SoftDevice Controller assert during DTM receiver test at dead/marginal RF link (nRF52833)
# SoftDevice Controller assert during DTM receiver test at dead/marginal RF link (nRF52833)
## Summary
On an nRF52833, running the nRF Connect SDK Direct Test Mode (DTM) 2-wire sample,
starting an **LE receiver test** on a **dead or near-dead RF link** intermittently
triggers an **internal SoftDevice Controller (SDC) assertion raised from the RADIO
interrupt**. The assertion escalates to a Zephyr kernel panic / HardFault. With the
stock configuration the device then halts forever and stops servicing the 2-wire
UART (it does not even answer `RESET`) until it is power-cycled.
The **same firmware source on an nRF52840-DK never reproduces** this under identical
host/RF conditions, which points to an nRF52833-specific SDC/silicon issue rather
than an application bug.
We have a working application-level **recovery** (reset-on-fatal, see "Workaround"
below), but it does **not prevent** the SDC assert — it only turns the permanent
wedge into an automatic ~4 ms reboot. This report is to ask Nordic to identify and
fix the underlying assert.
## Environment
| Item | Value |
| SoC | nRF52833 (QIAA / `nRF52833_xxAA`), Cortex-M4 |
| Reference device (no repro) | nRF52840-DK |
| nRF Connect SDK | `v3.4.99-481b5685488a` (west manifest `sdk-nrf` @ `main`) |
| Zephyr | `v4.4.0-b8e6b9b3ed1f` |
| SDC build revision | `84 d6 38 af 90 80 24 b8 90 a2 fa 5f 15 8f ac 7c b2 ed 6d dc` |
| Sample | `samples/bluetooth/direct_test_mode` (2-wire UART -> HCI -> SDC), vendored |
| Transport | 2-wire UART, 8N1, 19200 baud |
| PHY under test | LE 1M |
The application is the standard DTM 2-wire firmware: `main.c` reads a 2-wire word,
`lib/dtm_twowire/dtm_twowire_to_hci.c` translates it to an HCI command, `bt_send()`
hands it to the SDC, and the main loop waits for the HCI event.
## Symptom (precise)
While the device is executing an **LE receiver test** (`HCI_LE_Receiver_Test`) at a
dead/marginal link, an SDC-internal assertion fires **inside the RADIO ISR**,
roughly tens of milliseconds into the receive window. The assertion handler
(`hci_driver.c:363`, `sdc_assertion_handler()`) prints:
ASSERTION FAIL [0] @ WEST_TOPDIR/nrf/subsys/bluetooth/controller/hci_driver.c:363
    SoftDevice Controller ASSERT: 0, 0x0c5a
i.e. **SDC assert file id `0`, line/code `0x0C5A` (3162 decimal)**. With
`CONFIG_ASSERT=y` this executes `__ASSERT(false, ...)`, which panics. Because the
context is an ISR, Zephyr escalates to a HardFault and (with the default handler)
halts:
<err> os: ***** HARD FAULT *****
<err> os:   Fault escalation (see below)
<err> os: ARCH_EXCEPT with reason 4                 (K_ERR_KERNEL_PANIC)
<err> os:  xpsr:  0x01000011                          (IPSR = 17 -> RADIO_IRQn, IRQ #1)
<err> os: Faulting instruction address (r15/pc): 0x000222da   (assert_post_action)
<err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
<err> os: Fault during interrupt handling
<err> os: Halting system
## On-target evidence (J-Link)
Freezing the wedged target (before any recovery workaround) showed the CPU parked
in the fatal-halt spin with interrupts disabled — confirming a crash, not a blocked
wait:
- `PC = arch_system_halt` (`zephyr/kernel/fatal.c`), infinite loop, `PRIMASK=1`.
- `LR = k_sys_fatal_error_handler` (default weak handler).
- Halted in **HardFault** (exception #3), `HFSR.FORCED=1` (escalation from the
  `ARCH_EXCEPT` raised inside the SDC assert).
- The exception stack frame's pre-fault `xPSR=0x01000011` => `IPSR=17` =>
  **RADIO_IRQn** — the assert originates in the SDC radio interrupt.
- RADIO peripheral at the freeze: `STATE=DISABLED`, `RSSISAMPLE≈0x56` (~ -86 dBm,
  i.e. a dead link), `EVENTS_CRCOK=1` and `EVENTS_CRCERROR=1` both latched,
  `SHORTS=0x2`, `INTENSET=0x10`.
## Reproduction
Two nRF devices; the nRF52833 is the DUT/receiver, a second device is the reference
transmitter. Drive both over 2-wire DTM. The trigger is the DUT running a **receiver
test with essentially no usable signal**.
Minimal DUT 2-wire sequence (as observed on the wire):
0x0000  RESET                              -> 0x0000
0x0204  TEST_SETUP: SET_PHY = LE 1M        -> 0x0000
0x09C4  TEST_SETUP: SET TX POWER = -60 dBm -> 0x03B0   (via HCI LE_Read_TX_Power)
0x4000  RECEIVER_TEST, channel 0           -> 0x0000   (RX starts OK)
        ... ~34 ms into the receive window: SDC assert in RADIO ISR -> crash ...
0xC000  TEST_END                           -> (no response; CPU already halted)
Conditions:
- Requested TX power -60 dBm on both ends (both clamp to the SoC minimum ~ -40 dBm),
  over a heavily attenuated / effectively dead RF path (channel 0 / 2402 MHz).
- **Intermittent and RF-dependent.** Over 40 receiver-test rounds we saw the assert
  fire on **35** of them; **2** rounds completed a full RX with real packet counts
  (472, 494); the rest were dead. A metal object placed over the DUT antenna makes
  it fire much more readily (even at otherwise strong signal).
## Ruled out (not the cause)
- Host tooling / 2-wire command encoding: reproduces with both a custom 2-wire host
  tool and the official nRF Connect DTM app; the 2-wire words are byte-identical.
- Host command ordering / timing: varying the stop order and adding settle delays
  does not prevent it.
- The nRF52840-DK running the same firmware source never wedges under identical
  conditions.
## Application-level workaround (recovery only — does not fix the assert)
To stop the permanent wedge we enabled auto-reset on fatal error so the device recovers
by itself in ~4 ms instead of hanging:
- `CONFIG_RESET_ON_FATAL_ERROR=y` (NCS `lib/fatal_error`) — `k_sys_fatal_error_handler`
  resets the SoC instead of halting.
## What we would like Nordic to investigate
1. What does SDC assert **file id 0, line/code `0x0C5A` (3162)** correspond to in this
   SDC build (`84 d6 38 af 90 80 24 b8 90 a2 fa 5f 15 8f ac 7c b2 ed 6d dc`)?
2. Why does an `HCI_LE_Receiver_Test` at a dead/marginal link assert in the RADIO ISR
   on **nRF52833** but not on **nRF52840** with the same SDC/DTM source?
3. Is there a known anomaly/errata or an SDC configuration/workaround that prevents
   this assert (so a dead-link receiver test simply reports 0 packets instead of
   faulting)?
    Stine is on vacation, and will be back on Friday. Thanks for your patience.
  • Hi Sergei,
    I have just returned from vacation. I will have a look at this and come back to you asap.
    Stine
  • Thank you for the very detailed report. To complete the information needed for our investigation, could you please share:
    • The complete prj.conf and any overlay files used for the nRF52833 DTM build.
    • The full build log, so we can verify the exact SDC library artifact and version linked into the image.
    • Whether the nRF52833 setup includes any external RF components, such as an LNA, FEM, or antenna switch.
    • Whether the issue is reproducible with CONFIG_BT_EXT_ADV disabled, if it is currently enabled.
  • Hi!
    Just letting you know that I have reported the issue, and that our team has been notified. They will have to do some testing. Please allow for some extra time due to summer vacations. I will get back to you asap.
    Note: I see that you are working on main. We recommend all customers to work with one of our official releases.
    Stine
  • Hi Stine,
    Thank you for looking into it.
    Answering you questions:
    Our nRF52833 setup does not include any external RF components, the radio drives the antenna directly.
    The issue is present with CONFIG_BT_EXT_ADV disabled, as it is not set in the config.
    Please see the complete prj.conf, .config, zephyr.map and the full build log below:
    prj.conf:
    # Vendored from nRF Connect SDK samples/bluetooth/direct_test_mode.
    # IO
    CONFIG_CONSOLE=n
    CONFIG_UART_CONSOLE=n
    CONFIG_UART_USE_RUNTIME_CONFIGURE=y
    # Assertions
    CONFIG_ASSERT=y
    # Fault recovery: on any fatal error (including a SoftDevice Controller internal
    # assertion raised from the RADIO ISR during marginal-link RX) reset the SoC
    # instead of halting forever, so the 2-wire DTM tester recovers without a power
    # cycle.
    # hci_raw
    CONFIG_BT=y
    CONFIG_BT_HCI_RAW=y
    CONFIG_BT_HCI_RAW_H4=y
    CONFIG_BT_HCI_RAW_H4_ENABLE=y
    # Data buffers
    CONFIG_NET_BUF=y
    CONFIG_BT_BUF_CMD_TX_SIZE=255
    CONFIG_BT_BUF_EVT_RX_SIZE=255
    # PHYs
    CONFIG_BT_CTLR_PHY_CODED=y
    # DTM
    CONFIG_BT_CTLR_DTM_HCI=y
    CONFIG_BT_CTLR_DTM_HCI_RX_V3=n
    # DTM 2-wire to HCI
    CONFIG_BT_CTLR_EXTENDED_FEAT_SET=y
    CONFIG_DTM_TWOWIRE_TO_HCI=y
    # Logging
    # To enable logging for this sample, assign 'y' to these options
    CONFIG_LOG=n
    CONFIG_LOG_PRINTK=n
    CONFIG_USE_SEGGER_RTT=n
    CONFIG_LOG_BACKEND_RTT=n
    .config:
    # Devicetree Info
    CONFIG_DT_HAS_ARM_ARMV7M_ITM_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M4F_ENABLED=y
    CONFIG_DT_HAS_ARM_V7M_NVIC_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_BT_HCI_SDC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_MWU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PPI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF52_FLASH_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF52_HFXO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF5X_REGULATOR_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    # end of Devicetree Info
    # CONFIG_INPUT is not set
    # CONFIG_WIFI is not set
    CONFIG_MAIN_STACK_SIZE=1128
    CONFIG_BT_BUF_ACL_TX_COUNT=7
    CONFIG_BT_BUF_EVT_RX_COUNT=10
    CONFIG_BT_HCI_ACL_FLOW_CONTROL=y
    # CONFIG_REGULATOR is not set
    CONFIG_BT_LONG_WQ_STACK_SIZE=1024
    # CONFIG_FPU is not set
    CONFIG_BT_RX_STACK_SIZE=768
    CONFIG_SERIAL=y
    # CONFIG_SPI is not set
    # CONFIG_MIPI_DSI is not set
    # CONFIG_MEMC is not set
    # CONFIG_MODEM is not set
    # CONFIG_UART_INTERRUPT_DRIVEN is not set
    # CONFIG_GPIO_HOGS is not set
    CONFIG_BT_HCI_VS=y
    CONFIG_HW_STACK_PROTECTION=y
    CONFIG_NUM_IRQS=48
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_FLASH_SIZE=512
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_MP_MAX_NUM_CPUS=1
    CONFIG_SOC_RESET_HOOK=y
    CONFIG_DCACHE_LINE_SIZE=32
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_IDLE_STACK_SIZE=320
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_CLOCK_CONTROL=y
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_BUILD_OUTPUT_BIN=y
    CONFIG_ROM_START_OFFSET=0
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_XIP=y
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    # CONFIG_COUNTER is not set
    # CONFIG_SRAM_VECTOR_TABLE is not set
    # CONFIG_SHARED_INTERRUPTS is not set
    CONFIG_CPU_HAS_ARM_MPU=y
    # CONFIG_PM_DEVICE is not set
    # CONFIG_OTP is not set
    # CONFIG_NVMEM is not set
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_BT_TX_PROCESSOR_STACK_SIZE=969
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    # CONFIG_USE_DT_CODE_PARTITION is not set
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    CONFIG_ZERO_LATENCY_IRQS=y
    CONFIG_ZERO_LATENCY_LEVELS=1
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    # CONFIG_POWER_DOMAIN is not set
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_BUILD_OUTPUT_HEX=y
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    CONFIG_GEN_ISR_TABLES=y
    # CONFIG_INIT_STACKS is not set
    CONFIG_TIMESLICE_SIZE=20
    CONFIG_FLASH_LOAD_OFFSET=0
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    # CONFIG_BUILD_OUTPUT_S19 is not set
    # CONFIG_ROMSTART_RELOCATION_ROM is not set
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    # CONFIG_FLASH is not set
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    # CONFIG_HCI_NXP_ENABLE_AUTO_SLEEP is not set
    # CONFIG_HCI_NXP_SET_CAL_DATA is not set
    # CONFIG_SYSTEM_TIMER_RESET_BY_LPM is not set
    CONFIG_GPIO=y
    # CONFIG_SYSTEM_CLOCK_HW_CYCLES_PER_SEC_RUNTIME_UPDATE is not set
    # CONFIG_MFD is not set
    # CONFIG_HCI_NXP_RX_THREAD is not set
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    # CONFIG_CACHE is not set
    # CONFIG_LOG is not set
    CONFIG_CMSIS_CORE_HAS_SYSTEM_CORE_CLOCK=y
    # CONFIG_PM_CPU_OPS is not set
    # CONFIG_RESET is not set
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    CONFIG_ASSERT=y
    # CONFIG_DEVICE_DEPS is not set
    CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    # CONFIG_SYSCON is not set
    # CONFIG_SOC_EARLY_INIT_HOOK is not set
    # CONFIG_CONSOLE is not set
    # CONFIG_WINSTREAM is not set
    CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_REBOOT=y
    CONFIG_GEN_IRQ_START_VECTOR=0
    CONFIG_SRAM_OFFSET=0
    CONFIG_SPIN_VALIDATE=y
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
    # CONFIG_BOOTLOADER_MCUBOOT is not set
    # CONFIG_SCHED_CPU_MASK is not set
    CONFIG_KERNEL_MEM_POOL=y
    CONFIG_MULTITHREADING=y
    # CONFIG_OUTPUT_DISASSEMBLY is not set
    CONFIG_LINKER_USE_RELAX=y
    # CONFIG_WATCHDOG is not set
    CONFIG_BT_BUF_ACL_TX_SIZE=27
    CONFIG_BT_BUF_ACL_RX_SIZE=27
    # Modules
    # CONFIG_BUILD_ONLY_NO_BLOBS is not set
    CONFIG_TAINT_BLOBS=y
    # Available modules.
    CONFIG_ZEPHYR_CLIENT_FW_DTM_MODULE=y
    # nrf (/workspaces/nrf)
    # CONFIG_NRF_802154_RADIO_DRIVER is not set
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    # CONFIG_ZMS is not set
    # Nordic nRF Connect
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    CONFIG_NRF_SECURITY_ENABLER=y
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # Image build variants
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # end of Image build variants
    # CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP is not set
    # Subsystems
    # Bootloader
    # CONFIG_SECURE_BOOT is not set
    CONFIG_SB_IMAGE_BOOT_OFFSET=0x200
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    # CONFIG_IS_SECURE_BOOTLOADER is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_INFO_TOTAL_SIZE_CHECK=y
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATION_STRUCT_HAS_HASH=y
    CONFIG_SB_VALIDATION_STRUCT_HAS_PUBLIC_KEY=y
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # CONFIG_SECURE_BOOT_STORAGE is not set
    # CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT_ENABLED is not set
    # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_ED25519 is not set
    # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_PURE is not set
    # CONFIG_NCS_MCUBOOT_BOOTLOADER_SIGN_MERGED_BINARY is not set
    # CONFIG_NCS_MCUBOOT_MANIFEST_UPDATES is not set
    CONFIG_NCS_MCUBOOT_IMGTOOL_SET_ROM_FIXED_ADDRESS=y
    # end of Bootloader
    # CONFIG_NRF_LCS is not set
    # Bluetooth Low Energy
    CONFIG_BT_COMPANY_ID_NORDIC=0x0059
    CONFIG_BT_COMPANY_ID=0x0059
    CONFIG_BT_MAX_CONN=2
    CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y
    CONFIG_BT_LL_SOFTDEVICE=y
    CONFIG_BT_CTLR_DF_SUPPORT=y
    CONFIG_BT_LL_SOFTDEVICE_BUILD_TYPE_LIB=y
    CONFIG_BT_HCI_TX_STACK_SIZE=1536
    # CONFIG_BT_CTLR_SDC_LLPM is not set
    # CONFIG_BT_CTLR_SDC_QOS_CHANNEL_SURVEY is not set
    # CONFIG_BT_CTLR_SDC_QOS_CONN_EVENT_REPORT is not set
    # CONFIG_BT_CTLR_SDC_ALLOW_PARALLEL_SCANNING_AND_INITIATING is not set
    CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=1
    # CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT_OVERRIDE is not set
    CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=7500
    CONFIG_BT_CTLR_SDC_CONN_EVENT_EXTEND_DEFAULT=y
    CONFIG_BT_CTLR_SDC_CENTRAL_ACL_EVENT_SPACING_DEFAULT=7500
    # CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT_OVERRIDE is not set
    CONFIG_BT_CTLR_SDC_TX_PACKET_COUNT=3
    CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT=2
    CONFIG_BT_CTLR_SDC_SCAN_BUFFER_COUNT=3
    CONFIG_BT_CTLR_SDC_PERIODIC_SYNC_BUFFER_COUNT=3
    CONFIG_BT_CTLR_SDC_RX_PRIO=6
    # CONFIG_BT_CTLR_DF is not set
    CONFIG_BT_LL_SOFTDEVICE_MULTIROLE=y
    CONFIG_BT_CTLR_FAL_SIZE=8
    # CONFIG_BT_CTLR_SDC_EVENT_TRIGGER is not set
    # CONFIG_BT_CTLR_SDC_CONN_ANCHOR_POINT_REPORT is not set
    CONFIG_BT_CTLR_SDC_EXTENDED_FEAT_MAX_REMOTE_PAGE=1
    # CONFIG_BT_CTLR_FRAME_SPACE_UPDATE is not set
    # CONFIG_BT_CTLR_LE_PATH_LOSS_MONITORING is not set
    # CONFIG_BT_CTLR_SDC_LE_POWER_CLASS_1 is not set
    # CONFIG_BT_CTLR_SDC_DATA_RELATED_ADDRESS_CHANGES is not set
    # CONFIG_BT_CTLR_LE_FLUSHABLE_ACL_DATA is not set
    CONFIG_BT_LL_SOFTDEVICE_INIT_PRIORITY=40
    # end of SoftDevice Controller
    # CONFIG_BT_RADIO_NOTIFICATION_CONN_CB is not set
    # BLE Libraries
    # CONFIG_BT_GATT_POOL is not set
    # CONFIG_BT_GATT_DM is not set
    # CONFIG_BT_ADV_PROV is not set
    # CONFIG_BT_FAST_PAIR is not set
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # CONFIG_BT_SCAN is not set
    # CONFIG_BT_CONN_CTX is not set
    # Bluetooth Services
    # CONFIG_BT_AMS_CLIENT is not set
    # CONFIG_BT_ANCS_CLIENT is not set
    # CONFIG_BT_BAS_CLIENT is not set
    # CONFIG_BT_BMS is not set
    # CONFIG_BT_CTS_CLIENT is not set
    # CONFIG_BT_DFU_SMP is not set
    # CONFIG_BT_GATTP is not set
    # CONFIG_BT_HIDS is not set
    # CONFIG_BT_HOGP is not set
    # CONFIG_BT_LBS is not set
    # CONFIG_BT_NSMS is not set
    # CONFIG_BT_NUS is not set
    # CONFIG_BT_NUS_CLIENT is not set
    # CONFIG_BT_RSCS is not set
    # CONFIG_BT_THROUGHPUT is not set
    # CONFIG_BT_LATENCY is not set
    # CONFIG_BT_LATENCY_CLIENT is not set
    # CONFIG_BT_HRS_CLIENT is not set
    # CONFIG_BT_DDFS is not set
    # CONFIG_BT_MDS is not set
    # CONFIG_BT_CGMS is not set
    # end of Bluetooth Services
    # BLE over nRF RPC
    CONFIG_HEAP_MEM_POOL_SIZE=0
    # CONFIG_BT_SHELL is not set
    CONFIG_BT_CONN_DYNAMIC_CALLBACKS=y
    # CONFIG_BT_RPC_STACK is not set
    CONFIG_BT_CENTRAL=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_OBSERVER=y
    CONFIG_BT_BROADCASTER=y
    CONFIG_BT_CONN=y
    CONFIG_BT_REMOTE_VERSION=y
    CONFIG_BT_PHY_UPDATE=y
    # CONFIG_BT_DATA_LEN_UPDATE is not set
    # CONFIG_BT_EXT_ADV is not set
    CONFIG_BT_BUF_ACL_RX_COUNT_EXTRA=2
    CONFIG_BT_HAS_HCI_VS=y
    # CONFIG_BT_HCI_MESH_EXT is not set
    # CONFIG_BT_WAIT_NOP is not set
    CONFIG_BT_RPA=y
    CONFIG_BT_ASSERT=y
    CONFIG_BT_ASSERT_VERBOSE=y
    # CONFIG_BT_ASSERT_PANIC is not set
    # CONFIG_BT_HCI_ERR_TO_STR is not set
    CONFIG_BT_DEBUG_NONE=y
    # CONFIG_BT_DEBUG_MONITOR_UART is not set
    # CONFIG_BT_LONG_WQ is not set
    # CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
    CONFIG_BT_HCI_TX_PRIO=7
    # CONFIG_BT_RECV_WORKQ_SYS is not set
    CONFIG_BT_RECV_WORKQ_BT=y
    CONFIG_BT_RX_PRIO=8
    CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
    CONFIG_BT_TX_PROCESSOR_THREAD=y
    CONFIG_BT_TX_PROCESSOR_THREAD_PRIO=-1
    # CONFIG_BT_CONN_TX_NOTIFY_WQ is not set
    # CONFIG_BT_HOST_CCM is not set
    # CONFIG_BT_LOG_SNIFFER_INFO is not set
    # CONFIG_BT_TESTING is not set
    # CONFIG_BT_HCI_VS_EVT_USER is not set
    CONFIG_BT_BUF_SYNC_EVT_POOL_COUNT=1
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    # CONFIG_DFU_TARGET is not set
    # end of DFU
    # CONFIG_ESB is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # DECT NR+ libraries
    # end of DECT NR+ libraries
    # CONFIG_NRF_CLOUD is not set
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOADER is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    # CONFIG_MQTT_HELPER is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
    # end of Application protocols
    # CONFIG_OPENTHREAD_RPC is not set
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # CONFIG_NFC_RPC is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    # CONFIG_FW_INFO is not set
    # Debug
    # CONFIG_NRF_CPU_LOAD is not set
    # CONFIG_PPI_TRACE is not set
    CONFIG_PPI_TRACE_PIN_CNT=8
    # end of Debug
    # CONFIG_SHELL_BT_NUS is not set
    # Multiprotocol service layer (MPSL)
    # CONFIG_MPSL_FEM_ONLY is not set
    CONFIG_MPSL_FEM_API_AVAILABLE=y
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    CONFIG_MPSL_THREAD_COOP_PRIO=6
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    CONFIG_MPSL_LOW_PRIO_IRQN=25
    CONFIG_MPSL_HFCLK_LATENCY=1400
    CONFIG_MPSL_INIT_PRIORITY=40
    # CONFIG_MPSL_USE_EXTERNAL_CLOCK_CONTROL is not set
    # end of Multiprotocol service layer (MPSL)
    # Partition Manager
    # CONFIG_PARTITION_MANAGER_ENABLED is not set
    CONFIG_SRAM_SIZE=128
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    # Zephyr subsystem configurations
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_EXTERNAL_FLASH_PATH=""
    CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
    # CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x20000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # Full Modem Firmware Update Management(FMFU)
    # end of Full Modem Firmware Update Management(FMFU)
    # Additional MCUmgr configuration
    # Additional MCUmgr group configuration
    # Additional MCUmgr OS group management functionality
    # end of Additional MCUmgr OS group management functionality
    # Additional MCUmgr image management group functionality
    # end of Additional MCUmgr image management group functionality
    # end of Additional MCUmgr group configuration
    # end of Additional MCUmgr configuration
    # CONFIG_CAF is not set
    # CONFIG_DM_MODULE is not set
    # nRF Security
    # CONFIG_PSA_CRYPTO is not set
    # Nordic-added meta types
    # Nordic added alg types
    # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
    # CONFIG_PSA_WANT_ALG_ED25519PH is not set
    # CONFIG_PSA_WANT_ALG_ED448PH is not set
    # CONFIG_PSA_WANT_ALG_HSS is not set
    # CONFIG_PSA_WANT_ALG_LMS is not set
    # CONFIG_PSA_WANT_ALG_ML_DSA is not set
    # CONFIG_PSA_WANT_ALG_DETERMINISTIC_ML_DSA is not set
    # CONFIG_PSA_WANT_ALG_HASH_ML_DSA is not set
    # CONFIG_PSA_WANT_ALG_DETERMINISTIC_HASH_ML_DSA is not set
    # CONFIG_PSA_WANT_ALG_XMSS is not set
    # CONFIG_PSA_WANT_ALG_XMSS_MT is not set
    # CONFIG_PSA_WANT_ALG_ML_KEM is not set
    # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    # CONFIG_PSA_WANT_ALG_SHA_256_192 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
    # CONFIG_PSA_WANT_ALG_ASCON_HASH256 is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
    # CONFIG_PSA_WANT_ALG_SRP_6 is not set
    # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_ALG_XTS is not set
    # CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CHACHA20 is not set
    # CONFIG_PSA_WANT_ALG_XCHACHA20_POLY1305 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE128_256 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_192 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_256 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
    # CONFIG_PSA_WANT_ALG_AES_KW is not set
    # CONFIG_PSA_WANT_ALG_AES_KWP is not set
    # CONFIG_PSA_WANT_ALG_WPA3_SAE_H2E is not set
    # CONFIG_PSA_WANT_ALG_WPA3_SAE_FIXED is not set
    # CONFIG_PSA_WANT_ALG_WPA3_SAE_GDH is not set
    # CONFIG_PSA_WANT_ALG_SHAKE128 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256 is not set
    # CONFIG_PSA_WANT_ALG_ASCON_XOF128 is not set
    # CONFIG_PSA_WANT_ALG_ASCON_CXOF128 is not set
    # CONFIG_PSA_WANT_ALG_ASCON_AEAD128 is not set
    # Nordic added ECC curve types
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
    # Nordic addded RNG configuration
    # CONFIG_PSA_WANT_GENERATE_RANDOM is not set
    # Nordic added key types
    # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_WPA3_SAE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_XCHACHA20 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_HSS_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_LMS_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_XMSS_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_XMSS_MT_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_44 is not set
    # CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_65 is not set
    # CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_87 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_512 is not set
    # CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_768 is not set
    # CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_1024 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ASCON is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_DERIVE is not set
    CONFIG_TF_PSA_CRYPTO_MODULE_DIR="/workspaces/modules/crypto/tf-psa-crypto"
    # end of nRF Security
    # Audio Modules
    # CONFIG_AUDIO_MODULE_TEST is not set
    # Log levels
    # end of Log levels
    # end of Audio Modules
    # Audio Modules
    # CONFIG_AUDIO_MODULE_TEMPLATE is not set
    # CONFIG_UART_ASYNC_ADAPTER is not set
    # CONFIG_TRUSTED_STORAGE is not set
    # Logging over RPC
    CONFIG_LOG_BACKED_RPC_CRASH_INFO_FILENAME_SIZE=255
    # end of Logging over RPC
    # CONFIG_DULT is not set
    # CONFIG_NRF_COMPRESS is not set
    # MCUboot IDs (informative only, do not change)
    CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_EXTRA_1_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_EXTRA_2_IMAGE_NUMBER=-1
    # end of MCUboot IDs (informative only, do not change)
    # end of Subsystems
    # CONFIG_BOOT_BANNER is not set
    # CONFIG_WFA_QT_CONTROL_APP is not set
    CONFIG_WFA_QT_THREAD_STACK_SIZE=5200
    CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
    CONFIG_WFA_QT_DEFAULT_INTERFACE="wlan0"
    CONFIG_WPAS_READY_TIMEOUT_MS=10000
    # Libraries
    # CONFIG_APP_JWT is not set
    # Binary libraries
    # end of Binary libraries
    # CONFIG_ACCEL_TO_ANGLE is not set
    # CONFIG_AT_MONITOR is not set
    # CONFIG_DISABLE_FLASH_PATCH is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x1000
    CONFIG_FPROTECT_BLOCK_SIZE=0x1000
    # CONFIG_FPROTECT is not set
    # CONFIG_AT_CMD_CUSTOM is not set
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_AT_PARSER is not set
    CONFIG_MULTITHREADING_LOCK=y
    # CONFIG_SMS is not set
    # CONFIG_SUPL_CLIENT_LIB is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    # CONFIG_LOCATION is not set
    # CONFIG_QOS is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY is not set
    # CONFIG_PCM_MIX is not set
    # CONFIG_TONE is not set
    # CONFIG_PSCM is not set
    # CONFIG_DATA_FIFO is not set
    # CONFIG_FEM_AL_LIB is not set
    # CONFIG_SAMPLE_RATE_CONVERTER is not set
    CONFIG_NCS_BOOT_BANNER=y
    CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
    CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
    CONFIG_DTM_TWOWIRE_TO_HCI_RECEIVER_TEST_VERSION=2
    CONFIG_DTM_TWOWIRE_TO_HCI_TRANSMITTER_TEST_VERSION=4
    # CONFIG_NRF_802154_CALLBACKS_DISPATCHER is not set
    CONFIG_NRF_802154_CALLBACKS_DISPATCHER_INIT_PRIORITY=80
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    # Configure DECT NR+ stack below DECT NR+ HAL
    # CONFIG_DECT is not set
    # end of Configure DECT NR+ stack below DECT NR+ HAL
    CONFIG_CLOCK_CONTROL_MPSL=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_ETH_RTT is not set
    # CONFIG_PPI_SEQ is not set
    # CONFIG_SENSOR is not set
    # CONFIG_NRF_SW_LPUART is not set
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    # CONFIG_VTF_MONITORING is not set
    # end of Device Drivers
    # External libraries
    # end of External libraries
    # Test
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # CONFIG_MOCK_NRF_RPC is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (/workspaces/nrf)
    # mcuboot (/workspaces/bootloader/mcuboot)
    # MCUboot
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    # CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY is not set
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (/workspaces/bootloader/mcuboot)
    CONFIG_ZEPHYR_QCBOR_MODULE=y
    CONFIG_ZEPHYR_T_COSE_MODULE=y
    # mbedtls (/workspaces/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    CONFIG_MBEDTLS_VERSION_4_x=y
    # end of mbedtls (/workspaces/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
    # trusted-firmware-m (/workspaces/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    # end of trusted-firmware-m (/workspaces/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
    # cjson (/workspaces/modules/lib/cjson)
    # CONFIG_CJSON_LIB is not set
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (/workspaces/modules/lib/cjson)
    # azure-sdk-for-c (/workspaces/modules/lib/azure-sdk-for-c)
    # CONFIG_AZURE_SDK is not set
    CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    # end of azure-sdk-for-c (/workspaces/modules/lib/azure-sdk-for-c)
    # cirrus-logic (/workspaces/modules/hal/cirrus-logic)
    # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
    CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    # end of cirrus-logic (/workspaces/modules/hal/cirrus-logic)
    # openthread (/workspaces/modules/lib/openthread)
    # CONFIG_OPENTHREAD is not set
    CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    # end of openthread (/workspaces/modules/lib/openthread)
    # nrf_wifi (/workspaces/modules/lib/nrf_wifi)
    CONFIG_ZEPHYR_NRF_WIFI_MODULE=y
    # CONFIG_NRF70_BUSLIB is not set
    CONFIG_ZEPHYR_NRF_WIFI_MODULE_BLOBS=y
    # end of nrf_wifi (/workspaces/modules/lib/nrf_wifi)
    # memfault-firmware-sdk (/workspaces/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (/workspaces/modules/lib/memfault-firmware-sdk)
    # coremark (/workspaces/modules/benchmark/coremark)
    # CONFIG_COREMARK is not set
    CONFIG_ZEPHYR_COREMARK_MODULE=y
    # end of coremark (/workspaces/modules/benchmark/coremark)
    # hostap (/workspaces/modules/lib/hostap)
    # CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
    CONFIG_ZEPHYR_HOSTAP_MODULE=y
    # end of hostap (/workspaces/modules/lib/hostap)
    # canopennode (/workspaces/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (/workspaces/modules/lib/canopennode)
    # chre (/workspaces/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (/workspaces/modules/lib/chre)
    # cmsis (/workspaces/modules/hal/cmsis)
    CONFIG_ZEPHYR_CMSIS_MODULE=y
    CONFIG_HAS_CMSIS_CORE=y
    # end of cmsis (/workspaces/modules/hal/cmsis)
    # cmsis-dsp (/workspaces/modules/lib/cmsis-dsp)
    CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
    # CONFIG_CMSIS_DSP is not set
    # end of cmsis-dsp (/workspaces/modules/lib/cmsis-dsp)
    # cmsis-nn (/workspaces/modules/lib/cmsis-nn)
    CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
    # CONFIG_CMSIS_NN is not set
    # end of cmsis-nn (/workspaces/modules/lib/cmsis-nn)
    # cmsis_6 (/workspaces/modules/hal/cmsis_6)
    CONFIG_ZEPHYR_CMSIS_6_MODULE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
    # end of cmsis_6 (/workspaces/modules/hal/cmsis_6)
    # dhara (/workspaces/modules/lib/dhara)
    CONFIG_ZEPHYR_DHARA_MODULE=y
    # end of dhara (/workspaces/modules/lib/dhara)
    # fatfs (/workspaces/modules/fs/fatfs)
    CONFIG_ZEPHYR_FATFS_MODULE=y
    # end of fatfs (/workspaces/modules/fs/fatfs)
    # hal_nordic (/workspaces/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    # CONFIG_NRF_802154_SER_RADIO is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # CONFIG_NRFX_CLOCK is not set
    # CONFIG_NRFX_COMP is not set
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    CONFIG_NRFX_GPIOTE=y
    CONFIG_NRFX_GPPI=y
    # CONFIG_NRFX_GPPI_V1 is not set
    # CONFIG_NRFX_I2S is not set
    # CONFIG_NRFX_KMU is not set
    # CONFIG_NRFX_LPCOMP is not set
    # CONFIG_NRFX_NFCT is not set
    # CONFIG_NRFX_NVMC is not set
    # CONFIG_NRFX_PDM is not set
    # CONFIG_NRFX_POWER is not set
    # CONFIG_NRFX_PWM is not set
    # CONFIG_NRFX_QDEC is not set
    # CONFIG_NRFX_RNG is not set
    # CONFIG_NRFX_RTC is not set
    # CONFIG_NRFX_SAADC is not set
    # CONFIG_NRFX_SPI is not set
    # CONFIG_NRFX_SPIM is not set
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TDM is not set
    # CONFIG_NRFX_TEMP is not set
    # CONFIG_NRFX_TIMER is not set
    # CONFIG_NRFX_TWI is not set
    # CONFIG_NRFX_TWIM is not set
    # CONFIG_NRFX_TWIS is not set
    # CONFIG_NRFX_UART is not set
    # CONFIG_NRFX_UARTE is not set
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # CONFIG_NRFX_PRS_BOX_5 is not set
    # CONFIG_NRFX_PRS_BOX_6 is not set
    # CONFIG_NRFX_PRS_BOX_7 is not set
    # CONFIG_NRFX_PRS_BOX_8 is not set
    # CONFIG_NRFX_PRS_BOX_9 is not set
    # end of Peripheral Resource Sharing module
    CONFIG_NRFX_RESERVED_RESOURCES_HEADER="nrfx_reserved_resources_ncs.h"
    # end of nrfx drivers
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE_BLOBS=y
    # end of hal_nordic (/workspaces/modules/hal/nordic)
    # hal_st (/workspaces/modules/hal/st)
    CONFIG_ZEPHYR_HAL_ST_MODULE=y
    # end of hal_st (/workspaces/modules/hal/st)
    # hal_tdk (/workspaces/modules/hal/tdk)
    CONFIG_ZEPHYR_HAL_TDK_MODULE=y
    # TDK drivers
    # CONFIG_TDK_HAL is not set
    # end of TDK drivers
    # end of hal_tdk (/workspaces/modules/hal/tdk)
    CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
    # liblc3 (/workspaces/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBLC3_MODULE=y
    # end of liblc3 (/workspaces/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBMETAL_MODULE=y
    # libsbc (/workspaces/modules/lib/libsbc)
    CONFIG_ZEPHYR_LIBSBC_MODULE=y
    # CONFIG_LIBSBC is not set
    # end of libsbc (/workspaces/modules/lib/libsbc)
    # littlefs (/workspaces/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (/workspaces/modules/fs/littlefs)
    # loramac-node (/workspaces/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (/workspaces/modules/lib/loramac-node)
    # lvgl (/workspaces/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (/workspaces/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
    CONFIG_ZEPHYR_MLDSA_NATIVE_MODULE=y
    # nanopb (/workspaces/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (/workspaces/modules/lib/nanopb)
    CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
    # percepio (/workspaces/modules/debug/percepio)
    # Percepio Tracealyzer support can be enabled from the tracing subsystem
    # CONFIG_PERCEPIO_DFM is not set
    CONFIG_ZEPHYR_PERCEPIO_MODULE=y
    # end of percepio (/workspaces/modules/debug/percepio)
    # picolibc (/workspaces/modules/lib/picolibc)
    # CONFIG_PICOLIBC_MODULE is not set
    CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    # end of picolibc (/workspaces/modules/lib/picolibc)
    # segger (/workspaces/modules/debug/segger)
    CONFIG_ZEPHYR_SEGGER_MODULE=y
    CONFIG_HAS_SEGGER_RTT=y
    # CONFIG_USE_SEGGER_RTT is not set
    # end of segger (/workspaces/modules/debug/segger)
    CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
    CONFIG_ZEPHYR_TF_PSA_CRYPTO_MODULE=y
    # uoscore-uedhoc (/workspaces/modules/lib/uoscore-uedhoc)
    CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    # end of uoscore-uedhoc (/workspaces/modules/lib/uoscore-uedhoc)
    # zcbor (/workspaces/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    # CONFIG_ZCBOR is not set
    # end of zcbor (/workspaces/modules/lib/zcbor)
    # nrfxlib (/workspaces/nrfxlib)
    # Nordic nrfxlib
    # nrf_modem (Modem library)
    # end of nrf_modem (Modem library)
    CONFIG_NFC_LIBRARY_SOURCE_NRFXLIB=y
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    CONFIG_MPSL=y
    CONFIG_MPSL_BUILD_TYPE_LIB=y
    CONFIG_MPSL_LIB_DIR="nrf52"
    CONFIG_MPSL_LIB_FLOAT_ABI_DIR="soft-float"
    # Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_OBERON is not set
    # CONFIG_NRF_CC310_BL is not set
    # end of Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_GZLL is not set
    # CONFIG_NRF_DM is not set
    # CONFIG_NRF_FUEL_GAUGE is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (/workspaces/nrfxlib)
    CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
    # connectedhomeip (/workspaces/modules/lib/matter)
    # CONFIG_CHIP is not set
    # CONFIG_CHIP_CUSTOM_BLE_ADV_DATA is not set
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (/workspaces/modules/lib/matter)
    # CONFIG_LIBMETAL is not set
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    # CONFIG_HAS_MEC5_HAL is not set
    # CONFIG_OPENAMP is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    # CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
    # Unavailable modules, please install those via the project manifest.
    # hal_bouffalolab module not available.
    # hal_gigadevice module not available.
    # hal_nxp module not available.
    # Trusted-firmware-a module not available.
    # LoRa Basics Modem module not available.
    # THRIFT module not available.
    # CONFIG_ACPI is not set
    # end of Modules
    CONFIG_BOARD="client_sensor"
    CONFIG_BOARD_REVISION=""
    CONFIG_BOARD_TARGET="client_sensor/nrf52833"
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_CLIENT_SENSOR=y
    CONFIG_BOARD_CLIENT_SENSOR_NRF52833=y
    CONFIG_BOARD_QUALIFIERS="nrf52833"
    # Board Options
    # end of Board Options
    # Hardware Configuration
    CONFIG_SOC="nrf52833"
    CONFIG_SOC_SERIES="nrf52"
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_SOC_FAMILY_NORDIC_NRF=y
    CONFIG_SOC_SERIES_NRF52=y
    CONFIG_SOC_NRF52833=y
    CONFIG_SOC_NRF52833_QIAA=y
    # CONFIG_HWINFO is not set
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_COMPATIBLE_NRF52X=y
    CONFIG_SOC_COMPATIBLE_NRF52833=y
    CONFIG_HAS_HW_NRF_ACL=y
    CONFIG_HAS_HW_NRF_CCM=y
    CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
    CONFIG_HAS_HW_NRF_CCM_HEADERMASK=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_ECB=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIO1=y
    CONFIG_HAS_HW_NRF_GPIOTE0=y
    CONFIG_HAS_HW_NRF_MWU=y
    CONFIG_HAS_HW_NRF_NVMC_PE=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_PPI=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
    CONFIG_HAS_HW_NRF_RADIO_DFE=y
    CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
    CONFIG_HAS_HW_NRF_RADIO_TX_PWR_HIGH=y
    CONFIG_HAS_HW_NRF_RNG=y
    CONFIG_HAS_HW_NRF_SWI0=y
    CONFIG_HAS_HW_NRF_SWI1=y
    CONFIG_HAS_HW_NRF_SWI2=y
    CONFIG_HAS_HW_NRF_SWI3=y
    CONFIG_HAS_HW_NRF_SWI4=y
    CONFIG_HAS_HW_NRF_SWI5=y
    CONFIG_HAS_HW_NRF_TEMP=y
    CONFIG_HAS_HW_NRF_UARTE0=y
    CONFIG_HAS_NORDIC_RAM_CTRL=y
    # CONFIG_NRF_FORCE_RAM_ON_REBOOT is not set
    # CONFIG_NRF_SYS_EVENT is not set
    # CONFIG_IS_IRONSIDE_SE_SECONDARY_IMAGE is not set
    # CONFIG_IS_GEN_UICR_IMAGE is not set
    CONFIG_NRF_ENABLE_ICACHE=y
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    # CONFIG_SOC_NRF54H20_PM_S2RAM_OVERRIDE is not set
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    CONFIG_NRF_APPROTECT_USE_UICR=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_TRACE_PORT is not set
    # CONFIG_NRF_PLATFORM_HALTIUM is not set
    # CONFIG_NRF_PLATFORM_LUMOS is not set
    CONFIG_GPIO_INIT_PRIORITY=40
    # end of Hardware Configuration
    CONFIG_ARCH="arm"
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_CPU_CORTEX=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    # CONFIG_MPU_ALLOW_FLASH_WRITE is not set
    # ARM Options
    CONFIG_CPU_CORTEX_M=y
    # CONFIG_ARM_ZIMAGE_HEADER is not set
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    # CONFIG_PLATFORM_SPECIFIC_INIT is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M4=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DWT is not set
    # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
    # CONFIG_ARM_GCC_FP_WORKAROUND is not set
    CONFIG_MPU_STACK_GUARD=y
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    # CONFIG_ARM_MPU_SRAM_WRITE_THROUGH is not set
    CONFIG_HAS_SWO=y
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    CONFIG_ARCH_SUPPORTS_ROM_OFFSET=y
    # CONFIG_EXCEPTION_DUMP_HOOK is not set
    CONFIG_ARM_MPU=y
    CONFIG_LITTLE_ENDIAN=y
    # CONFIG_USERSPACE is not set
    # CONFIG_NOINIT_SNIPPET_FIRST is not set
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # CONFIG_FRAME_POINTER is not set
    # Interrupt Configuration
    # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
    CONFIG_ARCH_DEVICE_STATE_ALIGN=4
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    CONFIG_GEN_SW_ISR_TABLE_ARRAY=y
    # CONFIG_GEN_SW_ISR_TABLE_SWITCH is not set
    # CONFIG_SRAM_SW_ISR_TABLE is not set
    CONFIG_EXCEPTION_DEBUG=y
    # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_VECTOR_TABLE_RELOCATION=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
    CONFIG_ARCH_SUPPORTS_COREDUMP_STACK_PTR=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_SUPPORTS_ROM_START=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MPU=y
    CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # DSP Options
    # end of DSP Options
    # Floating Point Options
    # end of Floating Point Options
    # Cache Options
    # CONFIG_CACHE_DOUBLEMAP is not set
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    # General Kernel Options
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-128
    # CONFIG_SCHED_DEADLINE is not set
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    # CONFIG_DYNAMIC_THREAD is not set
    CONFIG_SCHED_SIMPLE=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_SIMPLE=y
    # Misc Kernel related options
    CONFIG_LIBC_ERRNO=y
    CONFIG_ERRNO=y
    CONFIG_CURRENT_THREAD_USE_TLS=y
    # CONFIG_NONZERO_SPINLOCK_SIZE is not set
    # end of Misc Kernel related options
    # Kernel Debugging and Metrics
    CONFIG_BOOT_DELAY=0
    # CONFIG_BOOT_CLEAR_SCREEN is not set
    # CONFIG_THREAD_MONITOR is not set
    # CONFIG_THREAD_NAME is not set
    # CONFIG_THREAD_RUNTIME_STATS is not set
    # CONFIG_THREAD_RUNTIME_STACK_SAFETY is not set
    # end of Kernel Debugging and Metrics
    # CONFIG_OBJ_CORE is not set
    # CONFIG_WORKQUEUE_WORK_TIMEOUT is not set
    # System Work Queue Options
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    CONFIG_SYSTEM_WORKQUEUE_WORK_TIMEOUT_MS=5000
    # end of System Work Queue Options
    # Barrier Operations
    CONFIG_BARRIER_OPERATIONS_ARCH=y
    # end of Barrier Operations
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    # CONFIG_TIMER_OBSERVER is not set
    # end of Timer API Options
    # Other Kernel Object Options
    # CONFIG_POLL is not set
    CONFIG_MEM_SLAB_POINTER_VALIDATE=y
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    # CONFIG_EVENTS is not set
    # CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
    # end of Other Kernel Object Options
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    # Security Options
    CONFIG_STACK_POINTER_RANDOM=0
    # end of Security Options
    # Memory Domains
    CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
    CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
    # end of Memory Domains
    # SMP Options
    # CONFIG_USE_SWITCH is not set
    CONFIG_USE_SWITCH_SUPPORTED=y
    # CONFIG_TICKET_SPINLOCKS is not set
    # end of SMP Options
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_THREAD_LOCAL_STORAGE=y
    CONFIG_TOOLCHAIN_SUPPORTS_STATIC_INIT_GNU=y
    # CONFIG_STATIC_INIT_GNU is not set
    # CONFIG_BOOTARGS is not set
    # end of General Kernel Options
    # Device Options
    # CONFIG_DEVICE_MUTABLE is not set
    # CONFIG_DEVICE_DT_METADATA is not set
    # CONFIG_DEVICE_DEINIT_SUPPORT is not set
    # end of Device Options
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_LIBC=35
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Virtual Memory Support
    # MMU Features
    # end of MMU Features
    # end of Virtual Memory Support
    # SoC and Board Hooks
    # CONFIG_SOC_EARLY_RESET_HOOK is not set
    # CONFIG_SOC_PREP_HOOK is not set
    # CONFIG_SOC_LATE_INIT_HOOK is not set
    # CONFIG_SOC_PER_CORE_INIT_HOOK is not set
    # CONFIG_BOARD_EARLY_INIT_HOOK is not set
    # CONFIG_BOARD_LATE_INIT_HOOK is not set
    # end of SoC and Board Hooks
    # Device Drivers
    # CONFIG_ADC is not set
    # CONFIG_AUDIO is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_BBRAM is not set
    # CONFIG_BIOMETRICS is not set
    CONFIG_BT_DRIVERS=y
    # Bluetooth HCI Driver Options
    CONFIG_BT_HCI_INIT_PRIORITY=50
    # CONFIG_BT_NXP_CTRL_WAKE_ON_BT is not set
    CONFIG_BT_DRV_TX_STACK_SIZE=256
    CONFIG_BT_DRV_RX_STACK_SIZE=768
    # CONFIG_CAN is not set
    # CONFIG_CHARGER is not set
    # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    CONFIG_CLOCK_CONTROL_NRF_FORCE_ALT=y
    CONFIG_CLOCK_CONTROL_NRF=y
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_FREQUENCY=32768
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    CONFIG_CLOCK_CONTROL_TISCI_PRIORITY=40
    # CONFIG_COMPARATOR is not set
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_CRC_DRIVER is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DAC is not set
    # CONFIG_DAI is not set
    # CONFIG_DEBUG_DRIVER is not set
    # CONFIG_DISK_DRIVERS is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_DMA is not set
    # CONFIG_DP_DRIVER is not set
    # CONFIG_EDAC is not set
    # CONFIG_EEPROM is not set
    CONFIG_ENTROPY_GENERATOR=y
    CONFIG_ENTROPY_INIT_PRIORITY=50
    CONFIG_ENTROPY_NRF5_RNG=y
    # CONFIG_ENTROPY_NRF5_BIAS_CORRECTION is not set
    CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8
    CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
    CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16
    CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
    CONFIG_ENTROPY_HAS_DRIVER=y
    # CONFIG_ESPI is not set
    # CONFIG_MDIO is not set
    # Firmware drivers
    # CONFIG_ARM_SCMI is not set
    # end of Firmware drivers
    CONFIG_FLASH_FILL_GENERIC_IMPLEMENTATION=y
    # CONFIG_FPGA is not set
    # CONFIG_FUEL_GAUGE is not set
    # CONFIG_GNSS is not set
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRFX_INTERRUPT=y
    # CONFIG_HAPTICS is not set
    # CONFIG_HWSPINLOCK is not set
    # CONFIG_I2C is not set
    # CONFIG_I2S is not set
    # CONFIG_I3C is not set
    # Interrupt controller drivers
    CONFIG_INTC_INIT_PRIORITY=40
    # end of Interrupt controller drivers
    # CONFIG_IPM is not set
    # CONFIG_LED is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LORA is not set
    # CONFIG_MBOX is not set
    # CONFIG_MIPI_DBI is not set
    # Miscellaneous drivers
    # Interconn Drivers
    # end of Interconn Drivers
    # CONFIG_TIMEAWARE_GPIO is not set
    # end of Miscellaneous drivers
    # CONFIG_MM_DRV is not set
    # CONFIG_MSPI is not set
    # CONFIG_OPAMP is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_PECI is not set
    CONFIG_PINCTRL=y
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    # CONFIG_PINCTRL_KEEP_SLEEP_STATE is not set
    # CONFIG_PINCTRL_MCHP_COMMON is not set
    # CONFIG_PINCTRL_NPCX_EX is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_PS2 is not set
    # CONFIG_PSI5 is not set
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_PWM is not set
    # CONFIG_RETAINED_MEM is not set
    # CONFIG_RTC is not set
    # CONFIG_SDHC is not set
    # CONFIG_SENT is not set
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    CONFIG_SERIAL_INIT_PRIORITY=50
    # CONFIG_UART_ASYNC_API is not set
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # CONFIG_UART_ASYNC_RX_HELPER is not set
    # Serial Drivers
    # CONFIG_UART_NPCX_FIFO_EX is not set
    CONFIG_UART_NRFX=y
    CONFIG_UART_NRFX_UARTE=y
    # CONFIG_UART_NRFX_UARTE_NO_IRQ is not set
    # CONFIG_UART_NRFX_UARTE_ENHANCED_RX is not set
    # CONFIG_UART_NRFX_UARTE_DIRECT_ISR is not set
    CONFIG_UART_0_ENHANCED_POLL_OUT=y
    # CONFIG_UART_0_NRF_PARITY_BIT is not set
    CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
    # CONFIG_SMBUS is not set
    # CONFIG_STEPPER is not set
    # Timer drivers
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
    CONFIG_NRF_RTC_TIMER=y
    CONFIG_NRF_RTC_TIMER_LOCK_ZERO_LATENCY_IRQS=y
    # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
    CONFIG_NRF_RTC_COUNTER_BIT_WIDTH=24
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # end of Timer drivers
    # CONFIG_UAOL is not set
    # CONFIG_USB_BC12 is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_UHC_DRIVER is not set
    # CONFIG_UVB is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # USB common
    # CONFIG_NRF_USBD_COMMON is not set
    # end of USB common
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_USBC_PPC_DRIVER is not set
    # CONFIG_VIDEO is not set
    # CONFIG_VIRTIO is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_W1 is not set
    CONFIG_NET_BUF_ALIGNMENT=0
    # CONFIG_WUC is not set
    # CONFIG_TEE is not set
    # CONFIG_REQUIRES_FULL_LIBC is not set
    # CONFIG_REQUIRES_FLOAT_PRINTF is not set
    # CONFIG_LIBC_ALLOW_LESS_THAN_64BIT_TIME is not set
    CONFIG_FULL_LIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC_SUPPORTED=y
    CONFIG_PICOLIBC_SUPPORTED=y
    # C Library
    # CONFIG_MINIMAL_LIBC is not set
    CONFIG_PICOLIBC=y
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_COMMON_LIBC_ABORT=y
    # CONFIG_COMMON_LIBC_ASCTIME_R is not set
    # CONFIG_COMMON_LIBC_CTIME_R is not set
    CONFIG_COMMON_LIBC_TIME=y
    CONFIG_COMMON_LIBC_MALLOC=y
    CONFIG_COMMON_LIBC_CALLOC=y
    CONFIG_COMMON_LIBC_REALLOCARRAY=y
    # CONFIG_COMMON_LIBC_REMOVE is not set
    # CONFIG_PICOLIBC_USE_MODULE is not set
    CONFIG_PICOLIBC_USE_TOOLCHAIN=y
    # CONFIG_PICOLIBC_IO_FLOAT is not set
    CONFIG_PICOLIBC_IO_LONG_LONG=y
    CONFIG_NEED_LIBC_MEM_PARTITION=y
    # end of C Library
    # C++ Language Support
    # CONFIG_CPP is not set
    # end of C++ Language Support
    # Additional libraries
    # Hash Function Support
    # CONFIG_SYS_HASH_FUNC32 is not set
    # end of Hash Function Support
    # Hashmap (Hash Table) Support
    # CONFIG_SYS_HASH_MAP is not set
    # end of Hashmap (Hash Table) Support
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_VALIDATE is not set
    # CONFIG_SYS_HEAP_STRESS is not set
    # CONFIG_SYS_HEAP_INFO is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    CONFIG_SYS_HEAP_ARRAY_SIZE=0
    # CONFIG_SYS_HEAP_LISTENER is not set
    # CONFIG_SYS_HEAP_HARDENING_NONE is not set
    # CONFIG_SYS_HEAP_HARDENING_BASIC is not set
    CONFIG_SYS_HEAP_HARDENING_MODERATE=y
    # CONFIG_SYS_HEAP_HARDENING_FULL is not set
    # CONFIG_SYS_HEAP_HARDENING_EXTREME is not set
    CONFIG_SYS_HEAP_HARDENING_LEVEL=2
    CONFIG_SYS_HEAP_SMALL_ONLY=y
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    # CONFIG_SYS_HEAP_AUTO is not set
    # CONFIG_MULTI_HEAP is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # end of Heap and Memory Allocation
    # Memory Blocks
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Memory Blocks
    # MIDI2
    # CONFIG_MIDI2_UMP_STREAM_RESPONDER is not set
    # end of MIDI2
    CONFIG_NET_BUF=y
    # CONFIG_NET_BUF_LOG is not set
    # CONFIG_NET_BUF_POOL_USAGE is not set
    # OS Support Library
    # CONFIG_ZVFS_OPEN_IGNORE_MIN is not set
    # CONFIG_PRINTK_SYNC is not set
    # CONFIG_MPSC_PBUF is not set
    # CONFIG_SPSC_PBUF is not set
    CONFIG_HAS_POWEROFF=y
    # CONFIG_POWEROFF is not set
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    # CONFIG_CBPRINTF_FP_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    # CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
    CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
    # CONFIG_ZVFS is not set
    # CONFIG_CPU_LOAD_METRIC is not set
    # end of OS Support Library
    # POSIX API Support
    # CONFIG_POSIX_SYSTEM_INTERFACES is not set
    # CONFIG_POSIX_API is not set
    # CONFIG_POSIX_AEP_CHOICE_NONE is not set
    CONFIG_POSIX_AEP_CHOICE_ZEPHYR=y
    # CONFIG_POSIX_AEP_CHOICE_BASE is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE51 is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE52 is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE53 is not set
    CONFIG_TC_PROVIDES_POSIX_C_LANG_SUPPORT_R=y
    # POSIX C Library Extensions
    CONFIG_POSIX_C_LANG_SUPPORT_R=y
    CONFIG_POSIX_C_LIB_EXT=y
    # end of POSIX C Library Extensions
    # end of POSIX API Support
    # CONFIG_EVENTFD is not set
    # CONFIG_SMF is not set
    CONFIG_LIBGCC_RTLIB=y
    # Utility Library
    # CONFIG_JSON_LIBRARY is not set
    CONFIG_RING_BUFFER=y
    # CONFIG_RING_BUFFER_LARGE is not set
    CONFIG_NOTIFY=y
    # CONFIG_BASE64 is not set
    CONFIG_ONOFF=y
    # CONFIG_UTF8 is not set
    # CONFIG_COBS is not set
    CONFIG_GETOPT=y
    # CONFIG_GETOPT_LONG is not set
    CONFIG_TIMEUTIL_APPLY_SKEW=y
    # end of Utility Library
    # CONFIG_UUID is not set
    # CONFIG_MIN_HEAP is not set
    # end of Additional libraries
    # Subsystems and OS Services
    # CONFIG_BINDESC is not set
    CONFIG_BT=y
    CONFIG_BT_HCI=y
    # CONFIG_BT_CUSTOM is not set
    CONFIG_BT_HCI_RAW=y
    # CONFIG_BT_HCI_RAW_CMD_EXT is not set
    CONFIG_BT_CONN_TX=y
    # CONFIG_BT_LE_EXTENDED_FEAT_SET is not set
    # CONFIG_BT_SCA_UPDATE is not set
    # CONFIG_BT_TRANSMIT_POWER_CONTROL is not set
    # CONFIG_BT_PATH_LOSS_MONITORING is not set
    # CONFIG_BT_SUBRATING is not set
    # CONFIG_BT_ISO_PERIPHERAL is not set
    # CONFIG_BT_ISO_CENTRAL is not set
    # CONFIG_BT_ISO_BROADCASTER is not set
    # CONFIG_BT_ISO_SYNC_RECEIVER is not set
    # Bluetooth buffer configuration
    # end of Bluetooth buffer configuration
    # Bluetooth Host
    # Bluetooth Classic Options
    # end of Bluetooth Classic Options
    # end of Bluetooth Host
    CONFIG_BT_CTLR_ENTROPY_SUPPORT=y
    CONFIG_BT_CTLR_CRYPTO_SUPPORT=y
    CONFIG_BT_CTLR_LE_ENC_SUPPORT=y
    CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT=y
    CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_PRIVACY_SUPPORT=y
    CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT=y
    CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_PHY_2M_SUPPORT=y
    CONFIG_BT_CTLR_PHY_CODED_SUPPORT=y
    CONFIG_BT_CTLR_ADV_EXT_SUPPORT=y
    CONFIG_BT_CTLR_ADV_EXT_CODING_SELECTION_SUPPORT=y
    CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT=y
    CONFIG_BT_CTLR_ADV_PERIODIC_RSP_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_PERIODIC_RSP_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_TRANSFER_RECEIVER_SUPPORT=y
    CONFIG_BT_CTLR_ADV_ISO_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_ISO_SUPPORT=y
    CONFIG_BT_CTLR_CENTRAL_ISO_SUPPORT=y
    CONFIG_BT_CTLR_PERIPHERAL_ISO_SUPPORT=y
    CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT=y
    CONFIG_BT_CTLR_SCA_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_CONN_RSSI_SUPPORT=y
    CONFIG_BT_CTLR_LE_POWER_CONTROL_SUPPORT=y
    CONFIG_BT_CTLR_LE_PATH_LOSS_MONITORING_SUPPORT=y
    CONFIG_BT_CTLR_SUBRATING_SUPPORT=y
    CONFIG_BT_CTLR_FRAME_SPACE_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_EXTENDED_FEAT_SET_SUPPORT=y
    CONFIG_BT_CTLR_SHORTER_CONNECTION_INTERVALS_SUPPORT=y
    CONFIG_HAS_BT_CTLR=y
    CONFIG_BT_CTLR_HCI=y
    CONFIG_BT_CTLR_HCI_NUM_CMD_PKT_MAX=1
    # Bluetooth Controller configuration
    CONFIG_BT_CTLR_ENTROPY=y
    CONFIG_BT_CTLR_CRYPTO=y
    CONFIG_BT_CTLR_HCI_VS_BUILD_INFO=""
    # CONFIG_BT_CTLR_TX_PWR_PLUS_8 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_7 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_6 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_5 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_4 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_3 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_2 is not set
    CONFIG_BT_CTLR_TX_PWR_0=y
    # CONFIG_BT_CTLR_TX_PWR_MINUS_4 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_8 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_12 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_16 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_20 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_40 is not set
    CONFIG_BT_CTLR_TX_PWR_DBM=0
    CONFIG_BT_CTLR_TX_PWR_ANTENNA=0
    # CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL is not set
    # Bluetooth Controller features
    CONFIG_BT_CTLR_LE_ENC=y
    CONFIG_BT_CTLR_EXT_REJ_IND=y
    CONFIG_BT_CTLR_LE_PING=y
    CONFIG_BT_CTLR_PHY=y
    CONFIG_BT_CTLR_CONN_RSSI=y
    # CONFIG_BT_CTLR_LE_POWER_CONTROL is not set
    CONFIG_BT_CTLR_FILTER_ACCEPT_LIST=y
    CONFIG_BT_CTLR_PRIVACY=y
    CONFIG_BT_CTLR_RL_SIZE=8
    CONFIG_BT_CTLR_EXT_SCAN_FP=y
    CONFIG_BT_CTLR_PHY_2M=y
    CONFIG_BT_CTLR_CHAN_SEL_2=y
    # CONFIG_BT_CTLR_ADV_EXT is not set
    # CONFIG_BT_CTLR_SET_HOST_FEATURE is not set
    # CONFIG_BT_CTLR_HCI_CODEC_AND_DELAY_INFO is not set
    # CONFIG_BT_CTLR_SUBRATING is not set
    CONFIG_BT_CTLR_DF_CTE_TX_SUPPORT=y
    CONFIG_BT_CTLR_DTM_HCI_SUPPORT=y
    CONFIG_BT_CTLR_DTM=y
    # CONFIG_BT_CTLR_DTM_HCI_RX_V3 is not set
    CONFIG_BT_CTLR_DTM_HCI_TX_V3=y
    CONFIG_BT_CTLR_DTM_HCI_TX_V4=y
    CONFIG_BT_CTLR_ASSERT_DEBUG=y
    # CONFIG_BT_CTLR_ASSERT_HANDLER is not set
    # CONFIG_BT_CTLR_VS_SCAN_REQ_RX is not set
    # CONFIG_BT_EAD is not set
    # Controller Area Network (CAN) bus subsystem
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # CONFIG_CPU_FREQ is not set
    # CONFIG_CRC is not set
    # CONFIG_DAP is not set
    # System Monitoring Options
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_UBSAN is not set
    # CONFIG_STACK_USAGE is not set
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    CONFIG_ASSERT_LEVEL=2
    # CONFIG_ASSERT_CUSTOM_HEADER is not set
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_THREAD_INFO is not set
    # CONFIG_DEBUG_COREDUMP is not set
    # CONFIG_SYMTAB is not set
    # end of Debugging Options
    # CONFIG_MIPI_STP_DECODER is not set
    # CONFIG_CS_TRACE_DEFMT is not set
    # CONFIG_CPU_LOAD is not set
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_DSP is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    # CONFIG_FILE_SYSTEM_LIB_LINK is not set
    # CONFIG_FILE_SYSTEM is not set
    # end of File Systems
    # CONFIG_GNSS_RTK is not set
    # CONFIG_INSTRUMENTATION is not set
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    # CONFIG_IPC_SERVICE is not set
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # Key-Value Storage Systems
    # end of Key-Value Storage Systems
    # CONFIG_LLEXT is not set
    # CONFIG_LLEXT_EDK is not set
    # Logging
    # CONFIG_LOG_OUTPUT is not set
    # end of Logging
    CONFIG_MEM_ATTR=y
    # CONFIG_MEM_ATTR_HEAP is not set
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # CONFIG_MODEM_MODULES is not set
    # Networking
    # CONFIG_NETWORKING is not set
    # end of Networking
    # Power Management
    # CONFIG_PM_POLICY_LATENCY_STANDALONE is not set
    # end of Power Management
    # Platform Management Communications Infrastructure (PMCI)
    # CONFIG_MCTP is not set
    # end of Platform Management Communications Infrastructure (PMCI)
    # Portability
    # end of Portability
    # CONFIG_PROFILING is not set
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
    CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
    # CONFIG_XOSHIRO_RANDOM_GENERATOR is not set
    CONFIG_ENTROPY_NODE_ENABLED=y
    # CONFIG_CSPRNG_NEEDED is not set
    CONFIG_CSPRNG_ENABLED=y
    CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
    # end of Random Number Generators
    # CONFIG_RTIO is not set
    # SD
    # CONFIG_MMC_STACK is not set
    # CONFIG_SDMMC_STACK is not set
    # CONFIG_SDIO_STACK is not set
    # end of SD
    # CONFIG_SECURE_STORAGE is not set
    # CONFIG_SETTINGS is not set
    # CONFIG_SHELL is not set
    # CONFIG_STATS is not set
    # Storage
    # CONFIG_STREAM_FLASH is not set
    # end of Storage
    # CONFIG_TASK_WDT is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # benchmarking options
    # CONFIG_ZTEST_BENCHMARK is not set
    # end of benchmarking options
    # CONFIG_TEST is not set
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    # Coverage
    # CONFIG_FORCE_COVERAGE is not set
    CONFIG_COVERAGE_DUMP_PATH_EXCLUDE=""
    # end of Coverage
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # CONFIG_USB_DEVICE_STACK is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_USB_HOST_STACK is not set
    # CONFIG_USBC_STACK is not set
    # CONFIG_ZBUS is not set
    # CONFIG_MODULES is not set
    # end of Subsystems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_1_0=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_GNU_EXTENSIONS=y
    CONFIG_PICOLIBC_DEFAULT=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_FLASH_LOAD_SIZE=0
    CONFIG_ROM_END_OFFSET=0
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    # end of Linker Sections
    CONFIG_LINKER_ITERABLE_SUBALIGN=4
    CONFIG_LINKER_DEVNULL_SUPPORT=y
    # CONFIG_LINKER_DEVNULL_MEMORY is not set
    # end of Linker Options
    # Compiler Options
    # CONFIG_STD_C90 is not set
    # CONFIG_STD_C99 is not set
    # CONFIG_STD_C11 is not set
    CONFIG_STD_C17=y
    # CONFIG_STD_C23 is not set
    CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
    # CONFIG_GNU_C_EXTENSIONS is not set
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_COMPILER_FREESTANDING is not set
    CONFIG_SIZE_OPTIMIZATIONS=y
    # CONFIG_SIZE_OPTIMIZATIONS_AGGRESSIVE is not set
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # CONFIG_NO_OPTIMIZATIONS is not set
    # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # CONFIG_DEPRECATION_TEST is not set
    # CONFIG_COMPILER_SAVE_TEMPS is not set
    CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    # CONFIG_FORTIFY_SOURCE_NONE is not set
    CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    CONFIG_TOOLCHAIN_SUPPORTS_VLA_IN_STATEMENTS=y
    CONFIG_TOOLCHAIN_SUPPORTS_VARIABLE_CLEANUP_ATTRIBUTE=y
    # CONFIG_SCOPE_CLEANUP_HELPERS is not set
    # Code Generation
    CONFIG_COMPILER_CODEGEN_VLIW_AUTO=y
    # CONFIG_COMPILER_CODEGEN_VLIW_ENABLED is not set
    # CONFIG_COMPILER_CODEGEN_VLIW_DISABLED is not set
    # end of Code Generation
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    CONFIG_BUILD_GAP_FILL_PATTERN=0xFF
    # CONFIG_BUILD_NO_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_HEX_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_VERILOG is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_MOT is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
    # CONFIG_BUILD_ALIGN_LMA is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    # CONFIG_BUILD_OUTPUT_META is not set
    CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    CONFIG_CHECK_INIT_PRIORITIES=y
    # CONFIG_EMIT_ALL_SYSCALLS is not set
    # end of Build Options
    CONFIG_WARN_DEPRECATED=y
    CONFIG_TAINT=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    # Compatibility
    CONFIG_LEGACY_GENERATED_INCLUDE_PATH=y
    # end of Compatibility
    zephyr.map:
    Archive member included to satisfy reference by file (symbol)
    app/libapp.a(dtm_twowire_transport.c.obj)
                                  (--whole-archive)
    app/libapp.a(main.c.obj)      (--whole-archive)
    zephyr/libzephyr.a(validate_libc.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(heap.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(cbprintf_packaged.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(clock.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(printk.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(sem.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(thread_entry.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(cbprintf_complete.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(assert.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(reboot.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(dec.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(hex.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(rb.c.obj)  (--whole-archive)
    zephyr/libzephyr.a(set.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(timeutil.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(bitarray.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(bitmask.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(getopt.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(getopt_common.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(onoff.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(notify.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(ring_buffer.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(last_section_id.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(configs.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(mem_attr.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(tracing_none.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(banner.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(hci_vs_sdc.c.obj)
                                  (--whole-archive)
    zephyr/libzephyr.a(host_extensions.c.obj)
                                  (--whole-archive)
    zephyr/arch/common/libarch__common.a(sw_isr_common.c.obj)
                                  (--whole-archive)
    zephyr/arch/common/libarch__common.a(init.c.obj)
                                  (--whole-archive)
    zephyr/arch/common/libarch__common.a(xip.c.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/libarch__arm__core.a(fatal.c.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi.c.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi_on_reset.S.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/libarch__arm__core.a(tls.c.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault_s.S.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fpu.c.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(reset.S.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(vector_table.S.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(svc.S.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(prep_c.c.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(cpu_idle.c.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(exc_exit.c.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread_abort.c.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(swap_helper.S.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_init.c.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(isr_wrapper.c.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(__aeabi_read_tp.S.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_core_mpu.c.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
                                  (--whole-archive)
    zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu_regions.c.obj)
                                  (--whole-archive)
    zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(assert.c.obj)
                                  (--whole-archive)
    zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(cbprintf.c.obj)
                                  (--whole-archive)
    zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(chk_fail.c.obj)
                                  (--whole-archive)
    zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(errno_wrap.c.obj)
                                  (--whole-archive)
    zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(exit.c.obj)
                                  (--whole-archive)
    zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
                                  (--whole-archive)
    zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
                                  (--whole-archive)
    zephyr/lib/libc/common/liblib__libc__common.a(abort.c.obj)
                                  (--whole-archive)
    zephyr/lib/libc/common/liblib__libc__common.a(time.c.obj)
                                  (--whole-archive)
    zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
                                  (--whole-archive)
    zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(fnmatch.c.obj)
                                  (--whole-archive)
    zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getentropy.c.obj)
                                  (--whole-archive)
    zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
                                  (--whole-archive)
    zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
                                  (--whole-archive)
    zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
                                  (--whole-archive)
    zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_base_addresses.c.obj)
                                  (--whole-archive)
    zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_binding_headers.c.obj)
                                  (--whole-archive)
    zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_enabled_instances.c.obj)
                                  (--whole-archive)
    zephyr/soc/soc/nrf52833/libsoc__nordic.a(soc.c.obj)
                                  (--whole-archive)
    zephyr/soc/soc/nrf52833/libsoc__nordic.a(reboot.c.obj)
                                  (--whole-archive)
    zephyr/soc/soc/nrf52833/libsoc__nordic.a(gppi_init.c.obj)
                                  (--whole-archive)
    zephyr/soc/soc/nrf52833/libsoc__nordic.a(gpiote_nrfx.c.obj)
                                  (--whole-archive)
    zephyr/subsys/random/libsubsys__random.a(random_entropy_device.c.obj)
                                  (--whole-archive)
    zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
                                  (--whole-archive)
    zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(dummy.c.obj)
                                  (--whole-archive)
    zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
                                  (--whole-archive)
    zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(rpa.c.obj)
                                  (--whole-archive)
    zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
                                  (--whole-archive)
    zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_common.c.obj)
                                  (--whole-archive)
    zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
                                  (--whole-archive)
    zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
                                  (--whole-archive)
    zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
                                  (--whole-archive)
    zephyr/drivers/pinctrl/libdrivers__pinctrl.a(common.c.obj)
                                  (--whole-archive)
    zephyr/drivers/pinctrl/libdrivers__pinctrl.a(pinctrl_nrf.c.obj)
                                  (--whole-archive)
    zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
                                  (--whole-archive)
    zephyr/drivers/timer/libdrivers__timer.a(sys_clock_init.c.obj)
                                  (--whole-archive)
    zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
                                  (--whole-archive)
    modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a(multithreading_lock.c.obj)
                                  (--whole-archive)
    modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a(fatal_error.c.obj)
                                  (--whole-archive)
    modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
                                  (--whole-archive)
    modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
                                  (--whole-archive)
    modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
                                  (--whole-archive)
    modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal_wrappers.c.obj)
                                  (--whole-archive)
    modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(crypto.c.obj)
                                  (--whole-archive)
    modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
                                  (--whole-archive)
    modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a(mpsl_fem_api_init.c.obj)
                                  (--whole-archive)
    modules/nrf/subsys/mpsl/hwres/lib..__nrf__subsys__mpsl__hwres.a(mpsl_hwres.c.obj)
                                  (--whole-archive)
    modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
                                  (--whole-archive)
    modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(system_nrf52833.c.obj)
                                  (--whole-archive)
    modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj)
                                  (--whole-archive)
    modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_flag32_allocator.c.obj)
                                  (--whole-archive)
    modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
                                  (--whole-archive)
    modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
                                  (--whole-archive)
    modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
                                  (--whole-archive)
    zephyr/kernel/libkernel.a(busy_wait.c.obj)
                                  modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj) (z_impl_k_busy_wait)
    zephyr/kernel/libkernel.a(device.c.obj)
                                  app/libapp.a(dtm_twowire_transport.c.obj) (z_impl_device_is_ready)
    zephyr/kernel/libkernel.a(fatal.c.obj)
                                  zephyr/arch/arch/arm/core/libarch__arm__core.a(fatal.c.obj) (z_fatal_error)
    zephyr/kernel/libkernel.a(init.c.obj)
                                  zephyr/libzephyr.a(thread_entry.c.obj) (z_sys_post_kernel)
    zephyr/kernel/libkernel.a(kheap.c.obj)
                                  zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj) (k_heap_alloc)
    zephyr/kernel/libkernel.a(idle.c.obj)
                                  zephyr/kernel/libkernel.a(init.c.obj) (idle)
    zephyr/kernel/libkernel.a(mutex.c.obj)
                                  zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj) (z_impl_k_mutex_init)
    zephyr/kernel/libkernel.a(queue.c.obj)
                                  zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj) (k_queue_append)
    zephyr/kernel/libkernel.a(sem.c.obj)
                                  zephyr/libzephyr.a(sem.c.obj) (z_impl_k_sem_init)
    zephyr/kernel/libkernel.a(work.c.obj)
                                  modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj) (k_work_init)
    zephyr/kernel/libkernel.a(thread.c.obj)
                                  zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj) (k_is_in_isr)
    zephyr/kernel/libkernel.a(sched.c.obj)
                                  zephyr/kernel/libkernel.a(init.c.obj) (z_ready_thread)
    zephyr/kernel/libkernel.a(timeslicing.c.obj)
                                  zephyr/kernel/libkernel.a(sched.c.obj) (z_reset_time_slice)
    zephyr/kernel/libkernel.a(spinlock_validate.c.obj)
                                  zephyr/libzephyr.a(clock.c.obj) (z_spin_lock_valid)
    zephyr/kernel/libkernel.a(timeout.c.obj)
                                  zephyr/kernel/libkernel.a(init.c.obj) (z_add_timeout)
    zephyr/kernel/libkernel.a(mempool.c.obj)
                                  zephyr/kernel/libkernel.a(queue.c.obj) (k_free)
    zephyr/kernel/libkernel.a(banner.c.obj)
                                  zephyr/kernel/libkernel.a(init.c.obj) (boot_banner)
    zephyr/kernel/libkernel.a(system_work_q.c.obj)
                                  zephyr/kernel/libkernel.a(work.c.obj) (k_sys_work_q)
    /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                                  modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj) (sdc_hci_cmd_le_set_adv_enable)
    /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
                                  /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf) (mpsl_fem_caps_get)
    /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                                  modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj) (MPSL_IRQ_RADIO_Handler)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(strcmp.S.o)
                                  zephyr/kernel/libkernel.a(device.c.obj) (strcmp)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(strcpy.S.o)
                                  zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj) (strcpy)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(memcpy.c.o)
                                  zephyr/libzephyr.a(heap.c.obj) (memcpy)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(memset.c.o)
                                  zephyr/libzephyr.a(heap.c.obj) (memset)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(strlen.S.o)
