devices/virtual/tty/tty16", device_node: Some("/dev/tty16"), subsystem_name: Some("tty"), system_name: "tty16", instance_number: Some(16), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.216Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1041), system_path: "/sys/devices/virtual/tty/tty17", device_path: "/devices/virtual/tty/tty17", device_node: Some("/dev/tty17"), subsystem_name: Some("tty"), system_name: "tty17", instance_number: Some(17), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.216Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1042), system_path: "/sys/devices/virtual/tty/tty18", device_path: "/devices/virtual/tty/tty18", device_node: Some("/dev/tty18"), subsystem_name: Some("tty"), system_name: "tty18", instance_number: Some(18), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.216Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1043), system_path: "/sys/devices/virtual/tty/tty19", device_path: "/devices/virtual/tty/tty19", device_node: Some("/dev/tty19"), subsystem_name: Some("tty"), system_name: "tty19", instance_number: Some(19), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.216Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1026), system_path: "/sys/devices/virtual/tty/tty2", device_path: "/devices/virtual/tty/tty2", device_node: Some("/dev/tty2"), subsystem_name: Some("tty"), system_name: "tty2", instance_number: Some(2), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.216Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1044), system_path: "/sys/devices/virtual/tty/tty20", device_path: "/devices/virtual/tty/tty20", device_node: Some("/dev/tty20"), subsystem_name: Some("tty"), system_name: "tty20", instance_number: Some(20), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.216Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1045), system_path: "/sys/devices/virtual/tty/tty21", device_path: "/devices/virtual/tty/tty21", device_node: Some("/dev/tty21"), subsystem_name: Some("tty"), system_name: "tty21", instance_number: Some(21), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.216Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1046), system_path: "/sys/devices/virtual/tty/tty22", device_path: "/devices/virtual/tty/tty22", device_node: Some("/dev/tty22"), subsystem_name: Some("tty"), system_name: "tty22", instance_number: Some(22), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.216Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1047), system_path: "/sys/devices/virtual/tty/tty23", device_path: "/devices/virtual/tty/tty23", device_node: Some("/dev/tty23"), subsystem_name: Some("tty"), system_name: "tty23", instance_number: Some(23), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.216Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1048), system_path: "/sys/devices/virtual/tty/tty24", device_path: "/devices/virtual/tty/tty24", device_node: Some("/dev/tty24"), subsystem_name: Some("tty"), system_name: "tty24", instance_number: Some(24), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.216Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1049), system_path: "/sys/devices/virtual/tty/tty25", device_path: "/devices/virtual/tty/tty25", device_node: Some("/dev/tty25"), subsystem_name: Some("tty"), system_name: "tty25", instance_number: Some(25), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.216Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1050), system_path: "/sys/devices/virtual/tty/tty26", device_path: "/devices/virtual/tty/tty26", device_node: Some("/dev/tty26"), subsystem_name: Some("tty"), system_name: "tty26", instance_number: Some(26), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.216Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1051), system_path: "/sys/devices/virtual/tty/tty27", device_path: "/devices/virtual/tty/tty27", device_node: Some("/dev/tty27"), subsystem_name: Some("tty"), system_name: "tty27", instance_number: Some(27), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.216Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1052), system_path: "/sys/devices/virtual/tty/tty28", device_path: "/devices/virtual/tty/tty28", device_node: Some("/dev/tty28"), subsystem_name: Some("tty"), system_name: "tty28", instance_number: Some(28), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.216Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1053), system_path: "/sys/devices/virtual/tty/tty29", device_path: "/devices/virtual/tty/tty29", device_node: Some("/dev/tty29"), subsystem_name: Some("tty"), system_name: "tty29", instance_number: Some(29), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.216Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1027), system_path: "/sys/devices/virtual/tty/tty3", device_path: "/devices/virtual/tty/tty3", device_node: Some("/dev/tty3"), subsystem_name: Some("tty"), system_name: "tty3", instance_number: Some(3), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.216Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1054), system_path: "/sys/devices/virtual/tty/tty30", device_path: "/devices/virtual/tty/tty30", device_node: Some("/dev/tty30"), subsystem_name: Some("tty"), system_name: "tty30", instance_number: Some(30), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.217Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1055), system_path: "/sys/devices/virtual/tty/tty31", device_path: "/devices/virtual/tty/tty31", device_node: Some("/dev/tty31"), subsystem_name: Some("tty"), system_name: "tty31", instance_number: Some(31), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.217Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1056), system_path: "/sys/devices/virtual/tty/tty32", device_path: "/devices/virtual/tty/tty32", device_node: Some("/dev/tty32"), subsystem_name: Some("tty"), system_name: "tty32", instance_number: Some(32), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.217Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1057), system_path: "/sys/devices/virtual/tty/tty33", device_path: "/devices/virtual/tty/tty33", device_node: Some("/dev/tty33"), subsystem_name: Some("tty"), system_name: "tty33", instance_number: Some(33), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.217Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1058), system_path: "/sys/devices/virtual/tty/tty34", device_path: "/devices/virtual/tty/tty34", device_node: Some("/dev/tty34"), subsystem_name: Some("tty"), system_name: "tty34", instance_number: Some(34), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.217Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1059), system_path: "/sys/devices/virtual/tty/tty35", device_path: "/devices/virtual/tty/tty35", device_node: Some("/dev/tty35"), subsystem_name: Some("tty"), system_name: "tty35", instance_number: Some(35), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.217Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1060), system_path: "/sys/devices/virtual/tty/tty36", device_path: "/devices/virtual/tty/tty36", device_node: Some("/dev/tty36"), subsystem_name: Some("tty"), system_name: "tty36", instance_number: Some(36), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.217Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1061), system_path: "/sys/devices/virtual/tty/tty37", device_path: "/devices/virtual/tty/tty37", device_node: Some("/dev/tty37"), subsystem_name: Some("tty"), system_name: "tty37", instance_number: Some(37), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.217Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1062), system_path: "/sys/devices/virtual/tty/tty38", device_path: "/devices/virtual/tty/tty38", device_node: Some("/dev/tty38"), subsystem_name: Some("tty"), system_name: "tty38", instance_number: Some(38), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.217Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1063), system_path: "/sys/devices/virtual/tty/tty39", device_path: "/devices/virtual/tty/tty39", device_node: Some("/dev/tty39"), subsystem_name: Some("tty"), system_name: "tty39", instance_number: Some(39), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.217Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1028), system_path: "/sys/devices/virtual/tty/tty4", device_path: "/devices/virtual/tty/tty4", device_node: Some("/dev/tty4"), subsystem_name: Some("tty"), system_name: "tty4", instance_number: Some(4), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.217Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1064), system_path: "/sys/devices/virtual/tty/tty40", device_path: "/devices/virtual/tty/tty40", device_node: Some("/dev/tty40"), subsystem_name: Some("tty"), system_name: "tty40", instance_number: Some(40), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.217Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1065), system_path: "/sys/devices/virtual/tty/tty41", device_path: "/devices/virtual/tty/tty41", device_node: Some("/dev/tty41"), subsystem_name: Some("tty"), system_name: "tty41", instance_number: Some(41), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.217Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1066), system_path: "/sys/devices/virtual/tty/tty42", device_path: "/devices/virtual/tty/tty42", device_node: Some("/dev/tty42"), subsystem_name: Some("tty"), system_name: "tty42", instance_number: Some(42), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.217Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1067), system_path: "/sys/devices/virtual/tty/tty43", device_path: "/devices/virtual/tty/tty43", device_node: Some("/dev/tty43"), subsystem_name: Some("tty"), system_name: "tty43", instance_number: Some(43), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.217Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1068), system_path: "/sys/devices/virtual/tty/tty44", device_path: "/devices/virtual/tty/tty44", device_node: Some("/dev/tty44"), subsystem_name: Some("tty"), system_name: "tty44", instance_number: Some(44), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.217Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1069), system_path: "/sys/devices/virtual/tty/tty45", device_path: "/devices/virtual/tty/tty45", device_node: Some("/dev/tty45"), subsystem_name: Some("tty"), system_name: "tty45", instance_number: Some(45), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.217Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1070), system_path: "/sys/devices/virtual/tty/tty46", device_path: "/devices/virtual/tty/tty46", device_node: Some("/dev/tty46"), subsystem_name: Some("tty"), system_name: "tty46", instance_number: Some(46), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.217Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1071), system_path: "/sys/devices/virtual/tty/tty47", device_path: "/devices/virtual/tty/tty47", device_node: Some("/dev/tty47"), subsystem_name: Some("tty"), system_name: "tty47", instance_number: Some(47), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.218Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1072), system_path: "/sys/devices/virtual/tty/tty48", device_path: "/devices/virtual/tty/tty48", device_node: Some("/dev/tty48"), subsystem_name: Some("tty"), system_name: "tty48", instance_number: Some(48), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.218Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1073), system_path: "/sys/devices/virtual/tty/tty49", device_path: "/devices/virtual/tty/tty49", device_node: Some("/dev/tty49"), subsystem_name: Some("tty"), system_name: "tty49", instance_number: Some(49), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.218Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1029), system_path: "/sys/devices/virtual/tty/tty5", device_path: "/devices/virtual/tty/tty5", device_node: Some("/dev/tty5"), subsystem_name: Some("tty"), system_name: "tty5", instance_number: Some(5), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.218Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1074), system_path: "/sys/devices/virtual/tty/tty50", device_path: "/devices/virtual/tty/tty50", device_node: Some("/dev/tty50"), subsystem_name: Some("tty"), system_name: "tty50", instance_number: Some(50), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.218Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1075), system_path: "/sys/devices/virtual/tty/tty51", device_path: "/devices/virtual/tty/tty51", device_node: Some("/dev/tty51"), subsystem_name: Some("tty"), system_name: "tty51", instance_number: Some(51), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.218Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1076), system_path: "/sys/devices/virtual/tty/tty52", device_path: "/devices/virtual/tty/tty52", device_node: Some("/dev/tty52"), subsystem_name: Some("tty"), system_name: "tty52", instance_number: Some(52), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.218Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1077), system_path: "/sys/devices/virtual/tty/tty53", device_path: "/devices/virtual/tty/tty53", device_node: Some("/dev/tty53"), subsystem_name: Some("tty"), system_name: "tty53", instance_number: Some(53), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.218Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1078), system_path: "/sys/devices/virtual/tty/tty54", device_path: "/devices/virtual/tty/tty54", device_node: Some("/dev/tty54"), subsystem_name: Some("tty"), system_name: "tty54", instance_number: Some(54), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.218Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1079), system_path: "/sys/devices/virtual/tty/tty55", device_path: "/devices/virtual/tty/tty55", device_node: Some("/dev/tty55"), subsystem_name: Some("tty"), system_name: "tty55", instance_number: Some(55), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.218Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1080), system_path: "/sys/devices/virtual/tty/tty56", device_path: "/devices/virtual/tty/tty56", device_node: Some("/dev/tty56"), subsystem_name: Some("tty"), system_name: "tty56", instance_number: Some(56), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.218Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1081), system_path: "/sys/devices/virtual/tty/tty57", device_path: "/devices/virtual/tty/tty57", device_node: Some("/dev/tty57"), subsystem_name: Some("tty"), system_name: "tty57", instance_number: Some(57), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.218Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1082), system_path: "/sys/devices/virtual/tty/tty58", device_path: "/devices/virtual/tty/tty58", device_node: Some("/dev/tty58"), subsystem_name: Some("tty"), system_name: "tty58", instance_number: Some(58), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.218Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1083), system_path: "/sys/devices/virtual/tty/tty59", device_path: "/devices/virtual/tty/tty59", device_node: Some("/dev/tty59"), subsystem_name: Some("tty"), system_name: "tty59", instance_number: Some(59), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.218Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1030), system_path: "/sys/devices/virtual/tty/tty6", device_path: "/devices/virtual/tty/tty6", device_node: Some("/dev/tty6"), subsystem_name: Some("tty"), system_name: "tty6", instance_number: Some(6), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.218Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1084), system_path: "/sys/devices/virtual/tty/tty60", device_path: "/devices/virtual/tty/tty60", device_node: Some("/dev/tty60"), subsystem_name: Some("tty"), system_name: "tty60", instance_number: Some(60), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.218Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1085), system_path: "/sys/devices/virtual/tty/tty61", device_path: "/devices/virtual/tty/tty61", device_node: Some("/dev/tty61"), subsystem_name: Some("tty"), system_name: "tty61", instance_number: Some(61), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.218Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1086), system_path: "/sys/devices/virtual/tty/tty62", device_path: "/devices/virtual/tty/tty62", device_node: Some("/dev/tty62"), subsystem_name: Some("tty"), system_name: "tty62", instance_number: Some(62), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.219Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1087), system_path: "/sys/devices/virtual/tty/tty63", device_path: "/devices/virtual/tty/tty63", device_node: Some("/dev/tty63"), subsystem_name: Some("tty"), system_name: "tty63", instance_number: Some(63), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.219Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1031), system_path: "/sys/devices/virtual/tty/tty7", device_path: "/devices/virtual/tty/tty7", device_node: Some("/dev/tty7"), subsystem_name: Some("tty"), system_name: "tty7", instance_number: Some(7), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.219Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1032), system_path: "/sys/devices/virtual/tty/tty8", device_path: "/devices/virtual/tty/tty8", device_node: Some("/dev/tty8"), subsystem_name: Some("tty"), system_name: "tty8", instance_number: Some(8), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.219Z] [1546] TRACE - [serialport_lister::platform] Ignoring serial port Device { initialized: true, device_major_minor_number: Some(1033), system_path: "/sys/devices/virtual/tty/tty9", device_path: "/devices/virtual/tty/tty9", device_node: Some("/dev/tty9"), subsystem_name: Some("tty"), system_name: "tty9", instance_number: Some(9), device_type: None, driver: None, action: None, parent: None }, no parent USB device found.
