Application fails to boot with MCUboot image in external flash and TF-M
For my project I want MCUboot with the upgrade image placed in the external flash, and TF-M. I am not able to get this combo to boot however, and I suspect the reason is that MCUboot and non-secure application is fighting over the SPI bus.
In this branch I've set up Zephyr's hello world to have the same configuration, and I see MCUboot running just fine, TF-M booting and printing jump to image, but I never see the application image boot. If I move the upgrade image back into the primary flash the configuration works right away.
Is there a chance that MCUboot running the SPI peripheral in the secure world collides with the application attempting to use the SPI peripheral in the non-secure world? The SPI is not configured to be secure, but is it a requirement that the peripheral is reset after MCUboot is done with it so the application can configure it for non-secure execution?
I'm running on a nRF54LM20A DK. I have upgrade image in external flash and TF-M running in separate projects without issues, however when I combine them I can't get them to boot. In a different project I had issues when the I2C peripheral had status="okay" in both the secure and non-secure DTS, which lead to a hard fault when I initialized it in my non-secure application. I', suspecting a similar issue, that the kernel initializes the peripheral even though it's not used and this causing issues for the non-secure application.
Thanks!
  • Hello!
    Could you share the runtime logs and/or any error messages that you run into when trying?
    Could you share your memory map (generated partitions,yml in your build folder is fine)?
    I'm more leaning towards the option of there being a non-correct partitioning w.r.t tf-m partitions rather than a conflict of spi resources, but I'm not excluding that this could be the case
    Andreas
  • Getting the partitions right for TF-M is difficult, so I'm also open to this being the issue. This is the compiled parititons.yml, or you can see the pm_static in my fork.
    app:
      address: 0x73000
      end_address: 0x1fd000
      region: flash_primary
    bootconf:
      address: 0xffd080
      end_address: 0xffd084
      region: bootconf
    external_flash:
      address: 0x0
      end_address: 0x800000
      region: external_flash
    mcuboot:
      address: 0x0
      end_address: 0x28000
      placement:
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0x28000
      end_address: 0x29000
      placement:
        before:
        - app
    mcuboot_primary:
      address: 0x28000
      end_address: 0x1e5000
      span:
      - mcuboot_pad
      - app
    mcuboot_primary_app:
      address: 0x28000
      span:
      - mcuboot_pad
      - app
    mcuboot_secondary:
      address: 0x0
      end_address: 0x1bc000
      placement:
        align:
          start: 0x1000
    mcuboot_sram:
      address: 0x20000000
      end_address: 0x20010000
      orig_span: &id001
      - tfm_sram
      region: sram_primary
      span: *id001
    otp:
      address: 0xffd500
      end_address: 0xffd980
      region: otp
    sram_nonsecure:
      address: 0x20010000
      end_address: 0x2007fe40
      orig_span: &id002
      - sram_primary
      span: *id002
    sram_primary:
      address: 0x20010000
    sram_secure:
      address: 0x20000000
      orig_span: &id003
      - tfm_sram
      span: *id003
    tfm:
      address: 0x29000
      end_address: 0x68800
      placement:
        before:
        - app
    tfm_its:
      address: 0x68800
      end_address: 0x6c800
      inside:
      - tfm_storage
      placement:
        before:
        - tfm_otp_nv_counters
    tfm_nonsecure:
      address: 0x73000
      orig_span: &id004
      - app
      span: *id004
    tfm_otp_nv_counters:
      address: 0x6c800
      end_address: 0x6e800
      inside:
      - tfm_storage
      placement:
        before:
        - tfm_ps
    tfm_ps:
      address: 0x6e800
      end_address: 0x73000
      inside:
      - tfm_storage
      placement:
        after:
        - tfm_secure
    tfm_secure:
      address: 0x29000
      orig_span: &id005
      - tfm
      span: *id005
    tfm_sram:
      address: 0x20000000
      inside:
      - sram_secure
      placement:
        after:
        - start
    tfm_storage:
      address: 0x68800
      orig_span: &id006
      - tfm_ps
      - tfm_its
      span: *id006
    This is the runtime logs I get from MCUboot:
    *** Booting Zephyr OS build ncs-v3.3.0-2-gda4454231faa ***
    *** Booting My Application v2.3.0-dev-fce4dac2e629 ***
    *** Using nRF Connect SDK v3.3.0-a7f2e9d655e2 ***
    *** Using Zephyr OS v4.3.99-da4454231faa ***
    [00:00:00.024,078] <inf> mcuboot: Starting bootloader
    [00:00:00.030,154] <inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    [00:00:00.040,139] <inf> mcuboot: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    [00:00:00.050,121] <inf> mcuboot: Boot source: none
    [00:00:00.055,659] <inf> mcuboot: Image index: 0, Swap type: none
    [00:00:00.154,197] <inf> mcuboot: Bootloader chainload address offset: 0x28000
    [00:00:00.161,754] <inf> mcuboot: Image version: v0.0.0
    [00:00:00.167,384] <inf> mcuboot: Jumping to the first image slot
    This is the runtime logs from TF-M (which do look a bit cut off):
    Pins have been configured as secure.
    GPIO port: 0x00000000
    Pin: 0x00000000
    Pin: 0x00000001
    Booting TF-M v2.2.2**
    I get no output from the application, even when I've tried to disable the UART for MCUboot and TF-M to make sure they don't fight over the peripheral. I also added blinky code to Hello World to have a visual confirmation other than UART logs, and the LED is not blinking which supports the app never booting.
    Apologies for the wait.
    I think this might show the issue. In your attached pm_static:
    • tfm_nonsecure has span: [app] yet is smaller than app: 0x172000 (0x73000–0x1e5000) vs 0x18a000 (0x73000–0x1fd000). A span can never be smaller than its member.
    • mcuboot_primary, mcuboot_primary_app, and tfm_nonsecure all end at 0x1e5000, but app runs to 0x1fd000, i.e. 0x18000 past the slot and past the image trailer region.
    And from the device logs:
    "[00:00:00.055,659] <inf> mcuboot: Image index: 0, Swap type: none" should also indicate that we do not touch the spi at this point (at least w.r.t the external flash), so if theres an SPI contestion it isn't here
    Could you do a pristine build with SB_CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y and let Partition Manager place everything, relocating only mcuboot_secondary to the external_flash region, i.e do not use a static partition map yet to see if partition manager sets things up properly, and then after create the static file based on the generated partition map (You can find it here build/partitions.yml) and move only mcuboot_secondary, leaving app, tfm_nonsecure, and the mcuboot_primary* entries as PM produced them.
    After regenerating, the map must satisfy: app == tfm_nonsecure (same address and size), app nested inside mcuboot_primary_app, mcuboot_primary_app starting at 0x29000 (after the pad), and app ending at 0x1e5000. The extra 0x18000 at 0x1e5000–0x1fd000 should be free or a separate storage partition, not part of app.
    The fact that MCUboot boots suggests that here suggests that CONFIG_BOOT_MAX_IMG_SECTORS  is adequate for reading the primary, but you could also increase CONFIG_BOOT_MAX_IMG_SECTORS for the external-flash erase-block size. Default might be a little to small for this configuration.
    Andreas
  • You were spot on - now it works! I misunderstood how app, tfm_nonsecure and mcuboot_primary ties together, so cleaning them up fixed it.
    Thanks a lot!