                                  zephyr/libzephyr.a(cbprintf_packaged.c.obj) (strlen)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_errno_errno.c.o)
                                  zephyr/libzephyr.a(timeutil.c.obj) (errno)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_memcmp.c.o)
                                  zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(rpa.c.obj) (memcmp)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_strchr.c.o)
                                  zephyr/libzephyr.a(getopt.c.obj) (strchr)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_strncpy.c.o)
                                  modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj) (strncpy)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_strnlen.c.o)
                                  zephyr/libzephyr.a(cbprintf_complete.c.obj) (strnlen)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_puts.c.o)
                                  zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(exit.c.obj) (puts)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_snprintf.c.o)
                                  zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj) (snprintf)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflprintf.c.o)
                                  (__l_vfprintf)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflscanf.c.o)
                                  (__l_vfscanf)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_fgetc.c.o)
                                  /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflscanf.c.o) (getc)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_filestrput.c.o)
                                  /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_snprintf.c.o) (__file_str_put)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_ungetc.c.o)
                                  /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflscanf.c.o) (ungetc)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_muldf3.o)
                                  zephyr/libzephyr.a(timeutil.c.obj) (__aeabi_dmul)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_addsubdf3.o)
                                  zephyr/libzephyr.a(timeutil.c.obj) (__aeabi_dsub)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_muldivdf3.o)
                                  zephyr/libzephyr.a(timeutil.c.obj) (__aeabi_ddiv)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_truncdfsf2.o)
                                  zephyr/libzephyr.a(timeutil.c.obj) (__aeabi_d2f)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_cmpsf2.o)
                                  zephyr/libzephyr.a(timeutil.c.obj) (__aeabi_fcmpeq)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_aeabi_ldivmod.o)
                                  zephyr/libzephyr.a(timeutil.c.obj) (__aeabi_ldivmod)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_aeabi_uldivmod.o)
                                  zephyr/libzephyr.a(clock.c.obj) (__aeabi_uldivmod)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_popcountsi2.o)
                                  zephyr/libzephyr.a(bitarray.c.obj) (__popcountsi2)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_fixdfdi.o)
                                  zephyr/libzephyr.a(timeutil.c.obj) (__aeabi_d2lz)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_fixunsdfdi.o)
                                  /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_fixdfdi.o) (__aeabi_d2ulz)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_udivmoddi4.o)
                                  /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_aeabi_ldivmod.o) (__udivmoddi4)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_dvmd_tls.o)
                                  /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_aeabi_ldivmod.o) (__aeabi_ldiv0)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_cmpdf2.o)
                                  /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_fixdfdi.o) (__aeabi_dcmplt)
    /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_fixunsdfsi.o)
                                  /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_fixunsdfdi.o) (__aeabi_d2uiz)
    Discarded input sections
     .text          0x00000000        0x0 zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
     .data          0x00000000        0x0 zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
     .bss           0x00000000        0x0 zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
     .debug_line    0x00000000        0x0 zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
     .debug_str     0x00000000      0x1e7 zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
     .comment       0x00000000       0x20 zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
     .text          0x00000000        0x0 zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
     .data          0x00000000        0x0 zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
     .bss           0x00000000        0x0 zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
     .text          0x00000000        0x0 zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj
     .data          0x00000000        0x0 zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj
     .bss           0x00000000        0x0 zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj
     .text          0x00000000        0x0 app/libapp.a(dtm_twowire_transport.c.obj)
     .data          0x00000000        0x0 app/libapp.a(dtm_twowire_transport.c.obj)
     .bss           0x00000000        0x0 app/libapp.a(dtm_twowire_transport.c.obj)
     .text          0x00000000        0x0 app/libapp.a(main.c.obj)
     .data          0x00000000        0x0 app/libapp.a(main.c.obj)
     .bss           0x00000000        0x0 app/libapp.a(main.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(validate_libc.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(validate_libc.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(validate_libc.c.obj)
     .debug_info    0x00000000       0x79 zephyr/libzephyr.a(validate_libc.c.obj)
     .debug_abbrev  0x00000000       0x26 zephyr/libzephyr.a(validate_libc.c.obj)
     .debug_aranges
                    0x00000000       0x18 zephyr/libzephyr.a(validate_libc.c.obj)
     .debug_line    0x00000000       0x4c zephyr/libzephyr.a(validate_libc.c.obj)
     .debug_str     0x00000000      0x289 zephyr/libzephyr.a(validate_libc.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(validate_libc.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(heap.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(heap.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(heap.c.obj)
     .text.inplace_realloc.isra.0
                    0x00000000      0x14e zephyr/libzephyr.a(heap.c.obj)
     .text.sys_heap_usable_size
                    0x00000000       0x1a zephyr/libzephyr.a(heap.c.obj)
     .text.sys_heap_aligned_alloc
                    0x00000000      0x114 zephyr/libzephyr.a(heap.c.obj)
     .text.sys_heap_realloc
                    0x00000000       0x5c zephyr/libzephyr.a(heap.c.obj)
     .text.sys_heap_aligned_realloc
                    0x00000000       0xa4 zephyr/libzephyr.a(heap.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .rodata.cbvprintf_package.str1.1
                    0x00000000       0x9f zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .text.cbvprintf_package
                    0x00000000      0x3d0 zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .text.cbprintf_package
                    0x00000000       0x1e zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .text.cbpprintf_external
                    0x00000000       0x62 zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .text.is_ptr   0x00000000       0x3a zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .rodata.cbprintf_package_convert.str1.1
                    0x00000000       0x5a zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .text.cbprintf_package_convert
                    0x00000000      0x3d4 zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .debug_info    0x00000000     0x164e zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .debug_abbrev  0x00000000      0x4cb zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .debug_loc     0x00000000     0x242c zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .debug_aranges
                    0x00000000       0x40 zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .debug_ranges  0x00000000      0x2b8 zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .debug_line    0x00000000     0x1057 zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .debug_str     0x00000000      0x7a5 zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .debug_frame   0x00000000       0xec zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(clock.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(clock.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(clock.c.obj)
     .rodata.timespec_is_valid.str1.1
                    0x00000000       0x60 zephyr/libzephyr.a(clock.c.obj)
     .text.timespec_is_valid
                    0x00000000       0x3c zephyr/libzephyr.a(clock.c.obj)
     .rodata.timespec_compare.str1.1
                    0x00000000       0x56 zephyr/libzephyr.a(clock.c.obj)
     .text.timespec_compare
                    0x00000000       0xa0 zephyr/libzephyr.a(clock.c.obj)
     .text.timespec_add
                    0x00000000       0xb4 zephyr/libzephyr.a(clock.c.obj)
     .rodata.timespec_negate.part.0.str1.1
                    0x00000000       0x2d zephyr/libzephyr.a(clock.c.obj)
     .text.timespec_negate.part.0
                    0x00000000       0x28 zephyr/libzephyr.a(clock.c.obj)
     .text.sys_clock_from_clockid
                    0x00000000        0xa zephyr/libzephyr.a(clock.c.obj)
     .rodata.z_impl_sys_clock_getrtoffset.str1.1
                    0x00000000       0xce zephyr/libzephyr.a(clock.c.obj)
     .text.z_impl_sys_clock_getrtoffset
                    0x00000000       0xcc zephyr/libzephyr.a(clock.c.obj)
     .rodata.sys_clock_gettime.str1.1
                    0x00000000       0x16 zephyr/libzephyr.a(clock.c.obj)
     .text.sys_clock_gettime
                    0x00000000       0xa8 zephyr/libzephyr.a(clock.c.obj)
     .text.z_impl_sys_clock_settime
                    0x00000000       0xec zephyr/libzephyr.a(clock.c.obj)
     .rodata.z_impl_sys_clock_nanosleep.str1.1
                    0x00000000       0x2f zephyr/libzephyr.a(clock.c.obj)
     .text.z_impl_sys_clock_nanosleep
                    0x00000000      0x25c zephyr/libzephyr.a(clock.c.obj)
     .bss.rt_clock_offset_lock
                    0x00000000        0x4 zephyr/libzephyr.a(clock.c.obj)
                    0x00000000       0x10 zephyr/libzephyr.a(clock.c.obj)
     .rodata        0x00000000       0x20 zephyr/libzephyr.a(clock.c.obj)
     .debug_info    0x00000000     0x1685 zephyr/libzephyr.a(clock.c.obj)
     .debug_abbrev  0x00000000      0x471 zephyr/libzephyr.a(clock.c.obj)
     .debug_loc     0x00000000      0xa8e zephyr/libzephyr.a(clock.c.obj)
     .debug_aranges
     .debug_ranges  0x00000000      0x1b8 zephyr/libzephyr.a(clock.c.obj)
     .debug_line    0x00000000      0xc99 zephyr/libzephyr.a(clock.c.obj)
     .debug_str     0x00000000      0x8f3 zephyr/libzephyr.a(clock.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(clock.c.obj)
     .debug_frame   0x00000000      0x124 zephyr/libzephyr.a(clock.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(printk.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(printk.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(printk.c.obj)
     .text.__printk_hook_install
                    0x00000000        0xc zephyr/libzephyr.a(printk.c.obj)
     .text.__printk_get_hook
     .text.z_impl_k_str_out
                    0x00000000       0x1c zephyr/libzephyr.a(printk.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(sem.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(sem.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(sem.c.obj)
     .text.sys_sem_init
                    0x00000000        0xa zephyr/libzephyr.a(sem.c.obj)
     .text.sys_sem_give
     .text.sys_sem_take
                    0x00000000       0x1e zephyr/libzephyr.a(sem.c.obj)
     .text.sys_sem_count_get
                    0x00000000        0x4 zephyr/libzephyr.a(sem.c.obj)
     .debug_info    0x00000000      0x4fb zephyr/libzephyr.a(sem.c.obj)
     .debug_abbrev  0x00000000      0x22d zephyr/libzephyr.a(sem.c.obj)
     .debug_loc     0x00000000      0x24d zephyr/libzephyr.a(sem.c.obj)
     .debug_aranges
                    0x00000000       0x38 zephyr/libzephyr.a(sem.c.obj)
     .debug_ranges  0x00000000       0x70 zephyr/libzephyr.a(sem.c.obj)
     .debug_line    0x00000000      0x333 zephyr/libzephyr.a(sem.c.obj)
     .debug_str     0x00000000      0x3e5 zephyr/libzephyr.a(sem.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(sem.c.obj)
     .debug_frame   0x00000000       0x68 zephyr/libzephyr.a(sem.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(thread_entry.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(thread_entry.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(thread_entry.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(cbprintf_complete.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(cbprintf_complete.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(cbprintf_complete.c.obj)
     .text.encode_uint
                    0x00000000       0x90 zephyr/libzephyr.a(cbprintf_complete.c.obj)
     .rodata.z_cbvprintf_impl.str1.1
                    0x00000000        0x6 zephyr/libzephyr.a(cbprintf_complete.c.obj)
     .text.z_cbvprintf_impl
                    0x00000000      0x780 zephyr/libzephyr.a(cbprintf_complete.c.obj)
     .debug_info    0x00000000     0x10d5 zephyr/libzephyr.a(cbprintf_complete.c.obj)
     .debug_abbrev  0x00000000      0x3e9 zephyr/libzephyr.a(cbprintf_complete.c.obj)
     .debug_loc     0x00000000     0x16b3 zephyr/libzephyr.a(cbprintf_complete.c.obj)
     .debug_aranges
                    0x00000000       0x28 zephyr/libzephyr.a(cbprintf_complete.c.obj)
     .debug_ranges  0x00000000      0x288 zephyr/libzephyr.a(cbprintf_complete.c.obj)
     .debug_line    0x00000000      0xd5d zephyr/libzephyr.a(cbprintf_complete.c.obj)
     .debug_str     0x00000000      0x6af zephyr/libzephyr.a(cbprintf_complete.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(cbprintf_complete.c.obj)
     .debug_frame   0x00000000       0x68 zephyr/libzephyr.a(cbprintf_complete.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(assert.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(assert.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(assert.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(reboot.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(reboot.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(reboot.c.obj)
     .rodata.sys_reboot.str1.1
                    0x00000000       0x29 zephyr/libzephyr.a(reboot.c.obj)
     .text.sys_reboot
                    0x00000000       0x34 zephyr/libzephyr.a(reboot.c.obj)
     .debug_info    0x00000000      0x2dd zephyr/libzephyr.a(reboot.c.obj)
     .debug_abbrev  0x00000000      0x1c9 zephyr/libzephyr.a(reboot.c.obj)
     .debug_loc     0x00000000       0x39 zephyr/libzephyr.a(reboot.c.obj)
     .debug_aranges
                    0x00000000       0x20 zephyr/libzephyr.a(reboot.c.obj)
     .debug_ranges  0x00000000       0x40 zephyr/libzephyr.a(reboot.c.obj)
     .debug_line    0x00000000      0x3bd zephyr/libzephyr.a(reboot.c.obj)
     .debug_str     0x00000000      0x353 zephyr/libzephyr.a(reboot.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(reboot.c.obj)
     .debug_frame   0x00000000       0x28 zephyr/libzephyr.a(reboot.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(dec.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(dec.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(dec.c.obj)
     .text.u8_to_dec
                    0x00000000       0x42 zephyr/libzephyr.a(dec.c.obj)
     .debug_info    0x00000000      0x12b zephyr/libzephyr.a(dec.c.obj)
     .debug_abbrev  0x00000000       0x9c zephyr/libzephyr.a(dec.c.obj)
     .debug_loc     0x00000000      0x107 zephyr/libzephyr.a(dec.c.obj)
     .debug_aranges
                    0x00000000       0x20 zephyr/libzephyr.a(dec.c.obj)
     .debug_ranges  0x00000000       0x10 zephyr/libzephyr.a(dec.c.obj)
     .debug_line    0x00000000      0x1d9 zephyr/libzephyr.a(dec.c.obj)
     .debug_str     0x00000000      0x2bc zephyr/libzephyr.a(dec.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(dec.c.obj)
     .debug_frame   0x00000000       0x30 zephyr/libzephyr.a(dec.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(hex.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(hex.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(hex.c.obj)
     .text.char2hex
                    0x00000000       0x30 zephyr/libzephyr.a(hex.c.obj)
     .text.hex2char
                    0x00000000       0x1a zephyr/libzephyr.a(hex.c.obj)
     .text.bin2hex  0x00000000       0x40 zephyr/libzephyr.a(hex.c.obj)
     .text.hex2bin  0x00000000       0x70 zephyr/libzephyr.a(hex.c.obj)
     .debug_info    0x00000000      0x29d zephyr/libzephyr.a(hex.c.obj)
     .debug_abbrev  0x00000000      0x117 zephyr/libzephyr.a(hex.c.obj)
     .debug_loc     0x00000000      0x332 zephyr/libzephyr.a(hex.c.obj)
     .debug_aranges
                    0x00000000       0x38 zephyr/libzephyr.a(hex.c.obj)
     .debug_ranges  0x00000000       0x40 zephyr/libzephyr.a(hex.c.obj)
     .debug_line    0x00000000      0x355 zephyr/libzephyr.a(hex.c.obj)
     .debug_str     0x00000000      0x2c3 zephyr/libzephyr.a(hex.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(hex.c.obj)
     .debug_frame   0x00000000       0x74 zephyr/libzephyr.a(hex.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(rb.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(rb.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(rb.c.obj)
     .text.find_and_stack
                    0x00000000       0x3a zephyr/libzephyr.a(rb.c.obj)
     .text.stack_left_limb
                    0x00000000       0x40 zephyr/libzephyr.a(rb.c.obj)
     .text.set_child
                    0x00000000       0x12 zephyr/libzephyr.a(rb.c.obj)
     .text.rotate   0x00000000       0x80 zephyr/libzephyr.a(rb.c.obj)
     .text.z_rb_get_minmax
                    0x00000000       0x18 zephyr/libzephyr.a(rb.c.obj)
     .text.rb_insert
                    0x00000000      0x13c zephyr/libzephyr.a(rb.c.obj)
     .rodata.rb_remove.str1.1
                    0x00000000       0x74 zephyr/libzephyr.a(rb.c.obj)
     .text.rb_remove
                    0x00000000      0x344 zephyr/libzephyr.a(rb.c.obj)
     .text.z_rb_walk
                    0x00000000       0x24 zephyr/libzephyr.a(rb.c.obj)
     .text.z_rb_child
                    0x00000000        0xe zephyr/libzephyr.a(rb.c.obj)
     .text.z_rb_is_black
                    0x00000000        0x8 zephyr/libzephyr.a(rb.c.obj)
     .text.rb_contains
                    0x00000000       0x2c zephyr/libzephyr.a(rb.c.obj)
     .text.z_rb_foreach_next
                    0x00000000       0x5e zephyr/libzephyr.a(rb.c.obj)
     .debug_info    0x00000000     0x2651 zephyr/libzephyr.a(rb.c.obj)
     .debug_abbrev  0x00000000      0x4d4 zephyr/libzephyr.a(rb.c.obj)
     .debug_loc     0x00000000     0x23fc zephyr/libzephyr.a(rb.c.obj)
     .debug_aranges
                    0x00000000       0x78 zephyr/libzephyr.a(rb.c.obj)
     .debug_ranges  0x00000000      0x468 zephyr/libzephyr.a(rb.c.obj)
     .debug_line    0x00000000     0x1385 zephyr/libzephyr.a(rb.c.obj)
     .debug_str     0x00000000      0x4d3 zephyr/libzephyr.a(rb.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(rb.c.obj)
     .debug_frame   0x00000000      0x180 zephyr/libzephyr.a(rb.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(set.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(set.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(set.c.obj)
     .text.sys_set_find
                    0x00000000       0x10 zephyr/libzephyr.a(set.c.obj)
     .text.sys_set_union
                    0x00000000       0x2a zephyr/libzephyr.a(set.c.obj)
     .debug_info    0x00000000      0x17d zephyr/libzephyr.a(set.c.obj)
     .debug_abbrev  0x00000000       0xf9 zephyr/libzephyr.a(set.c.obj)
     .debug_loc     0x00000000       0x99 zephyr/libzephyr.a(set.c.obj)
     .debug_aranges
                    0x00000000       0x28 zephyr/libzephyr.a(set.c.obj)
     .debug_ranges  0x00000000       0x18 zephyr/libzephyr.a(set.c.obj)
     .debug_line    0x00000000      0x200 zephyr/libzephyr.a(set.c.obj)
     .debug_str     0x00000000      0x2ce zephyr/libzephyr.a(set.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(set.c.obj)
     .debug_frame   0x00000000       0x38 zephyr/libzephyr.a(set.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(timeutil.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(timeutil.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(timeutil.c.obj)
     .text.timeutil_timegm64
                    0x00000000       0xf0 zephyr/libzephyr.a(timeutil.c.obj)
                    0x00000000       0x20 zephyr/libzephyr.a(timeutil.c.obj)
     .text.timeutil_sync_state_update
                    0x00000000       0x5c zephyr/libzephyr.a(timeutil.c.obj)
     .text.timeutil_sync_state_set_skew
                    0x00000000       0x3a zephyr/libzephyr.a(timeutil.c.obj)
     .text.timeutil_sync_estimate_skew
                    0x00000000       0x96 zephyr/libzephyr.a(timeutil.c.obj)
     .text.timeutil_sync_ref_from_local
                    0x00000000       0xae zephyr/libzephyr.a(timeutil.c.obj)
     .text.timeutil_sync_local_from_ref
                    0x00000000       0xa8 zephyr/libzephyr.a(timeutil.c.obj)
     .text.timeutil_sync_skew_to_ppb
                    0x00000000       0x3c zephyr/libzephyr.a(timeutil.c.obj)
     .rodata.timespec_normalize.str1.1
                    0x00000000       0x6d zephyr/libzephyr.a(timeutil.c.obj)
     .text.timespec_normalize
                    0x00000000       0xc0 zephyr/libzephyr.a(timeutil.c.obj)
     .debug_info    0x00000000      0xa51 zephyr/libzephyr.a(timeutil.c.obj)
     .debug_abbrev  0x00000000      0x26a zephyr/libzephyr.a(timeutil.c.obj)
     .debug_loc     0x00000000      0x848 zephyr/libzephyr.a(timeutil.c.obj)
     .debug_aranges
                    0x00000000       0x60 zephyr/libzephyr.a(timeutil.c.obj)
     .debug_ranges  0x00000000       0xb0 zephyr/libzephyr.a(timeutil.c.obj)
     .debug_line    0x00000000      0x7b9 zephyr/libzephyr.a(timeutil.c.obj)
     .debug_str     0x00000000      0x5f4 zephyr/libzephyr.a(timeutil.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(timeutil.c.obj)
     .debug_frame   0x00000000      0x13c zephyr/libzephyr.a(timeutil.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(bitarray.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(bitarray.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(bitarray.c.obj)
     .text.setup_bundle_data.isra.0
                    0x00000000       0x3a zephyr/libzephyr.a(bitarray.c.obj)
     .text.match_region
                    0x00000000       0x64 zephyr/libzephyr.a(bitarray.c.obj)
     .rodata.is_region_set_clear.str1.1
                    0x00000000       0xf8 zephyr/libzephyr.a(bitarray.c.obj)
     .text.is_region_set_clear
                    0x00000000      0x100 zephyr/libzephyr.a(bitarray.c.obj)
     .text.set_region
                    0x00000000       0x90 zephyr/libzephyr.a(bitarray.c.obj)
     .text.set_clear_region
     .text.sys_bitarray_popcount_region
                    0x00000000      0x13c zephyr/libzephyr.a(bitarray.c.obj)
     .rodata.sys_bitarray_xor.str1.1
                    0x00000000       0x4e zephyr/libzephyr.a(bitarray.c.obj)
     .text.sys_bitarray_xor
                    0x00000000      0x1dc zephyr/libzephyr.a(bitarray.c.obj)
     .text.sys_bitarray_set_bit
                    0x00000000       0xec zephyr/libzephyr.a(bitarray.c.obj)
     .text.sys_bitarray_clear_bit
     .text.sys_bitarray_test_bit
     .text.sys_bitarray_test_and_set_bit
     .text.sys_bitarray_test_and_clear_bit
                    0x00000000      0x104 zephyr/libzephyr.a(bitarray.c.obj)
     .text.sys_bitarray_alloc
                    0x00000000      0x17c zephyr/libzephyr.a(bitarray.c.obj)
     .text.sys_bitarray_find_nth_set
                    0x00000000      0x164 zephyr/libzephyr.a(bitarray.c.obj)
     .text.sys_bitarray_free
                    0x00000000      0x148 zephyr/libzephyr.a(bitarray.c.obj)
     .text.sys_bitarray_is_region_set
                    0x00000000        0x6 zephyr/libzephyr.a(bitarray.c.obj)
     .text.sys_bitarray_is_region_cleared
     .text.sys_bitarray_test_and_set_region
                    0x00000000      0x120 zephyr/libzephyr.a(bitarray.c.obj)
     .text.sys_bitarray_set_region
     .text.sys_bitarray_clear_region
     .debug_info    0x00000000     0x3c22 zephyr/libzephyr.a(bitarray.c.obj)
     .debug_abbrev  0x00000000      0x46e zephyr/libzephyr.a(bitarray.c.obj)
     .debug_loc     0x00000000     0x376e zephyr/libzephyr.a(bitarray.c.obj)
     .debug_aranges
                    0x00000000       0xb8 zephyr/libzephyr.a(bitarray.c.obj)
     .debug_ranges  0x00000000      0x5a8 zephyr/libzephyr.a(bitarray.c.obj)
     .debug_line    0x00000000     0x2183 zephyr/libzephyr.a(bitarray.c.obj)
     .debug_str     0x00000000      0x721 zephyr/libzephyr.a(bitarray.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(bitarray.c.obj)
     .debug_frame   0x00000000      0x2b0 zephyr/libzephyr.a(bitarray.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(bitmask.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(bitmask.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(bitmask.c.obj)
     .text.bitmask_find_gap
                    0x00000000       0x76 zephyr/libzephyr.a(bitmask.c.obj)
     .debug_info    0x00000000      0x1f1 zephyr/libzephyr.a(bitmask.c.obj)
     .debug_abbrev  0x00000000      0x107 zephyr/libzephyr.a(bitmask.c.obj)
     .debug_loc     0x00000000      0x352 zephyr/libzephyr.a(bitmask.c.obj)
     .debug_aranges
                    0x00000000       0x20 zephyr/libzephyr.a(bitmask.c.obj)
     .debug_ranges  0x00000000       0x30 zephyr/libzephyr.a(bitmask.c.obj)
     .debug_line    0x00000000      0x312 zephyr/libzephyr.a(bitmask.c.obj)
     .debug_str     0x00000000      0x306 zephyr/libzephyr.a(bitmask.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(bitmask.c.obj)
     .debug_frame   0x00000000       0x30 zephyr/libzephyr.a(bitmask.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(getopt.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(getopt.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(getopt.c.obj)
     .rodata.sys_getopt_init.str1.1
                    0x00000000        0x1 zephyr/libzephyr.a(getopt.c.obj)
     .text.sys_getopt_init
                    0x00000000       0x48 zephyr/libzephyr.a(getopt.c.obj)
     .text.sys_getopt
                    0x00000000       0xf4 zephyr/libzephyr.a(getopt.c.obj)
     .debug_info    0x00000000      0x3b8 zephyr/libzephyr.a(getopt.c.obj)
     .debug_abbrev  0x00000000      0x1ae zephyr/libzephyr.a(getopt.c.obj)
     .debug_loc     0x00000000      0x134 zephyr/libzephyr.a(getopt.c.obj)
     .debug_aranges
                    0x00000000       0x28 zephyr/libzephyr.a(getopt.c.obj)
     .debug_ranges  0x00000000       0x18 zephyr/libzephyr.a(getopt.c.obj)
     .debug_line    0x00000000      0x438 zephyr/libzephyr.a(getopt.c.obj)
     .debug_str     0x00000000      0x4b3 zephyr/libzephyr.a(getopt.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(getopt.c.obj)
     .debug_frame   0x00000000       0x4c zephyr/libzephyr.a(getopt.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(getopt_common.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(getopt_common.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(getopt_common.c.obj)
     .text.z_getopt_global_state_update
                    0x00000000       0x38 zephyr/libzephyr.a(getopt_common.c.obj)
     .text.sys_getopt_state_get
                    0x00000000        0x8 zephyr/libzephyr.a(getopt_common.c.obj)
     .rodata.str1.1
                    0x00000000        0x1 zephyr/libzephyr.a(getopt_common.c.obj)
     .data.m_getopt_common_state
                    0x00000000       0x18 zephyr/libzephyr.a(getopt_common.c.obj)
     .bss.sys_getopt_optarg
                    0x00000000        0x4 zephyr/libzephyr.a(getopt_common.c.obj)
     .bss.sys_getopt_optreset
     .bss.sys_getopt_optopt
     .data.sys_getopt_optind
     .data.sys_getopt_opterr
     .debug_info    0x00000000      0x2b5 zephyr/libzephyr.a(getopt_common.c.obj)
     .debug_abbrev  0x00000000      0x159 zephyr/libzephyr.a(getopt_common.c.obj)
     .debug_loc     0x00000000       0x2b zephyr/libzephyr.a(getopt_common.c.obj)
     .debug_aranges
                    0x00000000       0x28 zephyr/libzephyr.a(getopt_common.c.obj)
     .debug_ranges  0x00000000       0x18 zephyr/libzephyr.a(getopt_common.c.obj)
     .debug_line    0x00000000      0x228 zephyr/libzephyr.a(getopt_common.c.obj)
     .debug_str     0x00000000      0x5c5 zephyr/libzephyr.a(getopt_common.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(getopt_common.c.obj)
     .debug_frame   0x00000000       0x30 zephyr/libzephyr.a(getopt_common.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(onoff.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(onoff.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(onoff.c.obj)
     .text.sys_slist_find_and_remove
                    0x00000000       0x36 zephyr/libzephyr.a(onoff.c.obj)
     .rodata.onoff_release.str1.1
                    0x00000000        0xe zephyr/libzephyr.a(onoff.c.obj)
     .text.onoff_release
                    0x00000000       0xd8 zephyr/libzephyr.a(onoff.c.obj)
     .text.onoff_reset
                    0x00000000       0xd4 zephyr/libzephyr.a(onoff.c.obj)
     .rodata.onoff_cancel.str1.1
                    0x00000000       0x77 zephyr/libzephyr.a(onoff.c.obj)
     .text.onoff_cancel
     .text.onoff_monitor_register
                    0x00000000       0xb0 zephyr/libzephyr.a(onoff.c.obj)
     .text.onoff_monitor_unregister
                    0x00000000       0xac zephyr/libzephyr.a(onoff.c.obj)
     .text.onoff_sync_lock
                    0x00000000       0x54 zephyr/libzephyr.a(onoff.c.obj)
     .rodata.onoff_sync_finalize.str1.1
                    0x00000000        0x3 zephyr/libzephyr.a(onoff.c.obj)
     .text.onoff_sync_finalize
                    0x00000000       0xb4 zephyr/libzephyr.a(onoff.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(notify.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(notify.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(notify.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(ring_buffer.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(ring_buffer.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(ring_buffer.c.obj)
     .text.ring_buf_area_claim
                    0x00000000       0x30 zephyr/libzephyr.a(ring_buffer.c.obj)
     .text.ring_buf_put_claim
                    0x00000000       0x1e zephyr/libzephyr.a(ring_buffer.c.obj)
     .text.ring_buf_get_claim
     .text.ring_buf_area_finish
                    0x00000000       0x32 zephyr/libzephyr.a(ring_buffer.c.obj)
     .rodata.ring_buf_put.str1.1
                    0x00000000       0x51 zephyr/libzephyr.a(ring_buffer.c.obj)
     .text.ring_buf_put
                    0x00000000       0x64 zephyr/libzephyr.a(ring_buffer.c.obj)
     .text.ring_buf_get
                    0x00000000       0x68 zephyr/libzephyr.a(ring_buffer.c.obj)
     .rodata.ring_buf_peek.str1.1
                    0x00000000       0x14 zephyr/libzephyr.a(ring_buffer.c.obj)
     .text.ring_buf_peek
                    0x00000000       0x7c zephyr/libzephyr.a(ring_buffer.c.obj)
     .rodata.ring_buf_item_put.str1.1
                    0x00000000       0x2d zephyr/libzephyr.a(ring_buffer.c.obj)
     .text.ring_buf_item_put
                    0x00000000       0xc8 zephyr/libzephyr.a(ring_buffer.c.obj)
     .text.ring_buf_item_get
                    0x00000000       0xd0 zephyr/libzephyr.a(ring_buffer.c.obj)
     .debug_info    0x00000000      0xf69 zephyr/libzephyr.a(ring_buffer.c.obj)
     .debug_abbrev  0x00000000      0x2da zephyr/libzephyr.a(ring_buffer.c.obj)
     .debug_loc     0x00000000      0xdf2 zephyr/libzephyr.a(ring_buffer.c.obj)
     .debug_aranges
                    0x00000000       0x60 zephyr/libzephyr.a(ring_buffer.c.obj)
     .debug_ranges  0x00000000       0xc0 zephyr/libzephyr.a(ring_buffer.c.obj)
     .debug_line    0x00000000      0x7f3 zephyr/libzephyr.a(ring_buffer.c.obj)
     .debug_str     0x00000000      0x4f4 zephyr/libzephyr.a(ring_buffer.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(ring_buffer.c.obj)
     .debug_frame   0x00000000      0x140 zephyr/libzephyr.a(ring_buffer.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(last_section_id.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(last_section_id.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(last_section_id.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(configs.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(configs.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(configs.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(mem_attr.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(mem_attr.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(mem_attr.c.obj)
     .text.mem_attr_check_buf
                    0x00000000        0xe zephyr/libzephyr.a(mem_attr.c.obj)
     .text.mem_attr_get_region_index_by_name
                    0x00000000        0x6 zephyr/libzephyr.a(mem_attr.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(tracing_none.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(tracing_none.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(tracing_none.c.obj)
     .text.sys_trace_isr_enter
                    0x00000000        0x2 zephyr/libzephyr.a(tracing_none.c.obj)
     .text.sys_trace_isr_exit
     .text.sys_trace_isr_exit_to_scheduler
     .text.sys_trace_idle
     .text.sys_trace_idle_exit
     .debug_info    0x00000000       0xb9 zephyr/libzephyr.a(tracing_none.c.obj)
     .debug_abbrev  0x00000000       0x5e zephyr/libzephyr.a(tracing_none.c.obj)
     .debug_aranges
                    0x00000000       0x40 zephyr/libzephyr.a(tracing_none.c.obj)
     .debug_ranges  0x00000000       0x30 zephyr/libzephyr.a(tracing_none.c.obj)
     .debug_line    0x00000000       0xa7 zephyr/libzephyr.a(tracing_none.c.obj)
     .debug_str     0x00000000      0x2f8 zephyr/libzephyr.a(tracing_none.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(tracing_none.c.obj)
     .debug_frame   0x00000000       0x60 zephyr/libzephyr.a(tracing_none.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(banner.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(banner.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(banner.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .text.hci_vs_cmd_with_rsp_only
                    0x00000000       0x2c zephyr/libzephyr.a(hci_vs_sdc.c.obj)
                    0x00000000       0x56 zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .text.hci_vs_cmd_no_rsp
                    0x00000000       0x36 zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .text.hci_vs_sdc_zephyr_read_version_info
                    0x00000000        0xc zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .text.hci_vs_sdc_zephyr_read_supported_commands
     .text.hci_vs_sdc_zephyr_write_bd_addr
     .text.hci_vs_sdc_zephyr_read_static_addresses
                    0x00000000       0x4c zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .text.hci_vs_sdc_zephyr_read_key_hierarchy_roots
     .text.hci_vs_sdc_zephyr_read_chip_temp
     .text.hci_vs_sdc_zephyr_write_tx_power
                    0x00000000       0x18 zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .text.hci_vs_sdc_zephyr_read_tx_power
                    0x00000000       0x1a zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .text.hci_vs_sdc_llpm_mode_set
     .text.hci_vs_sdc_conn_update
     .text.hci_vs_sdc_conn_event_extend
     .text.hci_vs_sdc_qos_conn_event_report_enable
     .text.hci_vs_sdc_event_length_set
     .text.hci_vs_sdc_periodic_adv_event_length_set
     .text.hci_vs_sdc_peripheral_latency_mode_set
     .text.hci_vs_sdc_write_remote_tx_power
     .text.hci_vs_sdc_set_adv_randomness
     .text.hci_vs_sdc_compat_mode_window_offset_set
     .text.hci_vs_sdc_qos_channel_survey_enable
     .text.hci_vs_sdc_set_power_control_request_params
     .text.hci_vs_sdc_read_average_rssi
     .text.hci_vs_sdc_central_acl_event_spacing_set
     .text.hci_vs_sdc_get_next_conn_event_counter
     .text.hci_vs_sdc_allow_parallel_connection_establishments
     .text.hci_vs_sdc_min_val_of_max_acl_tx_payload_set
     .text.hci_vs_sdc_iso_read_tx_timestamp
     .text.hci_vs_sdc_big_reserved_time_set
     .text.hci_vs_sdc_cig_reserved_time_set
     .text.hci_vs_sdc_cis_subevent_length_set
     .text.hci_vs_sdc_scan_channel_map_set
     .text.hci_vs_sdc_scan_accept_ext_adv_packets_set
     .text.hci_vs_sdc_set_role_priority
     .text.hci_vs_sdc_set_event_start_task
     .text.hci_vs_sdc_conn_anchor_point_update_event_report_enable
     .text.hci_vs_sdc_enable_periodic_adv_event_counter_reports
     .debug_info    0x00000000     0x1feb zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .debug_abbrev  0x00000000      0x3b2 zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .debug_loc     0x00000000      0xc75 zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .debug_aranges
                    0x00000000      0x148 zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .debug_ranges  0x00000000      0x138 zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .debug_line    0x00000000      0x8b0 zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .debug_str     0x00000000     0x1b8c zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .debug_frame   0x00000000      0x2e8 zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .text          0x00000000        0x0 zephyr/libzephyr.a(host_extensions.c.obj)
     .data          0x00000000        0x0 zephyr/libzephyr.a(host_extensions.c.obj)
     .bss           0x00000000        0x0 zephyr/libzephyr.a(host_extensions.c.obj)
     .debug_info    0x00000000       0x79 zephyr/libzephyr.a(host_extensions.c.obj)
     .debug_abbrev  0x00000000       0x26 zephyr/libzephyr.a(host_extensions.c.obj)
     .debug_aranges
                    0x00000000       0x18 zephyr/libzephyr.a(host_extensions.c.obj)
     .debug_line    0x00000000       0x63 zephyr/libzephyr.a(host_extensions.c.obj)
     .debug_str     0x00000000      0x2a0 zephyr/libzephyr.a(host_extensions.c.obj)
     .comment       0x00000000       0x20 zephyr/libzephyr.a(host_extensions.c.obj)
     .text          0x00000000        0x0 zephyr/arch/common/libarch__common.a(sw_isr_common.c.obj)
     .data          0x00000000        0x0 zephyr/arch/common/libarch__common.a(sw_isr_common.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/common/libarch__common.a(sw_isr_common.c.obj)
     .rodata.z_get_sw_isr_table_idx.str1.1
                    0x00000000       0x61 zephyr/arch/common/libarch__common.a(sw_isr_common.c.obj)
     .text.z_get_sw_isr_table_idx
                    0x00000000       0x28 zephyr/arch/common/libarch__common.a(sw_isr_common.c.obj)
     .debug_info    0x00000000      0x13b zephyr/arch/common/libarch__common.a(sw_isr_common.c.obj)
     .debug_abbrev  0x00000000       0xc3 zephyr/arch/common/libarch__common.a(sw_isr_common.c.obj)
     .debug_loc     0x00000000       0x70 zephyr/arch/common/libarch__common.a(sw_isr_common.c.obj)
     .debug_aranges
                    0x00000000       0x20 zephyr/arch/common/libarch__common.a(sw_isr_common.c.obj)
     .debug_ranges  0x00000000       0x10 zephyr/arch/common/libarch__common.a(sw_isr_common.c.obj)
     .debug_line    0x00000000       0xbd zephyr/arch/common/libarch__common.a(sw_isr_common.c.obj)
     .debug_str     0x00000000      0x2cd zephyr/arch/common/libarch__common.a(sw_isr_common.c.obj)
     .comment       0x00000000       0x20 zephyr/arch/common/libarch__common.a(sw_isr_common.c.obj)
     .debug_frame   0x00000000       0x28 zephyr/arch/common/libarch__common.a(sw_isr_common.c.obj)
     .text          0x00000000        0x0 zephyr/arch/common/libarch__common.a(init.c.obj)
     .data          0x00000000        0x0 zephyr/arch/common/libarch__common.a(init.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/common/libarch__common.a(init.c.obj)
     .text          0x00000000        0x0 zephyr/arch/common/libarch__common.a(xip.c.obj)
     .data          0x00000000        0x0 zephyr/arch/common/libarch__common.a(xip.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/common/libarch__common.a(xip.c.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/libarch__arm__core.a(fatal.c.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/libarch__arm__core.a(fatal.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/libarch__arm__core.a(fatal.c.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi.c.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi.c.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi_on_reset.S.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi_on_reset.S.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi_on_reset.S.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/libarch__arm__core.a(tls.c.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/libarch__arm__core.a(tls.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/libarch__arm__core.a(tls.c.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault_s.S.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault_s.S.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault_s.S.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fpu.c.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fpu.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fpu.c.obj)
     .text.z_arm_save_fp_context
                    0x00000000        0x2 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fpu.c.obj)
     .text.z_arm_restore_fp_context
     .debug_info    0x00000000      0x146 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fpu.c.obj)
     .debug_abbrev  0x00000000       0xcd zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fpu.c.obj)
     .debug_aranges
                    0x00000000       0x28 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fpu.c.obj)
     .debug_ranges  0x00000000       0x18 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fpu.c.obj)
     .debug_line    0x00000000      0x1a9 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fpu.c.obj)
     .debug_str     0x00000000      0x30e zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fpu.c.obj)
     .comment       0x00000000       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fpu.c.obj)
     .debug_frame   0x00000000       0x30 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fpu.c.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(reset.S.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(reset.S.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(reset.S.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
     .text.sys_arch_reboot
                    0x00000000       0x24 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
     .rodata.z_arm_save_scb_context.str1.1
                    0x00000000       0x64 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
     .text.z_arm_save_scb_context
                    0x00000000       0x5c zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
     .text.z_arm_restore_scb_context
                    0x00000000       0x6c zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(vector_table.S.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(vector_table.S.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(vector_table.S.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(svc.S.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(svc.S.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(svc.S.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(prep_c.c.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(prep_c.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(prep_c.c.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
     .text.arch_irq_lock_outlined
                    0x00000000       0x10 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(cpu_idle.c.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(cpu_idle.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(cpu_idle.c.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(exc_exit.c.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(exc_exit.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(exc_exit.c.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread_abort.c.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread_abort.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread_abort.c.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(swap_helper.S.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(swap_helper.S.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(swap_helper.S.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_init.c.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_init.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_init.c.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(isr_wrapper.c.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(isr_wrapper.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(isr_wrapper.c.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(__aeabi_read_tp.S.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(__aeabi_read_tp.S.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(__aeabi_read_tp.S.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_core_mpu.c.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_core_mpu.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_core_mpu.c.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .rodata.z_arm_save_mpu_context.str1.1
                    0x00000000       0x13 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .text.z_arm_save_mpu_context
                    0x00000000       0x78 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .text.z_arm_restore_mpu_context
                    0x00000000       0x70 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .text          0x00000000        0x0 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu_regions.c.obj)
     .data          0x00000000        0x0 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu_regions.c.obj)
     .bss           0x00000000        0x0 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu_regions.c.obj)
     .text          0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(assert.c.obj)
     .data          0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(assert.c.obj)
     .bss           0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(assert.c.obj)
     .rodata.__assert_no_args.str1.1
                    0x00000000       0x4d zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(assert.c.obj)
     .text.__assert_no_args
                    0x00000000       0x24 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(assert.c.obj)
     .debug_info    0x00000000      0x10f zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(assert.c.obj)
     .debug_abbrev  0x00000000       0x9c zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(assert.c.obj)
     .debug_aranges
                    0x00000000       0x20 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(assert.c.obj)
     .debug_ranges  0x00000000       0x10 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(assert.c.obj)
     .debug_line    0x00000000       0xb2 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(assert.c.obj)
     .debug_str     0x00000000      0x2c5 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(assert.c.obj)
     .comment       0x00000000       0x20 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(assert.c.obj)
     .debug_frame   0x00000000       0x28 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(assert.c.obj)
     .text          0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(cbprintf.c.obj)
     .data          0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(cbprintf.c.obj)
     .bss           0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(cbprintf.c.obj)
     .text.cbputc   0x00000000        0xc zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(cbprintf.c.obj)
     .text.cbvprintf
                    0x00000000       0x38 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(cbprintf.c.obj)
     .debug_info    0x00000000      0x31b zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(cbprintf.c.obj)
     .debug_abbrev  0x00000000      0x196 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(cbprintf.c.obj)
     .debug_loc     0x00000000      0x14c zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(cbprintf.c.obj)
     .debug_aranges
                    0x00000000       0x28 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(cbprintf.c.obj)
     .debug_ranges  0x00000000       0x18 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(cbprintf.c.obj)
     .debug_line    0x00000000      0x260 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(cbprintf.c.obj)
     .debug_str     0x00000000      0x347 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(cbprintf.c.obj)
     .comment       0x00000000       0x20 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(cbprintf.c.obj)
     .debug_frame   0x00000000       0x4c zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(cbprintf.c.obj)
     .text          0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(chk_fail.c.obj)
     .data          0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(chk_fail.c.obj)
     .bss           0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(chk_fail.c.obj)
     .rodata.__chk_fail.str1.1
                    0x00000000       0x1e zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(chk_fail.c.obj)
     .text.__chk_fail
                    0x00000000       0x1c zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(chk_fail.c.obj)
     .debug_info    0x00000000      0x1ba zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(chk_fail.c.obj)
     .debug_abbrev  0x00000000      0x14d zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(chk_fail.c.obj)
     .debug_loc     0x00000000       0x2c zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(chk_fail.c.obj)
     .debug_aranges
                    0x00000000       0x20 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(chk_fail.c.obj)
     .debug_ranges  0x00000000       0x10 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(chk_fail.c.obj)
     .debug_line    0x00000000      0x2dc zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(chk_fail.c.obj)
     .debug_str     0x00000000      0x36f zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(chk_fail.c.obj)
     .comment       0x00000000       0x20 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(chk_fail.c.obj)
     .debug_frame   0x00000000       0x28 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(chk_fail.c.obj)
     .text          0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(errno_wrap.c.obj)
     .data          0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(errno_wrap.c.obj)
     .bss           0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(errno_wrap.c.obj)
     .debug_info    0x00000000       0x79 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(errno_wrap.c.obj)
     .debug_abbrev  0x00000000       0x26 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(errno_wrap.c.obj)
     .debug_aranges
                    0x00000000       0x18 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(errno_wrap.c.obj)
     .debug_line    0x00000000       0x52 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(errno_wrap.c.obj)
     .debug_str     0x00000000      0x298 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(errno_wrap.c.obj)
     .comment       0x00000000       0x20 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(errno_wrap.c.obj)
     .text          0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(exit.c.obj)
     .data          0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(exit.c.obj)
     .bss           0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(exit.c.obj)
     .rodata._exit.str1.1
                    0x00000000        0x5 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(exit.c.obj)
     .text._exit    0x00000000       0x10 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(exit.c.obj)
     .debug_info    0x00000000       0xca zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(exit.c.obj)
     .debug_abbrev  0x00000000       0x82 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(exit.c.obj)
     .debug_loc     0x00000000       0x2b zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(exit.c.obj)
     .debug_aranges
                    0x00000000       0x20 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(exit.c.obj)
     .debug_ranges  0x00000000       0x10 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(exit.c.obj)
     .debug_line    0x00000000       0x7e zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(exit.c.obj)
     .debug_str     0x00000000      0x2b3 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(exit.c.obj)
     .comment       0x00000000       0x20 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(exit.c.obj)
     .debug_frame   0x00000000       0x28 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(exit.c.obj)
     .text          0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
     .data          0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
     .bss           0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
     .rodata.__retarget_lock_init_recursive.str1.1
                    0x00000000       0x96 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
     .text.__retarget_lock_init_recursive
                    0x00000000       0x58 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
                    0x00000000        0x4 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
     .text.__retarget_lock_close_recursive
                    0x00000000       0x2c zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
     .text.__retarget_lock_acquire_recursive
                    0x00000000       0x34 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
     .text.__retarget_lock_try_acquire_recursive
     .text.__retarget_lock_release_recursive
     ._k_mutex.static.__lock___libc_recursive_mutex_
                    0x00000000       0x14 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
     .debug_info    0x00000000      0xd3f zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
     .debug_abbrev  0x00000000      0x36d zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
     .debug_loc     0x00000000      0x364 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
     .debug_aranges
                    0x00000000       0x68 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
     .debug_ranges  0x00000000       0xb8 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
     .debug_line    0x00000000      0x654 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
     .debug_str     0x00000000      0x930 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
     .comment       0x00000000       0x20 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
     .debug_frame   0x00000000       0xe8 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
     .text          0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .data          0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .bss           0x00000000        0x0 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .text.z_impl_zephyr_fputc
                    0x00000000       0x10 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .text.picolibc_put
                    0x00000000        0xa zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .text.__stdout_hook_install
                    0x00000000       0x18 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .text.__stdin_hook_install
                    0x00000000       0x14 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .rodata.stdout
                    0x00000000        0x4 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .rodata.stdin  0x00000000        0x4 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .bss.__stdin   0x00000000       0x10 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .data.__stdout
     .bss._stdout_hook
     .debug_info    0x00000000      0x40d zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .debug_abbrev  0x00000000      0x205 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .debug_loc     0x00000000       0xf8 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .debug_aranges
                    0x00000000       0x38 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .debug_ranges  0x00000000       0x40 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .debug_line    0x00000000      0x30b zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .debug_str     0x00000000      0x59b zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .comment       0x00000000       0x20 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .debug_frame   0x00000000       0x60 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .text          0x00000000        0x0 zephyr/lib/libc/common/liblib__libc__common.a(abort.c.obj)
     .data          0x00000000        0x0 zephyr/lib/libc/common/liblib__libc__common.a(abort.c.obj)
     .bss           0x00000000        0x0 zephyr/lib/libc/common/liblib__libc__common.a(abort.c.obj)
     .rodata.abort.str1.1
                    0x00000000        0x9 zephyr/lib/libc/common/liblib__libc__common.a(abort.c.obj)
     .text.abort    0x00000000       0x1c zephyr/lib/libc/common/liblib__libc__common.a(abort.c.obj)
     .debug_info    0x00000000      0x1ba zephyr/lib/libc/common/liblib__libc__common.a(abort.c.obj)
     .debug_abbrev  0x00000000      0x14d zephyr/lib/libc/common/liblib__libc__common.a(abort.c.obj)
     .debug_loc     0x00000000       0x2c zephyr/lib/libc/common/liblib__libc__common.a(abort.c.obj)
     .debug_aranges
                    0x00000000       0x20 zephyr/lib/libc/common/liblib__libc__common.a(abort.c.obj)
     .debug_ranges  0x00000000       0x10 zephyr/lib/libc/common/liblib__libc__common.a(abort.c.obj)
     .debug_line    0x00000000      0x356 zephyr/lib/libc/common/liblib__libc__common.a(abort.c.obj)
     .debug_str     0x00000000      0x37e zephyr/lib/libc/common/liblib__libc__common.a(abort.c.obj)
     .comment       0x00000000       0x20 zephyr/lib/libc/common/liblib__libc__common.a(abort.c.obj)
     .debug_frame   0x00000000       0x28 zephyr/lib/libc/common/liblib__libc__common.a(abort.c.obj)
     .text          0x00000000        0x0 zephyr/lib/libc/common/liblib__libc__common.a(time.c.obj)
     .data          0x00000000        0x0 zephyr/lib/libc/common/liblib__libc__common.a(time.c.obj)
     .bss           0x00000000        0x0 zephyr/lib/libc/common/liblib__libc__common.a(time.c.obj)
     .text.time     0x00000000       0x28 zephyr/lib/libc/common/liblib__libc__common.a(time.c.obj)
     .debug_info    0x00000000      0x14f zephyr/lib/libc/common/liblib__libc__common.a(time.c.obj)
     .debug_abbrev  0x00000000       0xff zephyr/lib/libc/common/liblib__libc__common.a(time.c.obj)
     .debug_loc     0x00000000       0x44 zephyr/lib/libc/common/liblib__libc__common.a(time.c.obj)
     .debug_aranges
                    0x00000000       0x20 zephyr/lib/libc/common/liblib__libc__common.a(time.c.obj)
     .debug_ranges  0x00000000       0x10 zephyr/lib/libc/common/liblib__libc__common.a(time.c.obj)
     .debug_line    0x00000000      0x243 zephyr/lib/libc/common/liblib__libc__common.a(time.c.obj)
     .debug_str     0x00000000      0x2f0 zephyr/lib/libc/common/liblib__libc__common.a(time.c.obj)
     .comment       0x00000000       0x20 zephyr/lib/libc/common/liblib__libc__common.a(time.c.obj)
     .debug_frame   0x00000000       0x30 zephyr/lib/libc/common/liblib__libc__common.a(time.c.obj)
     .text          0x00000000        0x0 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .data          0x00000000        0x0 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .bss           0x00000000        0x0 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .rodata.malloc_lock.str1.1
                    0x00000000       0x65 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .text.malloc_lock
                    0x00000000       0x38 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .text.malloc_unlock
                    0x00000000        0xc zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .text.malloc   0x00000000       0x34 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .text.aligned_alloc
     .text.realloc  0x00000000       0x38 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .text.free     0x00000000       0x1c zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .text.calloc   0x00000000       0x34 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .text.reallocarray
                    0x00000000       0x24 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .data.z_malloc_heap_mutex
                    0x00000000       0x14 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .text          0x00000000        0x0 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(fnmatch.c.obj)
     .data          0x00000000        0x0 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(fnmatch.c.obj)
     .bss           0x00000000        0x0 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(fnmatch.c.obj)
     .text.foldcase
                    0x00000000       0x10 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(fnmatch.c.obj)
     .text.fnmatchx
                    0x00000000      0x4e8 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(fnmatch.c.obj)
     .text.fnmatch  0x00000000       0x14 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(fnmatch.c.obj)
     .debug_info    0x00000000      0x8d4 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(fnmatch.c.obj)
     .debug_abbrev  0x00000000      0x26a zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(fnmatch.c.obj)
     .debug_loc     0x00000000      0xb83 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(fnmatch.c.obj)
     .debug_aranges
                    0x00000000       0x30 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(fnmatch.c.obj)
     .debug_ranges  0x00000000       0xe8 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(fnmatch.c.obj)
     .debug_line    0x00000000      0x860 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(fnmatch.c.obj)
     .debug_str     0x00000000      0x36a zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(fnmatch.c.obj)
     .comment       0x00000000       0x20 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(fnmatch.c.obj)
     .debug_frame   0x00000000       0x68 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(fnmatch.c.obj)
     .text          0x00000000        0x0 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getentropy.c.obj)
     .data          0x00000000        0x0 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getentropy.c.obj)
     .bss           0x00000000        0x0 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getentropy.c.obj)
     .rodata.getentropy.str1.1
                    0x00000000       0x97 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getentropy.c.obj)
     .text.getentropy
                    0x00000000       0x7c zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getentropy.c.obj)
     .debug_info    0x00000000      0x4be zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getentropy.c.obj)
     .debug_abbrev  0x00000000      0x244 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getentropy.c.obj)
     .debug_loc     0x00000000      0x14e zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getentropy.c.obj)
     .debug_aranges
                    0x00000000       0x20 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getentropy.c.obj)
     .debug_ranges  0x00000000       0x10 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getentropy.c.obj)
     .debug_line    0x00000000      0x38f zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getentropy.c.obj)
     .debug_str     0x00000000      0x447 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getentropy.c.obj)
     .comment       0x00000000       0x20 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getentropy.c.obj)
     .debug_frame   0x00000000       0x2c zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getentropy.c.obj)
     .text          0x00000000        0x0 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .data          0x00000000        0x0 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .bss           0x00000000        0x0 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .text.getopt_init
                    0x00000000        0x4 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .text.getopt_state_get
     .text.getopt   0x00000000        0x4 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .text.z_getopt_global_state_update_shim
                    0x00000000       0x2c zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .bss.optopt    0x00000000        0x4 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .bss.optind    0x00000000        0x4 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .bss.opterr    0x00000000        0x4 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .bss.optarg    0x00000000        0x4 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .debug_info    0x00000000      0x33a zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .debug_abbrev  0x00000000      0x1a7 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .debug_loc     0x00000000       0x81 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .debug_aranges
                    0x00000000       0x38 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .debug_ranges  0x00000000       0x28 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .debug_line    0x00000000      0x23d zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .debug_str     0x00000000      0x58a zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .comment       0x00000000       0x20 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .debug_frame   0x00000000       0x50 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .text          0x00000000        0x0 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .data          0x00000000        0x0 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .bss           0x00000000        0x0 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.generic_data_ref
                    0x00000000       0x28 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.mem_pool_data_unref
                    0x00000000       0x38 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.mem_pool_data_alloc
                    0x00000000       0x6c zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.net_buf_alloc_with_data
                    0x00000000       0x26 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.net_buf_slist_put
                    0x00000000       0xd4 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.net_buf_slist_get
                    0x00000000       0xb8 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.net_buf_ref
                    0x00000000       0x30 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .rodata.net_buf_clone.str1.1
                    0x00000000       0x49 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.net_buf_clone
                    0x00000000      0x124 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .rodata.net_buf_user_data_copy.str1.1
                    0x00000000        0x8 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.net_buf_user_data_copy
                    0x00000000       0x60 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.net_buf_frag_last
                    0x00000000       0x34 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .rodata.net_buf_frag_insert.str1.1
                    0x00000000        0xc zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.net_buf_frag_insert
                    0x00000000       0x58 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.net_buf_frag_add
                    0x00000000       0x48 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .rodata.net_buf_frag_del.str1.1
                    0x00000000       0x24 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.net_buf_frag_del
                    0x00000000       0x78 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.net_buf_linearize
                    0x00000000       0x56 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.net_buf_append_bytes
                    0x00000000       0x98 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.net_buf_data_match
                    0x00000000       0x50 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .bss.net_buf_slist_lock
                    0x00000000        0x4 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .rodata.net_buf_var_cb
     .text          0x00000000        0x0 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .data          0x00000000        0x0 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .bss           0x00000000        0x0 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.sys_put_be32
                    0x00000000       0x12 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.sys_put_le32
     .text.net_buf_simple_init_with_data
                    0x00000000        0xc zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_reserve
                    0x00000000       0x44 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_clone
                    0x00000000        0xe zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_add_le16
     .text.net_buf_simple_add_be16
     .text.net_buf_simple_add_le24
                    0x00000000       0x18 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_add_be24
     .text.net_buf_simple_add_le32
                    0x00000000       0x16 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_add_be32
     .text.net_buf_simple_add_le40
     .text.net_buf_simple_add_be40
                    0x00000000       0x1c zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_add_le48
                    0x00000000       0x1e zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_add_be48
                    0x00000000       0x20 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_add_le64
     .text.net_buf_simple_add_be64
     .text.net_buf_simple_remove_mem
                    0x00000000       0x34 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_remove_u8
     .text.net_buf_simple_remove_le16
     .text.net_buf_simple_remove_be16
                    0x00000000       0x10 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_remove_le24
     .text.net_buf_simple_remove_be24
     .text.net_buf_simple_remove_le32
     .text.net_buf_simple_remove_be32
     .text.net_buf_simple_remove_le40
     .text.net_buf_simple_remove_be40
                    0x00000000       0x26 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_remove_le48
                    0x00000000       0x14 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_remove_be48
                    0x00000000       0x2c zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_remove_le64
     .text.net_buf_simple_remove_be64
     .rodata.net_buf_simple_push.str1.1
                    0x00000000       0x24 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_push
                    0x00000000       0x40 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_push_mem
     .text.net_buf_simple_push_le16
     .text.net_buf_simple_push_be16
     .text.net_buf_simple_push_u8
     .text.net_buf_simple_push_le24
     .text.net_buf_simple_push_be24
     .text.net_buf_simple_push_le32
     .text.net_buf_simple_push_be32
     .text.net_buf_simple_push_le40
     .text.net_buf_simple_push_be40
     .text.net_buf_simple_push_le48
     .text.net_buf_simple_push_be48
     .text.net_buf_simple_push_le64
     .text.net_buf_simple_push_be64
     .text.net_buf_simple_pull_mem
                    0x00000000       0x3c zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_pull_le16
     .text.net_buf_simple_pull_be16
     .text.net_buf_simple_pull_le24
     .text.net_buf_simple_pull_be24
                    0x00000000       0x2a zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_pull_le32
     .text.net_buf_simple_pull_be32
     .text.net_buf_simple_pull_le40
     .text.net_buf_simple_pull_be40
                    0x00000000       0x28 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_pull_le48
                    0x00000000       0x1a zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_pull_be48
                    0x00000000       0x38 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .text.net_buf_simple_pull_le64
     .text.net_buf_simple_pull_be64
     .text          0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_base_addresses.c.obj)
     .data          0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_base_addresses.c.obj)
     .bss           0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_base_addresses.c.obj)
     .debug_info    0x00000000       0x79 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_base_addresses.c.obj)
     .debug_abbrev  0x00000000       0x26 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_base_addresses.c.obj)
     .debug_aranges
                    0x00000000       0x18 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_base_addresses.c.obj)
     .debug_line    0x00000000       0x58 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_base_addresses.c.obj)
     .debug_str     0x00000000      0x295 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_base_addresses.c.obj)
     .comment       0x00000000       0x20 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_base_addresses.c.obj)
     .text          0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_binding_headers.c.obj)
     .data          0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_binding_headers.c.obj)
     .bss           0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_binding_headers.c.obj)
     .debug_info    0x00000000       0x79 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_binding_headers.c.obj)
     .debug_abbrev  0x00000000       0x26 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_binding_headers.c.obj)
     .debug_aranges
                    0x00000000       0x18 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_binding_headers.c.obj)
     .debug_line    0x00000000       0x59 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_binding_headers.c.obj)
     .debug_str     0x00000000      0x296 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_binding_headers.c.obj)
     .comment       0x00000000       0x20 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_binding_headers.c.obj)
     .text          0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_enabled_instances.c.obj)
     .data          0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_enabled_instances.c.obj)
     .bss           0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_enabled_instances.c.obj)
     .debug_info    0x00000000       0x79 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_enabled_instances.c.obj)
     .debug_abbrev  0x00000000       0x26 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_enabled_instances.c.obj)
     .debug_aranges
                    0x00000000       0x18 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_enabled_instances.c.obj)
     .debug_line    0x00000000       0x5b zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_enabled_instances.c.obj)
     .debug_str     0x00000000      0x298 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_enabled_instances.c.obj)