    [2026-07-08T07:58:54.219Z] [1546] DEBUG - [nrfdl::device_lister] enumerate: Device with sn 001050351525 has board version PCA10040
    [2026-07-08T07:58:54.219Z] [1546] DEBUG - [nrfdl::device_lister] enumerate plugin: Probe
    [2026-07-08T07:58:54.219Z] [1546] INFO - [jlink::backend] Opened J-Link DLL at /opt/SEGGER/JLink/libjlinkarm.so with version 9.24a
    [2026-07-08T07:58:54.221Z] [1546] INFO - [jlink::backend] Found 1 attached J-Link devices
    [2026-07-08T07:58:54.221Z] [1546] DEBUG - [probe] Found the following J-Link devices: [JLinkSerialNumber(1050351525)]
    [2026-07-08T07:58:54.221Z] [1546] DEBUG - [nrfdl::device_lister] enumerate plugin Probe done in: 1ms
    [2026-07-08T07:58:54.221Z] [1546] DEBUG - [nrfdl::device_lister] enumerate plugin: BOARDCONTROLLER
    [2026-07-08T07:58:54.221Z] [1546] DEBUG - [nrfdl::device_lister] enumerate plugin BOARDCONTROLLER done in: 0ms
    [2026-07-08T07:58:54.221Z] [1546] DEBUG - [nrfdl::device_lister] enumerate plugin: SDFU-RS
    [2026-07-08T07:58:54.221Z] [1546] DEBUG - [nrfdl::device_lister] enumerate plugin SDFU-RS done in: 0ms
    [2026-07-08T07:58:54.221Z] [1546] DEBUG - [nrfdl::device_lister] enumerate plugin: MCUBOOT
    [2026-07-08T07:58:54.221Z] [1546] DEBUG - [nrfdl::device_lister] enumerate plugin MCUBOOT done in: 0ms
    [2026-07-08T07:58:54.221Z] [1546] DEBUG - [nrfutil_device::device] operations to get devices for : Ok("{\"operations\":[{\"operation\":{\"type\":\"recover\",\"erase_protect_key\":null},\"core\":\"NRFDL_DEVICE_CORE_APPLICATION\"}]}")
    [2026-07-08T07:58:54.221Z] [1546] TRACE - [nrfutil_device::device] Operations required by a device to do: {"recover"}
    [2026-07-08T07:58:54.221Z] [1546] TRACE - [nrfutil_device::device] List of devices capable of performing the operations : [Device { id: DeviceId(1), serial_number: Some("001050351525"), traits: {"boardController": false, "broken": false, "devkit": true, "jlink": true, "mcuBoot": false, "modem": false, "nordicDfu": false, "nordicUsb": false, "seggerUsb": true, "serialPorts": true, "usb": true}, usb: Some(Usb { serial_number: Some("001050351525"), manufacturer: Some("SEGGER"), product: Some("J-Link"), usb_identifier: "/sys/devices/platform/vhci_hcd.0/usb1/1-1", os_device_path: Some("/sys/devices/platform/vhci_hcd.0/usb1/1-1"), device: Some(UsbDevice { address: 2, bus_number: 1, descriptor: UsbDeviceDescriptor { b_descriptor_type: 1, id_vendor: 4966, id_product: 4192, bcd_device: 256 } }), interfaces: [UsbInterface { interface_string: Some("CDC"), interface_number: 0, class: 2 }, UsbInterface { interface_string: Some("CDC DATA interface"), interface_number: 1, class: 10 }, UsbInterface { interface_string: Some("CDC"), interface_number: 2, class: 2 }, UsbInterface { interface_string: Some("CDC DATA interface"), interface_number: 3, class: 10 }, UsbInterface { interface_string: Some("BULK interface"), interface_number: 4, class: 255 }] }), identifier: "/sys/devices/platform/vhci_hcd.0/usb1/1-1", serial_ports: [Serialport { com_name: Some("/dev/ttyACM0"), manufacturer: Some("SEGGER"), serial_number: Some("001050351525"), vendor_id: Some("1366"), product_id: Some("1060"), usb_identifier: Some("/sys/devices/platform/vhci_hcd.0/usb1/1-1"), path: "/dev/ttyACM0", container_id: Some("/sys/devices/platform/vhci_hcd.0/usb1"), interface_number: Some(0), vcom: 0 }, Serialport { com_name: Some("/dev/ttyACM1"), manufacturer: Some("SEGGER"), serial_number: Some("001050351525"), vendor_id: Some("1366"), product_id: Some("1060"), usb_identifier: Some("/sys/devices/platform/vhci_hcd.0/usb1/1-1"), path: "/dev/ttyACM1", container_id: Some("/sys/devices/platform/vhci_hcd.0/usb1"), interface_number: Some(2), vcom: 1 }], plugin_data: {"devkit": Object {"boardVersion": String("PCA10040"), "deviceFamily": String("NRF52_FAMILY")}, "probe": String("{}")} }]
    [2026-07-08T07:58:54.221Z] [1546] DEBUG - [nrfutil_device::device] No serial number or traits provided. But only one relevant device is connected. Will perform operation with Device { id: DeviceId(1), serial_number: Some("001050351525"), traits: {"boardController": false, "broken": false, "devkit": true, "jlink": true, "mcuBoot": false, "modem": false, "nordicDfu": false, "nordicUsb": false, "seggerUsb": true, "serialPorts": true, "usb": true}, usb: Some(Usb { serial_number: Some("001050351525"), manufacturer: Some("SEGGER"), product: Some("J-Link"), usb_identifier: "/sys/devices/platform/vhci_hcd.0/usb1/1-1", os_device_path: Some("/sys/devices/platform/vhci_hcd.0/usb1/1-1"), device: Some(UsbDevice { address: 2, bus_number: 1, descriptor: UsbDeviceDescriptor { b_descriptor_type: 1, id_vendor: 4966, id_product: 4192, bcd_device: 256 } }), interfaces: [UsbInterface { interface_string: Some("CDC"), interface_number: 0, class: 2 }, UsbInterface { interface_string: Some("CDC DATA interface"), interface_number: 1, class: 10 }, UsbInterface { interface_string: Some("CDC"), interface_number: 2, class: 2 }, UsbInterface { interface_string: Some("CDC DATA interface"), interface_number: 3, class: 10 }, UsbInterface { interface_string: Some("BULK interface"), interface_number: 4, class: 255 }] }), identifier: "/sys/devices/platform/vhci_hcd.0/usb1/1-1", serial_ports: [Serialport { com_name: Some("/dev/ttyACM0"), manufacturer: Some("SEGGER"), serial_number: Some("001050351525"), vendor_id: Some("1366"), product_id: Some("1060"), usb_identifier: Some("/sys/devices/platform/vhci_hcd.0/usb1/1-1"), path: "/dev/ttyACM0", container_id: Some("/sys/devices/platform/vhci_hcd.0/usb1"), interface_number: Some(0), vcom: 0 }, Serialport { com_name: Some("/dev/ttyACM1"), manufacturer: Some("SEGGER"), serial_number: Some("001050351525"), vendor_id: Some("1366"), product_id: Some("1060"), usb_identifier: Some("/sys/devices/platform/vhci_hcd.0/usb1/1-1"), path: "/dev/ttyACM1", container_id: Some("/sys/devices/platform/vhci_hcd.0/usb1"), interface_number: Some(2), vcom: 1 }], plugin_data: {"devkit": Object {"boardVersion": String("PCA10040"), "deviceFamily": String("NRF52_FAMILY")}, "probe": String("{}")} }
    [2026-07-08T07:58:54.221Z] [1546] INFO - [nrfutil_device::operations] Executing operation recover
    [2026-07-08T07:58:54.221Z] [1546] DEBUG - [probe] Checking whether operations are supported
    [2026-07-08T07:58:54.221Z] [1546] DEBUG - [probe] Executing operation: {"operations":[{"core":"NRFDL_DEVICE_CORE_APPLICATION","operation":{"erase_protect_key":null,"type":"recover"}}]}
    [2026-07-08T07:58:54.221Z] [1546] DEBUG - [probe] The J-Link device jlink_usb_001050351525 has USB product id 0x1060. Mass storage device (MSD) is not enabled on this device
    [2026-07-08T07:58:54.221Z] [1546] DEBUG - [nrf_probe_common::pathfinder] Looking for file in /home/cbuec/.nrfutil/lib/nrfutil-device/plugin-probe-worker
    [2026-07-08T07:58:54.221Z] [1546] DEBUG - [nrf_probe_common::pathfinder] Found file at /home/cbuec/.nrfutil/lib/nrfutil-device/plugin-probe-worker
    [2026-07-08T07:58:54.221Z] [1546] TRACE - [nrf_probe::probe_pool] Created IPC server /tmp/.tmpDjvghy/socket
    [2026-07-08T07:58:54.222Z] [1546] DEBUG - [nrf_probe::probe_pool] Spawned worker process with ID 1554
    [2026-07-08T07:58:54.222Z] [1546] TRACE - [nrf_probe::probe_pool] Accepting IPC connection
    [2026-07-08T07:58:54.235Z] [1546] TRACE - [nrf_probe::probe_pool] Accepted IPC connection
    [2026-07-08T07:58:54.235Z] [1546] TRACE - [nrf_probe::probe_pool] The worker supervisor's role is finished
    [2026-07-08T07:58:54.235Z] [1546] DEBUG - [nrf_probe::probe_pool] Received signal from master; stopping
    [2026-07-08T07:58:54.235Z] [1546] INFO - [nrf_probe::probe_pool] Handshake signatures match
    [2026-07-08T07:58:54.235Z] [1546] INFO - [nrf_probe::probe_pool] Connection with Probe worker established
    [2026-07-08T07:58:54.235Z] [1546] TRACE - [nrf_probe::probe_pool] Starting trace thread
    [2026-07-08T07:58:54.235Z] [1546] INFO - [nrf_probe::probe_pool::worker] {jlink_usb_001050351525} nrf-probe version 0.58.6 (458c89f)
    [2026-07-08T07:58:54.235Z] [1546] DEBUG - [nrf_probe::probe_pool::worker] {jlink_usb_001050351525} Sending IPC handshake response from worker
    [2026-07-08T07:58:54.235Z] [1546] DEBUG - [nrf_probe::probe_pool::worker] {jlink_usb_001050351525} Started worker message processing loop
    [2026-07-08T07:58:54.235Z] [1546] DEBUG - [nrf_probe::probe_pool::worker] {jlink_usb_001050351525} Probe worker received initial message: Initialize(InitializeRequest { configuration: Configuration { jlink: JLinkConfig { dll_location: None, log_file: None }, target: DeviceConfig { swd_clock_frequency: None, adac_timeout: None, firmware_config: None, swd_mode: PointToPoint, target_family: None, override_detection: None, override_sdfw_variant: None, record: false } } })
    [2026-07-08T07:58:54.235Z] [1546] INFO - [nrf_probe::probe_pool::worker] {jlink_usb_001050351525} -> handle_initialize
    [2026-07-08T07:58:54.235Z] [1546] INFO - [nrf_probe::probe_pool::plugin_worker] {jlink_usb_001050351525} -> create_probe
    [2026-07-08T07:58:54.235Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> new
    [2026-07-08T07:58:54.235Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> new_from_path
    [2026-07-08T07:58:54.235Z] [1546] INFO - [jlink::backend] {jlink_usb_001050351525} -> JLinkDLL::new
    [2026-07-08T07:58:54.241Z] [1546] INFO - [jlink::backend] {jlink_usb_001050351525} <- JLinkDLL::new
    [2026-07-08T07:58:54.241Z] [1546] INFO - [jlink::backend] {jlink_usb_001050351525} -> version
    [2026-07-08T07:58:54.241Z] [1546] INFO - [jlink::backend] {jlink_usb_001050351525} <- version
    [2026-07-08T07:58:54.242Z] [1546] INFO - [jlink::backend] {jlink_usb_001050351525} Opened J-Link DLL at /opt/SEGGER/JLink/libjlinkarm.so with version 9.24a
    [2026-07-08T07:58:54.242Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- new_from_path
    [2026-07-08T07:58:54.242Z] [1546] TRACE - [nrf_probe::probe_pool::plugin_worker] {jlink_usb_001050351525} Setting up J-Link interface
    [2026-07-08T07:58:54.242Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> connect
    [2026-07-08T07:58:54.242Z] [1546] INFO - [jlink::backend] {jlink_usb_001050351525} -> select_jlink
    [2026-07-08T07:58:54.242Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} Selecting J-Link with serial number 001050351525
    [2026-07-08T07:58:54.242Z] [1546] INFO - [jlink::backend] {jlink_usb_001050351525} <- select_jlink
    [2026-07-08T07:58:54.243Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} ExecCommand SuppressInfoUpdateFW
    [2026-07-08T07:58:54.243Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} ExecCommand SuppressInfoUpdateFW returned 0
    [2026-07-08T07:58:54.243Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} ExecCommand DisableAutoUpdateFW
    [2026-07-08T07:58:54.243Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} ExecCommand DisableAutoUpdateFW returned 0
    [2026-07-08T07:58:54.243Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Applied firmware settings to J-Link
    [2026-07-08T07:58:54.243Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} ExecCommand SetBatchMode 1
    [2026-07-08T07:58:54.243Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} ExecCommand SetBatchMode 1 returned 0
    [2026-07-08T07:58:54.243Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} ExecCommand SuppressGUI
    [2026-07-08T07:58:54.243Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} ExecCommand SuppressGUI returned 0
    [2026-07-08T07:58:54.243Z] [1546] INFO - [jlink::backend] {jlink_usb_001050351525} -> open_ex
    [2026-07-08T07:58:54.283Z] [1546] INFO - [jlink::backend] {jlink_usb_001050351525} <- open_ex
    [2026-07-08T07:58:54.283Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} ExecCommand SetAllowFlashCache = 0
    [2026-07-08T07:58:54.283Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} ExecCommand SetAllowFlashCache = 0 returned 1
    [2026-07-08T07:58:54.283Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} ExecCommand DisableInfoWinFlashDL
    [2026-07-08T07:58:54.283Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} ExecCommand DisableInfoWinFlashDL returned 0
    [2026-07-08T07:58:54.283Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} ExecCommand DisableFlashDL
    [2026-07-08T07:58:54.283Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} ExecCommand DisableFlashDL returned 0
    [2026-07-08T07:58:54.283Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} ExecCommand SetRestartOnClose 0
    [2026-07-08T07:58:54.283Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} ExecCommand SetRestartOnClose 0 returned 1
    [2026-07-08T07:58:54.288Z] [1546] DEBUG - [jlink::backend] {jlink_usb_001050351525} Speed info: JLINKARM_SPEED_INFO { SizeOfStruct: 12, BaseFreq: 128000000, MinDiv: 64, SupportAdaptive: 0 }
    [2026-07-08T07:58:54.288Z] [1546] DEBUG - [debug_probes::jlink] {jlink_usb_001050351525} Max frequency: 2000 kHz
    [2026-07-08T07:58:54.289Z] [1546] INFO - [debug_probes::jlink] {jlink_usb_001050351525} Clock frequency was set to 2000 kHz
    [2026-07-08T07:58:54.289Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} Retrieved J-Link firmware string: J-Link OB-nRF5340-NordicSemi compiled Jun 11 2026 13:12:28
    [2026-07-08T07:58:54.289Z] [1546] INFO - [debug_probes::jlink] {jlink_usb_001050351525} Emulator Usb(JLinkSerialNumber(1050351525)) running firmware: J-Link OB-nRF5340-NordicSemi compiled Jun 11 2026 13:12:28
    [2026-07-08T07:58:54.290Z] [1546] DEBUG - [debug_probes::jlink] {jlink_usb_001050351525} J-Link probe uptime: 105s
    [2026-07-08T07:58:54.290Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- connect
    [2026-07-08T07:58:54.290Z] [1546] INFO - [nrf_probe::probe_pool::plugin_worker] {jlink_usb_001050351525} <- create_probe
    [2026-07-08T07:58:54.290Z] [1546] INFO - [nrf_probe::probe_pool::worker] {jlink_usb_001050351525} <- handle_initialize
    [2026-07-08T07:58:54.291Z] [1546] DEBUG - [nrf_probe::probe_pool::worker] {jlink_usb_001050351525} Probe worker received message: Request { sequence_no: 0, request: Recover { core_id: Application, program_recovery_firmware_if_needed: true, erase_protect_key: None } }
    [2026-07-08T07:58:54.291Z] [1546] INFO - [nrf_probe::probe_pool::worker] {jlink_usb_001050351525} -> handle_message
    [2026-07-08T07:58:54.291Z] [1546] INFO - [nrf_probe::device_context] {jlink_usb_001050351525} -> get_or_create_opened_probe
    [2026-07-08T07:58:54.291Z] [1546] INFO - [nrf_probe::probe_state] {jlink_usb_001050351525} -> open_with_mode
    [2026-07-08T07:58:54.291Z] [1546] INFO - [debug_probes::jlink] {jlink_usb_001050351525} -> open_dap
    [2026-07-08T07:58:54.291Z] [1546] INFO - [jlink::backend] {jlink_usb_001050351525} -> get_hw_status
    [2026-07-08T07:58:54.292Z] [1546] INFO - [jlink::backend] {jlink_usb_001050351525} <- get_hw_status
    [2026-07-08T07:58:54.293Z] [1546] DEBUG - [debug_probes::jlink] {jlink_usb_001050351525} JLINKARM_HW_STATUS: JLINKARM_HW_STATUS { VTarget: 3300, tck: 0, tdi: 1, tdo: 1, tms: 1, tres: 1, trst: 255 }
    [2026-07-08T07:58:54.293Z] [1546] INFO - [jlink::backend] {jlink_usb_001050351525} -> coresight_configure
    [2026-07-08T07:58:54.293Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} CORESIGHT_Configure
    [2026-07-08T07:58:54.294Z] [1546] INFO - [jlink::backend] {jlink_usb_001050351525} <- coresight_configure
    [2026-07-08T07:58:54.294Z] [1546] INFO - [debug_probes::jlink] {jlink_usb_001050351525} <- open_dap
    [2026-07-08T07:58:54.294Z] [1546] INFO - [nrf_probe::probe_state] {jlink_usb_001050351525} -> Powering up sys and debug region
    [2026-07-08T07:58:54.294Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.294Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.295Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.295Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x00000000 to 0x08
    [2026-07-08T07:58:54.295Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.295Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_dp
    [2026-07-08T07:58:54.295Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.296Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.296Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from debug port: read 0xf0000000 from register CTRL/STAT
    [2026-07-08T07:58:54.296Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_dp
    [2026-07-08T07:58:54.296Z] [1546] DEBUG - [nrf_probe::probe_state] {jlink_usb_001050351525} Powered up sys and dbg regions in 1 ms
    [2026-07-08T07:58:54.296Z] [1546] INFO - [nrf_probe::probe_state] {jlink_usb_001050351525} <- Powering up sys and debug region
    [2026-07-08T07:58:54.296Z] [1546] INFO - [nrf_probe::probe_state] {jlink_usb_001050351525} <- open_with_mode
    [2026-07-08T07:58:54.296Z] [1546] INFO - [nrf_probe::device_context] {jlink_usb_001050351525} <- get_or_create_opened_probe
    [2026-07-08T07:58:54.297Z] [1546] INFO - [nrf_probe::device_operations::detect_device] {jlink_usb_001050351525} -> detect_device_with_options
    [2026-07-08T07:58:54.298Z] [1546] INFO - [nrf_probe::device_operations::detect_device] {jlink_usb_001050351525} -> detect device family
    [2026-07-08T07:58:54.298Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_dp
    [2026-07-08T07:58:54.298Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.299Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.299Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from debug port: read 0x2ba01477 from register DPIDR
    [2026-07-08T07:58:54.299Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_dp
    [2026-07-08T07:58:54.299Z] [1546] DEBUG - [nrf_probe::device_operations::detect_device] {jlink_usb_001050351525} DPIDR: Register { content: 731911287, revision: 2, part_no: 186, res0: 0, min: 0, version: 1, designer: 571, always_one: 1 }
    [2026-07-08T07:58:54.299Z] [1546] INFO - [nrf_probe::device_operations::detect_device] {jlink_usb_001050351525} <- detect device family
    [2026-07-08T07:58:54.299Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.299Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.299Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.300Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.300Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.300Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.300Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.301Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.301Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from CSW(mem-ap) or RESET(ctrl-ap)
    [2026-07-08T07:58:54.301Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.301Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.301Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.301Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.302Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.302Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x010000f0 to 0x08
    [2026-07-08T07:58:54.302Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.302Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.302Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.302Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x02880000 from IDR
    [2026-07-08T07:58:54.302Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.302Z] [1546] DEBUG - [nrf_probe::ctrl_ap] {jlink_usb_001050351525} Detected CTRL-AP revision 0 at access port 1
    [2026-07-08T07:58:54.302Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.302Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.302Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.303Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.303Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.303Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.303Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.304Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.304Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:58:54.304Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.304Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.304Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.304Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.305Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.305Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.305Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.305Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.306Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.306Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:58:54.306Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.306Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.306Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.306Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.307Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.307Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.307Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.307Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.308Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.308Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:58:54.308Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.308Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.308Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.308Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.309Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.309Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.309Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.309Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.310Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.310Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:58:54.310Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.310Z] [1546] WARN - [nrf_probe::device_operations::detect_device::nrf52] {jlink_usb_001050351525} AP-Protect is enabled, unable to read the device revision for nRF52. Returning only with the family
    [2026-07-08T07:58:54.310Z] [1546] INFO - [nrf_probe::device_operations::detect_device] {jlink_usb_001050351525} <- detect_device_with_options
    [2026-07-08T07:58:54.310Z] [1546] INFO - [nrf_probe::device_context] {jlink_usb_001050351525} -> get_or_create_opened_probe
    [2026-07-08T07:58:54.310Z] [1546] INFO - [nrf_probe::device_context] {jlink_usb_001050351525} <- get_or_create_opened_probe
    [2026-07-08T07:58:54.310Z] [1546] DEBUG - [nrf_probe::device_operations::ap_protection] {jlink_usb_001050351525} -> Get AP-Protect Status
    [2026-07-08T07:58:54.310Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.310Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.310Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.311Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.311Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.311Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.311Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.312Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.312Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from CSW(mem-ap) or RESET(ctrl-ap)
    [2026-07-08T07:58:54.312Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.312Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.312Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.312Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.313Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.313Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x010000f0 to 0x08
    [2026-07-08T07:58:54.313Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.313Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.313Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.313Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x02880000 from IDR
    [2026-07-08T07:58:54.313Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.313Z] [1546] DEBUG - [nrf_probe::ctrl_ap] {jlink_usb_001050351525} Detected CTRL-AP revision 0 at access port 1
    [2026-07-08T07:58:54.313Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.313Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.313Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.314Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.314Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.314Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.314Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.315Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.315Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:58:54.315Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.315Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.315Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.315Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.315Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.315Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.315Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.315Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.316Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.316Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:58:54.316Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.316Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.316Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.316Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.317Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.317Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.317Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.317Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.318Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.318Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:58:54.318Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.318Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.318Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.318Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.319Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.319Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.319Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.319Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.319Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.319Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:58:54.319Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.319Z] [1546] DEBUG - [nrf_probe::device_operations::ap_protection] {jlink_usb_001050351525} AP-Protect status is 'All'
    [2026-07-08T07:58:54.319Z] [1546] DEBUG - [nrf_probe::device_operations::ap_protection] {jlink_usb_001050351525} <- Get AP-Protect Status
    [2026-07-08T07:58:54.320Z] [1546] INFO - [nrf_probe::device_context] {jlink_usb_001050351525} -> get_or_create_opened_probe
    [2026-07-08T07:58:54.320Z] [1546] INFO - [nrf_probe::device_context] {jlink_usb_001050351525} <- get_or_create_opened_probe
    [2026-07-08T07:58:54.320Z] [1546] INFO - [nrf_probe::device_operations::detect_device] {jlink_usb_001050351525} -> detect_device_with_options
    [2026-07-08T07:58:54.320Z] [1546] INFO - [nrf_probe::device_operations::detect_device] {jlink_usb_001050351525} -> detect device family
    [2026-07-08T07:58:54.320Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_dp
    [2026-07-08T07:58:54.320Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.320Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.320Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from debug port: read 0x2ba01477 from register DPIDR
    [2026-07-08T07:58:54.320Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_dp
    [2026-07-08T07:58:54.320Z] [1546] DEBUG - [nrf_probe::device_operations::detect_device] {jlink_usb_001050351525} DPIDR: Register { content: 731911287, revision: 2, part_no: 186, res0: 0, min: 0, version: 1, designer: 571, always_one: 1 }
    [2026-07-08T07:58:54.320Z] [1546] INFO - [nrf_probe::device_operations::detect_device] {jlink_usb_001050351525} <- detect device family
    [2026-07-08T07:58:54.320Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.320Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.320Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.321Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.321Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.321Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.321Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.322Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.322Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from CSW(mem-ap) or RESET(ctrl-ap)
    [2026-07-08T07:58:54.322Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.322Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.322Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.322Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.323Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.323Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x010000f0 to 0x08
    [2026-07-08T07:58:54.323Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.323Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.324Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.324Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x02880000 from IDR
    [2026-07-08T07:58:54.324Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.324Z] [1546] DEBUG - [nrf_probe::ctrl_ap] {jlink_usb_001050351525} Detected CTRL-AP revision 0 at access port 1
    [2026-07-08T07:58:54.324Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.324Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.324Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.325Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.325Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.325Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.325Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.325Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.325Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:58:54.325Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.325Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.325Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.325Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.326Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.326Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.326Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.326Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.327Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.327Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:58:54.327Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.327Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.327Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.327Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.327Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.328Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.328Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.328Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.328Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.328Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:58:54.328Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.328Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.328Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.328Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.329Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.329Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.329Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.329Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.330Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.330Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:58:54.330Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.330Z] [1546] WARN - [nrf_probe::device_operations::detect_device::nrf52] {jlink_usb_001050351525} AP-Protect is enabled, unable to read the device revision for nRF52. Returning only with the family
    [2026-07-08T07:58:54.330Z] [1546] INFO - [nrf_probe::device_operations::detect_device] {jlink_usb_001050351525} <- detect_device_with_options
    [2026-07-08T07:58:54.330Z] [1546] INFO - [nrf_probe::device_context] {jlink_usb_001050351525} -> get_or_create_opened_probe
    [2026-07-08T07:58:54.330Z] [1546] INFO - [nrf_probe::device_context] {jlink_usb_001050351525} <- get_or_create_opened_probe
    [2026-07-08T07:58:54.330Z] [1546] INFO - [nrf_probe::device_operations::detect_device] {jlink_usb_001050351525} -> detect_device_with_options
    [2026-07-08T07:58:54.330Z] [1546] INFO - [nrf_probe::device_operations::detect_device] {jlink_usb_001050351525} -> detect device family
    [2026-07-08T07:58:54.330Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_dp
