Unexplained current spikes during sleep
I am trying to track down the source of unexplained current spikes visible on the Power Profiler Kit 2 when the nRF52832 should be in sleep mode.
I have stripped the project down to as bare bones as possible (see below) and tried every possible solution from Google's AI (most of which were hallucinations...) to no avail.
 #include <zephyr/kernel.h>
int main(void) {
	for(unsigned int i = 0; i < 2000; i++) {
		k_msleep(1);
	for(;;) {
		const unsigned int width = 250;
		k_msleep(5 * 1000 - width);
		for(unsigned int i = 0; i < width; i++) {
			k_msleep(1);
# prj.conf
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_BT=n
CONFIG_CLOCK_CONTROL=y
CONFIG_LOG=n
CONFIG_MCUMGR=n
CONFIG_PM_DEVICE=y
CONFIG_SERIAL=n
CONFIG_TICKLESS_KERNEL=y
CONFIG_TIMESLICING=n
CONFIG_UART_CONSOLE=n
CONFIG_WATCHDOG=n
CONFIG_SHELL=n
I am building using v3.2.3 of the SDK using the nRF Connect extension in VS Code
I'm using a custom board that does _NOT_ exhibit these spikes when using code built using v2.5.x of the SDK (not a hardware problem!!!)
The board uses an external crystal for the 32.768 kHz
PPK2 capture
Things I've already tried:
  • PPK2 is in "source" mode, no other connections to the board (including completely disconnecting the JTAG cable)
  • power cycling the board after programming and before capturing the plot of current
  • disabling all 20 PPI channels at the start of main (no effect on most, one actually causes the k_sleep to never wake up...)
  • stopping all 3 timers at the start of main
  • removing all mentions of peripherals (I2C, SPI, PWM, etc.) from the C code, prj.conf, and board files
  • switching from the DC/DC regulator to the LDO (again, same hardware does not show the problem with older SDKs!)
  • using the debugger to look for unexpected threads or IRQs
  • adding special code to main() to differentiate between legitimate wake behavior (and code resets) and the unexpected wakeups - the legit ones are the "fat" ones.
    The spikes are actually expected. They are caused by a fix for a potential HW bug concerning RTC bit corruption in the nRF52832:
    For nRF52832, the default RTC bit width is 15 instead of 24. This is related to some RTC bits being possibly corrupted. This could be overridden by changing CONFIG_NRF_RTC_COUNTER_BIT_WIDTH, but the Kconfig is not user-selectable intentionally, counter’s oldest bits may not work properly.
    For the default bit width of 15 and RTC prescaler of 0, the counter wrapping happens every 1s. At the same time, RTC driver’s logic limits scheduling to half of counter span because of uint math. Hence, the CPU is awake every 0.5s. The shorter intervals seem like an offset of the one set in main.c, which is in different phase from the steady 0.5s driver’s intervals.
    And if we consider that the spikes are smaller than what they seem (due to the PPK2 switching range) the price to pay for that fix is still quite small and reasonable.
    Simon
  • Huh. That's unfortunate, but I suppose better to have a fix than the risk of the RTC not functioning properly.
    Is it known whether this same bug affects other controllers (e.g. nRF52840)?
    If I recall correctly, I tried to run the application on multiple other MCUs (nRF54L15, nRF52840, ...), and it only happened on the nRF52DK, so I would guess it only happens on the nRF52832 (probably also on nRF52810, nRF52805 as they are based on the same silicon).
    And as you put the nRF52840 as an example, I just re-tried on the nRF52840 DK just to be sure, and I don't see any spikes.
    Simon