     .comment       0x00000000       0x20 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_enabled_instances.c.obj)
     .text          0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(soc.c.obj)
     .data          0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(soc.c.obj)
     .bss           0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(soc.c.obj)
     .text          0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(reboot.c.obj)
     .data          0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(reboot.c.obj)
     .bss           0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(reboot.c.obj)
     .text          0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gppi_init.c.obj)
     .data          0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gppi_init.c.obj)
     .bss           0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gppi_init.c.obj)
     .text          0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gpiote_nrfx.c.obj)
     .data          0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gpiote_nrfx.c.obj)
     .bss           0x00000000        0x0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gpiote_nrfx.c.obj)
     .text          0x00000000        0x0 zephyr/subsys/random/libsubsys__random.a(random_entropy_device.c.obj)
     .data          0x00000000        0x0 zephyr/subsys/random/libsubsys__random.a(random_entropy_device.c.obj)
     .bss           0x00000000        0x0 zephyr/subsys/random/libsubsys__random.a(random_entropy_device.c.obj)
     .rodata.rand_get.str1.1
                    0x00000000       0x97 zephyr/subsys/random/libsubsys__random.a(random_entropy_device.c.obj)
     .text.rand_get
                    0x00000000       0x84 zephyr/subsys/random/libsubsys__random.a(random_entropy_device.c.obj)
     .text.z_impl_sys_rand_get
                    0x00000000        0x6 zephyr/subsys/random/libsubsys__random.a(random_entropy_device.c.obj)
     .text.z_impl_sys_csrand_get
                    0x00000000       0x12 zephyr/subsys/random/libsubsys__random.a(random_entropy_device.c.obj)
     .debug_info    0x00000000      0x6b4 zephyr/subsys/random/libsubsys__random.a(random_entropy_device.c.obj)
     .debug_abbrev  0x00000000      0x348 zephyr/subsys/random/libsubsys__random.a(random_entropy_device.c.obj)
     .debug_loc     0x00000000      0x228 zephyr/subsys/random/libsubsys__random.a(random_entropy_device.c.obj)
     .debug_aranges
                    0x00000000       0x30 zephyr/subsys/random/libsubsys__random.a(random_entropy_device.c.obj)
     .debug_ranges  0x00000000       0x38 zephyr/subsys/random/libsubsys__random.a(random_entropy_device.c.obj)
     .debug_line    0x00000000      0x4c8 zephyr/subsys/random/libsubsys__random.a(random_entropy_device.c.obj)
     .debug_str     0x00000000      0x4ef zephyr/subsys/random/libsubsys__random.a(random_entropy_device.c.obj)
     .comment       0x00000000       0x20 zephyr/subsys/random/libsubsys__random.a(random_entropy_device.c.obj)
     .debug_frame   0x00000000       0x5c zephyr/subsys/random/libsubsys__random.a(random_entropy_device.c.obj)
     .text          0x00000000        0x0 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
     .data          0x00000000        0x0 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
     .bss           0x00000000        0x0 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
     .rodata.bt_addr_tmp_str.str1.1
                    0x00000000       0x1e zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
     .text.bt_addr_tmp_str
                    0x00000000       0x4c zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
     .rodata.bt_addr_le_tmp_str.str1.1
     .text.bt_addr_le_tmp_str
                    0x00000000       0x98 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
     .rodata.bt_addr_le_none
                    0x00000000        0x7 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
     .rodata.bt_addr_le_any
     .rodata.bt_addr_none
                    0x00000000        0x6 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
     .rodata.bt_addr_any
     .debug_info    0x00000000      0x41e zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
     .debug_abbrev  0x00000000      0x1f6 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
     .debug_loc     0x00000000      0x22f zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
     .debug_aranges
                    0x00000000       0x28 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
     .debug_ranges  0x00000000       0x58 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
     .debug_line    0x00000000      0x34b zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
     .debug_str     0x00000000      0x34f zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
     .comment       0x00000000       0x20 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
     .debug_frame   0x00000000       0x58 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
     .text          0x00000000        0x0 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(dummy.c.obj)
     .data          0x00000000        0x0 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(dummy.c.obj)
     .bss           0x00000000        0x0 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(dummy.c.obj)
     .debug_info    0x00000000       0x79 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(dummy.c.obj)
     .debug_abbrev  0x00000000       0x26 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(dummy.c.obj)
     .debug_aranges
                    0x00000000       0x18 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(dummy.c.obj)
     .debug_line    0x00000000       0x53 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(dummy.c.obj)
     .debug_str     0x00000000      0x290 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(dummy.c.obj)
     .comment       0x00000000       0x20 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(dummy.c.obj)
     .text          0x00000000        0x0 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
     .data          0x00000000        0x0 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
     .bss           0x00000000        0x0 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
     .text.bt_hex   0x00000000       0x44 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
     .text.bt_uuid_str
                    0x00000000       0x14 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
     .bss.str.0     0x00000000       0x25 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
     .bss.str.1     0x00000000       0x81 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
     .rodata.hex.2  0x00000000       0x11 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
     .debug_info    0x00000000      0x22e zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
     .debug_abbrev  0x00000000      0x127 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
     .debug_loc     0x00000000      0x105 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
     .debug_aranges
                    0x00000000       0x28 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
     .debug_ranges  0x00000000       0x18 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
     .debug_line    0x00000000      0x287 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
     .debug_str     0x00000000      0x2de zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
     .comment       0x00000000       0x20 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
     .debug_frame   0x00000000       0x44 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
     .text          0x00000000        0x0 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(rpa.c.obj)
     .data          0x00000000        0x0 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(rpa.c.obj)
     .bss           0x00000000        0x0 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(rpa.c.obj)
     .text.ah       0x00000000       0x3a zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(rpa.c.obj)
     .text.bt_rpa_irk_matches
                    0x00000000       0x26 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(rpa.c.obj)
     .text.bt_rpa_create
                    0x00000000       0x2e zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(rpa.c.obj)
     .debug_info    0x00000000      0x5d4 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(rpa.c.obj)
     .debug_abbrev  0x00000000      0x254 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(rpa.c.obj)
     .debug_loc     0x00000000      0x20e zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(rpa.c.obj)
     .debug_aranges
                    0x00000000       0x30 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(rpa.c.obj)
     .debug_ranges  0x00000000       0x38 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(rpa.c.obj)
     .debug_line    0x00000000      0x3c6 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(rpa.c.obj)
     .debug_str     0x00000000      0x461 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(rpa.c.obj)
     .comment       0x00000000       0x20 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(rpa.c.obj)
     .debug_frame   0x00000000       0x78 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(rpa.c.obj)
     .text          0x00000000        0x0 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .data          0x00000000        0x0 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .bss           0x00000000        0x0 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .text          0x00000000        0x0 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_common.c.obj)
     .data          0x00000000        0x0 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_common.c.obj)
     .bss           0x00000000        0x0 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_common.c.obj)
     .rodata.bt_hci_evt_create.str1.1
                    0x00000000       0x57 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_common.c.obj)
     .text.bt_hci_evt_create
                    0x00000000       0x50 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_common.c.obj)
     .text.bt_hci_cmd_complete_create
                    0x00000000       0x24 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_common.c.obj)
     .text.bt_hci_cmd_status_create
     .debug_info    0x00000000      0x714 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_common.c.obj)
     .debug_abbrev  0x00000000      0x2dd zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_common.c.obj)
     .debug_loc     0x00000000      0x289 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_common.c.obj)
     .debug_aranges
                    0x00000000       0x30 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_common.c.obj)
     .debug_ranges  0x00000000       0x50 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_common.c.obj)
     .debug_line    0x00000000      0x4f4 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_common.c.obj)
     .debug_str     0x00000000      0x4fc zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_common.c.obj)
     .comment       0x00000000       0x20 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_common.c.obj)
     .debug_frame   0x00000000       0x64 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_common.c.obj)
     .text          0x00000000        0x0 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .data          0x00000000        0x0 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .bss           0x00000000        0x0 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.z_nrf_clock_control_get_onoff
                    0x00000000       0x10 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.z_nrf_clock_bt_ctlr_hf_request
                    0x00000000       0x2c zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.z_nrf_clock_bt_ctlr_hf_release
                    0x00000000       0x34 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text          0x00000000        0x0 zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .data          0x00000000        0x0 zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .bss           0x00000000        0x0 zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .text          0x00000000        0x0 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .data          0x00000000        0x0 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .bss           0x00000000        0x0 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .text.gpio_nrf_gpiote_by_port_get
                    0x00000000        0x6 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .text          0x00000000        0x0 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(common.c.obj)
     .data          0x00000000        0x0 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(common.c.obj)
     .bss           0x00000000        0x0 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(common.c.obj)
     .text          0x00000000        0x0 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(pinctrl_nrf.c.obj)
     .data          0x00000000        0x0 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(pinctrl_nrf.c.obj)
     .bss           0x00000000        0x0 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(pinctrl_nrf.c.obj)
     .text          0x00000000        0x0 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .data          0x00000000        0x0 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .bss           0x00000000        0x0 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .text          0x00000000        0x0 zephyr/drivers/timer/libdrivers__timer.a(sys_clock_init.c.obj)
     .data          0x00000000        0x0 zephyr/drivers/timer/libdrivers__timer.a(sys_clock_init.c.obj)
     .bss           0x00000000        0x0 zephyr/drivers/timer/libdrivers__timer.a(sys_clock_init.c.obj)
     .text.sys_clock_set_timeout
                    0x00000000        0x2 zephyr/drivers/timer/libdrivers__timer.a(sys_clock_init.c.obj)
     .text.sys_clock_idle_exit
     .debug_info    0x00000000       0xda zephyr/drivers/timer/libdrivers__timer.a(sys_clock_init.c.obj)
     .debug_abbrev  0x00000000       0x7e zephyr/drivers/timer/libdrivers__timer.a(sys_clock_init.c.obj)
     .debug_aranges
                    0x00000000       0x28 zephyr/drivers/timer/libdrivers__timer.a(sys_clock_init.c.obj)
     .debug_ranges  0x00000000       0x18 zephyr/drivers/timer/libdrivers__timer.a(sys_clock_init.c.obj)
     .debug_line    0x00000000      0x16d zephyr/drivers/timer/libdrivers__timer.a(sys_clock_init.c.obj)
     .debug_str     0x00000000      0x2d6 zephyr/drivers/timer/libdrivers__timer.a(sys_clock_init.c.obj)
     .comment       0x00000000       0x20 zephyr/drivers/timer/libdrivers__timer.a(sys_clock_init.c.obj)
     .debug_frame   0x00000000       0x30 zephyr/drivers/timer/libdrivers__timer.a(sys_clock_init.c.obj)
     .text          0x00000000        0x0 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .data          0x00000000        0x0 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .bss           0x00000000        0x0 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .rodata.z_nrf_rtc_timer_compare_evt_address_get.str1.1
                    0x00000000       0x6e zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .text.z_nrf_rtc_timer_compare_evt_address_get
                    0x00000000       0x2c zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .text.z_nrf_rtc_timer_capture_task_address_get
                    0x00000000        0x4 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .rodata.z_nrf_rtc_timer_compare_int_lock.str1.1
                    0x00000000       0x1f zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .text.z_nrf_rtc_timer_compare_int_lock
                    0x00000000       0x24 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .text.z_nrf_rtc_timer_compare_int_unlock
     .text.z_nrf_rtc_timer_compare_read
                    0x00000000       0x30 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .text.z_nrf_rtc_timer_set
                    0x00000000       0x28 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .text.z_nrf_rtc_timer_exact_set
     .text.z_nrf_rtc_timer_abort
     .text.z_nrf_rtc_timer_get_ticks
                    0x00000000       0x40 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .text.z_nrf_rtc_timer_chan_alloc
                    0x00000000       0x44 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .text.z_nrf_rtc_timer_chan_free
     .text.z_nrf_rtc_timer_trigger_overflow
                    0x00000000        0x6 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .text.sys_clock_cycle_get_32
                    0x00000000        0x8 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .text.sys_clock_disable
     .bss.alloc_mask
     .text          0x00000000        0x0 modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a(multithreading_lock.c.obj)
     .data          0x00000000        0x0 modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a(multithreading_lock.c.obj)
     .bss           0x00000000        0x0 modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a(multithreading_lock.c.obj)
     .text          0x00000000        0x0 modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a(fatal_error.c.obj)
     .data          0x00000000        0x0 modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a(fatal_error.c.obj)
     .bss           0x00000000        0x0 modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a(fatal_error.c.obj)
     .text          0x00000000        0x0 modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
     .data          0x00000000        0x0 modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
     .bss           0x00000000        0x0 modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
     .text          0x00000000        0x0 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .data          0x00000000        0x0 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .bss           0x00000000        0x0 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .text.bt_ctlr_set_public_addr
                    0x00000000        0x4 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .text          0x00000000        0x0 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
     .data          0x00000000        0x0 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
     .bss           0x00000000        0x0 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
     .text.hci_internal_user_cmd_handler_register
                    0x00000000       0x18 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
     .text          0x00000000        0x0 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal_wrappers.c.obj)
     .data          0x00000000        0x0 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal_wrappers.c.obj)
     .bss           0x00000000        0x0 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal_wrappers.c.obj)
     .text          0x00000000        0x0 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(crypto.c.obj)
     .data          0x00000000        0x0 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(crypto.c.obj)
     .bss           0x00000000        0x0 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(crypto.c.obj)
     .rodata.bt_rand.str1.1
                    0x00000000       0x97 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(crypto.c.obj)
     .text.bt_rand  0x00000000       0x58 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(crypto.c.obj)
     .text.bt_encrypt_le
                    0x00000000        0xc modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(crypto.c.obj)
     .text.bt_encrypt_be
     .debug_info    0x00000000      0x74d modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(crypto.c.obj)
     .debug_abbrev  0x00000000      0x281 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(crypto.c.obj)
     .debug_loc     0x00000000      0x2bf modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(crypto.c.obj)
     .debug_aranges
                    0x00000000       0x30 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(crypto.c.obj)
     .debug_ranges  0x00000000       0x68 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(crypto.c.obj)
     .debug_line    0x00000000      0x443 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(crypto.c.obj)
     .debug_str     0x00000000      0x57c modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(crypto.c.obj)
     .comment       0x00000000       0x20 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(crypto.c.obj)
     .debug_frame   0x00000000       0x68 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(crypto.c.obj)
     .text          0x00000000        0x0 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .data          0x00000000        0x0 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .bss           0x00000000        0x0 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .text.mpsl_lib_init
                    0x00000000        0x6 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .text.mpsl_lib_uninit
     .text          0x00000000        0x0 modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a(mpsl_fem_api_init.c.obj)
     .data          0x00000000        0x0 modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a(mpsl_fem_api_init.c.obj)
     .bss           0x00000000        0x0 modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a(mpsl_fem_api_init.c.obj)
     .text          0x00000000        0x0 modules/nrf/subsys/mpsl/hwres/lib..__nrf__subsys__mpsl__hwres.a(mpsl_hwres.c.obj)
     .data          0x00000000        0x0 modules/nrf/subsys/mpsl/hwres/lib..__nrf__subsys__mpsl__hwres.a(mpsl_hwres.c.obj)
     .bss           0x00000000        0x0 modules/nrf/subsys/mpsl/hwres/lib..__nrf__subsys__mpsl__hwres.a(mpsl_hwres.c.obj)
     .debug_info    0x00000000       0x79 modules/nrf/subsys/mpsl/hwres/lib..__nrf__subsys__mpsl__hwres.a(mpsl_hwres.c.obj)
     .debug_abbrev  0x00000000       0x26 modules/nrf/subsys/mpsl/hwres/lib..__nrf__subsys__mpsl__hwres.a(mpsl_hwres.c.obj)
     .debug_aranges
                    0x00000000       0x18 modules/nrf/subsys/mpsl/hwres/lib..__nrf__subsys__mpsl__hwres.a(mpsl_hwres.c.obj)
     .debug_line    0x00000000       0x4f modules/nrf/subsys/mpsl/hwres/lib..__nrf__subsys__mpsl__hwres.a(mpsl_hwres.c.obj)
     .debug_str     0x00000000      0x28c modules/nrf/subsys/mpsl/hwres/lib..__nrf__subsys__mpsl__hwres.a(mpsl_hwres.c.obj)
     .comment       0x00000000       0x20 modules/nrf/subsys/mpsl/hwres/lib..__nrf__subsys__mpsl__hwres.a(mpsl_hwres.c.obj)
     .text          0x00000000        0x0 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
     .data          0x00000000        0x0 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
     .bss           0x00000000        0x0 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
     .text.nrfx_clock_hfclk_stop
                    0x00000000        0x6 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
     .text.nrfx_clock_hfclk_start
     .text          0x00000000        0x0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(system_nrf52833.c.obj)
     .data          0x00000000        0x0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(system_nrf52833.c.obj)
     .bss           0x00000000        0x0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(system_nrf52833.c.obj)
     .text.nvmc_config
                    0x00000000       0x10 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(system_nrf52833.c.obj)
     .text.SystemCoreClockUpdate
     .text          0x00000000        0x0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj)
     .data          0x00000000        0x0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj)
     .bss           0x00000000        0x0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj)
     .rodata.nrfx_error_string_get.str1.1
                    0x00000000       0x31 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj)
     .text.nrfx_error_string_get
                    0x00000000       0xc8 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj)
     .text          0x00000000        0x0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_flag32_allocator.c.obj)
     .data          0x00000000        0x0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_flag32_allocator.c.obj)
     .bss           0x00000000        0x0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_flag32_allocator.c.obj)
     .text.nrfx_flag32_is_allocated
                    0x00000000        0xa modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_flag32_allocator.c.obj)
     .text          0x00000000        0x0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .data          0x00000000        0x0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .bss           0x00000000        0x0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .text.ram_ctrl_block_section_power_enable_set
                    0x00000000       0x14 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .text.ram_ctrl_block_section_retention_enable_set
                    0x00000000       0x16 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .rodata.ram_ctrl_block_section_iterate.str1.1
                    0x00000000       0x7c modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .text.ram_ctrl_block_section_iterate
                    0x00000000       0x74 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .text.nrfx_ram_ctrl_power_enable_set
                    0x00000000        0xc modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .text.nrfx_ram_ctrl_power_enable_all_set
     .text.nrfx_ram_ctrl_retention_enable_set
     .text.nrfx_ram_ctrl_retention_enable_all_set
     .rodata.unit_to_block_section_lut
                    0x00000000       0x20 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .debug_info    0x00000000      0xc62 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .debug_abbrev  0x00000000      0x2f6 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .debug_loc     0x00000000      0x6e9 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .debug_aranges
                    0x00000000       0x50 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .debug_ranges  0x00000000       0xe0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .debug_line    0x00000000      0x55b modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .debug_str     0x00000000      0x86e modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .comment       0x00000000       0x20 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .debug_frame   0x00000000       0x94 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .text          0x00000000        0x0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .data          0x00000000        0x0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .bss           0x00000000        0x0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .text.flag_free
                    0x00000000       0x2c modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .text.nrfx_gppi_channel_alloc
                    0x00000000       0x34 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .text.nrfx_gppi_channel_free
                    0x00000000        0xc modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .text.nrfx_gppi_conn_free
                    0x00000000       0x58 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .text.nrfx_gppi_domain_conn_free
                    0x00000000       0x10 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .text.nrfx_gppi_group_alloc
                    0x00000000       0x40 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .text.nrfx_gppi_group_channel_alloc
                    0x00000000       0x38 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .text.nrfx_gppi_group_free
                    0x00000000       0x20 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .text.nrfx_gppi_group_channel_free
     .text.nrfx_gppi_ep_to_ch_attach
                    0x00000000       0x4c modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .text.nrfx_gppi_ep_attach
                    0x00000000        0x4 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .text.nrfx_gppi_ep_channel_get
     .text.nrfx_gppi_ep_ch_clear
                    0x00000000       0x3c modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .text.nrfx_gppi_ep_clear
                    0x00000000       0x1a modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .text.nrfx_gppi_ep_enable
                    0x00000000       0x1c modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .text.nrfx_gppi_ep_disable
     .text.nrfx_gppi_conn_disable
     .text.nrfx_gppi_chan_is_enabled
                    0x00000000       0x14 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .text.nrfx_gppi_channels_enable
     .text.nrfx_gppi_channels_disable
     .text.nrfx_gppi_domain_channel_get
                    0x00000000        0x2 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .text.nrfx_gppi_group_ch_add
     .text.nrfx_gppi_group_ch_remove
                    0x00000000       0x1e modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .text.nrfx_gppi_group_channels_get
     .text.nrfx_gppi_group_enable
     .text.nrfx_gppi_group_disable
     .text.nrfx_gppi_group_task_en_addr
     .text.nrfx_gppi_group_task_dis_addr
     .text          0x00000000        0x0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .data          0x00000000        0x0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .bss           0x00000000        0x0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .rodata.pin_out_task_get.str1.1
                    0x00000000       0x48 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.pin_out_task_get
     .text.pin_set_task_get
     .text.pin_clr_task_get
     .rodata.pin_in_event_get.str1.1
                    0x00000000       0x66 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.pin_in_event_get
                    0x00000000       0x5c modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .rodata.nrfx_gpiote_in_is_set.str1.1
                    0x00000000       0x21 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.nrfx_gpiote_in_is_set
     .text.nrfx_gpiote_channels_number_get
                    0x00000000       0x2c modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .rodata.nrfx_gpiote_uninit.str1.1
                    0x00000000       0x35 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.nrfx_gpiote_uninit
                    0x00000000       0x98 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .rodata.nrfx_gpiote_out_set.str1.1
                    0x00000000       0x69 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.nrfx_gpiote_out_set
                    0x00000000       0x58 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.nrfx_gpiote_out_clear
     .text.nrfx_gpiote_out_toggle
                    0x00000000       0x64 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.nrfx_gpiote_out_task_enable
                    0x00000000       0x6c modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.nrfx_gpiote_out_task_disable
     .text.nrfx_gpiote_out_task_get
                    0x00000000       0x30 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.nrfx_gpiote_out_task_address_get
                    0x00000000       0x34 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.nrfx_gpiote_set_task_get
     .text.nrfx_gpiote_set_task_address_get
     .text.nrfx_gpiote_clr_task_get
     .text.nrfx_gpiote_clr_task_address_get
     .text.nrfx_gpiote_out_task_force
                    0x00000000       0x78 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .rodata.nrfx_gpiote_out_task_trigger.str1.1
                    0x00000000       0x5f modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.nrfx_gpiote_out_task_trigger
     .rodata.nrfx_gpiote_set_task_trigger.str1.1
                    0x00000000       0x65 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.nrfx_gpiote_set_task_trigger
                    0x00000000       0x74 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.nrfx_gpiote_clr_task_trigger
     .text.nrfx_gpiote_in_event_get
                    0x00000000        0x4 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.nrfx_gpiote_in_event_address_get
                    0x00000000        0xe modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .rodata.port_lens.0
                    0x00000000        0x2 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text          0x00000000        0x0 zephyr/kernel/libkernel.a(busy_wait.c.obj)
     .data          0x00000000        0x0 zephyr/kernel/libkernel.a(busy_wait.c.obj)
     .bss           0x00000000        0x0 zephyr/kernel/libkernel.a(busy_wait.c.obj)
     .text          0x00000000        0x0 zephyr/kernel/libkernel.a(device.c.obj)
     .data          0x00000000        0x0 zephyr/kernel/libkernel.a(device.c.obj)
     .bss           0x00000000        0x0 zephyr/kernel/libkernel.a(device.c.obj)
     .text.z_impl_device_init
                    0x00000000       0x12 zephyr/kernel/libkernel.a(device.c.obj)
     .text.z_device_get_all_static
                    0x00000000       0x18 zephyr/kernel/libkernel.a(device.c.obj)
     .rodata.z_impl_device_get_binding.str1.1
                    0x00000000       0x37 zephyr/kernel/libkernel.a(device.c.obj)
     .text.z_impl_device_get_binding
                    0x00000000       0x74 zephyr/kernel/libkernel.a(device.c.obj)
     .text.z_impl_device_deinit
                    0x00000000        0x6 zephyr/kernel/libkernel.a(device.c.obj)
     .text          0x00000000        0x0 zephyr/kernel/libkernel.a(fatal.c.obj)
     .data          0x00000000        0x0 zephyr/kernel/libkernel.a(fatal.c.obj)
     .bss           0x00000000        0x0 zephyr/kernel/libkernel.a(fatal.c.obj)
     .text.arch_system_halt
                    0x00000000       0x10 zephyr/kernel/libkernel.a(fatal.c.obj)
     .text.k_sys_fatal_error_handler
                    0x00000000        0x6 zephyr/kernel/libkernel.a(fatal.c.obj)
     .text.k_fatal_halt
     .text          0x00000000        0x0 zephyr/kernel/libkernel.a(init.c.obj)
     .data          0x00000000        0x0 zephyr/kernel/libkernel.a(init.c.obj)
     .bss           0x00000000        0x0 zephyr/kernel/libkernel.a(init.c.obj)
     .text.z_early_rand_get
                    0x00000000       0x94 zephyr/kernel/libkernel.a(init.c.obj)
     .data.state.1  0x00000000        0x8 zephyr/kernel/libkernel.a(init.c.obj)
     .text          0x00000000        0x0 zephyr/kernel/libkernel.a(kheap.c.obj)
     .data          0x00000000        0x0 zephyr/kernel/libkernel.a(kheap.c.obj)
     .bss           0x00000000        0x0 zephyr/kernel/libkernel.a(kheap.c.obj)
     .text.z_heap_alloc_helper
                    0x00000000      0x13c zephyr/kernel/libkernel.a(kheap.c.obj)
     .text.k_heap_array_get
                    0x00000000       0x18 zephyr/kernel/libkernel.a(kheap.c.obj)
     .text.k_heap_alloc
                    0x00000000       0x1c zephyr/kernel/libkernel.a(kheap.c.obj)
     .rodata.k_heap_aligned_alloc.str1.1
                    0x00000000       0x38 zephyr/kernel/libkernel.a(kheap.c.obj)
     .text.k_heap_aligned_alloc
                    0x00000000       0x4c zephyr/kernel/libkernel.a(kheap.c.obj)
     .text.k_heap_calloc
                    0x00000000       0x28 zephyr/kernel/libkernel.a(kheap.c.obj)
     .text.k_heap_realloc
     .text.k_heap_free_sched_locked
                    0x00000000       0x9c zephyr/kernel/libkernel.a(kheap.c.obj)
     .text          0x00000000        0x0 zephyr/kernel/libkernel.a(idle.c.obj)
     .data          0x00000000        0x0 zephyr/kernel/libkernel.a(idle.c.obj)
     .bss           0x00000000        0x0 zephyr/kernel/libkernel.a(idle.c.obj)
     .rodata.arch_spin_relax.str1.1
                    0x00000000       0x54 zephyr/kernel/libkernel.a(idle.c.obj)
     .text.arch_spin_relax
                    0x00000000       0x40 zephyr/kernel/libkernel.a(idle.c.obj)
     .text          0x00000000        0x0 zephyr/kernel/libkernel.a(mutex.c.obj)
     .data          0x00000000        0x0 zephyr/kernel/libkernel.a(mutex.c.obj)
     .bss           0x00000000        0x0 zephyr/kernel/libkernel.a(mutex.c.obj)
     .text.z_impl_k_mutex_init
                    0x00000000        0xe zephyr/kernel/libkernel.a(mutex.c.obj)
     .text          0x00000000        0x0 zephyr/kernel/libkernel.a(queue.c.obj)
     .data          0x00000000        0x0 zephyr/kernel/libkernel.a(queue.c.obj)
     .bss           0x00000000        0x0 zephyr/kernel/libkernel.a(queue.c.obj)
     .text.z_impl_k_queue_init
                    0x00000000       0x12 zephyr/kernel/libkernel.a(queue.c.obj)
     .text.z_impl_k_queue_cancel_wait
                    0x00000000       0xf4 zephyr/kernel/libkernel.a(queue.c.obj)
     .text.k_queue_insert
                    0x00000000       0x10 zephyr/kernel/libkernel.a(queue.c.obj)
     .text.z_impl_k_queue_alloc_append
                    0x00000000       0x14 zephyr/kernel/libkernel.a(queue.c.obj)
     .text.z_impl_k_queue_alloc_prepend
     .text.k_queue_append_list
                    0x00000000      0x174 zephyr/kernel/libkernel.a(queue.c.obj)
     .text.k_queue_merge_slist
                    0x00000000       0x1e zephyr/kernel/libkernel.a(queue.c.obj)
     .text.k_queue_remove
                    0x00000000       0x4c zephyr/kernel/libkernel.a(queue.c.obj)
     .text.k_queue_unique_append
     .text.z_impl_k_queue_peek_head
                    0x00000000        0x8 zephyr/kernel/libkernel.a(queue.c.obj)
     .text.z_impl_k_queue_peek_tail
     .text          0x00000000        0x0 zephyr/kernel/libkernel.a(sem.c.obj)
     .data          0x00000000        0x0 zephyr/kernel/libkernel.a(sem.c.obj)
     .bss           0x00000000        0x0 zephyr/kernel/libkernel.a(sem.c.obj)
     .text.z_impl_k_sem_reset
                    0x00000000      0x100 zephyr/kernel/libkernel.a(sem.c.obj)
     .text          0x00000000        0x0 zephyr/kernel/libkernel.a(work.c.obj)
     .data          0x00000000        0x0 zephyr/kernel/libkernel.a(work.c.obj)
     .bss           0x00000000        0x0 zephyr/kernel/libkernel.a(work.c.obj)
     .text.handle_flush
                    0x00000000        0x2 zephyr/kernel/libkernel.a(work.c.obj)
     .text.unschedule_locked
                    0x00000000       0x1e zephyr/kernel/libkernel.a(work.c.obj)
     .text.cancel_async_locked
                    0x00000000       0x66 zephyr/kernel/libkernel.a(work.c.obj)
     .text.cancel_sync_locked
                    0x00000000       0x3c zephyr/kernel/libkernel.a(work.c.obj)
     .text.work_timeout
                    0x00000000       0xb8 zephyr/kernel/libkernel.a(work.c.obj)
     .rodata.work_flush_locked.str1.1
                    0x00000000       0x15 zephyr/kernel/libkernel.a(work.c.obj)
     .text.work_flush_locked
                    0x00000000       0xa0 zephyr/kernel/libkernel.a(work.c.obj)
     .text.k_work_busy_get
                    0x00000000       0x90 zephyr/kernel/libkernel.a(work.c.obj)
     .text.k_work_submit
                    0x00000000        0xc zephyr/kernel/libkernel.a(work.c.obj)
     .rodata.k_work_flush.str1.1
                    0x00000000       0x52 zephyr/kernel/libkernel.a(work.c.obj)
     .text.k_work_flush
                    0x00000000      0x11c zephyr/kernel/libkernel.a(work.c.obj)
     .text.k_work_cancel
                    0x00000000       0xd0 zephyr/kernel/libkernel.a(work.c.obj)
     .text.k_work_cancel_sync
                    0x00000000      0x138 zephyr/kernel/libkernel.a(work.c.obj)
     .text.k_work_queue_init
                    0x00000000       0x34 zephyr/kernel/libkernel.a(work.c.obj)
     .text.k_work_queue_run
                    0x00000000       0x80 zephyr/kernel/libkernel.a(work.c.obj)
     .text.k_work_queue_drain
                    0x00000000      0x110 zephyr/kernel/libkernel.a(work.c.obj)
     .text.k_work_queue_unplug
                    0x00000000       0xbc zephyr/kernel/libkernel.a(work.c.obj)
     .text.k_work_queue_stop
                    0x00000000      0x154 zephyr/kernel/libkernel.a(work.c.obj)
     .rodata.k_work_init_delayable.str1.1
     .text.k_work_init_delayable
                    0x00000000       0x58 zephyr/kernel/libkernel.a(work.c.obj)
     .text.k_work_delayable_busy_get
                    0x00000000       0xb0 zephyr/kernel/libkernel.a(work.c.obj)
     .text.k_work_schedule_for_queue
                    0x00000000      0x108 zephyr/kernel/libkernel.a(work.c.obj)
     .text.k_work_reschedule_for_queue
                    0x00000000      0x104 zephyr/kernel/libkernel.a(work.c.obj)
     .text.k_work_cancel_delayable
     .text.k_work_cancel_delayable_sync
                    0x00000000      0x120 zephyr/kernel/libkernel.a(work.c.obj)
     .text.k_work_flush_delayable
                    0x00000000      0x134 zephyr/kernel/libkernel.a(work.c.obj)
     .text          0x00000000        0x0 zephyr/kernel/libkernel.a(thread.c.obj)
     .data          0x00000000        0x0 zephyr/kernel/libkernel.a(thread.c.obj)
     .bss           0x00000000        0x0 zephyr/kernel/libkernel.a(thread.c.obj)
     .text.z_impl_k_is_preempt_thread
                    0x00000000       0x20 zephyr/kernel/libkernel.a(thread.c.obj)
     .text.z_impl_k_thread_priority_get
                    0x00000000        0x6 zephyr/kernel/libkernel.a(thread.c.obj)
     .text.k_thread_name_get
                    0x00000000        0x4 zephyr/kernel/libkernel.a(thread.c.obj)
     .text.z_impl_k_thread_name_copy
     .rodata.k_thread_state_str.str1.1
                    0x00000000        0x3 zephyr/kernel/libkernel.a(thread.c.obj)
     .text.k_thread_state_str
                    0x00000000       0x7c zephyr/kernel/libkernel.a(thread.c.obj)
     .text.z_init_thread_base
                    0x00000000       0x14 zephyr/kernel/libkernel.a(thread.c.obj)
     .text.k_thread_user_mode_enter
                    0x00000000       0x1c zephyr/kernel/libkernel.a(thread.c.obj)
     .text.k_thread_runtime_stats_get
     .text.k_thread_runtime_stats_all_get
                    0x00000000        0xc zephyr/kernel/libkernel.a(thread.c.obj)
     .text.k_thread_runtime_stats_cpu_get
     .rodata.str1.1
                    0x00000000       0x41 zephyr/kernel/libkernel.a(thread.c.obj)
     .rodata.state_string.0
                    0x00000000       0x40 zephyr/kernel/libkernel.a(thread.c.obj)
     .text          0x00000000        0x0 zephyr/kernel/libkernel.a(sched.c.obj)
     .data          0x00000000        0x0 zephyr/kernel/libkernel.a(sched.c.obj)
     .bss           0x00000000        0x0 zephyr/kernel/libkernel.a(sched.c.obj)
     .text.z_requeue_current
                    0x00000000       0x8c zephyr/kernel/libkernel.a(sched.c.obj)
     .text.z_yield_testing_only
                    0x00000000       0x88 zephyr/kernel/libkernel.a(sched.c.obj)
     .text.z_impl_k_thread_suspend
                    0x00000000      0x204 zephyr/kernel/libkernel.a(sched.c.obj)
     .text.z_impl_k_thread_resume
                    0x00000000       0xa4 zephyr/kernel/libkernel.a(sched.c.obj)
     .rodata.z_pend_thread.str1.1
                    0x00000000       0x3d zephyr/kernel/libkernel.a(sched.c.obj)
     .text.z_pend_thread
                    0x00000000       0xe8 zephyr/kernel/libkernel.a(sched.c.obj)
     .text.z_unpend_thread_no_timeout
                    0x00000000       0x90 zephyr/kernel/libkernel.a(sched.c.obj)
     .text.z_unpend1_no_timeout
                    0x00000000       0x9c zephyr/kernel/libkernel.a(sched.c.obj)
                    0x00000000       0x14 zephyr/kernel/libkernel.a(sched.c.obj)
     .text.z_swap_next_thread
                    0x00000000       0x18 zephyr/kernel/libkernel.a(sched.c.obj)
     .text.init_ready_q
                    0x00000000        0x8 zephyr/kernel/libkernel.a(sched.c.obj)
     .rodata.z_impl_k_thread_priority_set.str1.1
                    0x00000000       0xb7 zephyr/kernel/libkernel.a(sched.c.obj)
     .text.z_impl_k_thread_priority_set
                    0x00000000       0x6c zephyr/kernel/libkernel.a(sched.c.obj)
     .text.z_impl_k_reschedule
                    0x00000000       0xb4 zephyr/kernel/libkernel.a(sched.c.obj)
     .text.k_can_yield
                    0x00000000       0x48 zephyr/kernel/libkernel.a(sched.c.obj)
     .text.z_impl_k_usleep
                    0x00000000       0x3c zephyr/kernel/libkernel.a(sched.c.obj)
     .rodata.z_impl_k_thread_join.str1.1
                    0x00000000       0x15 zephyr/kernel/libkernel.a(sched.c.obj)
     .text.z_impl_k_thread_join
                    0x00000000      0x148 zephyr/kernel/libkernel.a(sched.c.obj)
     .text.z_sched_waitq_walk
                    0x00000000       0xd8 zephyr/kernel/libkernel.a(sched.c.obj)
     .text.z_unready_thread
     .text          0x00000000        0x0 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .data          0x00000000        0x0 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .bss           0x00000000        0x0 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .text.k_sched_time_slice_set
                    0x00000000       0xbc zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .text          0x00000000        0x0 zephyr/kernel/libkernel.a(spinlock_validate.c.obj)
     .data          0x00000000        0x0 zephyr/kernel/libkernel.a(spinlock_validate.c.obj)
     .bss           0x00000000        0x0 zephyr/kernel/libkernel.a(spinlock_validate.c.obj)
     .text          0x00000000        0x0 zephyr/kernel/libkernel.a(timeout.c.obj)
     .data          0x00000000        0x0 zephyr/kernel/libkernel.a(timeout.c.obj)
     .bss           0x00000000        0x0 zephyr/kernel/libkernel.a(timeout.c.obj)
     .text.timeout_rem
                    0x00000000       0x30 zephyr/kernel/libkernel.a(timeout.c.obj)
     .text.z_timeout_remaining
                    0x00000000       0xa8 zephyr/kernel/libkernel.a(timeout.c.obj)
     .text.z_timeout_expires
     .text.z_get_next_timeout_expiry
                    0x00000000       0x90 zephyr/kernel/libkernel.a(timeout.c.obj)
     .text.sys_clock_unlock
                    0x00000000       0x4c zephyr/kernel/libkernel.a(timeout.c.obj)
     .text          0x00000000        0x0 zephyr/kernel/libkernel.a(mempool.c.obj)
     .data          0x00000000        0x0 zephyr/kernel/libkernel.a(mempool.c.obj)
     .bss           0x00000000        0x0 zephyr/kernel/libkernel.a(mempool.c.obj)
     .text.k_free_sched_locked
                    0x00000000        0xe zephyr/kernel/libkernel.a(mempool.c.obj)
     .text.z_thread_aligned_alloc
                    0x00000000        0xc zephyr/kernel/libkernel.a(mempool.c.obj)
     .text          0x00000000        0x0 zephyr/kernel/libkernel.a(banner.c.obj)
     .data          0x00000000        0x0 zephyr/kernel/libkernel.a(banner.c.obj)
     .bss           0x00000000        0x0 zephyr/kernel/libkernel.a(banner.c.obj)
     .text          0x00000000        0x0 zephyr/kernel/libkernel.a(system_work_q.c.obj)
     .data          0x00000000        0x0 zephyr/kernel/libkernel.a(system_work_q.c.obj)
     .bss           0x00000000        0x0 zephyr/kernel/libkernel.a(system_work_q.c.obj)
     .text          0x00000000        0x0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x2c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000        0xe /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000        0x2 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x26 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x64 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x12 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x3e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x1a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x2e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x32 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x36 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x34 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x2a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x58 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x68 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xa4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x4c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x66 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x40 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x74 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x90 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x22 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x54 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x8c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x184 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x78 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x84 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xdc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x120 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x11c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xe8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x6c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xbc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x50 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x5c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x60 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x70 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x164 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x2cc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xe0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x468 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x7c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x268 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x9c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x29c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x100 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x148 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x48 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x1a4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x39c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xec /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x44 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x144 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xfc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x214 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x264 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x12c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xc0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x404 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x958 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x88 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xc8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x200 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x430 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x1ec /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x1dc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x134 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x2dc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xa0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xac /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x410 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x1cc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xa8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xd8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x13c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x94 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x6e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xb0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x82 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x8a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x42 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000        0xa /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x28c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x1e4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x1d4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xc6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x3a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x76 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x17c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x138 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x19c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x270 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x274 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x19e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x15c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x46 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x4e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x8e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x5e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xea /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x804 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x26c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x27a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x56 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x92 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xa2 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xd4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x212 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x50c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xf4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x178 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x4a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x1a6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x52 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x62 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x5dc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x1bc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x1fc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x2ac /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x180 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x1e8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x9a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x294 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x54c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x1d0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x11a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x7a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x170 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x1d8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xb8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xf8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xc4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x1b0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x18c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x3c4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x96 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x5a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xae /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xcc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x520 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x108 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x458 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x12e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xde /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x40c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x238 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xd2 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x98 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x9e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xba /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xd0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xbe /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xca /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x10c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x28e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x24e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x110 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0xb4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000       0x86 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x7cc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000      0x3ba /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .data          0x00000000        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x00000000        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000000        0x0 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00000000       0x14 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00000000        0xc /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00000000       0x1a /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00000000       0x28 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00000000       0x7c /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00000000       0x10 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00000000       0x18 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00000000       0x1c /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00000000       0x3c /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00000000       0x54 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00000000        0x0 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x38 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000        0x4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x18 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000        0xa /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000        0x6 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x14 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x5c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x68 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x1c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x3c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x2c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000        0x8 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x30 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000        0x2 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x90 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x6c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x24 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x10 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x4c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0xf8 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x54 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x80 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x8c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x28 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x44 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x84 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000      0x198 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x58 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x20 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000        0xe /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000      0x108 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000      0x1be /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x46 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0xbc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x74 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x2a /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x48 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0xe8 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x64 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0xa0 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0xac /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x40 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x60 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x78 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0xec /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00000000       0x14 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(strcmp.S.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(strcmp.S.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(strcmp.S.o)
     .debug_frame   0x00000000       0x20 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(strcmp.S.o)
     .text          0x00000000       0x10 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(strcpy.S.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(strcpy.S.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(strcpy.S.o)
     .debug_frame   0x00000000       0x20 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(strcpy.S.o)
     .text          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(memcpy.c.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(memcpy.c.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(memcpy.c.o)
     .text          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(memset.c.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(memset.c.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(memset.c.o)
     .text          0x00000000       0x10 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(strlen.S.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(strlen.S.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(strlen.S.o)
     .debug_frame   0x00000000       0x20 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(strlen.S.o)
     .text          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_errno_errno.c.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_errno_errno.c.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_errno_errno.c.o)
     .tbss.errno    0x00000000        0x4 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_errno_errno.c.o)
     .text          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_memcmp.c.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_memcmp.c.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_memcmp.c.o)
     .text.memcmp   0x00000000       0x20 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_memcmp.c.o)
     .text          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_strchr.c.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_strchr.c.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_strchr.c.o)
     .text.strchr   0x00000000       0x1a /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_strchr.c.o)
     .text          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_strncpy.c.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_strncpy.c.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_strncpy.c.o)
     .text          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_strnlen.c.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_strnlen.c.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_strnlen.c.o)
     .text          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_puts.c.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_puts.c.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_puts.c.o)
     .text.puts     0x00000000       0x40 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_puts.c.o)
     .text          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_snprintf.c.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_snprintf.c.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_snprintf.c.o)
     .text.snprintf
                    0x00000000       0x54 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_snprintf.c.o)
     .text          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflprintf.c.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflprintf.c.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflprintf.c.o)
     .text          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflscanf.c.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflscanf.c.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflscanf.c.o)
     .text.scanf_getc
                    0x00000000       0x14 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflscanf.c.o)
     .text.skip_spaces
                    0x00000000       0x2e /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflscanf.c.o)
     .text.putval   0x00000000       0x2c /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflscanf.c.o)
     .rodata.__l_vfscanf.str1.1
                    0x00000000        0xc /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflscanf.c.o)
     .text.__l_vfscanf
                    0x00000000      0x3b8 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflscanf.c.o)
     .text          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_fgetc.c.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_fgetc.c.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_fgetc.c.o)
     .text.getc     0x00000000       0x46 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_fgetc.c.o)
     .text          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_filestrput.c.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_filestrput.c.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_filestrput.c.o)
     .text.__file_str_put
                    0x00000000       0x10 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_filestrput.c.o)
     .text          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_ungetc.c.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_ungetc.c.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_ungetc.c.o)
     .text.ungetc   0x00000000       0x3a /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_ungetc.c.o)
     .text          0x00000000      0x254 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_muldf3.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_muldf3.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_muldf3.o)
     .debug_frame   0x00000000       0x30 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_muldf3.o)
     .text          0x00000000      0x378 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_addsubdf3.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_addsubdf3.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_addsubdf3.o)
     .debug_frame   0x00000000       0xac /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_addsubdf3.o)
     .text          0x00000000      0x424 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_muldivdf3.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_muldivdf3.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_muldivdf3.o)
     .debug_frame   0x00000000       0x50 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_muldivdf3.o)
     .text          0x00000000       0xa0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_truncdfsf2.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_truncdfsf2.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_truncdfsf2.o)
     .debug_frame   0x00000000       0x24 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_truncdfsf2.o)
     .text          0x00000000       0xec /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_cmpsf2.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_cmpsf2.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_cmpsf2.o)
     .debug_frame   0x00000000       0xc8 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_cmpsf2.o)
     .text          0x00000000       0xa0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_aeabi_ldivmod.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_aeabi_ldivmod.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_aeabi_ldivmod.o)
     .debug_frame   0x00000000       0x44 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_aeabi_ldivmod.o)
     .text          0x00000000       0x30 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_aeabi_uldivmod.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_aeabi_uldivmod.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_aeabi_uldivmod.o)
     .debug_frame   0x00000000       0x2c /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_aeabi_uldivmod.o)
     .text          0x00000000       0x26 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_popcountsi2.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_popcountsi2.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_popcountsi2.o)
     .debug_frame   0x00000000       0x20 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_popcountsi2.o)
     .text          0x00000000       0x2e /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_fixdfdi.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_fixdfdi.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_fixdfdi.o)
     .debug_frame   0x00000000       0x38 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_fixdfdi.o)
     .text          0x00000000       0x3c /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_fixunsdfdi.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_fixunsdfdi.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_fixunsdfdi.o)
     .debug_frame   0x00000000       0x2c /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_fixunsdfdi.o)
     .text          0x00000000      0x2bc /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_udivmoddi4.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_udivmoddi4.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_udivmoddi4.o)
     .ARM.extab     0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_udivmoddi4.o)
     .ARM.exidx     0x00000000        0x8 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_udivmoddi4.o)
     .debug_frame   0x00000000       0x34 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_udivmoddi4.o)
     .text          0x00000000        0x4 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_dvmd_tls.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_dvmd_tls.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_dvmd_tls.o)
     .text          0x00000000      0x110 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_cmpdf2.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_cmpdf2.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_cmpdf2.o)
     .debug_frame   0x00000000       0xc4 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_cmpdf2.o)
     .text          0x00000000       0x40 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_fixunsdfsi.o)
     .data          0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_fixunsdfsi.o)
     .bss           0x00000000        0x0 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_fixunsdfsi.o)
     .debug_frame   0x00000000       0x24 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_fixunsdfsi.o)
    Memory Configuration
    Name             Origin             Length             Attributes
    FLASH            0x00000000         0x00080000         xr
    RAM              0x20000000         0x00020000         xw
    IDT_LIST         0xffff7fff         0x00008000         xw
    *default*        0x00000000         0xffffffff
    Linker script and memory map
                    0x0002038c                        vfprintf = __l_vfprintf
                    0x00000000                        vfscanf = __l_vfscanf
    LOAD zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    LOAD zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    LOAD zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj
    LOAD app/libapp.a
    LOAD zephyr/libzephyr.a
    LOAD zephyr/arch/common/libarch__common.a
    LOAD zephyr/arch/arch/arm/core/libarch__arm__core.a
    LOAD zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a
    LOAD zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a
    LOAD zephyr/lib/libc/picolibc/liblib__libc__picolibc.a
    LOAD zephyr/lib/libc/common/liblib__libc__common.a
    LOAD zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a
    LOAD zephyr/lib/net_buf/liblib__net_buf.a
    LOAD zephyr/soc/soc/nrf52833/libsoc__nordic.a
    LOAD zephyr/subsys/random/libsubsys__random.a
    LOAD zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a
    LOAD zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a
    LOAD zephyr/drivers/clock_control/libdrivers__clock_control.a
    LOAD zephyr/drivers/entropy/libdrivers__entropy.a
    LOAD zephyr/drivers/gpio/libdrivers__gpio.a
    LOAD zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    LOAD zephyr/drivers/serial/libdrivers__serial.a
    LOAD zephyr/drivers/timer/libdrivers__timer.a
    LOAD modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a
    LOAD modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
    LOAD modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a
    LOAD modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a
    LOAD modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a
    LOAD modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a
    LOAD modules/nrf/subsys/mpsl/hwres/lib..__nrf__subsys__mpsl__hwres.a
    LOAD modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a
    LOAD modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a
    LOAD zephyr/kernel/libkernel.a
    LOAD zephyr/arch/common/libisr_tables.a
    LOAD /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a
    LOAD /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a
    LOAD /workspaces/nrfxlib/mpsl/fem/nrf21540_gpio/lib/nrf52/soft-float/libmpsl_fem_nrf21540_gpio.a
    LOAD /workspaces/nrfxlib/mpsl/fem/nrf21540_gpio_spi/lib/nrf52/soft-float/libmpsl_fem_nrf21540_gpio_spi.a
    LOAD /workspaces/nrfxlib/mpsl/fem/nrf2220/lib/nrf52/soft-float/libmpsl_fem_nrf2220.a
    LOAD /workspaces/nrfxlib/mpsl/fem/nrf2240/lib/nrf52/soft-float/libmpsl_fem_nrf2240.a
    LOAD /workspaces/nrfxlib/mpsl/fem/nrf22xx/lib/nrf52/soft-float/libmpsl_fem_nrf22xx.a
    LOAD /workspaces/nrfxlib/mpsl/fem/simple_gpio/lib/nrf52/soft-float/libmpsl_fem_simple_gpio.a
    LOAD /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a
    LOAD /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a
    LOAD /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a
                    0x00000020                        _region_min_align = 0x20
    .rel.plt        0x00000000        0x0
     *(SORT_BY_ALIGNMENT(.rel.plt))
                    [!provide]                        PROVIDE (__rel_iplt_start = .)
     *(SORT_BY_ALIGNMENT(.rel.iplt))
     .rel.iplt      0x00000000        0x0 zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
                    [!provide]                        PROVIDE (__rel_iplt_end = .)
    .rela.plt       0x00000000        0x0
     *(SORT_BY_ALIGNMENT(.rela.plt))
                    [!provide]                        PROVIDE (__rela_iplt_start = .)
     *(SORT_BY_ALIGNMENT(.rela.iplt))
                    [!provide]                        PROVIDE (__rela_iplt_end = .)
    .rel.dyn
     *(SORT_BY_ALIGNMENT(.rel.*))
    .rela.dyn
     *(SORT_BY_ALIGNMENT(.rela.*))
    /DISCARD/
     *(SORT_BY_ALIGNMENT(.plt))
    /DISCARD/
     *(SORT_BY_ALIGNMENT(.iplt))
                    0x00000000                        __rom_region_start = 0x0
    rom_start       0x00000000      0x100
                    0x00000000                        __rom_start_address = .
     FILL mask 0x00
                    0x00000000                        . = (. + (0x0 - (. - __rom_start_address)))
                    0x00000000                        . = ALIGN (0x4)
                    0x00000000                        . = ALIGN (0x80)
                    0x00000000                        . = ALIGN (0x100)
                    0x00000000                        _vector_start = .
     *(SORT_BY_ALIGNMENT(.exc_vector_table))
     *(SORT_BY_ALIGNMENT(.exc_vector_table.*))
     .exc_vector_table._vector_table_section
                    0x00000000       0x40 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(vector_table.S.obj)
                    0x00000000                _vector_table
     *(SORT_BY_ALIGNMENT(.vectors))
                    0x00000100                        _vector_end = .
                    0x00000040                        . = ALIGN (0x4)
     *(SORT_BY_ALIGNMENT(.gnu.linkonce.irq_vector_table*))
                    0x00000040       0xc0 zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
                    0x00000040                _irq_vector_table
    text            0x00000100    0x21704
                    0x00000100                        __text_region_start = .