    [2026-07-08T07:58:54.330Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.330Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from debug port: read 0x2ba01477 from register DPIDR
    [2026-07-08T07:58:54.330Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_dp
    [2026-07-08T07:58:54.330Z] [1546] DEBUG - [nrf_probe::device_operations::detect_device] {jlink_usb_001050351525} DPIDR: Register { content: 731911287, revision: 2, part_no: 186, res0: 0, min: 0, version: 1, designer: 571, always_one: 1 }
    [2026-07-08T07:58:54.330Z] [1546] INFO - [nrf_probe::device_operations::detect_device] {jlink_usb_001050351525} <- detect device family
    [2026-07-08T07:58:54.330Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.330Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.330Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.331Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.331Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.331Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.331Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.332Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.332Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from CSW(mem-ap) or RESET(ctrl-ap)
    [2026-07-08T07:58:54.332Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.332Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.332Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.332Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.332Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.332Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x010000f0 to 0x08
    [2026-07-08T07:58:54.332Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.332Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.333Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.333Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x02880000 from IDR
    [2026-07-08T07:58:54.333Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.333Z] [1546] DEBUG - [nrf_probe::ctrl_ap] {jlink_usb_001050351525} Detected CTRL-AP revision 0 at access port 1
    [2026-07-08T07:58:54.333Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.333Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.333Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.334Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.334Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.334Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.334Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.334Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.334Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:58:54.334Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.334Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.334Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.334Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.335Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.335Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.335Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.335Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.336Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.336Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:58:54.336Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.336Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.336Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.336Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.336Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.336Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.336Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.336Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.337Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.337Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:58:54.337Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.337Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.337Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.337Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.338Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.338Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.338Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.338Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.338Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.338Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:58:54.338Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.338Z] [1546] WARN - [nrf_probe::device_operations::detect_device::nrf52] {jlink_usb_001050351525} AP-Protect is enabled, unable to read the device revision for nRF52. Returning only with the family
    [2026-07-08T07:58:54.338Z] [1546] INFO - [nrf_probe::device_operations::detect_device] {jlink_usb_001050351525} <- detect_device_with_options
    [2026-07-08T07:58:54.338Z] [1546] INFO - [nrf_probe::device_context] {jlink_usb_001050351525} -> get_or_create_opened_probe
    [2026-07-08T07:58:54.338Z] [1546] INFO - [nrf_probe::device_context] {jlink_usb_001050351525} <- get_or_create_opened_probe
    [2026-07-08T07:58:54.338Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.338Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.339Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.339Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.339Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.339Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.339Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.340Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.340Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from CSW(mem-ap) or RESET(ctrl-ap)
    [2026-07-08T07:58:54.340Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.340Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.340Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.340Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.340Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.340Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x010000f0 to 0x08
    [2026-07-08T07:58:54.340Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.340Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.341Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.341Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x02880000 from IDR
    [2026-07-08T07:58:54.341Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:54.341Z] [1546] DEBUG - [nrf_probe::ctrl_ap] {jlink_usb_001050351525} Detected CTRL-AP revision 0 at access port 1
    [2026-07-08T07:58:54.341Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_ap
    [2026-07-08T07:58:54.341Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.341Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.342Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.342Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.342Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.342Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.342Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to access port 1: Write 0x00000001 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2026-07-08T07:58:54.342Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_ap
    [2026-07-08T07:58:54.342Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:58:54.843Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:58:54.843Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:54.843Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:54.843Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:54.845Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:54.846Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:54.846Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:54.846Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:54.848Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:54.848Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:58:54.848Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:55.348Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:58:55.348Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:55.348Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:55.348Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:55.353Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:55.353Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:55.353Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:55.353Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:55.354Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:55.354Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:58:55.354Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:55.855Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:58:55.855Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:55.855Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:55.855Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:55.857Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:55.857Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:55.857Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:55.857Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:55.860Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:55.860Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:58:55.860Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:56.360Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:58:56.360Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:56.360Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:56.360Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:56.363Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:56.364Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:56.364Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:56.364Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:56.367Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:56.367Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:58:56.367Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:56.867Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:56.867Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:58:56.867Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:56.867Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:56.869Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:56.869Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:56.869Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:56.869Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:56.870Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:56.870Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:58:56.870Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:57.370Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:58:57.370Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:57.370Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:57.370Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:57.371Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:57.371Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:57.371Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:57.371Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:57.372Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:57.372Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:58:57.372Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:57.873Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:58:57.873Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:57.873Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:57.873Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:57.874Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:57.874Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:57.874Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:57.874Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:57.876Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:57.877Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:58:57.877Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:58.377Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:58:58.377Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:58.377Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:58.377Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:58.381Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:58.381Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:58.381Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:58.381Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:58.383Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:58.383Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:58:58.383Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:58.883Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:58:58.883Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:58.883Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:58.883Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:58.888Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:58.888Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:58.888Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:58.888Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:58.890Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:58.890Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:58:58.890Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:59.391Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:58:59.390Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:59.390Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:59.390Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:59.392Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:59.392Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:59.392Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:59.392Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:59.394Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:59.394Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:58:59.394Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:58:59.894Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:58:59.895Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:58:59.894Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:58:59.894Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:58:59.898Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:58:59.898Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:58:59.898Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:58:59.898Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:58:59.900Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:58:59.900Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:58:59.900Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:00.401Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:00.402Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:00.401Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:00.401Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:00.405Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:00.405Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:00.405Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:00.405Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:00.408Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:00.408Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:00.409Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:00.909Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:00.909Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:00.909Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:00.909Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:00.911Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:00.912Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:00.912Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:00.912Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:00.913Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:00.913Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:00.913Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:01.414Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:01.414Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:01.414Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:01.414Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:01.415Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:01.415Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:01.415Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:01.416Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:01.417Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:01.417Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:01.417Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:01.918Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:01.917Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:01.917Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:01.918Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:01.919Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:01.919Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:01.919Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:01.919Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:01.920Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:01.920Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:01.920Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:02.421Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:02.421Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:02.421Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:02.421Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:02.423Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:02.423Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:02.423Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:02.423Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:02.425Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:02.425Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:02.425Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:02.926Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:02.926Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:02.926Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:02.926Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:02.929Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:02.929Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:02.929Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:02.929Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:02.931Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:02.931Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:02.931Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:03.432Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:03.431Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:03.431Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:03.431Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:03.435Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:03.435Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:03.435Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:03.435Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:03.437Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:03.437Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:03.437Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:03.937Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:03.937Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:03.937Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:03.937Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:03.940Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:03.940Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:03.940Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:03.940Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:03.941Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:03.941Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:03.941Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:04.441Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:04.441Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:04.441Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:04.441Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:04.442Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:04.443Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:04.443Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:04.443Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:04.444Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:04.444Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:04.444Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:04.945Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:04.944Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:04.945Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:04.945Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:04.948Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:04.948Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:04.948Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:04.948Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:04.951Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:04.951Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:04.951Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:05.451Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:05.451Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:05.451Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:05.451Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:05.455Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:05.455Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:05.455Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:05.455Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:05.458Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:05.458Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:05.458Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:05.958Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:05.958Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:05.958Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:05.958Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:05.960Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:05.960Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:05.960Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:05.960Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:05.961Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:05.961Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:05.961Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:06.461Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:06.461Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:06.461Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:06.461Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:06.463Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:06.463Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:06.463Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:06.463Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:06.465Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:06.465Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:06.465Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:06.965Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:06.965Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:06.965Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:06.965Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:06.967Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:06.967Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:06.967Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:06.967Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:06.969Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:06.969Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:06.969Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:07.470Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:07.470Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:07.470Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:07.470Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:07.472Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:07.472Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:07.472Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:07.472Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:07.475Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:07.475Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:07.475Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:07.977Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:07.976Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:07.977Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:07.977Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:07.979Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:07.979Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:07.979Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:07.979Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:07.981Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:07.981Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:07.981Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:08.482Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:08.481Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:08.482Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:08.482Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:08.484Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:08.484Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:08.484Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:08.484Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:08.485Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:08.485Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:08.485Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:08.986Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:08.986Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:08.986Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:08.986Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:08.990Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:08.990Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:08.990Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:08.990Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:08.992Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:08.992Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:08.992Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:09.493Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:09.493Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:09.493Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:09.493Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:09.495Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:09.496Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:09.496Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:09.496Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:09.499Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:09.499Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:09.499Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:10.000Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:10.000Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:10.000Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:10.000Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:10.002Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:10.002Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:10.002Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:10.003Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:10.006Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:10.006Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:10.006Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:10.507Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:10.507Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:10.507Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:10.508Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:10.509Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:10.509Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:10.509Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:10.509Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:10.511Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:10.511Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:10.511Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:11.011Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:11.011Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:11.011Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:11.011Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:11.014Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:11.014Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:11.014Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:11.014Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:11.015Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:11.015Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:11.015Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:11.516Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:11.515Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:11.516Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:11.516Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:11.517Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:11.517Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:11.517Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:11.517Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:11.520Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:11.520Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:11.520Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:12.021Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:12.021Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:12.021Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:12.021Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:12.025Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:12.025Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:12.025Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:12.025Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:12.027Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:12.027Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:12.027Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:12.527Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:12.527Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:12.527Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:12.527Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:12.529Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:12.529Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:12.529Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:12.529Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:12.530Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:12.530Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:12.530Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:13.031Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:13.031Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:13.031Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:13.031Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:13.034Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:13.034Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:13.034Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:13.034Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:13.036Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:13.036Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:13.036Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:13.536Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:13.536Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:13.536Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:13.536Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:13.537Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:13.537Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:13.537Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:13.537Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:13.538Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:13.538Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:13.538Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:14.039Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:14.039Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:14.039Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:14.039Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:14.045Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:14.045Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:14.045Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:14.045Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:14.047Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:14.047Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:14.047Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:14.547Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:14.547Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:14.547Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:14.547Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:14.548Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:14.548Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:14.548Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:14.548Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:14.549Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:14.549Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:14.549Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:15.050Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:15.050Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:15.050Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:15.050Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:15.057Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:15.057Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:15.057Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:15.057Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:15.060Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:15.060Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:15.060Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:15.561Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:15.561Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:15.561Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:15.561Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:15.562Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:15.562Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:15.562Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:15.562Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:15.563Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:15.563Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:15.564Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:16.064Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:16.064Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:16.064Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:16.064Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:16.067Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:16.067Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:16.067Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:16.067Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:16.069Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:16.069Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:16.069Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:16.569Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:16.569Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:16.569Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:16.569Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:16.571Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:16.571Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:16.571Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:16.571Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:16.572Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:16.572Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:16.572Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:17.073Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:17.073Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:17.073Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:17.073Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:17.075Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:17.075Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:17.075Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:17.075Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:17.077Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:17.077Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:17.077Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:17.578Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:17.578Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:17.578Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:17.578Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:17.579Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:17.579Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:17.579Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:17.579Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:17.582Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:17.582Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:17.582Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:18.082Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:18.082Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:18.082Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:18.082Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:18.083Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:18.083Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:18.083Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:18.083Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:18.086Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:18.086Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:18.086Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:18.586Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:18.586Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:18.586Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:18.586Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:18.588Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:18.588Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:18.588Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:18.588Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:18.589Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:18.589Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:18.589Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:19.090Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:19.090Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:19.090Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:19.090Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:19.094Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:19.094Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:19.094Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:19.094Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:19.095Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:19.095Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:19.095Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:19.596Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:19.596Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:19.596Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:19.596Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:19.598Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:19.598Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:19.598Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:19.598Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:19.599Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:19.600Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:19.600Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:20.100Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:20.100Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:20.100Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:20.100Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:20.101Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:20.101Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:20.101Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:20.101Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:20.103Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:20.103Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:20.103Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:20.603Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:20.603Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:20.603Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:20.603Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:20.604Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:20.604Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:20.604Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:20.604Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:20.605Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:20.605Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:20.605Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:21.105Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:21.105Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:21.105Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:21.105Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:21.109Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:21.109Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:21.109Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:21.109Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:21.111Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:21.111Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:21.111Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:21.611Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:21.611Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:21.611Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:21.611Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:21.612Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:21.613Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:21.613Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:21.613Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:21.614Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:21.614Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:21.614Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:22.115Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:22.115Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:22.115Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:22.115Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:22.119Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:22.119Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:22.119Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:22.119Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:22.122Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:22.122Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:22.122Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:22.623Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:22.623Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:22.623Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:22.623Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:22.625Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:22.625Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:22.625Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:22.625Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:22.626Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:22.626Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:22.626Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:23.127Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:23.127Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:23.127Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:23.127Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:23.131Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:23.131Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:23.131Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:23.131Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:23.133Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:23.133Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:23.133Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:23.634Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:23.634Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:23.634Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:23.634Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:23.635Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:23.635Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:23.635Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:23.635Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:23.636Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:23.636Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:23.636Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:24.137Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:24.137Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:24.137Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:24.137Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:24.139Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:24.139Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:24.139Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:24.139Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:24.140Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:24.140Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:24.140Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:24.641Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:24.641Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:24.641Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:24.641Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:24.645Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:24.645Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:24.645Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:24.645Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:24.646Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:24.646Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:24.646Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:25.147Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:25.147Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:25.147Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:25.147Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:25.149Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:25.149Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:25.149Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:25.149Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:25.150Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:25.150Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:25.150Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:25.651Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:25.651Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:25.651Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:25.651Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:25.654Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:25.654Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:25.654Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:25.654Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:25.657Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:25.657Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:25.657Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:26.157Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:26.157Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:26.157Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:26.157Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:26.159Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:26.159Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:26.159Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:26.159Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:26.161Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:26.161Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:26.161Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:26.661Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:26.661Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:26.661Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:26.661Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:26.662Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:26.662Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:26.662Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:26.662Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:26.663Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:26.664Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:26.664Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:27.164Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:27.164Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:27.164Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:27.164Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:27.166Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:27.166Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:27.166Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:27.166Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:27.167Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:27.167Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:27.167Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:27.668Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:27.668Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:27.668Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:27.668Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:27.670Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:27.670Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:27.670Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:27.670Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:27.672Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:27.672Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:27.672Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:28.173Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:28.172Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:28.173Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:28.173Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:28.176Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:28.176Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:28.176Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:28.176Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:28.177Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:28.177Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:28.178Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:28.678Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:28.678Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:28.678Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:28.678Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:28.680Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:28.680Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:28.680Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:28.680Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:28.681Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:28.681Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:28.681Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:29.182Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:29.182Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:29.182Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:29.182Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:29.183Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:29.183Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:29.183Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:29.183Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:29.185Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:29.185Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:29.185Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:29.685Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:29.685Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:29.685Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:29.685Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:29.687Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:29.687Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:29.687Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:29.687Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:29.691Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:29.691Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:29.691Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:30.191Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:30.191Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:30.191Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:30.191Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:30.195Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:30.195Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:30.195Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:30.195Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:30.197Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:30.197Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:30.197Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:30.698Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:30.698Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:30.698Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:30.698Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:30.701Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:30.701Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:30.701Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:30.701Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:30.702Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:30.702Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:30.703Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:31.203Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:31.203Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:31.203Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:31.203Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:31.205Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:31.205Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:31.205Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:31.205Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:31.207Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:31.207Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:31.207Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:31.708Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:31.708Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:31.708Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:31.708Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:31.711Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:31.711Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:31.711Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:31.711Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:31.713Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:31.713Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:31.713Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:32.213Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:32.213Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:32.213Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:32.213Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:32.216Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:32.216Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:32.216Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:32.216Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:32.218Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:32.218Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:32.218Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:32.719Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:32.719Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:32.719Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:32.719Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:32.723Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:32.723Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:32.723Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:32.723Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:32.725Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:32.725Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:32.725Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:33.226Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:33.226Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:33.226Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:33.226Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:33.228Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:33.228Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:33.228Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:33.228Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:33.231Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:33.231Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:33.231Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:33.731Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:33.731Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:33.731Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:33.731Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:33.734Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:33.734Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:33.734Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:33.734Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:33.735Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:33.735Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:33.735Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:34.235Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:34.235Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:34.235Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:34.235Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:34.238Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:34.238Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:34.238Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:34.238Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:34.241Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:34.241Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:34.241Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:34.741Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:34.741Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:34.741Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:34.741Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:34.743Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:34.743Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:34.743Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:34.743Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:34.745Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:34.745Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:34.745Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:34.745Z] [1546] WARN - [nrf_probe::device_operations::ap_protection] {jlink_usb_001050351525} Failed CTRL-AP erase when unprotecting nRF52 device:  Timed out erasing flash
    [2026-07-08T07:59:34.745Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_ap
    [2026-07-08T07:59:34.745Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:34.745Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:34.747Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:34.747Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:34.747Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:34.747Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:34.749Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:34.749Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to access port 1: Write 0x00000001 to CSW(mem-ap) or RESET(ctrl-ap)
    [2026-07-08T07:59:34.749Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_ap
    [2026-07-08T07:59:34.759Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_ap
    [2026-07-08T07:59:34.759Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:34.759Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:34.763Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:34.763Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:34.763Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:34.763Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:34.765Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:34.765Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to access port 1: Write 0x00000000 to CSW(mem-ap) or RESET(ctrl-ap)
    [2026-07-08T07:59:34.765Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_ap
    [2026-07-08T07:59:34.765Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_ap
    [2026-07-08T07:59:34.765Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:34.765Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:34.766Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:34.766Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:34.766Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:34.766Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:34.767Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:34.768Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to access port 1: Write 0x00000000 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2026-07-08T07:59:34.768Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_ap
    [2026-07-08T07:59:34.819Z] [1546] DEBUG - [nrf_probe::device_operations::ap_protection] {jlink_usb_001050351525} -> Get AP-Protect Status
    [2026-07-08T07:59:34.819Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:34.819Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:34.819Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:34.822Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:34.822Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:34.822Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:34.822Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:34.824Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:34.824Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from CSW(mem-ap) or RESET(ctrl-ap)
    [2026-07-08T07:59:34.824Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:34.824Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:34.824Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:34.824Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:34.826Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:34.826Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x010000f0 to 0x08
    [2026-07-08T07:59:34.826Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:34.826Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:34.828Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:34.828Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x02880000 from IDR
    [2026-07-08T07:59:34.828Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:34.828Z] [1546] DEBUG - [nrf_probe::ctrl_ap] {jlink_usb_001050351525} Detected CTRL-AP revision 0 at access port 1