     *(SORT_BY_ALIGNMENT(.text))
     .text          0x00000100       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000120       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000144       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000168       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000018c       0x2c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000001b8      0x2f0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000004a8       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000004a8                sym_476LRB5XNUARAHCHHC7ZAIGPFC5VZ4W2N4467LI
     .text          0x000004e4       0x54 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000538       0x9c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000538                sdc_init
     .text          0x000005d4      0x194 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000005d4                sdc_cfg_set
     .text          0x00000768       0x60 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000768                sdc_enable
     .text          0x000007c8       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000007c8                sdc_disable
     .text          0x000007ec       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000007ec                sdc_support_adv
     .text          0x00000804       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000804                sdc_support_peripheral
     .text          0x0000081c       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000081c                sdc_support_central
     .text          0x0000084c       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000084c                sdc_support_extended_feature_set_central
     .text          0x00000864       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000864                sdc_support_extended_feature_set_peripheral
     .text          0x0000087c       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000087c                sym_TG7NSIC2UKHCUBZWZ4K4EMD5QRI2QVSKVKV6CFQ
     .text          0x000008a4       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000008a4                sym_Z7NJGBYWCKFTEHRYWAIDKWPEUN45273QSWUA5CY
     .text          0x000008e0       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000008e0                sdc_hci_cmd_cb_set_event_mask
     .text          0x00000904       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000904                sdc_hci_cmd_cb_set_event_mask_page_2
     .text          0x00000918       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000918                sdc_hci_cmd_le_set_event_mask
     .text          0x0000092c       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000092c                sym_CEENVC5DZRUT7MGF5LABXKT4NV7YUL5F6EX6TEQ
     .text          0x0000094c       0x48 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000994       0x40 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000994                sym_T2KVJXUKBW7E6DZMIXB2ENUQYG6P2TBYLXO3PAY
     .text          0x000009d4       0x4c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00000a20       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000a20                sym_QFMUQVSA2RVLCOVZ24CAF3TBH45MAZ6DL5HLWKY
     .text          0x00000a30      0x174 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000a30                sym_EQ53CEL7EDVHMFMHMFPRRQU46C5YKKFEBAACFOA
     .text          0x00000ba4       0x6c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000ba4                sym_DMJHGENWVWA7ILXIIOOHU6SYMMXUDCUFUUBACLQ
     .text          0x00000c10       0x78 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000c10                sym_7JFC7IFAJQVPYCQHAIUKZ626ISM3VUWBEEXY7WI
     .text          0x00000c88       0x2c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000c88                sym_5X75WALYYBUWN4XT5LYOZBIGSZHVNFKF5J4CSQI
     .text          0x00000cb4       0x48 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000cb4                sym_4AWF7EXI3MMHUULTY73E756U3IY5DEXOZ265MZY
     .text          0x00000cfc       0x40 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000cfc                sym_6I4XEOIW7LI2E3Z53L54ZHQQHYICXR4H4JQWXLA
     .text          0x00000d3c       0x4c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000d3c                sym_4JEYQTIVM6L33X3X5LHFP2ZBRKGVYMF2G2KG7MY
     .text          0x00000d88       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000d88                sym_6DYG6C6ROXZA67GZINNB2XIQHL3KE2RCKK4QFXA
     .text          0x00000db8       0x7c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000db8                sym_24NU2MJKHN4R2Z7HXHMPDWTTDYSB32VL6HEQPZA
     .text          0x00000e34       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000e34                sym_3QFBRH4ZSIA64QP2I3K547Y5WIALGQTCBP5Y5SQ
     .text          0x00000e5c       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000e5c                sym_NOQRMQ5IH6SQFJEPI5A3UBMITO54HG4WO4DTTXA
     .text          0x00000e6c       0x80 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000e6c                sym_YL4RMM7WH2QQSRTLJX7L5Q2F5KYIEZ5IWMCN3UQ
     .text          0x00000eec       0x5c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000eec                sym_47U6MZ7GC5PU2CVEGYFSZO6JE3OMJD4DVLRAUZQ
     .text          0x00000f48       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000f48                sym_LD2UWOJIHNEPQLGRHPDQLYGR7RM2YL5X5777QYQ
     .text          0x00000f78       0xd0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00000f78                sym_YBUOIVJGKD57C5J4XCQFOKF4I5XT74ICLDOCNXA
     .text          0x00001048       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00001048                sym_F7HIJU67AV7VUFR5DUTQHA7VZXJ26XSC4BNRSYY
     .text          0x00001064       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00001064                sym_JEHUVO5SR4QMOCPDSPFG6JWZKTAGI6V6YDTMCBQ
     .text          0x00001084       0x5c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00001084                sym_E5WZNPP2DINHF6K4PHXLYLX5AXTYBQYGQESRSGQ
     .text          0x000010e0       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000010e0                sdc_rand_source_register
     .text          0x000010f0        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000010f0                sym_CVMXQJYKHZVHIOMGOYEICPLVAIQNUBL6USVNZSA
     .text          0x000010fc       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000010fc                sym_EZ7BAEZZMYJFIJAONX254JF3WPGEXUT4NMP2WJQ
     .text          0x0000110c       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00001130       0x74 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000011a4       0x60 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00001204       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00001218       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00001240       0x80 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000012c0      0x40c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000016cc       0x6c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00001738      0x57c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00001cb4       0x9c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00001d50      0x10c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00001e5c       0x40 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00001e5c                sym_7TCX7VR3LQDB2G4LYUM4YUKX3ZVIO33J3JZVMKY
     .text          0x00001e9c       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00001e9c                sym_DOZBRJLK4YK3UIAPC27JGEBDCH5Y2BCX3XMRURY
     .text          0x00001ec0      0x250 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00001ec0                sym_EXF7QYQZRNDSXD5BXX5JHASOOMIXFF6ILEF5NVA
     .text          0x00002110        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00002110                sym_UXGGQ7KT7KLQURU53WAWGAVBCTGQC65UKGCUU4A
     .text          0x00002114        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00002114                sym_R2K72KVDRFDRB7INCDL2G5SJCI6KNYCIUBETXWY
     .text          0x00002120       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00002120                sym_NOPEFU3WXUVOQBVPT7CQRX6GMPVN5PSMG7ZKLTQ
     .text          0x00002140       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00002140                sym_HMWMSCLS2E7KO3CEVZ6FUZGM6YUJ4GDX4JETJTI
     .text          0x00002150        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00002150                sym_57CDLB7NR4I66F4XUEVXWWEJBBBXGSJ37LGPUXA
     .text          0x0000215c       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000216c       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00002184        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00002190       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000021b4       0xd0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00002284       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000229c       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000022b4       0x54 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00002308      0x13c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00002444        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00002450       0xac /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000024fc       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00002538       0x78 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000025b0       0xe8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00002698       0x60 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000026f8      0x4a4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00002b9c      0x1b0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00002d4c       0x34 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00002d80       0x34 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00002db4       0x44 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00002df8      0x31c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00003114       0x70 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00003184       0x48 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000031cc       0x60 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000322c       0x80 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000032ac       0x8c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00003338      0x16c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000034a4       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000034c0       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000034fc       0x88 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00003584        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003584                sym_FLBXO3C2TGTXVEYELOG5B33ZBUVUNXUU6YZL7TY
     .text          0x00003590        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003590                sym_TNTVRUTCX6QDICT5SCWQINK5TBPSWJENFWCYQCI
     .text          0x0000359c       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000359c                sym_MSYMIWR3PI6HXHUAZX2P7HGFCTCK3HSW5N3BC2A
     .text          0x000035d4       0xb4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000035d4                sym_DT76CGJPKTZTBYTJ74CI3APDNUWUPZSXP2BUGWY
     .text          0x00003688       0x7c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003688                sym_NN7F2AFPNY6STZCCSXFBV5372QVP4U2ULKNO6YY
     .text          0x00003704       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003704                sym_K7SQKMVWESLZUZE22L4CEOMCL4JSVJET4SYEPLI
     .text          0x00003714       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003714                sym_KTO2H4NDIYSSQUUKE3NMMN4YAJAKAHZE3TQVHOY
     .text          0x00003738       0x48 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003738                sym_5SX7ENFQDOZAYBYWRHFJ26FURZRMVA3A5KG2A6A
     .text          0x00003780        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003780                sym_2QCSOYKJNF32ZBJORU6CJN7O5NDB7M3GD4LTM7A
     .text          0x00003788       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003788                sym_B3TRKHN4ULE4PFM5I6AFL42SLKULKQU5F7TRKNA
     .text          0x000037b8        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000037b8                sym_UEULVNDQB4E2WOIURLARZUGWNRNWHFWAZWRTJLI
     .text          0x000037c0       0x48 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000037c0                sym_CWCJBYNEE73YTWZDQ2FWMB5MOYKQIAA5AHOKAEI
     .text          0x00003808       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003808                sym_MWLD7ADI4DKLCCAP7TV4Z4ALM2E7XBXHCX6LARQ
     .text          0x0000381c       0x54 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000381c                sym_RV6GUX365M7FFXCRHFZAYAMXL6KOKZ6C32BIKXQ
     .text          0x00003870        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003870                sym_WYXBJE6NWBKILRWDCM2MMYJSSQVAUS4Y4CIL3JA
     .text          0x00003878       0x68 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003878                sym_CAWX7VFIWXNZLGUALKXHPOWKG5OUKQTCDAWDIJQ
     .text          0x000038e0       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000038e0                sym_DKYSP3NMOGW5WL2AN37B2ETSQMQQZYB63CFPVXY
     .text          0x00003918       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003918                sym_IRV7IF6I52F3HYHZNFCDRHHNP7EOMECHNPGJUGI
     .text          0x00003950       0xb4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003950                sym_RCFIWRLBP5ZDA7JRIG5IGCZAXKUKDNBSOBVRKUA
     .text          0x00003a04       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003a04                sym_2P3U35PVPGI22WKCAIMTRDZZMPBUUYDSHVM74OA
     .text          0x00003a3c       0x58 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003a3c                sym_MTC4J2MZE6VAAPCSLUXPAJHBAOGCFLQEYGARL6I
     .text          0x00003a94        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003a94                sym_E357R5GSET4BZKCOLPRJE7KKKMWMTNVTPX35LJQ
     .text          0x00003a9c        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003a9c                sym_SPOA75Q2J6LVU6OSBDIHNSVXF4UIA7YYLMJNW6Y
     .text          0x00003aa8       0x60 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003aa8                sym_Y3LLBAILR6W7PLNIFAS76NKLAMZYWOKXIQMSIJY
     .text          0x00003b08       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003b08                sym_J6ZBQHQVGAE27VWSVS7K3UO3AB6TBJZKIAWGLHI
     .text          0x00003b24       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00003b24                sym_YAXRHPGUPFCJO4WSKQPZEO436Y5T46SXRHLZXQQ
     .text          0x00003b44       0x34 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00003b78        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00003b80        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00003b88        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00003b90        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00003b98       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00003bb0       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00003bc0      0x52c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000040ec       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000040ec                sym_MZZ5CJE5YKBRI3UNENSSXM3SF3FKPPVI2OL74NY
     .text          0x00004110       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00004110                sym_OMWXBZW422C6DKXO7GJC4CUO6XR5IIZSWYHWWEY
     .text          0x00004124        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00004124                sym_WA43CPGHRWDHNG2TB3B7DYHXYBCWBZQF4FOGBTQ
     .text          0x00004130       0x5c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00004130                sym_64JITM2GCO5TNL2C5JQR6XU5LLQ4EW7FBY3YW4Y
     .text          0x0000418c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000418c                sym_6SR5FGIT2BUCA4BUYLG742GH74UKLXYFZPRQHKI
     .text          0x00004190       0x40 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00004190                sym_OJP2ACYSPOALNHQ7TSY7BQKRFD4ET6T3CI6ZENY
     .text          0x000041d0       0x6c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000041d0                sym_23XPTURR4DW4ZQPJM5PC7AK46H5FSWTLTCCARJI
     .text          0x0000423c       0x80 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000423c                sym_FO2KXXPMB6IQFAA5KGFFJWZILDAFSKWASS4B2FY
     .text          0x000042bc       0x98 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000042bc                sym_VT32C45B7GWIM6JWNGEA5DKX5ROTAQOVT2QHK3Y
     .text          0x00004354      0x14c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00004354                sym_APQBQYVRLINLVCFXLBBEITGXGOI22AKEZA4TBXI
     .text          0x000044a0       0xec /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000044a0                sym_O5OKVEPVXGQWULJQT7IB7WKP5SOAFRRRLE3UUPI
     .text          0x0000458c        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000458c                sym_5ATVDULIG6DGCAQSRDHXRO37ITSFNT7QVD7OMTQ
     .text          0x00004598       0x70 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00004598                sym_H6SJIQXHKN7VVG6C62ASOS3CUN62ZMELS5YDO4I
     .text          0x00004608       0xdc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00004608                sym_JDOK3ILHJSLIOCXZDFBFGS5GHZ7GEUIL56O2LBY
     .text          0x000046e4       0x6c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000046e4                sym_TGI4XR2SIZYZ634WEPOQE72CWFTQNRKDW5F5MZI
     .text          0x00004750       0xc4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00004814       0x88 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000489c       0x84 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00004920      0x178 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00004a98      0x424 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00004ebc       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00004ebc                sym_ONCJZGDCVZ7ETEDMUY5VMUUWXXIFFJBUOZSJQ3Q
     .text          0x00004ed0       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00004ed0                sym_CEIRMF45E42FC47RKIFGTU36Z7XGQCJUDSF57LQ
     .text          0x00004ee4       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00004ee4                sym_Q2F2U6CZWIZT5YZN73XVBXN5RQLCGTRVRP74TUQ
     .text          0x00004ef8        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00004ef8                sym_4XLDF2WZT4TA7RGOKZ6JV247XMO4JDJ3ALS62AQ
     .text          0x00004f04       0xd4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00004f04                sym_55O3MNUIQHFB3ZIFUNFWN7FWVNGYLI4M2WMX5NQ
     .text          0x00004fd8       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00004fd8                sym_GM7QU7LP6UH4DZPOIR7WHUEKZSOPEOATHYRRTQI
     .text          0x00004ff8       0xb8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00004ff8                sym_FWBDPDM7VY7WBRWZ3WP5JROXJKUZAWVORDIS6GI
     .text          0x000050b0       0x7c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000050b0                sym_CCEPBH7XTE4AYEYEHC6PAGXUR7U27BWTBNX6N3I
     .text          0x0000512c      0x228 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00005354       0x5c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00005354                sym_FOQ3QPGOR6JQQMW2UGNYKWNNYYOKZLMCFF3HUQI
     .text          0x000053b0       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000053b0                sym_4SBBLL64WWP4ZG5OZI4AZRNE5QSDGST5WG4LTOA
     .text          0x000053e0      0x250 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000053e0                sym_KBLYJZQ5R2WICKGMMMTOVLLRNIVEKRPHH44ZWLQ
     .text          0x00005630      0x1e4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00005630                sym_BAQ6XKIJ2DDNHUPTZJSMTWD7KTOEUEG7XPMPCIA
     .text          0x00005814       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00005814                sym_VAP7MVIHIUME4OM7W3TSZHFYIDAGUUCVV3GS5BY
     .text          0x0000584c       0x6c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000584c                sym_DOABKABWEXEJSA2H5Z2UO6MFQES34UYN7XL6GMA
     .text          0x000058b8       0x60 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000058b8                sym_HRCF6LWSDWPWEZA7S5YQFCNRDXXCJA6WGOZECRY
     .text          0x00005918       0x54 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000596c       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000059a4       0x54 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000059f8       0x70 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00005a68       0x44 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00005aac       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00005ae4       0x94 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00005b78      0x224 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00005d9c       0x34 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00005d9c                sym_APXCWAGUBVOVC7H47YUQ2L4IAV2DPJETCDCHIVA
     .text          0x00005dd0        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00005dd0                sym_XV5BXO36JYHRYWWC2Z33R43AV4MEIVV3W2JQCCQ
     .text          0x00005ddc       0x98 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00005ddc                sym_RGKYP5TXYS27EGT6ZHZS5EDDAZK5QGTWLBOBJEA
     .text          0x00005e74       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00005e74                sym_5EMU3BEOS6JCQEXTZ5M5LP72YGJNCV3W3R43AOI
     .text          0x00005e8c      0x114 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00005e8c                sym_DVO2EX3JGPIV6FVT5SJBVRKA5UGS2QSHNQOVQ2A
     .text          0x00005fa0      0x14c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000060ec       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000060ec                sdc_hci_cmd_cb_set_controller_to_host_flow_control
     .text          0x00006124       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006124                sdc_hci_cmd_cb_host_buffer_size
     .text          0x00006148       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006148                sdc_hci_cmd_cb_host_number_of_completed_packets
     .text          0x00006158        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006158                sym_UY577SX5HIKP7SN7G6RHWTFDXAXFXXF32S4VJUA
     .text          0x00006164       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006164                sdc_hci_cmd_le_read_buffer_size
     .text          0x00006178       0xdc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006178                sdc_hci_cmd_lc_disconnect
     .text          0x00006254       0x58 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006254                sdc_hci_cmd_le_set_default_phy
     .text          0x000062ac       0x50 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000062ac                sdc_hci_cmd_lc_read_remote_version_information
     .text          0x000062fc      0x164 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000062fc                sym_CNVWBND3CKNA7X75YYI34DQVJHIIO67GC5L2TOA
     .text          0x00006460       0x6c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006460                sdc_hci_cmd_le_set_scan_params
     .text          0x000064cc      0x1b8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000064cc                sym_DBR55P7EHPHN7AH2UBGHEP2JEK5DKIFJI53O4RA
     .text          0x00006684      0x340 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006684                sym_WOLK7J5ES7P57ZMVXNQUWAYV6XJ7AZYSV3TL56A
     .text          0x000069c4       0xcc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000069c4                sdc_hci_cmd_le_create_conn
     .text          0x00006a90       0xe4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006a90                sdc_hci_cmd_le_create_conn_cancel
     .text          0x00006b74       0x84 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006b74                sdc_hci_cmd_le_read_all_remote_features
     .text          0x00006bf8      0x1dc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006bf8                sym_A32XXMQ5QRPQRH3R656RZXETZB6Y54SG45FSCYI
     .text          0x00006dd4       0xb4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006dd4                sdc_hci_cmd_le_set_adv_params
     .text          0x00006e88       0x2c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006e88                sym_XQWU4MX22DPQIRRYTXBNWTH2DBYK7MH33FME7FI
     .text          0x00006eb4       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006eb4                sdc_hci_cmd_vs_event_length_set
     .text          0x00006ec4       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006ec4                sdc_hci_cmd_vs_central_acl_event_spacing_set
     .text          0x00006ed4       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006ed4                sdc_hci_cmd_vs_min_val_of_max_acl_tx_payload_set
     .text          0x00006eec       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006eec                sdc_hci_cmd_vs_scan_channel_map_set
     .text          0x00006f28        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006f28                sym_AZDVN5NCVR7WZFBQMTBKDS4ZECELF7HJDO5FKMQ
     .text          0x00006f34        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006f34                sym_BLF47GKHG6ZQOW3KS7Z2FM5ECAJ3LF5DPZBMLNA
     .text          0x00006f40       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006f40                sdc_hci_cmd_le_reject_cis_request
     .text          0x00006f50       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006f50                sym_DMGHH2LVWSZ3D4EEQRLLRGZGW5RDVC7GB2SNS6Y
     .text          0x00006f74       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006f74                sym_VV5MFLHWCEPFHB4IPPJ6GCDB4JDTRVRP5NYD26Y
     .text          0x00006f98       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00006fbc       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006fbc                sym_EANB2LFFCPDZUHTPF7SNNYVWVGG3AE7JVOONSTY
     .text          0x00006fe4       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00006fe4                sym_BFBDHRTPYGNRMJSAT7WCAPOXBGIVSWF4E5GFHOA
     .text          0x0000701c        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000701c                sym_PRWTRTI5GPQHIT26MFBSSOCWTUYYRLQLJWD2ZOI
     .text          0x00007028       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007028                sym_XUBYH6XGZLLFFVYC6KQVA5MFJUUESCU2IF7KXFI
     .text          0x00007064       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007064                sym_K4MZGJ6VXRQ7Y7JVDNONAAOVIUR7UYO7EUO5KSA
     .text          0x0000708c       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000708c                sym_G4TIIR7KO3GHFF45HCHTIL3RIPRK2LVDQADUYJQ
     .text          0x000070b0        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000070b0                sym_HG37ZAHWDO2P65KBJXRLV5PVSG5TCUWPMKZOZLQ
     .text          0x000070bc       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000070bc                sym_4W26TPGCKOCVVRKXQDBKGXGC2Y5LMZXNKS2QITA
     .text          0x000070ec        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000070ec                sym_7LJ5ZOVGW4HVLCIBFPRDZHVGAEUMXZL2NQEWSPA
     .text          0x000070f4        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000070f4                sym_WPMPLIQ2CLUGQDJNOO2POJJZZ26EUTXAQT6I3BQ
     .text          0x000070fc        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000070fc                sym_4GYPMR5DNSPTTPCK56HLK457TQWWCRBKTZ6GK7Q
     .text          0x00007108        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007108                sym_ZT5CPONXDAFRAB5RWMA6LXPAT5TEFYV2YKU6P6A
     .text          0x00007114       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007114                sym_N6TOG3AODPPFNS6LXFKKIADNGIMUMBS5BXPEFOY
     .text          0x0000713c       0x48 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000713c                sym_URLSG7CV3FP3A5NOA5XBW7KDTALLBU4J45QH6MQ
     .text          0x00007184        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007184                sym_BWOH6AZ6T4WLRA7IVWYARAF5KSHS6SUPQAKZW4A
     .text          0x00007190        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007190                sym_YIV6K35ZCZOSWXVUXD7CQCXKSKLZTF7IC2OJA7Y
     .text          0x00007198       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007198                sym_RMKUJW745T4AR7BPEGIRC3RX56XJCQLGQO5DVUA
     .text          0x000071b8        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000071b8                sym_522WSVG3UTP5XWCKDIFLXMJEEZNBVRJBBSBODPY
     .text          0x000071c0       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000071c0                sym_HA7EOSELAQYVMG5UXMJGQLLFEIRQPB7MNOSYOXQ
     .text          0x000071dc       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000071dc                sym_MJMICEV3AHUJUDNI6JLXYNXCJNL4PTPUQLXISYA
     .text          0x0000720c       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000720c                sym_W6QCODUONZ7VOOA5DU2R7RKAJUNWNTC3INZ7OGY
     .text          0x0000721c      0x100 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000721c                sym_26RMEELALLXJFEPDF46FU6ZXQPR2QA7KDXS3TSY
     .text          0x0000731c       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000731c                sym_GECJUMXC7GX4QNB2JHCJHLFH72UPMJZW6VAQVRA
     .text          0x00007358       0x6c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007358                sym_A5G4MU6XLOQ576G3WSRBT7T3BXSWM2RGHLCL6SQ
     .text          0x000073c4      0x188 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000073c4                sym_5AGU3LRCMVBHIA54A3ONXYPBDIAMDNM2I6LE6DA
     .text          0x0000754c       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000754c                sym_MJCF2WRL4I323V23HKVENOJWV5IXH54R5X6LJRY
     .text          0x0000755c       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000755c                sym_65LA7GM3MU7DDFQKTB75BYTZMPMROSWKS3VXCNI
     .text          0x00007574       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007574                sym_AGWGY6I3YKHHV6TMAWL24HN4IKGOB7PZYXPWBRA
     .text          0x00007590       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007590                sym_JHXS4T25BAYOMDDZMWPX3HMPENRV73GSV2RYHAI
     .text          0x000075ac       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000075ac                sym_54CHYGRI3UHSVLN5ZOGJESXNRISJW5CS4IYBN7Y
     .text          0x000075c4       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000075c4                sym_V7MOOXL5SOLISKFFGWJC7M3XDITU574WBQOXGWY
     .text          0x000075d8       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000075d8                sym_QKSVBALUN2V4XT4OCC56LE75IAYLDFRRIVLBZ2Q
     .text          0x00007608       0x34 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007608                sym_WCOWXKSKBH7DOKKKINFZAPWXKW4NYAUCJWTUKBI
     .text          0x0000763c       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000763c                sym_AO3U45UEGFLUPMT565ZR5UWUQUONF5AKILLCT3A
     .text          0x00007654       0x44 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00007698       0x2c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000076c4       0xbc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00007780       0x9c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000781c       0xbc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000078d8       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000078d8                sym_BEUFSWAQKCWS5CDGVZRIC3BRKSTHGOKRJJDB32I
     .text          0x000078f0       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000078f0                sym_BAUTABQSJLBAZ6GNH7KOF4MJMAA6NF7CDAZNOEQ
     .text          0x00007908       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007908                sym_62DUXM4M5AM4URNPP7IKDX3NCPAODBT4BMADGAY
     .text          0x00007928        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007928                sym_JQOBED6Y6P46KNYF2UD53QPDVNRPPOKMQL6EEBY
     .text          0x00007934        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007934                sym_WPF5GN3T7F3CCL7OKOL6G2LW47JA44MC6XIU4NQ
     .text          0x00007940       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007940                sym_AH5PFWTC7OGNFGHZO3OGQJX75M4BUE2VWXVZZ5A
     .text          0x0000797c       0xf8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000797c                sym_Z3745JZ5MC4MMBP2LFCOSP7OKPPVFDOPIURJWVQ
     .text          0x00007a74       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007a74                sym_FLX2PIIVHO3CLB5CJ7E7YSNFE2YWATNH27BL53A
     .text          0x00007a94        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007a94                sym_R5RFYNEZN3LQHKUKJDN3JLSNHLY4DPKXW3KZMYA
     .text          0x00007aa0        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007aa0                sym_WHSZ4VQHSDNZTVWJWAYGMNU7AWSUZKLKTBUNDPY
     .text          0x00007aac       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007aac                sym_62B4NCI2CQZLPPINCQVCHO6SYLZVDAWVVCHWS3I
     .text          0x00007ac8        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007ac8                sym_RHRHCWPUPZHCOID576WBS7QZ2KAUT2GASS2T3QY
     .text          0x00007ad4       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007ad4                sym_YAOI5BW7G2C6EUUY2B4S7A3CWX63A6MP2T3O5KA
     .text          0x00007b04       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007b04                sym_CMDXCVZHYNPLMTHXOO2UL3QOD6EXLAZP5GS7LRI
     .text          0x00007b40       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007b40                sym_NILI2ETYIVMR32XQ6WFMUWXYMXNONBSH2DACBCQ
     .text          0x00007b60       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007b60                sym_2X6ZBBHQKFJV27I6OQZLD4IRAL5JANEGA5N34WA
     .text          0x00007b84       0xc8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007b84                sym_ZBPJ22BXDBC3S7A4QI6WOFWFQMYIGT2P4GNU3XA
     .text          0x00007c4c       0x68 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007c4c                sym_EV54ITVX6ZJNRIULZTHEWNSCWW5GNYKPCEWELSY
     .text          0x00007cb4       0x74 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007cb4                sym_GIJNJPFWODT7EMZGJ5C7DGNKPDDXY2MLUHAWNUI
     .text          0x00007d28       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007d28                sym_DHR6XELGSD2MHYS7JWGEPSKXD43VLKKJDN33HMA
     .text          0x00007d4c       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007d4c                sym_QEQGMTIGG3AOZQY7JM4T2FY2O3KM2UFUMT6Q7PI
     .text          0x00007d6c       0x4c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007d6c                sym_3DXBFDJKO3IQEXOOHBMVXVTLDDG5FSS3TKAZNFY
     .text          0x00007db8       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007db8                sym_AIEQYZJFZQBQ5LEMJNMQV56TMLIGCBAC63QLHGI
     .text          0x00007dcc       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007dcc                sym_X4BJXGE5YMMDVCD7UITV5VC77BPMS3T24YB4VZA
     .text          0x00007de8       0x58 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007de8                sym_GJ3ILQRIJG2QUTUCQL7NXAZGAIP3QDHZO52KQLI
     .text          0x00007e40       0x54 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007e40                sym_CSEHPXTLDZSIPENXPGKETZBADO4EXIIC2RSVIXI
     .text          0x00007e94       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007e94                sym_RQLOJUGFCKCS5YSXHMF5LIHXPBLO5AO63KQE3GQ
     .text          0x00007eb4       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007eb4                sym_MAOKHHVPGVT23KVRN33B7KPEJU6F55EB66KOGDQ
     .text          0x00007ed4       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007ed4                sym_S635TH4ZNECIWRKFWYBUXBZ3GFP7WORE4PRXDPQ
     .text          0x00007ef4       0x2c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00007ef4                sym_3S3ZPZTS3JKT3LR3P6QZ3KOW4P72YQZEIQOYGSA
     .text          0x00007f20       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00007f38       0xc8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00008000       0x58 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00008058       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008058                sym_VKBDHCW5KWYFAEZJJBKQNHH4JDURIHHEJCK4SOA
     .text          0x0000807c       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000807c                sym_JKMI2SFC2N7KXC6XI6ZEAONO7SV2US6LWEISHOY
     .text          0x00008090        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008090                sym_LZWMHZYOCOZFEZM63EFTHCONDNYRE5YDAMU6QDQ
     .text          0x0000809c       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000809c                sym_BXRWRIA3M3K52MZ3ABK6S37OOTXMFTRBOBYS7TY
     .text          0x000080ac       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000080ac                sym_FHMOSTDS4FAIPN4GDRMMMBPMBOTEQ5DLCM2A23Q
     .text          0x000080bc      0x1a4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000080bc                sym_XOOTGCSEAKA3PUKZW3QYB4DCVC2FKUP2TS5AZ5Q
     .text          0x00008260        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008260                sym_6AZNKMTHYRXSS2VO46OU4P3TDG7IZG3ISBYAVPI
     .text          0x0000826c       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000826c                sym_XYMSM3YEXEOTUFIX3SPRBT27O44DJZKZVLNHELY
     .text          0x00008290       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008290                sym_HHT5YV37VWRBGUMO4AOJUKOJARZKAH2OUWPZF7Q
     .text          0x000082ac       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000082ac                sym_NJ23GB56DKRDWNC3A6OFPLEADGH3SOLDHUUSOYQ
     .text          0x000082d0       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000082d0                sym_ZWMGPE3QKJAQI4HTKIFMREKNKAUYHMAALNVM2QI
     .text          0x000082f4       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000082f4                sym_MWHYECJZLQQJKLQZGDI66SVA3IIWYKXL7G5FMHY
     .text          0x0000830c       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000830c                sym_43VAZS4NQXUMOPHD7W7SYFZ3WJ6KGQYQH6UOYPQ
     .text          0x00008348        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008348                sym_AF3JRBCZ7PPPC2OIPGWR52CQ5D7FSYRIUWXTLSA
     .text          0x00008354       0xa0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008354                sym_ZR6CJJRS2HZDDO4E6EVM5XF7S72SVVUNOYQICNA
     .text          0x000083f4       0x84 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000083f4                sym_DPZZZNFZBDYHRYTGBGDDIRHKSJJGCFLKHHX3EPY
     .text          0x00008478        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008478                sym_JVF7PF6RTOUMOSOOAHN6XGS6BTMZGVEBJKAKNBI
     .text          0x00008484        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008484                sym_VLZYODAV2LKRVZ5U6Q4CDF3UFZES3VV342R37AI
     .text          0x00008490        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008490                sym_B2H4NLF4X6HPSUNAHEMROXO2ID2YZMSUZAGRGTQ
     .text          0x0000849c       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000849c                sym_K5GMJMBHBYPRCUIWKNEXGPSNQEZKEMBAP4JWHBQ
     .text          0x000084cc       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000084cc                sym_7LZ5OF5UTH4WGXV6IKS6GUUHKYRIWQTTIJXNBEY
     .text          0x000084fc       0x34 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000084fc                sym_77ICNIHY2R2L3JRP4ZLMOWZSS3UZRKJXJOBWTWI
     .text          0x00008530       0x44 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008530                sym_NUAUKG3UHAJMAJB3VWKIDP75NSBCJHFDAIIU6EI
     .text          0x00008574       0x48 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000085bc       0xc0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000085bc                sym_5UEPRCW3EPZ7AP72CPP4EMSXBK27JNQSU5DMVOI
     .text          0x0000867c       0xc0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000867c                sym_O4OEFTDQOHR27DXSKIP2NTPPTRMSYXD4NWCXJCY
     .text          0x0000873c       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000873c                sym_Q4666MQBABRNQWVVM7BXH6CZLBLJXH7EUKSGMNQ
     .text          0x0000876c       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000876c                sym_IXYRVGMAX4SRXA2W5Z6EII6E55G3FBKT7HXOFRA
     .text          0x0000879c       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000879c                sym_T6XERXTZALZL23WNSNOCLR7DGHTAQBX7KTHLVFY
     .text          0x000087ac       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000087ac                sym_YWKG2CUUR2GL777Z5UMBJUNP43MWBKQQSZRPK7Q
     .text          0x000087bc      0x2ec /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000087bc                sym_CSIN2TPOFUQE2IY2MBBINVJ54FZNLPSYHTWOCVI
     .text          0x00008aa8       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008aa8                sym_NDXK2LOMZUDHFXKAI2VSFPUCPEZUOQPNHNILM7Y
     .text          0x00008abc       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008abc                sym_R3OVSIK4NXKOTUBI3IUCWAF5GBSLNFLFQGOT2YA
     .text          0x00008ad0       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008ad0                sym_HRA437GJ2CDV2E32FJ2QNXI3YG322UHSFPFJ3CI
     .text          0x00008ae4       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008ae4                sym_JOD4HBACYVOMP3CDGJCWGWOV76FFL6T5SRSXLJA
     .text          0x00008af8       0xa4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008af8                sym_EROH2ERI6YP4PUJVAMOS4KJ2YDG74D2WAXB2TOI
     .text          0x00008b9c       0x54 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008b9c                sym_IM3N55HLVRFQYD25P6A2DK6S6UPAUWTY4RZRVZY
     .text          0x00008bf0       0x78 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00008c68       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008c68                sym_VFOLPFPCBUBOWLD5S5NLUE2HEG4YIVT4AHJSRAA
     .text          0x00008c84       0x40 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008c84                sym_72MKWSQ4IBIQLDXWKLPZYWWIXADQ6TTGOUW7T4Q
     .text          0x00008cc4       0x8c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008cc4                sym_JU6OV3GKZF5HIJH3MU2Q3OVF2CL7DGZ6RFYTUVY
     .text          0x00008d50       0x90 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008d50                sym_37NODBYTBKFFSSK63VRMJNBJWPSLOW2TI6JJ5VA
     .text          0x00008de0       0x84 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008de0                sym_5PX46PPXISSLTQOT7WU7ULFUTTIKTAFVIDYCAVY
     .text          0x00008e64       0x5c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008e64                sym_7ABLLIXUF3HMINU3DLWXJDVBNAU7RSUXPXZ3RFQ
     .text          0x00008ec0       0x7c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008ec0                sym_RHE23VLW3YS5P4HRDMPTVWIHXVLEGJ7BJEAEEUI
     .text          0x00008f3c       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008f3c                sym_KH2TZBL3IC4Q72SOWRZYKXJYTC66QUG36J2D64Q
     .text          0x00008f74       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008f74                sym_CYYZ5DA5UWAE37FM7XP643I473QUSWWZ2MS7OLY
     .text          0x00008f98       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008f98                sym_KQ4RAL3HW3LUBE4EKZDESO77BJMQRXFGP63ANLQ
     .text          0x00008fd4       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008fd4                sym_LMH35HXRSICNKY264VR73PZXZMLFD2JWWXNP7TA
     .text          0x00008fe4       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00008fe4                sym_56UVHHES3DVKQZWKPD4W2O56B6Q35VFE7VP3FTY
     .text          0x0000901c       0xa8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000901c                sym_365Y77DXDRWJHR4QPTXJM46KZ7L557J533F2SNY
     .text          0x000090c4       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000090c4                sym_MKU2XEL6QB4MO4JU3HW4P3NALUM7PALQ3OF2VGA
     .text          0x000090e8       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000090e8                sym_3LKWZEY2K7UEF3M7QI5VCO43HM3TH6VAPJSZJBY
     .text          0x000090f8       0x84 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000917c       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000917c                sym_ECAFXV3NMZ2THIWY27PTYY6WSGFWQJNAJOG5HIY
     .text          0x000091a0        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000091a0                sym_FKU5SDIGNJ3CUR3VYEELCK5CK3EK42NLF7KQXSQ
     .text          0x000091ac        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000091ac                sym_MD2ACKWOI3UMWSI6IONGH6VN62ROA3VVQP7HYBQ
     .text          0x000091b8       0x58 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000091b8                sym_VT36OYILRYR2ODZV34U7WHVGGSRS7VN6JG7WPYI
     .text          0x00009210       0x40 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00009210                sym_3BV6HS2RZST6R6C5ZWOISO6OTZHTSW3BAFXBSVQ
     .text          0x00009250       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00009268       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00009268                sym_HI2TBRABOHC3QVQBVA25DO62WJKQLUMOFDQVQ3Y
     .text          0x00009288       0xe4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00009288                sym_PC4ZGEMN7XLV4PJZIJSXM6XLDD6GX7PXBYL6TFQ
     .text          0x0000936c       0x5c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000093c8        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000093c8                sym_P52EVHQKGJ5EMXHU27BFVEFSO6ZMLSI4P52LQDA
     .text          0x000093d4       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000093d4                sym_GWAYX66NWSVNQ3OHE5BQRMOI6IRTYM6NL6TBSRQ
     .text          0x000093ec       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000093ec                sym_BX5YZFMHL2USJCWZLKU3OCEXSW44HM5CAVH72SA
     .text          0x000093fc       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000093fc                sym_D5NLMVIFIEWOBYVCUG3PRIVQTYKXWDCRYPG4WDA
     .text          0x0000941c       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000941c                sym_WQEYNQYPTFH4BI2WPULDBBECIY2RT3HWWUCSKNI
     .text          0x00009438       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00009438                sym_ZKPLK624IRELGER42R2ZHKGWJUXMU6RHHHTNAQY
     .text          0x00009474       0x50 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00009474                sym_O6XGUO2YE6EJZ7P2GIXT7NMMWYUEBQ4F3KREAXA
     .text          0x000094c4        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000094c4                sym_KN3K6STNQWQWR2LORBLVX4RFT5RXJO5L5JNKV4I
     .text          0x000094d0       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000094d0                sym_WVUR7FIOL24MFCJHZIBLTPA7O44X57VSRLSLAPQ
     .text          0x000094e4       0x34 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000094e4                sym_JEWVWUVPPBKFY6NTG3STLQ3KWMWEBIH34A75HKI
     .text          0x00009518       0x44 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00009518                sym_LFMV7ZPMP2MCCNFNC4U7QQJ547VTI3Z5P2EL4WQ
     .text          0x0000955c       0xac /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000955c                sym_CRB5YCB3Z3AAZH7A5G7WM2JFASUE6SGAJROBYAA
     .text          0x00009608       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00009630       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00009630                sym_QCAWKLQF54ZUVQEUZYI3LS3CAU7N52INENNQS4A
     .text          0x00009640       0x80 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00009640                sym_DTBEJNW7A7JHG4MN52YFYEA2GZJHMHF7KQIBYHA
     .text          0x000096c0       0x2c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000096ec      0x6a4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00009d90      0x1c0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00009d90                sym_GJBRHN5U6HD3WESRK6JKLQICJKKQR5AFLKLZW4Y
     .text          0x00009f50       0xf0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000a040      0x170 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000a1b0      0x14c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000a1b0                sym_U3OFHSWAAHECAZEDHWSQTU63SOSYAQR6QI45AFY
     .text          0x0000a2fc       0x64 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000a2fc                sym_3LXCSEW4O4NZFGMXLMWXSJJVGEQV4VDRFCVRV4Q
     .text          0x0000a360       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000a360                sym_4O3EP57XWWWRY57PVJMDKXNE25ZWFBDV6LLBFQQ
     .text          0x0000a37c        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000a37c                sym_O6J3MUC4KJEDMNJLCC5Z3G5LTC5IHVL4PW7F6QI
     .text          0x0000a388       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000a388                sym_FQCHK2QLF7THGK7G4A4OWWNXI3K2TVYTTB4U4GY
     .text          0x0000a3a4       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000a3a4                sym_EPRPLWOAI3YMJ24HN6AZUGT5NWULVXEG6CTCI2Y
     .text          0x0000a3c0      0x218 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000a3c0                sym_EXAZKO22MNOFNIXIFHQ2Z4GAYMKBCE2UPJ6JSVI
     .text          0x0000a5d8        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000a5d8                sym_YZMCMF2VDK5EZ5GH5K4G77V4XY7KHBJNPGELPVQ
     .text          0x0000a5e4       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000a5e4                sym_3B7QVYTDAM6UK4EQXWODZ5A2SG2H3XKM3QLKRSA
     .text          0x0000a5f4       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000a60c       0x40 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000a64c      0x250 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000a89c       0xac /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000a948       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000a96c       0x70 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000a9dc       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000aa04       0x70 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000aa74       0x70 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000aae4       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000ab20       0x78 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000ab98       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000abbc       0xa4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000ac60       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000ac84      0x10c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000ad90      0x110 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000aea0       0x90 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000af30      0x124 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000b054       0x44 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000b098       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000b0a8       0x58 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000b100       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000b100                sym_4WIY2RAFLOZNOS4O5BEVWEYHIO3NV42IZ2Q2NWQ
     .text          0x0000b120       0x2c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000b120                sym_KC3JIKE7HTERE3Q3BXMRUIDPAENUZKVBIDO6ODY
     .text          0x0000b14c       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000b14c                sym_BPVIPCP3IMFHHNRASYWRUQPTOXIXQGWP3DTKXWI
     .text          0x0000b15c       0x2c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000b15c                sym_I72BLVRK23UDT6KM4GEW6EVDLN4L7QB2CLD4CMY
     .text          0x0000b188       0xc0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000b188                sym_JIJASGQH4XEEPZL7D35VQHVPKKLANGDBS2M46NQ
     .text          0x0000b248      0x120 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000b368      0x178 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000b368                sym_KBJ4SX4MJK4IAM4DI3ILSISVXIP6O72O62TW3OQ
     .text          0x0000b4e0       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000b4e0                sym_PY5KUATPBYOYJBMP6H7AVRPSEO7BZX2JK524O6A
     .text          0x0000b4f0       0x58 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000b4f0                sym_RPDYS5TXULS3Z2BQR7IFNSOINXPPN4LN764SRIY
     .text          0x0000b548        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000b54c        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000b554        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000b558       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000b570       0x44 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000b570                sym_6FVWF5AWPR7EN7BPHS4APSIUXYFZQTTZCMRDKPY
     .text          0x0000b5b4       0xb4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000b668       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000b6a0      0x244 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000b8e4      0x10c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000b9f0       0xdc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000bacc       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000bacc                sym_PVCVFCIVK7I4BDGU46UNJJZCMRD7PQMGJLTK2PY
     .text          0x0000baf4       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000baf4                sym_OTZAOT4DEZSL3R4MXRNUS2BIBKPPCOEO2SMZYAI
     .text          0x0000bb04       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000bb04                sym_FIYSAC63N2FF462LEI76F5US34JKFTAQDSI2LXA
     .text          0x0000bb20      0x160 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000bb20                sym_GRKUQI62F6CK2HPCZKZRWSZ3PZVCGXTWPZAIMJA
     .text          0x0000bc80       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000bc80                sym_UFX5YQMS76OVX4LZ7T6GRG5R56NF5732ZNTZZJA
     .text          0x0000bc90      0x93c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000c5cc       0xe8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000c5cc                sym_HT64RIVISXSWFJE3LL26YHKQRTRRXKVEDBUUUOQ
     .text          0x0000c6b4       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000c6b4                sym_5FEKI42Y7X4UUCIREKQKGKFQEDDJSDSE2JIWZPY
     .text          0x0000c6c4       0x2c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000c6f0       0x48 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000c738      0x1ac /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000c8e4       0x78 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000c95c      0x108 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000c95c                sym_PRPVY42KTARK5ALUBCODXQWVRSCWFIVUAJWLOHI
     .text          0x0000ca64       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000ca64                sym_R2R62GLIY7S3OCJMRDPIB4TBZFUG2AN7TI7ERPI
     .text          0x0000ca74        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000ca74                sym_O5ZKMVYIIKH3EAJRECXZFOUFXDW4MCMBS67KZZI
     .text          0x0000ca80       0x60 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000ca80                sym_YFJA2DR3B2GMOYCYI4FI6MGASQ2G5S4BSZFCCSA
     .text          0x0000cae0       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000cae0                sym_SVA6DLBGPY6XV2V2F4HOMHWDPSDIRD722L2FDEI
     .text          0x0000cafc      0x140 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000cafc                sym_75TAEO5RFHKNVZFZHMOMYUKRALUIDEKJ3QZBZUI
     .text          0x0000cc3c       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000cc78       0x60 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000ccd8      0x130 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000ce08       0x94 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000ce9c      0x150 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000cfec      0xb2c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000db18      0x124 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000db18                sym_C4R73COZU7NKK6UAUGTJ6HNWDG7QPVROF5RMZMA
     .text          0x0000dc3c       0x94 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000dc3c                sym_ELB4EXXRKBATZ6KCANX37LXPZBQQJSOFPSAT7UI
     .text          0x0000dcd0       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000dcd0                sym_BMRRBGTBOMNCTFRC4JMUHQRHBFAPJMHPHDKCL4A
     .text          0x0000dce0        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000dce0                sym_3XKM6UG6VRZCVJ2BX2RFP2VJ4QFPCECECEPTV5I
     .text          0x0000dcec       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000dcec                sym_MYZDSWHZMVTUGPWK7CFFVMNCPRPZBKC3UH2GTLQ
     .text          0x0000dd10       0x44 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000dd10                sym_ZIE6EQ2YDF5ZLLLNRMU6NPOFHB7VMBHYMI4646I
     .text          0x0000dd54       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000dd54                sym_JANNQMW3JZGYLNSOPAA2HBYBA6JBSX4W7VBR56Q
     .text          0x0000dd64       0x40 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000dd64                sym_BYAP75KATHCDX4IND7ISKAZXYQ3QR4KXXESSZBA
     .text          0x0000dda4        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000dda4                sym_6JN2PCOTRFUGZCX7BJQW6G5Z7ARSLW36MVVM4XQ
     .text          0x0000ddb0       0xa4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000ddb0                sym_MXMY7G6DV4KGHQXPGF5PNCQJ4P7UL6GP7EZE2MY
     .text          0x0000de54       0x34 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000de54                sym_LAQL4VZN7EULGUZI4COG24PPO3LANTHFUJNXKSQ
     .text          0x0000de88       0x90 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000de88                sym_XJ575BPZCD4OG6SJU7DRFZQEV32YI6PQAVCGXNI
     .text          0x0000df18       0x34 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000df18                sym_3ERNNWZVQMQ773DIBEVAR5SRSFYV4N3FPRRZ3YI
     .text          0x0000df4c       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000df4c                sym_LOTFHGQTFUFWGX7HOTL4Q2XATGIJRVIMCMOYRMA
     .text          0x0000df60       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000df60                sym_MDF364N4PQDEA5ZGP5CB3ZDZVZM5Q32KSEZZ5HI
     .text          0x0000df90       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000df90                sym_XCEN5K7VEI2CAO42XW7S3FKM3HKMOCDCUFDX25Y
     .text          0x0000dfcc       0x54 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000dfcc                sym_5DEPI2OGSPXE5OVFBPVFPSPYPRYUQ54QVVXIKNI
     .text          0x0000e020       0x2c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e020                sym_MSITFZMEKFRIBNA2WU2C6VUZYGJRSJIVBH2SBPI
     .text          0x0000e04c       0x50 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e04c                sym_ZG4AW57AAT4BVE2J2CU4KMCCWK46ENDRPKBYXEQ
     .text          0x0000e09c       0x34 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e09c                sym_ZQHB3ANU2DANFLJZLZL5U4SPQ2ZDVUAHI35744Y
     .text          0x0000e0d0       0x34 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000e104       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e104                sym_XPKSFPKFBNSTZZU4FUMGC3XRHAVS24BBL53HRMA
     .text          0x0000e120       0x50 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e120                sym_6Q45YYTUN2KDQ5V5UGE3T2LTI5FNGX6WIJYLIDI
     .text          0x0000e170       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e170                sym_VZTCNK7LPLGUYYITUFBRKT7IMIMSPIN7PNNZ2FA
     .text          0x0000e180       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e180                sym_4QZZGSV4Q73MRWLGT2JUIEO54MWVQREPXC6OEZI
     .text          0x0000e1a8       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e1a8                sym_7PGC4MOVTGXGCSJIIZLK7LXVVTIMRADTYZRCCLY
     .text          0x0000e1e0       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e1e0                sym_TPGZXEEC7E4AAOPPZUXN6Z5FKNO7FYNLY6SIXUY
     .text          0x0000e218       0x50 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000e268       0xc4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000e32c       0x74 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e32c                sym_RUQBFILZ5CHV2AAL6C3D2J5Y33TCCAPZTHBGZ3A
     .text          0x0000e3a0       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e3a0                sym_USARD2GALAUGUROVU2MJRPCD73L2ZTHZLWWAABQ
     .text          0x0000e3b0       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e3b0                sym_DRIMECVE2FH7O6C2LQ25QRVJOICPHLA5GC6TM2I
     .text          0x0000e3c0        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e3c0                sym_ARLNRKQ66P65CL63VENK3NR6NFAZLWPJOOVV7RQ
     .text          0x0000e3cc       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e3cc                sym_GI7KSEEMTJQ7HR2XTQJ6A3EAB54YYLMWKNL2RBA
     .text          0x0000e3dc       0x48 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e3dc                sym_6NKMJ5NHE5TDDKADRKC3LPHMAGMN4CSHKV4DZZA
     .text          0x0000e424       0x88 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e424                sym_5CHOZAQ75MOW32NPEGX5AYLDFVQR6HZCDXZY5PQ
     .text          0x0000e4ac       0x88 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e4ac                sym_FY64OI6JRV3CK6UZDJBVOPA33ZIK3BGBMGMWYKA
     .text          0x0000e534       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e534                sym_YUNWMAOOL6VPZ57LS54EAM7TJ65IEHYU7XKGKUI
     .text          0x0000e570       0xb8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e570                sym_JQ5GTNCJKXERB3SSKQRXLQOKWJQVRNEOVZZZVXI
     .text          0x0000e628       0xbc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e628                sym_GVSNNBZMBIJOMUA3FPIAVVC7S5MNBYUF4QELXZA
     .text          0x0000e6e4       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e6e4                sym_HE5JGYEZFIITGQL7PMATDHSORSCK7HJIY5UXOZA
     .text          0x0000e6f4       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e6f4                sym_YLRTPBVG5ROXKOW4KXUYITRUY3FD2MVZW5LF7ZA
     .text          0x0000e708       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e708                sym_ZQE76VUU7S5U7DETTZA65E75LHFWL5PGRN4JPHI
     .text          0x0000e720        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e720                sym_AH4AUKTEXKNNQ75DTAA3USWZY7NBPLTF22FEMMY
     .text          0x0000e72c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000e72c                sym_LENF26TCWPPN4SCLTAR5A2ZUXP4RV6DSMX5F5KA
     .text          0x0000e730       0xc0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000e7f0      0x100 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000e8f0      0x25c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000eb4c      0x1c0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000eb4c                sym_6PPYXQQOLTVZ6DHASA45P4Y6MOJ5US37OHECCGI
     .text          0x0000ed0c       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000ed0c                sym_E7IS652W2J5N5UTHP752WOA4YNSR7E5S5H4J2AA
     .text          0x0000ed34       0x80 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000ed34                sym_X2OPELT6OFJBU77R5R7QDKLXQUDKTQW6IEUFVIQ
     .text          0x0000edb4        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000edb4                sym_DA7WRFYOYJD7SG5G5J55TF23JJMFBPQNM46DPMA
     .text          0x0000edc0      0x138 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000edc0                sym_A5S3P57NWYYY5XJWBYERU6H4QSVP5TCTU7HKA5Y
     .text          0x0000eef8       0xb8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000eef8                sym_2YSDS7VWGMSD5CN64D2VGQIYXBV3A6NJCHWFZEY
     .text          0x0000efb0        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000efb0                sym_XD56LJG2JTRU4Q2V7WCY72EI3VTZICA3O4ERV2A
     .text          0x0000efbc       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000efbc                sym_YG4UROEKVB7ZBE5TWHLNJHYKSFBTXGBYAX3RXRI
     .text          0x0000eff4       0x70 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000eff4                sym_LPFN6QJEOHBT4AP2K7MEYWDZW35U5VHIHXOA54I
     .text          0x0000f064       0x68 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f064                sym_VQAAPKOYTNBXWM73YG7JTMODY25W7PKP7WAPGJI
     .text          0x0000f0cc       0x70 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f0cc                sym_7CIQBS4FNO23MS6BAN7Q3LK45R62DBPT5FNCWOA
     .text          0x0000f13c       0x90 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f13c                sym_Y6HXZQJARJ7FDWKGPREPQGRRGDOQMXHDALUK6KY
     .text          0x0000f1cc       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f1cc                sym_JSHLXOVZJZP3KPTLSJTCXHNIGRQ2VOB7UW7IQAA
     .text          0x0000f208       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f208                sym_RXYEX777ZXB2E2DXJWDBCV7AAHWTCHNTLOSENBY
     .text          0x0000f220       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f220                sym_PCLF3MATC3G3MYGRPG4ATMGCS6N4B7M5CSF2C2Y
     .text          0x0000f23c       0x48 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f23c                sym_EZCFQXKGAFHY5HQVJOXWDLO45XWMEJQY5WUGZNI
     .text          0x0000f284       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f284                sym_MX2GIHHNIMWNJLD4TWTGEWNIWGRHSCIPCBEEPVY
     .text          0x0000f298       0x78 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f298                sym_ULMELQ5YH34MJZXM2JNH5UBSGUFRHFFLYGWUAAI
     .text          0x0000f310       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f310                sym_VEC44ISWPJAJ32J57NYIBEMC7Q6QEP7J6SVR4BQ
     .text          0x0000f330       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f330                sym_LSYZDZOMTD6BKKRX25HIBNLFKSFDXBS3PS4UKOY
     .text          0x0000f348      0x2a0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f348                sym_EMR2H7KEGRFFKS6A4P3ZPPGOJSTVXLGRI25MEYQ
     .text          0x0000f5e8       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f5e8                sym_V67AIMSO57NYVNGXZF2PDQSJQJLITHU4KD4CKAY
     .text          0x0000f5f8       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f5f8                sym_UX6VBOIQ7ULLMX3I6UDFOFZ6IT2DVZKKVIEVRMY
     .text          0x0000f608       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f608                sym_L4JTLGMK2AWYAAPRB3O77773SG36X2NTZJ3FAHA
     .text          0x0000f618       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f618                sym_KM5SKFVNZKDXUQ7BDD3RZ5UCA5E3ZDVNWYJVR3Y
     .text          0x0000f634       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f634                sym_WD6EQ3FQVKOAARDWHQJJC5SVKHQS7A2MF5YDCPA
     .text          0x0000f65c       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f65c                sym_WGW6HZ6PNLYQSUJALICWZO27AY5UJWYCU6B6ACI
     .text          0x0000f680       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f680                sym_2EA2WBXQOKCTPMK7YNDR6QM6MTGHJCDTPZEXNNA
     .text          0x0000f6a0       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f6a0                sym_7VLVVPDI26BVJ64XQBSGXOQYGQA4VH5APIPDGYA
     .text          0x0000f6dc       0x40 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f6dc                sym_55XNA7W2CQFJPCH62ZAKHLPISYHJ7KMNREEN6EA
     .text          0x0000f71c       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f71c                sym_MEIHG7NCZGGHWUGVLRGXMDTZB2OODFJAGHVWGLI
     .text          0x0000f758       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f758                sym_TRMXENGHOH4VBQQZPIN222FLCEFU3Z3CD5C47DY
     .text          0x0000f768      0x15c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f768                sym_5I5MTMPTF2F4WI7MIXG5OG4TUPLUR53CB2QHVUA
     .text          0x0000f8c4       0x78 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f8c4                sym_34OQXU6XYDWKWHN5EMSCVCYRBEVOEZSUTYFYNWA
     .text          0x0000f93c       0x68 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f93c                sym_LZKUPPVFGF7KN7J3NAQQZHRWZPBIWIFOZAIRSWQ
     .text          0x0000f9a4       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f9a4                sym_VIDE7XVSTT4HHX2MQJX6VUVABAKVNGIPRTLRLEQ
     .text          0x0000f9dc       0x7c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000f9dc                sym_FYMYD324TMLKJZE62CZN4WTXFSPL6FPU2SZH6CI
     .text          0x0000fa58        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000fa58                sym_QQVHHHKNBN5TJBK4NCDSUYAMXMOEHFSL7HE7RRA
     .text          0x0000fa64       0xbc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000fa64                sym_CGZ3BF5ZKU6UVWHMUR5K3BTZYRKKHJZWYR44XTQ
     .text          0x0000fb20       0x50 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000fb20                sym_HGEYULLQFPGOCDUKWRXVXO5PYMDQCXREQGIGBVI
     .text          0x0000fb70        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000fb70                sym_I4MQGE3DKU2722TN7VIKAMWI3K5ZF2WRKNHLQNI
     .text          0x0000fb78       0x5c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000fb78                sym_LTPM5W6HOSKOWUVSOMQPOWG3TNNGMMZG4BBMFLY
     .text          0x0000fbd4       0x7c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000fbd4                sym_NM3NC22VCAJWDWP22LMDLLYRKYFLPOLTLPLJBTQ
     .text          0x0000fc50      0x1e8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000fc50                sym_BBEDNPQKB47SFC5ZKHGFDRE73X4SOFXGRLW54IA
     .text          0x0000fe38      0x120 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000fe38                sym_HFZHYA225GOHR3CNLTR6BRDMBVARDCSC72CK2GI
     .text          0x0000ff58        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000ff58                sym_X3V5KLWVLXHOLSU2PFGP6AMZ2Q746PMP6KQ46KA
     .text          0x0000ff64       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0000ff64                sym_XA5H4VPSPUXRG7PS4WSKZAIIFG5TMK4YQE3NXKA
     .text          0x0000ff74       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000ff90       0x5c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0000ffec       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00010028       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00010058       0xe8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00010140       0x94 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000101d4       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000101d4                sym_WP2M6F3KLYAV2UPD3NRHYRNOC2MXHDINQ723WIA
     .text          0x000101fc       0x40 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000101fc                sym_BDAH5ZZZLD7YDWJX4NK5LAWMMV2ZLUEQ62G7MUQ
     .text          0x0001023c       0xe8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001023c                sym_4TEUYRCFWCSQ6FTKO3BNFZBZXMIMKICSX5AYN3I
     .text          0x00010324       0x8c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00010324                sym_77ZFRD2P4SS4KHGMUROGCUHOHCMXE6H4OZWDCAQ
     .text          0x000103b0       0x5c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000103b0                sym_7Z2PN5FG3N2MNOF7PYHAHMNMDHG47RAJ5KQORXI
     .text          0x0001040c       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001041c       0x94 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001041c                sym_X7FI75RHOOLSZXGNVRPI3URKHEHK4RC7UYINLNY
     .text          0x000104b0       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000104b0                sym_TFVM2YD37OCOV6CPHIZ6U5DZME2VWJAYOCXZCPA
     .text          0x000104ec       0x88 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000104ec                sym_PGHYXS45ELGABETBKLHC44RLIO7ED7IIX6IR6WI
     .text          0x00010574       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00010584       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00010594        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000105a0       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000105bc       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000105bc                sym_T7VNKRFTRETJPNLHZUSK3KYNNJ74C4IFQD4NNHA
     .text          0x000105cc        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000105cc                sym_57EQTLF2S5UPOVZBBDLZKM5QMXMHPXPCXTSGD4Y
     .text          0x000105d8       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000105f4       0x50 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000105f4                sym_C2BMRHXC6YUGNOSXBSLT32MZR4IO4KKU4VF2Y4Q
     .text          0x00010644       0x68 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00010644                sym_HJXVM5XNFCTWWTQ4YLDP2IGYXOWNE4Q2JMCPZOA
     .text          0x000106ac       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000106ac                sym_2X3BT7BPHDD7LM2JK3H4NSU62TU3JWWE4WBGUMQ
     .text          0x000106cc       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000106cc                sym_6YG2XOY245ORZDAIB7IC5LMWO62SVGV3SYH4SYQ
     .text          0x000106f4       0x54 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000106f4                sym_K2NC2BIVFPITNJF53LD7PVJ2MKJHONZTL5WGF7A
     .text          0x00010748       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00010748                sym_THJMAW6SLTIFS5ZZJOFQ7EVUAVAGE7ZBUQNLOWI
     .text          0x0001076c       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001076c                sym_5TLERBFPJKRWQPVMHQVN4SPRMLUG3L57LXJAZ5I
     .text          0x000107a8       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000107a8                sym_F7IKMTFNRRALDUIC5CFAFOZWMHWI7JFMHO26D6I
     .text          0x000107b8       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000107b8                sym_J32TUFDCPQ7VZSX2HM7WVGCFTHTRE2CBZX443ZI
     .text          0x000107d0       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000107f4       0x34 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000107f4                sym_BZNHVORFFCB2VFYUC457ZCPYEKY4F5PGHOJ4GMQ
     .text          0x00010828       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00010828                sym_G7HJT7KU3VO444USDANIJFQYKYAZGURTI5LDR7I
     .text          0x00010844       0x58 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00010844                sym_2MNSL3NYFANWKOCCUB5OVR6CS76PVIOWXVZ4XNY
     .text          0x0001089c       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001089c                sym_L3EXR6IVYR56SHLRVEKAVQ5XTMJ6ELP4C5BLBVQ
     .text          0x000108c0        0xc /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
                    0x000108c0                mpsl_fem_caps_get
     .text          0x000108cc        0xc /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
                    0x000108cc                mpsl_fem_enable
     .text          0x000108d8        0xc /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
                    0x000108d8                mpsl_fem_disable
     .text          0x000108e4        0xc /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
                    0x000108e4                mpsl_fem_pa_configuration_set
     .text          0x000108f0        0xc /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
                    0x000108f0                mpsl_fem_lna_configuration_set
     .text          0x000108fc        0xc /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
                    0x000108fc                mpsl_fem_pa_configuration_clear
     .text          0x00010908        0xc /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
                    0x00010908                mpsl_fem_lna_configuration_clear
     .text          0x00010914        0xc /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
                    0x00010914                mpsl_fem_pa_power_control_set
     .text          0x00010920       0x18 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
                    0x00010920                mpsl_fem_tx_power_split
     .text          0x00010938        0xc /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
                    0x00010938                mpsl_fem_device_config_254_apply_get
     .text          0x00010944       0x3c /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
                    0x00010944                mpsl_fem_utils_available_cc_channels_cache
     .text          0x00010980       0x40 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
                    0x00010980                sym_NIQMZN22R7GGCSNM3BZ25GTCR6D457XB3DIUGWA
     .text          0x000109c0        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000109c0                sym_3NUECOSAIC227DBCPHAP4U7EQ3UBTGANU5ASIOA
     .text          0x000109cc       0x34 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000109cc                sym_QLJBNB55XHXGY3EZ4W3ZZ3U6AVPE2YGDOXRUZSQ
     .text          0x00010a00       0x54 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00010a00                sym_VWOYI7XCNXBFVPWSS6WFJ2CWKPJYCMRRQTU7QWQ
     .text          0x00010a54       0x20 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00010a54                mpsl_tx_power_radio_supported_power_adjust
     .text          0x00010a74       0x7c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00010a74                sym_JBMIQXYLJQQB56KLSIZ2WVKBMEMRZHLRBGLEPTA
     .text          0x00010af0       0x28 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00010af0                sym_QQG7HJZF5RKNVZ5ORSKL5T523LPMNSUMOGD3C6I
     .text          0x00010b18        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00010b18                sym_PIRI3CTIHOPR5MPDQRHBJRRZEA2NVOD4J3GXGOA
     .text          0x00010b24       0x24 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00010b24                sym_ANRUIR5GOVXEY2YOSMACTCMXBQZWQ3XNE43TVMQ
     .text          0x00010b48       0x18 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00010b60       0x30 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00010b90       0x44 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00010b90                sym_D6LBAH3FIHQ2AN26SDSJLEG4XAEK556FOQIW6HA
     .text          0x00010bd4       0x18 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00010bd4                sym_7QFYP6TVNTWMYUHAAVGAS6P7DNXRGA425JCWAYA
     .text          0x00010bec        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00010bec                sym_3SZAYBC5OCNQZBIVUZYG7A3DU4BAGVEUO2Y2ZRA
     .text          0x00010bf8        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00010bf8                sym_2KMHJG6IWTS4F37J76OPGV6TB6CGBJE6GPXD32Q
     .text          0x00010c04        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00010c04                sym_NOQLYJY4KXAQRVVN7T7QV7ANR4MNJAXOKJCQGHI
     .text          0x00010c10       0x38 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00010c10                sym_G5J6GA5DO57F3RA6WFNEHNPECPBC7Z24DL4LMSI
     .text          0x00010c48       0x34 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00010c7c       0x34 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00010c7c                sym_KDG2QV44ALYOJ3VXK5EAFUKKY3P3LYTXXEA7CSI
     .text          0x00010cb0       0x10 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00010cb0                sym_SDHO22NE7WQFGQ4CQJRIJINUULFKMZETRQXV3VQ
     .text          0x00010cc0       0x78 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00010cc0                sym_PPHZHUJXI7LPAEI5QUASSIIGHAIVT4H7EME7O3Y
     .text          0x00010d38      0x138 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00010d38                MPSL_IRQ_CLOCK_Handler
     .text          0x00010e70       0x1c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00010e70                sym_76IVKPQMZOZ7IXNJTGMWOSIWIVCASAX3TTNHN7I
     .text          0x00010e8c      0x230 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00010e8c                sym_GYXW4XY25R4ELPOOTEBFKAUAI3X7A5AGZZV7OTI
     .text          0x000110bc       0x44 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000110bc                sym_YHVCZX2JW2WJF77BGOWGQVSUJFQZOE2VIV4ZMVI
     .text          0x00011100       0x38 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011100                mpsl_clock_hfclk_src_request
     .text          0x00011138       0x34 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011138                mpsl_clock_hfclk_src_release
     .text          0x0001116c       0x54 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x0001116c                sym_XEJLNUQGS5P4R5IXDJFF6NE6C2FZWRZYDQOGMPI
     .text          0x000111c0        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000111c0                sym_PEUB6CZG5CWXXD4M2S6OVBXZGDFOG4XII7USUDQ
     .text          0x000111cc        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000111cc                sym_AF5XKA2WT4DMFZTLKHOBWE7E2EZAMLDDFPQGGTQ
     .text          0x000111d8        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000111d8                sym_DCDRLVBT43ANSLX3KNDZ4TST3Z3CVWXAQQUSXQQ
     .text          0x000111e4        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000111e4                sym_4CZSFTTT34WDYFZKE2NSCSVSYLPHLZYN7QUTGHY
     .text          0x000111f0        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000111f0                sym_UG7CMBAYEZEKSKQK753P4TBTSPUXVRWUS6QJJOA
     .text          0x000111fc       0x14 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000111fc                sym_ETIE3PCEXQYLK2GIVZENQ6V7PLBRV57MB7BDMNY
     .text          0x00011210       0x14 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011210                sym_5GIX3FGTOA3AFESAMMV6FULZ3AVI2Q2R6VR4L4A
     .text          0x00011224       0x10 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011224                sym_A4JUKJUCTJV55V2WD6TXU63VO5GAMB4XA4EE56Q
     .text          0x00011234        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011234                sym_4PX37LW4KIUYQZ73JWLPH5GAGIRWAKTV3E6F62Q
     .text          0x00011240       0x70 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011240                sym_FYHKZOVAJN6VDDHY43FT7PF4YLRDHWRTEWHFG6I
     .text          0x000112b0       0x24 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000112b0                mpsl_clock_hfclk_latency_set
     .text          0x000112d4       0x24 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000112d4                sym_AZF6WXJCN65YCD7ZAP7TGVQYTJ5FWOMJFQCRXXY
     .text          0x000112f8        0x4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000112f8                sym_HKMCZYQJFPVS7WWBB467IOVE6DXROPF6QTNSZSY
     .text          0x000112fc        0x8 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000112fc                sym_RKTRVZBVZOE2H7X26CNCGRCK4TXNFDN5CYTLZVI
     .text          0x00011304        0x4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011304                sym_X4EOLDS7HLJRJIC2W2ME75XVHAUB5QNQKLPOW5A
     .text          0x00011308        0x4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011308                sym_7XZ7GBQEVTLKCTY6TSRHEGOCEELZ2ECRZJ6DHRI
     .text          0x0001130c        0x4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x0001130c                sym_SPAHHGRX4AQXQBNMW7NMLLFT4LSP2I3MBEV7CZQ
     .text          0x00011310        0x4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011310                sym_K25ZYC6ARN7UUPJQIXPX4BET2ZZRP6QSSPY5TIY
     .text          0x00011314        0x4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011314                sym_2LPOSKXZQ7LV24SDKLXMO6RTRMIQKBMN6P3PD6I
     .text          0x00011318       0x10 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011318                sym_L3BWYCQWIETVHY7KA4HB4DY5VX35JKUQV3DDRQI
     .text          0x00011328       0x84 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011328                sym_5UC6I2IFHRSO64HSQBXZGO3KJYKHBIJFZGOJVAQ
     .text          0x000113ac       0x48 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000113ac                sym_3WNEAT5G5YP2Y26XV3EJMEXLDNBI744C4KPB2PI
     .text          0x000113f4       0x58 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000113f4                sym_P6UKWXUEG2A2QOVDYCZXLZEWNE6FKCCKUQ7RSXQ
     .text          0x0001144c       0x10 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x0001144c                sym_7YM64HZKJSZJ2NGD75BB2X7S77SP5MW3H47NBFQ
     .text          0x0001145c       0x2c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x0001145c                sym_VEA3XUXA6JWPVDZO4KUGMREAFE6SS5ISNSUBONI
     .text          0x00011488       0x4c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011488                sym_T24WQXZURS7Z5GWHZHR3TQPSU7OKZ2PFAUQ5SIA
     .text          0x000114d4       0x58 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000114d4                sym_CRE2QWRQ3K2HPKTULCVLC7KROLI7YLNX5JECKWI
     .text          0x0001152c       0x5c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x0001152c                sym_VFDKZQRJAY62UBZN675F55ZLCNSA6LERZFHLF3Q
     .text          0x00011588        0x8 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011588                sym_IGFWPOUREFVROBJVR4P53OHBIBQSQYQO7JFK4KY
     .text          0x00011590        0x4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011590                sym_DCETU5HKNHTQ67HARON3NMO7S3T2ZRZMZY3DKOI
     .text          0x00011594       0x14 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011594                sym_STPNHTH23VFTLN4WX6C46XEWV2PMYYGL54MRIKA
     .text          0x000115a8       0xb0 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000115a8                sym_VWCQC4A3I3LBNIAAOSCGISP76ESOP4DNE3DCHGI
     .text          0x00011658       0x78 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x000116d0       0xa4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00011774      0x1cc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00011940       0x34 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011940                sym_NAXHIIDB2OHTHT3Y3H6X2OTPPEM5W7LSTNSI73Q
     .text          0x00011974       0x14 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011974                sym_C5J26E5S2LFIPDPNZOXPD63JBZN57EZGBRF2HIQ
     .text          0x00011988       0x30 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011988                sym_ZOPRLHE544AAAOQWETJSYDQQYAWWWJXKNTSNVGA
     .text          0x000119b8       0x8c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000119b8                sym_AMBHYXNU7PYNDAKUHUROD5SXBMYJXIUVA52R4VA
     .text          0x00011a44       0x60 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011a44                sym_6QFB7MDKADZ77L2VCGCE3NDXUGZBDHKLHID2BJA
     .text          0x00011aa4      0x130 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011aa4                sym_6W3JRFJFKWMHX5TF6XOWKXMCNHQXLMTODZI37OA
     .text          0x00011bd4       0x1c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011bd4                sym_JV7ILQ3KWGAHJYOG3LBRTREVFC2XKOW6DAXBQEY
     .text          0x00011bf0       0x78 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011bf0                sym_VYUIG5G7GY35JENLAM47M3J7YIGG7HW6HUGO6KQ
     .text          0x00011c68       0x60 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011c68                sym_B2V4CDOC44GG7XX3H5MPZLGUPL7TEUR3AYKLLBQ
     .text          0x00011cc8       0x4c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011cc8                sym_5JCST2ZL2CQUW54F7Y33QYQ7U6G6DOTLZEP3EWY
     .text          0x00011d14       0xfc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00011d14                sym_VWNWKQK3PM3PBLDVWENR67TH6FEMRVCKKZSIK2Q
     .text          0x00011e10       0x10 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00011e20       0x1c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00011e3c      0x14c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00011f88       0x74 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00011ffc       0xd0 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x000120cc      0x1f4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x000122c0       0x2c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x000122ec       0x24 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000122ec                sym_3IXWYTL62NHWC237SHWLZ2OF2TW5NMM4SULZS3Q
     .text          0x00012310       0x24 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012310                sym_JMUFINQ2ZTLEACYBPPJYZKOXXLILGIDNEIYCRWA
     .text          0x00012334       0x1c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012334                sym_HDMVO4M24IIKUBW344PSZFWT25OK2Y3PVJE5WRI
     .text          0x00012350       0x2c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012350                sym_S4TFNK3WGRXVRRDW5ADPHNU4GFD4F3DVY5ZY6KI
     .text          0x0001237c       0x1c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x0001237c                sym_CYUDWAUG2VYBNAB2X3MWFN66YIYJWWBK3FINVBY
     .text          0x00012398       0x18 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012398                sym_YG3B2TXGZTCM6KBDWLP4S74MKBRFKP2JB24T3HQ
     .text          0x000123b0       0x18 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000123b0                sym_E6S7HOMFELNIBFF7WVBBMRGAYP3FKFJEQZB5NWQ
     .text          0x000123c8       0x18 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000123c8                MPSL_IRQ_TIMER0_Handler
     .text          0x000123e0       0x18 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000123e0                MPSL_IRQ_RADIO_Handler
     .text          0x000123f8        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000123f8                sym_H7CLSHW3BPTUSN7LCXDTWPY3F6XXYV3MEQ2IQLI
     .text          0x00012404       0x1c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012404                sym_G3XKMK6YL3MTP4PJEB2KZSJIFBUFHOHIA7GBHTY
     .text          0x00012420       0x14 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012420                sym_S6YNDQBPWWSLDB7LTJPEYQR76RDFWJKOMVQ2DOQ
     .text          0x00012434       0x1c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00012450       0x1c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x0001246c       0x78 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x000124e4       0x10 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000124e4                sym_ZC6NJBPUISWILQK6OTOBMJVVUT63JRIDGH5WNCY
     .text          0x000124f4       0x28 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000124f4                sym_SFR5TVV24PZRIRC5QGOHL2X436PUHKRY2QWKP5Y
     .text          0x0001251c        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x0001251c                sym_YIXEQJMC74KOMUIELN7JRBVVVXGKVCXD6BJJPLY
     .text          0x00012528       0xe8 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012528                sym_JDHOFUMREBDWEIDJYXMJPWHSFHOMYLYNQJSPRFI
     .text          0x00012610       0x40 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012610                sym_CVH6S6LMSFPC2RM6I6LYWFRVOJUD3A6OCMG7AAI
     .text          0x00012650       0x74 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012650                sym_3LN4G2W73DBJOAL3YCEBF3DXNFZD3YNXJCCG6XA
     .text          0x000126c4       0x70 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00012734       0x38 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012734                sym_YUVDG5ODI45JFXF2MI2J45OIQTGFR4STYDHP3IA
     .text          0x0001276c      0x104 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x0001276c                sym_WBVPSVQ6CYPOTN4U22HRFFY3ALJECB3FCOQILFY
     .text          0x00012870       0x18 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012870                sym_NUK6YCYQAPRYART2WXI76K4M4WFNS4ROZRZYOLA
     .text          0x00012888       0x68 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012888                sym_JDJVBJ5RZTQP4SUZCUDJQCUWRNJJ5325BFBDJBQ
     .text          0x000128f0      0x184 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000128f0                sym_MDIROPJ5CN4EOK522EMBID7TI3QVUPNMDDKEDRA
     .text          0x00012a74       0x24 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012a74                sym_AXCLSX5ZESHPV2W4MPD4KGSIC6MNQT6A3I2UDNI
     .text          0x00012a98       0xf8 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012a98                sym_4JJF5G6JDH5DHHWGXYULEBA37RWDGSYCSW4GQCA
     .text          0x00012b90      0x100 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012b90                sym_GQJZK6O6HQLD66XOBFIMPYL2IHZEM2RHSAX5AXQ
     .text          0x00012c90      0x188 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012c90                sym_OXF7O7KEVCVLWTVCZQ7QCG5LQEVF5ZV5KG57PFY
     .text          0x00012e18       0x24 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012e18                sym_5AITSRFP5K4RU2IVS7HZRJZWJLBW627WCUYUDJY
     .text          0x00012e3c       0xf8 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012e3c                sym_TR5YGWT3XYIZVSRJPYXHIXDE5EZF5EOQTYW6CQA
     .text          0x00012f34       0x10 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012f34                sym_53QDCYY323GAZ4LCKPG5SCWBP6WXE2TVYFFHUXI
     .text          0x00012f44       0x10 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012f44                sym_IFX47LUD6HWXPW2DRHE2LCAEOQIIP2C2RULGL6Y
     .text          0x00012f54       0x2c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012f54                sym_EC336Q65G3J36PYUB7SGHXXHMHDTOULAOHEJK2I
     .text          0x00012f80      0x104 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00012f80                MPSL_IRQ_RTC0_Handler
     .text          0x00013084        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013084                sym_SKFSQME5SGNPYLL7B75KY7PHXFYWSRI2HSTT45A
     .text          0x00013090       0x18 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013090                sym_4RNEPYYQOFM4LAOGLN2TB27X7L3XBISTGAWYOHQ
     .text          0x000130a8       0x30 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x000130d8       0x30 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00013108       0x2c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00013134       0x3c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013134                sym_S2UAPMFVIQXDUOA6CV7GJMB33TYHEUH5D6LHO5Q
     .text          0x00013170       0x88 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013170                mpsl_init
     .text          0x000131f8       0x28 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000131f8                sym_XR32KBBIVYD5OVRJM2RBQ57EGCCM2C3F5IY6OHQ
     .text          0x00013220        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013220                mpsl_is_initialized
     .text          0x0001322c       0x24 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x0001322c                mpsl_build_revision_get
     .text          0x00013250       0xb4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x00013304       0xa4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013304                sym_KRTSAGE6UQEKIDTX7YT7JTDHPIQDYPJEPVEBI7Y
     .text          0x000133a8       0x14 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000133a8                mpsl_ecb_block_encrypt_extended
     .text          0x000133bc       0x78 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000133bc                mpsl_temperature_get
     .text          0x00013434       0x34 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013434                sym_W7ROFHNOSDKPIRUKDGIZZ5YR3MC3DAM2YLJOUIA
     .text          0x00013468       0x20 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013468                sym_BJJ4JJDCVJTQH3OQZK6RMMOLISQZEJEZ3BJOKJY
     .text          0x00013488       0x3c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013488                sym_GURZ3AH6X65RGSKYMYNWZVP6HM56LA5MRAQWT6Q
     .text          0x000134c4       0x4c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000134c4                sym_VWGRUQT3LYZHLYS5KJ7UOCJEHLDJTWH4RVJBGKQ
     .text          0x00013510       0x18 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013510                sym_CG4RHEKAJT5SDDAMNZDGCGOIJ7U3JN5EOJ5RYKA
     .text          0x00013528       0x30 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013528                sym_4WL3TG4Q7RCTFEMPQ2CQTOL4PAKUULDPJUM5DTY
     .text          0x00013558       0x60 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x000135b8       0x90 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000135b8                sym_2FGI6PRNKAQGGACVKJNWC6EWB4C4ZZYUSEGOPOI
     .text          0x00013648       0x18 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013648                sym_ZY67JFDYC72ZRZASFF2HOA7TV55LM74BXABVWRI
     .text          0x00013660       0xa8 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013660                sym_R66O3ZG7PAFXV56YPWXD7FGU6UB3QYBQIHK33BQ
     .text          0x00013708       0x3c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013708                sym_K65IFLJONCLHPD5IQ4ENBWGA3PVI55UHZKOIVDQ
     .text          0x00013744       0x80 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013744                sym_525JLJ5JEQ6FEZGTSIW74UTOCUZ2F4YECMQ6KVQ
     .text          0x000137c4       0x80 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000137c4                sym_VSILKYHVQ5DVF6LG5MG267DQVA3A2XZQ6FSCLXA
     .text          0x00013844       0x84 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013844                sym_BJB2SHFVXTCG6O44QAJRYK7KNHZRHZ4BETJJQ7Y
     .text          0x000138c8      0x158 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000138c8                sym_DQONLUECJTIEYFOFJXXAPJO4POIAJKJNKBGVN5A
     .text          0x00013a20        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013a20                mpsl_cx_request
     .text          0x00013a2c        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013a2c                mpsl_cx_release
     .text          0x00013a38        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013a38                mpsl_cx_granted_ops_get
     .text          0x00013a44        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013a44                mpsl_cx_register_callback
     .text          0x00013a50       0x18 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013a50                sym_OHTBSWYPR4OU4P2B6NF3OXQS5L223XCMLPNSNLI
     .text          0x00013a68       0x14 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00013a68                sym_OW4FCVYV7CD5K552B5EATVXKXK5HNDFX7JEYSUI
     .text          0x00013a7c       0x12 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013a7c                sdc_hci_cmd_cb_reset
     .text          0x00013a8e        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013a8e                sdc_build_revision_get
     .text          0x00013a92        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013a92                sdc_support_le_2m_phy
     .text          0x00013a96        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013a96                sdc_support_le_coded_phy
     .text          0x00013a9a        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013a9a                sdc_support_phy_update_central
     .text          0x00013a9e        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013a9e                sdc_support_phy_update_peripheral
     .text          0x00013aa2        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013aa2                sdc_support_le_privacy
     .text          0x00013aa6        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013aa6                sdc_support_direct_test_mode
     .text          0x00013aaa       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013aaa                sdc_hci_cmd_vs_zephyr_read_version_info
     .text          0x00013ada        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013ada                sdc_hci_cmd_vs_zephyr_write_bd_addr
     .text          0x00013ade       0x48 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013ade                sdc_hci_cmd_vs_zephyr_read_static_addresses
     .text          0x00013b26       0x3a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013b26                sdc_hci_cmd_vs_zephyr_read_key_hierarchy_roots
     .text          0x00013b60       0x2c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013b60                sdc_hci_cmd_vs_zephyr_read_chip_temp
     .text          0x00013b8c        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013b8c                sdc_hci_cmd_vs_peripheral_latency_mode_set
     .text          0x00013b94        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013b94                sdc_hci_cmd_vs_compat_mode_window_offset_set
     .text          0x00013ba0       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013ba0                sdc_hci_cmd_vs_get_next_conn_event_counter
     .text          0x00013bbe       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00013bda       0x92 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013bda                sym_MS2INTHZLDZMKZ5TZUDLWHPLKH3FLVZPA26JG6A
     .text          0x00013c6c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013c6c                sym_PVKZWZJ5CJJGE5FITE5FOMMY5J4BUV2COWMQKSY
     .text          0x00013c70      0x200 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013c70                sym_XMQQMVD4MD6DRWNW2DWSCGOMJHFY3IX7NXUHTGI
     .text          0x00013e70       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013e70                sdc_hci_data_put
     .text          0x00013e86       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013e86                sdc_hci_get
     .text          0x00013ea6       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013ea6                sym_A7PVZLRTORLFMETW3GOBE4DG32WTH46LP2SW5QQ
     .text          0x00013ee2       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013ee2                sym_XCF2HHS4DO2JW2ILCF4RJW66HXXYOROBK7NUPMY
     .text          0x00013f1a       0x26 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013f1a                sym_E56LW5YVGUG6HP2OML5URHI7K2KCWX5ULQKQOKY
     .text          0x00013f40       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013f40                sym_GY6HW2EOPDDWC2CI5H63QTBNGQK3KCPAMBHR3EY
     .text          0x00013f58       0x36 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013f58                sym_TDLIKQLE652KPCFAMYL33G6BKGPHRLYLWNEOTHQ
     .text          0x00013f8e       0x4a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013f8e                sym_47GVMLF7NXDJBYC2TPU2ES3ZL6CP4GIPWKYYWBI
     .text          0x00013fd8       0x48 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00013fd8                sym_UOYZDE3MDLGPDL5S5WKUFLPYH4DJIMF3BJSBDYA
     .text          0x00014020       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014020                sym_PTZ4EWNTFK5S5TZGCBNFETDF37P4DBX7VGM33II
     .text          0x00014034        0xe /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014034                sym_B62EJKCCJ4JFC5I4BFTUJG7GNOKGWQ4KKFBS6RI
     .text          0x00014042       0x42 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014042                sym_4WKKRRMMNLQOCTRGC2MVIREG5QOCFUEL67TBUQY
     .text          0x00014084       0x2e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014084                sym_4DUZAAZKVNAL6VUHN4XAFX35FQKJS4D7DISLHDI
     .text          0x000140b2       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000140b2                sym_3LZ364FVGUVSOSH6XGIFMW5SY36X7BQXDOES46Y
     .text          0x000140c2       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000140c2                sym_RZ3AO5KZJYCPFG5YW4CBZQF5SRGN3BPTEGBY47I
     .text          0x000140de        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000140de                sym_ML67AS5GCNDBSY5FTPMH2FWCRUGNSSLQDJ2QTYY
     .text          0x000140e6        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000140e6                sym_KS7EREVMGN2POBMEM6TE3IGK2TH5L7OSMH6ZTTQ
     .text          0x000140ee        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000140ee                sym_UPAEGKLCM3QW7VHROMMVD5MIRBTM2NGCYENWSLI
     .text          0x000140f2       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000140f2                sym_Q4EW623JZHY67RB7U4Z2L2SMI5ENWIDFL23JZHQ
     .text          0x00014112       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014112                sym_LIYGXI2UGDXBB3WZBJYHTKFR7X66AHBTSGA7ZTA
     .text          0x00014126       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014126                sym_4FRIF7JGOVTE7JZ3KYQVPKX5PKSXGKCIHE6GQDY
     .text          0x0001413e       0x48 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001413e                sym_JTNP7UFMKYWSFCHJEA5IASO3QVW3HK4YV6YOJYQ
     .text          0x00014186        0xe /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014186                sym_B627VJPECYREV5OY4VJ652ISBA4XGPKVOUJ747A
     .text          0x00014194       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000141d0       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000141e0       0x36 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000141e0                sym_HNCDHITBYWLO4GMOSPKCO7YXRRWIUQ2IKIZ4C5A
     .text          0x00014216       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014216                sym_WDNTHBFS7DQM3AR7WDCR7ZEICFH5ZM5PJ35BRPY
     .text          0x0001423e       0x44 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001423e                sym_XSEZXMQQS2VJJZHPRHPSZNIZGQFJE2LG6GV7GQQ
     .text          0x00014282        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014282                sym_G2PUTSSEY3RLL4V2PRG7SOQ4CXZCM7HCVJY7ENI
     .text          0x0001428e       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001428e                sym_EOUZIDBP3HL2GT63FUCLAQVGISX2MLIV4MK5FZY
     .text          0x000142ae       0x12 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000142ae                sym_5RQ4FZRNKDUYW7D36K54TV4FI3NLNURNJPSLJOY
     .text          0x000142c0        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000142c0                sym_SCCFLYV5KOPRJ5S7RGDC2KDSCCHMKXYC3EQIE6A
     .text          0x000142c6       0x62 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000142c6                sym_F5SXUQLY6DFZ5NXKJ4VFIGAK52D6AM5LN2AJKSY
     .text          0x00014328       0x48 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014328                sym_OC5GPSERLPE7TKXSCU3QAZ62H3OM4MWFYV7WX2I
     .text          0x00014370       0x4e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014370                sym_VPXIA5P4C72CY3ME4ZVXBADOKEG5S4C7Z7QZZFA
     .text          0x000143be       0x4a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000143be                sym_MF4WRTQNYFRYRFGW7FZUI3ZAYNQZ5EQ54QSK6JQ
     .text          0x00014408       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014408                sym_DPFAWTOI3GRLXCS5TV5FXLZJNKWMRLYTLT4DRFY
     .text          0x0001441e       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001441e                sym_27RZBWKBTESKUPVNN3E7RHYQU6UH4RT372SK2WA
     .text          0x00014434       0x12 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014434                sym_IBQ2J6PQMWEGB2QFNQVSDUN2ZUMMRTUFKUUZT2I
     .text          0x00014446       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014446                sym_RIJIFYF46ZRKFDPA3GKV7WCH2VGEUEP6MVN4JFI
     .text          0x00014466       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014466                sym_MJFFFAJVV3IQTOJK6UL2575XXGCEKTIIFXD5MAQ
     .text          0x00014486       0x4c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000144d2        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000144d2                sym_T2WGCKXTT3AQKC37WUCKG6LFMKIXXWS3R6ESLQQ
     .text          0x000144d6       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000144f6       0x22 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00014518      0x14c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00014664       0x3e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014664                sym_DP474BSWQ6W7M27XE2M7XMGWSDEQ3KL66B2SR5Q
     .text          0x000146a2        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000146ae       0x34 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000146e2       0x1a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000146fc       0x7a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00014776       0x2a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000147a0       0x8c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001482c       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00014842        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001484e       0x1a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00014868       0x48 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000148b0       0x64 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00014914       0x1a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014914                sym_24AALTDC2IQ6VNWU2ALOY4V3RG5R2RARTUG4AZY
     .text          0x0001492e        0xe /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001492e                sdc_hci_cmd_le_read_filter_accept_list_size
     .text          0x0001493c       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001493c                sdc_hci_cmd_le_clear_filter_accept_list
     .text          0x00014958       0x46 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014958                sdc_hci_cmd_le_add_device_to_resolving_list
     .text          0x0001499e       0x34 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001499e                sdc_hci_cmd_le_remove_device_from_resolving_list
     .text          0x000149d2       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000149d2                sdc_hci_cmd_le_add_device_to_filter_accept_list
     .text          0x00014a0a       0x36 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014a0a                sdc_hci_cmd_le_remove_device_from_filter_accept_list
     .text          0x00014a40       0x12 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014a40                sdc_hci_cmd_le_set_resolvable_private_address_timeout
     .text          0x00014a52       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014a52                sdc_hci_cmd_le_set_address_resolution_enable
     .text          0x00014a72       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014a72                sdc_hci_cmd_le_clear_resolving_list
     .text          0x00014a8e        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014a8e                sdc_hci_cmd_le_read_resolving_list_size
     .text          0x00014a96       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014a96                sdc_hci_cmd_ip_read_local_version_information
     .text          0x00014aae        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014aae                sdc_hci_cmd_le_rand
     .text          0x00014aba       0x36 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014aba                sdc_hci_cmd_cb_read_transmit_power_level
     .text          0x00014af0       0x22 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014af0                sdc_hci_cmd_le_read_transmit_power
     .text          0x00014b12       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014b12                sdc_hci_cmd_le_read_adv_physical_channel_tx_power
     .text          0x00014b28       0x12 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014b28                sdc_hci_cmd_le_encrypt
     .text          0x00014b3a       0x2e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014b3a                sym_ARFXVVF4DL2JIIQASHFJMIOCUHMKDVBFL25PD3A
     .text          0x00014b68       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014b68                sdc_hci_cmd_ip_read_bd_addr
     .text          0x00014b7e       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014b7e                sym_4JSL5B25NNB5WWK7I5BGUTCTKEZ4HYLOODANEEQ
     .text          0x00014ba2       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014ba2                sdc_hci_cmd_le_set_random_address
     .text          0x00014bbe       0x3e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014bbe                sdc_hci_cmd_le_read_channel_map
     .text          0x00014bfc       0x2e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014bfc                sdc_hci_cmd_le_set_privacy_mode
     .text          0x00014c2a       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014c2a                sdc_hci_cmd_le_read_phy
     .text          0x00014c66       0x68 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014c66                sym_TWSXGABZDFOR6GMTPL43NA2Q7GCJDL7RARUHBMQ
     .text          0x00014cce       0x56 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014cce                sdc_hci_cmd_le_set_phy
     .text          0x00014d24       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014d24                sdc_hci_cmd_le_set_scan_enable
     .text          0x00014d48       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014d48                sym_7FOXGNIIIKWTK7LVO3GURVRGLMM3ARJVLEJOXQY
     .text          0x00014d68       0xf0 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014d68                sdc_hci_cmd_le_conn_update
     .text          0x00014e58       0xac /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014e58                sdc_hci_cmd_le_set_host_channel_classification
     .text          0x00014f04       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014f04                sdc_hci_cmd_le_read_remote_features
     .text          0x00014f24       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014f24                sdc_hci_cmd_le_read_local_supported_features
     .text          0x00014f34       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014f34                sdc_hci_cmd_le_read_all_local_supported_features
     .text          0x00014f64       0x80 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014f64                sym_UDDGVC44TSMRJ3562FYNYMFQZCK4HTKMJC6WPRQ
     .text          0x00014fe4       0x3e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00014fe4                sdc_hci_cmd_le_enable_encryption
     .text          0x00015022       0x4a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015022                sdc_hci_cmd_le_set_scan_response_data
     .text          0x0001506c       0x4a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001506c                sdc_hci_cmd_le_set_adv_data
     .text          0x000150b6       0x42 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000150b6                sdc_hci_cmd_le_set_adv_enable
     .text          0x000150f8       0x22 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000150f8                sdc_hci_cmd_le_long_term_key_request_reply
     .text          0x0001511a       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001511a                sdc_hci_cmd_le_long_term_key_request_negative_reply
     .text          0x00015138       0x46 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015138                sdc_hci_cmd_cb_read_authenticated_payload_timeout
     .text          0x0001517e       0x84 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001517e                sdc_hci_cmd_cb_write_authenticated_payload_timeout
     .text          0x00015202       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015202                sdc_hci_cmd_sp_read_rssi
     .text          0x0001521e       0x3a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001521e                sym_HZRUCXEK6VH2SKHLITFSCAH5JZW3VUS5CZD2RBY
     .text          0x00015258       0x2e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015258                sdc_hci_cmd_vs_set_adv_randomness
     .text          0x00015286       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015286                sdc_hci_cmd_vs_conn_event_extend
     .text          0x000152a6        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000152a6                sym_VEJZA46I7OZP2PT3YB4JPMA4TOGX2UDHPJG3AMA
     .text          0x000152ac        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000152ac                sym_266BMVQDBLXULMLATXWWN2P23YFP57RBL2ZNQ7A
     .text          0x000152b2        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000152b2                sym_RJCZ3TUNFFUZPTNFXG35SLVXYYJ7NVMTPNXKOXY
     .text          0x000152b8        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000152b8                sym_7ZWRNRN6OJ5G7BJWG232R5QOQBW4NK4HJWYOG5A
     .text          0x000152bc        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000152bc                sym_XGMYPLGF3Q5IDBTHXI7LBKOVEGJV3YOSYITNMYA
     .text          0x000152c0       0x2c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000152c0                sdc_hci_cmd_le_transmitter_test_v1
     .text          0x000152ec       0x2c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000152ec                sdc_hci_cmd_le_transmitter_test_v2
     .text          0x00015318       0x3e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015318                sdc_hci_cmd_le_transmitter_test_v3
     .text          0x00015356       0x54 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015356                sdc_hci_cmd_le_transmitter_test_v4
     .text          0x000153aa       0x2e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000153aa                sdc_hci_cmd_vs_transmitter_carrier_test
     .text          0x000153d8       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000153d8                sdc_hci_cmd_le_receiver_test_v1
     .text          0x000153f8       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000153f8                sdc_hci_cmd_le_receiver_test_v2
     .text          0x00015418        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015418                sdc_hci_cmd_le_test_end
     .text          0x0001541c       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001542c       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00015448       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001545e       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00015474        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00015478        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001547c       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001549a       0x26 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000154c0        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000154c4       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000154da       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000154f0        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000154f4       0x12 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00015506       0x1a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00015520       0x1a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001553a       0x40 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001553a                sym_IQSWXNPAP5XQLQLUPE5FMOB6CHB4XTBZ5UPHZ5Q
     .text          0x0001557a        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001557a                sym_YF4J4DGFDTHAWVS7CGH7Q6ZE54T3BMAUQX7A5ZA
     .text          0x00015586        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015586                sym_R2552DB5ZKNDWW24PBGEV77VCDBC44WVAYRCUXQ
     .text          0x0001558a       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001558a                sym_N4QRZBF2FIWL2SJPDNB5CJNAF73PGHUMQ7KGJGA
     .text          0x000155a0       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000155c4       0x2a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000155c4                sym_5VVLOOBGZR2S7XESULKPEPPOXTZI2DRVE7VW2TY
     .text          0x000155ee       0x9e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001568c       0x56 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000156e2       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000156e2                sym_5UID3SBXLTGQYGRFXVINZNLWHB7EKFT76O275JI
     .text          0x000156f8       0x1a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000156f8                sym_J7GHPMETICF7YIYPYOXLDAIRSL3H3JYLLEQ3C4Q
     .text          0x00015712       0xc6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015712                sym_RRC5YHH6YM3SHNGPFUCE3YX5LDRJC7YUGPWWYHQ
     .text          0x000157d8       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000157d8                sym_6NVBTUP3F2K4CR6EQ2CJTT2FVJIBKKWMISPRCSI
     .text          0x00015808       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015808                sym_Z5P37ZM5NV6ZBT22ED5VVQFLDPP3QCCN56BNOSQ
     .text          0x0001581e       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001581e                sym_3QEMBVUTVAJLNXVXP3EOW4CIXWUCZWELPHO6BVA
     .text          0x00015856       0x6e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015856                sym_C7VVW2UID5D7DBAAW3VTJSH5PCAO3YSDQWXSCAI
     .text          0x000158c4       0x74 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000158c4                sym_DVTRQHAKMDV4YAVEAR5OWKIEHAIERTOUNUNQQCA
     .text          0x00015938       0x42 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015938                sym_HXHGQZG5JTAFRHWMQAPJ6HVLUUHUFG7HQQBAFUY
     .text          0x0001597a       0x52 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001597a                sym_WUTHT64SVNE35IPANCVDTV5MBBBF5CQ7VOGI65I
     .text          0x000159cc       0x62 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000159cc                sym_YNSETM6OCWZFPZYFRH2O6YPHBA6N2DTJIZFZSCA
     .text          0x00015a2e       0x1a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015a2e                sym_SICJIUWQ7BCWEYTQIT6XRP4QI64HKVMZBOORCIY
     .text          0x00015a48       0xa2 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015a48                sym_4PJDZ4FU7KQEM7YSHRV27QJQIZ7GNDHCRYXGEQQ
     .text          0x00015aea        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015aea                sym_QXKT3PVMDTZRAAU2QNTWO5VOUEZ4NW6TWISREXY
     .text          0x00015aee        0x2 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015aee                sym_BGPX36PUCNVPV3544HQ5RQFY5WG7CJAFVVBI7AY
     .text          0x00015af0       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015af0                sym_4ZZLWI6QQY4KJYYVP4RVDTJJJ6MW72AL2TJDVOI
     .text          0x00015b2c       0x1a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00015b46       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015b46                sym_G6YVAU2J75AOT237PVQAC5AEQMWPZ6OKE6ASZAI
     .text          0x00015b64       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015b64                sym_QW6JOH7RCJIC2YFNJEURX5QNB5EIQT646EHIWEA
     .text          0x00015b78       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015b78                sym_GKUVQYGVTZ7DKWBNC3M5TXN4XZ4Q6TUJFSFOWBA
     .text          0x00015b8c       0x2c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015b8c                sym_J5GU2YSZI45UA3YHIJMMX6SWAYPKQ5HXJLXKPXY
     .text          0x00015bb8       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015bb8                sym_35JWAFJL2IEYRDNORVIQ7BBAS7FQNUVOFCLQNSQ
     .text          0x00015bd0       0x5e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015bd0                sym_K4XFYUFHWSS4WLYRDTKOJ7STOPYHBKAJBCXHBBY
     .text          0x00015c2e       0x56 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015c2e                sym_GT5PXDRDJCW4T55T6SLYRUGPPUJNPEQXNJCWURY
     .text          0x00015c84       0x44 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015c84                sym_CMGYAOMYUJOSH7VMLD3ENK3VLSIPR3DVYN2F44Y
     .text          0x00015cc8       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015cc8                sym_QOK2KYWK62QNZBQRPK2GPAU2IEJXSELK32IAUUA
     .text          0x00015d00       0x2a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015d00                sym_O52EM5ENIV67VZX3VQYHH655SXI2W3CR4KDMOAA
     .text          0x00015d2a       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015d2a                sym_DSAIJDVMFSSNYDQYP4G3W4ZBYTG4PAWPSVOBJ2Y
     .text          0x00015d52       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015d52                sym_YFJSESHZ5DYBYWQLQXN4IQRZ2MQYWWJOWMNYVWY
     .text          0x00015d7a       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015d7a                sym_7EDYJJSQZBDN3JDCU6ZDC5J4JCO2FTKMWSQHVRI
     .text          0x00015d96       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015d96                sym_NUBRCPOYKIORCU2AYFF2GDT5VED2Z6XGQXCSRXY
     .text          0x00015db4       0x5a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015db4                sym_QDJHQP63YIT4ARYDRM57EHNY2AYBNDIGHQIT6EY
     .text          0x00015e0e       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015e0e                sym_QMP73YXNTKQUE53UB5ZFFMF37JBBIFURPTNTHGA
     .text          0x00015e2c       0x5e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015e2c                sym_CVEXIQTWQ7GDDFOJMQT6QDDA3I4XIHTGWNWFXPA
     .text          0x00015e8a       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00015ea0       0x4e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00015eee       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015eee                sym_DGQRK6XVXAAPQDRCJOVOHOTQ47PE7QQ4MNBOW5I
     .text          0x00015f1e       0x5c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015f1e                sym_KHCOV3Y476ESNIVYZPGAZMIYAIZNR3YMGCWNDEQ
     .text          0x00015f7a       0xba /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00015f7a                sym_EMRT7PRPOJDVU5Z5ET5VJFU2CWFE2OMTIKS35RA
     .text          0x00016034        0xe /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016034                sym_SKY6LLKHYM3MTKIUASL3OKO4LAKLVGGKKAJ3I2Y
     .text          0x00016042       0x12 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016042                sym_YBOODJ7VBLXRRILCBQXIORIXU3GHRAYK6WULLQY
     .text          0x00016054        0xe /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016054                sym_NAGMMCXDNSRJLJ55T6DS4CG2FNZEN6Y562ZTFRY
     .text          0x00016062        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016062                sym_2RWLERIIOLMYS4LVQVNNIFLEQSG65A5Q5F2FPLA
     .text          0x00016068       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016068                sym_252O2EYK5FIXU63T5SACWK2VO6UFAQRM77ITNFA
     .text          0x00016086       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016086                sym_W6IKRDQNYMHGTRDGPLEMFTUCJYSU6SRYW73T4XI
     .text          0x000160a4       0x9a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000160a4                sym_33X4NJAF5ERGJDTOD7NIRDMR4KT4JWBGAGRR5WQ
     .text          0x0001613e       0xc8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001613e                sym_YFEG7XETZSEYL2RRUIGUAZZ26GZ66YZE576CSFY
     .text          0x00016206       0x3c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016206                sym_DEQ52UXGGOG3CBHCSM5ZCBFPFTNN2OZ3BBWERRI
     .text          0x00016242        0xe /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016242                sym_H3NF7V2EYDGPUFAQEJQIA2BFAJPUZD343N5IYHY
     .text          0x00016250       0x68 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016250                sym_WLQ6YP4CLBLEMT6X4SKN2P2RM7K53RQFGIL5RPY
     .text          0x000162b8       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000162b8                sym_F2YEG7LG2K4M2PP2ISXH2ZTMWJ6S3M4N73JXFJI
     .text          0x000162c8       0x32 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000162c8                sym_7LMKRMQ2L35LNXR46RI7Y3BVMVYAICJYJCWUSXA
     .text          0x000162fa       0x52 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000162fa                sym_PBUYHYNPX6UVR3SOSML43PVJV4TB32DZKPBWZSI
     .text          0x0001634c       0x4e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001639a       0x36 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001639a                sym_3IXVTMQQZGUASJJL3VMH35PYBTYROF3TY6Z7RDQ
     .text          0x000163d0       0x34 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000163d0                sym_GSWR3VMQYTBBLEEXNPYAGKUY5XX24O5ABWIFKUI
     .text          0x00016404       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016404                sym_EHH4TL4V6XWVDGG5OCXTIQQT5C4OFTGXZXSIJAA
     .text          0x0001641a       0x4e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001641a                sym_V6WVC3IEGFJGJMCL2AM6XT7PQZ2G3RNXA5M3I2A
     .text          0x00016468       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016468                sym_LDFW4OY5TOKCR2MMH4J6WIDM27FFMWUGGCVUBSQ
     .text          0x00016480       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016480                sym_NORIA4HWCV5CFHFK4OOXISIP5EQ5LDTDZB2MMQA
     .text          0x00016498       0xc2 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001655a       0x68 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001655a                sym_ZUFGUNQKQRINYDDQ2AFT3BJLR3IFVV6WJFPT3PA
     .text          0x000165c2        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000165ce        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000165ce                sym_5G7NLKZS4L5IIOBRUSBNVX2FPWE5MWDV7ZI2IXQ
     .text          0x000165d2       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001660a        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001660a                sym_BJ2HPZ6QMX3FHGHFBIX2GT3BI2SOGGBTIATKVOQ
     .text          0x00016610        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016610                sym_RH6FZQRBS4UKFN4MYJSECW7EJMU5464YS3XX4EQ
     .text          0x00016616        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016616                sym_KTCPHKPMWNHFL5F33V7S5RPUDDKGTUD3PGP5JDY
     .text          0x0001661c        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001661c                sym_L5C26ZSNQI565LEG7RLARW2YHH2JFY3FSKUZSXI
     .text          0x00016622        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016622                sym_43BYC3K4M44JBPOX4EUJM44GYCCY2C3C4SYEF6I
     .text          0x00016628       0x2e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00016656       0x2e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00016684       0x4c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000166d0        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000166d0                sym_72KBD3C5B67H6PWOG3S7CCYVGGTJG6L3WNWZOFQ
     .text          0x000166d4       0x52 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000166d4                sym_436OKKOGR27QX7FMSZKYSEYLCMU4ZXR5RN4XUBY
     .text          0x00016726       0xf4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016726                sym_IPYDOGNKVSD5CNASNRZPFKSG4XKU4ZG4SVERI7Q
     .text          0x0001681a       0x7c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001681a                sym_XRSFUVJVALTQXGE7INRI3M6HEEON3PEMDM73SDI
     .text          0x00016896       0x74 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016896                sym_PCXA5PUEL3U2IYTBOKIVTAUUKZ2VIBC2UTXQWCA
     .text          0x0001690a       0x52 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001690a                sym_RX6N47ZM7HX2HECXI5A73FQNKGPE6XKIWOJKPAQ
     .text          0x0001695c       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001695c                sym_B4SOI7ZERMZJ76YVIJFCACJN3HNVAJYEHZSLSTQ
     .text          0x00016994       0x32 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016994                sym_JTQDHDYLS5LICSCDJI5EFN6YEYME6HOA3N2FD7I
     .text          0x000169c6       0x22 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000169c6                sym_KQ7WDRFWHZIBRVZJQIHMC5NBIZUJ4NGFK5AE4FQ
     .text          0x000169e8        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000169e8                sym_KX4ODCDF63RBCM4RLVD2FMITN5XCORTH2S6ZQ5A
     .text          0x000169f0        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000169f0                sym_SXDJMN33ZTIOKKQRN453LYTHGYQUHQFKP7UVZHY
     .text          0x000169fc       0x22 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00016a1e       0x68 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00016a86       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016a86                sym_GRWJSKDQ3POPWSRNDRQTNNGA4TE3WRBKWXT5JAQ
     .text          0x00016a96       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016a96                sym_WN24RDMSAOQ4REDS6M5SAD27A5BMKW36N3VHGXI
     .text          0x00016aba       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016aba                sym_5ANWEAIBKDLEVCFMBX2VFT7WI2MWAIHK5BAGBTA
     .text          0x00016ae2       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016ae2                sym_XXAEKBISPVMBPB5XR2LC6ZMRORQRA6PX6KCWIEA
     .text          0x00016afa       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016afa                sym_KB52DURVZMKV23HAOWR2F7RBPDMWZDB7UEFUF5Y
     .text          0x00016b1a       0x22 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016b1a                sym_D2T2CRIOLYY45OMGCO4KH6B7LZXZRGO6ZS2WVVA
     .text          0x00016b3c       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016b3c                sym_LHLPURQHSJUG4HIEP67V53OFTD4W5APB2YBT5HY
     .text          0x00016b5a       0x2a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016b5a                sym_VVCM4A7VP7IJHYIXSG3772IU7C3TCBTZRLFANJI
     .text          0x00016b84       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016b84                sym_NT2IJ3T3KMFT6N2I2OJU2HPSQ63J6FQHEAYOFIA
     .text          0x00016b9a       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016b9a                sym_MWD4AC6ISIKEYDTZF7KXOTJOBUPKKWWLNRGAYAA
     .text          0x00016baa       0x44 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016baa                sym_6TSCY3EYJJ4NL2AB3FYZQO3YP65H7OZIFYTNMBQ
     .text          0x00016bee       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016bee                sym_4XA63GDF5VPGFICAPIWKAN7ECSASXPYNSFM5PJI
     .text          0x00016c04       0x36 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016c04                sym_ZKDVALXXS4QOZ3LHQJNLA3KEOQMWQRO7IBUGBCA
     .text          0x00016c3a       0xc8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016c3a                sym_EE6CWFU3HVZEIO75U57YKGOKYWQBWKA2J3FSOQQ
     .text          0x00016d02       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016d02                sym_24PTBIAZ2OKSUMWBHATZCO4EQUFF3BOLAN2QX4Y
     .text          0x00016d22       0xc6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016d22                sym_R6DW7P5722C5WP5B4RKPYMZATZ5BMBDRUM6NNYQ
     .text          0x00016de8       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016de8                sym_SRMCA4T3EHCWEHT5D2LQE6QBKZFVL4SOXAN5PZQ
     .text          0x00016dfe       0x98 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016dfe                sym_PS3VGB6FWMACQ5YG2BRPJNKIKVL2BMSXYK52FKA
     .text          0x00016e96       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016e96                sym_2TCPCDAUQ3FXZYG56Z6ZP7VCFNUJTBV3EZJYPGY
     .text          0x00016eae       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00016ec6       0x34 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016ec6                sym_DC2I7QHCXXJXKKML7TPS4RYWM6O67UYR7RLZSYY
     .text          0x00016efa       0x2c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016efa                sym_WAPBTULKYVVVKYGHLMYDIXNPJMDOYSDHUVO7CKQ
     .text          0x00016f26       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016f26                sym_SXTLUKIFRVQLBLBXFUUAUJAMDUQ22SBPD2XEEYI
     .text          0x00016f3c       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016f3c                sym_JWKB45JRB5JNYYO3MFLOTW7POAFLW4JG665TYOY
     .text          0x00016f5a       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016f5a                sym_5KQEKFOHAHY7H4YQZFOMBHKJR7UXXRMBYRHSOKA
     .text          0x00016f92       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016f92                sym_RTPW34URA5OC7HP5UM7G7G6DKV4XBRT7CDOHPRA
     .text          0x00016fb0       0x12 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016fb0                sym_5X5PLXM74Z3PECRXYVZGE5QLEWZX4H3BRJVO7TA
     .text          0x00016fc2       0x1a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016fc2                sym_32TMQSVE6U4ANJKUXLQPGXGRIVQJQAN65IQXIPY
     .text          0x00016fdc       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016fdc                sym_RNTRYUNMPUWLW2ULGAI2DOZQSMWTRXKHN4WA6OQ
     .text          0x00016ffa       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00016ffa                sym_4PKZPV6KHQLZVLIOJABWXGUL7UXOPCQSGZIQF4Q
     .text          0x00017012       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017012                sym_X3LEEXH652MSVLI2KB3L5GB7SFASJI44U5MWQ6Q
     .text          0x0001702a       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001702a                sym_ONXU7JNR4RGP7PPPUFZNTYDUB3ALHZ2YTAKW3HA
     .text          0x00017046       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017046                sym_6B7RCIBMBVR4AA4UBAXILCUYCJNNOH6DZHPKBTY
     .text          0x0001706e       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00017096       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017096                sym_OPCORHVHZVKAWEVWCDZOHGGLXMSL2TBGHVHNDOY
     .text          0x000170ac       0x2e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000170ac                sym_FW4JPGKXKHARAAJ7L3QR6HU5OB4PHXARNGBNCMY
     .text          0x000170da        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000170da                sym_NK4HRRKGX3ST3ARVTU6HUEXLOWZFFBMCIDNT3EI
     .text          0x000170e6       0x22 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000170e6                sym_M65PCSZAPVYR7V5YEMYJW264OYLXMV6F2CRGMXQ
     .text          0x00017108       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017108                sym_P2OZB7UAJZNJ47VR5DS7V33BAD5DESWDHJYKOZA
     .text          0x00017138       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017138                sym_E2LE5OMX5VGHQ6BJ4G7CNEBI3KUUYONP2PS2EJQ
     .text          0x0001714c       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001714c                sym_BR7VCSB75RGRQ7O7PYOVLMHXKJKUMK6XH3GVGZA
     .text          0x0001716c       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001716c                sym_TOLOQJPSR6AHJTVGJONFWHKIB7SNRVEHQGGLKBQ
     .text          0x0001718c       0x22 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001718c                sym_2UKPFKMGRDZ4VV635IPSP7DNWK4DJAJ7LOHQN6A
     .text          0x000171ae       0x50 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000171ae                sym_XIDO6C76MBHDNIEQMWYSJKF4P7A3PGI2HBO3R5Q
     .text          0x000171fe       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00017216       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017216                sym_FZRZ4CL3JR4VYYKFPYJ3VMCNBL7BVDZZP4POIWA
     .text          0x0001722a       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001723a       0x52 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001728c       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000172a2       0x46 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000172e8       0x42 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001732a       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001732a                sym_HUV6MMPRL3KDMQFLXMNXTNDYSK5H7OKRHLVMQTY
     .text          0x00017348       0x22 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001736a       0x12 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001736a                sym_2RDISJXERNPMBLAROCL4JWHLKVABCMPSEI3SYLQ
     .text          0x0001737c       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001737c                sym_5HK6QZWV7DBERINBBSPZEQQG5GKHWIQKMMWDRPY
     .text          0x00017394        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017394                sym_QRI4VE3TE4GSJW4NKF3FFIQKNBULXGQOQOJESDY
     .text          0x0001739c       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001739c                sym_UXRNNIFU5PXIYRINROHWBAFH5AGNGDMLJAXKACY
     .text          0x000173bc       0x50 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000173bc                sym_T7A3EXF7COQYY26GAAJPICZ426P6RGZH73WYDII
     .text          0x0001740c       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001740c                sym_CRKG4ZYPYRSQ4G5LBLJGXHHQ6INUHX54ZTHJRVI
     .text          0x00017428       0x40 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017428                sym_SNFHQYHRDTKKUOQXA5QDBF3DIEI2HFW6TWATFAA
     .text          0x00017468       0x36 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017468                sym_A3ADY4J2FQCM6IVTTK5E6RCDPADI2QXOETLS64I
     .text          0x0001749e       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001749e                sym_777IRO5NNDPACNP4N53FBQNUHCW7DFN4EQMNG2Q
     .text          0x000174ba       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000174ba                sym_67JXCW5HX6M5UYUVDKKNNAF4KBATNIGJCXW77CI
     .text          0x000174d6       0x20 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000174f6       0x1a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00017510       0x46 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00017556       0x44 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001759a        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001759a                sym_MHDCHYAEWBCIUYGOTWRWGZEJ6XEBEBUHOO5T6WY
     .text          0x000175a0       0x36 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000175a0                sym_7Q3OGK46EJ4CJTNREFMB4I3YQOYV4MCCW6KC7XI
     .text          0x000175d6       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000175d6                sym_3ZNIOFG7XMX7YS4WHN4QVNG3AVWN2QVSTHUWDXQ
     .text          0x000175fa       0x3e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000175fa                sym_XVWN3IZ65SG2YZAV5STIEBPJ2RGWTP2JZ3UEJLQ
     .text          0x00017638      0x102 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017638                sym_FY3JF6XBXLAG22E42UPFUU55A3QFAFZDUGSPAPY
     .text          0x0001773a        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001773a                sym_VKORYLCFNIWNGETWJR24ZOUACQP66MFSZSXVABY
     .text          0x00017746       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001775c       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00017774       0x50 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000177c4       0x4a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001780e       0x56 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00017864       0xbc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00017920       0x44 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00017964        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001796a        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001796e       0x2c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001796e                sym_OAGVEJLAHKQB2YTTUDIS6TDHXZIVWZXKUMPIBHQ
     .text          0x0001799a       0x76 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001799a                sym_YA57TPZ3CLQ6C73TD2RIGTELUAMYOOAKHU5T7RQ
     .text          0x00017a10        0xa /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017a10                sym_2ORNMU44KG57RJ5GYPW4FCTEFWDXBHWXYAE3J6I
     .text          0x00017a1a        0xa /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017a1a                sym_WGJLFS2PDN6RZG7JWUITZ3W5MGJYYXFXIKI3GGQ
     .text          0x00017a24       0x4c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017a24                sym_3NMQXTBVJ27TN5IIVET3BSKEAUONNKTPZTYP2HY
     .text          0x00017a70        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017a70                sym_RYQA5YFFRJZLTYB2ISC2Y3WUY3XB3LBBL37F22Q
     .text          0x00017a76        0xa /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017a76                sym_H6NC6L6VJY74V6C72Y6E5P4HGSZIVJQXMUOQZ5Y
     .text          0x00017a80      0x1e8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017a80                sym_L2IWXNCKXJIQJRTEIIW7HGFEPJAQM34TKD2GOIA
     .text          0x00017c68       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017c68                sym_DG6VHZEFRVR44ESTRZM42ZEBJG4KXT7IVJESA4Y
     .text          0x00017c7c        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017c7c                sym_L5UCRJFFWEVVII5IYG6PAKIQHXM34B62KO6ERPY
     .text          0x00017c82        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017c82                sym_UEZ3FVWFJ5XVLQBVVAHW7UTXVCC77F7ZYGOMLTQ
     .text          0x00017c8a        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017c8a                sym_NGJGZTNK6YIH3QX2NKB6A6MT7N5AOKWA6ZOOANQ
     .text          0x00017c92        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017c92                sym_XRU76NANM3C4EMKWQU3DF6CELSRNDV6766IKPJI
     .text          0x00017c9a       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017c9a                sym_WE45Z7LOSJEAVMD3HUIMZMMRDD5BLMKOFVBGE4Y
     .text          0x00017cb8       0x1a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017cb8                sym_4HDCBJCT2JOHNORERPDEH2A3V47FOX6NCTAKLUA
     .text          0x00017cd2       0x12 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017cd2                sym_2ATBZOC3GIGKGFK4DATZCXIAUN2OHFM74LMHKDQ
     .text          0x00017ce4       0x1a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00017cfe       0x1c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017cfe                sym_4FKJZF4AXR7RHM7IPPZMVUWU7W6MFHLX726TPNY
     .text          0x00017d1a        0x2 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017d1a                sym_ID5SI2L6AD3KMSDR72YSJZGVIA6DEYQZU7WJI3I
     .text          0x00017d1c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017d1c                sym_2K3JTQJLCTROZQI43ERT7GF5BTQ3SMAJXYMCVJI
     .text          0x00017d20        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017d20                sym_WAXMY55QAGCTLTIDQV34FPT2PPSDRT5VDN7EYYY
     .text          0x00017d26       0x34 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00017d5a       0x12 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00017d6c       0x22 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00017d8e        0xe /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017d8e                sym_32MURW7CSXICOYPMCVOPRARLMRLK4UASNCF4JWQ
     .text          0x00017d9c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017d9c                sym_YZ554N3225FHWC7CK3UNRUMI3O4SGFLKXVRCFXA
     .text          0x00017da0       0x24 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017da0                sym_XD3FX5TVO57NBJG4QV33FUOBCL7SNGB4OOT7C3Y
     .text          0x00017dc4        0xa /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017dc4                sym_UEYPZKGY2IF5BYZ3QDKK4LEW4OE7NWR6DH5XEZQ
     .text          0x00017dce       0x3e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017dce                sym_GDGGQ5EKEJNZBTEWASFQ2LUSL4TZGNXHPD7BDQA
     .text          0x00017e0c       0x2e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017e0c                sym_4U2RA2RXIRU5BEMWZTHT3PETZK6K62P2SAJVWHA
     .text          0x00017e3a       0x1a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017e3a                sym_STP6UONGXHZIIGYZLLHSWZFO5DU7227CCUKBTDQ
     .text          0x00017e54        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017e54                sym_USXJ3USYRHE5AVFUSG2J2G7QDHRASPG75ESP25A
     .text          0x00017e5a        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00017e5a                sym_FHGEXLJ7V34P3MECCDTYSDEZTZHFJ2TXYSFZQHQ
     .text          0x00017e62       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00017e7a       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00017eaa       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00017ed2       0x44 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00017f16       0x4c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00017f62       0x8e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00017ff0       0x4c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001803c       0x1a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00018056       0x56 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00018056                sym_PDDLBAI7RAK2OQ7ZHFU33L5KMJV5YKPLX5ITXAY
     .text          0x000180ac       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000180ac                sym_IYZQNCOB4T4XO27DREWRIWJFVHVS355NEDBEGEQ
     .text          0x000180c2       0x5e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000180c2                sym_TLMTJNRYMIPTFJ2BLGCEHSZKVDBLFBSNMQEHHZI
     .text          0x00018120        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00018120                sym_B2B7AU2WDMX5JQNGTX4YKNCWQCXQIG5PWSSOSAI
     .text          0x00018124       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00018142        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00018142                sym_C2OROK7MMAFVDZS534TELVVJ2FCCBKQAERGDZHY
     .text          0x00018146        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00018146                sym_YE7I37LHQCQAD4BK6Z7IM36Q2F6U6N5UTM73DOY
     .text          0x0001814c       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001814c                sym_5ZBAGF5IPZJLTC3H62ZY4U4SW6MV7I4QJW2DD3I
     .text          0x00018174       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001818c       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000181a2       0x26 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000181c8       0x76 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001823e       0x38 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00018276       0x1a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00018290       0x68 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00018290                sym_3AP322LX5PIMI4GVZ7JO5VXSHDSDLPGKXAH2IAI
     .text          0x000182f8        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000182f8                sym_VJEPN3SDR5AQAFQ3NEQBRQ5LOSN3JDHOXS2M77A
     .text          0x000182fc        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000182fc                sym_JMIQO3ILZD7SKROBEXXUMUGX2B5S6MSFF2CM3XY
     .text          0x00018300        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00018300                sym_MEJ7N2FHYOI6WKBF6QPZGKUNC3JXLY6XDOIDFTY
     .text          0x00018304       0x68 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00018304                sym_XMSQSHOMUQJNNSSEXDAX4NHMQIFY5G5ZMQIBDRA
     .text          0x0001836c       0x28 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001836c                sym_FSAGK3KYGJZ6TL4N5JD4AOYKDU36GANHEO5GRTI
     .text          0x00018394       0x12 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00018394                sym_AGYGMJJLNZ3OUAGF7EU6BV4ZDBZCTDBRZLY27WA
     .text          0x000183a6       0x12 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000183a6                sym_KEGGHGQL6JDMBU54KJKZYI4X76QJRM6TXCH5TWI
     .text          0x000183b8       0x14 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000183b8                sym_W72IACT6Q3O76EZNEGUPZYMMFAA4GPIIEYHXXRA
     .text          0x000183cc        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000183cc                sym_7Y2HO5GM4MVVG4OU7B3KBEZXWIJCASFZW6ESP2Q
     .text          0x000183d2       0x32 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000183d2                sym_SVRJQWU24HVOGL26B7MZ34B4ZPEMRU67W2UHR5I
     .text          0x00018404       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00018404                sym_XHY7XXYFPU2X64DQE7W27FXXH3M76RIOVQ6TXJA
     .text          0x00018422        0x6 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00018422                sym_42PCSL2CD4EYUN5ADMVOT7HPG5FFTNFLCDQJ4HA
     .text          0x00018428       0x4a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00018472       0x9c /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00018472                sym_VMQCVHWKTNF2VV3DKW4SLPNHUNMHZ6ZJ2G2VNEI
     .text          0x0001850e       0x36 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001850e                sym_IFP6AMASJAFADAND3PHQHNAFENJITJLJ2XZ5MLI
     .text          0x00018544       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00018544                sym_6ALNLLJJU4L4GWYU66RPC2NU3OVUILUN2AUAXMY
     .text          0x00018562       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00018562                sym_Z7BGFJPBYKFED4E4DADURNKT77RHEXHXGENFGQI
     .text          0x00018578       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00018578                sym_BIDMG7YHRFQNLIKRFVSOGOT6IXZCQ6UEJKN52VI
     .text          0x0001858e        0x2 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x00018590        0xa /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001859a       0x32 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000185cc        0x2 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000185cc                sym_K3UBYIUX4UPUV5D6BCLUFWYJHYHHDMYARQX7B7I
     .text          0x000185ce        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000185ce                sym_EMX6CZDL6TQRN6QPJ6FLYMHODYZ6G5VRVDEB2TQ
     .text          0x000185d6       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000185d6                sym_O4OOPNKE6TEWL2FAKI7OWK3RDXWQ5Z4L5GTAENI
     .text          0x000185ec        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000185ec                sym_OT6G2EKW5NJAW6LVBOXBMR6W22P7GKFIYBASB2A
     .text          0x000185f4       0x16 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000185f4                sym_ALNNBM7ZYFAFG34UVHA727YIPT7HGPCG5WA3DPA
     .text          0x0001860a        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001860e       0x1e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001862c       0x30 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x0001865c       0x2a /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x0001865c                sym_WHYRUHJDLU2UOVNFSBGTEFIKGNDZOGORL7TQGHY
     .text          0x00018686       0x2e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00018686                sym_CGE7K4F5QCIQU2RNOXCK7SNOPN6B4LLS4X4N6MA
     .text          0x000186b4       0x26 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x000186b4                sym_3MO5GSIQT6O4H7UOZZVYKDTH2ENYSIKRGZ72UFY
     .text          0x000186da        0xe /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
                    0x000186da                mpsl_fem_init
     .text          0x000186e8       0x20 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
                    0x000186e8                sym_PX4SKXGNX25XLMGGWQM65ZRFHI6666YGHL6AYMA
     .text          0x00018708        0x6 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x0001870e        0x2 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00018710        0x4 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00018714        0x6 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x0001871a        0x6 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00018720        0x2 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00018722        0x6 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00018728        0x4 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x0001872c        0x4 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00018730        0x6 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00018736        0xa /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00018740        0x6 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00018746        0x4 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x0001874a        0x6 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00018750        0x6 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00018756        0x2 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .text          0x00018758       0x18 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00018758                sym_4SCKUN7IRBDDM3D2RCMMHPR6OHBR3PQTBKCR77I
     .text          0x00018770        0x6 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00018770                sym_LIY23QT3GHIV7NCGJ6ZW6LB2ZUSI56CIFCL6HUY
     .text          0x00018776        0xe /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00018776                sym_TIWHB6UQGI33JQCQDL7C2BRAEXCRAFYENVN6QEI
     .text          0x00018784        0xe /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00018784                sym_AL7FCNVVCF72BNYCTLA5UGAWCQFXFPGE2ULTWOA
     .text          0x00018792        0xe /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00018792                sym_7BUNPUBNWNFVXXIMNFFNK765OVON5LBIUZ66QRI
     .text          0x000187a0       0x20 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000187a0                sym_LZEJCP3HZIBKMJQC47UQXAHGCQ52QF47EXOH2WA
     .text          0x000187c0        0x6 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000187c0                sym_ZA5SDIYL3AVNDD7AHK7E7AUJI3LEYUOUHLD4V7A
     .text          0x000187c6        0x6 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000187c6                sym_BRWWBUSI76W7RNK4752SPUHXUPDEXM36TXJBBPY
     .text          0x000187cc        0x6 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000187cc                sym_BBMUHPEY4VNB2DKVTP3ESXPAA5CZWI754JPOB6Y
     .text          0x000187d2       0x22 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000187d2                sym_47MBMNER75N2M6YIZRIF4DAHSAATJOMK3LAIDCY
     .text          0x000187f4        0x4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000187f4                mpsl_memcpy
     .text          0x000187f8       0x50 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x000187f8                sym_V5ILJEYQUHITD7K5U5BVWARUBFYNVMXXWVRAE5Q
     .text          0x00018848       0x12 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00018848                sym_NSXBBLQXKUW7767I5GHALYQHXM25IDHCQ7ON6AQ
     .text          0x0001885a        0x8 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x0001885a                sym_YS3AHD7GWBHZEQHPIQANPGALEXB4QGY5O2DQKRY
     .text          0x00018862       0x1e /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00018862                sym_AR22FPVUFSZMVYMQBBXG7EEZNA2HPS2RLAKRPBA
     .text          0x00018880       0x12 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00018880                sym_OWJYSTADR5I36MIHWNPICVB7CMCWNSFIZPFXQ2Q
     .text          0x00018892        0x4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00018892                mpsl_low_priority_process
     .text          0x00018896        0x4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x00018896                sym_PAD7XREQQORPXRJMXMW2EYVS4S43S42A5D43SBA
     .text          0x0001889a        0x4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x0001889a                sym_PHK7RXLFFTGYQNCW3IEEUVLOAYXWQJQYEN3DT7Y
     .text          0x0001889e        0xc /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x000188aa        0x4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x000188ae        0x8 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x000188b6        0x4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x000188ba        0x4 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .text          0x000188be       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000188ce       0xff /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .text          0x000189cd       0xff /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     *(SORT_BY_ALIGNMENT(.text.*))
     .text.dtm_tw_transport_init
                    0x00018acc       0x44 app/libapp.a(dtm_twowire_transport.c.obj)
                    0x00018acc                dtm_tw_transport_init
     .text.dtm_tw_transport_read
                    0x00018b10       0xa8 app/libapp.a(dtm_twowire_transport.c.obj)
                    0x00018b10                dtm_tw_transport_read
     .text.dtm_tw_transport_write
                    0x00018bb8       0x20 app/libapp.a(dtm_twowire_transport.c.obj)
                    0x00018bb8                dtm_tw_transport_write
     .text.main     0x00018bd8       0xf8 app/libapp.a(main.c.obj)
                    0x00018bd8                main
     .text.sys_heap_init
                    0x00018cd0      0x124 zephyr/libzephyr.a(heap.c.obj)
                    0x00018cd0                sys_heap_init
     .text.char_out
                    0x00018df4        0xc zephyr/libzephyr.a(printk.c.obj)
     .text.vprintk  0x00018e00       0x30 zephyr/libzephyr.a(printk.c.obj)
                    0x00018e00                vprintk
     .text.z_thread_entry
                    0x00018e30       0x6c zephyr/libzephyr.a(thread_entry.c.obj)
                    0x00018e30                z_thread_entry
     .text.process_event
                    0x00018e9c      0x39c zephyr/libzephyr.a(onoff.c.obj)
     .text.transition_complete
                    0x00019238       0x64 zephyr/libzephyr.a(onoff.c.obj)
     .text.onoff_request
                    0x0001929c      0x12c zephyr/libzephyr.a(onoff.c.obj)
                    0x0001929c                onoff_request
     .text.sys_notify_finalize
                    0x000193c8       0x40 zephyr/libzephyr.a(notify.c.obj)
                    0x000193c8                sys_notify_finalize
     .text.mem_attr_get_regions
                    0x00019408        0xc zephyr/libzephyr.a(mem_attr.c.obj)
                    0x00019408                mem_attr_get_regions
     .text.ncs_boot_banner
                    0x00019414       0x1c zephyr/libzephyr.a(banner.c.obj)
     .text.arch_bss_zero
                    0x00019430       0x18 zephyr/arch/common/libarch__common.a(init.c.obj)
                    0x00019430                arch_bss_zero
     .text.arch_data_copy
                    0x00019448       0x38 zephyr/arch/common/libarch__common.a(xip.c.obj)
                    0x00019448                arch_data_copy
     .text.z_arm_fatal_error
                    0x00019480       0x60 zephyr/arch/arch/arm/core/libarch__arm__core.a(fatal.c.obj)
                    0x00019480                z_arm_fatal_error
     .text.z_SysNmiOnReset
                    0x000194e0        0x8 zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi_on_reset.S.obj)
                    0x000194e0                z_SysNmiOnReset
     .text.arch_tls_stack_setup
                    0x000194e8       0x40 zephyr/arch/arch/arm/core/libarch__arm__core.a(tls.c.obj)
                    0x000194e8                arch_tls_stack_setup
     .text.mem_manage_fault
                    0x00019528      0x124 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .text.usage_fault.isra.0
                    0x0001964c       0x98 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .text.bus_fault.isra.0
                    0x000196e4       0xb8 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .text.z_arm_fault
                    0x0001979c      0x210 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
                    0x0001979c                z_arm_fault
     .text.z_arm_fault_init
                    0x000199ac       0x18 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
                    0x000199ac                z_arm_fault_init
     .text.__fault  0x000199c4       0x14 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault_s.S.obj)
                    0x000199c4                z_arm_exc_spurious
                    0x000199c4                z_arm_usage_fault
                    0x000199c4                z_arm_mpu_fault
                    0x000199c4                z_arm_debug_monitor
                    0x000199c4                z_arm_hard_fault
                    0x000199c4                z_arm_bus_fault
     .text._reset_section
                    0x000199d8       0x54 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(reset.S.obj)
                    0x000199d8                __start
                    0x000199d8                z_arm_reset
     .text.z_arm_clear_arm_mpu_config
                    0x00019a2c       0x24 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
                    0x00019a2c                z_arm_clear_arm_mpu_config
     .text.z_arm_init_arch_hw_at_boot
                    0x00019a50       0x64 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
                    0x00019a50                z_arm_init_arch_hw_at_boot