    [2026-07-08T07:59:34.828Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:34.828Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:34.828Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:34.830Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:34.830Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:34.830Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:34.830Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:34.832Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:34.832Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:59:34.832Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:34.832Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:34.832Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:34.832Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:34.834Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:34.834Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:34.834Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:34.834Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:34.835Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:34.835Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:59:34.835Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:34.835Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:34.835Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:34.835Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:34.836Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:34.836Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:34.836Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:34.837Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:34.838Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:34.838Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:59:34.838Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:34.838Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:34.838Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:34.838Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:34.839Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:34.839Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:34.839Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:34.839Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:34.841Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:34.841Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:34.841Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T07:59:34.841Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:34.841Z] [1546] DEBUG - [nrf_probe::device_operations::ap_protection] {jlink_usb_001050351525} AP-Protect status is 'All'
    [2026-07-08T07:59:34.841Z] [1546] DEBUG - [nrf_probe::device_operations::ap_protection] {jlink_usb_001050351525} <- Get AP-Protect Status
    [2026-07-08T07:59:34.841Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_ap
    [2026-07-08T07:59:34.841Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:34.841Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:34.842Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:34.842Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:34.842Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:34.842Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:34.844Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:34.844Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to access port 1: Write 0x00000001 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2026-07-08T07:59:34.844Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_ap
    [2026-07-08T07:59:34.844Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:35.344Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:35.344Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:35.344Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:35.344Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:35.347Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:35.347Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:35.347Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:35.347Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:35.350Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:35.350Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:35.350Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:35.850Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:35.850Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:35.850Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:35.850Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:35.854Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:35.854Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:35.854Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:35.854Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:35.856Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:35.856Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:35.856Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:36.356Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:36.356Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:36.356Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:36.356Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:36.359Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:36.359Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:36.359Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:36.359Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:36.360Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:36.361Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:36.361Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:36.861Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:36.861Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:36.861Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:36.861Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:36.863Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:36.863Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:36.863Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:36.863Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:36.865Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:36.865Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:36.865Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:37.366Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:37.365Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:37.365Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:37.365Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:37.368Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:37.368Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:37.368Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:37.368Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:37.370Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:37.371Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:37.371Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:37.871Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:37.871Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:37.871Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:37.871Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:37.873Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:37.873Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:37.873Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:37.873Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:37.874Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:37.874Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:37.874Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:38.375Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:38.375Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:38.375Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:38.375Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:38.376Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:38.376Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:38.376Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:38.376Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:38.377Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:38.377Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:38.377Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:38.878Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:38.878Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:38.878Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:38.878Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:38.881Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:38.881Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:38.881Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:38.881Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:38.883Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:38.883Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:38.883Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:39.384Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:39.383Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:39.383Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:39.383Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:39.386Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:39.386Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:39.386Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:39.386Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:39.389Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:39.389Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:39.389Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:39.890Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:39.890Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:39.890Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:39.890Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:39.892Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:39.892Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:39.892Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:39.892Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:39.893Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:39.894Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:39.894Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:40.394Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:40.394Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:40.394Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:40.394Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:40.397Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:40.397Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:40.397Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:40.397Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:40.399Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:40.399Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:40.399Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:40.899Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:40.899Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:40.899Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:40.899Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:40.901Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:40.901Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:40.901Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:40.901Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:40.903Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:40.903Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:40.903Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:41.403Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:41.403Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:41.403Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:41.403Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:41.405Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:41.405Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:41.405Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:41.405Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:41.407Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:41.407Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:41.407Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:41.907Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:41.907Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:41.907Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:41.907Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:41.910Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:41.910Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:41.910Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:41.910Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:41.912Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:41.912Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:41.912Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:42.413Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:42.412Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:42.412Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:42.412Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:42.414Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:42.414Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:42.414Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:42.414Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:42.415Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:42.415Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:42.415Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:42.915Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:42.915Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:42.915Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:42.915Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:42.919Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:42.919Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:42.919Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:42.919Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:42.920Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:42.920Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:42.920Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:43.421Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:43.421Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:43.421Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:43.421Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:43.423Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:43.423Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:43.423Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:43.423Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:43.425Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:43.425Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:43.425Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:43.925Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:43.925Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:43.925Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:43.925Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:43.929Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:43.930Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:43.930Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:43.930Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:43.931Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:43.931Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:43.931Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:44.432Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:44.432Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:44.432Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:44.432Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:44.435Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:44.435Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:44.435Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:44.435Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:44.438Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:44.438Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:44.438Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:44.939Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:44.938Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:44.939Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:44.939Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:44.941Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:44.941Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:44.941Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:44.941Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:44.943Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:44.943Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:44.943Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:45.443Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:45.443Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:45.443Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:45.443Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:45.445Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:45.445Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:45.445Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:45.445Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:45.446Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:45.446Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:45.446Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:45.947Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:45.947Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:45.947Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:45.947Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:45.948Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:45.948Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:45.948Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:45.948Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:45.949Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:45.949Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:45.949Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:46.449Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:46.449Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:46.449Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:46.449Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:46.451Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:46.451Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:46.451Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:46.451Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:46.453Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:46.453Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:46.453Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:46.954Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:46.954Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:46.954Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:46.954Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:46.957Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:46.957Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:46.957Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:46.957Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:46.959Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:46.959Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:46.959Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:47.460Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:47.460Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:47.460Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:47.460Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:47.463Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:47.463Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:47.463Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:47.463Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:47.464Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:47.464Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:47.464Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:47.965Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:47.965Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:47.965Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:47.965Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:47.967Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:47.967Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:47.967Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:47.967Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:47.970Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:47.970Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:47.970Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:48.470Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:48.470Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:48.470Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:48.470Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:48.472Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:48.472Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:48.472Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:48.472Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:48.474Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:48.474Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:48.474Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:48.975Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:48.975Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:48.975Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:48.975Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:48.978Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:48.978Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:48.978Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:48.978Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:48.980Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:48.980Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:48.980Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:49.481Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:49.480Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:49.480Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:49.480Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:49.483Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:49.483Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:49.483Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:49.483Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:49.487Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:49.487Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:49.487Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:49.987Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:49.987Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:49.987Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:49.987Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:49.989Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:49.989Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:49.989Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:49.989Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:49.990Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:49.990Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:49.990Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:50.491Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:50.491Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:50.491Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:50.491Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:50.493Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:50.494Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:50.494Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:50.494Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:50.496Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:50.496Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:50.496Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:50.996Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:50.996Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:50.996Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:50.996Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:50.998Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:50.998Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:50.998Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:50.998Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:51.001Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:51.001Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:51.001Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:51.502Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:51.501Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:51.502Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:51.502Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:51.505Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:51.505Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:51.505Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:51.505Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:51.506Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:51.506Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:51.506Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:52.007Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:52.007Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:52.007Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:52.007Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:52.009Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:52.009Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:52.010Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:52.010Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:52.012Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:52.012Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:52.012Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:52.512Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:52.512Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:52.512Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:52.512Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:52.514Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:52.514Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:52.514Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:52.514Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:52.515Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:52.515Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:52.515Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:53.017Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:53.016Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:53.016Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:53.016Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:53.020Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:53.020Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:53.020Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:53.020Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:53.022Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:53.022Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:53.022Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:53.523Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:53.523Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:53.523Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:53.523Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:53.525Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:53.525Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:53.525Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:53.525Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:53.528Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:53.528Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:53.528Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:54.028Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:54.028Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:54.028Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:54.029Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:54.031Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:54.031Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:54.031Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:54.031Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:54.033Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:54.033Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:54.033Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:54.534Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:54.534Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:54.534Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:54.534Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:54.535Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:54.535Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:54.535Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:54.535Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:54.537Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:54.537Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:54.537Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:55.038Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:55.038Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:55.038Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:55.038Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:55.040Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:55.040Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:55.040Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:55.040Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:55.043Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:55.043Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:55.043Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:55.543Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:55.543Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:55.543Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:55.543Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:55.546Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:55.546Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:55.546Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:55.546Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:55.548Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:55.549Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:55.549Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:56.049Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:56.049Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:56.049Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:56.049Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:56.052Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:56.052Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:56.052Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:56.052Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:56.053Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:56.054Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:56.054Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:56.554Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:56.554Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:56.554Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:56.554Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:56.557Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:56.557Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:56.557Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:56.557Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:56.559Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:56.559Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:56.559Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:57.059Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:57.059Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:57.059Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:57.059Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:57.062Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:57.062Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:57.062Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:57.062Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:57.063Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:57.063Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:57.063Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:57.563Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:57.563Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:57.563Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:57.563Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:57.565Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:57.565Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:57.565Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:57.565Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:57.566Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:57.566Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:57.566Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:58.067Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:58.067Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:58.067Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:58.067Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:58.069Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:58.069Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:58.069Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:58.069Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:58.071Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:58.071Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:58.071Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:58.571Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:58.571Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:58.571Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:58.571Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:58.573Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:58.573Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:58.573Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:58.573Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:58.575Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:58.575Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:58.575Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:59.076Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:59.076Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:59.076Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:59.076Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:59.077Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:59.077Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:59.077Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:59.077Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:59.079Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:59.079Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:59.079Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T07:59:59.579Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T07:59:59.579Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T07:59:59.579Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T07:59:59.579Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T07:59:59.582Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T07:59:59.582Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T07:59:59.582Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T07:59:59.582Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T07:59:59.583Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T07:59:59.583Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T07:59:59.583Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:00.084Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:00.084Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:00.084Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:00.084Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:00.086Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:00.086Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:00.086Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:00.086Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:00.087Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:00.087Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:00.087Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:00.588Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:00.588Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:00.588Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:00.588Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:00.591Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:00.591Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:00.591Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:00.591Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:00.593Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:00.593Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:00.593Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:01.094Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:01.093Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:01.094Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:01.094Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:01.096Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:01.096Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:01.096Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:01.096Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:01.098Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:01.098Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:01.098Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:01.599Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:01.598Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:01.599Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:01.599Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:01.601Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:01.601Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:01.601Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:01.601Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:01.603Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:01.603Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:01.603Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:02.103Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:02.103Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:02.103Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:02.103Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:02.105Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:02.105Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:02.105Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:02.105Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:02.110Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:02.110Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:02.110Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:02.610Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:02.610Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:02.610Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:02.610Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:02.612Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:02.612Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:02.612Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:02.612Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:02.613Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:02.613Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:02.613Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:03.114Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:03.114Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:03.114Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:03.114Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:03.117Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:03.117Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:03.117Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:03.117Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:03.119Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:03.119Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:03.119Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:03.619Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:03.620Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:03.619Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:03.619Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:03.624Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:03.624Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:03.624Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:03.624Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:03.626Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:03.626Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:03.626Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:04.126Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:04.126Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:04.126Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:04.126Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:04.127Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:04.127Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:04.127Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:04.127Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:04.130Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:04.130Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:04.131Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:04.631Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:04.631Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:04.631Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:04.631Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:04.633Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:04.634Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:04.634Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:04.634Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:04.635Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:04.635Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:04.635Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:05.135Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:05.135Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:05.135Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:05.135Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:05.136Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:05.136Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:05.136Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:05.136Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:05.138Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:05.138Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:05.138Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:05.638Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:05.638Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:05.638Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:05.638Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:05.639Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:05.639Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:05.639Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:05.639Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:05.640Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:05.640Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:05.640Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:06.140Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:06.140Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:06.140Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:06.140Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:06.142Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:06.142Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:06.142Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:06.142Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:06.143Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:06.143Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:06.143Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:06.644Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:06.644Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:06.644Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:06.644Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:06.645Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:06.645Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:06.645Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:06.645Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:06.646Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:06.646Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:06.646Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:07.146Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:07.146Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:07.146Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:07.146Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:07.148Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:07.148Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:07.148Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:07.148Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:07.149Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:07.149Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:07.149Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:07.649Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:07.649Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:07.649Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:07.649Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:07.651Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:07.651Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:07.651Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:07.651Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:07.652Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:07.652Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:07.652Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:08.153Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:08.153Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:08.153Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:08.153Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:08.155Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:08.155Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:08.155Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:08.155Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:08.158Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:08.158Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:08.158Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:08.658Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:08.658Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:08.658Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:08.658Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:08.659Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:08.659Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:08.659Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:08.659Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:08.660Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:08.660Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:08.660Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:09.161Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:09.161Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:09.161Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:09.161Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:09.162Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:09.162Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:09.162Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:09.162Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:09.163Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:09.163Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:09.163Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:09.663Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:09.663Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:09.663Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:09.663Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:09.664Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:09.665Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:09.665Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:09.665Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:09.666Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:09.666Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:09.666Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:10.166Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:10.166Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:10.166Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:10.166Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:10.167Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:10.167Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:10.167Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:10.167Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:10.168Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:10.168Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:10.168Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:10.669Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:10.668Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:10.669Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:10.669Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:10.670Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:10.670Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:10.670Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:10.670Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:10.671Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:10.671Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:10.671Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:11.171Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:11.171Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:11.171Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:11.171Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:11.172Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:11.172Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:11.172Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:11.172Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:11.173Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:11.173Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:11.173Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:11.673Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:11.673Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:11.673Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:11.673Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:11.674Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:11.674Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:11.674Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:11.674Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:11.675Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:11.675Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:11.675Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:12.176Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:12.176Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:12.176Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:12.176Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:12.178Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:12.178Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:12.178Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:12.178Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:12.180Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:12.180Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:12.180Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:12.680Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:12.680Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:12.680Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:12.680Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:12.681Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:12.681Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:12.681Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:12.681Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:12.682Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:12.683Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:12.683Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:13.183Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:13.183Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:13.183Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:13.183Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:13.187Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:13.187Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:13.188Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:13.188Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:13.190Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:13.190Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:13.190Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:13.690Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:13.690Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:13.690Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:13.690Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:13.692Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:13.692Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:13.692Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:13.692Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:13.694Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:13.694Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:13.694Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:14.195Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:14.195Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:14.195Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:14.195Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:14.197Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:14.197Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:14.197Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:14.197Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:14.199Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:14.199Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:14.199Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:14.699Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:14.699Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:14.699Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:14.699Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:14.702Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:14.702Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:14.702Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:14.702Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:14.704Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:14.704Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:14.704Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:15.205Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:15.204Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:15.204Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:15.204Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:15.206Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:15.206Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:15.206Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:15.206Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:15.207Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:15.207Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:15.207Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:15.207Z] [1546] WARN - [nrf_probe::device_operations::ap_protection] {jlink_usb_001050351525} Failed CTRL-AP erase when unprotecting nRF52 device:  Timed out erasing flash
    [2026-07-08T08:00:15.207Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_ap
    [2026-07-08T08:00:15.207Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:15.207Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:15.208Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:15.208Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:15.208Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:15.208Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:15.209Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:15.209Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to access port 1: Write 0x00000001 to CSW(mem-ap) or RESET(ctrl-ap)
    [2026-07-08T08:00:15.209Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_ap
    [2026-07-08T08:00:15.219Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_ap
    [2026-07-08T08:00:15.219Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:15.219Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:15.220Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:15.220Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:15.220Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:15.220Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:15.222Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:15.222Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to access port 1: Write 0x00000000 to CSW(mem-ap) or RESET(ctrl-ap)
    [2026-07-08T08:00:15.222Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_ap
    [2026-07-08T08:00:15.222Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_ap
    [2026-07-08T08:00:15.222Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:15.222Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:15.223Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:15.223Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:15.223Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:15.223Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:15.225Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:15.225Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to access port 1: Write 0x00000000 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2026-07-08T08:00:15.225Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_ap
    [2026-07-08T08:00:15.275Z] [1546] DEBUG - [nrf_probe::device_operations::ap_protection] {jlink_usb_001050351525} -> Get AP-Protect Status
    [2026-07-08T08:00:15.275Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:15.275Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:15.275Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:15.279Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:15.279Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:15.279Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:15.279Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:15.282Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:15.282Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from CSW(mem-ap) or RESET(ctrl-ap)
    [2026-07-08T08:00:15.282Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:15.282Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:15.282Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:15.282Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:15.285Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:15.285Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x010000f0 to 0x08
    [2026-07-08T08:00:15.285Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:15.285Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:15.286Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:15.286Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x02880000 from IDR
    [2026-07-08T08:00:15.286Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:15.286Z] [1546] DEBUG - [nrf_probe::ctrl_ap] {jlink_usb_001050351525} Detected CTRL-AP revision 0 at access port 1
    [2026-07-08T08:00:15.286Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:15.286Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:15.286Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:15.287Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:15.287Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:15.287Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:15.287Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:15.288Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:15.288Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T08:00:15.288Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:15.288Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:15.288Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:15.288Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:15.289Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:15.289Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:15.289Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:15.289Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:15.290Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:15.290Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T08:00:15.290Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:15.290Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:15.290Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:15.290Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:15.291Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:15.291Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:15.291Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:15.291Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:15.292Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:15.292Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T08:00:15.292Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:15.292Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:15.292Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:15.292Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:15.294Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:15.294Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:15.295Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:15.295Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:15.297Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:15.298Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:15.298Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T08:00:15.298Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:15.298Z] [1546] DEBUG - [nrf_probe::device_operations::ap_protection] {jlink_usb_001050351525} AP-Protect status is 'All'
    [2026-07-08T08:00:15.298Z] [1546] DEBUG - [nrf_probe::device_operations::ap_protection] {jlink_usb_001050351525} <- Get AP-Protect Status
    [2026-07-08T08:00:15.298Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_ap
    [2026-07-08T08:00:15.298Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:15.298Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:15.299Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:15.299Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:15.299Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:15.299Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:15.300Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:15.300Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to access port 1: Write 0x00000001 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2026-07-08T08:00:15.300Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_ap