     .text.z_arm_svc
                    0x00019ab4       0x24 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(svc.S.obj)
                    0x00019ab4                z_arm_svc
     .text.arm_irq_enable
                    0x00019ad8       0x1c zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
                    0x00019ad8                arm_irq_enable
     .text.arm_irq_disable
                    0x00019af4       0x28 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
                    0x00019af4                arm_irq_disable
     .text.arm_irq_is_enabled
                    0x00019b1c       0x1c zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
                    0x00019b1c                arm_irq_is_enabled
     .text.arm_irq_priority_set
                    0x00019b38       0x6c zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
                    0x00019b38                arm_irq_priority_set
     .text.relocate_vector_table
                    0x00019ba4       0x1c zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(prep_c.c.obj)
                    0x00019ba4                relocate_vector_table
     .text.z_prep_c
                    0x00019bc0       0x28 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(prep_c.c.obj)
                    0x00019bc0                z_prep_c
     .text.arch_new_thread
                    0x00019be8       0x38 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
                    0x00019be8                arch_new_thread
     .text.z_check_thread_stack_fail
                    0x00019c20       0x2c zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
                    0x00019c20                z_check_thread_stack_fail
     .text.arch_switch_to_main_thread
                    0x00019c4c       0x3c zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
                    0x00019c4c                arch_switch_to_main_thread
     .text.z_arm_cpu_idle_init
                    0x00019c88        0xc zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(cpu_idle.c.obj)
                    0x00019c88                z_arm_cpu_idle_init
     .text._HandlerModeExit
                    0x00019c94       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(exc_exit.c.obj)
                    0x00019c94                z_arm_int_exit
                    0x00019c94                z_arm_exc_exit
     .text.z_impl_k_thread_abort
                    0x00019cb4       0x2c zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread_abort.c.obj)
                    0x00019cb4                z_impl_k_thread_abort
     .text.z_arm_pendsv
                    0x00019ce0       0x60 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(swap_helper.S.obj)
                    0x00019ce0                z_arm_pendsv
     .text.z_arm_interrupt_init
                    0x00019d40       0x18 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_init.c.obj)
                    0x00019d40                z_arm_interrupt_init
     .text._isr_wrapper
                    0x00019d58       0x24 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(isr_wrapper.c.obj)
                    0x00019d58                _isr_wrapper
     .text.__aeabi_read_tp
                    0x00019d7c        0xc zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(__aeabi_read_tp.S.obj)
                    0x00019d7c                __aeabi_read_tp
     .text.z_arm_configure_static_mpu_regions
                    0x00019d88       0x18 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_core_mpu.c.obj)
                    0x00019d88                z_arm_configure_static_mpu_regions
     .text.z_arm_configure_dynamic_mpu_regions
                    0x00019da0       0x20 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_core_mpu.c.obj)
                    0x00019da0                z_arm_configure_dynamic_mpu_regions
     .text.region_init
                    0x00019dc0       0x28 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .text.mpu_configure_regions
                    0x00019de8       0x6c zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .text.arm_core_mpu_enable
                    0x00019e54       0x18 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
                    0x00019e54                arm_core_mpu_enable
     .text.arm_core_mpu_disable
                    0x00019e6c       0x14 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
                    0x00019e6c                arm_core_mpu_disable
     .text.arm_core_mpu_configure_static_mpu_regions
                    0x00019e80       0x4c zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
                    0x00019e80                arm_core_mpu_configure_static_mpu_regions
     .text.arm_core_mpu_configure_dynamic_mpu_regions
                    0x00019ecc       0x6c zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
                    0x00019ecc                arm_core_mpu_configure_dynamic_mpu_regions
     .text.z_arm_mpu_init
                    0x00019f38      0x23c zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
                    0x00019f38                z_arm_mpu_init
     .text.malloc_prepare
                    0x0001a174       0x24 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .text.net_buf_destroy
                    0x0001a198       0x38 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.net_buf_pool_get
                    0x0001a1d0       0x10 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
                    0x0001a1d0                net_buf_pool_get
     .text.net_buf_id
                    0x0001a1e0       0x20 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
                    0x0001a1e0                net_buf_id
     .text.fixed_data_alloc
                    0x0001a200       0x24 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.net_buf_reset
                    0x0001a224       0x30 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
                    0x0001a224                net_buf_reset
     .text.net_buf_alloc_len
                    0x0001a254      0x1b8 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
                    0x0001a254                net_buf_alloc_len
     .text.net_buf_unref
                    0x0001a40c       0x84 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
                    0x0001a40c                net_buf_unref
     .text.net_buf_simple_add
                    0x0001a490       0x40 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
                    0x0001a490                net_buf_simple_add
     .text.net_buf_simple_pull
                    0x0001a4d0       0x3c zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
                    0x0001a4d0                net_buf_simple_pull
     .text.nordicsemi_nrf52_init
                    0x0001a50c       0x18 zephyr/soc/soc/nrf52833/libsoc__nordic.a(soc.c.obj)
     .text.arch_busy_wait
                    0x0001a524       0x24 zephyr/soc/soc/nrf52833/libsoc__nordic.a(soc.c.obj)
                    0x0001a524                arch_busy_wait
     .text.sys_arch_reboot
                    0x0001a548       0x24 zephyr/soc/soc/nrf52833/libsoc__nordic.a(reboot.c.obj)
                    0x0001a548                sys_arch_reboot
     .text.gppi_init
                    0x0001a56c       0x20 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gppi_init.c.obj)
     .text.hci_rx_buf_destroy
                    0x0001a58c       0x40 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .text.bt_hci_recv
                    0x0001a5cc       0x14 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
                    0x0001a5cc                bt_hci_recv
     .text.bt_buf_type_to_h4
                    0x0001a5e0       0x50 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .text.bt_buf_get_rx
                    0x0001a630       0x40 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
                    0x0001a630                bt_buf_get_rx
     .text.bt_buf_rx_freed_cb_set
                    0x0001a670        0xc zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
                    0x0001a670                bt_buf_rx_freed_cb_set
     .text.bt_buf_get_tx
                    0x0001a67c       0x6c zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
                    0x0001a67c                bt_buf_get_tx
     .text.bt_send  0x0001a6e8       0x18 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
                    0x0001a6e8                bt_send
     .text.bt_enable_raw
                    0x0001a700       0x30 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
                    0x0001a700                bt_enable_raw
     .text.onoff_start
                    0x0001a730       0x3c zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.get_status
                    0x0001a76c       0x38 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.stop     0x0001a7a4       0x78 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.onoff_stop
                    0x0001a81c       0x28 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.clk_init
                    0x0001a844       0x58 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.api_blocking_start
                    0x0001a89c       0x30 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.generic_hfclk_stop
                    0x0001a8cc       0x34 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.clkstarted_handle.constprop.0
                    0x0001a900       0x4c zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.clock_event_handler
                    0x0001a94c       0x5c zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.generic_hfclk_start
                    0x0001a9a8       0x78 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.z_nrf_clock_control_lf_on
                    0x0001aa20      0x13c zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
                    0x0001aa20                z_nrf_clock_control_lf_on
     .text.random_byte_get
                    0x0001ab5c       0x3c zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .text.rng_pool_get
                    0x0001ab98       0x84 zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .text.entropy_nrf5_get_entropy_isr
                    0x0001ac1c       0xdc zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
                    0x0001acf8       0x7c zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .text.entropy_nrf5_init
                    0x0001ad74       0x98 zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .text.isr      0x0001ae0c       0x74 zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .text.gpio_nrfx_manage_callback
                    0x0001ae80       0xa4 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .text.nrf_gpio_pin_port_decode
                    0x0001af24       0x58 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .text.gpio_nrfx_pin_interrupt_configure
                    0x0001af7c      0x110 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .text.gpio_nrfx_pin_configure
                    0x0001b08c      0x190 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .text.nrfx_gpio_handler
                    0x0001b21c       0x78 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .text.gpio_nrfx_init
                    0x0001b294       0x3c zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
                    0x0001b2d0       0x58 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(pinctrl_nrf.c.obj)
     .text.pinctrl_configure_pins
                    0x0001b328       0xe4 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(pinctrl_nrf.c.obj)
                    0x0001b328                pinctrl_configure_pins
     .text.uarte_nrfx_configure
                    0x0001b40c      0x170 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .text.uarte_nrfx_poll_out
                    0x0001b57c       0xb8 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .text.sys_clock_timeout_handler
                    0x0001b634       0x54 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .text.z_nrf_rtc_timer_read
                    0x0001b688       0x44 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
                    0x0001b688                z_nrf_rtc_timer_read
     .text.rtc_nrf_isr
                    0x0001b6cc       0xc4 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
                    0x0001b6cc                rtc_nrf_isr
     .text.compare_set.constprop.0.isra.0
                    0x0001b790      0x154 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .text.sys_clock_driver_init
                    0x0001b8e4       0x80 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .text.sys_clock_set_timeout
                    0x0001b964       0x4c zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
                    0x0001b964                sys_clock_set_timeout
     .text.sys_clock_elapsed
                    0x0001b9b0       0x14 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
                    0x0001b9b0                sys_clock_elapsed
     .text.multithreading_lock_acquire
                    0x0001b9c4       0x10 modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a(multithreading_lock.c.obj)
                    0x0001b9c4                multithreading_lock_acquire
     .text.multithreading_lock_release
                    0x0001b9d4        0xc modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a(multithreading_lock.c.obj)
                    0x0001b9d4                multithreading_lock_release
     .text.dtm_tw_to_hci_init
                    0x0001b9e0       0x14 modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
     .text.dtm_tw_to_hci_process_tw_cmd
                    0x0001b9f4      0x1e8 modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
                    0x0001b9f4                dtm_tw_to_hci_process_tw_cmd
     .text.dtm_tw_to_hci_process_hci_event
                    0x0001bbdc      0x234 modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
                    0x0001bbdc                dtm_tw_to_hci_process_hci_event
     .text.sdc_assertion_handler
                    0x0001be10       0x4c modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
                    0x0001be10                sdc_assertion_handler
     .text.hci_driver_open
                    0x0001be5c       0xc0 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .text.rand_prio_low_vector_get_blocking
                    0x0001bf1c       0x6c modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .text.hci_driver_init
                    0x0001bf88      0x158 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .text.receive_signal_raise
                    0x0001c0e0       0x44 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .text.hci_driver_receive_process
                    0x0001c124       0xe8 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
                    0x0001c124                hci_driver_receive_process
                    0x0001c20c       0x2c modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .text.hci_internal_cmd_put
                    0x0001c238      0x830 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
                    0x0001c238                hci_internal_cmd_put
     .text.hci_internal_msg_get
                    0x0001ca68       0x2c modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
                    0x0001ca68                hci_internal_msg_get
     .text.m_assert_handler
                    0x0001ca94       0x4c modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .text.mpsl_lib_init_sys
                    0x0001cae0       0x58 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .text.mpsl_low_prio_work_handler
                    0x0001cb38       0x3c modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .text.mpsl_low_prio_irq_handler
                    0x0001cb74       0x44 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .text.mpsl_low_prio_init
                    0x0001cbb8       0x4c modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .text.mpsl_hfclk_src_callback
                    0x0001cc04       0x10 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
     .text.nrfx_clock_start
                    0x0001cc14       0x54 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
                    0x0001cc14                nrfx_clock_start
     .text.nrfx_clock_stop
                    0x0001cc68       0x40 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
                    0x0001cc68                nrfx_clock_stop
     .text.nrfx_clock_init
                    0x0001cca8        0xc modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
                    0x0001cca8                nrfx_clock_init
     .text.nvmc_wait
                    0x0001ccb4       0x10 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(system_nrf52833.c.obj)
                    0x0001ccb4                nvmc_wait
     .text.SystemInit
                    0x0001ccc4      0x14c modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(system_nrf52833.c.obj)
                    0x0001ccc4                SystemInit
     .text.nrfx_gppi_init
                    0x0001ce10        0xc modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
                    0x0001ce10                nrfx_gppi_init
     .text.nrfx_gppi_domain_conn_alloc
                    0x0001ce1c       0x3c modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
                    0x0001ce1c                nrfx_gppi_domain_conn_alloc
     .text.nrfx_gppi_conn_enable
                    0x0001ce58       0x10 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
                    0x0001ce58                nrfx_gppi_conn_enable
     .text.get_pin_idx
                    0x0001ce68       0x14 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.release_handler
                    0x0001ce7c       0x74 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
                    0x0001cef0       0x68 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.nrf_gpiote_in_event_get
                    0x0001cf58       0x34 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.latch_pending_read_and_check
                    0x0001cf8c       0x60 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.pin_uninit
                    0x0001cfec       0x78 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.nrfx_gpiote_input_configure
                    0x0001d064      0x184 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
                    0x0001d064                nrfx_gpiote_input_configure
     .text.nrfx_gpiote_output_configure
                    0x0001d1e8      0x10c modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
                    0x0001d1e8                nrfx_gpiote_output_configure
     .text.nrfx_gpiote_global_callback_set
                    0x0001d2f4       0x30 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
                    0x0001d2f4                nrfx_gpiote_global_callback_set
     .text.nrfx_gpiote_channel_get
                    0x0001d324       0x68 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
                    0x0001d324                nrfx_gpiote_channel_get
     .text.nrfx_gpiote_init
                    0x0001d38c       0x6c modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
                    0x0001d38c                nrfx_gpiote_init
     .text.nrfx_gpiote_init_check
                    0x0001d3f8       0x34 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
                    0x0001d3f8                nrfx_gpiote_init_check
     .text.nrfx_gpiote_pin_uninit
                    0x0001d42c       0x30 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
                    0x0001d42c                nrfx_gpiote_pin_uninit
     .text.nrfx_gpiote_channel_free
                    0x0001d45c       0x38 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
                    0x0001d45c                nrfx_gpiote_channel_free
     .text.nrfx_gpiote_channel_alloc
                    0x0001d494       0x40 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
                    0x0001d494                nrfx_gpiote_channel_alloc
     .text.nrfx_gpiote_trigger_enable
                    0x0001d4d4      0x104 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
                    0x0001d4d4                nrfx_gpiote_trigger_enable
     .text.nrfx_gpiote_trigger_disable
                    0x0001d5d8       0x30 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
                    0x0001d5d8                nrfx_gpiote_trigger_disable
     .text.nrfx_gpiote_irq_handler
                    0x0001d608      0x1f8 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
                    0x0001d608                nrfx_gpiote_irq_handler
     .text.do_device_init
                    0x0001d800       0x60 zephyr/kernel/libkernel.a(device.c.obj)
                    0x0001d800                do_device_init
     .text.z_fatal_error
                    0x0001d860       0x60 zephyr/kernel/libkernel.a(fatal.c.obj)
                    0x0001d860                z_fatal_error
     .text.z_sys_init_run_level
                    0x0001d8c0       0x30 zephyr/kernel/libkernel.a(init.c.obj)
     .text.bg_thread_main
                    0x0001d8f0      0x104 zephyr/kernel/libkernel.a(init.c.obj)
     .text.z_init_cpu
                    0x0001d9f4       0x70 zephyr/kernel/libkernel.a(init.c.obj)
                    0x0001d9f4                z_init_cpu
     .text.z_cstart
                    0x0001da64      0x110 zephyr/kernel/libkernel.a(init.c.obj)
                    0x0001da64                z_cstart
     .text.statics_init
                    0x0001db74       0x50 zephyr/kernel/libkernel.a(kheap.c.obj)
     .text.k_heap_free
                    0x0001dbc4       0xa8 zephyr/kernel/libkernel.a(kheap.c.obj)
                    0x0001dbc4                k_heap_free
     .text.idle     0x0001dc6c       0x48 zephyr/kernel/libkernel.a(idle.c.obj)
                    0x0001dc6c                idle
     .text.z_impl_k_mutex_lock
                    0x0001dcb4      0x190 zephyr/kernel/libkernel.a(mutex.c.obj)
                    0x0001dcb4                z_impl_k_mutex_lock
     .text.z_impl_k_mutex_unlock
                    0x0001de44      0x1a0 zephyr/kernel/libkernel.a(mutex.c.obj)
                    0x0001de44                z_impl_k_mutex_unlock
     .text.unpend_thread_no_timeout
                    0x0001dfe4       0x40 zephyr/kernel/libkernel.a(queue.c.obj)
     .text.queue_insert
                    0x0001e024      0x17c zephyr/kernel/libkernel.a(queue.c.obj)
     .text.z_impl_k_queue_get
                    0x0001e1a0       0xd4 zephyr/kernel/libkernel.a(queue.c.obj)
                    0x0001e1a0                z_impl_k_queue_get
                    0x0001e274       0x40 zephyr/kernel/libkernel.a(sem.c.obj)
     .text.z_impl_k_sem_give
                    0x0001e2b4       0xf8 zephyr/kernel/libkernel.a(sem.c.obj)
                    0x0001e2b4                z_impl_k_sem_give
     .text.z_impl_k_sem_take
                    0x0001e3ac       0xf4 zephyr/kernel/libkernel.a(sem.c.obj)
                    0x0001e3ac                z_impl_k_sem_take
     .text.work_queue_main
                    0x0001e4a0      0x214 zephyr/kernel/libkernel.a(work.c.obj)
     .text.submit_to_queue_locked
                    0x0001e6b4       0xcc zephyr/kernel/libkernel.a(work.c.obj)
     .text.k_work_init
                    0x0001e780       0x4c zephyr/kernel/libkernel.a(work.c.obj)
                    0x0001e780                k_work_init
     .text.z_work_submit_to_queue
                    0x0001e7cc       0xd4 zephyr/kernel/libkernel.a(work.c.obj)
                    0x0001e7cc                z_work_submit_to_queue
     .text.k_work_queue_start
                    0x0001e8a0       0xe0 zephyr/kernel/libkernel.a(work.c.obj)
                    0x0001e8a0                k_work_queue_start
     .text.z_setup_new_thread
                    0x0001e980       0xe4 zephyr/kernel/libkernel.a(thread.c.obj)
                    0x0001e980                z_setup_new_thread
     .text.z_impl_k_thread_create
                    0x0001ea64       0x8c zephyr/kernel/libkernel.a(thread.c.obj)
                    0x0001ea64                z_impl_k_thread_create
     .text.z_dummy_thread_init
                    0x0001eaf0       0x18 zephyr/kernel/libkernel.a(thread.c.obj)
                    0x0001eaf0                z_dummy_thread_init
     .text.ready_thread
                    0x0001eb08       0xd0 zephyr/kernel/libkernel.a(sched.c.obj)
     .text.unready_thread
                    0x0001ebd8       0xbc zephyr/kernel/libkernel.a(sched.c.obj)
     .text.z_swap_irqlock
                    0x0001ec94       0x64 zephyr/kernel/libkernel.a(sched.c.obj)
     .text.reschedule
                    0x0001ecf8       0x8c zephyr/kernel/libkernel.a(sched.c.obj)
                    0x0001ed84       0x38 zephyr/kernel/libkernel.a(sched.c.obj)
     .text.move_current_to_end_of_prio_q
                    0x0001edbc       0x6c zephyr/kernel/libkernel.a(sched.c.obj)
                    0x0001edbc                move_current_to_end_of_prio_q
     .text.z_ready_thread
                    0x0001ee28       0x8c zephyr/kernel/libkernel.a(sched.c.obj)
                    0x0001ee28                z_ready_thread
     .text.z_thread_timeout
                    0x0001eeb4       0x90 zephyr/kernel/libkernel.a(sched.c.obj)
                    0x0001eeb4                z_thread_timeout
     .text.z_pend_curr
                    0x0001ef44      0x10c zephyr/kernel/libkernel.a(sched.c.obj)
                    0x0001ef44                z_pend_curr
     .text.z_thread_prio_set
                    0x0001f050      0x1b4 zephyr/kernel/libkernel.a(sched.c.obj)
                    0x0001f050                z_thread_prio_set
     .text.z_reschedule_irqlock
                    0x0001f204       0x28 zephyr/kernel/libkernel.a(sched.c.obj)
                    0x0001f204                z_reschedule_irqlock
     .text.k_sched_lock
                    0x0001f22c       0xe4 zephyr/kernel/libkernel.a(sched.c.obj)
                    0x0001f22c                k_sched_lock
     .text.k_sched_unlock
                    0x0001f310       0xe4 zephyr/kernel/libkernel.a(sched.c.obj)
                    0x0001f310                k_sched_unlock
     .text.z_unpend_all
                    0x0001f3f4       0x90 zephyr/kernel/libkernel.a(sched.c.obj)
                    0x0001f3f4                z_unpend_all
     .text.z_sched_init
                    0x0001f484       0x10 zephyr/kernel/libkernel.a(sched.c.obj)
                    0x0001f484                z_sched_init
     .text.z_impl_k_yield
                    0x0001f494      0x11c zephyr/kernel/libkernel.a(sched.c.obj)
                    0x0001f494                z_impl_k_yield
     .text.z_tick_sleep
                    0x0001f5b0      0x114 zephyr/kernel/libkernel.a(sched.c.obj)
     .text.z_impl_k_sleep
                    0x0001f6c4       0x64 zephyr/kernel/libkernel.a(sched.c.obj)
                    0x0001f6c4                z_impl_k_sleep
     .text.z_impl_k_wakeup
                    0x0001f728       0xb0 zephyr/kernel/libkernel.a(sched.c.obj)
                    0x0001f728                z_impl_k_wakeup
     .text.z_impl_k_sched_current_thread_query
                    0x0001f7d8        0xc zephyr/kernel/libkernel.a(sched.c.obj)
                    0x0001f7d8                z_impl_k_sched_current_thread_query
     .text.z_thread_abort
                    0x0001f7e4      0x268 zephyr/kernel/libkernel.a(sched.c.obj)
                    0x0001f7e4                z_thread_abort
     .text.z_sched_wake
                    0x0001fa4c       0xbc zephyr/kernel/libkernel.a(sched.c.obj)
                    0x0001fa4c                z_sched_wake
     .text.z_sched_wait
                    0x0001fb08       0x24 zephyr/kernel/libkernel.a(sched.c.obj)
                    0x0001fb08                z_sched_wait
     .text.z_time_slice_size
                    0x0001fb2c       0x40 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .text.slice_timeout
                    0x0001fb6c       0x5c zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .text.z_reset_time_slice
                    0x0001fbc8       0x44 zephyr/kernel/libkernel.a(timeslicing.c.obj)
                    0x0001fbc8                z_reset_time_slice
     .text.z_time_slice
                    0x0001fc0c       0xc8 zephyr/kernel/libkernel.a(timeslicing.c.obj)
                    0x0001fc0c                z_time_slice
     .text.z_spin_lock_valid
                    0x0001fcd4       0x1c zephyr/kernel/libkernel.a(spinlock_validate.c.obj)
                    0x0001fcd4                z_spin_lock_valid
     .text.z_spin_unlock_valid
                    0x0001fcf0       0x2c zephyr/kernel/libkernel.a(spinlock_validate.c.obj)
                    0x0001fcf0                z_spin_unlock_valid
     .text.z_spin_lock_set_owner
                    0x0001fd1c       0x10 zephyr/kernel/libkernel.a(spinlock_validate.c.obj)
                    0x0001fd1c                z_spin_lock_set_owner
     .text.first    0x0001fd2c       0x10 zephyr/kernel/libkernel.a(timeout.c.obj)
     .text.elapsed  0x0001fd3c       0x14 zephyr/kernel/libkernel.a(timeout.c.obj)
     .text.remove_timeout
                    0x0001fd50       0x38 zephyr/kernel/libkernel.a(timeout.c.obj)
     .text.z_add_timeout
                    0x0001fd88      0x1b8 zephyr/kernel/libkernel.a(timeout.c.obj)
                    0x0001fd88                z_add_timeout
     .text.z_abort_timeout
                    0x0001ff40       0xd8 zephyr/kernel/libkernel.a(timeout.c.obj)
                    0x0001ff40                z_abort_timeout
     .text.sys_clock_announce_locked
                    0x00020018      0x134 zephyr/kernel/libkernel.a(timeout.c.obj)
                    0x00020018                sys_clock_announce_locked
     .text.sys_clock_lock
                    0x0002014c       0x54 zephyr/kernel/libkernel.a(timeout.c.obj)
                    0x0002014c                sys_clock_lock
     .text.sys_clock_tick_get
                    0x000201a0       0x9c zephyr/kernel/libkernel.a(timeout.c.obj)
                    0x000201a0                sys_clock_tick_get
     .text.z_thread_alloc_helper
                    0x0002023c      0x114 zephyr/kernel/libkernel.a(mempool.c.obj)
     .text.z_thread_malloc
                    0x00020350       0x10 zephyr/kernel/libkernel.a(mempool.c.obj)
                    0x00020350                z_thread_malloc
     .text.k_sys_work_q_init
                    0x00020360       0x2c zephyr/kernel/libkernel.a(system_work_q.c.obj)
     .text.__l_vfprintf
                    0x0002038c      0x488 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflprintf.c.o)
                    0x0002038c                __l_vfprintf
     .text._OffsetAbsSyms
                    0x00020814        0x2 zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj
                    0x00020814                _OffsetAbsSyms
     .text.chunk_size
                    0x00020816        0xa zephyr/libzephyr.a(heap.c.obj)
     .text.right_chunk
                    0x00020820        0xa zephyr/libzephyr.a(heap.c.obj)
     .text.free_list_remove_bidx
                    0x0002082a       0x56 zephyr/libzephyr.a(heap.c.obj)
                    0x00020880       0x1a zephyr/libzephyr.a(heap.c.obj)
     .text.free_list_add
                    0x0002089a       0x6c zephyr/libzephyr.a(heap.c.obj)
     .text.free_chunk_check.isra.0
                    0x00020906       0x40 zephyr/libzephyr.a(heap.c.obj)
     .text.alloc_chunk
                    0x00020946       0x7e zephyr/libzephyr.a(heap.c.obj)
     .text.merge_chunks
                    0x000209c4       0x2c zephyr/libzephyr.a(heap.c.obj)
     .text.split_chunks
                    0x000209f0       0x36 zephyr/libzephyr.a(heap.c.obj)
     .text.sys_heap_free
                    0x00020a26       0xd8 zephyr/libzephyr.a(heap.c.obj)
                    0x00020a26                sys_heap_free
     .text.sys_heap_alloc
                    0x00020afe       0x5a zephyr/libzephyr.a(heap.c.obj)
                    0x00020afe                sys_heap_alloc
     .text.sys_heap_noalign_alloc
                    0x00020b58        0x6 zephyr/libzephyr.a(heap.c.obj)
                    0x00020b58                sys_heap_noalign_alloc
     .text.arch_printk_char_out
                    0x00020b5e        0x4 zephyr/libzephyr.a(printk.c.obj)
                    0x00020b5e                arch_printk_char_out
     .text.printk   0x00020b62       0x1a zephyr/libzephyr.a(printk.c.obj)
                    0x00020b62                printk
     .text.assert_post_action
                    0x00020b7c       0x12 zephyr/libzephyr.a(assert.c.obj)
                    0x00020b7c                assert_post_action
     .text.assert_print
                    0x00020b8e       0x1a zephyr/libzephyr.a(assert.c.obj)
                    0x00020b8e                assert_print
     .text.process_recheck
                    0x00020ba8       0x38 zephyr/libzephyr.a(onoff.c.obj)
     .text.validate_args
                    0x00020be0       0x20 zephyr/libzephyr.a(onoff.c.obj)
     .text.notify_one
                    0x00020c00       0x2c zephyr/libzephyr.a(onoff.c.obj)
     .text.onoff_manager_init
                    0x00020c2c       0x26 zephyr/libzephyr.a(onoff.c.obj)
                    0x00020c2c                onoff_manager_init
     .text.sys_notify_validate
                    0x00020c52       0x22 zephyr/libzephyr.a(notify.c.obj)
                    0x00020c52                sys_notify_validate
     .text._ConfigAbsSyms
                    0x00020c74        0x2 zephyr/libzephyr.a(configs.c.obj)
                    0x00020c74                _ConfigAbsSyms
     .text.arch_early_memset
                    0x00020c76        0x4 zephyr/arch/common/libarch__common.a(init.c.obj)
                    0x00020c76                arch_early_memset
     .text.arch_early_memcpy
                    0x00020c7a        0x4 zephyr/arch/common/libarch__common.a(init.c.obj)
                    0x00020c7a                arch_early_memcpy
     .text.z_do_kernel_oops
                    0x00020c7e        0x8 zephyr/arch/arch/arm/core/libarch__arm__core.a(fatal.c.obj)
                    0x00020c7e                z_do_kernel_oops
     .text.z_arm_nmi
                    0x00020c86        0xe zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi.c.obj)
                    0x00020c86                z_arm_nmi
     .text.z_irq_spurious
                    0x00020c94        0x8 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
                    0x00020c94                z_irq_spurious
     .text.arch_coprocessors_disable
                    0x00020c9c        0x6 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
                    0x00020c9c                arch_coprocessors_disable
     .text.arch_irq_unlock_outlined
                    0x00020ca2        0xe zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
                    0x00020ca2                arch_irq_unlock_outlined
     .text.arch_cpu_idle
                    0x00020cb0       0x1a zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(cpu_idle.c.obj)
                    0x00020cb0                arch_cpu_idle
     .text.arch_cpu_atomic_idle
                    0x00020cca       0x1e zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(cpu_idle.c.obj)
                    0x00020cca                arch_cpu_atomic_idle
     .text.size_to_mpu_rasr_size
                    0x00020ce8       0x20 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .text.fixed_data_unref
                    0x00020d08        0x2 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .text.net_buf_alloc_fixed
                    0x00020d0a        0x8 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
                    0x00020d0a                net_buf_alloc_fixed
     .text.net_buf_simple_add_mem
                    0x00020d12       0x18 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
                    0x00020d12                net_buf_simple_add_mem
     .text.net_buf_simple_add_u8
                    0x00020d2a        0xe zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
                    0x00020d2a                net_buf_simple_add_u8
     .text.net_buf_simple_pull_u8
                    0x00020d38       0x10 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
                    0x00020d38                net_buf_simple_pull_u8
     .text.bt_buf_get_evt
                    0x00020d48        0x6 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
                    0x00020d48                bt_buf_get_evt
     .text.async_start
                    0x00020d4e       0x60 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.api_start
                    0x00020dae        0xe zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.onoff_started_callback
                    0x00020dbc        0xc zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.blocking_start_callback
                    0x00020dc8        0x6 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.lfclk_stop
                    0x00020dce        0x4 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.lfclk_start
                    0x00020dd2        0x4 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.api_stop
                    0x00020dd6        0x6 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .text.z_nrf_clock_bt_ctlr_hf_get_startup_time_us
                    0x00020ddc        0x6 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
                    0x00020ddc                z_nrf_clock_bt_ctlr_hf_get_startup_time_us
     .text.gpio_nrfx_port_get_raw
                    0x00020de2        0xe zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .text.gpio_nrfx_port_set_masked_raw
                    0x00020df0       0x18 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .text.gpio_nrfx_port_set_bits_raw
                    0x00020e08        0xc zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .text.gpio_nrfx_port_clear_bits_raw
                    0x00020e14        0xc zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .text.gpio_nrfx_port_toggle_bits
                    0x00020e20       0x1a zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .text.gpio_nrfx_gpiote_irq_handler
                    0x00020e3a        0x4 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
                    0x00020e3a                gpio_nrfx_gpiote_irq_handler
     .text.pinctrl_lookup_state
                    0x00020e3e       0x26 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(common.c.obj)
                    0x00020e3e                pinctrl_lookup_state
     .text.uarte_nrfx_config_get
                    0x00020e64       0x10 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .text.uarte_nrfx_err_check
                    0x00020e74        0xe zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .text.uarte_nrfx_poll_in
                    0x00020e82       0x26 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .text.is_tx_ready.isra.0
                    0x00020ea8       0x20 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .text.uarte_nrfx_isr_int
                    0x00020ec8       0x42 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .text.pinctrl_apply_state.isra.0
                    0x00020f0a       0x1e zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .text.uarte_0_init
                    0x00020f28       0xca zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .text.k_sys_fatal_error_handler
                    0x00020ff2        0x8 modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a(fatal_error.c.obj)
                    0x00020ff2                k_sys_fatal_error_handler
     .text.hci_driver_close
                    0x00020ffa       0x2e modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .text.receive_work_handler
                    0x00021028        0x4 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .text.hci_driver_send
                    0x0002102c       0x76 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .text.hci_internal_supported_commands
                    0x000210a2       0x70 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
                    0x000210a2                hci_internal_supported_commands
     .text.sdc_hci_cmd_cb_host_buffer_size_wrapper
                    0x00021112       0x2e modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal_wrappers.c.obj)
                    0x00021112                sdc_hci_cmd_cb_host_buffer_size_wrapper
     .text.mpsl_radio_isr_wrapper
                    0x00021140       0x16 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
                    0x00021140                mpsl_radio_isr_wrapper
     .text.mpsl_timer0_isr_wrapper
                    0x00021156       0x16 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
                    0x00021156                mpsl_timer0_isr_wrapper
     .text.mpsl_rtc0_isr_wrapper
                    0x0002116c       0x16 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
                    0x0002116c                mpsl_rtc0_isr_wrapper
     .text.mpsl_fem_api_init
                    0x00021182        0xa modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a(mpsl_fem_api_init.c.obj)
     .text.nrfx_clock_lfclk_stop
                    0x0002118c        0x2 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
                    0x0002118c                nrfx_clock_lfclk_stop
     .text.nrfx_clock_lfclk_start
                    0x0002118e        0x6 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
                    0x0002118e                nrfx_clock_lfclk_start
     .text.nrfx_clock_enable
                    0x00021194        0x2 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
                    0x00021194                nrfx_clock_enable
     .text.nrfx_power_clock_irq_handler
                    0x00021196        0x4 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
                    0x00021196                nrfx_power_clock_irq_handler
     .text.nrfx_isr
                    0x0002119a        0x6 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj)
                    0x0002119a                nrfx_isr
     .text.nrfx_busy_wait
                    0x000211a0        0x4 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj)
                    0x000211a0                nrfx_busy_wait
     .text.nrfx_flag32_alloc
                    0x000211a4       0x3c modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_flag32_allocator.c.obj)
                    0x000211a4                nrfx_flag32_alloc
     .text.nrfx_flag32_free
                    0x000211e0       0x3a modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_flag32_allocator.c.obj)
                    0x000211e0                nrfx_flag32_free
     .text.nrfx_gppi_conn_alloc
                    0x0002121a       0x28 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
                    0x0002121a                nrfx_gppi_conn_alloc
     .text.nrf_gpio_pin_present_check
                    0x00021242       0x24 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.pin_in_use_by_te
                    0x00021266       0x16 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.pin_has_trigger
                    0x0002127c       0x1c modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.pin_is_output
                    0x00021298       0x16 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.pin_is_task_output
                    0x000212ae       0x16 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.pin_te_get
                    0x000212c4       0x14 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.call_handler
                    0x000212d8       0x3e modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.nrf_gpio_reconfigure
                    0x00021316       0x9a modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.nrf_gpio_cfg_sense_set
                    0x000213b0       0x1e modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.__nrfy_internal_gpiote_events_process
                    0x000213ce       0x5a modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.pin_trigger_disable
                    0x00021428       0x44 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .text.z_impl_k_busy_wait
                    0x0002146c        0x8 zephyr/kernel/libkernel.a(busy_wait.c.obj)
                    0x0002146c                z_impl_k_busy_wait
     .text.z_impl_device_is_ready
                    0x00021474       0x16 zephyr/kernel/libkernel.a(device.c.obj)
                    0x00021474                z_impl_device_is_ready
     .text.k_heap_init
                    0x0002148a       0x14 zephyr/kernel/libkernel.a(kheap.c.obj)
                    0x0002148a                k_heap_init
     .text.adjust_owner_prio.isra.0
                    0x0002149e       0x10 zephyr/kernel/libkernel.a(mutex.c.obj)
     .text.z_queue_node_peek
                    0x000214ae       0x18 zephyr/kernel/libkernel.a(queue.c.obj)
                    0x000214ae                z_queue_node_peek
     .text.k_queue_append
                    0x000214c6       0x16 zephyr/kernel/libkernel.a(queue.c.obj)
                    0x000214c6                k_queue_append
     .text.k_queue_prepend
                    0x000214dc       0x14 zephyr/kernel/libkernel.a(queue.c.obj)
                    0x000214dc                k_queue_prepend
     .text.z_impl_k_sem_init
                    0x000214f0       0x18 zephyr/kernel/libkernel.a(sem.c.obj)
                    0x000214f0                z_impl_k_sem_init
     .text.flag_test_and_clear
                    0x00021508       0x16 zephyr/kernel/libkernel.a(work.c.obj)
     .text.notify_queue_locked.isra.0
                    0x0002151e        0xe zephyr/kernel/libkernel.a(work.c.obj)
     .text.k_work_submit_to_queue
                    0x0002152c       0x20 zephyr/kernel/libkernel.a(work.c.obj)
                    0x0002152c                k_work_submit_to_queue
     .text.k_is_in_isr
                    0x0002154c        0xc zephyr/kernel/libkernel.a(thread.c.obj)
                    0x0002154c                k_is_in_isr
     .text.z_impl_k_thread_name_set
                    0x00021558        0x6 zephyr/kernel/libkernel.a(thread.c.obj)
                    0x00021558                z_impl_k_thread_name_set
     .text.sys_dlist_remove
                    0x0002155e       0x10 zephyr/kernel/libkernel.a(sched.c.obj)
     .text.add_to_waitq_locked
                    0x0002156e       0x4c zephyr/kernel/libkernel.a(sched.c.obj)
     .text.z_sched_wake_thread_locked
                    0x000215ba       0x28 zephyr/kernel/libkernel.a(sched.c.obj)
                    0x000215ba                z_sched_wake_thread_locked
     .text.z_reschedule
                    0x000215e2        0x4 zephyr/kernel/libkernel.a(sched.c.obj)
                    0x000215e2                z_reschedule
     .text.z_unpend_all_locked
                    0x000215e6       0x30 zephyr/kernel/libkernel.a(sched.c.obj)
                    0x000215e6                z_unpend_all_locked
     .text.next_timeout
                    0x00021616       0x2e zephyr/kernel/libkernel.a(timeout.c.obj)
     .text.sys_clock_tick_get_32
                    0x00021644        0x8 zephyr/kernel/libkernel.a(timeout.c.obj)
                    0x00021644                sys_clock_tick_get_32
     .text.z_impl_k_uptime_ticks
                    0x0002164c        0x4 zephyr/kernel/libkernel.a(timeout.c.obj)
                    0x0002164c                z_impl_k_uptime_ticks
     .text.sys_timepoint_calc
                    0x00021650       0x4a zephyr/kernel/libkernel.a(timeout.c.obj)
                    0x00021650                sys_timepoint_calc
     .text.sys_timepoint_timeout
                    0x0002169a       0x42 zephyr/kernel/libkernel.a(timeout.c.obj)
                    0x0002169a                sys_timepoint_timeout
     .text.k_free   0x000216dc        0xe zephyr/kernel/libkernel.a(mempool.c.obj)
                    0x000216dc                k_free
     .text.boot_banner
                    0x000216ea        0x2 zephyr/kernel/libkernel.a(banner.c.obj)
                    0x000216ea                boot_banner
     .text.memcpy   0x000216ec       0x1c /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(memcpy.c.o)
                    0x000216ec                __aeabi_memcpy4
                    0x000216ec                __aeabi_memcpy8
                    0x000216ec                memcpy
     .text.memset   0x00021708       0x10 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(memset.c.o)
                    0x00021708                memset
     .text.strncpy  0x00021718       0x26 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_strncpy.c.o)
                    0x00021718                strncpy
     .text.strnlen  0x0002173e       0x18 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_strnlen.c.o)
                    0x0002173e                strnlen
     .text.__ultoa_invert
                    0x00021756       0xae /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflprintf.c.o)
     *(SORT_BY_ALIGNMENT(.gnu.linkonce.t.*))
     *(SORT_BY_ALIGNMENT(.glue_7t))
     .glue_7t       0x00021804        0x0 linker stubs
     *(SORT_BY_ALIGNMENT(.glue_7))
     .glue_7        0x00021804        0x0 linker stubs
     *(SORT_BY_ALIGNMENT(.vfp11_veneer))
     .vfp11_veneer  0x00021804        0x0 linker stubs
     *(SORT_BY_ALIGNMENT(.v4_bx))
     .v4_bx         0x00021804        0x0 linker stubs
                    0x00021804                        . = ALIGN (0x4)
                    0x00021804                        __text_region_end = .
    .ARM.exidx      0x00021804        0x0
                    0x00021804                        __exidx_start = .
     *(SORT_BY_ALIGNMENT(.ARM.exidx*) SORT_BY_ALIGNMENT(gnu.linkonce.armexidx.*))
                    0x00021804                        __exidx_end = .
                    0x00021804                        __rodata_region_start = .
    initlevel       0x00021804       0x88
                    0x00021804                        __init_start = .
                    0x00021804                        __init_EARLY_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_EARLY_P_?_*)))
     .z_init_EARLY_P_0_SUB_0_
                    0x00021804        0x8 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gppi_init.c.obj)
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_EARLY_P_??_*)))
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_EARLY_P_???_*)))
                    0x0002180c                        __init_PRE_KERNEL_1_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_PRE_KERNEL_1_P_?_*)))
     .z_init_PRE_KERNEL_1_P_0_SUB_0_
                    0x0002180c        0x8 zephyr/soc/soc/nrf52833/libsoc__nordic.a(soc.c.obj)
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_PRE_KERNEL_1_P_??_*)))
     .z_init_PRE_KERNEL_1_P_30_SUB_00022_
                    0x00021814        0x8 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .z_init_PRE_KERNEL_1_P_30_SUB_0_
                    0x0002181c        0x8 zephyr/kernel/libkernel.a(kheap.c.obj)
     .z_init_PRE_KERNEL_1_P_40_SUB_00033_
                    0x00021824        0x8 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .z_init_PRE_KERNEL_1_P_40_SUB_00034_
                    0x0002182c        0x8 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .z_init_PRE_KERNEL_1_P_40_SUB_0_
                    0x00021834        0x8 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
                    0x0002183c        0x8 modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a(mpsl_fem_api_init.c.obj)
     .z_init_PRE_KERNEL_1_P_50_SUB_00048_
                    0x00021844        0x8 zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .z_init_PRE_KERNEL_1_P_50_SUB_00062_
                    0x0002184c        0x8 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_PRE_KERNEL_1_P_???_*)))
                    0x00021854                        __init_PRE_KERNEL_2_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_PRE_KERNEL_2_P_?_*)))
     .z_init_PRE_KERNEL_2_P_0_SUB_0_
                    0x00021854        0x8 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_PRE_KERNEL_2_P_??_*)))
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_PRE_KERNEL_2_P_???_*)))
                    0x0002185c                        __init_POST_KERNEL_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_POST_KERNEL_P_?_*)))
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_POST_KERNEL_P_??_*)))
     .z_init_POST_KERNEL_P_35_SUB_0_
                    0x0002185c        0x8 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .z_init_POST_KERNEL_P_40_SUB_00081_
                    0x00021864        0x8 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .z_init_POST_KERNEL_P_40_SUB_0_
                    0x0002186c        0x8 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
                    0x00021874        0x8 zephyr/kernel/libkernel.a(system_work_q.c.obj)
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_POST_KERNEL_P_???_*)))
                    0x0002187c                        __init_APPLICATION_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_APPLICATION_P_?_*)))
     .z_init_APPLICATION_P_0_SUB_0_
                    0x0002187c        0x8 zephyr/libzephyr.a(banner.c.obj)
                    0x00021884        0x8 modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_APPLICATION_P_??_*)))
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_APPLICATION_P_???_*)))
                    0x0002188c                        __init_SMP_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_SMP_P_?_*)))
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_SMP_P_??_*)))
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_SMP_P_???_*)))
                    0x0002188c                        __init_end = .
    device_area     0x0002188c       0xa8
                    0x0002188c                        _device_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._device.static.*_?_*)))
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._device.static.*_??_*)))
     ._device.static.1_30_
                    0x0002188c       0x1c zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
                    0x0002188c                __device_dts_ord_22
     ._device.static.1_40_
                    0x000218a8       0x38 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
                    0x000218a8                __device_dts_ord_34
                    0x000218c4                __device_dts_ord_33
     ._device.static.1_50_
                    0x000218e0       0x1c zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
                    0x000218e0                __device_dts_ord_48
                    0x000218fc       0x1c zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
                    0x000218fc                __device_dts_ord_62
     ._device.static.3_40_
                    0x00021918       0x1c modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
                    0x00021918                __device_dts_ord_81
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._device.static.*_???_*)))
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._device.static.*_????_*)))
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._device.static.*_?????_*)))
                    0x00021934                        _device_list_end = .
    sw_isr_table    0x00021934      0x180
                    0x00021934                        . = ALIGN (0x4)
     *(SORT_BY_ALIGNMENT(.gnu.linkonce.sw_isr_table*))
                    0x00021934      0x180 zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
                    0x00021934                _sw_isr_table
    initlevel_error
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.z_init_*)))
                    0x00000001                        ASSERT ((SIZEOF (initlevel_error) == 0x0), Undefined initialization levels used.)
    app_shmem_regions
                    0x00021ab4        0x0
                    0x00021ab4                        __app_shmem_regions_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.app_regions.*)))
                    0x00021ab4                        __app_shmem_regions_end = .
    k_p4wq_initparam_area
                    0x00021ab4        0x0
                    0x00021ab4                        _k_p4wq_initparam_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._k_p4wq_initparam.static.*)))
                    0x00021ab4                        _k_p4wq_initparam_list_end = .
    _static_thread_data_area
                    0x00021ab4        0x0
                    0x00021ab4                        __static_thread_data_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.__static_thread_data.static.*)))
                    0x00021ab4                        __static_thread_data_list_end = .
    device_deps     0x00021ab4        0x0
                    0x00021ab4                        __device_deps_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.__device_deps_pass2*)))
                    0x00021ab4                        __device_deps_end = .
    entropy_driver_api_area
                    0x00021ab4        0x8
                    0x00021ab4                        _entropy_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._entropy_driver_api.static.*)))
     ._entropy_driver_api.static.entropy_nrf5_api_funcs_
                    0x00021ab4        0x8 zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
                    0x00021abc                        _entropy_driver_api_list_end = .
    gpio_driver_api_area
                    0x00021abc       0x24
                    0x00021abc                        _gpio_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._gpio_driver_api.static.*)))
     ._gpio_driver_api.static.gpio_nrfx_drv_api_funcs_
                    0x00021abc       0x24 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
                    0x00021ae0                        _gpio_driver_api_list_end = .
    shared_irq_driver_api_area
                    0x00021ae0        0x0
                    0x00021ae0                        _shared_irq_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._shared_irq_driver_api.static.*)))
                    0x00021ae0                        _shared_irq_driver_api_list_end = .
    crypto_driver_api_area
                    0x00021ae0        0x0
                    0x00021ae0                        _crypto_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._crypto_driver_api.static.*)))
                    0x00021ae0                        _crypto_driver_api_list_end = .
    adc_driver_api_area
                    0x00021ae0        0x0
                    0x00021ae0                        _adc_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._adc_driver_api.static.*)))
                    0x00021ae0                        _adc_driver_api_list_end = .
    auxdisplay_driver_api_area
                    0x00021ae0        0x0
                    0x00021ae0                        _auxdisplay_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._auxdisplay_driver_api.static.*)))
                    0x00021ae0                        _auxdisplay_driver_api_list_end = .
    bbram_driver_api_area
                    0x00021ae0        0x0
                    0x00021ae0                        _bbram_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._bbram_driver_api.static.*)))
                    0x00021ae0                        _bbram_driver_api_list_end = .
    biometric_driver_api_area
                    0x00021ae0        0x0
                    0x00021ae0                        _biometric_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._biometric_driver_api.static.*)))
                    0x00021ae0                        _biometric_driver_api_list_end = .
    bt_hci_driver_api_area
                    0x00021ae0        0x0
                    0x00021ae0                        _bt_hci_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._bt_hci_driver_api.static.*)))
                    0x00021ae0                        _bt_hci_driver_api_list_end = .
    can_driver_api_area
                    0x00021ae0        0x0
                    0x00021ae0                        _can_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._can_driver_api.static.*)))
                    0x00021ae0                        _can_driver_api_list_end = .
    cellular_driver_api_area
                    0x00021ae0        0x0
                    0x00021ae0                        _cellular_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._cellular_driver_api.static.*)))
                    0x00021ae0                        _cellular_driver_api_list_end = .
    charger_driver_api_area
                    0x00021ae0        0x0
                    0x00021ae0                        _charger_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._charger_driver_api.static.*)))
                    0x00021ae0                        _charger_driver_api_list_end = .
    clock_control_driver_api_area
                    0x00021ae0       0x1c
                    0x00021ae0                        _clock_control_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._clock_control_driver_api.static.*)))
     ._clock_control_driver_api.static.clock_control_api_
                    0x00021ae0       0x1c zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
                    0x00021afc                        _clock_control_driver_api_list_end = .
    comparator_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _comparator_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._comparator_driver_api.static.*)))
                    0x00021afc                        _comparator_driver_api_list_end = .
    coredump_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _coredump_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._coredump_driver_api.static.*)))
                    0x00021afc                        _coredump_driver_api_list_end = .
    counter_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _counter_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._counter_driver_api.static.*)))
                    0x00021afc                        _counter_driver_api_list_end = .
    crc_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _crc_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._crc_driver_api.static.*)))
                    0x00021afc                        _crc_driver_api_list_end = .
    dac_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _dac_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._dac_driver_api.static.*)))
                    0x00021afc                        _dac_driver_api_list_end = .
    dai_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _dai_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._dai_driver_api.static.*)))
                    0x00021afc                        _dai_driver_api_list_end = .
                    0x00021afc        0x0
                    0x00021afc                        _display_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._display_driver_api.static.*)))
                    0x00021afc                        _display_driver_api_list_end = .
    dma_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _dma_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._dma_driver_api.static.*)))
                    0x00021afc                        _dma_driver_api_list_end = .
    edac_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _edac_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._edac_driver_api.static.*)))
                    0x00021afc                        _edac_driver_api_list_end = .
    eeprom_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _eeprom_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._eeprom_driver_api.static.*)))
                    0x00021afc                        _eeprom_driver_api_list_end = .
    emul_bbram_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _emul_bbram_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._emul_bbram_driver_api.static.*)))
                    0x00021afc                        _emul_bbram_driver_api_list_end = .
    fuel_gauge_emul_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _fuel_gauge_emul_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._fuel_gauge_emul_driver_api.static.*)))
                    0x00021afc                        _fuel_gauge_emul_driver_api_list_end = .
    emul_sensor_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _emul_sensor_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._emul_sensor_driver_api.static.*)))
                    0x00021afc                        _emul_sensor_driver_api_list_end = .
    espi_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _espi_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._espi_driver_api.static.*)))
                    0x00021afc                        _espi_driver_api_list_end = .
    espi_saf_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _espi_saf_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._espi_saf_driver_api.static.*)))
                    0x00021afc                        _espi_saf_driver_api_list_end = .
    flash_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _flash_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._flash_driver_api.static.*)))
                    0x00021afc                        _flash_driver_api_list_end = .
    fpga_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _fpga_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._fpga_driver_api.static.*)))
                    0x00021afc                        _fpga_driver_api_list_end = .
    fuel_gauge_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _fuel_gauge_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._fuel_gauge_driver_api.static.*)))
                    0x00021afc                        _fuel_gauge_driver_api_list_end = .
    gnss_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _gnss_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._gnss_driver_api.static.*)))
                    0x00021afc                        _gnss_driver_api_list_end = .
    haptics_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _haptics_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._haptics_driver_api.static.*)))
                    0x00021afc                        _haptics_driver_api_list_end = .
    hwspinlock_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _hwspinlock_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._hwspinlock_driver_api.static.*)))
                    0x00021afc                        _hwspinlock_driver_api_list_end = .
    i2c_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _i2c_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._i2c_driver_api.static.*)))
                    0x00021afc                        _i2c_driver_api_list_end = .
    i2c_target_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _i2c_target_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._i2c_target_driver_api.static.*)))
                    0x00021afc                        _i2c_target_driver_api_list_end = .
    i2s_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _i2s_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._i2s_driver_api.static.*)))
                    0x00021afc                        _i2s_driver_api_list_end = .
    i3c_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _i3c_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._i3c_driver_api.static.*)))
                    0x00021afc                        _i3c_driver_api_list_end = .
    ipm_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _ipm_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._ipm_driver_api.static.*)))
                    0x00021afc                        _ipm_driver_api_list_end = .
    led_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _led_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._led_driver_api.static.*)))
                    0x00021afc                        _led_driver_api_list_end = .
    led_strip_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _led_strip_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._led_strip_driver_api.static.*)))
                    0x00021afc                        _led_strip_driver_api_list_end = .
    lora_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _lora_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._lora_driver_api.static.*)))
                    0x00021afc                        _lora_driver_api_list_end = .
    mbox_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _mbox_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._mbox_driver_api.static.*)))
                    0x00021afc                        _mbox_driver_api_list_end = .
    mdio_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _mdio_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._mdio_driver_api.static.*)))
                    0x00021afc                        _mdio_driver_api_list_end = .
    mipi_dbi_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _mipi_dbi_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._mipi_dbi_driver_api.static.*)))
                    0x00021afc                        _mipi_dbi_driver_api_list_end = .
    mipi_dsi_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _mipi_dsi_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._mipi_dsi_driver_api.static.*)))
                    0x00021afc                        _mipi_dsi_driver_api_list_end = .
    mspi_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _mspi_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._mspi_driver_api.static.*)))
                    0x00021afc                        _mspi_driver_api_list_end = .
    opamp_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _opamp_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._opamp_driver_api.static.*)))
                    0x00021afc                        _opamp_driver_api_list_end = .
    otp_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _otp_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._otp_driver_api.static.*)))
                    0x00021afc                        _otp_driver_api_list_end = .
    peci_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _peci_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._peci_driver_api.static.*)))
                    0x00021afc                        _peci_driver_api_list_end = .
    ps2_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _ps2_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._ps2_driver_api.static.*)))
                    0x00021afc                        _ps2_driver_api_list_end = .
    ptp_clock_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _ptp_clock_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._ptp_clock_driver_api.static.*)))
                    0x00021afc                        _ptp_clock_driver_api_list_end = .
    pwm_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _pwm_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._pwm_driver_api.static.*)))
                    0x00021afc                        _pwm_driver_api_list_end = .
    regulator_parent_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _regulator_parent_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._regulator_parent_driver_api.static.*)))
                    0x00021afc                        _regulator_parent_driver_api_list_end = .
    regulator_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _regulator_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._regulator_driver_api.static.*)))
                    0x00021afc                        _regulator_driver_api_list_end = .
    reset_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _reset_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._reset_driver_api.static.*)))
                    0x00021afc                        _reset_driver_api_list_end = .
    retained_mem_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _retained_mem_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._retained_mem_driver_api.static.*)))
                    0x00021afc                        _retained_mem_driver_api_list_end = .
    rtc_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _rtc_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._rtc_driver_api.static.*)))
                    0x00021afc                        _rtc_driver_api_list_end = .
    sdhc_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _sdhc_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._sdhc_driver_api.static.*)))
                    0x00021afc                        _sdhc_driver_api_list_end = .
                    0x00021afc        0x0
                    0x00021afc                        _sensor_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._sensor_driver_api.static.*)))
                    0x00021afc                        _sensor_driver_api_list_end = .
    smbus_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _smbus_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._smbus_driver_api.static.*)))
                    0x00021afc                        _smbus_driver_api_list_end = .
    spi_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _spi_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._spi_driver_api.static.*)))
                    0x00021afc                        _spi_driver_api_list_end = .
    syscon_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _syscon_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._syscon_driver_api.static.*)))
                    0x00021afc                        _syscon_driver_api_list_end = .
    tee_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _tee_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._tee_driver_api.static.*)))
                    0x00021afc                        _tee_driver_api_list_end = .
    uaol_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _uaol_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._uaol_driver_api.static.*)))
                    0x00021afc                        _uaol_driver_api_list_end = .
    video_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _video_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._video_driver_api.static.*)))
                    0x00021afc                        _video_driver_api_list_end = .
    virtio_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _virtio_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._virtio_driver_api.static.*)))
                    0x00021afc                        _virtio_driver_api_list_end = .
    w1_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _w1_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._w1_driver_api.static.*)))
                    0x00021afc                        _w1_driver_api_list_end = .
    wdt_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _wdt_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._wdt_driver_api.static.*)))
                    0x00021afc                        _wdt_driver_api_list_end = .
    wuc_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _wuc_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._wuc_driver_api.static.*)))
                    0x00021afc                        _wuc_driver_api_list_end = .
    can_transceiver_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _can_transceiver_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._can_transceiver_driver_api.static.*)))
                    0x00021afc                        _can_transceiver_driver_api_list_end = .
    nrf_clock_control_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _nrf_clock_control_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._nrf_clock_control_driver_api.static.*)))
                    0x00021afc                        _nrf_clock_control_driver_api_list_end = .
    i3c_target_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _i3c_target_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._i3c_target_driver_api.static.*)))
                    0x00021afc                        _i3c_target_driver_api_list_end = .
    its_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _its_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._its_driver_api.static.*)))
                    0x00021afc                        _its_driver_api_list_end = .
    vtd_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _vtd_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._vtd_driver_api.static.*)))
                    0x00021afc                        _vtd_driver_api_list_end = .
    renesas_elc_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _renesas_elc_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._renesas_elc_driver_api.static.*)))
                    0x00021afc                        _renesas_elc_driver_api_list_end = .
    tgpio_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _tgpio_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._tgpio_driver_api.static.*)))
                    0x00021afc                        _tgpio_driver_api_list_end = .
    pcie_ctrl_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _pcie_ctrl_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._pcie_ctrl_driver_api.static.*)))
                    0x00021afc                        _pcie_ctrl_driver_api_list_end = .
    pcie_ep_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _pcie_ep_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._pcie_ep_driver_api.static.*)))
                    0x00021afc                        _pcie_ep_driver_api_list_end = .
    psi5_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _psi5_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._psi5_driver_api.static.*)))
                    0x00021afc                        _psi5_driver_api_list_end = .
    sent_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _sent_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._sent_driver_api.static.*)))
                    0x00021afc                        _sent_driver_api_list_end = .
    svc_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _svc_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._svc_driver_api.static.*)))
                    0x00021afc                        _svc_driver_api_list_end = .
    stepper_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _stepper_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._stepper_driver_api.static.*)))
                    0x00021afc                        _stepper_driver_api_list_end = .
    stepper_ctrl_driver_api_area
                    0x00021afc        0x0
                    0x00021afc                        _stepper_ctrl_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._stepper_ctrl_driver_api.static.*)))
                    0x00021afc                        _stepper_ctrl_driver_api_list_end = .
    uart_driver_api_area
                    0x00021afc       0x14
                    0x00021afc                        _uart_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._uart_driver_api.static.*)))
     ._uart_driver_api.static.uart_nrfx_uarte_driver_api_
                    0x00021afc       0x14 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
                    0x00021b10                        _uart_driver_api_list_end = .
    bc12_emul_driver_api_area
                    0x00021b10        0x0
                    0x00021b10                        _bc12_emul_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._bc12_emul_driver_api.static.*)))
                    0x00021b10                        _bc12_emul_driver_api_list_end = .
    bc12_driver_api_area
                    0x00021b10        0x0
                    0x00021b10                        _bc12_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._bc12_driver_api.static.*)))
                    0x00021b10                        _bc12_driver_api_list_end = .
    usbc_ppc_driver_api_area
                    0x00021b10        0x0
                    0x00021b10                        _usbc_ppc_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._usbc_ppc_driver_api.static.*)))
                    0x00021b10                        _usbc_ppc_driver_api_list_end = .
    tcpc_driver_api_area
                    0x00021b10        0x0
                    0x00021b10                        _tcpc_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._tcpc_driver_api.static.*)))
                    0x00021b10                        _tcpc_driver_api_list_end = .
    usbc_vbus_driver_api_area
                    0x00021b10        0x0
                    0x00021b10                        _usbc_vbus_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._usbc_vbus_driver_api.static.*)))
                    0x00021b10                        _usbc_vbus_driver_api_list_end = .
    ivshmem_driver_api_area
                    0x00021b10        0x0
                    0x00021b10                        _ivshmem_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._ivshmem_driver_api.static.*)))
                    0x00021b10                        _ivshmem_driver_api_list_end = .
    ethphy_driver_api_area
                    0x00021b10        0x0
                    0x00021b10                        _ethphy_driver_api_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._ethphy_driver_api.static.*)))
                    0x00021b10                        _ethphy_driver_api_list_end = .
    ztest           0x00021b10        0x0
                    0x00021b10                        _ztest_expected_result_entry_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._ztest_expected_result_entry.static.*)))
                    0x00021b10                        _ztest_expected_result_entry_list_end = .
                    0x00021b10                        _ztest_suite_node_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._ztest_suite_node.static.*)))
                    0x00021b10                        _ztest_suite_node_list_end = .
                    0x00021b10                        _ztest_unit_test_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._ztest_unit_test.static.*)))
                    0x00021b10                        _ztest_unit_test_list_end = .
                    0x00021b10                        _ztest_test_rule_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._ztest_test_rule.static.*)))
                    0x00021b10                        _ztest_test_rule_list_end = .
    init_array      0x00021b10        0x0
                    0x00021b10                        __zephyr_init_array_start = .
     *(SORT_BY_INIT_PRIORITY(.init_array.*) SORT_BY_INIT_PRIORITY(.ctors.*))
     *(SORT_BY_ALIGNMENT(.init_array) SORT_BY_ALIGNMENT(.ctors))
                    0x00021b10                        __zephyr_init_array_end = .