    [2026-07-08T08:00:15.300Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:15.801Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:15.801Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:15.801Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:15.801Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:15.802Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:15.802Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:15.802Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:15.802Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:15.805Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:15.805Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:15.805Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:16.306Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:16.306Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:16.306Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:16.306Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:16.308Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:16.308Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:16.308Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:16.308Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:16.311Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:16.311Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:16.311Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:16.811Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:16.811Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:16.811Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:16.811Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:16.814Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:16.814Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:16.814Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:16.814Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:16.815Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:16.815Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:16.815Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:17.315Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:17.315Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:17.315Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:17.315Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:17.317Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:17.317Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:17.317Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:17.317Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:17.318Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:17.318Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:17.318Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:17.819Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:17.819Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:17.819Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:17.819Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:17.821Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:17.821Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:17.821Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:17.821Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:17.824Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:17.824Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:17.824Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:18.324Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:18.324Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:18.324Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:18.324Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:18.325Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:18.325Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:18.325Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:18.325Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:18.326Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:18.326Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:18.326Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:18.827Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:18.826Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:18.826Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:18.826Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:18.828Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:18.828Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:18.828Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:18.828Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:18.830Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:18.830Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:18.830Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:19.330Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:19.330Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:19.330Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:19.330Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:19.332Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:19.333Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:19.333Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:19.333Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:19.335Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:19.335Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:19.335Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:19.835Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:19.835Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:19.835Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:19.835Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:19.838Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:19.838Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:19.838Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:19.838Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:19.839Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:19.839Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:19.839Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:20.339Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:20.339Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:20.339Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:20.339Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:20.340Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:20.340Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:20.341Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:20.341Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:20.342Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:20.342Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:20.342Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:20.843Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:20.843Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:20.843Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:20.843Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:20.845Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:20.846Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:20.846Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:20.846Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:20.848Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:20.848Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:20.848Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:21.348Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:21.348Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:21.348Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:21.348Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:21.349Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:21.349Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:21.349Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:21.349Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:21.351Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:21.351Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:21.351Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:21.852Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:21.852Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:21.852Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:21.852Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:21.853Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:21.854Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:21.854Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:21.854Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:21.855Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:21.855Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:21.855Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:22.355Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:22.355Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:22.355Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:22.355Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:22.357Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:22.357Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:22.357Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:22.357Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:22.360Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:22.360Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:22.360Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:22.860Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:22.860Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:22.860Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:22.860Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:22.861Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:22.861Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:22.861Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:22.861Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:22.862Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:22.863Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:22.863Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:23.363Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:23.363Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:23.363Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:23.363Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:23.367Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:23.367Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:23.367Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:23.367Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:23.369Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:23.369Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:23.369Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:23.869Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:23.869Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:23.869Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:23.869Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:23.871Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:23.871Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:23.871Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:23.871Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:23.872Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:23.872Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:23.872Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:24.372Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:24.372Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:24.372Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:24.372Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:24.375Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:24.376Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:24.376Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:24.376Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:24.377Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:24.377Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:24.377Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:24.878Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:24.878Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:24.878Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:24.878Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:24.880Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:24.880Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:24.880Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:24.880Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:24.883Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:24.883Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:24.883Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:25.384Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:25.383Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:25.383Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:25.383Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:25.386Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:25.387Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:25.387Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:25.387Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:25.389Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:25.389Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:25.389Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:25.890Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:25.889Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:25.890Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:25.890Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:25.893Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:25.893Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:25.893Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:25.893Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:25.895Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:25.895Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:25.895Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:26.396Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:26.396Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:26.396Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:26.396Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:26.399Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:26.399Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:26.399Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:26.399Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:26.402Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:26.402Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:26.402Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:26.903Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:26.902Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:26.903Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:26.903Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:26.905Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:26.906Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:26.906Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:26.906Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:26.909Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:26.909Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:26.909Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:27.410Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:27.409Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:27.409Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:27.409Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:27.412Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:27.412Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:27.412Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:27.412Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:27.414Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:27.414Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:27.414Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:27.914Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:27.914Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:27.914Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:27.914Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:27.918Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:27.918Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:27.918Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:27.918Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:27.919Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:27.919Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:27.919Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:28.420Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:28.420Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:28.420Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:28.420Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:28.424Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:28.424Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:28.424Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:28.424Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:28.427Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:28.427Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:28.427Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:28.928Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:28.927Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:28.928Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:28.928Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:28.931Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:28.931Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:28.931Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:28.931Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:28.935Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:28.935Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:28.935Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:29.435Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:29.435Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:29.435Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:29.435Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:29.438Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:29.438Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:29.438Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:29.438Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:29.440Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:29.441Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:29.441Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:29.941Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:29.941Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:29.941Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:29.941Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:29.942Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:29.942Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:29.942Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:29.942Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:29.943Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:29.943Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:29.943Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:30.444Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:30.444Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:30.444Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:30.444Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:30.448Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:30.448Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:30.448Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:30.448Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:30.450Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:30.450Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:30.450Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:30.950Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:30.951Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:30.950Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:30.950Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:30.952Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:30.952Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:30.952Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:30.952Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:30.953Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:30.953Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:30.953Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:31.453Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:31.453Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:31.453Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:31.453Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:31.458Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:31.458Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:31.458Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:31.458Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:31.459Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:31.459Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:31.459Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:31.960Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:31.960Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:31.960Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:31.960Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:31.962Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:31.962Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:31.962Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:31.962Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:31.963Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:31.963Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:31.963Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:32.465Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:32.464Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:32.465Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:32.465Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:32.468Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:32.468Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:32.468Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:32.468Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:32.470Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:32.470Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:32.470Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:32.971Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:32.971Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:32.971Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:32.971Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:32.973Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:32.973Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:32.973Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:32.973Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:32.975Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:32.975Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:32.975Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:33.476Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:33.476Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:33.476Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:33.476Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:33.478Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:33.478Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:33.478Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:33.478Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:33.480Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:33.480Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:33.480Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:33.980Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:33.980Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:33.980Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:33.980Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:33.982Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:33.982Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:33.982Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:33.982Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:33.983Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:33.983Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:33.983Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:34.484Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:34.484Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:34.484Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:34.484Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:34.487Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:34.487Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:34.487Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:34.487Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:34.490Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:34.490Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:34.490Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:34.990Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:34.990Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:34.990Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:34.990Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:34.992Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:34.992Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:34.992Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:34.992Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:34.993Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:34.993Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:34.993Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:35.493Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:35.493Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:35.493Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:35.493Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:35.497Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:35.497Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:35.497Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:35.497Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:35.501Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:35.501Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:35.501Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:36.001Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:36.001Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:36.001Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:36.001Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:36.002Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:36.003Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:36.003Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:36.003Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:36.004Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:36.004Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:36.004Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:36.504Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:36.504Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:36.504Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:36.504Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:36.507Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:36.507Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:36.507Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:36.507Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:36.510Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:36.510Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:36.510Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:37.010Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:37.010Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:37.010Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:37.010Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:37.012Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:37.012Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:37.012Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:37.012Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:37.013Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:37.013Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:37.013Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:37.514Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:37.514Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:37.514Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:37.514Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:37.519Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:37.519Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:37.519Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:37.519Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:37.522Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:37.522Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:37.522Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:38.022Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:38.022Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:38.022Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:38.022Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:38.023Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:38.024Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:38.024Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:38.024Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:38.025Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:38.025Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:38.025Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:38.525Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:38.525Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:38.525Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:38.525Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:38.526Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:38.526Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:38.526Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:38.526Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:38.528Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:38.528Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:38.529Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:39.029Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:39.029Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:39.029Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:39.029Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:39.030Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:39.030Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:39.030Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:39.030Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:39.031Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:39.031Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:39.031Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:39.532Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:39.531Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:39.532Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:39.532Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:39.535Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:39.535Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:39.535Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:39.535Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:39.537Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:39.537Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:39.537Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:40.038Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:40.038Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:40.038Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:40.038Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:40.039Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:40.039Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:40.039Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:40.039Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:40.041Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:40.041Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:40.041Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:40.541Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:40.541Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:40.541Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:40.541Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:40.544Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:40.544Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:40.544Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:40.544Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:40.546Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:40.546Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:40.546Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:41.046Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:41.046Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:41.046Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:41.046Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:41.048Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:41.049Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:41.049Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:41.049Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:41.050Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:41.050Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:41.050Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:41.550Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:41.550Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:41.550Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:41.550Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:41.555Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:41.555Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:41.555Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:41.555Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:41.558Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:41.559Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:41.559Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:42.059Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:42.059Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:42.059Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:42.059Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:42.060Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:42.060Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:42.060Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