                    0x00000001                        ASSERT ((__zephyr_init_array_start == __zephyr_init_array_end), GNU-style constructors required but STATIC_INIT_GNU not enabled)
    bt_l2cap_fixed_chan_area
                    0x00021b10        0x0
                    0x00021b10                        _bt_l2cap_fixed_chan_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._bt_l2cap_fixed_chan.static.*)))
                    0x00021b10                        _bt_l2cap_fixed_chan_list_end = .
    bt_conn_cb_area
                    0x00021b10        0x0
                    0x00021b10                        _bt_conn_cb_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._bt_conn_cb.static.*)))
                    0x00021b10                        _bt_conn_cb_list_end = .
    bt_gatt_service_static_area
                    0x00021b10        0x0
                    0x00021b10                        _bt_gatt_service_static_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._bt_gatt_service_static.static.*)))
                    0x00021b10                        _bt_gatt_service_static_list_end = .
    log_strings_area
                    0x00021b10        0x0
                    0x00021b10                        _log_strings_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._log_strings.static.*)))
                    0x00021b10                        _log_strings_list_end = .
    log_stmesp_ptr_area
                    0x00021b10        0x0
                    0x00021b10                        _log_stmesp_ptr_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._log_stmesp_ptr.static.*)))
                    0x00021b10                        _log_stmesp_ptr_list_end = .
    log_stmesp_str_area
                    0x00021b10        0x0
                    0x00021b10                        _log_stmesp_str_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._log_stmesp_str.static.*)))
                    0x00021b10                        _log_stmesp_str_list_end = .
    log_const_area  0x00021b10        0x0
                    0x00021b10                        _log_const_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._log_const.static.*)))
                    0x00021b10                        _log_const_list_end = .
    log_backend_area
                    0x00021b10        0x0
                    0x00021b10                        _log_backend_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._log_backend.static.*)))
                    0x00021b10                        _log_backend_list_end = .
    log_link_area   0x00021b10        0x0
                    0x00021b10                        _log_link_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._log_link.static.*)))
                    0x00021b10                        _log_link_list_end = .
    tracing_backend_area
                    0x00021b10        0x0
                    0x00021b10                        _tracing_backend_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._tracing_backend.static.*)))
                    0x00021b10                        _tracing_backend_list_end = .
    zephyr_dbg_info
     *(SORT_BY_ALIGNMENT(.dbg_thread_info))
    intc_table_area
                    0x00021b10        0x0
                    0x00021b10                        _intc_table_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._intc_table.static.*)))
                    0x00021b10                        _intc_table_list_end = .
    symbol_to_keep  0x00021b10        0x0
                    0x00021b10                        __symbol_to_keep_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(.symbol_to_keep*)))
                    0x00021b10                        __symbol_to_keep_end = .
    shell_area      0x00021b10        0x0
                    0x00021b10                        _shell_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._shell.static.*)))
                    0x00021b10                        _shell_list_end = .
    shell_root_cmds_area
                    0x00021b10        0x0
                    0x00021b10                        _shell_root_cmds_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._shell_root_cmds.static.*)))
                    0x00021b10                        _shell_root_cmds_list_end = .
    shell_subcmds_area
                    0x00021b10        0x0
                    0x00021b10                        _shell_subcmds_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._shell_subcmds.static.*)))
                    0x00021b10                        _shell_subcmds_list_end = .
    shell_dynamic_subcmds_area
                    0x00021b10        0x0
                    0x00021b10                        _shell_dynamic_subcmds_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._shell_dynamic_subcmds.static.*)))
                    0x00021b10                        _shell_dynamic_subcmds_list_end = .
    cfb_font_area   0x00021b10        0x0
                    0x00021b10                        _cfb_font_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._cfb_font.static.*)))
                    0x00021b10                        _cfb_font_list_end = .
    tdata           0x00021b10        0x0
     *(SORT_BY_ALIGNMENT(.tdata) SORT_BY_ALIGNMENT(.tdata.*) SORT_BY_ALIGNMENT(.gnu.linkonce.td.*))
    tbss            0x00021b10        0x4
     *(SORT_BY_ALIGNMENT(.tbss) SORT_BY_ALIGNMENT(.tbss.*) SORT_BY_ALIGNMENT(.gnu.linkonce.tb.*) SORT_BY_ALIGNMENT(.tcommon))
     .tbss.z_tls_current
                    0x00021b10        0x4 zephyr/libzephyr.a(thread_entry.c.obj)
                    0x00021b10                z_tls_current
                    0x00021b10                        PROVIDE (__tdata_start = LOADADDR (tdata))
                    0x00000001                        PROVIDE (__tdata_align = ALIGNOF (tdata))
                    0x00000000                        PROVIDE (__tdata_size = (((SIZEOF (tdata) + __tdata_align) - 0x1) & ~ ((__tdata_align - 0x1))))
                    [!provide]                        PROVIDE (__tdata_end = (__tdata_start + __tdata_size))
                    0x00000004                        PROVIDE (__tbss_align = ALIGNOF (tbss))
                    [!provide]                        PROVIDE (__tbss_start = ADDR (tbss))
                    0x00000004                        PROVIDE (__tbss_size = (((SIZEOF (tbss) + __tbss_align) - 0x1) & ~ ((__tbss_align - 0x1))))
                    [!provide]                        PROVIDE (__tbss_end = (__tbss_start + __tbss_size))
                    [!provide]                        PROVIDE (__tls_start = __tdata_start)
                    [!provide]                        PROVIDE (__tls_end = __tbss_end)
                    [!provide]                        PROVIDE (__tls_size = (__tbss_end - __tdata_start))
    rodata          0x00021b10     0x22c4
     *(SORT_BY_ALIGNMENT(.rodata))
     .rodata        0x00021b10      0x2b2 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x00021d64                sym_4AYPF6WLCUFYAQ6MJPMXJNRKT3EN725RCCCR2RI
                    0x00021d78                sym_YLWTFT5XCFQVKUEDNIITVQPB77I7BPYVMQIA2XQ
                    0x00021d8c                sym_5PW4ZKOPWJFV4VWTTYK27JYQME3VTB7JJVC4OAY
                    0x00021da0                sym_YYCWMCGH5PVM77GXSK22JWSRXJXGTRGMSHCBNZA
     .rodata        0x00021dc2       0x74 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     *(SORT_BY_ALIGNMENT(.rodata.*))
     *fill*         0x00021e36        0xa
     .rodata.delay_machine_code.0
                    0x00021e40        0x6 zephyr/soc/soc/nrf52833/libsoc__nordic.a(soc.c.obj)
     *fill*         0x00021e46        0x2
     .rodata.mem_attr_region
                    0x00021e48        0x0 zephyr/libzephyr.a(mem_attr.c.obj)
     .rodata.static_regions
                    0x00021e48        0xc zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_core_mpu.c.obj)
     .rodata.mpu_config
                    0x00021e54        0x8 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu_regions.c.obj)
                    0x00021e54                mpu_config
     .rodata.mpu_regions
                    0x00021e5c       0x18 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu_regions.c.obj)
     .rodata.net_buf_fixed_cb
                    0x00021e74        0xc zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
                    0x00021e74                net_buf_fixed_cb
     .rodata.net_buf_fixed_alloc_hci_acl_pool
                    0x00021e80       0x10 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .rodata.net_buf_fixed_hci_acl_pool
                    0x00021e90        0x4 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .rodata.net_buf_fixed_alloc_hci_cmd_pool
                    0x00021e94       0x10 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .rodata.net_buf_fixed_hci_cmd_pool
                    0x00021ea4        0x4 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .rodata.net_buf_fixed_alloc_hci_rx_pool
                    0x00021ea8       0x10 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .rodata.net_buf_fixed_hci_rx_pool
                    0x00021eb8        0x4 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .rodata.transitions.0
                    0x00021ebc        0xc zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .rodata.config
                    0x00021ec8       0x10 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .rodata.gpio_nrfx_p1_cfg
                    0x00021ed8       0x14 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .rodata.gpio_nrfx_p0_cfg
                    0x00021eec       0x14 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .rodata.uarte_0z_config
                    0x00021f00       0x1c zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .rodata.__pinctrl_dev_config__device_dts_ord_62
                    0x00021f1c        0xc zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .rodata.__pinctrl_states__device_dts_ord_62
                    0x00021f28        0x8 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .rodata.__pinctrl_state_pins_0__device_dts_ord_62
                    0x00021f30        0x8 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .rodata.hci_driver_api
                    0x00021f38        0xc modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .rodata.m_config
                    0x00021f44        0x8 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .rodata.levels.0
                    0x00021f4c       0x18 zephyr/kernel/libkernel.a(init.c.obj)
     .rodata.cfg.0  0x00021f64        0xc zephyr/kernel/libkernel.a(system_work_q.c.obj)
     .rodata.main.str1.1
                    0x00021f70     0x1e47 app/libapp.a(main.c.obj)
                                     0xcd (size before relaxing)
     .rodata.sys_heap_aligned_alloc.str1.1
                    0x00023db7       0x78 zephyr/libzephyr.a(heap.c.obj)
     .rodata.sys_heap_init.str1.1
                    0x00023db7       0xbb zephyr/libzephyr.a(heap.c.obj)
     .rodata.z_thread_entry.str1.1
                    0x00023db7       0x7d zephyr/libzephyr.a(thread_entry.c.obj)
     .rodata.process_event.str1.1
                    0x00023db7      0x149 zephyr/libzephyr.a(onoff.c.obj)
     .rodata.sys_notify_finalize.str1.1
                    0x00023db7       0x45 zephyr/libzephyr.a(notify.c.obj)
     .rodata.ncs_boot_banner.str1.1
                    0x00023db7       0x63 zephyr/libzephyr.a(banner.c.obj)
     .rodata.z_arm_fatal_error.str1.1
                    0x00023db7       0xb3 zephyr/arch/arch/arm/core/libarch__arm__core.a(fatal.c.obj)
     .rodata.mem_manage_fault.str1.1
                    0x00023db7      0x19b zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .rodata.usage_fault.isra.0.str1.1
                    0x00023db7       0xd4 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .rodata.bus_fault.isra.0.str1.1
                    0x00023db7       0x8e zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .rodata.z_arm_fault.str1.1
                    0x00023db7      0x1c0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .rodata.arm_irq_priority_set.str1.1
                    0x00023db7       0xaf zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
     .rodata.arm_core_mpu_configure_static_mpu_regions.str1.1
                    0x00023db7       0x7a zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .rodata.arm_core_mpu_configure_dynamic_mpu_regions.str1.1
                    0x00023db7       0x2d zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .rodata.z_arm_mpu_init.str1.1
                    0x00023db7      0x124 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .rodata.str1.1
                    0x00023db7        0xf zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu_regions.c.obj)
     .rodata.net_buf_reset.str1.1
                    0x00023db7       0x5c zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .rodata.net_buf_alloc_len.str1.1
                    0x00023db7       0x9a zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .rodata.net_buf_slist_put.str1.1
                    0x00023db7        0x9 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .rodata.net_buf_unref.str1.1
                    0x00023db7       0x1e zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .rodata.net_buf_simple_reserve.str1.1
                    0x00023db7       0x5c zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .rodata.net_buf_simple_add.str1.1
                    0x00023db7       0x24 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .rodata.net_buf_simple_remove_mem.str1.1
                    0x00023db7       0x10 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .rodata.bt_buf_type_to_h4.str1.1
                    0x00023db7       0x51 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .rodata.get_status.str1.1
                    0x00023db7       0x7e zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .rodata.clock_event_handler.str1.1
                    0x00023db7        0x2 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .rodata.z_nrf_clock_control_lf_on.str1.1
                    0x00023db7        0x9 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .rodata.str1.1
                    0x00023db7        0xf zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .rodata.entropy_nrf5_get_entropy_isr.str1.1
                    0x00023db7       0x6f zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .rodata.str1.1
                    0x00023db7       0x10 zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .rodata.gpio_nrfx_manage_callback.str1.1
                    0x00023db7       0x9a zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .rodata.nrf_gpio_pin_port_decode.str1.1
                    0x00023db7       0x56 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .rodata.gpio_nrfx_pin_interrupt_configure.str1.1
                    0x00023db7       0x35 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .rodata.nrfx_gpio_handler.str1.1
                    0x00023db7        0xc zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .rodata.str1.1
                    0x00023db7       0x1c zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
                    0x00023db7       0x73 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(pinctrl_nrf.c.obj)
     .rodata.drive_modes
                    0x00023db7        0x8 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(pinctrl_nrf.c.obj)
     .rodata.str1.1
                    0x00023dbf        0xe zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .rodata.dtm_tw_to_hci_process_hci_event.str1.1
                    0x00023dbf      0x1a9 modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
     .rodata.sdc_assertion_handler.str1.1
                    0x00023dbf       0x84 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .rodata.rand_prio_low_vector_get_blocking.str1.1
                    0x00023dbf       0xbd modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .rodata.hci_driver_init.str1.1
                    0x00023dbf       0x58 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .rodata.receive_signal_raise.str1.1
                    0x00023dbf       0x4c modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .rodata.str1.1
                    0x00023dbf        0xb modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .rodata.hci_internal_cmd_put.str1.1
                    0x00023dbf       0xb0 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
     .rodata.m_assert_handler.str1.1
                    0x00023dbf       0x67 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .rodata.mpsl_low_prio_work_handler.str1.1
                    0x00023dbf        0xd modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .rodata.mpsl_low_prio_irq_handler.str1.1
                    0x00023dbf       0x4c modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .rodata.mpsl_low_prio_init.str1.1
                    0x00023dbf        0xa modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .rodata.nrfx_clock_start.str1.1
                    0x00023dbf       0x6c modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
     .rodata.flag_free.str1.1
                    0x00023dbf       0x62 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .rodata.nrfx_gppi_domain_conn_alloc.str1.1
                    0x00023dbf       0x16 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .rodata.release_handler.str1.1
                    0x00023dbf       0x64 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
                    0x00023dbf       0x58 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .rodata.nrf_gpiote_in_event_get.str1.1
                    0x00023dbf       0x3f modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .rodata.nrfx_gpiote_input_configure.str1.1
                    0x00023dbf        0xb modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .rodata.nrfx_gpiote_channel_get.str1.1
                    0x00023dbf        0xa modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .rodata.nrfx_gpiote_trigger_enable.str1.1
                    0x00023dbf       0x2c modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .rodata.port_offset.1
                    0x00023dbf       0x10 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .rodata.ports  0x00023dcf        0x2 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .rodata.do_device_init.str1.1
                    0x00023dd1       0x7d zephyr/kernel/libkernel.a(device.c.obj)
     .rodata.z_fatal_error.str1.1
                    0x00023dd1       0x91 zephyr/kernel/libkernel.a(fatal.c.obj)
     .rodata.bg_thread_main.str1.1
                    0x00023dd1       0x8a zephyr/kernel/libkernel.a(init.c.obj)
     .rodata.z_cstart.str1.1
                    0x00023dd1       0x1d zephyr/kernel/libkernel.a(init.c.obj)
     .rodata.z_heap_alloc_helper.str1.1
                    0x00023dd1      0x10b zephyr/kernel/libkernel.a(kheap.c.obj)
     .rodata.statics_init.str1.1
                    0x00023dd1       0x38 zephyr/kernel/libkernel.a(kheap.c.obj)
     .rodata.idle.str1.1
                    0x00023dd1       0x66 zephyr/kernel/libkernel.a(idle.c.obj)
     .rodata.z_impl_k_mutex_lock.str1.1
                    0x00023dd1       0xfa zephyr/kernel/libkernel.a(mutex.c.obj)
     .rodata.z_impl_k_mutex_unlock.str1.1
                    0x00023dd1       0x74 zephyr/kernel/libkernel.a(mutex.c.obj)
     .rodata.unpend_thread_no_timeout.str1.1
                    0x00023dd1       0x5f zephyr/kernel/libkernel.a(queue.c.obj)
     .rodata.queue_insert.str1.1
                    0x00023dd1       0x9f zephyr/kernel/libkernel.a(queue.c.obj)
                    0x00023dd1       0x5f zephyr/kernel/libkernel.a(sem.c.obj)
     .rodata.z_impl_k_sem_give.str1.1
                    0x00023dd1       0x9f zephyr/kernel/libkernel.a(sem.c.obj)
     .rodata.z_impl_k_sem_take.str1.1
                    0x00023dd1       0x6d zephyr/kernel/libkernel.a(sem.c.obj)
     .rodata.work_queue_main.str1.1
                    0x00023dd1       0xd9 zephyr/kernel/libkernel.a(work.c.obj)
     .rodata.submit_to_queue_locked.str1.1
                    0x00023dd1       0x1b zephyr/kernel/libkernel.a(work.c.obj)
     .rodata.k_work_init.str1.1
                    0x00023dd1       0x14 zephyr/kernel/libkernel.a(work.c.obj)
     .rodata.z_work_submit_to_queue.str1.1
                    0x00023dd1       0x1d zephyr/kernel/libkernel.a(work.c.obj)
     .rodata.k_work_queue_run.str1.1
                    0x00023dd1       0x34 zephyr/kernel/libkernel.a(work.c.obj)
     .rodata.k_work_queue_start.str1.1
                    0x00023dd1        0xc zephyr/kernel/libkernel.a(work.c.obj)
     .rodata.z_setup_new_thread.str1.1
                    0x00023dd1       0xf1 zephyr/kernel/libkernel.a(thread.c.obj)
     .rodata.z_impl_k_thread_create.str1.1
                    0x00023dd1       0x37 zephyr/kernel/libkernel.a(thread.c.obj)
     .rodata.ready_thread.str1.1
                    0x00023dd1       0xb6 zephyr/kernel/libkernel.a(sched.c.obj)
     .rodata.unready_thread.str1.1
                    0x00023dd1       0x19 zephyr/kernel/libkernel.a(sched.c.obj)
     .rodata.z_swap_irqlock.str1.1
                    0x00023dd1       0xbb zephyr/kernel/libkernel.a(sched.c.obj)
     .rodata.reschedule.str1.1
                    0x00023dd1       0x59 zephyr/kernel/libkernel.a(sched.c.obj)
                    0x00023dd1       0x42 zephyr/kernel/libkernel.a(sched.c.obj)
     .rodata.z_ready_thread.str1.1
                    0x00023dd1       0x2b zephyr/kernel/libkernel.a(sched.c.obj)
     .rodata.z_pend_curr.str1.1
                    0x00023dd1       0x39 zephyr/kernel/libkernel.a(sched.c.obj)
     .rodata.k_sched_lock.str1.1
                    0x00023dd1       0x43 zephyr/kernel/libkernel.a(sched.c.obj)
     .rodata.k_sched_unlock.str1.1
                    0x00023dd1       0x31 zephyr/kernel/libkernel.a(sched.c.obj)
     .rodata.z_thread_abort.str1.1
                    0x00023dd1       0x56 zephyr/kernel/libkernel.a(sched.c.obj)
     .rodata.slice_timeout.str1.1
                    0x00023dd1      0x1f0 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .rodata.k_sched_time_slice_set.str1.1
                    0x00023dd1       0x84 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .rodata.z_add_timeout.str1.1
                    0x00023dd1       0xe8 zephyr/kernel/libkernel.a(timeout.c.obj)
     .rodata.z_thread_alloc_helper.str1.1
                    0x00023dd1      0x157 zephyr/kernel/libkernel.a(mempool.c.obj)
     .rodata.str1.1
                    0x00023dd1        0x9 zephyr/kernel/libkernel.a(system_work_q.c.obj)
     .rodata.str1.1
                    0x00023dd1       0x18 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .rodata.str1.1
                    0x00023dd1       0x17 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .rodata.__l_vfprintf.str1.1
                    0x00023dd1        0xf /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflprintf.c.o)
     *(SORT_BY_ALIGNMENT(.gnu.linkonce.r.*))
                    0x00023fc4                        . = ALIGN (0x4)
     *fill*         0x00023dd1        0x3
                    [!provide]                        PROVIDE (__eh_frame_start = 0x0)
                    [!provide]                        PROVIDE (__eh_frame_end = 0x0)
                    [!provide]                        PROVIDE (__eh_frame_hdr_start = 0x0)
                    [!provide]                        PROVIDE (__eh_frame_hdr_end = 0x0)
    /DISCARD/
     *(SORT_BY_ALIGNMENT(.eh_frame))
                    0x00023dd4                        __rodata_region_end = .
                    0x00023de0                        . = ALIGN (_region_min_align)
                    0x00040000                        . = ALIGN ((0x1 << LOG2CEIL ((__rodata_region_end - ADDR (rom_start)))))
                    0x00040000                        __rom_region_end = ((__rom_region_start + .) - ADDR (rom_start))
                    0x00040000                        __rom_region_size = (__rom_region_end - __rom_region_start)
    /DISCARD/
     *(SORT_BY_ALIGNMENT(.got.plt))
     *(SORT_BY_ALIGNMENT(.igot.plt))
     *(SORT_BY_ALIGNMENT(.got))
     *(SORT_BY_ALIGNMENT(.igot))
                    0x20000000                        . = 0x20000000
                    0x20000000                        . = ALIGN (_region_min_align)
                    0x20000000                        _image_ram_start = .
    .ramfunc        0x20000000        0x0 load address 0x00023dd4
                    0x20000000                        __ramfunc_region_start = .
                    0x20000000                        . = ALIGN ((0x1 << LOG2CEIL (__ramfunc_size)))
                    0x20000000                        __ramfunc_start = .
     *(SORT_BY_ALIGNMENT(.ramfunc))
     *(SORT_BY_ALIGNMENT(.ramfunc.*))
                    0x20000000                        __ramfunc_end = .
                    0x00000000                        __ramfunc_size = (__ramfunc_end - __ramfunc_start)
                    0x00023dd4                        __ramfunc_load_start = LOADADDR (.ramfunc)
    datas           0x20000000      0x17c load address 0x00023dd4
                    0x20000000                        __data_region_start = .
                    0x20000000                        __data_start = .
     *(SORT_BY_ALIGNMENT(.data))
     .data          0x20000000       0x68 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x20000064                sym_REJBUCWCBODKZS5VJQ54HACILUKXX7LQT2NGX7Q
     .data          0x20000068        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .data          0x20000070        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .data          0x20000078        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .data          0x20000080        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .data          0x20000088        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .data          0x20000090        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .data          0x20000098        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .data          0x200000a0        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .data          0x200000a8        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .data          0x200000b0        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .data          0x200000b8        0x4 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .data          0x200000bc        0x9 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     *(SORT_BY_ALIGNMENT(.data.*))
     *fill*         0x200000c5        0x3
     .data._char_out
                    0x200000c8        0x4 zephyr/libzephyr.a(printk.c.obj)
     .data.g_nrfx_gpiote1073766400U
                    0x200000cc       0x84 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gpiote_nrfx.c.obj)
                    0x200000cc                g_nrfx_gpiote1073766400U
     .data.bt_dev   0x20000150        0x4 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
                    0x20000150                bt_dev
     .data.uarte_0_data
                    0x20000154       0x14 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .data.SystemCoreClock
                    0x20000168        0x4 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(system_nrf52833.c.obj)
                    0x20000168                SystemCoreClock
     .data.available_channels_mask
                    0x2000016c        0x4 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .data.slice_ticks
                    0x20000170        0x4 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .data.timeout_list
                    0x20000174        0x8 zephyr/kernel/libkernel.a(timeout.c.obj)
     *(SORT_BY_ALIGNMENT(.kernel.*))
                    0x2000017c                        __data_end = .
                    0x0000017c                        __data_size = (__data_end - __data_start)
                    0x00023dd4                        __data_load_start = LOADADDR (datas)
                    0x00023dd4                        __data_region_load_start = LOADADDR (datas)
    device_states   0x2000017c        0xc load address 0x00023f50
                    0x2000017c                        . = ALIGN (0x4)
                    0x2000017c                        __device_states_start = .
     *(SORT_BY_ALIGNMENT(.z_devstate))
     .z_devstate    0x2000017c        0x2 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .z_devstate    0x2000017e        0x2 zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .z_devstate    0x20000180        0x4 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .z_devstate    0x20000184        0x2 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .z_devstate    0x20000186        0x2 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     *(SORT_BY_ALIGNMENT(.z_devstate.*))
                    0x20000188                        __device_states_end = .
                    0x20000188                        . = ALIGN (0x4)
    log_mpsc_pbuf_area
                    0x20000188        0x0 load address 0x00023f5c
                    0x20000188                        _log_mpsc_pbuf_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._log_mpsc_pbuf.static.*)))
                    0x20000188                        _log_mpsc_pbuf_list_end = .
    log_msg_ptr_area
                    0x20000188                        _log_msg_ptr_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._log_msg_ptr.static.*)))
                    0x20000188                        _log_msg_ptr_list_end = .
    log_dynamic_area
                    0x20000188                        _log_dynamic_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._log_dynamic.static.*)))
                    0x20000188                        _log_dynamic_list_end = .
    k_timer_area    0x20000188        0x0 load address 0x00023f5c
                    0x20000188                        _k_timer_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._k_timer.static.*)))
                    0x20000188                        _k_timer_list_end = .
    k_mem_slab_area
                    0x20000188                        _k_mem_slab_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._k_mem_slab.static.*)))
                    0x20000188                        _k_mem_slab_list_end = .
    k_heap_area     0x20000188        0x0 load address 0x00023f5c
                    0x20000188                        _k_heap_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._k_heap.static.*)))
                    0x20000188                        _k_heap_list_end = .
    k_mutex_area    0x20000188       0x14 load address 0x00023f5c
                    0x20000188                        _k_mutex_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._k_mutex.static.*)))
     ._k_mutex.static.mpsl_lock_
                    0x20000188       0x14 modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a(multithreading_lock.c.obj)
                    0x2000019c                        _k_mutex_list_end = .
    k_stack_area    0x2000019c        0x0 load address 0x00023f70
                    0x2000019c                        _k_stack_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._k_stack.static.*)))
                    0x2000019c                        _k_stack_list_end = .
    k_msgq_area     0x2000019c        0x0 load address 0x00023f70
                    0x2000019c                        _k_msgq_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._k_msgq.static.*)))
                    0x2000019c                        _k_msgq_list_end = .
    k_mbox_area     0x2000019c        0x0 load address 0x00023f70
                    0x2000019c                        _k_mbox_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._k_mbox.static.*)))
                    0x2000019c                        _k_mbox_list_end = .
    k_pipe_area     0x2000019c        0x0 load address 0x00023f70
                    0x2000019c                        _k_pipe_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._k_pipe.static.*)))
                    0x2000019c                        _k_pipe_list_end = .
    k_sem_area      0x2000019c        0x0 load address 0x00023f70
                    0x2000019c                        _k_sem_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._k_sem.static.*)))
                    0x2000019c                        _k_sem_list_end = .
    k_event_area    0x2000019c        0x0 load address 0x00023f70
                    0x2000019c                        _k_event_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._k_event.static.*)))
                    0x2000019c                        _k_event_list_end = .
    k_queue_area    0x2000019c        0x0 load address 0x00023f70
                    0x2000019c                        _k_queue_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._k_queue.static.*)))
                    0x2000019c                        _k_queue_list_end = .
    k_fifo_area     0x2000019c       0x14 load address 0x00023f70
                    0x2000019c                        _k_fifo_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._k_fifo.static.*)))
     ._k_fifo.static.hci_c2h_queue_
                    0x2000019c       0x14 app/libapp.a(main.c.obj)
                    0x200001b0                        _k_fifo_list_end = .
    k_lifo_area     0x200001b0        0x0 load address 0x00023f84
                    0x200001b0                        _k_lifo_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._k_lifo.static.*)))
                    0x200001b0                        _k_lifo_list_end = .
    k_condvar_area  0x200001b0        0x0 load address 0x00023f84
                    0x200001b0                        _k_condvar_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._k_condvar.static.*)))
                    0x200001b0                        _k_condvar_list_end = .
    sys_mem_blocks_ptr_area
                    0x200001b0                        _sys_mem_blocks_ptr_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._sys_mem_blocks_ptr.static.*)))
                    0x200001b0                        _sys_mem_blocks_ptr_list_end = .
    net_buf_pool_area
                    0x200001b0       0x84 load address 0x00023f84
                    0x200001b0                        _net_buf_pool_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._net_buf_pool.static.*)))
     ._net_buf_pool.static.hci_acl_pool_
                    0x200001b0       0x2c zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     ._net_buf_pool.static.hci_cmd_pool_
                    0x200001dc       0x2c zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     ._net_buf_pool.static.hci_rx_pool_
                    0x20000208       0x2c zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
                    0x20000234                        _net_buf_pool_list_end = .
                    0x20000234                        __data_region_end = .
    hci_internal_user_extension_handler_area
                    0x00024008        0x0
                    0x00024008                        _hci_internal_user_extension_handler_list_start = .
     *(SORT_BY_NAME(SORT_BY_ALIGNMENT(._hci_internal_user_extension_handler.static.*)))
                    0x00024008                        _hci_internal_user_extension_handler_list_end = .
                    0x0001ccc4                        PROVIDE (soc_reset_hook = SystemInit)
    /DISCARD/
     *(SORT_BY_ALIGNMENT(.irq_info*))
     *(SORT_BY_ALIGNMENT(.intList*))
    .stab
     *(SORT_BY_ALIGNMENT(.stab))
    .stabstr
     *(SORT_BY_ALIGNMENT(.stabstr))
    .stab.excl
     *(SORT_BY_ALIGNMENT(.stab.excl))
    .stab.exclstr
     *(SORT_BY_ALIGNMENT(.stab.exclstr))
    .stab.index
     *(SORT_BY_ALIGNMENT(.stab.index))
    .stab.indexstr
     *(SORT_BY_ALIGNMENT(.stab.indexstr))
    .gnu.build.attributes
     *(SORT_BY_ALIGNMENT(.gnu.build.attributes) SORT_BY_ALIGNMENT(.gnu.build.attributes.*))
    .comment        0x00000000       0x1f
     *(SORT_BY_ALIGNMENT(.comment))
     .comment       0x00000000       0x1f zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
                                     0x20 (size before relaxing)
     .comment       0x0000001f       0x20 zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj
     .comment       0x0000001f       0x20 app/libapp.a(dtm_twowire_transport.c.obj)
     .comment       0x0000001f       0x20 app/libapp.a(main.c.obj)
     .comment       0x0000001f       0x20 zephyr/libzephyr.a(heap.c.obj)
     .comment       0x0000001f       0x20 zephyr/libzephyr.a(printk.c.obj)
     .comment       0x0000001f       0x20 zephyr/libzephyr.a(thread_entry.c.obj)
     .comment       0x0000001f       0x20 zephyr/libzephyr.a(assert.c.obj)
     .comment       0x0000001f       0x20 zephyr/libzephyr.a(onoff.c.obj)
     .comment       0x0000001f       0x20 zephyr/libzephyr.a(notify.c.obj)
     .comment       0x0000001f       0x20 zephyr/libzephyr.a(last_section_id.c.obj)
     .comment       0x0000001f       0x20 zephyr/libzephyr.a(configs.c.obj)
     .comment       0x0000001f       0x20 zephyr/libzephyr.a(mem_attr.c.obj)
     .comment       0x0000001f       0x20 zephyr/libzephyr.a(banner.c.obj)
     .comment       0x0000001f       0x20 zephyr/arch/common/libarch__common.a(init.c.obj)
     .comment       0x0000001f       0x20 zephyr/arch/common/libarch__common.a(xip.c.obj)
     .comment       0x0000001f       0x20 zephyr/arch/arch/arm/core/libarch__arm__core.a(fatal.c.obj)
     .comment       0x0000001f       0x20 zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi.c.obj)
     .comment       0x0000001f       0x20 zephyr/arch/arch/arm/core/libarch__arm__core.a(tls.c.obj)
     .comment       0x0000001f       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .comment       0x0000001f       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
     .comment       0x0000001f       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
     .comment       0x0000001f       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(prep_c.c.obj)
     .comment       0x0000001f       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
     .comment       0x0000001f       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(cpu_idle.c.obj)
     .comment       0x0000001f       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(exc_exit.c.obj)
     .comment       0x0000001f       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread_abort.c.obj)
     .comment       0x0000001f       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_init.c.obj)
     .comment       0x0000001f       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(isr_wrapper.c.obj)
     .comment       0x0000001f       0x20 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_core_mpu.c.obj)
     .comment       0x0000001f       0x20 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .comment       0x0000001f       0x20 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu_regions.c.obj)
     .comment       0x0000001f       0x20 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .comment       0x0000001f       0x20 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .comment       0x0000001f       0x20 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .comment       0x0000001f       0x20 zephyr/soc/soc/nrf52833/libsoc__nordic.a(soc.c.obj)
     .comment       0x0000001f       0x20 zephyr/soc/soc/nrf52833/libsoc__nordic.a(reboot.c.obj)
     .comment       0x0000001f       0x20 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gppi_init.c.obj)
     .comment       0x0000001f       0x20 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gpiote_nrfx.c.obj)
     .comment       0x0000001f       0x20 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .comment       0x0000001f       0x20 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .comment       0x0000001f       0x20 zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .comment       0x0000001f       0x20 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .comment       0x0000001f       0x20 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(common.c.obj)
     .comment       0x0000001f       0x20 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(pinctrl_nrf.c.obj)
     .comment       0x0000001f       0x20 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .comment       0x0000001f       0x20 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .comment       0x0000001f       0x20 modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a(multithreading_lock.c.obj)
     .comment       0x0000001f       0x20 modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a(fatal_error.c.obj)
     .comment       0x0000001f       0x20 modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
     .comment       0x0000001f       0x20 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .comment       0x0000001f       0x20 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
     .comment       0x0000001f       0x20 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal_wrappers.c.obj)
     .comment       0x0000001f       0x20 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .comment       0x0000001f       0x20 modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a(mpsl_fem_api_init.c.obj)
     .comment       0x0000001f       0x20 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
     .comment       0x0000001f       0x20 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(system_nrf52833.c.obj)
     .comment       0x0000001f       0x20 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj)
     .comment       0x0000001f       0x20 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_flag32_allocator.c.obj)
     .comment       0x0000001f       0x20 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .comment       0x0000001f       0x20 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .comment       0x0000001f       0x20 zephyr/kernel/libkernel.a(busy_wait.c.obj)
     .comment       0x0000001f       0x20 zephyr/kernel/libkernel.a(device.c.obj)
     .comment       0x0000001f       0x20 zephyr/kernel/libkernel.a(fatal.c.obj)
     .comment       0x0000001f       0x20 zephyr/kernel/libkernel.a(init.c.obj)
     .comment       0x0000001f       0x20 zephyr/kernel/libkernel.a(kheap.c.obj)
     .comment       0x0000001f       0x20 zephyr/kernel/libkernel.a(idle.c.obj)
     .comment       0x0000001f       0x20 zephyr/kernel/libkernel.a(mutex.c.obj)
     .comment       0x0000001f       0x20 zephyr/kernel/libkernel.a(queue.c.obj)
     .comment       0x0000001f       0x20 zephyr/kernel/libkernel.a(sem.c.obj)
     .comment       0x0000001f       0x20 zephyr/kernel/libkernel.a(work.c.obj)
     .comment       0x0000001f       0x20 zephyr/kernel/libkernel.a(thread.c.obj)
     .comment       0x0000001f       0x20 zephyr/kernel/libkernel.a(sched.c.obj)
     .comment       0x0000001f       0x20 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .comment       0x0000001f       0x20 zephyr/kernel/libkernel.a(spinlock_validate.c.obj)
     .comment       0x0000001f       0x20 zephyr/kernel/libkernel.a(timeout.c.obj)
     .comment       0x0000001f       0x20 zephyr/kernel/libkernel.a(mempool.c.obj)
     .comment       0x0000001f       0x20 zephyr/kernel/libkernel.a(banner.c.obj)
     .comment       0x0000001f       0x20 zephyr/kernel/libkernel.a(system_work_q.c.obj)
    .debug
     *(SORT_BY_ALIGNMENT(.debug))
    .line
     *(SORT_BY_ALIGNMENT(.line))
    .debug_srcinfo
     *(SORT_BY_ALIGNMENT(.debug_srcinfo))
    .debug_sfnames
     *(SORT_BY_ALIGNMENT(.debug_sfnames))
    .debug_aranges  0x00000000     0x1b28
     *(SORT_BY_ALIGNMENT(.debug_aranges))
     .debug_aranges
                    0x00000000       0x20 zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi_on_reset.S.obj)
     .debug_aranges
                    0x00000020       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault_s.S.obj)
     .debug_aranges
                    0x00000040       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(reset.S.obj)
     .debug_aranges
                    0x00000060       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(svc.S.obj)
     .debug_aranges
                    0x00000080       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(swap_helper.S.obj)
     .debug_aranges
                    0x000000a0       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(__aeabi_read_tp.S.obj)
     .debug_aranges
                    0x000000c0       0x18 zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
     .debug_aranges
                    0x000000d8       0x20 zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj
     .debug_aranges
                    0x000000f8       0x30 app/libapp.a(dtm_twowire_transport.c.obj)
     .debug_aranges
                    0x00000128       0x20 app/libapp.a(main.c.obj)
     .debug_aranges
                    0x00000148       0xa8 zephyr/libzephyr.a(heap.c.obj)
     .debug_aranges
                    0x000001f0       0x50 zephyr/libzephyr.a(printk.c.obj)
     .debug_aranges
                    0x00000240       0x20 zephyr/libzephyr.a(thread_entry.c.obj)
     .debug_aranges
                    0x00000260       0x28 zephyr/libzephyr.a(assert.c.obj)
     .debug_aranges
                    0x00000288       0x90 zephyr/libzephyr.a(onoff.c.obj)
     .debug_aranges
                    0x00000318       0x28 zephyr/libzephyr.a(notify.c.obj)
     .debug_aranges
                    0x00000340       0x18 zephyr/libzephyr.a(last_section_id.c.obj)
     .debug_aranges
                    0x00000358       0x20 zephyr/libzephyr.a(configs.c.obj)
     .debug_aranges
                    0x00000378       0x30 zephyr/libzephyr.a(mem_attr.c.obj)
     .debug_aranges
                    0x000003a8       0x20 zephyr/libzephyr.a(banner.c.obj)
     .debug_aranges
                    0x000003c8       0x30 zephyr/arch/common/libarch__common.a(init.c.obj)
     .debug_aranges
                    0x000003f8       0x20 zephyr/arch/common/libarch__common.a(xip.c.obj)
     .debug_aranges
                    0x00000418       0x28 zephyr/arch/arch/arm/core/libarch__arm__core.a(fatal.c.obj)
     .debug_aranges
                    0x00000440       0x20 zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi.c.obj)
     .debug_aranges
                    0x00000460       0x20 zephyr/arch/arch/arm/core/libarch__arm__core.a(tls.c.obj)
     .debug_aranges
                    0x00000480       0x40 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .debug_aranges
                    0x000004c0       0x40 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
     .debug_aranges
                    0x00000500       0x40 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
     .debug_aranges
                    0x00000540       0x28 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(prep_c.c.obj)
     .debug_aranges
                    0x00000568       0x48 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
     .debug_aranges
                    0x000005b0       0x30 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(cpu_idle.c.obj)
     .debug_aranges
                    0x000005e0       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(exc_exit.c.obj)
     .debug_aranges
                    0x00000600       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread_abort.c.obj)
     .debug_aranges
                    0x00000620       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_init.c.obj)
     .debug_aranges
                    0x00000640       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(isr_wrapper.c.obj)
     .debug_aranges
                    0x00000660       0x28 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_core_mpu.c.obj)
     .debug_aranges
                    0x00000688       0x68 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .debug_aranges
                    0x000006f0       0x18 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu_regions.c.obj)
     .debug_aranges
                    0x00000708       0x60 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .debug_aranges
                    0x00000768       0xe0 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .debug_aranges
                    0x00000848      0x218 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .debug_aranges
                    0x00000a60       0x28 zephyr/soc/soc/nrf52833/libsoc__nordic.a(soc.c.obj)
     .debug_aranges
                    0x00000a88       0x20 zephyr/soc/soc/nrf52833/libsoc__nordic.a(reboot.c.obj)
     .debug_aranges
                    0x00000aa8       0x20 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gppi_init.c.obj)
     .debug_aranges
                    0x00000ac8       0x18 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gpiote_nrfx.c.obj)
     .debug_aranges
                    0x00000ae0       0x60 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .debug_aranges
                    0x00000b40       0xc8 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .debug_aranges
                    0x00000c08       0x48 zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .debug_aranges
                    0x00000c50       0x80 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .debug_aranges
                    0x00000cd0       0x20 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(common.c.obj)
     .debug_aranges
                    0x00000cf0       0x28 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(pinctrl_nrf.c.obj)
     .debug_aranges
                    0x00000d18       0x60 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .debug_aranges
                    0x00000d78       0xc0 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .debug_aranges
                    0x00000e38       0x28 modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a(multithreading_lock.c.obj)
     .debug_aranges
                    0x00000e60       0x20 modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a(fatal_error.c.obj)
     .debug_aranges
                    0x00000e80       0x30 modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
     .debug_aranges
                    0x00000eb0       0x70 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .debug_aranges
                    0x00000f20       0x38 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
     .debug_aranges
                    0x00000f58       0x20 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal_wrappers.c.obj)
     .debug_aranges
                    0x00000f78       0x68 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .debug_aranges
                    0x00000fe0       0x20 modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a(mpsl_fem_api_init.c.obj)
     .debug_aranges
                    0x00001000       0x68 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
     .debug_aranges
                    0x00001068       0x38 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(system_nrf52833.c.obj)
     .debug_aranges
                    0x000010a0       0x30 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj)
     .debug_aranges
                    0x000010d0       0x30 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_flag32_allocator.c.obj)
     .debug_aranges
                    0x00001100      0x118 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .debug_aranges
                    0x00001218      0x1c0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .debug_aranges
                    0x000013d8       0x20 zephyr/kernel/libkernel.a(busy_wait.c.obj)
     .debug_aranges
                    0x000013f8       0x48 zephyr/kernel/libkernel.a(device.c.obj)
     .debug_aranges
                    0x00001440       0x38 zephyr/kernel/libkernel.a(fatal.c.obj)
     .debug_aranges
                    0x00001478       0x40 zephyr/kernel/libkernel.a(init.c.obj)
     .debug_aranges
                    0x000014b8       0x68 zephyr/kernel/libkernel.a(kheap.c.obj)
     .debug_aranges
                    0x00001520       0x28 zephyr/kernel/libkernel.a(idle.c.obj)
     .debug_aranges
                    0x00001548       0x38 zephyr/kernel/libkernel.a(mutex.c.obj)
     .debug_aranges
                    0x00001580       0xa0 zephyr/kernel/libkernel.a(queue.c.obj)
     .debug_aranges
                    0x00001620       0x40 zephyr/kernel/libkernel.a(sem.c.obj)
     .debug_aranges
                    0x00001660      0x120 zephyr/kernel/libkernel.a(work.c.obj)
     .debug_aranges
                    0x00001780       0x90 zephyr/kernel/libkernel.a(thread.c.obj)
     .debug_aranges
                    0x00001810      0x180 zephyr/kernel/libkernel.a(sched.c.obj)
     .debug_aranges
                    0x00001990       0x40 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .debug_aranges
                    0x000019d0       0x30 zephyr/kernel/libkernel.a(spinlock_validate.c.obj)
     .debug_aranges
                    0x00001a00       0xa8 zephyr/kernel/libkernel.a(timeout.c.obj)
     .debug_aranges
                    0x00001aa8       0x40 zephyr/kernel/libkernel.a(mempool.c.obj)
     .debug_aranges
                    0x00001ae8       0x20 zephyr/kernel/libkernel.a(banner.c.obj)
     .debug_aranges
                    0x00001b08       0x20 zephyr/kernel/libkernel.a(system_work_q.c.obj)
    .debug_pubnames
     *(SORT_BY_ALIGNMENT(.debug_pubnames))
    .debug_info     0x00000000    0x6aabf
     *(SORT_BY_ALIGNMENT(.debug_info) SORT_BY_ALIGNMENT(.gnu.linkonce.wi.*))
     .debug_info    0x00000000      0x1a3 zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
     .debug_info    0x000001a3       0xdc zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj
     .debug_info    0x0000027f      0xaa6 app/libapp.a(dtm_twowire_transport.c.obj)
     .debug_info    0x00000d25      0x926 app/libapp.a(main.c.obj)
     .debug_info    0x0000164b     0x431b zephyr/libzephyr.a(heap.c.obj)
     .debug_info    0x00005966      0x581 zephyr/libzephyr.a(printk.c.obj)
     .debug_info    0x00005ee7      0x845 zephyr/libzephyr.a(thread_entry.c.obj)
     .debug_info    0x0000672c      0x246 zephyr/libzephyr.a(assert.c.obj)
     .debug_info    0x00006972     0x385c zephyr/libzephyr.a(onoff.c.obj)
     .debug_info    0x0000a1ce      0x3a4 zephyr/libzephyr.a(notify.c.obj)
     .debug_info    0x0000a572       0x95 zephyr/libzephyr.a(last_section_id.c.obj)
     .debug_info    0x0000a607       0x38 zephyr/libzephyr.a(configs.c.obj)
     .debug_info    0x0000a63f      0x33e zephyr/libzephyr.a(mem_attr.c.obj)
     .debug_info    0x0000a97d      0x30d zephyr/libzephyr.a(banner.c.obj)
     .debug_info    0x0000ac8a      0x225 zephyr/arch/common/libarch__common.a(init.c.obj)
     .debug_info    0x0000aeaf      0x12d zephyr/arch/common/libarch__common.a(xip.c.obj)
     .debug_info    0x0000afdc      0x58e zephyr/arch/arch/arm/core/libarch__arm__core.a(fatal.c.obj)
     .debug_info    0x0000b56a       0xb6 zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi.c.obj)
     .debug_info    0x0000b620       0x23 zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi_on_reset.S.obj)
     .debug_info    0x0000b643      0x739 zephyr/arch/arch/arm/core/libarch__arm__core.a(tls.c.obj)
     .debug_info    0x0000bd7c     0x13c8 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .debug_info    0x0000d144       0x23 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault_s.S.obj)
     .debug_info    0x0000d167       0x23 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(reset.S.obj)
     .debug_info    0x0000d18a      0x94b zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
     .debug_info    0x0000dad5       0x23 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(svc.S.obj)
     .debug_info    0x0000daf8      0x9af zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
     .debug_info    0x0000e4a7      0x424 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(prep_c.c.obj)
     .debug_info    0x0000e8cb      0xbfb zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
     .debug_info    0x0000f4c6      0x4b7 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(cpu_idle.c.obj)
     .debug_info    0x0000f97d      0x7de zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(exc_exit.c.obj)
     .debug_info    0x0001015b      0x883 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread_abort.c.obj)
     .debug_info    0x000109de       0x23 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(swap_helper.S.obj)
     .debug_info    0x00010a01      0x5b3 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_init.c.obj)
     .debug_info    0x00010fb4      0x1ab zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(isr_wrapper.c.obj)
     .debug_info    0x0001115f       0x23 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(__aeabi_read_tp.S.obj)
     .debug_info    0x00011182      0x788 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_core_mpu.c.obj)
     .debug_info    0x0001190a     0x1356 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .debug_info    0x00012c60      0x1cc zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu_regions.c.obj)
     .debug_info    0x00012e2c      0xecd zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .debug_info    0x00013cf9     0x343e zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .debug_info    0x00017137     0x2f61 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .debug_info    0x0001a098      0x916 zephyr/soc/soc/nrf52833/libsoc__nordic.a(soc.c.obj)
     .debug_info    0x0001a9ae      0x319 zephyr/soc/soc/nrf52833/libsoc__nordic.a(reboot.c.obj)
     .debug_info    0x0001acc7      0x2ae zephyr/soc/soc/nrf52833/libsoc__nordic.a(gppi_init.c.obj)
     .debug_info    0x0001af75      0x512 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gpiote_nrfx.c.obj)
     .debug_info    0x0001b487     0x1641 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .debug_info    0x0001cac8     0x38b3 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .debug_info    0x0002037b     0x1e3e zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .debug_info    0x000221b9     0x2d4a zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .debug_info    0x00024f03      0x1b0 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(common.c.obj)
     .debug_info    0x000250b3      0xdca zephyr/drivers/pinctrl/libdrivers__pinctrl.a(pinctrl_nrf.c.obj)
     .debug_info    0x00025e7d     0x303c zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .debug_info    0x00028eb9     0x33f9 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .debug_info    0x0002c2b2      0x77d modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a(multithreading_lock.c.obj)
     .debug_info    0x0002ca2f      0x333 modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a(fatal_error.c.obj)
     .debug_info    0x0002cd62     0x1cc3 modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
     .debug_info    0x0002ea25     0x2e25 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .debug_info    0x0003184a     0x6131 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
     .debug_info    0x0003797b      0x169 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal_wrappers.c.obj)
     .debug_info    0x00037ae4     0x1459 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .debug_info    0x00038f3d      0x20f modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a(mpsl_fem_api_init.c.obj)
     .debug_info    0x0003914c      0x617 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
     .debug_info    0x00039763     0x142d modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(system_nrf52833.c.obj)
     .debug_info    0x0003ab90      0x1c6 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj)
     .debug_info    0x0003ad56      0x286 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_flag32_allocator.c.obj)
     .debug_info    0x0003afdc     0x1c6e modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .debug_info    0x0003cc4a     0x7501 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .debug_info    0x0004414b       0xe9 zephyr/kernel/libkernel.a(busy_wait.c.obj)
     .debug_info    0x00044234      0x4e5 zephyr/kernel/libkernel.a(device.c.obj)
     .debug_info    0x00044719      0xd1b zephyr/kernel/libkernel.a(fatal.c.obj)
     .debug_info    0x00045434     0x1ff3 zephyr/kernel/libkernel.a(init.c.obj)
     .debug_info    0x00047427     0x1db1 zephyr/kernel/libkernel.a(kheap.c.obj)
     .debug_info    0x000491d8      0x991 zephyr/kernel/libkernel.a(idle.c.obj)
     .debug_info    0x00049b69     0x1dba zephyr/kernel/libkernel.a(mutex.c.obj)
     .debug_info    0x0004b923     0x3a1b zephyr/kernel/libkernel.a(queue.c.obj)
     .debug_info    0x0004f33e     0x1b9b zephyr/kernel/libkernel.a(sem.c.obj)
     .debug_info    0x00050ed9     0x8172 zephyr/kernel/libkernel.a(work.c.obj)
     .debug_info    0x0005904b     0x1864 zephyr/kernel/libkernel.a(thread.c.obj)
     .debug_info    0x0005a8af     0xa8c4 zephyr/kernel/libkernel.a(sched.c.obj)
     .debug_info    0x00065173     0x1251 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .debug_info    0x000663c4      0x6e9 zephyr/kernel/libkernel.a(spinlock_validate.c.obj)
     .debug_info    0x00066aad     0x27a9 zephyr/kernel/libkernel.a(timeout.c.obj)
     .debug_info    0x00069256      0xeab zephyr/kernel/libkernel.a(mempool.c.obj)
     .debug_info    0x0006a101       0x93 zephyr/kernel/libkernel.a(banner.c.obj)
     .debug_info    0x0006a194      0x92b zephyr/kernel/libkernel.a(system_work_q.c.obj)
    .debug_abbrev   0x00000000     0xfbd7
     *(SORT_BY_ALIGNMENT(.debug_abbrev))
     .debug_abbrev  0x00000000      0x12e zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
     .debug_abbrev  0x0000012e       0x62 zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj
     .debug_abbrev  0x00000190      0x357 app/libapp.a(dtm_twowire_transport.c.obj)
     .debug_abbrev  0x000004e7      0x32f app/libapp.a(main.c.obj)
     .debug_abbrev  0x00000816      0x4e9 zephyr/libzephyr.a(heap.c.obj)
     .debug_abbrev  0x00000cff      0x2f1 zephyr/libzephyr.a(printk.c.obj)
     .debug_abbrev  0x00000ff0      0x303 zephyr/libzephyr.a(thread_entry.c.obj)
     .debug_abbrev  0x000012f3      0x1ca zephyr/libzephyr.a(assert.c.obj)
     .debug_abbrev  0x000014bd      0x53d zephyr/libzephyr.a(onoff.c.obj)
     .debug_abbrev  0x000019fa      0x207 zephyr/libzephyr.a(notify.c.obj)
     .debug_abbrev  0x00001c01       0x46 zephyr/libzephyr.a(last_section_id.c.obj)
     .debug_abbrev  0x00001c47       0x2e zephyr/libzephyr.a(configs.c.obj)
     .debug_abbrev  0x00001c75      0x1c2 zephyr/libzephyr.a(mem_attr.c.obj)
     .debug_abbrev  0x00001e37      0x19b zephyr/libzephyr.a(banner.c.obj)
     .debug_abbrev  0x00001fd2       0xf3 zephyr/arch/common/libarch__common.a(init.c.obj)
     .debug_abbrev  0x000020c5       0xd1 zephyr/arch/common/libarch__common.a(xip.c.obj)
     .debug_abbrev  0x00002196      0x20e zephyr/arch/arch/arm/core/libarch__arm__core.a(fatal.c.obj)
     .debug_abbrev  0x000023a4       0x70 zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi.c.obj)
     .debug_abbrev  0x00002414       0x14 zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi_on_reset.S.obj)
     .debug_abbrev  0x00002428      0x294 zephyr/arch/arch/arm/core/libarch__arm__core.a(tls.c.obj)
     .debug_abbrev  0x000026bc      0x451 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .debug_abbrev  0x00002b0d       0x14 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault_s.S.obj)
     .debug_abbrev  0x00002b21       0x14 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(reset.S.obj)
     .debug_abbrev  0x00002b35      0x2ec zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
     .debug_abbrev  0x00002e21       0x14 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(svc.S.obj)
     .debug_abbrev  0x00002e35      0x290 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
     .debug_abbrev  0x000030c5      0x186 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(prep_c.c.obj)
     .debug_abbrev  0x0000324b      0x3fc zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
     .debug_abbrev  0x00003647      0x191 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(cpu_idle.c.obj)
     .debug_abbrev  0x000037d8      0x1a5 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(exc_exit.c.obj)
     .debug_abbrev  0x0000397d      0x24d zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread_abort.c.obj)
     .debug_abbrev  0x00003bca       0x14 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(swap_helper.S.obj)
     .debug_abbrev  0x00003bde      0x159 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_init.c.obj)
     .debug_abbrev  0x00003d37      0x13d zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(isr_wrapper.c.obj)
     .debug_abbrev  0x00003e74       0x14 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(__aeabi_read_tp.S.obj)
     .debug_abbrev  0x00003e88      0x255 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_core_mpu.c.obj)
     .debug_abbrev  0x000040dd      0x472 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .debug_abbrev  0x0000454f       0xca zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu_regions.c.obj)
     .debug_abbrev  0x00004619      0x4b0 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .debug_abbrev  0x00004ac9      0x721 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .debug_abbrev  0x000051ea      0x435 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .debug_abbrev  0x0000561f      0x2b0 zephyr/soc/soc/nrf52833/libsoc__nordic.a(soc.c.obj)
     .debug_abbrev  0x000058cf      0x128 zephyr/soc/soc/nrf52833/libsoc__nordic.a(reboot.c.obj)
     .debug_abbrev  0x000059f7      0x194 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gppi_init.c.obj)
     .debug_abbrev  0x00005b8b      0x14c zephyr/soc/soc/nrf52833/libsoc__nordic.a(gpiote_nrfx.c.obj)
     .debug_abbrev  0x00005cd7      0x57b zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .debug_abbrev  0x00006252      0x738 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .debug_abbrev  0x0000698a      0x5d4 zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .debug_abbrev  0x00006f5e      0x612 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .debug_abbrev  0x00007570       0xdf zephyr/drivers/pinctrl/libdrivers__pinctrl.a(common.c.obj)
     .debug_abbrev  0x0000764f      0x305 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(pinctrl_nrf.c.obj)
     .debug_abbrev  0x00007954      0x565 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .debug_abbrev  0x00007eb9      0x649 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .debug_abbrev  0x00008502      0x281 modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a(multithreading_lock.c.obj)
     .debug_abbrev  0x00008783      0x151 modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a(fatal_error.c.obj)
     .debug_abbrev  0x000088d4      0x43b modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
     .debug_abbrev  0x00008d0f      0x6f2 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .debug_abbrev  0x00009401      0x50f modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
     .debug_abbrev  0x00009910       0xf4 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal_wrappers.c.obj)
     .debug_abbrev  0x00009a04      0x593 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .debug_abbrev  0x00009f97      0x148 modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a(mpsl_fem_api_init.c.obj)
     .debug_abbrev  0x0000a0df      0x2c2 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
     .debug_abbrev  0x0000a3a1      0x2d0 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(system_nrf52833.c.obj)
     .debug_abbrev  0x0000a671      0x133 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj)
     .debug_abbrev  0x0000a7a4       0xef modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_flag32_allocator.c.obj)
     .debug_abbrev  0x0000a893      0x4a2 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .debug_abbrev  0x0000ad35      0x5c2 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .debug_abbrev  0x0000b2f7       0x9d zephyr/kernel/libkernel.a(busy_wait.c.obj)
     .debug_abbrev  0x0000b394      0x1f0 zephyr/kernel/libkernel.a(device.c.obj)
     .debug_abbrev  0x0000b584      0x3e1 zephyr/kernel/libkernel.a(fatal.c.obj)
     .debug_abbrev  0x0000b965      0x6c1 zephyr/kernel/libkernel.a(init.c.obj)
     .debug_abbrev  0x0000c026      0x4d7 zephyr/kernel/libkernel.a(kheap.c.obj)
     .debug_abbrev  0x0000c4fd      0x314 zephyr/kernel/libkernel.a(idle.c.obj)
     .debug_abbrev  0x0000c811      0x4af zephyr/kernel/libkernel.a(mutex.c.obj)
     .debug_abbrev  0x0000ccc0      0x58e zephyr/kernel/libkernel.a(queue.c.obj)
     .debug_abbrev  0x0000d24e      0x4b2 zephyr/kernel/libkernel.a(sem.c.obj)
     .debug_abbrev  0x0000d700      0x677 zephyr/kernel/libkernel.a(work.c.obj)
     .debug_abbrev  0x0000dd77      0x567 zephyr/kernel/libkernel.a(thread.c.obj)
     .debug_abbrev  0x0000e2de      0x688 zephyr/kernel/libkernel.a(sched.c.obj)
     .debug_abbrev  0x0000e966      0x470 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .debug_abbrev  0x0000edd6      0x227 zephyr/kernel/libkernel.a(spinlock_validate.c.obj)
     .debug_abbrev  0x0000effd      0x557 zephyr/kernel/libkernel.a(timeout.c.obj)
     .debug_abbrev  0x0000f554      0x404 zephyr/kernel/libkernel.a(mempool.c.obj)
     .debug_abbrev  0x0000f958       0x44 zephyr/kernel/libkernel.a(banner.c.obj)
     .debug_abbrev  0x0000f99c      0x23b zephyr/kernel/libkernel.a(system_work_q.c.obj)
    .debug_line     0x00000000    0x2f861
     *(SORT_BY_ALIGNMENT(.debug_line) SORT_BY_ALIGNMENT(.debug_line.*) SORT_BY_ALIGNMENT(.debug_line_end))
     .debug_line    0x00000000      0x196 zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
     .debug_line    0x00000196      0x10b zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj
     .debug_line    0x000002a1      0x60f app/libapp.a(dtm_twowire_transport.c.obj)
     .debug_line    0x000008b0      0x4b9 app/libapp.a(main.c.obj)
     .debug_line    0x00000d69     0x1a75 zephyr/libzephyr.a(heap.c.obj)
     .debug_line    0x000027de      0x42b zephyr/libzephyr.a(printk.c.obj)
     .debug_line    0x00002c09      0x425 zephyr/libzephyr.a(thread_entry.c.obj)
     .debug_line    0x0000302e      0x37a zephyr/libzephyr.a(assert.c.obj)
     .debug_line    0x000033a8     0x1ab6 zephyr/libzephyr.a(onoff.c.obj)
     .debug_line    0x00004e5e      0x2bd zephyr/libzephyr.a(notify.c.obj)
     .debug_line    0x0000511b      0x146 zephyr/libzephyr.a(last_section_id.c.obj)
     .debug_line    0x00005261      0x2cc zephyr/libzephyr.a(configs.c.obj)
     .debug_line    0x0000552d      0x315 zephyr/libzephyr.a(mem_attr.c.obj)
     .debug_line    0x00005842      0x1ef zephyr/libzephyr.a(banner.c.obj)
     .debug_line    0x00005a31      0x1cd zephyr/arch/common/libarch__common.a(init.c.obj)
     .debug_line    0x00005bfe      0x167 zephyr/arch/common/libarch__common.a(xip.c.obj)
     .debug_line    0x00005d65      0x37a zephyr/arch/arch/arm/core/libarch__arm__core.a(fatal.c.obj)
     .debug_line    0x000060df       0x9f zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi.c.obj)
     .debug_line    0x0000617e       0x61 zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi_on_reset.S.obj)
     .debug_line    0x000061df      0x445 zephyr/arch/arch/arm/core/libarch__arm__core.a(tls.c.obj)
     .debug_line    0x00006624      0xadd zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .debug_line    0x00007101       0x6e zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault_s.S.obj)
     .debug_line    0x0000716f       0x89 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(reset.S.obj)
     .debug_line    0x000071f8      0x7f4 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
     .debug_line    0x000079ec       0x73 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(svc.S.obj)
     .debug_line    0x00007a5f      0x427 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
     .debug_line    0x00007e86      0x32f zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(prep_c.c.obj)
     .debug_line    0x000081b5      0x695 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
     .debug_line    0x0000884a      0x3b2 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(cpu_idle.c.obj)
     .debug_line    0x00008bfc      0x342 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(exc_exit.c.obj)
     .debug_line    0x00008f3e      0x43b zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread_abort.c.obj)
     .debug_line    0x00009379       0xa4 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(swap_helper.S.obj)
     .debug_line    0x0000941d      0x262 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_init.c.obj)
     .debug_line    0x0000967f      0x273 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(isr_wrapper.c.obj)
     .debug_line    0x000098f2       0x6f zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(__aeabi_read_tp.S.obj)
     .debug_line    0x00009961      0x443 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_core_mpu.c.obj)
     .debug_line    0x00009da4      0xd23 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .debug_line    0x0000aac7      0x24a zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu_regions.c.obj)
     .debug_line    0x0000ad11      0x71c zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .debug_line    0x0000b42d     0x180d zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .debug_line    0x0000cc3a     0x12ce zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .debug_line    0x0000df08      0x31f zephyr/soc/soc/nrf52833/libsoc__nordic.a(soc.c.obj)
     .debug_line    0x0000e227      0x1fa zephyr/soc/soc/nrf52833/libsoc__nordic.a(reboot.c.obj)
     .debug_line    0x0000e421      0x23b zephyr/soc/soc/nrf52833/libsoc__nordic.a(gppi_init.c.obj)
     .debug_line    0x0000e65c      0x2a4 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gpiote_nrfx.c.obj)
     .debug_line    0x0000e900      0x772 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .debug_line    0x0000f072     0x160d zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .debug_line    0x0001067f      0xd41 zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .debug_line    0x000113c0      0xfb3 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .debug_line    0x00012373      0x1f0 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(common.c.obj)
     .debug_line    0x00012563      0x535 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(pinctrl_nrf.c.obj)
     .debug_line    0x00012a98     0x12ad zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .debug_line    0x00013d45     0x1527 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .debug_line    0x0001526c      0x3ac modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a(multithreading_lock.c.obj)
     .debug_line    0x00015618      0x1f9 modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a(fatal_error.c.obj)
     .debug_line    0x00015811      0xb15 modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
     .debug_line    0x00016326      0xf45 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .debug_line    0x0001726b      0xd04 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
     .debug_line    0x00017f6f      0x1ea modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal_wrappers.c.obj)
     .debug_line    0x00018159      0x884 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .debug_line    0x000189dd      0x1e5 modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a(mpsl_fem_api_init.c.obj)
     .debug_line    0x00018bc2      0x408 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
     .debug_line    0x00018fca      0x5dc modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(system_nrf52833.c.obj)
     .debug_line    0x000195a6      0x2ac modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj)
     .debug_line    0x00019852      0x2af modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_flag32_allocator.c.obj)
     .debug_line    0x00019b01      0xbc9 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .debug_line    0x0001a6ca     0x2dbe modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .debug_line    0x0001d488      0x1a0 zephyr/kernel/libkernel.a(busy_wait.c.obj)
     .debug_line    0x0001d628      0x48b zephyr/kernel/libkernel.a(device.c.obj)
     .debug_line    0x0001dab3      0x6a3 zephyr/kernel/libkernel.a(fatal.c.obj)
     .debug_line    0x0001e156      0xcfe zephyr/kernel/libkernel.a(init.c.obj)
     .debug_line    0x0001ee54      0xe0b zephyr/kernel/libkernel.a(kheap.c.obj)
     .debug_line    0x0001fc5f      0x56c zephyr/kernel/libkernel.a(idle.c.obj)
     .debug_line    0x000201cb      0xdde zephyr/kernel/libkernel.a(mutex.c.obj)
     .debug_line    0x00020fa9     0x199e zephyr/kernel/libkernel.a(queue.c.obj)
     .debug_line    0x00022947      0xdb1 zephyr/kernel/libkernel.a(sem.c.obj)
     .debug_line    0x000236f8     0x379c zephyr/kernel/libkernel.a(work.c.obj)
     .debug_line    0x00026e94      0xc40 zephyr/kernel/libkernel.a(thread.c.obj)
     .debug_line    0x00027ad4     0x5136 zephyr/kernel/libkernel.a(sched.c.obj)
     .debug_line    0x0002cc0a      0x876 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .debug_line    0x0002d480      0x41f zephyr/kernel/libkernel.a(spinlock_validate.c.obj)
     .debug_line    0x0002d89f     0x15d0 zephyr/kernel/libkernel.a(timeout.c.obj)
     .debug_line    0x0002ee6f      0x638 zephyr/kernel/libkernel.a(mempool.c.obj)
     .debug_line    0x0002f4a7       0x57 zephyr/kernel/libkernel.a(banner.c.obj)
     .debug_line    0x0002f4fe      0x363 zephyr/kernel/libkernel.a(system_work_q.c.obj)
    .debug_frame    0x00000000     0x423c
     *(SORT_BY_ALIGNMENT(.debug_frame))
     .debug_frame   0x00000000       0x20 zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj
     .debug_frame   0x00000020       0x7c app/libapp.a(dtm_twowire_transport.c.obj)
     .debug_frame   0x0000009c       0x34 app/libapp.a(main.c.obj)
     .debug_frame   0x000000d0      0x258 zephyr/libzephyr.a(heap.c.obj)
     .debug_frame   0x00000328       0xbc zephyr/libzephyr.a(printk.c.obj)
     .debug_frame   0x000003e4       0x2c zephyr/libzephyr.a(thread_entry.c.obj)
     .debug_frame   0x00000410       0x50 zephyr/libzephyr.a(assert.c.obj)
     .debug_frame   0x00000460      0x1e4 zephyr/libzephyr.a(onoff.c.obj)
     .debug_frame   0x00000644       0x38 zephyr/libzephyr.a(notify.c.obj)
     .debug_frame   0x0000067c       0x20 zephyr/libzephyr.a(configs.c.obj)
     .debug_frame   0x0000069c       0x40 zephyr/libzephyr.a(mem_attr.c.obj)
     .debug_frame   0x000006dc       0x28 zephyr/libzephyr.a(banner.c.obj)
     .debug_frame   0x00000704       0x48 zephyr/arch/common/libarch__common.a(init.c.obj)
     .debug_frame   0x0000074c       0x2c zephyr/arch/common/libarch__common.a(xip.c.obj)
     .debug_frame   0x00000778       0x44 zephyr/arch/arch/arm/core/libarch__arm__core.a(fatal.c.obj)
     .debug_frame   0x000007bc       0x2c zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi.c.obj)
     .debug_frame   0x000007e8       0x30 zephyr/arch/arch/arm/core/libarch__arm__core.a(tls.c.obj)
     .debug_frame   0x00000818       0xa0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .debug_frame   0x000008b8       0x78 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
     .debug_frame   0x00000930       0x6c zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
     .debug_frame   0x0000099c       0x38 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(prep_c.c.obj)
     .debug_frame   0x000009d4       0x78 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
     .debug_frame   0x00000a4c       0x40 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(cpu_idle.c.obj)
     .debug_frame   0x00000a8c       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(exc_exit.c.obj)
     .debug_frame   0x00000aac       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread_abort.c.obj)
     .debug_frame   0x00000acc       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_init.c.obj)
     .debug_frame   0x00000aec       0x2c zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(isr_wrapper.c.obj)
     .debug_frame   0x00000b18       0x30 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_core_mpu.c.obj)
     .debug_frame   0x00000b48      0x10c zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .debug_frame   0x00000c54       0xf8 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .debug_frame   0x00000d4c      0x2d8 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .debug_frame   0x00001024      0x6a8 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .debug_frame   0x000016cc       0x30 zephyr/soc/soc/nrf52833/libsoc__nordic.a(soc.c.obj)
     .debug_frame   0x000016fc       0x20 zephyr/soc/soc/nrf52833/libsoc__nordic.a(reboot.c.obj)
     .debug_frame   0x0000171c       0x28 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gppi_init.c.obj)
     .debug_frame   0x00001744       0xf4 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .debug_frame   0x00001838      0x23c zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .debug_frame   0x00001a74       0xbc zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .debug_frame   0x00001b30      0x140 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .debug_frame   0x00001c70       0x2c zephyr/drivers/pinctrl/libdrivers__pinctrl.a(common.c.obj)
     .debug_frame   0x00001c9c       0x58 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(pinctrl_nrf.c.obj)
     .debug_frame   0x00001cf4       0xdc zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .debug_frame   0x00001dd0      0x230 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .debug_frame   0x00002000       0x30 modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a(multithreading_lock.c.obj)
     .debug_frame   0x00002030       0x28 modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a(fatal_error.c.obj)
     .debug_frame   0x00002058       0x60 modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
     .debug_frame   0x000020b8      0x130 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .debug_frame   0x000021e8       0x8c modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
     .debug_frame   0x00002274       0x28 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal_wrappers.c.obj)
     .debug_frame   0x0000229c      0x114 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .debug_frame   0x000023b0       0x28 modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a(mpsl_fem_api_init.c.obj)
     .debug_frame   0x000023d8       0xd8 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
     .debug_frame   0x000024b0       0x58 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(system_nrf52833.c.obj)
     .debug_frame   0x00002508       0x40 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj)
     .debug_frame   0x00002548       0x50 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_flag32_allocator.c.obj)
     .debug_frame   0x00002598      0x280 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .debug_frame   0x00002818      0x5e8 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .debug_frame   0x00002e00       0x20 zephyr/kernel/libkernel.a(busy_wait.c.obj)
     .debug_frame   0x00002e20       0x88 zephyr/kernel/libkernel.a(device.c.obj)
     .debug_frame   0x00002ea8       0x74 zephyr/kernel/libkernel.a(fatal.c.obj)
     .debug_frame   0x00002f1c       0xb4 zephyr/kernel/libkernel.a(init.c.obj)
     .debug_frame   0x00002fd0      0x15c zephyr/kernel/libkernel.a(kheap.c.obj)
     .debug_frame   0x0000312c       0x40 zephyr/kernel/libkernel.a(idle.c.obj)
     .debug_frame   0x0000316c       0x78 zephyr/kernel/libkernel.a(mutex.c.obj)
     .debug_frame   0x000031e4      0x1d4 zephyr/kernel/libkernel.a(queue.c.obj)
     .debug_frame   0x000033b8       0xb0 zephyr/kernel/libkernel.a(sem.c.obj)
     .debug_frame   0x00003468      0x3b8 zephyr/kernel/libkernel.a(work.c.obj)
     .debug_frame   0x00003820      0x158 zephyr/kernel/libkernel.a(thread.c.obj)
     .debug_frame   0x00003978      0x52c zephyr/kernel/libkernel.a(sched.c.obj)
     .debug_frame   0x00003ea4       0x98 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .debug_frame   0x00003f3c       0x40 zephyr/kernel/libkernel.a(spinlock_validate.c.obj)
     .debug_frame   0x00003f7c      0x200 zephyr/kernel/libkernel.a(timeout.c.obj)
     .debug_frame   0x0000417c       0x78 zephyr/kernel/libkernel.a(mempool.c.obj)
     .debug_frame   0x000041f4       0x20 zephyr/kernel/libkernel.a(banner.c.obj)
     .debug_frame   0x00004214       0x28 zephyr/kernel/libkernel.a(system_work_q.c.obj)
    .debug_str      0x00000000    0x174b3
     *(SORT_BY_ALIGNMENT(.debug_str))
     .debug_str     0x00000000    0x174b3 zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
                                    0x381 (size before relaxing)
     .debug_str     0x000174b3      0x39c zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj
     .debug_str     0x000174b3      0x6a4 app/libapp.a(dtm_twowire_transport.c.obj)
     .debug_str     0x000174b3      0x8fb app/libapp.a(main.c.obj)
     .debug_str     0x000174b3      0x9b3 zephyr/libzephyr.a(heap.c.obj)
     .debug_str     0x000174b3      0x620 zephyr/libzephyr.a(printk.c.obj)
     .debug_str     0x000174b3      0x803 zephyr/libzephyr.a(thread_entry.c.obj)
     .debug_str     0x000174b3      0x39f zephyr/libzephyr.a(assert.c.obj)
     .debug_str     0x000174b3      0x8cc zephyr/libzephyr.a(onoff.c.obj)
     .debug_str     0x000174b3      0x391 zephyr/libzephyr.a(notify.c.obj)
     .debug_str     0x000174b3      0x29d zephyr/libzephyr.a(last_section_id.c.obj)
     .debug_str     0x000174b3      0x217 zephyr/libzephyr.a(configs.c.obj)
     .debug_str     0x000174b3      0x5b7 zephyr/libzephyr.a(mem_attr.c.obj)
     .debug_str     0x000174b3      0x56a zephyr/libzephyr.a(banner.c.obj)
     .debug_str     0x000174b3      0x2eb zephyr/arch/common/libarch__common.a(init.c.obj)
     .debug_str     0x000174b3      0x323 zephyr/arch/common/libarch__common.a(xip.c.obj)
     .debug_str     0x000174b3      0x47a zephyr/arch/arch/arm/core/libarch__arm__core.a(fatal.c.obj)
     .debug_str     0x000174b3      0x2ad zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi.c.obj)
     .debug_str     0x000174b3       0x64 zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi_on_reset.S.obj)
     .debug_str     0x000174b3      0x7a5 zephyr/arch/arch/arm/core/libarch__arm__core.a(tls.c.obj)
     .debug_str     0x000174b3      0xe04 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .debug_str     0x000174b3       0x68 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault_s.S.obj)
     .debug_str     0x000174b3       0x66 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(reset.S.obj)
     .debug_str     0x000174b3      0x585 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
     .debug_str     0x000174b3       0x64 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(svc.S.obj)
     .debug_str     0x000174b3      0x7f8 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
     .debug_str     0x000174b3      0x44f zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(prep_c.c.obj)
     .debug_str     0x000174b3      0x771 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
     .debug_str     0x000174b3      0x3c9 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(cpu_idle.c.obj)
     .debug_str     0x000174b3      0x5f0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(exc_exit.c.obj)
     .debug_str     0x000174b3      0x63a zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread_abort.c.obj)
     .debug_str     0x000174b3       0x6c zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(swap_helper.S.obj)
     .debug_str     0x000174b3      0x69c zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_init.c.obj)
     .debug_str     0x000174b3      0x319 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(isr_wrapper.c.obj)
     .debug_str     0x000174b3       0x70 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(__aeabi_read_tp.S.obj)
     .debug_str     0x000174b3      0x6ed zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_core_mpu.c.obj)
     .debug_str     0x000174b3      0x948 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .debug_str     0x000174b3      0x3c7 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu_regions.c.obj)
     .debug_str     0x000174b3      0x83e zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .debug_str     0x000174b3      0xe31 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .debug_str     0x000174b3      0xac6 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .debug_str     0x000174b3      0x6b5 zephyr/soc/soc/nrf52833/libsoc__nordic.a(soc.c.obj)
     .debug_str     0x000174b3      0x36c zephyr/soc/soc/nrf52833/libsoc__nordic.a(reboot.c.obj)
     .debug_str     0x000174b3      0x3ff zephyr/soc/soc/nrf52833/libsoc__nordic.a(gppi_init.c.obj)
     .debug_str     0x000174b3      0x7e6 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gpiote_nrfx.c.obj)
     .debug_str     0x000174b3      0xb6c zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .debug_str     0x000174b3     0x1887 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .debug_str     0x000174b3      0xe7b zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .debug_str     0x000174b3     0x1715 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .debug_str     0x000174b3      0x338 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(common.c.obj)
     .debug_str     0x000174b3      0x96d zephyr/drivers/pinctrl/libdrivers__pinctrl.a(pinctrl_nrf.c.obj)
     .debug_str     0x000174b3     0x1725 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .debug_str     0x000174b3     0x1663 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .debug_str     0x000174b3      0x7e0 modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a(multithreading_lock.c.obj)
     .debug_str     0x000174b3      0x401 modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a(fatal_error.c.obj)
     .debug_str     0x000174b3     0x1371 modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
     .debug_str     0x000174b3     0x1a6d modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .debug_str     0x000174b3     0x976f modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
     .debug_str     0x000174b3      0x3c6 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal_wrappers.c.obj)
     .debug_str     0x000174b3      0xf7c modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .debug_str     0x000174b3      0x35d modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a(mpsl_fem_api_init.c.obj)
     .debug_str     0x000174b3      0x6bf modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
     .debug_str     0x000174b3      0x91d modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(system_nrf52833.c.obj)
     .debug_str     0x000174b3      0x326 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj)
     .debug_str     0x000174b3      0x36a modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_flag32_allocator.c.obj)
     .debug_str     0x000174b3      0xd6d modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .debug_str     0x000174b3     0x230a modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .debug_str     0x000174b3      0x2c6 zephyr/kernel/libkernel.a(busy_wait.c.obj)
     .debug_str     0x000174b3      0x405 zephyr/kernel/libkernel.a(device.c.obj)
     .debug_str     0x000174b3      0x80e zephyr/kernel/libkernel.a(fatal.c.obj)
     .debug_str     0x000174b3     0x115a zephyr/kernel/libkernel.a(init.c.obj)
     .debug_str     0x000174b3      0x9b9 zephyr/kernel/libkernel.a(kheap.c.obj)
     .debug_str     0x000174b3      0x685 zephyr/kernel/libkernel.a(idle.c.obj)
     .debug_str     0x000174b3      0xab5 zephyr/kernel/libkernel.a(mutex.c.obj)
     .debug_str     0x000174b3      0xd4e zephyr/kernel/libkernel.a(queue.c.obj)
     .debug_str     0x000174b3      0xa57 zephyr/kernel/libkernel.a(sem.c.obj)
     .debug_str     0x000174b3     0x123c zephyr/kernel/libkernel.a(work.c.obj)
     .debug_str     0x000174b3      0xbca zephyr/kernel/libkernel.a(thread.c.obj)
     .debug_str     0x000174b3     0x1495 zephyr/kernel/libkernel.a(sched.c.obj)
     .debug_str     0x000174b3      0xab4 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .debug_str     0x000174b3      0x5af zephyr/kernel/libkernel.a(spinlock_validate.c.obj)
     .debug_str     0x000174b3      0x9cf zephyr/kernel/libkernel.a(timeout.c.obj)
     .debug_str     0x000174b3      0x782 zephyr/kernel/libkernel.a(mempool.c.obj)
     .debug_str     0x000174b3      0x28c zephyr/kernel/libkernel.a(banner.c.obj)
     .debug_str     0x000174b3      0x88b zephyr/kernel/libkernel.a(system_work_q.c.obj)
    .debug_loc      0x00000000    0x3685b
     *(SORT_BY_ALIGNMENT(.debug_loc))
     .debug_loc     0x00000000      0x2db app/libapp.a(dtm_twowire_transport.c.obj)
     .debug_loc     0x000002db      0x17a app/libapp.a(main.c.obj)
     .debug_loc     0x00000455     0x4ca5 zephyr/libzephyr.a(heap.c.obj)
     .debug_loc     0x000050fa      0x17b zephyr/libzephyr.a(printk.c.obj)
     .debug_loc     0x00005275       0x9d zephyr/libzephyr.a(thread_entry.c.obj)
     .debug_loc     0x00005312       0x57 zephyr/libzephyr.a(assert.c.obj)
     .debug_loc     0x00005369     0x29e9 zephyr/libzephyr.a(onoff.c.obj)
     .debug_loc     0x00007d52      0x20f zephyr/libzephyr.a(notify.c.obj)
     .debug_loc     0x00007f61       0xc6 zephyr/libzephyr.a(mem_attr.c.obj)
     .debug_loc     0x00008027      0x102 zephyr/arch/common/libarch__common.a(init.c.obj)
     .debug_loc     0x00008129      0x196 zephyr/arch/arch/arm/core/libarch__arm__core.a(fatal.c.obj)
     .debug_loc     0x000082bf       0x8b zephyr/arch/arch/arm/core/libarch__arm__core.a(tls.c.obj)
     .debug_loc     0x0000834a      0xad0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .debug_loc     0x00008e1a      0x26e zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
     .debug_loc     0x00009088      0x217 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
     .debug_loc     0x0000929f      0x268 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
     .debug_loc     0x00009507       0x56 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(cpu_idle.c.obj)
     .debug_loc     0x0000955d       0x40 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread_abort.c.obj)
     .debug_loc     0x0000959d       0x6a zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_init.c.obj)
     .debug_loc     0x00009607       0x3f zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(isr_wrapper.c.obj)
     .debug_loc     0x00009646       0x89 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_core_mpu.c.obj)
     .debug_loc     0x000096cf      0x956 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .debug_loc     0x0000a025      0x528 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .debug_loc     0x0000a54d     0x2051 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .debug_loc     0x0000c59e     0x21a1 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .debug_loc     0x0000e73f      0x12d zephyr/soc/soc/nrf52833/libsoc__nordic.a(soc.c.obj)
     .debug_loc     0x0000e86c      0x63d zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .debug_loc     0x0000eea9     0x1cad zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .debug_loc     0x00010b56      0xee1 zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .debug_loc     0x00011a37     0x19bb zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .debug_loc     0x000133f2       0x4e zephyr/drivers/pinctrl/libdrivers__pinctrl.a(common.c.obj)
     .debug_loc     0x00013440      0x613 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(pinctrl_nrf.c.obj)
     .debug_loc     0x00013a53     0x177c zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .debug_loc     0x000151cf     0x188f zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .debug_loc     0x00016a5e       0x1a modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a(multithreading_lock.c.obj)
     .debug_loc     0x00016a78       0x56 modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a(fatal_error.c.obj)
     .debug_loc     0x00016ace     0x2452 modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
     .debug_loc     0x00018f20      0xc82 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .debug_loc     0x00019ba2     0x2514 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
     .debug_loc     0x0001c0b6       0x38 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal_wrappers.c.obj)
     .debug_loc     0x0001c0ee      0x155 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .debug_loc     0x0001c243      0x17c modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
     .debug_loc     0x0001c3bf      0x113 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(system_nrf52833.c.obj)
     .debug_loc     0x0001c4d2      0x223 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj)
     .debug_loc     0x0001c6f5      0x1fe modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_flag32_allocator.c.obj)
     .debug_loc     0x0001c8f3     0x1249 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .debug_loc     0x0001db3c     0x5a66 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .debug_loc     0x000235a2       0x38 zephyr/kernel/libkernel.a(busy_wait.c.obj)
     .debug_loc     0x000235da      0x1f2 zephyr/kernel/libkernel.a(device.c.obj)
     .debug_loc     0x000237cc      0x1bf zephyr/kernel/libkernel.a(fatal.c.obj)
     .debug_loc     0x0002398b      0x7bd zephyr/kernel/libkernel.a(init.c.obj)
     .debug_loc     0x00024148      0xf72 zephyr/kernel/libkernel.a(kheap.c.obj)
     .debug_loc     0x000250ba      0x14f zephyr/kernel/libkernel.a(idle.c.obj)
     .debug_loc     0x00025209      0xb96 zephyr/kernel/libkernel.a(mutex.c.obj)
     .debug_loc     0x00025d9f     0x21ba zephyr/kernel/libkernel.a(queue.c.obj)
     .debug_loc     0x00027f59      0xb25 zephyr/kernel/libkernel.a(sem.c.obj)
     .debug_loc     0x00028a7e     0x539f zephyr/kernel/libkernel.a(work.c.obj)
     .debug_loc     0x0002de1d      0xca3 zephyr/kernel/libkernel.a(thread.c.obj)
     .debug_loc     0x0002eac0     0x5c9a zephyr/kernel/libkernel.a(sched.c.obj)
     .debug_loc     0x0003475a      0x3e8 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .debug_loc     0x00034b42       0xcc zephyr/kernel/libkernel.a(spinlock_validate.c.obj)
     .debug_loc     0x00034c0e     0x16ba zephyr/kernel/libkernel.a(timeout.c.obj)
     .debug_loc     0x000362c8      0x593 zephyr/kernel/libkernel.a(mempool.c.obj)
    .debug_macinfo
     *(SORT_BY_ALIGNMENT(.debug_macinfo))
    .debug_weaknames
     *(SORT_BY_ALIGNMENT(.debug_weaknames))
    .debug_funcnames
     *(SORT_BY_ALIGNMENT(.debug_funcnames))
    .debug_typenames
     *(SORT_BY_ALIGNMENT(.debug_typenames))
    .debug_varnames
     *(SORT_BY_ALIGNMENT(.debug_varnames))
    .debug_pubtypes
     *(SORT_BY_ALIGNMENT(.debug_pubtypes))
    .debug_ranges   0x00000000     0x7af0
     *(SORT_BY_ALIGNMENT(.debug_ranges))
     .debug_ranges  0x00000000       0x10 zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj
     .debug_ranges  0x00000010      0x110 app/libapp.a(dtm_twowire_transport.c.obj)
     .debug_ranges  0x00000120       0x48 app/libapp.a(main.c.obj)
     .debug_ranges  0x00000168      0x600 zephyr/libzephyr.a(heap.c.obj)
     .debug_ranges  0x00000768       0x58 zephyr/libzephyr.a(printk.c.obj)
     .debug_ranges  0x000007c0       0x10 zephyr/libzephyr.a(thread_entry.c.obj)
     .debug_ranges  0x000007d0       0x18 zephyr/libzephyr.a(assert.c.obj)
     .debug_ranges  0x000007e8      0x4b8 zephyr/libzephyr.a(onoff.c.obj)
     .debug_ranges  0x00000ca0       0x38 zephyr/libzephyr.a(notify.c.obj)
     .debug_ranges  0x00000cd8       0x10 zephyr/libzephyr.a(configs.c.obj)
     .debug_ranges  0x00000ce8       0x20 zephyr/libzephyr.a(mem_attr.c.obj)
     .debug_ranges  0x00000d08       0x10 zephyr/libzephyr.a(banner.c.obj)
     .debug_ranges  0x00000d18       0x20 zephyr/arch/common/libarch__common.a(init.c.obj)
     .debug_ranges  0x00000d38       0x10 zephyr/arch/common/libarch__common.a(xip.c.obj)
     .debug_ranges  0x00000d48       0x18 zephyr/arch/arch/arm/core/libarch__arm__core.a(fatal.c.obj)
     .debug_ranges  0x00000d60       0x10 zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi.c.obj)
     .debug_ranges  0x00000d70       0x48 zephyr/arch/arch/arm/core/libarch__arm__core.a(tls.c.obj)
     .debug_ranges  0x00000db8       0xf0 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .debug_ranges  0x00000ea8       0x60 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
     .debug_ranges  0x00000f08       0x30 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
     .debug_ranges  0x00000f38       0x18 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(prep_c.c.obj)
     .debug_ranges  0x00000f50       0x50 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
     .debug_ranges  0x00000fa0       0x20 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(cpu_idle.c.obj)
     .debug_ranges  0x00000fc0       0x10 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(exc_exit.c.obj)
     .debug_ranges  0x00000fd0       0x10 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread_abort.c.obj)
     .debug_ranges  0x00000fe0       0x38 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_init.c.obj)
     .debug_ranges  0x00001018       0x28 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(isr_wrapper.c.obj)
     .debug_ranges  0x00001040       0x18 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_core_mpu.c.obj)
     .debug_ranges  0x00001058      0x2a8 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .debug_ranges  0x00001300       0xb0 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .debug_ranges  0x000013b0      0x398 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .debug_ranges  0x00001748      0x4f0 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .debug_ranges  0x00001c38       0x30 zephyr/soc/soc/nrf52833/libsoc__nordic.a(soc.c.obj)
     .debug_ranges  0x00001c68       0x10 zephyr/soc/soc/nrf52833/libsoc__nordic.a(reboot.c.obj)
     .debug_ranges  0x00001c78       0x10 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gppi_init.c.obj)
     .debug_ranges  0x00001c88       0xd0 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .debug_ranges  0x00001d58      0x368 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .debug_ranges  0x000020c0      0x240 zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .debug_ranges  0x00002300      0x2b0 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .debug_ranges  0x000025b0       0x10 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(common.c.obj)
     .debug_ranges  0x000025c0       0xd0 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(pinctrl_nrf.c.obj)
     .debug_ranges  0x00002690      0x2a8 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .debug_ranges  0x00002938      0x3e8 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .debug_ranges  0x00002d20       0x30 modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a(multithreading_lock.c.obj)
     .debug_ranges  0x00002d50       0x10 modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a(fatal_error.c.obj)
     .debug_ranges  0x00002d60      0x150 modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
     .debug_ranges  0x00002eb0      0x1c0 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .debug_ranges  0x00003070      0x190 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
     .debug_ranges  0x00003200       0x10 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal_wrappers.c.obj)
     .debug_ranges  0x00003210       0xd0 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .debug_ranges  0x000032e0       0x10 modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a(mpsl_fem_api_init.c.obj)
     .debug_ranges  0x000032f0       0x58 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
     .debug_ranges  0x00003348       0x60 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(system_nrf52833.c.obj)
     .debug_ranges  0x000033a8       0x20 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj)
     .debug_ranges  0x000033c8       0x58 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_flag32_allocator.c.obj)
     .debug_ranges  0x00003420      0x1f8 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .debug_ranges  0x00003618      0x980 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .debug_ranges  0x00003f98       0x10 zephyr/kernel/libkernel.a(busy_wait.c.obj)
     .debug_ranges  0x00003fa8       0x70 zephyr/kernel/libkernel.a(device.c.obj)
     .debug_ranges  0x00004018       0x70 zephyr/kernel/libkernel.a(fatal.c.obj)
     .debug_ranges  0x00004088      0x1b0 zephyr/kernel/libkernel.a(init.c.obj)
     .debug_ranges  0x00004238      0x2c0 zephyr/kernel/libkernel.a(kheap.c.obj)
     .debug_ranges  0x000044f8       0x78 zephyr/kernel/libkernel.a(idle.c.obj)
     .debug_ranges  0x00004570      0x248 zephyr/kernel/libkernel.a(mutex.c.obj)
     .debug_ranges  0x000047b8      0x658 zephyr/kernel/libkernel.a(queue.c.obj)
     .debug_ranges  0x00004e10      0x200 zephyr/kernel/libkernel.a(sem.c.obj)
     .debug_ranges  0x00005010      0xb10 zephyr/kernel/libkernel.a(work.c.obj)
     .debug_ranges  0x00005b20      0x210 zephyr/kernel/libkernel.a(thread.c.obj)
     .debug_ranges  0x00005d30     0x1658 zephyr/kernel/libkernel.a(sched.c.obj)
     .debug_ranges  0x00007388      0x130 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .debug_ranges  0x000074b8       0x20 zephyr/kernel/libkernel.a(spinlock_validate.c.obj)
     .debug_ranges  0x000074d8      0x5c8 zephyr/kernel/libkernel.a(timeout.c.obj)
     .debug_ranges  0x00007aa0       0x30 zephyr/kernel/libkernel.a(mempool.c.obj)
     .debug_ranges  0x00007ad0       0x10 zephyr/kernel/libkernel.a(banner.c.obj)
     .debug_ranges  0x00007ae0       0x10 zephyr/kernel/libkernel.a(system_work_q.c.obj)
    .debug_addr
     *(SORT_BY_ALIGNMENT(.debug_addr))
    .debug_line_str
     *(SORT_BY_ALIGNMENT(.debug_line_str))
    .debug_loclists
     *(SORT_BY_ALIGNMENT(.debug_loclists))
    .debug_macro
     *(SORT_BY_ALIGNMENT(.debug_macro))
    .debug_names
     *(SORT_BY_ALIGNMENT(.debug_names))
    .debug_rnglists
     *(SORT_BY_ALIGNMENT(.debug_rnglists))
    .debug_str_offsets
     *(SORT_BY_ALIGNMENT(.debug_str_offsets))
    .debug_sup
     *(SORT_BY_ALIGNMENT(.debug_sup))
    /DISCARD/
     *(SORT_BY_ALIGNMENT(.note.GNU-stack))
    .ARM.attributes
                    0x00000000       0x32
     *(SORT_BY_ALIGNMENT(.ARM.attributes))
     .ARM.attributes
                    0x00000000       0x30 zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
     .ARM.attributes
                    0x00000030       0x30 zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
     .ARM.attributes
                    0x00000060       0x30 zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj
     .ARM.attributes
                    0x00000090       0x30 app/libapp.a(dtm_twowire_transport.c.obj)
     .ARM.attributes
                    0x000000c0       0x30 app/libapp.a(main.c.obj)
     .ARM.attributes
                    0x000000f0       0x30 zephyr/libzephyr.a(validate_libc.c.obj)
     .ARM.attributes
                    0x00000120       0x30 zephyr/libzephyr.a(heap.c.obj)
     .ARM.attributes
                    0x00000150       0x30 zephyr/libzephyr.a(cbprintf_packaged.c.obj)
     .ARM.attributes
                    0x00000180       0x30 zephyr/libzephyr.a(clock.c.obj)
     .ARM.attributes
                    0x000001b0       0x30 zephyr/libzephyr.a(printk.c.obj)
     .ARM.attributes
                    0x000001e0       0x30 zephyr/libzephyr.a(sem.c.obj)
     .ARM.attributes
                    0x00000210       0x30 zephyr/libzephyr.a(thread_entry.c.obj)
     .ARM.attributes
                    0x00000240       0x30 zephyr/libzephyr.a(cbprintf_complete.c.obj)
     .ARM.attributes
                    0x00000270       0x30 zephyr/libzephyr.a(assert.c.obj)
     .ARM.attributes
                    0x000002a0       0x30 zephyr/libzephyr.a(reboot.c.obj)
     .ARM.attributes
                    0x000002d0       0x30 zephyr/libzephyr.a(dec.c.obj)
     .ARM.attributes
                    0x00000300       0x30 zephyr/libzephyr.a(hex.c.obj)
     .ARM.attributes
                    0x00000330       0x30 zephyr/libzephyr.a(rb.c.obj)
     .ARM.attributes
                    0x00000360       0x30 zephyr/libzephyr.a(set.c.obj)
     .ARM.attributes
                    0x00000390       0x30 zephyr/libzephyr.a(timeutil.c.obj)
     .ARM.attributes
                    0x000003c0       0x30 zephyr/libzephyr.a(bitarray.c.obj)
     .ARM.attributes
                    0x000003f0       0x30 zephyr/libzephyr.a(bitmask.c.obj)
     .ARM.attributes
                    0x00000420       0x30 zephyr/libzephyr.a(getopt.c.obj)
     .ARM.attributes
                    0x00000450       0x30 zephyr/libzephyr.a(getopt_common.c.obj)
     .ARM.attributes
                    0x00000480       0x30 zephyr/libzephyr.a(onoff.c.obj)
     .ARM.attributes
                    0x000004b0       0x30 zephyr/libzephyr.a(notify.c.obj)
     .ARM.attributes
                    0x000004e0       0x30 zephyr/libzephyr.a(ring_buffer.c.obj)
     .ARM.attributes
                    0x00000510       0x30 zephyr/libzephyr.a(last_section_id.c.obj)
     .ARM.attributes
                    0x00000540       0x30 zephyr/libzephyr.a(configs.c.obj)
     .ARM.attributes
                    0x00000570       0x30 zephyr/libzephyr.a(mem_attr.c.obj)
     .ARM.attributes
                    0x000005a0       0x30 zephyr/libzephyr.a(tracing_none.c.obj)
     .ARM.attributes
                    0x000005d0       0x30 zephyr/libzephyr.a(banner.c.obj)
     .ARM.attributes
                    0x00000600       0x30 zephyr/libzephyr.a(hci_vs_sdc.c.obj)
     .ARM.attributes
                    0x00000630       0x30 zephyr/libzephyr.a(host_extensions.c.obj)
     .ARM.attributes
                    0x00000660       0x30 zephyr/arch/common/libarch__common.a(sw_isr_common.c.obj)
     .ARM.attributes
                    0x00000690       0x30 zephyr/arch/common/libarch__common.a(init.c.obj)
     .ARM.attributes
                    0x000006c0       0x30 zephyr/arch/common/libarch__common.a(xip.c.obj)
     .ARM.attributes
                    0x000006f0       0x30 zephyr/arch/arch/arm/core/libarch__arm__core.a(fatal.c.obj)
     .ARM.attributes
                    0x00000720       0x30 zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi.c.obj)
     .ARM.attributes
                    0x00000750       0x1c zephyr/arch/arch/arm/core/libarch__arm__core.a(nmi_on_reset.S.obj)
     .ARM.attributes
                    0x0000076c       0x30 zephyr/arch/arch/arm/core/libarch__arm__core.a(tls.c.obj)
     .ARM.attributes
                    0x0000079c       0x30 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault.c.obj)
     .ARM.attributes
                    0x000007cc       0x1c zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fault_s.S.obj)
     .ARM.attributes
                    0x000007e8       0x30 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(fpu.c.obj)
     .ARM.attributes
                    0x00000818       0x1c zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(reset.S.obj)
     .ARM.attributes
                    0x00000834       0x30 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(scb.c.obj)
     .ARM.attributes
                    0x00000864       0x1e zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(vector_table.S.obj)
     .ARM.attributes
                    0x00000882       0x1c zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(svc.S.obj)
     .ARM.attributes
                    0x0000089e       0x30 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_manage.c.obj)
     .ARM.attributes
                    0x000008ce       0x30 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(prep_c.c.obj)
     .ARM.attributes
                    0x000008fe       0x30 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread.c.obj)
     .ARM.attributes
                    0x0000092e       0x30 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(cpu_idle.c.obj)
     .ARM.attributes
                    0x0000095e       0x30 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(exc_exit.c.obj)
     .ARM.attributes
                    0x0000098e       0x30 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(thread_abort.c.obj)
     .ARM.attributes
                    0x000009be       0x1c zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(swap_helper.S.obj)
     .ARM.attributes
                    0x000009da       0x30 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(irq_init.c.obj)
     .ARM.attributes
                    0x00000a0a       0x30 zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(isr_wrapper.c.obj)
     .ARM.attributes
                    0x00000a3a       0x1c zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a(__aeabi_read_tp.S.obj)
     .ARM.attributes
                    0x00000a56       0x30 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_core_mpu.c.obj)
     .ARM.attributes
                    0x00000a86       0x30 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .ARM.attributes
                    0x00000ab6       0x30 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu_regions.c.obj)
     .ARM.attributes
                    0x00000ae6       0x30 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(assert.c.obj)
     .ARM.attributes
                    0x00000b16       0x30 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(cbprintf.c.obj)
     .ARM.attributes
                    0x00000b46       0x30 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(chk_fail.c.obj)
     .ARM.attributes
                    0x00000b76       0x30 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(errno_wrap.c.obj)
     .ARM.attributes
                    0x00000ba6       0x30 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(exit.c.obj)
     .ARM.attributes
                    0x00000bd6       0x30 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(locks.c.obj)
     .ARM.attributes
                    0x00000c06       0x30 zephyr/lib/libc/picolibc/liblib__libc__picolibc.a(stdio.c.obj)
     .ARM.attributes
                    0x00000c36       0x30 zephyr/lib/libc/common/liblib__libc__common.a(abort.c.obj)
     .ARM.attributes
                    0x00000c66       0x30 zephyr/lib/libc/common/liblib__libc__common.a(time.c.obj)
     .ARM.attributes
                    0x00000c96       0x30 zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .ARM.attributes
                    0x00000cc6       0x30 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(fnmatch.c.obj)
     .ARM.attributes
                    0x00000cf6       0x30 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getentropy.c.obj)
     .ARM.attributes
                    0x00000d26       0x30 zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a(getopt_shim.c.obj)
     .ARM.attributes
                    0x00000d56       0x30 zephyr/lib/net_buf/liblib__net_buf.a(buf.c.obj)
     .ARM.attributes
                    0x00000d86       0x30 zephyr/lib/net_buf/liblib__net_buf.a(buf_simple.c.obj)
     .ARM.attributes
                    0x00000db6       0x30 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_base_addresses.c.obj)
     .ARM.attributes
                    0x00000de6       0x30 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_binding_headers.c.obj)
     .ARM.attributes
                    0x00000e16       0x30 zephyr/soc/soc/nrf52833/libsoc__nordic.a(validate_enabled_instances.c.obj)
     .ARM.attributes
                    0x00000e46       0x30 zephyr/soc/soc/nrf52833/libsoc__nordic.a(soc.c.obj)
     .ARM.attributes
                    0x00000e76       0x30 zephyr/soc/soc/nrf52833/libsoc__nordic.a(reboot.c.obj)
     .ARM.attributes
                    0x00000ea6       0x30 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gppi_init.c.obj)
     .ARM.attributes
                    0x00000ed6       0x30 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gpiote_nrfx.c.obj)
     .ARM.attributes
                    0x00000f06       0x30 zephyr/subsys/random/libsubsys__random.a(random_entropy_device.c.obj)
     .ARM.attributes
                    0x00000f36       0x30 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(addr.c.obj)
     .ARM.attributes
                    0x00000f66       0x30 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(dummy.c.obj)
     .ARM.attributes
                    0x00000f96       0x30 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(bt_str.c.obj)
     .ARM.attributes
                    0x00000fc6       0x30 zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a(rpa.c.obj)
     .ARM.attributes
                    0x00000ff6       0x30 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .ARM.attributes
                    0x00001026       0x30 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_common.c.obj)
     .ARM.attributes
                    0x00001056       0x30 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .ARM.attributes
                    0x00001086       0x30 zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .ARM.attributes
                    0x000010b6       0x30 zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .ARM.attributes
                    0x000010e6       0x30 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(common.c.obj)
     .ARM.attributes
                    0x00001116       0x30 zephyr/drivers/pinctrl/libdrivers__pinctrl.a(pinctrl_nrf.c.obj)
     .ARM.attributes
                    0x00001146       0x30 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .ARM.attributes
                    0x00001176       0x30 zephyr/drivers/timer/libdrivers__timer.a(sys_clock_init.c.obj)
     .ARM.attributes
                    0x000011a6       0x30 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .ARM.attributes
                    0x000011d6       0x30 modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a(multithreading_lock.c.obj)
     .ARM.attributes
                    0x00001206       0x30 modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a(fatal_error.c.obj)
     .ARM.attributes
                    0x00001236       0x30 modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
     .ARM.attributes
                    0x00001266       0x30 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .ARM.attributes
                    0x00001296       0x30 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
     .ARM.attributes
                    0x000012c6       0x30 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal_wrappers.c.obj)
     .ARM.attributes
                    0x000012f6       0x30 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(crypto.c.obj)
     .ARM.attributes
                    0x00001326       0x30 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .ARM.attributes
                    0x00001356       0x30 modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a(mpsl_fem_api_init.c.obj)
     .ARM.attributes
                    0x00001386       0x30 modules/nrf/subsys/mpsl/hwres/lib..__nrf__subsys__mpsl__hwres.a(mpsl_hwres.c.obj)
     .ARM.attributes
                    0x000013b6       0x30 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
     .ARM.attributes
                    0x000013e6       0x30 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(system_nrf52833.c.obj)
     .ARM.attributes
                    0x00001416       0x30 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_glue.c.obj)
     .ARM.attributes
                    0x00001446       0x30 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_flag32_allocator.c.obj)
     .ARM.attributes
                    0x00001476       0x30 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_ram_ctrl.c.obj)
     .ARM.attributes
                    0x000014a6       0x30 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .ARM.attributes
                    0x000014d6       0x30 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gpiote.c.obj)
     .ARM.attributes
                    0x00001506       0x30 zephyr/kernel/libkernel.a(busy_wait.c.obj)
     .ARM.attributes
                    0x00001536       0x30 zephyr/kernel/libkernel.a(device.c.obj)
     .ARM.attributes
                    0x00001566       0x30 zephyr/kernel/libkernel.a(fatal.c.obj)
     .ARM.attributes
                    0x00001596       0x30 zephyr/kernel/libkernel.a(init.c.obj)
     .ARM.attributes
                    0x000015c6       0x30 zephyr/kernel/libkernel.a(kheap.c.obj)
     .ARM.attributes
                    0x000015f6       0x30 zephyr/kernel/libkernel.a(idle.c.obj)
     .ARM.attributes
                    0x00001626       0x30 zephyr/kernel/libkernel.a(mutex.c.obj)
     .ARM.attributes
                    0x00001656       0x30 zephyr/kernel/libkernel.a(queue.c.obj)
     .ARM.attributes
                    0x00001686       0x30 zephyr/kernel/libkernel.a(sem.c.obj)
     .ARM.attributes
                    0x000016b6       0x30 zephyr/kernel/libkernel.a(work.c.obj)
     .ARM.attributes
                    0x000016e6       0x30 zephyr/kernel/libkernel.a(thread.c.obj)
     .ARM.attributes
                    0x00001716       0x30 zephyr/kernel/libkernel.a(sched.c.obj)
     .ARM.attributes
                    0x00001746       0x30 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .ARM.attributes
                    0x00001776       0x30 zephyr/kernel/libkernel.a(spinlock_validate.c.obj)
     .ARM.attributes
                    0x000017a6       0x30 zephyr/kernel/libkernel.a(timeout.c.obj)
     .ARM.attributes
                    0x000017d6       0x30 zephyr/kernel/libkernel.a(mempool.c.obj)
     .ARM.attributes
                    0x00001806       0x30 zephyr/kernel/libkernel.a(banner.c.obj)
     .ARM.attributes
                    0x00001836       0x30 zephyr/kernel/libkernel.a(system_work_q.c.obj)
     .ARM.attributes
                    0x00001866       0x2e /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .ARM.attributes
                    0x00001894       0x2e /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     .ARM.attributes
                    0x000018c2       0x2c /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
     .ARM.attributes
                    0x000018ee       0x1c /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(strcmp.S.o)
     .ARM.attributes
                    0x0000190a       0x1c /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(strcpy.S.o)
     .ARM.attributes
                    0x00001926       0x32 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(memcpy.c.o)
     .ARM.attributes
                    0x00001958       0x32 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(memset.c.o)
     .ARM.attributes
                    0x0000198a       0x17 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(strlen.S.o)
     .ARM.attributes
                    0x000019a1       0x32 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_errno_errno.c.o)
     .ARM.attributes
                    0x000019d3       0x32 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_memcmp.c.o)
     .ARM.attributes
                    0x00001a05       0x32 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_strchr.c.o)
     .ARM.attributes
                    0x00001a37       0x32 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_strncpy.c.o)
     .ARM.attributes
                    0x00001a69       0x32 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_string_strnlen.c.o)
     .ARM.attributes
                    0x00001a9b       0x32 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_puts.c.o)
     .ARM.attributes
                    0x00001acd       0x32 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_snprintf.c.o)
     .ARM.attributes
                    0x00001aff       0x32 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflprintf.c.o)
     .ARM.attributes
                    0x00001b31       0x32 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_vflscanf.c.o)
     .ARM.attributes
                    0x00001b63       0x32 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_fgetc.c.o)
     .ARM.attributes
                    0x00001b95       0x32 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_filestrput.c.o)
     .ARM.attributes
                    0x00001bc7       0x32 /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/lib/thumb/v7e-m/nofp/space/libc.a(libc_tinystdio_ungetc.c.o)
     .ARM.attributes
                    0x00001bf9       0x1e /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_muldf3.o)
     .ARM.attributes
                    0x00001c17       0x1e /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_addsubdf3.o)
     .ARM.attributes
                    0x00001c35       0x1e /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_muldivdf3.o)
     .ARM.attributes
                    0x00001c53       0x1e /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_truncdfsf2.o)
     .ARM.attributes
                    0x00001c71       0x1e /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_cmpsf2.o)
     .ARM.attributes
                    0x00001c8f       0x1e /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_aeabi_ldivmod.o)
     .ARM.attributes
                    0x00001cad       0x1e /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_aeabi_uldivmod.o)
     .ARM.attributes
                    0x00001ccb       0x2e /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_popcountsi2.o)
     .ARM.attributes
                    0x00001cf9       0x2e /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_fixdfdi.o)
     .ARM.attributes
                    0x00001d27       0x2e /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_fixunsdfdi.o)
     .ARM.attributes
                    0x00001d55       0x2e /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_udivmoddi4.o)
     .ARM.attributes
                    0x00001d83       0x1e /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_dvmd_tls.o)
     .ARM.attributes
                    0x00001da1       0x1e /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_cmpdf2.o)
     .ARM.attributes
                    0x00001dbf       0x1e /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/thumb/v7e-m/nofp/space/libgcc.a(_arm_fixunsdfsi.o)
     *(SORT_BY_ALIGNMENT(.gnu.attributes))
    .last_section   0x00024008        0x4
     *(SORT_BY_ALIGNMENT(.last_section))
     .last_section  0x00024008        0x4 zephyr/libzephyr.a(last_section_id.c.obj)
                    0x0002400c                        _flash_used = ((LOADADDR (.last_section) + SIZEOF (.last_section)) - __rom_region_start)
    bss             0x20000238     0x2784
                    0x20000238                        . = ALIGN (0x4)
                    0x20000238                        __bss_start = .
                    0x20000238                        __kernel_ram_start = .
     *(SORT_BY_ALIGNMENT(.bss))
     .bss           0x20000238      0xaf4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
                    0x20000d28                sym_WEP6LVHDNU4MKN3X4XQZD6HHTMCDF6RCIN44MJY
     *fill*         0x20000d2c        0x4
     .bss           0x20000d30       0xc8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20000df8      0x224 /workspaces/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
                    0x20000fa8                sym_7LBMAA24CEDVERJKWG7WPIWVTH77M4INOWT5F3I
                    0x20000fac                sym_HNGMT5WXUZEPGIYV5R25JUTTXYGTBKOTZQ4VH6Q
     .bss           0x2000101c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001020        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001024        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001028        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x2000102c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001030        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001034        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001038        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x2000103c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001040        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001044        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001048        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x2000104c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001050        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001054        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001058        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x2000105c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001060        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001064        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001068        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x2000106c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001070        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001074        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001078        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x2000107c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001080        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001084        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001088        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x2000108c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001090        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001094        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001098        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x2000109c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200010a0        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200010a4        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200010a8      0x100 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200011a8      0x100 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200012a8      0x100 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200013a8      0x100 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200014a8        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200014ac        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200014b0        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200014b4        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200014b8        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200014bc        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200014c0       0x10 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200014d0        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200014d4        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200014d8        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200014dc        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200014e0        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200014e4        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200014e8        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200014ec        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200014f4        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x200014fc        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001504        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001508        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001510        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001518        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001520        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001524        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001528        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x2000152c        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001534        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001538        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x2000153c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001540        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001544        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001548        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x2000154c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001550        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001554        0x8 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x2000155c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001560        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001564        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001568        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x2000156c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001570        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001574        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001578        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x2000157c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001580        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001584        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001588        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x2000158c        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001590        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001594        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x20001598        0x4 /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     .bss           0x2000159c       0x11 /workspaces/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a(libmpsl_fem_common_debug_soft__obfuscated.elf)
     *fill*         0x200015ad        0x1
     .bss           0x200015ae        0xc /workspaces/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_multirole.a(libsoftdevice_controller_s140_debug_soft__obfuscated.elf)
     *(SORT_BY_ALIGNMENT(.bss.*))
     *fill*         0x200015ba        0x6
     .bss.cc_data   0x200015c0       0x10 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .bss.last_count
                    0x200015d0        0x8 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .bss.anchor    0x200015d8        0x8 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .bss.sdc_mempool
                    0x200015e0      0xd6b modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     *fill*         0x2000234b        0x5
     .bss.mpsl_work_q
                    0x20002350       0xa0 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
                    0x20002350                mpsl_work_q
     .bss.z_idle_threads
                    0x200023f0       0x80 zephyr/kernel/libkernel.a(init.c.obj)
                    0x200023f0                z_idle_threads
     .bss.z_main_thread
                    0x20002470       0x80 zephyr/kernel/libkernel.a(init.c.obj)
                    0x20002470                z_main_thread
     .bss._thread_dummy
                    0x200024f0       0x80 zephyr/kernel/libkernel.a(sched.c.obj)
                    0x200024f0                _thread_dummy
     .bss.slice_timeouts
                    0x20002570       0x18 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .bss.curr_tick
                    0x20002588        0x8 zephyr/kernel/libkernel.a(timeout.c.obj)
     .bss.k_sys_work_q
                    0x20002590       0xa0 zephyr/kernel/libkernel.a(system_work_q.c.obj)
                    0x20002590                k_sys_work_q
     .bss.z_arm_tls_ptr
                    0x20002630        0x4 zephyr/arch/arch/arm/core/libarch__arm__core.a(tls.c.obj)
                    0x20002630                z_arm_tls_ptr
     .bss.dynamic_regions.0
                    0x20002634        0xc zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_core_mpu.c.obj)
     .bss.z_malloc_heap
                    0x20002640        0xc zephyr/lib/libc/common/liblib__libc__common.a(malloc.c.obj)
     .bss.gppi_instance.0
                    0x2000264c        0x8 zephyr/soc/soc/nrf52833/libsoc__nordic.a(gppi_init.c.obj)
     .bss.buf_rx_freed_cb
                    0x20002654        0x4 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .bss.raw_rx    0x20002658        0x4 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .bss.cli.1     0x2000265c       0x10 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .bss.on.2      0x2000266c        0x4 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .bss.data      0x20002670       0x58 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .bss.hfclk_users
                    0x200026c8        0x4 zephyr/drivers/clock_control/libdrivers__clock_control.a(clock_control_nrf.c.obj)
     .bss.entropy_nrf5_data
                    0x200026cc       0x44 zephyr/drivers/entropy/libdrivers__entropy.a(entropy_nrf5.c.obj)
     .bss.gpio_nrfx_p1_data
                    0x20002710        0xc zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .bss.gpio_nrfx_p0_data
                    0x2000271c        0xc zephyr/drivers/gpio/libdrivers__gpio.a(gpio_nrfx.c.obj)
     .bss.force_isr_mask
                    0x20002728        0x4 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .bss.int_mask  0x2000272c        0x4 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .bss.overflow_cnt
                    0x20002730        0x4 zephyr/drivers/timer/libdrivers__timer.a(nrf_rtc_timer.c.obj)
     .bss.data_0    0x20002734        0x4 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .bss.receive_work
                    0x20002738       0x10 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .bss.user_cmd_handler
                    0x20002748        0x4 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
     .bss.mpsl_low_prio_work
                    0x2000274c       0x10 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .bss.event_handler
                    0x2000275c        0x4 modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a(nrfx_clock_mpsl.c.obj)
     .bss.p_gppi    0x20002760        0x4 modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a(nrfx_gppi_ppi.c.obj)
     .bss._kernel   0x20002764       0x20 zephyr/kernel/libkernel.a(init.c.obj)
                    0x20002764                _kernel
     .bss.lock      0x20002784        0x4 zephyr/kernel/libkernel.a(mutex.c.obj)
     .bss.lock      0x20002788        0x4 zephyr/kernel/libkernel.a(sem.c.obj)
     .bss.pending_cancels
                    0x2000278c        0x8 zephyr/kernel/libkernel.a(work.c.obj)
     .bss.lock      0x20002794        0x4 zephyr/kernel/libkernel.a(work.c.obj)
     .bss._sched_spinlock
                    0x20002798        0x4 zephyr/kernel/libkernel.a(sched.c.obj)
                    0x20002798                _sched_spinlock
     .bss.pending_current
                    0x2000279c        0x4 zephyr/kernel/libkernel.a(timeslicing.c.obj)
                    0x2000279c                pending_current
     .bss.slice_max_prio
                    0x200027a0        0x4 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     .bss.announce_remaining
                    0x200027a4        0x4 zephyr/kernel/libkernel.a(timeout.c.obj)
     .bss.timeout_lock
                    0x200027a8        0x4 zephyr/kernel/libkernel.a(timeout.c.obj)
     .bss.static_regions_num
                    0x200027ac        0x1 zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a(arm_mpu.c.obj)
     .bss.uarte0_poll_in_byte
                    0x200027ad        0x1 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .bss.uarte0_poll_out_byte
                    0x200027ae        0x1 zephyr/drivers/serial/libdrivers__serial.a(uart_nrfx_uarte.c.obj)
     .bss.dtm_hci_parameters
                    0x200027af        0x5 modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a(dtm_twowire_to_hci.c.obj)
                    0x200027af                dtm_hci_parameters
     .bss.rx_hci_msg
                    0x200027b4      0x103 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj)
     .bss.cmd_complete_or_status
                    0x200028b7      0x103 modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_internal.c.obj)
     .bss.z_sys_post_kernel
                    0x200029ba        0x1 zephyr/kernel/libkernel.a(init.c.obj)
                    0x200029ba                z_sys_post_kernel
     .bss.slice_expired
                    0x200029bb        0x1 zephyr/kernel/libkernel.a(timeslicing.c.obj)
     *(SORT_BY_ALIGNMENT(COMMON))
     *(SORT_BY_ALIGNMENT(.kernel_bss.*))
                    0x200029bc                        __bss_end = ALIGN (0x4)
    noinit          0x200029c0     0x33b8
     *(SORT_BY_ALIGNMENT(.noinit))
     *(SORT_BY_ALIGNMENT(.noinit.*))
     .noinit.WEST_TOPDIR/nrf/subsys/mpsl/init/mpsl_init.c.0
                    0x200029c0      0x440 modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a(mpsl_init.c.obj)
     .noinit.WEST_TOPDIR/zephyr/kernel/init.c.2
                    0x20002e00      0x840 zephyr/kernel/libkernel.a(init.c.obj)
                    0x20002e00                z_interrupt_stacks
     .noinit.WEST_TOPDIR/zephyr/kernel/init.c.1
                    0x20003640      0x180 zephyr/kernel/libkernel.a(init.c.obj)
     .noinit.WEST_TOPDIR/zephyr/kernel/init.c.0
                    0x200037c0      0x4c0 zephyr/kernel/libkernel.a(init.c.obj)
                    0x200037c0                z_main_stack
     .noinit.WEST_TOPDIR/zephyr/kernel/system_work_q.c.0
                    0x20003c80      0x840 zephyr/kernel/libkernel.a(system_work_q.c.obj)
     .noinit.WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_raw.c.5
                    0x200044c0       0xe0 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .noinit.WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_raw.c.4
                    0x200045a0       0xa8 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .noinit.WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_raw.c.3
                    0x20004648      0xb21 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     *fill*         0x20005169        0x3
     .noinit.WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_raw.c.2
                    0x2000516c      0x108 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .noinit.WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_raw.c.1
                    0x20005274      0xa14 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
     .noinit.WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_raw.c.0
                    0x20005c88       0xf0 zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_raw.c.obj)
                    0x20020000                        __kernel_ram_end = 0x20020000
                    0x0001fdc8                        __kernel_ram_size = (__kernel_ram_end - __kernel_ram_start)
    .last_ram_section
                    0x20005d78        0x0
                    0x20005d78                        _image_ram_end = .
                    0x00005d78                        _image_ram_size = (_image_ram_end - _image_ram_start)
                    0x20005d78                        _end = .
                    0x20005d78                        z_mapped_end = .
    OUTPUT(zephyr/zephyr.elf elf32-littlearm)
    LOAD linker stubs
    build.log:
    -- west build: making build dir /workspaces/client-fw-dtm/build/dtm pristine
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: /opt/ncs-toolchain/usr/local/bin/python3.12 (found suitable version "3.12.4", minimum required is "3.12") found components: Interpreter
    -- Cache files will be written to: /home/dev/.cache/zephyr
    -- Found west (found suitable version "1.5.0", minimum required is "0.14.0")
    -- Board: client_sensor, qualifiers: nrf52833
    Parsing /workspaces/client-fw-dtm/apps/dtm/Kconfig.sysbuild
    Loaded configuration '/workspaces/client-fw-dtm/build/dtm/_sysbuild/empty.conf'
    Merged configuration '/workspaces/client-fw-dtm/build/dtm/_sysbuild/empty.conf'
    Configuration saved to '/workspaces/client-fw-dtm/build/dtm/zephyr/.config'
    Kconfig header saved to '/workspaces/client-fw-dtm/build/dtm/_sysbuild/autoconf.h'
       * Running CMake for dtm *
    -- Application: /workspaces/client-fw-dtm/apps/dtm
    -- CMake version: 4.2.1
    -- Zephyr version: 4.4.0 (/workspaces/zephyr)
    -- Found host-tools: zephyr 1.0.1 (/opt/ncs-toolchain/opt/zephyr-sdk)
    -- Found toolchain: zephyr 1.0.1 (/opt/ncs-toolchain/opt/zephyr-sdk)
    -- Found Dtc: /opt/ncs-toolchain/usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6")
    -- Found BOARD.dts: /workspaces/client-fw-dtm/apps/dtm/boards/lx/client_sensor/client_sensor_nrf52833.dts
    -- Generated zephyr.dts: /workspaces/client-fw-dtm/build/dtm/dtm/zephyr/zephyr.dts
    -- Generated pickled edt: /workspaces/client-fw-dtm/build/dtm/dtm/zephyr/edt.pickle
    -- Generated devicetree_generated.h: /workspaces/client-fw-dtm/build/dtm/dtm/zephyr/include/generated/zephyr/devicetree_generated.h
    Loaded configuration '/workspaces/client-fw-dtm/apps/dtm/boards/lx/client_sensor/client_sensor_nrf52833_defconfig'
    Merged configuration '/workspaces/client-fw-dtm/apps/dtm/prj.conf'
    Merged configuration '/workspaces/client-fw-dtm/build/dtm/dtm/zephyr/.config.sysbuild'
    Configuration saved to '/workspaces/client-fw-dtm/build/dtm/dtm/zephyr/.config'
    Kconfig header saved to '/workspaces/client-fw-dtm/build/dtm/dtm/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: /opt/nordic/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.43.1")
    -- The C compiler identification is GNU 14.3.0
    -- The CXX compiler identification is GNU 14.3.0
    -- Found assembler: /opt/ncs-toolchain/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    -- Using ccache: /opt/ncs-toolchain/usr/bin/ccache
    -- Found gen_kobject_list: /workspaces/zephyr/scripts/build/gen_kobject_list.py
    CMake Warning at /workspaces/zephyr/CMakeLists.txt:2358 (message):
    -- Configuring done (9.9s)
    -- Generating done (0.3s)
    -- Build files have been written to: /workspaces/client-fw-dtm/build/dtm/dtm
    -- Configuring done (15.5s)
    -- Generating done (0.0s)
    [1/8] Creating directories for 'dtm'
    [2/8] No download step for 'dtm'
    [3/8] No update step for 'dtm'
    [4/8] No patch step for 'dtm'
    [5/8] No configure step for 'dtm'
    [5/8] Performing build step for 'dtm'
    [1/197] Preparing syscall dependency handling
    [2/197] Generating ../../zephyr/include/generated/zephyr_commit.h
    [3/197] Generating ../../zephyr/include/generated/ncs_commit.h
    [4/197] Generating misc/generated/syscalls_subdirs.trigger
    [5/197] Generating ../../zephyr/include/generated/ncs_version.h
    [6/197] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.4.0 (/workspaces/zephyr), build: ncs-v3.4.0-rc1-258-gb8e6b9b3ed1f
    [7/197] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [8/197] Generating include/generated/device-api-sections.ld, include/generated/device-api-sections.cmake
    [9/197] Generating include/generated/zephyr/syscall_dispatch.c, include/generated/zephyr/syscall_exports_llext.c, syscall_weakdefs_llext.c, include/generated/zephyr/syscall_list.h
    [10/197] Generating include/generated/zephyr/kobj-types-enum.h, include/generated/zephyr/otype-to-str.h, include/generated/zephyr/otype-to-size.h
    [11/197] Generating include/generated/zephyr/driver-validation.h
    [12/197] Building C object zephyr/lib/heap/CMakeFiles/heap_constants.dir/heap_constants.c.obj
    [13/197] Generating ../../include/generated/zephyr/heap_constants.h
    [14/197] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [15/197] Generating include/generated/zephyr/offsets.h
    [16/197] Building C object CMakeFiles/app.dir/src/main.c.obj
    [17/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/heap/heap.c.obj
    [18/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/libc/validate_libc.c.obj
    [19/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [20/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [21/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [22/197] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [23/197] Building C object CMakeFiles/app.dir/src/dtm_twowire_transport.c.obj
    [24/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/clock.c.obj
    [25/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [26/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [27/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/dec.c.obj
    [28/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/hex.c.obj
    [29/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/rb.c.obj
    [30/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [31/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [32/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/set.c.obj
    [33/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/timeutil.c.obj
    [34/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitarray.c.obj
    [35/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitmask.c.obj
    [36/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/getopt/getopt.c.obj
    [37/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/notify.c.obj
    [38/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/ring_buffer.c.obj
    [39/197] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [40/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/onoff.c.obj
    [41/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/last_section_id.c.obj
    [42/197] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/mem_mgmt/mem_attr.c.obj
    [43/197] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [44/197] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/getopt/getopt_common.c.obj
    [45/197] Building C object zephyr/CMakeFiles/zephyr.dir/workspaces/nrf/lib/boot_banner/banner.c.obj
    [46/197] Building C object zephyr/CMakeFiles/zephyr.dir/workspaces/nrf/subsys/bluetooth/host_extensions/host_extensions.c.obj
    [47/197] Building C object zephyr/CMakeFiles/zephyr.dir/workspaces/nrf/subsys/bluetooth/hci_vs_sdc.c.obj
    [48/197] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [49/197] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/init.c.obj
    [50/197] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/xip.c.obj
    [51/197] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/fatal.c.obj
    [52/197] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi.c.obj
    [53/197] Building ASM object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi_on_reset.S.obj
    [54/197] Linking C static library zephyr/arch/common/libisr_tables.a
    [55/197] Building C object zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/tls.c.obj
    [56/197] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault.c.obj
    [57/197] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.S.obj
    [58/197] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fpu.c.obj
    [59/197] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.obj
    [60/197] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/scb.c.obj
    [61/197] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/vector_table.S.obj
    [62/197] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/svc.S.obj
    [63/197] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/prep_c.c.obj
    [64/197] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_manage.c.obj
    [65/197] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread.c.obj
    [66/197] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_idle.c.obj
    [67/197] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread_abort.c.obj
    [68/197] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c.obj
    [69/197] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/swap_helper.S.obj
    [70/197] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_init.c.obj
    [71/197] Building ASM object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/__aeabi_read_tp.S.obj
    [72/197] Building C object zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/isr_wrapper.c.obj
    [73/197] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_core_mpu.c.obj
    [74/197] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu.c.obj
    [75/197] Building C object zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu_regions.c.obj
    [76/197] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/assert.c.obj
    [77/197] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/cbprintf.c.obj
    [78/197] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/chk_fail.c.obj
    [79/197] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/errno_wrap.c.obj
    [80/197] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/exit.c.obj
    [81/197] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/time/time.c.obj
    [82/197] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/locks.c.obj
    [83/197] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/stdio.c.obj
    [84/197] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abort.c.obj
    [85/197] Building C object zephyr/lib/posix/c_lib_ext/CMakeFiles/lib__posix__c_lib_ext.dir/fnmatch.c.obj
    [86/197] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj
    [87/197] Building C object zephyr/lib/posix/c_lib_ext/CMakeFiles/lib__posix__c_lib_ext.dir/getopt_shim.c.obj
    [88/197] Building C object zephyr/lib/posix/c_lib_ext/CMakeFiles/lib__posix__c_lib_ext.dir/getentropy.c.obj
    [89/197] Building C object zephyr/lib/net_buf/CMakeFiles/lib__net_buf.dir/buf_simple.c.obj
    [90/197] Building C object zephyr/soc/soc/nrf52833/CMakeFiles/soc__nordic.dir/validate_base_addresses.c.obj
    [91/197] Building C object zephyr/soc/soc/nrf52833/CMakeFiles/soc__nordic.dir/validate_binding_headers.c.obj
    [92/197] Building C object zephyr/soc/soc/nrf52833/CMakeFiles/soc__nordic.dir/validate_enabled_instances.c.obj
    [93/197] Building C object zephyr/lib/net_buf/CMakeFiles/lib__net_buf.dir/buf.c.obj
    [94/197] Building C object zephyr/soc/soc/nrf52833/CMakeFiles/soc__nordic.dir/nrf52/soc.c.obj
    [95/197] Building C object zephyr/soc/soc/nrf52833/CMakeFiles/soc__nordic.dir/common/gppi_init.c.obj
    [96/197] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/addr.c.obj
    [97/197] Building C object zephyr/soc/soc/nrf52833/CMakeFiles/soc__nordic.dir/common/reboot.c.obj
    [98/197] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/random_entropy_device.c.obj
    [99/197] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/dummy.c.obj
    [100/197] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/bt_str.c.obj
    [101/197] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/rpa.c.obj
    [102/197] Building C object zephyr/soc/soc/nrf52833/CMakeFiles/soc__nordic.dir/common/gpiote_nrfx.c.obj
    [103/197] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_raw.c.obj
    [104/197] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_common.c.obj
    [105/197] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [106/197] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_nrf5.c.obj
    [107/197] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [108/197] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [109/197] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [110/197] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [111/197] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [112/197] Building C object modules/nrf/lib/multithreading_lock/CMakeFiles/..__nrf__lib__multithreading_lock.dir/multithreading_lock.c.obj
    [113/197] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [114/197] Generating linker_zephyr_pre0.cmd
    [115/197] Building C object modules/nrf/lib/dtm_twowire/CMakeFiles/..__nrf__lib__dtm_twowire.dir/dtm_twowire_to_hci.c.obj
    [116/197] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/nrfx.dir/nrfx_glue.c.obj
    [117/197] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [118/197] Building C object modules/nrf/subsys/mpsl/fem/CMakeFiles/..__nrf__subsys__mpsl__fem.dir/api_init/mpsl_fem_api_init.c.obj
    [119/197] Building C object modules/nrf/subsys/mpsl/hwres/CMakeFiles/..__nrf__subsys__mpsl__hwres.dir/mpsl_hwres.c.obj
    [120/197] Building C object modules/nrf/drivers/mpsl/clock_control/CMakeFiles/..__nrf__drivers__mpsl__clock_control.dir/nrfx_clock_mpsl.c.obj
    [121/197] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/nrfx.dir/workspaces/modules/hal/nordic/nrfx/bsp/stable/mdk/nrf52/nrf52833/system_nrf52833.c.obj
    [122/197] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_driver.c.obj
    [123/197] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_internal_wrappers.c.obj
    [124/197] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/crypto.c.obj
    [125/197] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/nrfx.dir/workspaces/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
    [126/197] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_internal.c.obj
    [127/197] Building C object modules/nrf/subsys/mpsl/init/CMakeFiles/subsys__mpsl__init.dir/mpsl_init.c.obj
    [128/197] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/nrfx.dir/workspaces/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [129/197] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/nrfx.dir/workspaces/modules/hal/nordic/nrfx/helpers/nrfx_gppi_ppi.c.obj
    [130/197] Building C object modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/nrfx.dir/workspaces/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [131/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [132/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [133/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
    [134/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [135/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [136/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [137/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [138/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [139/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [140/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [141/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [142/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [143/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [144/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [145/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/float.c.obj
    [146/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [147/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [148/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [149/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [150/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [151/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [152/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [153/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [154/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeslicing.c.obj
    [155/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipe.c.obj
    [156/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/spinlock_validate.c.obj
    [157/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [158/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [159/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [160/197] Building C object zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj
    [161/197] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [162/197] Linking C static library zephyr/arch/common/libarch__common.a
    [163/197] Linking C static library app/libapp.a
    [164/197] Linking C static library zephyr/lib/libc/common/liblib__libc__common.a
    [165/197] Linking C static library zephyr/arch/arch/arm/core/libarch__arm__core.a
    [166/197] Linking C static library zephyr/lib/posix/c_lib_ext/liblib__posix__c_lib_ext.a
    [167/197] Linking C static library zephyr/lib/net_buf/liblib__net_buf.a
    [168/197] Linking C static library zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a
    [169/197] Linking C static library zephyr/soc/soc/nrf52833/libsoc__nordic.a
    [170/197] Linking C static library zephyr/subsys/random/libsubsys__random.a
    [171/197] Linking C static library zephyr/lib/libc/picolibc/liblib__libc__picolibc.a
    [172/197] Linking C static library zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a
    [173/197] Linking C static library zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a
    [174/197] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
    [175/197] Linking C static library zephyr/drivers/entropy/libdrivers__entropy.a
    [176/197] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
    [177/197] Linking C static library zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a
    [178/197] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
    [179/197] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
    [180/197] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
    [181/197] Linking C static library modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a
    [182/197] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
    [183/197] Linking C static library zephyr/libzephyr.a
    [184/197] Linking C static library modules/nrf/lib/dtm_twowire/lib..__nrf__lib__dtm_twowire.a
    [185/197] Linking C static library modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a
    [186/197] Linking C static library modules/nrf/subsys/mpsl/init/libsubsys__mpsl__init.a
    [187/197] Linking C static library modules/nrf/subsys/mpsl/hwres/lib..__nrf__subsys__mpsl__hwres.a
    [188/197] Linking C static library modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a
    [189/197] Linking C static library modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a
    [190/197] Linking C static library modules/hal_nordic/modules/hal_nordic/nrfx/libnrfx.a
    [191/197] Linking C static library zephyr/kernel/libkernel.a
    [192/197] Linking C executable zephyr/zephyr_pre0.elf; Logical command for additional byproducts on target: zephyr_pre0
    [193/197] Generating linker.cmd
    [194/197] Generating isr_tables.c, isr_tables_vt.ld, isr_tables_swi.ld
    [195/197] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [196/197] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [197/197] Linking C executable zephyr/zephyr.elf
               FLASH:      147468 B       512 KB     28.13%
                 RAM:       23928 B       128 KB     18.26%
            IDT_LIST:           0 B        32 KB      0.00%
    Generating files from /workspaces/client-fw-dtm/build/dtm/dtm/zephyr/zephyr.elf for board: client_sensor/nrf52833
    [7/8] No install step for 'dtm'
    [8/8] Completed 'dtm'
    Sergei