:42.060Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:42.061Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:42.061Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:42.061Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:42.562Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:42.562Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:42.562Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:42.562Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:42.565Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:42.565Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:42.565Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:42.565Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:42.568Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:42.568Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:42.568Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:43.068Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:43.068Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:43.068Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:43.068Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:43.070Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:43.070Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:43.070Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:43.070Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:43.071Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:43.071Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:43.071Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:43.572Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:43.572Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:43.572Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:43.572Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:43.575Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:43.575Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:43.575Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:43.575Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:43.577Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:43.577Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:43.577Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:44.077Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:44.077Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:44.077Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:44.077Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:44.078Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:44.078Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:44.078Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:44.078Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:44.079Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:44.079Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:44.079Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:44.580Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:44.580Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:44.580Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:44.580Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:44.583Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:44.583Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:44.583Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:44.583Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:44.585Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:44.585Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:44.585Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:45.086Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:45.086Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:45.086Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:45.086Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:45.090Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:45.090Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:45.090Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:45.090Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:45.093Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:45.093Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:45.093Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:45.594Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:45.594Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:45.594Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:45.594Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:45.597Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:45.597Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:45.597Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:45.597Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:45.599Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:45.599Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:45.599Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:46.099Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:46.099Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:46.099Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:46.099Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:46.102Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:46.102Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:46.102Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:46.102Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:46.105Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:46.105Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:46.105Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:46.605Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:46.605Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:46.605Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:46.605Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:46.609Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:46.609Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:46.609Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:46.609Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:46.611Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:46.611Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:46.611Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:47.112Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:47.112Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:47.112Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:47.112Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:47.115Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:47.115Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:47.115Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:47.115Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:47.117Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:47.117Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:47.117Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:47.618Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:47.618Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:47.618Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:47.618Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:47.621Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:47.621Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:47.621Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:47.621Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:47.623Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:47.623Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:47.623Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:48.123Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:48.123Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:48.123Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:48.123Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:48.127Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:48.127Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:48.127Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:48.127Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:48.130Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:48.130Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:48.130Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:48.631Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:48.631Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:48.631Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:48.631Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:48.634Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:48.634Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:48.634Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:48.634Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:48.635Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:48.635Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:48.635Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:49.136Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:49.136Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:49.136Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:49.136Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:49.139Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:49.139Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:49.139Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:49.139Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:49.141Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:49.141Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:49.141Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:49.641Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:49.641Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:49.641Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:49.641Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:49.645Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:49.646Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:49.646Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:49.646Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:49.648Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:49.648Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:49.648Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:50.148Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:50.148Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:50.148Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:50.148Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:50.150Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:50.150Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:50.150Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:50.150Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:50.152Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:50.152Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:50.152Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:50.652Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:50.652Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:50.652Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:50.652Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:50.656Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:50.656Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:50.656Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:50.656Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:50.659Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:50.659Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:50.659Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:51.160Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:51.159Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:51.159Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:51.159Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:51.162Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:51.163Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:51.163Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:51.163Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:51.166Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:51.166Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:51.166Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:51.667Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:51.666Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:51.667Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:51.667Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:51.670Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:51.670Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:51.670Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:51.670Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:51.672Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:51.672Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:51.672Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:52.173Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:52.173Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:52.173Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:52.173Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:52.174Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:52.174Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:52.174Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:52.174Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:52.176Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:52.176Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:52.176Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:52.676Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:52.676Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:52.676Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:52.676Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:52.678Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:52.678Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:52.678Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:52.678Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:52.679Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:52.679Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:52.679Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:53.180Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:53.180Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:53.180Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:53.180Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:53.182Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:53.182Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:53.182Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:53.182Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:53.184Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:53.184Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:53.184Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:53.684Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:53.684Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:53.684Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:53.684Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:53.686Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:53.686Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:53.686Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:53.686Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:53.687Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:53.687Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:53.687Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:54.187Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:54.187Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:54.187Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:54.187Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:54.189Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:54.189Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:54.189Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:54.189Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:54.190Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:54.190Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:54.190Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:54.690Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:54.690Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:54.690Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:54.690Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:54.691Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:54.691Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:54.691Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:54.691Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:54.693Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:54.693Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:54.693Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:55.193Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:55.193Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:55.193Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:55.193Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:55.194Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:55.194Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:55.194Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:55.194Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:55.196Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:55.196Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:55.196Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:55.696Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:55.696Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:55.696Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:55.696Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:55.699Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:55.699Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:55.699Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:55.699Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:55.700Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:55.700Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000001 from ERASEALL_STATUS(ctrl-ap)
    [2026-07-08T08:00:55.700Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:55.700Z] [1546] WARN - [nrf_probe::device_operations::ap_protection] {jlink_usb_001050351525} Failed CTRL-AP erase when unprotecting nRF52 device:  Timed out erasing flash
    [2026-07-08T08:00:55.700Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_ap
    [2026-07-08T08:00:55.700Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:55.700Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:55.701Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:55.701Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:55.701Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:55.701Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:55.703Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:55.703Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to access port 1: Write 0x00000001 to CSW(mem-ap) or RESET(ctrl-ap)
    [2026-07-08T08:00:55.703Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_ap
    [2026-07-08T08:00:55.713Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_ap
    [2026-07-08T08:00:55.713Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:55.713Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:55.715Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:55.715Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:55.715Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:55.715Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:55.716Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:55.716Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to access port 1: Write 0x00000000 to CSW(mem-ap) or RESET(ctrl-ap)
    [2026-07-08T08:00:55.716Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_ap
    [2026-07-08T08:00:55.716Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_ap
    [2026-07-08T08:00:55.716Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:55.716Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:55.717Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:55.717Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:55.717Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:55.717Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:55.718Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:55.718Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to access port 1: Write 0x00000000 to TAR(mem-ap) or ERASEALL(ctrl-ap)
    [2026-07-08T08:00:55.718Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_ap
    [2026-07-08T08:00:55.768Z] [1546] DEBUG - [nrf_probe::device_operations::ap_protection] {jlink_usb_001050351525} -> Get AP-Protect Status
    [2026-07-08T08:00:55.768Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:55.768Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:55.768Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:55.770Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:55.770Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:55.770Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:55.770Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:55.772Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:55.772Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from CSW(mem-ap) or RESET(ctrl-ap)
    [2026-07-08T08:00:55.772Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:55.772Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:55.772Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:55.772Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:55.774Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:55.774Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x010000f0 to 0x08
    [2026-07-08T08:00:55.774Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:55.774Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:55.775Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:55.775Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x02880000 from IDR
    [2026-07-08T08:00:55.775Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:55.775Z] [1546] DEBUG - [nrf_probe::ctrl_ap] {jlink_usb_001050351525} Detected CTRL-AP revision 0 at access port 1
    [2026-07-08T08:00:55.776Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:55.776Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:55.776Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:55.776Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:55.776Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:55.776Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:55.776Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:55.777Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:55.777Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T08:00:55.777Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:55.777Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:55.777Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:55.777Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:55.778Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:55.778Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:55.778Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:55.778Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:55.779Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:55.779Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T08:00:55.779Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:55.779Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:55.779Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:55.779Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:55.780Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:55.780Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:55.780Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:55.780Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:55.780Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:55.780Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T08:00:55.781Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:55.781Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_ap
    [2026-07-08T08:00:55.781Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:55.781Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:55.781Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:55.781Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x01000000 to 0x08
    [2026-07-08T08:00:55.781Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:55.781Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:55.782Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:55.782Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from access port 1: Read 0x00000000 from DRW(mem-ap) or APPROTECT.STATUS(ctrl-ap)
    [2026-07-08T08:00:55.782Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_ap
    [2026-07-08T08:00:55.782Z] [1546] DEBUG - [nrf_probe::device_operations::ap_protection] {jlink_usb_001050351525} AP-Protect status is 'All'
    [2026-07-08T08:00:55.782Z] [1546] DEBUG - [nrf_probe::device_operations::ap_protection] {jlink_usb_001050351525} <- Get AP-Protect Status
    [2026-07-08T08:00:55.782Z] [1546] INFO - [nrf_probe::probe_pool::worker] {jlink_usb_001050351525} <- handle_message
    [2026-07-08T08:00:55.783Z] [1546] TRACE - [nrf_probe::probe_pool] Got progress from worker
    [2026-07-08T08:00:55.783Z] [1546] TRACE - [nrf_probe::probe_pool] Got device error response
    [2026-07-08T08:00:55.783Z] [1546] TRACE - [nrf_probe::probe_pool] Expecting trace channel to disconnect
    [2026-07-08T08:00:55.783Z] [1546] DEBUG - [nrf_probe::probe_pool] Terminating worker with ID 1554
    [2026-07-08T08:00:55.783Z] [1546] TRACE - [nrf_probe::probe_pool] Waiting for worker to exit
    [2026-07-08T08:00:55.783Z] [1546] DEBUG - [nrf_probe::probe_pool::worker] {jlink_usb_001050351525} Probe worker received message: Shutdown
    [2026-07-08T08:00:55.783Z] [1546] INFO - [nrf_probe::probe_pool::worker] {jlink_usb_001050351525} Worker shutting down
    [2026-07-08T08:00:55.783Z] [1546] INFO - [nrf_probe::probe_state] {jlink_usb_001050351525} -> Powering down debug region
    [2026-07-08T08:00:55.783Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:55.783Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:55.784Z] [1546] TRACE - [nrf_probe::probe_pool] Waiting for worker to exit
    [2026-07-08T08:00:55.784Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:55.784Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x00000000 to 0x08
    [2026-07-08T08:00:55.784Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:55.784Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_dp
    [2026-07-08T08:00:55.784Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:55.785Z] [1546] TRACE - [nrf_probe::probe_pool] Waiting for worker to exit
    [2026-07-08T08:00:55.786Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:55.786Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from debug port: read 0xf0000040 from register CTRL/STAT
    [2026-07-08T08:00:55.786Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_dp
    [2026-07-08T08:00:55.786Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:55.786Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:55.787Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:55.787Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x00000000 to 0x08
    [2026-07-08T08:00:55.787Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:55.787Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_dp
    [2026-07-08T08:00:55.787Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:55.787Z] [1546] TRACE - [nrf_probe::probe_pool] Waiting for worker to exit
    [2026-07-08T08:00:55.788Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:55.788Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from debug port: read 0xf0000040 from register CTRL/STAT
    [2026-07-08T08:00:55.788Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_dp
    [2026-07-08T08:00:55.788Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:55.788Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:55.789Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:55.789Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port CTRL/STAT: Write 0x00000000 to 0x04
    [2026-07-08T08:00:55.789Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:55.791Z] [1546] TRACE - [nrf_probe::probe_pool] Waiting for worker to exit
    [2026-07-08T08:00:55.791Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> write_dp_unchecked
    [2026-07-08T08:00:55.791Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> write_apdp_register
    [2026-07-08T08:00:55.792Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- write_apdp_register
    [2026-07-08T08:00:55.793Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Submitted write to debug port SELECT: Write 0x00000000 to 0x08
    [2026-07-08T08:00:55.793Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- write_dp_unchecked
    [2026-07-08T08:00:55.793Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} -> read_dp
    [2026-07-08T08:00:55.793Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} -> read_apdp_register
    [2026-07-08T08:00:55.794Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} <- read_apdp_register
    [2026-07-08T08:00:55.794Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Got read from debug port: read 0x00000040 from register CTRL/STAT
    [2026-07-08T08:00:55.794Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} <- read_dp
    [2026-07-08T08:00:55.794Z] [1546] DEBUG - [nrf_probe::probe_state] {jlink_usb_001050351525} Powered down sys and dbg regions in 7 ms
    [2026-07-08T08:00:55.794Z] [1546] INFO - [nrf_probe::probe_state] {jlink_usb_001050351525} <- Powering down debug region
    [2026-07-08T08:00:55.794Z] [1546] TRACE - [debug_probes::jlink] {jlink_usb_001050351525} Closing emulator connection
    [2026-07-08T08:00:55.794Z] [1546] TRACE - [jlink::backend] {jlink_usb_001050351525} Closing connection to the J-Link
    [2026-07-08T08:00:55.796Z] [1546] TRACE - [nrf_probe::probe_pool] Waiting for worker to exit
    [2026-07-08T08:00:55.804Z] [1546] TRACE - [nrf_probe::probe_pool] Waiting for worker to exit
    [2026-07-08T08:00:55.812Z] [1546] DEBUG - [nrf_probe::probe_pool::worker] {jlink_usb_001050351525} Probe worker stopped
    [2026-07-08T08:00:55.813Z] [1546] TRACE - [nrf_probe::probe_pool] Trace channel disconnected as expected
    [2026-07-08T08:00:55.813Z] [1546] TRACE - [nrf_probe::probe_pool] Trace thread ends now
    [2026-07-08T08:00:55.817Z] [1546] INFO - [nrf_probe::probe_pool] Worker exited successfully
    [2026-07-08T08:00:55.818Z] [1546] TRACE - [nrf_probe::probe_pool] Joined trace thread
    [2026-07-08T08:00:55.818Z] [1546] INFO - [nrfutil_device::operations] 1 error(s) occured while executing operation recover
    [2026-07-08T08:00:55.818Z] [1546] INFO - [nrfutil_device::operations]  - 1050351525: Device error: Access port is still protected after Erase and Reset (Generic)
    [2026-07-08T08:00:55.818Z] [1546] TRACE - [boardcontroller] BoardControllerPlugin::drop - ref 0x5b268479b400
    [2026-07-08T08:00:55.818Z] [1546] TRACE - [sdfu] SdfuPlugin::drop - ref 0x5b268476f750
    [2026-07-08T08:00:55.818Z] [1546] TRACE - [mcuboot] McuBootPlugin::drop - ref 0x5b268479cf10
    The nRF52832 on my board is a later revision, QFAAG0, but the same errata seems to apply: https://docs.nordicsemi.com/r/bundle/errata_nrf52832_rev3/page/err/nrf52832/rev3/latest/anomaly_832_176.html
    The watchdog is not configured in the application that is running on the nRF at the moment.
    Best Regards,
    Chris
  • We can't see anything wrong per se in the log, an erase all is triggered in the CTRL-AP, and that doesn't seem to finish.
    Can you share the application that causes this, or provide more details on what the application is doing?
  • Sure, the application is this: https://github.com/RIOT-OS/RIOT/blob/master/examples/basic/blinky/main.c
    To spare you setting up a RIOT environment, I attached the .elf file.
    This is the command that is used to flash the board:
    JLinkExe -nogui 1 -exitonerror 1 -device nrf52832_xxaa -speed 2000 -if SWD -jtagconf -1,-1 -commandfile burn.seg
    And this is the burn.seg file:
    loadfile blinky.elf
    Write4 0x10001200 00000015 00000015
    r
    g
    exit
    As previously mentioned, the Write4 command sets the pinreset pin in the UCIR register.
    8625.blinky.zip
    When I was flashing the board, I could always reflash it until it has been power cycled for the first time.
    The application is still running despite all the recovery attempts btw.
